SM712GX04LF04-BA
SM712GX04LF04-BA
    SILICONMOTION(慧荣)
    BBGA256
    SM712GX04LF04-BA
SM712GX04LF04-BA 数据手册
Silicon Motion, Inc. Mobile Computer Display Controller Preliminary Version 1.3 Last Updated 4/23/03 LynxEM+ DataBook ® Silicon Motion , Inc. LynxEM+ Databook ® Silicon Motion , Inc. LynxEM+ DataBook Notice Silicon Motion, Inc. has made best efforts to ensure that the information contained in this document is accurate and reliable. However, the information is subject to change without notice. No responsibility is assumed by Silicon Motion, Inc. for the use of this information, nor for infringements of patents or other rights of third parties. Copyright Notice Copyright 2002, Silicon Motion, Inc. All rights reserved. No part of this publication may be reproduced, photocopied, or transmitted in any form, without the prior written consent of Silicon Motion, Inc. Silicon Motion, Inc. reserves the right to make changes to the product specification without reservation and without notice to our users Version Number Date 0.1 9/30/99 0.2 11/12/99 0.3 0.4 0.5 05/23/00 Note 12/20/99 • • • • All registers are the same as the LynxEM with the exception of the following: CCR62 bit 7:6, and MCR62 bit 7, bit 6, bit 2 Figure 2 Pin Diagram updated Table 1: Pin Description - Updated Table 2: SM712 Pin Diagram for 256 BGA Package - Updated Add VCLK table to register CCR6D 02/16/99 • Updates to Pin Description table and Power-on configuration table • Change to Pin Description Table (VCC & Ground Pins) delete 5V reference from FPVDD Delete 5V reference to I2C Bus or VESA DDC2B Interface Added 4Mbyte internal memory configuration Minor corrections based on field input. Change M4 in pin diagram to VCC. Changed M4 and K1 in Pin List Added ordering information table Changed ICC Digital DC Specification and operating power dissipation Revised block diagram Changed DC Specification MCLK in Electrical Specifications Added ICC Sleep Mode to Digital DC Specification table in Electrical Specifications 0.6 12/07/00 0.7 3/31/01 0.8 6/27/01 0.9 10/18/01 • • • • • • • • • • • iii ® Silicon Motion , Inc. Version Number LynxEM+ Databook Date 1.0 3/28/02 1.1 7/16/02 1.2 1/14/03 1.3 4/23/03 Note • • • • • • • • • • • • • iv Change pin M17 to N/C Removed panel support for 1280x1024 Changed VCCA and VCC to VDD Delete External 2MG SGRAM Configuration figure Minor corrections based on field input Changed Digital DC Specificaitons for VIH and ICC Changed pin K3 from MEMINT to DSF Clarified definition of PCI Bus Interface page 4-1 Removed AGP references Removed Bus Master Mode with DMA - LynxEM+ does not support this feature Added clarifcation to PCI Interface burst read and burst write. The LynxEM+ supports burst read and burst write for master mode and burst write for slave mode. Added clarification to the Drawing Engine Control Registers. The LynxEM+ supports Bresenham line draw (8 and 16-bit only) and rectangle fill (8 and 16-bit only). Changed SCR18 [0] enable definition. Silicon Motion®, Inc. LynxEM+ DataBook Table of Contents Chapter 1: Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-1 Functional Block Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-4 PCI Interface and HIF. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-4 Memory Controller . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-4 Drawing Engine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-4 Power Down Control Unit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-4 Video Processor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-5 Video Capture. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-5 LCD Backend Controller . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-5 Popup Icon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-6 VGA Core. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-6 PLL Module . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-6 RAMDAC. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-6 Chapter 2: Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-1 LynxEM+ Pin Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-1 LynxEM+ NAND Tree Scan Testing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-14 General Information . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-14 Chapter 3: Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-1 LynxEM+ Power-On Configurations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-3 Chapter 4: PCI Bus Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-1 PCI Configuration Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-1 Chapter 5: Display Memory Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-1 Memory Configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-1 Page Break Look Ahead . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-1 Memory Timing Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-1 Chapter 7: Video Processor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-1 Chapter 6: Drawing Engine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7-1 Chapter 8: Zoom Video Port and Video Capture Unit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-1 Zoom Video Port . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-1 Video Capture Unit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-2 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-3 Theory of Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-4 Chapter 9: Flat Panel Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-1 EMI Reduction Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-1 LynxEM+ Flat Panel Enhancements . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-1 LynxEM+ Graphics/Text Expansion Information . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-1 Introduction. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-1 Horizontal Expansion for Text and Graphics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-1 Vertical Expansion for Text and Graphics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-2 LCD Dithering Engine . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-3 Flat Panel Power ON/OFF Sequencing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-3 LVDS Chipset Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-8 Chapter 10: Miscellaneous Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-1 Video BIOS ROM Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-1 VESA DPMS Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-2 I2C Bus or VESA DDC2B Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-2 Chapter 11: Clock Synthesizers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11-1 Chapter 12: Multimedia RAMDAC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12-1 Table of Contents v Silicon Motion®, Inc. LynxEM+ DataBook LCD Backend RAM (RAM1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12-1 Chapter 13: Signature Analyzer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13-1 Chapter 14: Power Management . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-1 ACPI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-1 Adaptive Power Management . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-1 Dynamic Control of Functional Blocks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-1 Dynamic Clock Control and Virtual Refresh. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-2 Standard Power Management . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-2 Standby Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-2 Power Saving In Standby Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-3 Sleep Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-3 Activity Detection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-4 Power-down Sleep Mode States . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-4 Chapter 15: PCI Configuration Space Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15-1 PCI Configuration Space Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15-2 Extended SMI Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15-8 Chapter 16: Standard VGA Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16-1 Standard VGA Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16-4 General Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16-4 Sequencer Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16-6 CRTC Controller Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16-9 Graphics Controller Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16-21 Attribute Controller Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16-26 RAMDAC Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16-30 Chapter 17: Extended SMI Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-1 Extended SMI Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-6 System Control Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-6 Power Down Control Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-13 Flat Panel Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-18 Memory Control Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-38 Clock Control Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-40 General Purpose Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-46 Pop-up Icon Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-50 Hardware Cursor Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-52 Extended CRT Control Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-54 Shadow VGA Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-63 Automatic Lock/Unlock Scheme for Shadow Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-64 Chapter 18: Memory Mapped Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18-1 Drawing Engine Control Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18-4 Video Processor Control Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18-20 Capture Processor Control Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18-36 Chapter 19: Electrical Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-1 Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-1 DC Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-1 AC Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-2 AC Timing Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-3 PCI Bus Cycles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-4 Flat Panel Interface Cycle Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-5 Chapter 20: Mechanical Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20-1 Chapter 21: Index . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21-1 vi Table of Contents Silicon Motion®, Inc. LynxEM+ DataBook List of Figures Figure 1: Figure 2: Figure 3: Figure 4: Figure 5: Figure 6: Figure 7: Figure 8: Figure 9: Figure 10: Figure 11: Figure 12: Figure 13: Figure 14: Figure 15: Figure 16: Figure 17: Figure 18: Figure 19: Figure 20: Figure 21: Figure 22: Figure 23: Figure 24: Figure 25: Figure 26: Figure 27: Figure 28: Figure 29: Figure 30: Figure 31: Figure 32: Figure 33: Figure 34: System Block Diagram for the LynxEM+ .................................................................................................. 