RV1206FR-077M5L
RV1206FR-077M5L
    YAGEO(国巨)
    贴片电阻 1206 7.5MΩ ±1% 1/4W ±200ppm/℃
RV1206FR-077M5L 数据手册
DATA SHEET HIGH VOLTAGE CHIP RESISTORS RV series 0.5%, 1%, 5% sizes 0603/0805/1206/2010/2512 RoHS compliant IEC 62368-1 Safety Certificate issued by UL Demko: Product specification – November 13, 2018 V.8 sizes 0603/0805/1206 Product specification Chip Resistor Surface Mount RV 0603/0805/1206/2010/2512 (RoHS Compliant) SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes RV0603/0805/1206/2010/2512 high voltage chip resistors with lead-free terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) APPLICATIONS  Converter  Printer equipment  Battery charger  Computer  Power supply  Car electronics FEATURES  AEC-Q200 qualified for 47ohm        ≤ R< 5Mohm RoHS compliant Reducing environmentally hazardous wastes High component and equipment reliability Non-forbidden materials used in products/production Halogen Free Epoxy Moisture sensitivity level: MSL 1 IEC 62368-1:2014 safety certificate (G.10.2) issued by UL Demko for the following sizes and resistance ranges: 9 RV XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0603/0805/1206/2010/2512 (2) TOLERANCE D = ± 0.5% F = ± 1% J = ± 5% (3) PACKAGING TYPE R = Paper/PE taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (5) TAPING REEL 07= 7 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed resistance rules show in table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is system default code for ordering only (Note) - 0603: 100KΩ to 10MΩ - 0805: 100KΩ to 22MΩ - 1206: 100KΩ to 27MΩ *Please refer to UL certification 2 Resistance rule of global part number Resistance code rule Example XXKX (10 to 97.6 KΩ) 10K = 10,000 Ω 97K6 = 97,600 Ω XXXK (100 to 976 KΩ) 100K = 100,000Ω 976K = 976,000Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76 = 9,760,000 Ω XXMX (10 to 16 MΩ) 10M = 10,000,000 Ω 27M = 27,000,000 Ω ORDERING EXAMPLE The ordering code of a RV1206 chip resistor, value 1 MΩ with ± 5% tolerance, supplied in 7-inch tape reel is: RV1206JR-071ML. NOTE 1. All our R-Chip products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Nov. 13, 2018 V.8 Product specification Chip Resistor Surface Mount RV SERIES 3 9 0603/0805/1206/2010/2512 (RoHS Compliant) PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER (PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2322 XXX XXXXX L (1) SIZE TYPE (2) (3) Last digit of 12NC Resistance decade (3) (4) START TOL. RESISTANCE IN (1) (%) RANGE Last digit EMBOSSED (2) PAPER/PE (2) TAPE ON REEL TAPE ON REEL (units) 0.01 to 0.0976 Ω 0 0.1 to 0.976 Ω 4,000 7 1 to 9.76 Ω 8 10 to 97.6 Ω 9 100 to 976 Ω 1 1 to 9.76 KΩ 2 10 to 97.6 KΩ 3 100 to 976 KΩ 4 1 to 9.76 MΩ 5 10 to 97.6 MΩ 6 5,000 0805 VRC11 2322 ± 5% 47 to 10M Ω - 792 61xxx VRC12 2322 ± 1% 47 to 10M Ω - 793 6xxxx 1206 VRC01 2322 ± 5% 47 to 27M Ω - 790 61xxx VRC02 2322 ± 1% 47 to 10M Ω - 791 6xxxx 2512 VPRC221 2322 ± 5% 47 to 16M Ω 762 98xxx (1) The resistors have a 12-digit ordering code starting with 2322. (2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. (3) The remaining 4 or 3 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. (4) "L" is optional symbol (Note) . ORDERING EXAMPLE The ordering code of a VRC01 resistor, value 1 MΩ with ± 5% tolerance, supplied in tape of 5,000 units per reel is: 232279061105L or RV1206JR-071ML. - Example: 0.02 Ω = 0200 or 200 0.3 Ω = 3007 or 307 1Ω = 1008 or 108 33 KΩ = 3303 or 333 10 MΩ = 1006 or 106 NOTE 1. All our R-Chip products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Nov. 13, 2018 V.8 Product specification Chip Resistor Surface Mount RV 0603/0805/1206/2010/2512 (RoHS Compliant) SERIES 4 9 MARKING RV0603/0805/1206/2010/2512 E-24 series: 3 digits, ±5% 03 First two digits for significant figure and 3rd digit for number of zeros YNSC001 Fig. 1 Value=10 KΩ RV0603 E-24 series: 3 digits, ±0.5% & ±1% 0 Exception values 10/11/13/15/20/75 of E24 series One short bar under marking letter YNSC037 