MSR820AJC288-12
MSR820AJC288-12
    MOSYS
    PBGA324_19X19MM
    IC SRAM 576MBIT PAR 324PBGA
MSR820AJC288-12 数据手册
BLAZAR BE2-RMW Accelerator Engine Intelligent In-Memory Computing 576Mb Memory PRODUCT BRIEF: MSR820 Acceleration Engines Give Software and Hardware System Architects Acceleration Options not Previously Available Bandwidth Engine (BE) Overview The BLAZAR Family of Accelerator Engines are high capacity, high-speed memories that support high bandwidth, fast random memory access rates and includes optional embedded In-Memory Functions (IMF) that solve critical memory access challenges for memory bottlenecked applications like network search, statistics, buffering, security, firewall, 8k video, anomaly detect, genomics, ML random forest of trees, graph walking, traffic monitoring, AI and IoT. All Accelerator Engines have two ways to be uses in a system: 1. As a standard parallel like QDR, SyncSRAM or RLDram 2. As a high density, high bandwidth memory with Optional In-Memory Acceleration Functions Both modes are independent. You do not have to use the In-Memory functions if they are not useful in your application. In that case, you would use the Accelerator Engine like any other memory. Base Features: The Bandwidth Engine 2 RMW (BE2-RMW) • 576 Mb of tRC of 3.2 ns memory o Replaces 4 QDR type memories • • • In-Memory BURST functions In-Memory RMW functions RTL Memory Controller • Applications Focus • • • • • Slower speed applications needing high capacity SRAM with high capacity and high speed High bandwidth data access application where low latency and movement of data is a critical Applications that use base level compute or decisions functions FPGA Acceleration for Xilinx and Intel Key Features - Memory Key Features – In-Memory Functions • • 576 SRAM (8M x 72b) o o • User defined WORD width Typical 8x, 16x, 32x, 36x, … 72x High Bandwidth, low pin count serial interface o Highly efficient reliable transport command and data protocol optimized for 90% efficiency o Eases board layout and signal integrity, minimal trace length matching required, operates over connectors o Reduction of I/O pins from 5x to 45x depending on equivalent memory density and type • • High access rate SRAM class memory o Up to 3.3 Billion transactions/sec o 2.7 ns tRC The Acceleration function is optional and does not impact the device used as a memory only BURST In-Memory Function • For sequential Read or Write functions for data movement • Burst length: 1, 2, 4 or 8 words • Can double or triple QDR bandwidth RMW In-Memory Function • RMW are Read/Modify/Write functions • Includes may functions for compute and decision • Examples: ADD, SUB, Compare, INC plus 15 other functions • Increases execution speed and bandwidth Highest Single Chip Bandwidth – up to 320 Gb/s throughput (160 full duplex) MoSys Accelerator Engine Elements of BE2-RMW MoSys Engines have a Unique Memory Architecture that can replace SyncRAM/RLDRAM memories and Embeds In Memory Functions (IMF) that execute many times faster. A single function replaces many traditional memory accesses. Bandwidth Engine Device Key Features BE2-RMW High Speed Serial I/O • GCI serial I/O versions of 10 and 12.5 Gbps for high bandwidth (up to 320 Gbps) • Device can operate with a minimum of 4 lanes • Has two, full duplex 8 lane ports that operate independently • Reduces number of signal pins over traditional memories, increases signal integrity allowing longer board traces to ease board signal routing • Operates across connectors Main MainMemory Memory • 576Mb (BE3 has 1Gb)) o 4 partitions/64 banks o 8 READ and 8 WRITE ports • 3.2 ns tRC • Allows parallel partition and bank execution Memory/Function Controller • Directs all read/write function execution to selected bank of memory • Manages the sequence of InMemory functions o o o • Tx SerDes BURST – Sequential read or writes Up to 8 read or writes RMW -- 4-8x reduction in RMW accesses Controls simultaneous memory access to partitions and banks Tx SerDes Common Key Features for Bandwidth Engines (BE2 & BE3) • • • High capacity High-Speed Memory on a single device o BE2 576Mb o BE3 1Gb High speed tRC access o BE2 with 3.2ns o BE3 with 2.7ns • external signal conditioning