1-2 SM712 Pin Diagram for 256 BGA Package ................................................................................................ 2-6 NAND Tree Connection ............................................................................................................................ 2-14 External SGRAM Power-Up and Initialization Sequence .......................................................................... 3-1 LynxEM+ BIOS Initialization Flowchart .................................................................................................... 3-2 Video Processor Block Diagram ................................................................................................................. 6-1 Video Encoder Interface via Video Port ..................................................................................................... 8-1 Video Capture Block Diagram .................................................................................................................... 8-3 Video Capture Data Flow ............................................................................................................................ 8-4 Capture Buffer Structure in Interlaced Mode .............................................................................................. 8-7 DDA Expansion Algorithm ......................................................................................................................... 9-2 TFT (Single Pixel/Clock) Interface Diagram .............................................................................................. 9-5 TFT Panel (2 pixels/clock) Interface Diagram ............................................................................................ 9-6 16-bit DSTN Interface Configuration ......................................................................................................... 9-6 24-bit Dual Color STN Interface Diagram .................................................................................................. 9-7 Panel Power On Sequencing Timing Diagram ............................................................................................ 9-7 Panel Power Off Sequencing Timing Diagram ........................................................................................... 9-8 LVDS Interface with TFT LCD Panel ........................................................................................................ 9-9 LVDS Interface with DSTN LCD Panel ..................................................................................................... 9-9 36-bit (18x2-bit) TFT Interface Diagram .................................................................................................. 9-10 PanelLink Interface with TFT LCD Panel ................................................................................................ 9-11 PanelLink Interface with DSTN LCD Panel ............................................................................................. 9-11 Video BIOS ROM Configuration Interface .............................................................................................. 10-1 LynxEM+ I2C Bus Protocol Flow Chart .................................................................................................. 10-3 Clocks Generator Block Diagram ............................................................................................................. 11-1 LynxEM+ RAMDAC Block Diagram ...................................................................................................... 12-1 Signature Analyzer Block Diagram ........................................................................................................... 13-1 Memory Mapped Address Diagram .......................................................................................................... 18-3 Power-on Reset and Reset Configuration Timing ..................................................................................... 19-3 PCI Bus Timing Diagram .......................................................................................................................... 19-4 TFT Interface Timing ................................................................................................................................ 19-5 DSTN Interface (Clock and Data) Timing ................................................................................................ 19-6 DSTN Interface (Control and Clock) Timing ........................................................................................... 19-6 256 BGA Mechanical Dimensions ............................................................................................................ 20-1 List of Figures vii Silicon Motion®, Inc. LynxEM+ DataBook List of Tables Table 1: Table 2: Table 3: Table 4: Table 5: Table 6: Table 7: Table 8: Table 9: Table 10: Table 11: Table 12: Table 13: Table 14: Table 15: Table 16: Table 17: Table 18: Table 19: Table 20: Table 21: Table 22: Table 23: Table 24: Table 25: Table 26: Table 27: Table 28: Table 29: LynxEM+: Display Support Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-7 Pin Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-2 SM712 Pin Diagram for 256 BGA Package. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-7 NAND Tree Scan Test Order . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-14 Power-On Configurations. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-3 LynxEM+ Video Port Interface I/O Configurations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-2 Bit Setting Summary for Video Capture . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-5 Flat Panel Interface Pins listing for color DSTN and color TFT LCD . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-4 LVDS Transmitter Pin Mapping for TFT Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-12 LVDS Transmitter Pin Mapping for DSTN Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-13 PanelLink Transmitter Pin Mapping for TFT Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-14 PanelLink Transmitter Pin Mapping for DSTN Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-15 DPMS Summary. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-2 Recommended VNR and VDR Values for Common VCLK Settings . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11-2 Interface Signals Sleep Mode States . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14-4 PCI Configuration Registers Quick Reference. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15-1 Standard VGA Registers Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16-1 PCI Configuration Registers Quick Reference. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-1 Memory Mapped Registers Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18-1 Absolute Maximum Ratings. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-1 Digital DC Specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-1 RAMDAC Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-2 RAMDAC/Clock Synthesizer DC Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-2 RAMDAC AC Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-2 Power-on Reset and Configuration Reset Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-3 PCI Bus Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-4 Color TFT Interface Timing. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-5 Color DSTN Interface Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19-6 Ordering Information . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20-2 List of Tables ix Silicon Motion®, Inc. LynxEM+ DataBook Chapter 1: Overview The LynxEM+ combines Silicon Motion's unique multimedia features into a MCB solution. The LynxEM+ includes 2MB and 4MB of video memory within a single footprint. This powerful single footprint solution, when combined with SMI's Virtual Refresh™ architecture provides a complete video subsystem which consumes very little power. LynxEM+ offers enhanced capabilities for dual view and for handling dual applications. Through its Virtual Refresh architecture, LynxEM+ can simultaneously drive LCD/CRT and LCD/TV display combinations. Each display can support independent full screen full motion video, as well as independent graphics refresh rates, resolutions, and color depths. LynxEM+ can display slides on TV/CRT while the attached speaker notes are available on the LCD display, invisible to the audience. For a dual application experience, a spreadsheet can be displayed on the LCD, while a word processing application or web browser can be displayed on the CRT. Dual view and dual application support is provided under Windows 95, Windows 98, Windows NT, and Windows 2000. The LynxEM+ incorporates three separate PLLs to allow flexible control of functional blocks within the device. A robust 2D Drawing Engine supports 3 ROPs, BitBLT, transparent BLT, pattern BLT, color expansion, and line draw. The Host Interface Unit is PCI 2.1 compliant and supports bus mastering. The Power Down Control Unit with Dynamic Power Management provides individual block shutdown capability and complete Standby and Suspend support. A VGA Core, LCD Backend Controller and 135 MHz RAMDAC are incorporated as well. The LynxEM+'s Concurrent Video Processor and Video Capture Unit provide superior video quality for real-time video capture and playback. LynxEM+'s Video Processor supports multiple independent full screen, full motion video windows with overlay. Each motion video window uses hardware YUV-to-RGB conversion, scaling, and color interpolation. When combined with the dual view capabilities of the chip, these independent video streams can be output to separate display devices and bilinear scaled to support applications such as full screen display of local and remote images for video conferencing. LynxEM+ is designed with 0.35m, TLM, 3.3V CMOS process technology. A hierarchical layout approach provides enhanced internal timing control. In addition to built-in test modes and a signature analyzer, the LynxEM+ incorporates a 20-bit test bus designated the TD Bus. The TD bus can be used to simultaneously monitor 20 internal signals from 8 functional blocks through Zoom Video (ZV) Port Interface. The capability can be used to increase fault coverage, and reduce silicon validation and debugging time. The LynxEM+ is available in a 256 BGA package. Overview 1-1 Silicon Motion®, Inc. LynxEM+ DataBook PCI/AGP PCI/AGP2X TV ZV Port Lynx3DM+ LynxEM+ 4/8/16MB CRT Monitor Flat Panel Figure 1: System Block Diagram for the LynxEM+ 1-2 Overview Silicon Motion®, Inc. LynxEM+ DataBook Features Benefits Dual Application support under Microsoft Windows 95, Windows 98, and Windows NT with one LynxEM+ device • Dual Display support