Fig. 2 Value=24Ω E-96 series: 3 digits, ±0.5% & ±1% Including values 10/11/13/15/20/75 of E24 series First two digits for E-96 marking rule and 3rd letter for number of zeros Fig. 3 Value=12.4 KΩ RV0805/1206/2010/2512 Both E-24 and E-96 series: 4 digits, ±0.5% & ±1% 00 First three digits for significant figure and 4th digit for number of zeros YNSC004 Fig. 4 Value=10 KΩ For further marking information, please refer to data sheet “Chip resistors marking”. CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added. See fig.5 OUTLINES For dimension see Table 1 marking layer overcoat Primary glass layer resistive layer (Jumper chip is a conductor) inner electrode H termination (Ni/matte tin) DIMENSIONS overcoat I1 Table 1 For outlines see fig. 5 TYPE L (mm) W (mm) ceramic substrate I2 H (mm) I1 (mm) I2 (mm) RV0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 W RV0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 RV1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 RV2010 5.00 ± 0.10 2.50 ± 0.15 0.55 ± 0.10 0.55 ± 0.15 0.50 ± 0.20 RV2512 6.35 ± 0.10 3.10 ± 0.15 0.55 ± 0.10 0.60 ± 0.20 0.50 ± 0.20 YNSC066 L Fig. 5 Chip resistor outlines www.yageo.com Nov. 13, 2018 V.8 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 5 9 ELECTRICAL CHARACTERISTICS Table 2 RESISTANCE RANGE TYPE Rated Power Operating Temperature Range CHARACTERISTICS Max. Max. Dielectric Working Overload Withstanding Voltage Voltage Voltage Temperature Coefficient of Resistance 5% (E-24) 47Ω to 10MΩ RV0603 1% (E-24/E-96) 47Ω to 10MΩ 0.5% (E-24/E-96) 47Ω to 10MΩ 1/10W 350V 500V 500V 400 V 800 V 800 V 500 V 1,000 V 1,000 V 3/4W 500 V 1,000 V 1,000 V 1W 500 V 1,000 V 1,000 V RV0805 5% (E-24) 47Ω to 22MΩ 1% (E-24/E-96) 47Ω to 22MΩ 0.5% (E-24/E-96) 47Ω to 10MΩ 1/8 W RV1206 5% (E-24) 47Ω to 27MΩ 1% (E-24/E-96) 47Ω to 27MΩ 0.5% (E-24/E-96) 47Ω to 15MΩ 1/4 W –55 °C to +155 °C ± 200 ppm/°C 5% (E-24) 47Ω to 22MΩ RV2010 RV2512 1% (E-24/E-96) 47Ω to 22MΩ 0.5% (E-24/E-96) 47Ω to 10MΩ 5% (E-24) 47Ω to 16MΩ 1% (E-24/E-96) 47Ω to 16MΩ 0.5% (E-24/E-96) 47Ω to 10MΩ FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE REEL DIMENSION RV0603 RV0805 RV1206 RV2010 RV2512 Paper/PE taping reel (R) 7" (178 mm) 5,000 5,000 5,000 --- --- Embossed taping reel (K) 7" (178 mm) --- --- --- 4,000 4,000 NOTE 1. For Paper/PE/Embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. www.yageo.com Nov. 13, 2018 V.8 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 6 9 FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE Range: –55 °C to +155 °C P OWER RATING Each type rated power at 70 °C: RV0603=1/10W; RV0805=1/8W; RV1206=1/4W; RV2010=3/4W; RV2512=1W RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: MLB206_1 P (%Prated) 100 50 0 55 0 50 70 100 155 o Tamb ( C) Fig. 6 Maximum dissipation (P max ) in percentage of rated power V= as a function of the operating ambient temperature (T amb ) or max. working voltage whichever is less Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) Maximum working voltage can be applicable to resistors only if the resistance value is equal to or higher than the critical resistance value. www.yageo.com Nov. 13, 2018 V.8 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 7 9 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements (AEC-Q200 report available for 47ohm ≤ R < 5Mohm) TEST TEST METHOD PROCEDURE Life/ Operational Life/ Endurance MIL-STD-202G-method 108A 1,000 hours at 70± 5 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required High Temperature Exposure/ Endurance at upper category temperature MIL-STD-202G-method 108A Moisture Resistance MIL-STD-202G-method 106F IEC 60115-1 4.24.2 IEC 60115-1 4.25.1 REQUIREMENTS ± (2%+0.05 Ω) JIS C 5202-7.10 IEC 60115-1 4.25.3 1,000 hours at maximum operating temperature depending on specification, unpowered JIS C 5202-7.11 No direct impingement of forced air to the parts ± (1%+0.05 Ω) Tolerances: 155± 3 °C Each temperature / humidity cycle is defined at 8 hours (method 106F), 3 cycles / 24 hours for 10d with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered ± (2%+0.05 Ω) Parts mounted on test-boards, without condensation on parts Measurement at 24± 2 hours after test conclusion Thermal Shock MIL-STD-202G-method 107G -55/+125 °C Note: Number of cycles required is 300. Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air Short time overload MIL-R-55342D-para 4.7.5 Board Flex/ Bending IEC60115-1 4.33 IEC60115-1 4.13 ± (0.5%+0.05 Ω) for 10 KΩ to 10 MΩ ± (1%+0.05 Ω) for others 2.5 times RCWV or maximum overload voltage whichever is less for 5 sec at room temperature ± (2%+0.05 Ω) Device mounted on PCB test board as described, only 1 board bending required Bending for 0603 & 0805: 3mm 1206 & above: 2mm Holding time: minimum 60 seconds ± (1%+0.05 Ω) No visible damage No visible damage Ohmic value checked during bending Humidity IEC 60115-1 4.24.8 Steady state for 1,000 hours at 40°C / 95% R.H. RCWV applied for 1.5 hours on and 0.5 hour off ± (3.0%+0.05 Ω) AEC-Q200 Test 7 for 47ohm ≤ R< 5Mohm, 1,000 hours; 85°C / 85% RH 10% of operating power Measurement at 24 ± 4 hours after test conclusion ± (5.0%+0.05 Ω) MIL-STD-202 Method 103 www.yageo.com Nov. 13, 2018 V.8 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 8 9 TEST TEST METHOD PROCEDURE REQUIREMENTS Solderability - Wetting IPC/JEDECJ-STD-002B test B Electrical Test not required Well tinned (≥95% covered) IEC 60068-2-58 Magnification 50X No visible damage SMD conditions: 1st step: method B, aging 4 hours at 155 °C dry heat 2nd step: leadfree solder bath at 245± 3 °C Dipping time: 3± 0.5 seconds - Leaching - Resistance to Soldering Heat IPC/JEDECJ-STD-002B test D No visible damage IEC 60068-2-58 Leadfree solder, 260 °C, 30 seconds immersion time MIL-STD-202G-method 210F Condition B, no pre-heat of samples ± (1%+0.05 Ω) IEC 60068-2-58 Leadfree solder, 260 °C, 10 seconds immersion time No visible damage Procedure 2 for SMD: devices fluxed and cleaned with isopropanol www.yageo.com Nov. 13, 2018 V.8 Product specification Chip Resistor Surface Mount RV SERIES 0603/0805/1206/2010/2512 (RoHS Compliant) 9 9 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 8 Nov .09, 2018 - - Add AEC-Q200 for 47ohm ≤ R < 5Mohm Version 7 Jul. 06, 2017 - - Add IEC62368-1 safety certificate declaration for sizes 0603/0805/1206 Version 6 Dec. 01, 2016 - - Extend resistor value of RV1206 0.5% Version 5 Aug. 27, 2015 - - Extend resistor range and add 0.5% Version 4 Jan. 27, 2014 - - RV0603 resistance range extend to 10MΩ - Add RV2010 Version 3 Aug. 26, 2013 - - Add RV0603 Version 2 Sep 29, 2011 - - Type error correction Version 1 Nov 19, 2008 - - Change to dual brand datasheet that describes RV0805/1206/2512 with RoHS compliant - Description of "Halogen Free Epoxy" added - Define global part number Version 0 Feb 14, 2006 - - New datasheet for high voltage chip resistors sizes of 0805/1206/2512, 5%, 1% tolerance with lead-free terminations - Replace the 0805/1206/2512 parts of pdf files: VRC01_02_11_12_51_3.pdf, VPRC221_5_3.pdf, and combine into a document. - Test method and procedure updated - PE tape added (paper tape will be replaced by PE tape) “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any product change will be announced by PCN.” www.yageo.com Nov. 13, 2018 V.8
RV1206FR-077M5L
物料型号:RV系列,包括0603/0805/1206/2010/2512尺寸。
器件简介:这是一系列高电压芯片电阻器,采用无铅端子,通过厚膜工艺制造,符合RoHS标准。
引脚分配:文档中没有明确提到引脚分配,但通常这类电阻器是表面贴装的,具有两个端子用于连接。
参数特性: - 额定功率:RV0603为1/10W,RV0805为1/8W,RV1206为1/4W,RV2010为3/4W,RV2512为1W。 - 工作温度范围:-55°C至+155°C。 - 最大工作电压:根据型号不同,从350V到1000V不等。 - 温度系数:+200ppm/°C。
功能详解:这些电阻器适用于多种应用,如转换器、打印机设备、电池充电器、计算机、电源和汽车电子等。它们具有高可靠性,使用无卤素环氧材料,并且具有IEC 62368-1安全证书。
应用信息:适用于需要高电压和可靠性的应用场合。
封装信息:提供多种尺寸的封装,包括0603、0805、1206、2010和2512,并且有纸带或压花胶带的包装选项。
RV1206FR-077M5L 价格&库存
很抱歉,暂时无法提供与“RV1206FR-077M5L”相匹配的价格&库存,您可以联系我们找货
RV1206FR-077M5L
    • 1+0.22080
    • 100+0.14250
    • 1000+0.10140
    • 2500+0.07540
    • 5000+0.05610
    库存:20