board components o Signals will work over a backplane • protocol Reduce number of interface pins compared to other memories - Typical system uses 8 lanes or 32 pins - Highest bandwidth uses 16 lanes or 64 pins - Minimum use of 4 lanes on one port or 16 pins Make the interface like a parallel QDR o MoSys supplies an RTL memory controller that handles the memory and serial interface o Serial device interface is transparent to user o Provides a parallel QDR like Read/Write RTL interface Achieve the highest bandwidth possible o Use of serial interface with high efficiency GCI o BE2 with 3.3B access per sec o BE3 with 6.5B accesses per sec • Eliminate external components required for signal integrity o On device Auto-Adaption to eliminate • Make interface easily adapted to an AXI or Avalon bus o Minimal RTL logic required Benefits of BE2 vs QDR SUMMARY OF BENEFITS More High-Speed memory generally allows acceleration options for software and hardware architects/designers Capacity … 576Mb memory … Replaces 4 QDR/SyncSRAM devices • Cost … One BE-2 with 4x the capacity is approximately the price of 2 QDR memories • Pins … Typical application uses only 16 signals (32 pins) with signal AutoAdaptation • Overview Comparison BE vs. QDR • Memory size o BE2 with 576Mb equivalent to 4 QDRs with 144Mb per device • Device PCB board Space Saving o 1 BE2 device vs 4 QDR devices • Signal Pin Reductions o 4 QDR…576Mb requires 500-720 pins o 1 BE2.…576Mb…BE2 typical system uses 8 lanes or 32 pins o All BE devices have Auto-Adaptation which handles on-board signal tuning, eliminating the need for any external components to insure clean, reliable signals • Cost o One BE-2 with 4x the memory capacity is approximately the price of two QDR memories • Application Benefits o Larger Buffers, High Bandwidth o Allows Realtime operations and analysis at Line rate o Eliminates need for complex parallel operations using RLDRAM, HBM, or slow DRAM In-Memory Functions Example of BURST Function (BE2/BE3/PHE) When there is a need to move data at a high bandwidth, the InMemory commands can save a tremendous amount of time in one tRC cycle In the BE2, • • • 8 Read 8 Writes 8 Reads + 8 Writes In the BE3 • • • 16 Reads 16 Writes 16 Reads + 16 Writes Example In-Memory BURST time saving • • • • • Example of RMW Function (BE2/BE3/PHE) ▪ tRC 3ns QDR 144b read QPR 576b read QPR 4x of a QDR There are more than 12 different commands Focused on DATA COMPUTING AND DECISION where there is need for memory location modification involving RMW in applications such as metering, as well a single or dual counter update for statistics. There are over 27 operations available such as add, subtract, compare, increment, etc. Example In-Memory RMW time saving Add a Number to a Location (RMW) QDR Traditional Memory System • • Compatibility Quazar - Blazar Family of Accelerator Engines • • MSP220 (QPR4) pin compatible MSR622/MSR820 (BE2) MSP230 (QPR8) pin compatible MSR630/MSR830 (BE3) 3 operations Time Analysis Total Time = 6ns + FPGA ADD TIME MoSys In Memory Function • • 1 operations Time Analysis Total Time = 3ns Simplifying User Interface to BE2/3 w/MoSys RTL Controller Interface Ports • • • • • Device has two, 8 lane independent ports Typical system uses one port (shown), 8 lanes or 32 pins Can use as few as 4 lanes on one port or 16 pins High bandwidth systems use both ports, 16 lanes, 64 pins Independent ports can operate as a dual port with simultaneous access between two FPGAs Serial Interface • • Benefits of a serial interface allows high bandwidth over very few pins Key to bandwidth is the MoSys GCI interface that is transparent to the user with the MoSys-supplied FPGA RTL Memory controller MOSYS FPGA Parallel RTL Interface MoSys-Supplied RTL Controller Simplifies The User Interface with the BE MoSys-supplied FPGA RTL Memory Controller interfaces with the MoSys Bandwidth Engine. This controller is between the User Application RTL logic and the BE device. MoSys-Supplied RTL Controller Simplifies the User Interface with the BE • • It handles all the logic for the Serial GigaChip Interface (GCI) in the FPGA Eliminates the user having to design a serial interface by making it transparent and providing