under Microsoft Windows 95, Windows 98, and Windows NT Portion of primary display can be zoomed up for display on secondary display. Example: Zoom up power point slide to CRT, slide and accompanying speaker notes visible on LCD Virtual Refresh Architecture • • • • Two applications available at the same time across two display devices. Example: Word on LCD, Excel on CRT Single chip implementation ideal for mobile systems Low operational power consumption Simultaneous display of CRT and LCD at different resolutions and refresh rates Simultaneous display of interlaced TV and non-interlaced LCD display Dynamic power management • Individual functional block shut-down • Standby, Suspend support Minimize power dissipation to extend battery life Multiple independent hardware video windows • YUV-RGB color space conversion • Bilinear XY interpolation • Robust, single clock cycle Drawing Engine • BitBLT, Transparent BLT, Pattern BLT • 3 ROPs • Color Expansion • Line Draw Top notch graphics performance for mobile systems High performance memory interface • 2MB or 4 MB internal memory • 64-bit memory bus LynxEM+ provides up to 400MB/s bandwidth to support graphics and video. LynxEM4+ provides up to 688MB/s bandwidth to support graphics and video. PCI Bus Mastering Move graphics data and video to/from system memory to local graphics memory without impacting CPU performance. Example: Bus Master local videoconferencing image to system memory. DSTN and TFT panel support up to 1024x768 Supports all panel requirements for mobile systems TVout support • Flicker filter • Overscan/Underscan support Graphics and/or video display on TV 135MHz 24-bit RAMDAC Provides for PC99 compliant refresh rates Zoom Video Port Provides support for camera or TV tuner input, or input to VCR Hardware support for LCD landscape/portrait rotation Portrait view applications PC99 Compliant, ACPI Compliant Meets WHQL certification requirements SW support for Microsoft Windows 95, Microsoft Windows NT, and Microsoft Windows 98 Complete OS support Hardware Video “Bob” Support Improves DVD playback quality • • Independent full screen, full motion video for separate displays. Complete dual view support for video under Windows98 Example: For video conferencing - Full screen local view on LCD, full screen remote view on CRT/TV. for desktop publishing, word processing Microsoft, Windows, and Windows NT are registered trademarks or trademarks of Microsoft Corporation Overview 1-3 Silicon Motion®, Inc. LynxEM+ DataBook Functional Block Summary The LynxEM+ consists of a logic block which interfaces to a 2MB or 4MB block of internal memory. The internal memory configuration consists of one 512Kx32 SGRAM, and supports single clock cycle transfers up to 100MHz. Peak memory bandwidth for the internal memory bus is over 500MB/s. The logic within the LynxEM+ consists of 11 functional blocks: PCI Interface, Host Interface (HIF), Memory Controller, Drawing Engine, Power Down Control Unit, Video Processor, Video Capture Module, LCD Backend Controller, VGA Core, PLL Module, and RAMDAC. A summary of each of the functional blocks, along with important features follows: PCI Interface and HIF LynxEM+'s PCI Host Interface Unit supports burst read and burst write for master mode, and burst write for slave mode. The Host Interface Unit decodes I/O read, I/O write, memory read, memory write, memory mapped access, 2D Drawing Engine access, VGA access, and others. The unit also supports Little-Endian and Big-Endian format, and 8-bit ROM decode for on board video BIOS ROM. A dual aperture feature is designed to support VGA modes and non-VGA modes. In addition, a special VGA aperture function is added to allow 64-bit memory access in VGA modes. LynxEM+ has an internal HIF (Host Interface) bus which is designed to transfer data between PCI Host Interface Unit and other functional blocks. The PCI Host Interface Unit controls the HIF bus protocol to effectively deliver PCI I/O and memory cycles to each functional block. Key Feature Summary: • • • 33 MHz & 66 MHz PCI Master/Slave interface PCI 2.1 compliant Dual aperture feature for concurrent VGA and video/drawing engine access Memory Controller Memory control is provided for the 2MB and 4MB internal memory. Page Break Look Ahead support assures a memory cycle is not broken if there is a change of memory bus agent within the same memory page. Programmable memory arbitration allows memory interface usage to be fully optimized - priority and round robin arbitration is supported. Key Feature Summary: • 500MB/s memory bandwidth Drawing Engine The LynxEM+'s Drawing Engine is designed to accelerate 2D through APIs such as Direct Draw. The engine pipeline runs at a single clock per cycle at speeds up to 62.5MHz. The engine supports key GUI functions such as 3 operand ALU with 256 raster operations, pattern BLT, color expansion, trapezoid fill, and line draw. Key Feature Summary: • • • 62.5MHz single clock/cycle engine (EM+) 86MHz single clock/cycle engine (EM4+) Designed to accelerate DirectDraw Power Down Control Unit The Power Down Control unit provides Dynamic Power Management for all functional blocks within the LynxEM+. Dynamic Power Management is made possible by individual clocking control to each of the functional blocks within LynxEM+. Each clock to a given functional block is skew matched to maintain synchronization between blocks. The functional blocks can then be turned on/off "on the fly" as needed. Power savings under fully operational conditions is maximized, yet the process completely transparent to the user. 1-4 Overview Silicon Motion®, Inc. LynxEM+ DataBook Control for Virtual Refresh is provided through the Power Down Control unit as well. Through Virtual Refresh, LCD panel timing may be driven from a fully independent PLL. VLCK can be significantly reduced, while retaining full graphics performance. The result is significant power savings for LCD only configurations. Finally, the Power Down Control unit generates power down sequencing for Standby and Suspend modes. Internal autostandby and system standby implementations are supported. Under sleep mode, options for memory refresh type and use of internal PLL/external clock for memory refresh clock are provided. Activity detection is supported for resuming from Standby or Suspend modes. Key Feature Summary: • • • • Dynamic Power Management Virtual Refresh Standby and Suspend model support ACPI, DPMS, APM compliant Video Processor The Video Processor module manages video playback to an LCD, CRT, or TV display. Independent video sources can be scaled up and displayed full screen different display devices - ideal for videoconferencing applications. The Video Processor module supports, bi-linear scaling, YUV to RGB color space conversion, color key, and overlay of graphics over video. The Video Processor module also supports flicker reduction and adjustable overscan/underscan for TV display. Key Feature Summary: • • • • Multiple video windows in HW Independent video sources on different displays Bi-linear scaling Flicker filter and underscan for TV display Video Capture The Video Capture module processes incoming video data from the Zoom Video Port and sends the data to the local video frame buffer. From there, the data may be displayed, as well as bus mastered out for storage on a hard drive. Incoming data from the Zoom Video port can be interlaced or non-interlace and in YUV or RGB format. The data can be cropped, horizontally filtered (2,3,or 4-tap), and shrunk to ¼ size. Single buffer as well as double buffer capture is supported. Key Feature Summary: • • • Support for Zoom Video Port interface Crop, filter, shrink support Support BOB implementation when interlaced data is captured LCD Backend Controller The LCD Backend Controller module manages data flow and generates timing to the selected LCD display. The module provides support for 3, 9, 12, 18, 24, 36-bit TFT and 16 or 24-bit DSTN panels up to 1024x768 resolution. The backend controller contains a color encoder, dithering engines for TFT and DSTN panels, frame accelerator, and a Virtual Refresh timing generation block. Each of the blocks within the LCD Backend controller module can be powered down if not in use. In addition LynxEM+ integrates innovative circuitry for reducing EMI. Key Feature Summary: • • • TFT and DSTN support up to 1024x768 Timing generation for Virtual Refresh EMI reduction circuit Overview 1-5 Silicon Motion®, Inc. LynxEM+ DataBook Popup Icon The LynxEM+ support 64x64 popup icon which can be zoomed up by 2 to become 128x128 popup icon. The popup icon can be programmed to anywhere on the screen display. In addition, the popup icon has transparency support. Key Feature Summary: • • Popup icon location flexible Transparency color support VGA Core The LynxEM+ has a high performance 32-bit VGA core which is 100% IBM VGA compatible. In addition to standard VGA functions, the LynxEM+'s VGA core module generates LCD timing, performs LCD screen autocentering and expansion, generates TV timing, and provides Hardware Cursor control. Key Feature Summary: • 100% IBM VGA compatible PLL Module The PLL module provides three separate PLLs for MCLK, VCLK, and Virtual Refresh clock to drive LCD panel timing. A 14.318MHz base clock is used to drive TV timing. This allows for completely independent timing for LCD/CRT or LCD/TV under dual application or dual view. For instance, the LCD panel can be driven at 60Hz while CRT refresh is 85Hz. Key Feature Summary: • Separate PLL for LCD panel timing RAMDAC The integrated RAMDAC supports pixel clock frequencies up to 135MHz at 3.3V. Anti-sparkle logic is provided for read/ writes to the palette. An internal band gap voltage reference saves need for external RC components. Key Feature Summary: • 135MHz at 3.3V 1-6 Overview Silicon Motion®, Inc. LynxEM+ DataBook Table 1: LynxEM+: Display Support Modes CRT Only Display Resolution 640x480 800x600 1024x768 Refresh (Hz) Color Depth 8 bpp 16 bpp 24 bpp 60 x x x 75 x x x 85 x x x 60 x x x 75 x x x 85 x x x 60 x x x 75 x x x 85 x x x Simultaneous Mode Display Resolution Refresh (Hz) 640x480 Color Depth 8 bpp 16 bpp 24 bpp 60 x x x 800x600 60 x x x 1024x768 60 x x x Dual Display Mode Display 1 (D1) 640x480 800x600 1024x768 Display 2 (D2) Color Depth (Max Color Depth Display 2 bpp) when D1 is 8 bpp when D1 is 16 bpp when D1¹ is 24 bpp 640x480 24 (D2) 24 (D2) - 800x600 24 24 - 1024x768 24 24 - 640x480 24 24 - 800x600 24 24 - 1024x768 24 24 - 640x480 24 24 - 800x600 24 24 - 1024x768 24 8 - ¹Max color depth for display 1, 16bpp under dual display Overview 1-7 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 2: Pins The SM712 is in a 256 BGA package. Figure 2 illustrates the pinout diagram for SM712 256 BGA package. Figure 34 illustrates the mechanical dimensions of the BGA package. LynxEM+ Pin Descriptions The following table, Table 2 provides brief description of each BGA ball of the LynxEM+. Signal names with ~ preceding are active "LOW" signals, whereas signal names without ~ preceding are active "HIGH" signals. Also, the following abbreviations are used for Pin Type. Table 3 outlines the numerical SM712 BGA pins. I - INPUT SIGNAL O - Output Signal I/O - Input or Output Signal Note: All Outputs and I/O signals are tri-stated. Internal pull-up for I/O pad are all 100KΩ resistor, with the exception for CPUCLK, which is 200KΩ resistor. Internal pull-down for I/O pad are all 100KΩ resistor. Pins 2-1 Silicon Motion®, Inc. LynxEM+ DataBook Table 2: Pin Description Signal Name Type Pull-up/ Pull-Down IOL (mA) Max. Load (pF) Description Host Interface AD [31:0] I/O 16 120 PCI multiplexed Address and Data Bus. A bus transaction consists of an address cycle followed by one or more data cycles. C/ ~BE [3:0] I/O 16 120 PCI Bus Command and Byte Enables. These signals carry the bus command during the address cycle and byte enable during data cycles. PAR I/O 16 120 Parity. LynxEM+ asserts this signal to verify even parity across AD [31:0] and C/~BE [3:0]. ~FRAME I/O 16 120 Cycle Frame. LynxEM+ asserts this signal to indicate the beginning and duration of a bus transaction. It is deasserted during the final data cycle of a bus transaction. ~TRDY I/O 16 120 Target Ready. A bus data cycle is completed when both ~IRDY and ~TRDY are asserted on the same cycle. ~IRDY I/O 16 120 Initiator Ready. A bus data cycle is completed when both ~IRDY and ~TRDY are asserted on the same cycle. ~STOP I/O 16 120 Stop. LynxEM+ asserts this signal to indicate that the current target is requesting the master to stop current transaction. ~DEVSEL I/O 16 120 Device Select. LynxEM+ asserts this signal when it decodes its addresses as the target of the current transaction. IDSEL I ID Select. This input is used during PCI configuration read/write cycles. CLK I PCI System Clock, 33 MHz. ~RST I PCI System Reset. LynxEM+ asserts this signal to force registers and state machines to initial default values ~REQ O ~GNT I ~INTA O 8 120 PCI Bus Request (bus master mode) PCI Bus Grant (bus master mode) 8 120 PCI Interrupt Power Down Interface ~PDOWN I pull-up Power down mode enable ~CLKRUN/ ACTIVITY O pull-up REFCLK I pull-up 32 KHz refresh clock source for power down or PALCLK for PALTV CKIN I pull-up 14.318 MHz clock (~EXCKEN = 1) or Video Clock (~EXCKEN = 0) MCKIN/ LVDSCLK I/O pull-up ~EXCKEN I pull-up 4 60 ~CLKRUN or LynxEM+ Memory and I/O activity detection depending on SCR18 [7] 0 = select ~CLKRUN 1 = select ACTIVITY Clock Interface 2-2 4 60 Memory Clock In (~EXCKEN = 0) or LVDSCLK Out (~ESCKEN = 1), LVDSCLK is a free running clock which can be used to drive LVDS transmitter for DSTN panels. 60 External Clock Enable. Select external VCLK form CKIN and MCLK from MCKIN. Pins Silicon Motion®, Inc. Signal Name Type LynxEM+ DataBook Pull-up/ Pull-Down IOL (mA) Max. Load (pF) Description External Display Memory Interface MA [9:0] O 8 50 External Memory Address Bus. The video memory row and column addresses are multiplexed on these lines. MD [63:0] I/O pull-up 4 20 External Memory Data Bus ~WE O pull-up 8 50 External Memory Write Strobe ~RAS O pull-up 8 50 External Memory SDRAM Row Address Select ~CAS O pull-up 8 50 External SGRAM Column Address Select ~CS0 O pull-up 8 50 External SGRAM Chip Select 0, select 1st 1MB within the 2MB memory, or select 1st 2MB within the 4MB memory ~DQM [7:0] O pull-up 8 50 External SGRAM I/O mask [7:0]. DQM [7:0] are byte specific. DQM0 masks MD [7:0], DQM1 masks MD [15:8],Ö,and DQM7 masks MD [63:58]. DSF O pull-up 8 50 External SGRAM Block write BA O 8 50 External SGRAM Bank Select. SDRAM has dual internal banks. Bank address defines to which bank the current command is being applied. SDCK I/O pull-up 16 50 External SGRAM clock. SDCK is driven by the memory clock. All SDRAM input signals are sampled on the positive edge of SDCK. SDCKEN I/O pull-up 8 50 External SGRAM clock enable. SDCKEN activates (HIGH) and deactivates (LOW) the SDCLK signal. Deactivating the SDCK provides POWER-DOWN and SELF-REFRESH mode. ~ROMEN O pull-up 4 20 ROM Enable Flat Panel Interface FDATA [23:0] O pull-down 6 50 Flat Panel Data bit 23 to bit 0. Note: For SM712, the upper 12 bits [25:24] are multiplexed with ZV port, and the upper 12 bits [23:11] are dedicated for flat panel data LP/FHSYNC O pull-down 6 50 DSTN LCD: Line Pulse TFT LCD: LCD Horizontal Sync FP/FVSYNC O pull-down 6 50 DSTN LCD: Frame Pulse TFT LCD: LCD vertical sync M/ DE O pull-down 6 50 M-signal or Display Enable. This signal is used to indicate the active horizontal display time. FPR3E [7] is used to select 1 = M-signal 0 = Display Enable FPSCLK O pull-down 6 50 Flat Panel Shift Clock. This is the pixel clock for Flat Panel Data. FPEN O pull-down 4 20 Flat Panel Enable. This signal needs to become active after all panel voltages, clocks, and data are supplied. This signal also needs to become inactive before any panel voltages or control signals are removed. FPEN is part of the VESA FPDI-1B specification. FPVDDEN O pull-down 4 20 Flat Panel VDD Enable. This signal is used to control LCD logic power. VBIASEN O pull-down 4 20 Flat Panel Voltage Bias Enable. This signal is used to control LCD Bias power. Pins 2-3 Silicon Motion®, Inc. Signal Name Type LynxEM+ DataBook Pull-up/ Pull-Down IOL (mA) Max. Load (pF) Description CRT Interface RED O Analog Red Current Output GREEN O Analog Green Current Output BLUE O Analog Blue Current Output IREF I Current Reference Input CRTVSYNCC O pull-up 6 50 CRT Vertical Sync CRTHSYNC/ CSYNC O pull-up 6 50 CRT Horizontal Sync or Composite Sync depending on CCR65 [0] 0 = CRT Horizontal Sync 1 = Composite Sync 4 20 RGB or YUV input/ RGB digital output Video Port Interface P [15:0] I/O PCLK I/O pull-up 4 20 Pixel Clock VREF I/O pull-up 4 20 VSYNC input from PC Card or video decoder HREF I/O pull-up 4 20 HSYNC input from PC Card or video decoder BLANK/ TVCLK I/O pull-up 4 20 Blank output or TVCLK output depending on CCR69 bit 7. 0 = BLANK output 1 = TVCLK output TVCLK output is used to drive external NTSC/PAL TV encoder. To select NTSC or PAL TV, please refer to CCR65 register General Purpose Registers / I2C USR3 I/O pull-up 4 20 General Purpose register. It is recommended to use USR3 to control TV On/Off. 0 = TV display is OFF 1 = TV display is ON USR2 I/O pull-up 4 20 General Purpose register. It is recommended to use USR2 to select NTSC/PAL TV settings. 0 = PALTVCLK 1 = NTSCTVCLK or REFCLK USR1 / SDA I/O pull-up 4 20 General Purpose register. USR1/ DDC2/ I2C Data. Can be used to select different test modes. USR0 / SCL I/O pull-up 4 20 General Purpose register. USR0/ DDC2/ I2C Clock. Can be used to select different test modes. I pull-down Test Mode Pins TEST [1:0] Test mode selects VCC and GROUND Pins HVDD Host Interface VDD on I/O Ring, 3.3V MVDD Display Memory Interface VDD on I/O Ring, 3.3V FPVDD Flat Panel Interface VDD on I/O Ring, 3.3V VPVDD VPort Interface VDD on I/O Ring 3.3V CVDD Clock (PLL) Analog Power, 3.3V AVDD DAC Analog Power, 3.3V 2-4 Pins Silicon Motion®, Inc. Signal Name Type LynxEM+ DataBook Pull-up/ Pull-Down IOL (mA) Max. Load (pF) Description RVDD RAM Filtered Palette Power, 3.3V CVSS PLL Analog Ground AVSS1 DAC Analog Ground AVSS2 DAC Analog Ground RVSS RAM Filtered Palette Ground VDD Digital 3.3V Core Power Supply Digital 3.3V Internal Memory Power Supply VSS Digital Ground Pins 2-5 Silicon Motion®, Inc. 1 2 LynxEM+ DataBook 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 MD12 MD3 MD4 MD5 MD7 MD31 MD17 MD28 MD20 MD25 MD22 AD0 AD4 AD7 AD9 AD12 AD14 PAR ~FRAME B MD2 MD0 MD11 MD9 MD8 ~DQM3 MD30 MD18 MD27 MD21 MD24 AD1 AD5 ~BE0 AD10 AD13 ~BE1 ~TRDY ~STOP AD16 B C MD15 MD1 MD13 MD10 MD6 ~DQM2 MD16 MD29 MD19 MD26 MD23 AD3 AD6 AD8 AD11 AD15 ~DEVSEL ~IRDY AD17 AD18 C D N/C ~CS0 ~DQM1 MD14 VDD VSS MVDD N/C MVDD VSS VSS AD2 HVDD VSS HVDD VDD VSS HVDD AD19 AD20 AD21 D E ~WE BA ~DQM0 VSS VSS AD22 AD23 IDSEL E MA5 ~CAS ~RAS MVDD HVDD ~BE3 AD24 AD25 F G MA7 MA3 MA4 VSS VDD AD26 AD27 AD28 G H MA1 MA8 MA2 MA6 VSS AD29 AD30 AD31 H J SDCKEN SDCK MA9 MA0 HVDD ~REQ ~GNT CLK J K N/C ~ROMEN DSF VSS ~RST ~INTA REFCLK K L MD55 MD56 MD54 VSSA MCKIN ~PDOWN ~CLKRUN ~EXCKEN L M MD57 MD53 MD58 VDD N/C PALCLK VREF HREF BLANK M N MD52 MD59 MD51 VSS P4 P1 P0 PCLK N P MD60 MD50 MD61 MVDD N/C P5 P3 P2 P R MD49 MD62 MD48 ~DQM7 VPVDD P8 P7 P6 R T MD63 ~DQM6 MD39 VSS N/C P12 P10 P9 T U MD40 MD38 MD41 MD43 MVDD N/C FDA22 N/C FPVDD N/C N/C FPVDD N/C FPVDDEN CVSS AVSS1 USR0 TEST1 P13 P11 U V MD37 MD42 MD34 MD33 ~DQM5 FPSCLK FDA23 FDA19 FDA16 FDA13 FDA8 FDA5 FDA2 VBIASEN CVDD RVSS BLUE USR1 TEST0 P14 V W MD36 MD46 MD45 MD47 LP DE FDA21 FDA18 FDA15 FDA12 FDA9 FDA6 FDA3 FDA0 CRTH SYNC RVDD IREF RED P15 USR2 W Y MD35 MD44 MD32 ~DQM4 FP FPEN FDA20 FDA17 FDA14 FDA11 FDA10 FDA7 FDA4 FDA1 CRTV SYNC CKIN AVDD GREEN AVSS2 USR3 Y 16 17 18 19 A F 1 2 3 SM712 TOP VIEW N/C 4 5 6 7 8 9 10 11 12 13 14 15 ~BE2 A 20 Figure 2: SM712 Pin Diagram for 256 BGA Package N/C = Not Connected but compatible with SM810. 2-6 Pins Silicon Motion®, Inc. LynxEM+ DataBook Table 3: SM712 Pin Diagram for 256 BGA Package # SM712 Name A1 MD12 {Function1} {Function2} {Function3} {Function4} VDD A2 MD3 {ROM} MVDD A3 MD4 ROMD4 MVDD A4 MD5 ROMD5 MVDD A5 MD7 ROMD7 MVDD A6 MD31 MVDD A7 MD17 MVDD A8 MD28 MVDD MVDD A9 MD20 MVDD A10 MD25 MVDD A11 MD22 MVDD A12 AD0 HVDD A13 AD4 HVDD A14 AD7 HVDD A15 AD9 HVDD A16 AD12 HVDD A17 AD14 HVDD A18 PAR HVDD A19 ~FRAME HVDD A20 C/~BE2 HVDD B1 MD2 ROMD2 MVDD B2 MD0 ROMD0 MVDD B3 MD11 MVDD B4 MD9 MVDD B5 MD8 MVDD B6 ~DQM3 MVDD B7 MD30 MVDD B8 MD18 MVDD B9 MD27 MVDD B10 MD21 MVDD B11 MD24 MVDD B12 AD1 HVDD B13 AD5 HVDD B14 C/~BE0 HVDD B15 AD10 HVDD B16 AD13 HVDD B17 C/~BE1 HVDD B18 ~TDRY HVDD B19 ~STOP HVDD B20 AD16 HVDD C1 MD15 MVDD Pins 2-7 Silicon Motion®, Inc. LynxEM+ DataBook # SM712 Name {Function1} {Function2} {Function3} {Function4} VDD C2 MD1 ROMD1 C3 MD13 C4 MD10 C5 MD6 C6 ~DQM2 MVDD C7 MD16 MVDD C8 MD29 MVDD C9 MD19 MVDD C10 MD26 MVDD C11 MD23 MVDD C12 AD3 HVDD C13 AD6 HVDD C14 AD8 HVDD C15 AD11 HVDD C16 AD15 HVDD C17 ~DEVSEL HVDD C18 ~IDRY HVDD C19 AD17 HVDD C20 AD18 HVDD D1 N/C MVDD D2 ~DQM1 MVDD D3 MD14 MVDD D4 VDD D5 VSS D6 MVDD D7 N/C D8 MVDD D9 VSS D10 VSS D11 AD2 D12 HVDD D13 VSS D14 HVDD D15 VDD MVDD MVDD MVDD ROMD6 MVDD HVDD D16 VSS D17 HVDD D18 AD19 HVDD D19 AD20 HVDD D20 AD21 HVDD E1 ~WE MVDD E2 BA MVDD E3 ~DQM0 MVDD 2-8 Pins Silicon Motion®, Inc. # SM712 Name E4 VSS E17 VSS LynxEM+ DataBook {Function1} {Function2} {Function3} {Function4} VDD E18 AD22 HVDD E19 AD23 HVDD E20 IDSEL HVDD F1 MA5 MVDD F2 ~CAS MVDD F3 ~RAS MVDD F4 MVDD F17 HVDD F18 C/~BE3 HVDD F19 AD24 HVDD F20 AD25 HVDD G1 MA7 MVDD G2 MA3 MVDD G3 MA4 MVDD G4 VSS G17 VDD G18 AD26 HVDD G19 AD27 HVDD G20 AD28 HVDD H1 MA1 MVDD H2 MA8 MVDD H3 MA2 MVDD H4 MA6 MVDD H17 VSS H18 AD29 HVDD H19 AD30 HVDD H20 AD31 HVDD J1 SDCKEN MVDD J2 SDCK MVDD J3 MA9 MVDD J4 MA0 MVDD J17 HVDD J18 ~REQ HVDD J19 ~GNT