a QDR parallel-like interface Memory WORD width is user definable in RTL • o • o • • Typical word widths are 8, 16, 32, 36, 64 … While the memory on the BE2 is organized as 8Mx72b and the BE3 is 16Mx72b, the address conversion mapping from the selected WORD width to the BE memory is handled by the RTL Address translation to BE memory organization is transparent to the application All memory addressing and commands are presented to the QDR like parallel interface If the optional In-Memory functions are used, the RTL controller will manage their execution The signal interface at the User Application is a simple SRAM memory Address, Data, Control structure. This simple interface shields the users from the BE commands, serial interface and the scheduling logic and memory partition timing. SIGNAL NAME DIR DESCRIPTION WIDTH DIR SIGNAL NAME WIDTH High Speed GCI Serial Interface Read Interface rd_p 1 Assertion of this signal indicates that In this is a read transaction. rd_addr_p 32 Read address. Please refer to the In Address section of this specification to see the detail of this address field. rd_partsel_p rd_data_p0 rd_data_p1 rd_datav_p0 rd_datav_p1 rd_wait_rq_p 1 * * Indicates the BE-2 partition that this read command will be operated upon: 0 = Partition 0 for GCI port A, Partition 1 In for GCI port B 1 = Partition 2 for GCI port A, Partition 3 for GCI port B Returned data from BE-2 memory. This Out data is qualified by the “rd_datav_p0” signal Returned data from BE-2 memory. This data is qualified by the “rd_datav_p1” Out signal. Note that rd_data_p1 will only have valid data if rd_data_p0 is valid as well. rd 1 The Memory Controller asserts this Out signal to indicate the current data in the “rd_data_p0” bus is valid 1 The Memory Controller asserts this signal to indicate the current data in the Out “rd_data_p1” bus is valid. Note that rd_data_p1 will only have valid data if rd_data_p0 is valid as well 1 The Memory controller asserts “rd_wait_rq_p” to indicate that it cannot accept the current read request from Out user. The User Application should hold all the request signals (rd_p, rd_addr_p …) until the de-assertion of this signal. DESCRIPTION Write Interface wr_p wr_addr_p 1 32 In Assertion of this signal indicates that this is a write transaction. In Write address of the memory for this transaction. Please refer to the Address section of this specification to see the detail of this address field. wr_partsel_p 1 In Indicates the BE-2 partition that this write command will be operated upon: 0=Partition 0 for GCI port A, Partition 1 for GCI port B 1=Partition 2 for GCI port A, Partition 3 for GCI port B wr_data_p * In Write data from the User Application logic. 1 The Memory controller asserts “wr_wait_rq_p” to indicate that it cannot accept the current write request. The Out User Application should hold all the request signals (wr_p, wr_addr_p …) until the de-assertion of this signal. wr_wait_rq_p Accelerator Engine Family Overview Software Defined - Hardware Accelerated In-Memory Acceleration Functions Optional Function Will Not Impact the Device When Used as Memory Only BURST In-Memory Function • • • • For sequential Read or Write functions for data movement Burst length: 1, 2, 4, or 8 words Can double or triple QDR bandwidth Simultaneous execution of read and writes RMW In-Memory Function • • • • RMW are Read/Modify/Write functions Includes many functions for compute and decision Examples: ADD, SUB, Compare, INC plus 15 other functions Increases execution, speed and bandwidth Flexible Configuration Uses CONTACT MOSYS TO LEARN ABOUT THESE ADVANCED FEATURES DUAL PORT www.mosys.com HIGH BANDWIDTH PIPELINE https://mosys.com/products/blazar-family-of-accelerator-engines/ MoSys is a registered trademark of MoSys, Inc. in the US and/or other countries. Blazar, Bandwidth Engine, HyperSpeed Engine, IC Spotlight, LineSpeed and the MoSys logo are trademarks of MoSys, Inc. All other marks mentioned herein are the property of their respective owners. 2309 Bering Drive, San Jose, CA 95131 Tel: 408-418-7500 Fax: 408-418-7501 www.mosys.com PB_AE_BE2-RMW w-RTL_R1_201006 www.mosys.com
MSR820AJC288-12 价格&库存
很抱歉,暂时无法提供与“MSR820AJC288-12”相匹配的价格&库存,您可以联系我们找货