HVDD J20 CLK HVDD K1 NC K2 ~ROMEN MVDD K3 DSF MVDD K4 N/C K17 VSS Pins 2-9 Silicon Motion®, Inc. LynxEM+ DataBook # SM712 Name {Function1} {Function2} {Function3} {Function4} VDD K18 ~RST HVDD K19 ~INTA HVDD K20 REFCLK HDD L1 MD55 MVDD L2 MD56 MVDD L3 MD54 MVDD L4 VSS L17 MCKIN/LVDSCK L18 ~PDOWN HVDD L19 ~CLKRUN / ACTIVITY HVDD L20 ~EXCKEN HVDD M1 MD57 MVDD M2 MD53 MVDD M3 MD58 MVDD M4 VDD M17 N/C {ZV IN} {TESTMODE1} {VP OUT} M18 VREF VS TD19 R2 VPVDD M19 HREF HREF {External TV encoder} TD18 R3 VPVDD M20 BLANK/TVCLK TVCLK TD17 BLANK VPVDD N1 MD52 MVDD N2 MD59 MVDD N3 MD51 N4 VSS N17 P4 UV4 Ge4 TD4 B3 VPVDD N18 P1 UV1 Be5 TD1 B6 VPVDD Be4 MCKIN LVDSCK HVDD MVDD {TFT 18x2} N19 P0 UV0 N20 PCLK PCLK TD0 B7 VPVDD TD16 PCLK VPVDD P1 MD60 MVDD P2 MD50 MVDD P3 MD61 MVDD P4 MVDD P17 N/C {ZV IN} P18 P5 UV5 Ge5 TD5 B2 VPVDD P19 P3 UV3 Bo5 TD3 B4 VPVDD P20 P2 UV2 Bo4 TD2 B5 VPVDD R1 MD49 MVDD R2 MD62 MVDD R3 MD48 MVDD 2 - 10 Pins Silicon Motion®, Inc. # SM712 Name R4 ~DQM7 R17 VPVDD LynxEM+ DataBook {Function1} {Function2} {Function3} {Function4} VDD MVDD R18 P8 Y0 Re4 TD8 G5 VPVDD R19 P7 UV7 Go5 TD7 G6 VPVDD R20 P6 UV6 Go4 TD6 G7 VPVDD T1 MD63 T2 ~DQM6 {ROM} MVDD T3 MD39 ROMA7 MVDD T4 VSS T17 N/C MVDD {ZV IN} T18 P12 Y4 TD12 R7 VPVDD T19 P10 Y2 Ro4 TD10 G3 VPVDD T20 P9 Y1 Re5 TD9 G4 VPVDD {ROM} U1 MD40 ROMA8 MVDD U2 MD38 ROMA6 MVDD U3 MD41 ROMA9 MVDD U4 MD43 ROMA11 MVDD U5 MVDD U6 N/C {DSTN} U7 FDATA22 UD10 U8 N/C RB5 Ro2 R6 FPVDD RB4 U9 FPVDD U10 N/C GB4 U11 N/C BB5 U12 FPVDD U13 N/C U14 FPVDDEN BA4 U15 CVSS U16 AVSS1 {I2C/DDC} {USR CFG} U17 USR0/SCL SCL (Prim) USR0 U18 TEST1 {ZV IN} U19 P13 Y5 {TFT18x2} TD13 R6 VPVDD U20 P11 Y3 Ro5 TD11 G2 VPVDD V1 MD37 ROMA5 MVDD V2 MD42 ROMA10 MVDD V3 MD34 ROMA2 MVDD V4 MD33 ROMA1 MVDD V5 ~DQM5 {DSTN} MVDD V6 FPSCLK XCK V7 FDATA23 UD11 VPVDD TEST1 VPVDD {ROM} Pins Ro3 CK FPVDD R7 FPVDD 2 - 11 Silicon Motion®, Inc. LynxEM+ DataBook # SM712 Name {Function1} {Function2} V8 FDATA19 UD7 V9 FDATA16 V10 V11 {Function3} {Function4} VDD Re3 R3 FPVDD UD4 Re0 R0 FPVDD FDATA13 UD1 Go1 G5 FPVDD FDATA8 LD8 Ge0 G0 FPVDD V12 FDATA5 LD5 Bo1 B5 FPVDD V13 FDATA2 LD2 Be2 B2 FPVDD V14 VBIASEN V15 CVDD FPVDD V16 RVSS V17 BLUE {I2C/DDC} {USR CFG} V18 USR1/SDA SDA (Prim) USR1 V19 TEST0 {ZV IN} TEST0 V20 P14 Y6 TD14 VPVDD VPVDD R5 VPVDD {ROM} W1 MD36 ROMA4 MVDD W2 MD46 ROMA14 MVDD W3 MD45 ROMA13 MVDD W4 MD47 ROMA15 MVDD W5 LP/ FHSYNC LP FHSYNC FPVDD W6 M/ DE M/DE DE FPVDD W7 FDATA21 UD9 R5 FPVDD W8 FDATA18 UD6 Re2 R2 FPVDD W9 FDATA15 UD3 Go3 G7 FPVDD W10 FDATA12 UD0 Go0 G4 FPVDD W11 FDATA9 LD9 Ge1 G1 FPVDD W12 FDATA6 LD6 Bo2 B6 FPVDD W13 FDATA3 LD3 Be3 B3 FPVDD W14 FDATA0 LD0 Be0 B0 FPVDD {DSTN} Ro1 {External TV encoder} W15 CSYNC CSYNC W16 RVDD W17 IREF W18 RED W19 P15 {ZV IN} Y7 2C/DDC} {I W20 USR2 VPVDD SCL TD15 R4 VPVDD {USR CFG} USR2/NTSCPAL VPVDD {ROM} Y1 MD35 ROMA3 MVDD Y2 MD44 ROMA12 MVDD 2 - 12 Pins Silicon Motion®, Inc. LynxEM+ DataBook # SM712 Name {Function1} {Function2} Y3 MD32 ROMA0 Y4 ~DQM4 {DSTN} Y5 FP/ FVSYNC FP Y6 FPEN FPEN {TFT 18x2} Y7 FDATD20 UD8 Y8 FDATA17 {Function3} {Function4} VDD MVDD {TFT} MVDD FVSYNC FPVDD FPEN FPVDD Ro0 R4 FPVDD UD5 Re1 R1 FPVDD Y9 FDATA14 UD2 Go2 G6 FPVDD Y10 FDATA11 LD11 Ge3 G3 FPVDD Y11 FDATA10 LD10 Ge2 G2 FPVDD Y12 FDATA7 LD7 Bo3 B7 FPVDD Y13 FDATA4 LD4 Bo0 B4 FPVDD Y14 FDATA1 LD1 Be1 B1 FPVDD Y15 CRTVSYNC Y16 CKIN FPVDD Y17 AVDD Y18 GREEN Y19 AVSS2 {I2C/DDC2} {USR CFG} Y20 USR3 SDA USR3/ TVONOFF Pins VPVDD 2 - 13 Silicon Motion®, Inc. LynxEM+ DataBook LynxEM+ NAND Tree Scan Testing The LynxEM+ NAND Tree scan test circuit is designed for verifying the device being properly soldered to the board. It detects opened/shorted traces of a signal pin with a simple test pattern which, for this particular case, only ~200 vectors in length. The NAND Tree scan test circuit uses Combinational logic; therefore, no clock pulses are required during the testing. General Information The LynxEM+ NAND Tree scan test circuit is a long chain of 2-input NAND gates. The first pin of the NAND chain is an input (signal pin "MCKIN"), the last pin of the chain is an output (signal pin "BLANK"). In order to setup LynxEM+ for NAND Tree scan testing, program USR[3:0] pins to 0011h and Test[1:0] pins to 10h. ALL VDD's, VSS's, and Analog pins RED, GREEN, BLUE, IREF, and Control pins USR[3:0], Test[1:0] are not included in the scan chain. NAND Tree Pad_output Nandtree_en pad_input 1 pad_input 2 pad_input 3 pad_input N Figure 3: NAND Tree Connection Table 4: NAND Tree Scan Test Order Nand Tree Scan Pin Order # Pin Name In/Out 1 MCKIN In 2 ~PDOWN In 3 ACTIVITY In 4 EXCKEN In 5 REFCLK In 6 ~INTA In 7 ~RST In 2 - 14 8 CLK In 9 ~GNT In 10 ~REQ In 11 AD31 In 12 AD30 In 13 AD29 In 14 AD28 In 15 AD27 In 16 AD26 In 17 AD25 In 18 AD24 In Pins Silicon Motion®, Inc. Pins LynxEM+ DataBook Nand Tree Scan Pin Order # Pin Name 19 ~CBE3 In 20 IDSEL In 21 AD23 In 22 AD22 In 23 AD21 In 24 AD20 In 25 AD19 In 26 AD18 In 27 AD17 In 28 AD16 In 29 CBE2 In 30 ~FRAME In 31 ~IRDY In 32 ~TRDY In 33 ~DEVSEL In 34 ~STOP In 35 PAR In 36 ~CBE1 In 37 AD15 In 38 AD14 In 39 AD13 In 40 AD12 In 41 AD11 In 42 AD10 In 43 AD9 In 44 AD8 In 45 ~CBE0 In 46 AD7 In 47 AD6 In 48 AD5 In 49 AD4 In 50 AD3 In 51 AD2 In 52 AD1 In 53 AD0 In 54 MD23 In 55 MD24 In 56 MD22 In 57 MD25 In 58 MD21 In 59 MD26 In In/Out 2 - 15 Silicon Motion®, Inc. LynxEM+ DataBook Nand Tree Scan Pin Order # Pin Name In/Out 60 MD20 In 61 MD27 In 62 MD19 In 63 MD28 In 64 MD18 In 65 MD29 In 66 MD17 In 67 MD30 In 68 MD16 In 69 MD31 In 70 DQM3 In 71 DQM2 In 72 MD7 In 73 MD8 In 74 MD6 In 75 MD9 In 76 MD5 In 77 MD10 In 78 MD4 In 79 MD11 In 80 MD3 In 81 MD12 In 82 MD2 In 83 MD13 In 84 MD1 In 85 MD14 In 86 MD0 In 87 MD15 In 88 DQM1 In 89 DQM0 In 90 BA In 91 ~WE In 92 ~RAS In 93 ~CAS In 94 MA5 In 95 MA4 In 96 MA6 In 97 MA3 In 98 MA7 In 99 MA2 In 100 MA8 In 2 - 16 Pins Silicon Motion®, Inc. Pins LynxEM+ DataBook Nand Tree Scan Pin Order # Pin Name In/Out 101 MA1 In 102 MA9 In 103 MA0 In 104 SDCK In 105 SDCKEN In 106 DSF In 107 ~ROMEN In 108 ~CS0 In 109 MD55 In 110 MD56 In 111 MD54 In 112 MD57 In 113 MD53 In 114 MD58 In 115 MD52 In 116 MD59 In 117 MD51 In 118 MD60 In 119 MD50 In 120 MD61 In 121 MD49 In 122 MD62 In 123 MD48 In 124 MD63 In 125 DQM7 In 126 DQM6 In 127 MD39 In 128 MD40 In 129 MD38 In 130 MD41 In 131 MD37 In 132 MD42 In 133 MD36 In 134 MD43 In 135 MD35 In 136 MD44 In 137 MD34 In 138 MD45 In 139 MD33 In 140 MD46 In 141 MD32 In 2 - 17 Silicon Motion®, Inc. Nand Tree Scan Pin Order # 2 - 18 LynxEM+ DataBook Pin Name In/Out 142 MD47 In 143 DQM5 In 144 DQM4 In 145 FHSYNC In 146 FVSYNC In 147 FPSCLK In 148 DE In 149 FPEN In 150 FDATA23 In 151 FDATA22 In 152 FDATA21 In 153 FDATA20 In 154 FDATA19 In 155 FDATA18 In 156 FDATA17 In 157 FDATA16 In 158 FDATA15 In 159 FDATA14 In 160 FDATA13 In 161 FDATA12 In 162 FDATA11 In 163 FDATA10 In 164 FDATA9 In 165 FDATA8 In 166 FDATA7 In 167 FDATA6 In 168 FDATA5 In 169 FDATA4 In 170 FDATA3 In 171 FDATA2 In 172 FDATA1 In 173 FDATA0 In 174 FPVDDEN In 175 VBIASEN In 176 CRTVSYNC In 177 CRTHSYNC In 178 P15 In 179 P14 In 180 P13 In 181 P12 In 182 P11 In Pins Silicon Motion®, Inc. Pins LynxEM+ DataBook Nand Tree Scan Pin Order # Pin Name In/Out 183 P10 In 184 P9 In 185 P8 In 186 P7 In 187 P6 In 188 P5 In 189 P4 In 190 P3 In 191 P2 In 192 P1 In 193 P0 In 194 PCLK In 195 VREF In 196 HREF In 197 BLANK Out 2 - 19 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 3: Initialization LynxEM+ generates an internal power-on reset during system power-on. After receiving the system ~RESET signal, LynxEM+ will release its internal power-on reset circuit and enter the RESET period until the host de-asserts the ~RESET signal. During the RESET period, LynxEM+ resets its internal state machines and registers to the power-on default states. During power-on, LynxEM+ is configured based on configuration lines MD [22:0]. Table 5 (see end of this section) provides a detailed description of each configuration line. All MD (memory data) lines have internal pull-up resistors on I/O pads which are latched into the corresponding register as logic "1" on the rising edge (trailing edge) of the ~RESET. To set a specific bit as logic "0" during power-on reset, an external pull-down resistor must be added on the corresponding MD line. In addition to power-on configuration, LynxEM+ performs an initialization sequence for the 2MB or 4MB of internal memory. Figure 4 illustrates the power-up sequence. • • • • • DQM and SDCKEN signals go HIGH, initially tracking VCC. 200ms delay PRECHARGE command for all banks LOAD MODE REGISTER command 8 AUTO REFRESH cycles After memory initialization has been completed, LynxEM+'s video BIOS is ready to service system BIOS requests. System BIOS passes a pointer to the LynxEM+ video BIOS to start the video BIOS initialization sequence. SDCK SDCKEN COMMAND NOP MA MD PRECHARGE LOAD MODE REGISTER BOTH BANKS CODE NOP AUTO REFRESH NOP AUTO REFRESH NOP ACTIVE BANK ROW High-Z T=200us POWER-UP VCC and SDCLK stable tRP PRECHARGE tMTC Program Mode Register tRC 1st AUTO REFRESH Cycle tRC 8th AUTO REFRESH Cycle Figure 4: External SGRAM Power-Up and Initialization Sequence Initialization 3-1 Silicon Motion®, Inc. LynxEM+ DataBook Figure 5 illustrates the LynxEM+ Video BIOS initialization flow. The initialization sequence consists of the following stages: • • • • • Determine memory size Check for display type. (FPR31 [2:0]) LCD only, CRT only, LCD and CRT or LCD and TV, etc. Program the appropriate timing registers based on the display type Set to mode 3h to display characters on the display for users to read Pass the pointer back to system BIOS Start Turn off display 3C5.1=20h Unlock extended reg 3C3=40h yes CFG_Flag no Over-write MD lines Int 15 Panel ID no yes Write MD[19:16] based on Panel ID Read MD settings Determine memory size Determine panel size and type initialize panel (load FPR30,32,34-57) Load CFG table (set MCLK, scratch-bits, etc.) Initialize INT 10h Initialize BIOS data area Set mode 3 Turn on display by setting FPR31 Display banner Done Figure 5: LynxEM+ BIOS Initialization Flowchart 3-2 Initialization Silicon Motion®, Inc. LynxEM+ DataBook LynxEM+ Power-On Configurations • • • All MD (memory data) lines have internal pull-up resistors on I/O pads. 0 = external pull-down resistor (recommended value is 1K ohm) 1 = no external pull-down resistor Table 5: Power-On Configurations Signal Name Read/Write Register Bits Address CPR00 [25] LynxEM+ Description MD [23] R 0 = External memory access only 1 = Allows both internal and external memory access (default) MD [22] CONFIG ONLY 0 = 32K 1 = 64K BIOS size default MD [21] 1 CONFIG ONLY EBROM Generate 0 = EBROM 1 = no EBROM (default) MD [20] 1 CONFIG ONLY Expansion ROM 0 = Expansion ROM 1 = no Expansion ROM (default) MD [19:16] R/W GPR70 [3:0] 3C5h.70 User configuration Bits MD15 R/W FPR30 [7] 3C5h.30 DSTN Interface Type 0 = 16-bit interface 1 = 24-bit interface MD [14:12] R/W FPR30 [6:4] 3C5h.30 Color TFT Interface Type 000 = 9-bit, 3-bit per R, G, B 001 = 12-bit, 4-bit per R, G, B 010 = 18-bit, 6-bit per R, G, B 011 = 24-bit, 8-bit per R, G, B 100 = 24-bit, (12+12-bit, 2 pixels/clock) 101 = Analog TFT w/ analog R, G, B interface 110 = 36-bit, (18+18-bit, 2 pixels/clock) MD [11:10] R/W FPR30 [3:2] 3C5h.30 LCD Display Size 00 = 640 x 480 01 = 800 x 600 10 = 1024 x 768 MD9 R/W FPR30 [1] 3C5h.30 TFT FPCLK Select 0 = Normal 1 = Inverted MD8 R/W FPR30 [0] 3C5h.30 Color LCD Type 0 = color TFT 1 = color STN MD7 R/W MCR62 [7] 3C5h.62 Internal Logic 0 = Internal logic will be running 1/2X MCLK 1 = Internal logic will be running 1X MCLK MD6 R/W MCR62 [6] 3C5h.62 Enable Memory Data Bus 0 = Enable 32-bit memory data bus 1 = Enable 64-bit memory data bus MD [5:4] R/W MCR62 [5:4] 3C5h.62 External SGRAM Memory Column Address Select 11 = 8-bit column address 10 = 9-bit column address 0x = 10-bit column address Memory Pre-charge Timing Select Reserved Initialization 3-3 Silicon Motion®, Inc. Signal Name Read/Write LynxEM+ DataBook Register Bits Address LynxEM+ Description MD2 R/W MCR62 [2] 3C5h.62 External Memory Enable 0 = Enable external 32-bit memory 1 = Disable external 32-bit memory MD1 R/W MCR62 [1] 3C5h.62 External SGRAM Memory Active-to-Precharge Delay Select 0 = 7 MCLK 1 = 6 MCLK MD0 R/W MCR62 [0] 3C5h.62 External SGRAM Memory Refresh to Command Delay 0 = 10 MCLK 1 = 9 MCLK 3-4 Initialization Silicon Motion®, Inc. LynxEM+ DataBook Chapter 4: PCI Bus Interface LynxEM+ provides a glue-less interface to the PCI system bus, and the PCI Host Interface Unit supports burst read and burst write for master mode and burst write for slave mode. To maximize performance, the Host Interface unit also supports burst write and burst read with Read Look Ahead. The LynxEM+ is fully compliant with PCI Verison 2.1, but does not have 5V tolerant I/O cell. If the LynxEM+ is used with 5V PCI then it will need an external glue-logic. The LynxEM+'s PCI Host Interface Unit manages data transfer between the external PCI bus and internal Host Interface (HIF) bus. All functional blocks, with the exception of the Drawing Engine, are tied to the HIF bus through a proprietary protocol. Separate decode logic and a dedicated FIFO are used for the Drawing Engine. In addition to PCI Configuration Space Registers, the PCI Host Interface Unit contains Power Down Control Registers (PDR20-PDR23) and System Control Registers (SCR10-SCR1A). These Registers may accessed by the CPU even while internal PLLs are turned off. PCI Configuration Registers The PCI configuration registers are designated CSR00 - CSR3D. A brief description of key elements of the register set follows: • • • • • • Vendor ID register (CSR00) - hardwired to 126Fh to identify Silicon Motion, Inc. as the chip vendor. Device ID register (CSR02) - hardwired to 0810h to identify the LynxEM+ device. The ~DEVSEL timing in the Status register (CSR06) - hardwired to 01b, which indicates medium speed for ~DEVSEL. Class Code register (CSR08) - hardwired to 030000h to specify LynxEM+ as a VGA compatible device. Bit [7:0] used to identify the revision of the LynxEM+. Memory Base Address register (CSR10) - specifies the PCI configuration space for address relocation. After poweron, the register defaults to 00h, which indicates the base register can be located anywhere in a 32-bit address space and that the base register is located in memory space. Subsystem Vendor ID and Subsystem ID (addressable at CSR2C and CSR2E respectively) - 32-bit read only registers. These registers are used to differentiate between multiple graphics adapters within the same system. PCI Bus Interface 4-1 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 5: Display Memory Interface Memory Configuration The LynxEM+ supports a 2 or 4 Mbytes of memory. There are three memory configurations: 1. 2. 2 Mbytes internal memory only 4 Mbytes of internal memory (there is no option for external memory with this configuration) The internal memory is 2 or 4 Mbytes of 512Kx32 SGRAM. The LynxEM+ single cycle interface may be clocked up to 129 MHz, which provides over 516 MB/s. The LynxEM4+ single cycle interface may be clocked up to 86 MHz, which provides over 688 MB/s. The LynxEM+ supports a total 2 Mbytes external memory composed of 256Kx32 SGRAM. Page Break Look Ahead For standard architectures, the memory controller will break cycle when the bus agent changes. LynxEM+ can allow a "No Wait Cycle" during agent changes if the preceding and current agents are in the same page. Both the internal memory bus and external memory bus support this capability. Memory Timing Control Memory timing control is configurable via MD[7:0] during power-on reset. See Table 5 in the Initialization section for a complete description of these memory configuration bits. Note: All MD lines have internal pull-up resistors on I/O pads. The default configuration is therefore a logical "1" during power-on reset. To set an MD line to 0, an external pull-down resistor needs to be added. After power-on initialization, software can be used to overwrite the initial setting by writing to MCR62 -- bits 7-0 correspond to MD[7:0]. Display Memory Interface 5-1 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 7: Video Processor LynxEM+'s Video Processor manages video data streams, as well as graphics data streams in non-VGA modes. The Video Processor can process two independent video data streams. The two video windows (primary and secondary) can be displayed at any screen location with any size, and can be overlaid with graphics data. Within the Video Processor, the Graphics Source Control block, Video Window I Control block, Video Window II Control block, and HW Pop-up Icon Control block all have independent Starting Address and Offset Address registers. This means that each control block can fetch data from any display memory location. Video Window I source control block supports double-buffered video capture. Internal logic automatically detects the control/status bits of the two capture buffers and fetches the captured video data from the buffer which is not used. The Video Processor supports TV flicker reduction for direct color modes (64K colors or 16M colors), as well as index color modes (256 colors and 16 colors). A special data path is designed to feed the outputs of the color palette RAM back to the TV Flicker Reduction block. The TV Overscan & Underscan Control block is used to convert 480 lines into 400 visible lines on NTSC TV display. The same function can also be used on PAL TV display. When the TV display is enabled, the Shadow registers need to be locked as 640 x 480 mode (or 720 x 525 for PAL). From VGA Core 8 8 HW Pop-Up Icon Control TV Flicker Reduction Display Memory 64 Graphics Source Control 64 Video Window I Source Control To Multimedia RAMDAC Block TV Overscan & Underscan Control 24 Color Key Horizontal Color Interpolation & Scaling 64 Video Window II Source Control Display Control YUV to RGB Vertical Color Interpolation & Scaling Figure 6: Video Processor Block Diagram Video Processor 7-1 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 6: Drawing Engine LynxEM+'s Drawing Engine is designed to accelerate Microsoft's DirectDraw applications. The engine contains a 3operand ALU with 256 raster operations, source and destination FIFOs, as well as a host data FIFO. The drawing engine pipeline allows single cycle operations and runs at the memory clock speed. LynxEM+'s Drawing Engine includes several key functions to achieve the high GUI performance. The device supports color expansion with packed mono font, color pattern fill, host BLT, stretch BLT, short stroke, line draw, and others. Dedicated pathways are designed to transfer data between host interface (HIF) bus and Drawing Engine, and memory interface (MIF) bus and Drawing Engine. In addition, the drawing engine supports rotation BIBLT for any block size, and automatic self activate rotation BLIT. This feature allows conversion between landscape and portrait display without the need for special software drivers. LynxEM+ also supports fast DMA BLT, source clear during BLT, transparent BLT, programmable blter stride, page flip, and current scan line refresh. LynxEM+'s Drawing Engine is also used to bus master captured data to the hard disk drive or to system memory during video capture. To accomplish this, the video capture driver turns on the Drawing Engine Capture Enable bit (DPR0E bit4), selects HOST BLT Read command function (DPR0E [3:0]), and enables PCI bus master mode (SCR17 bit 6). The Video Capture Unit loads the incoming video stream into Capture Buffer 1 or 2, depending on which is idle (VPR3C bit 1 or bit 2 = 0 indicates idle status). The Drawing Engine resets Capture Buffer I or Capture Buffer II control/Status bit to 0 (VPR3C bit 1 or bit 2) after a transfer has completed. Drawing Engine 6-1 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 8: Zoom Video Port and Video Capture Unit Zoom Video Port LynxEM+'s Zoom Video Port (ZV Port) is designed to interface with video solutions implemented as PCMCIA (or PC CardBus) cards: examples are NTSC/PAL decoders, MPEG-2 decoders, and JPEG Codecs. The ZV Port can also directly interface with an NTSC/PAL decoder, such as Phillips 7111 or BT819. Figure 7 illustrates an example of the Phillips video encoder interface via the ZV Port. Incoming video data from the ZV Port interface can be YUV or RGB format. The data can be interlaced or noninterlaced. The ZV Port can be configured for output if the video capture function is disabled. 18-bit graphics and video data in RGB format can be sent out when the ZV Port is configured for output mode. The ZV Port may also be configured as a test port. Up to 20 signals from each of the logic blocks within the LynxEM+ can be brought out to an internal test bus (TD Bus) connected to the ZV Port. System designers or silicon validation engineers can access these signals by setting the TEST0, TEST1, USR0, USR1, and USR2 pins. This approach can bring out a total of 180 internal signals to the primary I/O pins. The test port capability can be used to enhance fault coverage, as well as reduce silicon validation or debugging time. Table 6 lists signal definitions for the following ZV Port interface configurations: YUV input mode, RGB input mode, and graphics/video (output mode). Philips SAA7110/ SAA7111 Video NTSC/PAL RF Signal LynxEM+ Y [7:0] Y [7:0] UV[7:0] UV[7:0] HREF HREF VS VREF LLC PCLK SDA SDA SCL SCL Figure 7: Video Encoder Interface via Video Port Zoom Video Port and Video Capture Unit 8-1 Silicon Motion®, Inc. LynxEM+ DataBook Table 6: LynxEM+ Video Port Interface I/O Configurations Video Port Interface ZV Port (Input mode) I/O NTSC/PAL Decoder (Input mode) I/O Graphics/Video (Output mode) I/O VREF VS I VS I R2 O HREF HREF I HREF I R3 O BLANK (note1) BLANK O PCLK PCLK I PCLK I PCLK O P15 UV7 I R7 I R4 O P14 UV6 I R6 I R5 O P13 UV5 I R5 I R6 O P12 UV4 I R4 I R7 O P11 UV3 I R3 I G2 O P10 UV2 I G7 I G3 O P9 UV1 I G6 I G4 O P8 UV0 I G5 I G5 O P7 Y7 I G4 I G6 O P6 Y6 I G3 I G7 O P5 Y5 I G2 I B2 O P4 Y4 I B7 I B3 O P3 Y3 I B6 I B4 O P2 Y2 I B5 I B5 O P1 Y1 I B4 I B6 O P0 Y0 I B3 I B7 O (note1) Note 1: BLANK pin can used as TVCLK output, which is independent of ZV port. Video Capture Unit The Video Capture Unit captures incoming video data from the ZV Port and then stores the data into the frame buffer. The Video Capture Unit support several features to maintain display quality, and balance the capture rate: • • • • • • • 2-tap, 3-tap, and 4-tap horizontal filtering 2 to 1 and 4 to 1 reduction for horizontal and vertical frame size YUV 4:2:2, YUV 4:2:2 with byte swap, RGB 5:5:5, and RGB 5:6:5 Multiple frame skipping methods Interlaced data and non-interlaced data capture Single buffer and double buffer capture Cropping LynxEM+ uses the Video Processor block to display the captured data on the LCD, TV, or CRT display. The captured data can be displayed through Video Window I or Video Window II. The stretching, color interpolation, YUV-to-RGB conversion, and color key functions are performed in the Video Processor. LynxEM+'s Video Processor can simultaneously process captured video data and perform CD-ROM playback on two independent video windows. LynxEM+ also supports real-time video capture to the hard drive or system memory through PCI master mode or slave mode. In PCI bus master mode, LynxEM+ uses the Drawing Engine's Host BLT and Host DMA functions to maximize performance. 8-2 Zoom Video Port and Video Capture Unit Silicon Motion®, Inc. LynxEM+ DataBook Functional Description LynxEM+'s Video Capture Unit supports the Video Port Extension (VPE) specification for video stream processing. This capture unit includes CLIP block, FILTER block, SHRINK block, and FIFO control block. Figure 8 and Figure 9 illustrate the LynxEM+ Video Capture Block Diagram and Data Flow. The CLIP functional block is used to select the desired rectangles from the video stream to be captured. VPR40 register (Video Source Clipping Control) is used to define the upper left corner of the rectangle from the video source. VPR44 register (Video Source Capture Size Control) is used to define the height and width of the rectangle from the video source. Video Stream from ZV Port Display Memory CLIP On Screen Graphics FILTER SHRINK Capture Buffer I VPR48 FIFO Capture Buffer II Drawing Engine PCI Bus Interface Block VPR1C Video Window I VPR30 Video Window II VPR4C Figure 8: Video Capture Block Diagram The FILTER functional block controls horizontal filtering logic. VPR3C (Capture Port Control) bit 21 and bit 20 are used to select 2 tap, 3 tap, and 4 tap filtering. The SHRINK functional block is used to not only reduce the storage area for both display memory and hard drive, but also increase performance of video capture and video playback. VPR3C bit 19 and 18 are used to enable vertical reduction, and bit 17 and bit 16 are used to enable horizontal reduction. With filter and shrink functions, LynxEM+ is able to achieve high video capture performance and maintain optimal video playback quality. VPR3C bit 13 to bit 11 are use to select 8 different frame skipping options in the event the capture rate is less than the incoming video stream. CPR00 bit 10 and bit 9 are used to support interlaced capture and double buffer capture. CPR00 bit 1 and bit 2 are used as control/status bits for Buffer I and Buffer II. The captured data can be displayed on either Video Window I or Video Window II. The video capture driver needs to program VPR1C (or VPR30), Video Window I (or II) Source Start Address, with the same address value from Capture Port Buffer I or II Start Address register. VPR00 (Miscellaneous Graphics and Video Control) bit 24 may be used to automatically display the capture data on Video Window I without programming VPR1C register. This feature is independent of single buffer or double buffer mode. If double buffer mode is at Video Window I, it will display the buffer which is not currently used to capture data. This feature allows the user to capture interlaced data and together with programming VPR24 bit [23:16] and VPR24 bit [31:24] it will display BOB implementations on Video Window I. Zoom Video Port and Video Capture Unit 8-3 Silicon Motion®, Inc. LynxEM+ DataBook From V ideo Su p p CPR04 [9:0] lier CPR04 [25:16] CPR08 [10:0] cropping filtering & scaling CPR08 [26:16] capture data capture buffer Figure 9: Video Capture Data Flow Theory of Operation Initialization • Enable Video Capture (CPR00 bit 0 = 1) • Preset Buffer I and Buffer II Status/Control bits (CPR00 [2:1] = 11b) • Enable Drawing Engine (DPR0E bit 4 = 1) • Select Host BLT Read Command function (DPR0E [3:0] =9h) • Enable PCI bus master mode (SCR17 bit 6 = 1) • Select Field Detection, VREF/HREF polarity, Vertical/Horizontal Reduction, Horizontal Filtering, Video Capture Input Data Format, Frame Skip, Interlaced/non-interlaced and other miscellaneous settings (CPR00, Capture Port Control Register) 8-4 Zoom Video Port and Video Capture Unit Silicon Motion®, Inc. LynxEM+ DataBook Table 7: Bit Setting Summary for Video Capture B1S Buffer 1 Status/Control (CPR00 bit 1) B2S Buffer 2 Status/Control (CPR00 bit 2) Continuous Capture CPR00bit 8 = 0 Conditional Capture CPR00 bit 8 = 1 Single Buffer CPR00 bit 9 = 0 Double Buffer CPR00 bit 9 = 1 Non-interlaced Mode CPR00 bit 10 = 0 Interlaced Mode CPR00 bit 10 = 1 The Video Capture Unit supports the following types of capture modes: • • • • • Single Buffer Mode with Continuous Capture Single Buffer Mode with Conditional Capture Double Buffer Mode with Continuous Capture Double Buffer Mode with Conditional Capture Interlace and Non-Interlaced Mode A Summary of each of the video capture modes follows: • Single Buffer Mode with Continuous Capture Video Capture Unit (VCU) 3. 4. • Drawing Engine (DE) Continuously capture incoming video data to capture buffer 1 Independent of B1S and B2S bits It is not recommended to use the Drawing Engine to transfer captured data from display memory to hard drive or system memory in this mode. This mode is used to view the captured data only. 4. 1. 2. 3. 4. VPR00 bit 24 = 0 Captured data can be displayed on either Video Window I or Video Window II by setting video window start address register. VPR00 bit 24 = 1 Captured data is automatically displayed on Video Window I. Single Buffer Mode with Conditional Capture Video Capture Unit (VCU) 1. 2. 3. Video Processor (VP) VCU monitors B1S bit If B1S = 1, start capture VCU will reset B1S to 0 after it completes a frame Go to step “a” Drawing Engine (DE) 1. 2. 3. 4. Zoom Video Port and Video Capture Unit 1. Test If B1S = 0, SW will activate the DE 2. to transfer captured data from capture buffer 1 to hard drive or system memory 3. DE will set B1S bit to 1 after it 4. completes a frame Go to step "a” Video Processor (VP) VPR00 bit 24 = 0 Captured data can be displayed on either Video Window I or Video Window II by setting video window start address register. VPR00 bit 24 = 1 Captured data is automatically displayed on Video Window I 8-5 Silicon Motion®, Inc. • LynxEM+ DataBook Double Buffer Mode with Continuous Capture Video Capture Unit (VCU) 1. Drawing Engine (DE) 3. Continuously capture the incoming video data into capture buffer 1 or buffer 2 Automatically switch from one buffer to the other when VCU completes a frame Independent of B1S and B2S bits • Double Buffer Mode with Conditional Capture 2. It is not recommended to use DE to 1. transfer captured data from display 2. memory to hard drive or system memory in this mode. This mode is used to view the captured data only. 3. 4. 5. Video Capture Unit (VCU) 1 2. 3. 4. 5. VCU monitors B1S and B2S bits If B1S (or B2S) = 1, start video capture and store into capture buffer 1 (or buffer 2). VCU will reset B1S (or B2S) to 0 after it completes a frame VCU will continue video capture if B1S or B2S = 1 Go to step "a" if both bits = 0 Drawing Engine (DE) 1. 2. 3. 4. 5. 6. • Video Processor (VP) VPR00 bit 24 = 0 Captured data can be displayed on either Video Window I or Video Window II by setting video window start address register. VPR00 bit 24 = 1 Captured data is automatically displayed on Video Window I. If capture buffer 1 is used by VCU, Video Window I will display captured data from capture buffer 2 Video Processor (VP) 1. SW monitors B1S or B2S bit 2. If B1S (or B2S) = 0, SW will activate the DE to transfer captured data from capture buffer 1(or buffer 2) to hard drive or system memory DE will set B1S (or B2S) bit to 1 3. 4. after it completes a frame 5. DE will continuously transfer Data from capture buffer 1 or 2 if B1S or B2S = 0 Go to step "a " if both bits = 1 VPR00 bit 24 = 0 Captured data can be displayed on either Video Window I or Video Window II by setting video window start address register. VPR00 bit 24 = 1 Captured data is automatically displayed on Video Window I. If capture buffer 2 is used by VCU, Video Window I will display captured data from capture buffer 1. Interlaced Capture CPR00 bits 10 are used to select the interlaced capture mode. In most of video capture applications, an interlaced video stream will be treated as non-interlaced video stream by dropping all even frames (CPR00[13:11] = 010b), or dropping all odd frames (CPR00[13:11] = 011). This approach will reduce artifacts when playing back the captured data. However, in some video capture applications, de-interlacing is needed to handle the incoming interlaced video stream. For the de-interlacing case, CPR00 bit 10 needs to be set to 1 to enable interlaced capture for incoming interlaced video stream. The double buffer mode (CPR00 bit 9 = 1) needs to be turned on at the same time. Capture Buffer 1 and Capture Buffer 2 are combined together as a single buffer with one line offset. Figure 9 illustrates the capture buffer structure. The video capture driver will preset B1S and B2S bits to 1 to initialize the buffer 1 and 2 status/control bits. The Video Capture Unit will start video capture if any one of B1S and B2S = 1. After VCU fills capture buffer 1 and 2, both B1S and B2S bits are set to "0" by VCU. The video capture driver will activate Drawing Engine to transfer captured data in capture buffer 1 and 2 to system memory or hard drive when both B1S and B2S are "0". After the completion of the transfer, the Drawing Engine will set both B1S and B2S to "1". The Video Capture Unit then continues video capture and repeats the same protocol. During video playback, the captured data can be displayed on either Video Window I or Video Window II. It is not recommended to display both even frame and odd frame for video playback. The video captured driver can program Video Window I (or II) Source Start Address Register and Video Window I (or II) Source Width and Offset Register in such a way that odd frame (or even frame) captured data will be dropped during video playback. The scaling, color interpolation, and YUV-to-RGB conversion functions can also be enabled at the same time. 8-6 Zoom Video Port and Video Capture Unit Silicon Motion®, Inc. LynxEM+ DataBook Even Field From Video Capture Unit To Drawing Engine or Video Processor Odd Field Even Field Capture Buffer 1 Capture Buffer 2 Even Field Odd Field Even Field Figure 10: Capture Buffer Structure in Interlaced Mode Zoom Video Port and Video Capture Unit 8-7 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 9: Flat Panel Interface LynxEM+ supports both color dual scan STN (passive) and color TFT (active) panel interface for notebook computers. It can also support color TFT panel with RGB analog interface. For color TFT panel, LynxEM+ can support single pixel per clock of 9-bit, 12-bit, 18-bit, 24-bit, or double-pixel per clock of 24-bit, 36-bit interfaces up to 1024x768 resolution. Table 8 lists the complete set of LynxEM+ panel interface pins for both color DSTN and TFT LCD. Figure 12 shows the singlepixel per clock TFT interface, Figure 13 shows the double-pixel per clock TFT interface, Figure 14 shows the 16-bit DSTN interface, and Figure 15 shows the 24-bit DSTN interface. EMI Reduction Circuit The LynxEM+ provides an EMI reduction circuit for the flat panel interface. The EMI circuit is controlled by the EMI Control Register (Address: 3C5h Index: 58h). EMI reduction control is enabled by setting bit 3 to a logical 1. When the circuit is turned on, the flat panel interface signals are driven in independent groups (e.g. for a 24-bit interface, 4 groups of 6 signals each) which are delayed by small time delta relative to one another. This approach eliminates noise peaks which occur when significant numbers of flat panel interface signals transition at the same time. The EMI spectrum is therefore flattened out and EMI is reduced. LynxEM+ Flat Panel Enhancements LynxEM+ integrates various flat panel enhancement features such as: LCD screen auto-centering, LCD screen expansion (including XY interpolated screen expansion), Virtual Refresh, and special dithering engines for TFT and DSTN flat panels. LynxEM+ Graphics/Text Expansion Information Introduction LynxEM+ provides full expansion capability for text and graphics modes. Text as well as graphics expansion is supported up to XGA resolution. Expansion is supported on TFT and DSTN panels. A detailed description of the expansion algorithms of these devices follows: Horizontal Expansion for Text and Graphics Horizontal expansion is handled in 8 pixel pieces whether the mode is text or graphics. There are two expansion mechanisms: 10-dot expansion and 12-dot expansion. 10-dot expansion is used to expand to 800 pixels, 12-dot is used to expand to 960 pixels for XGA panel sizes. For 10-dot expansion, every 4th pixel is duplicated. For example, for mode3h (80x25 text) or mode 12h(640x480 graphics), where p0 is pixel one and p7 is pixel 8 - p0p1p2p3p3p4p5p6p7p7 - the 4th pixel (p3) is duplicated, as well as the 8th pixel (p7). The pattern repeats for each 8 pixel piece. For 12-dot expansion, every other pixel, beginning with p1 is duplicated. For example, for mode 3h or mode 12h p0p1p1p2p3p3p4p5p5p6p7p7. Again, the pattern repeats for each pixel piece. Flat Panel Interface 9-1 Silicon Motion®, Inc. LynxEM+ DataBook So far, all examples assume 8x16 font size. There is also 9x16 font size to consider (in this case the actual font is still 8x16, but an additional 9th dot - either the background color or a repeat of the 8th pixel - is inserted). For 9x16 case, pixel p3 is duplicated just like 8x16 case. Pixel p7 is handled somewhat differently depending on whether the character is a text character or graphics character - for text character case, the second p7 value becomes the background color. For graphics case, p7 is repeated. Vertical Expansion for Text and Graphics Vertical expansion for text or graphics uses a Dynamic Duplication Algorithm (DDA) method to achieve expansion. The same basic methodology is used independent of resolution. First, an initial DDA constant value (for LynxEM+ this is a 10-bit value) is loaded into the Vertical Screen Expansion DDA Constant Registers. This value is used as part of a logical algorithm to determine which lines on the display to duplicate. Figure 11 is a diagram of the algorithm. ADDER NewSum [10:0] Sum [10:0] Figure 11: DDA Expansion Algorithm For each line of the display, the following equation is calculated via the illustrated algorithm: NewSum [10:0] = Sum[10:0] + DDA If Sum [10:0] = NewSum [10:0], the given line is duplicated. For text case, the DDA logic algorithm will reset each character block, so expansion is handled in terms of character rows (e.g. 25 character rows of 16 lines each). For the graphics case, the DDA logic algorithm will reset when the bottom of the display is reached. The DDA constant may be calculated by the following equation: 1024 = DDA Expanded Resolution Existing Resolution For example, to expand a 480 line mode to 768, the equation would be: 1024 = DDA 9-2 768 Lines 480 Lines Flat Panel Interface Silicon Motion®, Inc. LynxEM+ DataBook DDA constant may then be calculated and entered into the expansion algorithm. DDA[9:0] LCD Dithering Engine LynxEM+ has separate dithering engines for color DSTN LCD and color TFT LCD. The DSTN dithering engine includes a set of 32 different dithering patterns which are developed with LCD's response time and contrast ratio in mind. FPR32 bit 5 is used to select 16 gray levels or 32 gray levels for each Red, Green, and Blue color. The TFT dithering engine includes a set of 8 different dithering patterns which combine frame rate modulation and space dithering algorithm. FPR32 bit 7 and 6 are used to select 4-gray level dithering, 8-gray level dithering, and no dithering. Flat Panel Power ON/OFF Sequencing LynxEM+ integrates logic for panel power ON/OFF sequencing during power down modes and display switching. There are two ways to power ON/OFF the flat panel: hardware panel power sequencing and software panel power sequencing. Hardware panel power sequencing: Hardware panel power sequencing is selected when FPR34 bit 7 =1. Whenever FPR31 bit toggles, LynxEM+ automatically controls LCD data, LCD controls, FPEN, FPVDD, and VBIASEN pins. FPR33 [3:2] determines the time period from FPEN to VBIASEN, from VBIASEN to LCD controls/data, and from LCD controls/data to FPVDDEN. FPR33[3:2] Power On Sequencing Time Select 00 1 vertical frame 01 2 vertical frames 10 4 vertical frames 11 8 vertical frames Figure 16 shows the auto panel power on sequencing timing relationship. Figure 17 shows the auto panel power off sequencing timing relationship. For flat panels which have non-standard requirements for on/off power sequencing, LynxEM+ supports panel power on/ off sequencing through software programming. Below are examples of software programming for panel power on sequencing: Software panel power sequencing- ON: • • • • • • • Set FPR34 bit 7 = 0 (software panel power sequencing) Setup shadow registers: SVR40 to SVR4B Set FPR31 bit 0 = 1 (enable LCD display) After X vertical frames, set PDR22 bit 0 = 1 (turn on FPVDDEN) After X vertical frames, set PDR22 bit 1 = 1 (enable LCD controls and data) After X vertical frame, set PDR22 bit 2 = 1 (turn on VBIASEN) After X vertical frames, set PDR22 bit 3 = 1 (turn on FPEN) Note: LCD backlight control is independent of power sequencing. The VBKLGT can be turned on at the same time as FPEN. Flat Panel Interface 9-3 Silicon Motion®, Inc. LynxEM+ DataBook Software panel power sequencing - OFF: • • • • • • • Set FPR34 bit 7 = 0 (software panel power sequencing) Select FPR33 [3:2] for panel power on/off timing: Set PDR22 bit 3 = 1 (turn on FPEN) After X vertical frames, set PDR22 bit 2 = 1 (turn on VBIASEN) After X vertical frames, set PDR22 bit 1 = 1 (enable LCD controls and data) After X vertical frames, set PDR22 bit 0 = 1 (turn on FPVDDEN) Set FPR31 bit 0 = 0 (disable LCD display) Table 8: Flat Panel Interface Pins listing for color DSTN and color TFT LCD LynxEM+ Pin Name Color DSTN 16-bit 24-bit Color TFT 9-bit 12-bit 18-bit 24-bit 12-bit x2 18-bit x2 LP/FHSYNC LP LP HSYNC HSYNC HSYNC HSYNC HSYNC HSYNC FP/FVSYNC FP FP VSYNC VSYNC VSYNC VSYNC VSYNC VSYNC FPSCLK XCK XCK CK CK CK CK CK ENAB ENAB ENAB ENAB ENAB ENAB FPEN FPEN FPEN FPEN FPEN FPEN DE FPEN FPEN FPEN CK FDA23 UD11 R7 RB3 RB3 FDA22 UD10 R6 RB2 RB2 FDA21 UD9 R5 R5 RB1 RB1 FDA20 UD8 R4 R4 RB0 RB0 R3 R3 R3 RA3 RA3 FDA19 UD7 UD7 FDA18 UD6 UD6 R2 R2 R2 R2 RA2 RA2 FDA17 UD5 UD5 R1 R1 R1 R1 RA1 RA1 FDA16 UD4 UD4 R0 R0 R0 R0 RA01 RA0 FDA15 UD3 UD3 G7 GB3 GB3 FDA14 UD2 UD2 G6 GB2 GB2 FDA13 UD1 UD1 G5 GB1 GB1 G4 G4 GB01 GB0 G3 G3 GA3 GA3 FDA12 UD0 FDA11 Pin Name G5 UD0 LD11 16-bit 24-bit G3 9-bit 12-bit 18-bit 24-bit 12-bit x2 18-bit x2 FDA10 LD10 G2 G2 G2 G2 GA2 GA2 FDA9 LD9 G1 G1 G1 G1 GA1 GA1 FDA8 LD8 G0 G0 G0 G0 GA0 GA0 FDA7 LD7 LD7 B7 BB3 BB3 FDA6 LD6 LD6 B6 BB2 BB2 FDA5 LD5 LD5 B5 B5 BB1 BB1 FDA4 LD4 LD4 B4 B4 BB0 BB0 FDA3 LD3 LD3 B3 B3 B3 BA3 BA3 FDA2 LD2 LD2 B2 B2 B2 BA2 BA2 9-4 B2 Flat Panel Interface Silicon Motion®, Inc. LynxEM+ DataBook LynxEM+ Color DSTN Color TFT FDA1 LD1 LD1 B1 B1 B1 B1 BA1 BA1 FDA0 LD0 LD0 B0 B0 B0 B0 BA0 BA0 FPVDDEN VDD VDD VDD VDD VDD VDD VDD VDD VBIASEN VEE VEE VEE VEE VEE VEE VEE VEE 2 RB5 P10 (FDA34) RB4 P9 (FDA33) RA5 P8 (FDA32) RA4 P7 (FDA31) GB5 P6 (FDA30) GB4 P5 (FDA29) GA5 P4 (FDA28) GA4 P3 (FDA27) BB5 P2 (FDA26) BB4 P1 (FDA25) BA5 P0 (FDA24) BA4 P11 (FDA35) 1 2 RA0 denotes first pixel of R0 for 2 pixels/clk interface. RB0 denotes second pixel of R0 for 2 pixels/clk interface. For LynxEM+ SM712 pinout, upper 12 bits of panel data multiplexed with ZV port pins P11-P0. 1 pixel/clock TFT LynxEM+ FPVDDEN VBIASEN FPEN DE FHYSNC FVSYNC FPSCLK FDATA [23:0] panel power control circuitry VDD VEE FPEN ENAB HSYNC VSYNC CK RGB (9,12,18,24) Figure 12: TFT (Single Pixel/Clock) Interface Diagram Flat Panel Interface 9-5 Silicon Motion®, Inc. LynxEM+ DataBook TFT Panel 2 pixels/clock LynxEM+ FPVDDEN VBIASEN panel power control circuitry VDD VEE FPEN ENAB HSYNC VSYNC CK FPEN DE FHYSNC FVSYNC FPSCLK 12/18 RGB (12, 18) A (first pixel) FDATA 12/18 RGB (12, 18) B (second pixel) Figure 13: TFT Panel (2 pixels/clock) Interface Diagram FPVDDEN VBIASEN FPEN LP FP FPSCLK LynxEM+ panel power control circuitry VDD VEE FPEN LP FP XCK FDATA19 FDATA18 FDATA17 FDATA16 FDATA15 FDATA14 FDATA13 FDATA12 UD7 UD6 UD5 UD4 UD3 UD2 UD1 UD0 FDATA7 FDATA6 FDATA 5 FDATA4 FDATA3 FDATA2 FDATA1 FDATA0 LD7 LD6 LD5 LD4 LD3 LD2 LD1 LD0 16-bit Dual Color STN Figure 14: 16-bit DSTN Interface Configuration 9-6 Flat Panel Interface Silicon Motion®, Inc. LynxEM+ DataBook panel power control circuitry FPVDDEN VBIASEN VDD VEE FPEN FPEN LP FP XCK LP FP FPSCLK LynxEM+ FDATA 23 FDATA22 FDATA21 FDATA20 FDATA19 FDATA18 FDATA17 FDATA16 FDATA15 FDATA14 FDATA13 FDATA12 UD11 UD10 UD9 UD8 UD7 UD6 UD5 UD4 UD3 UD2 UD1 UD0 FDATA11 FDATA10 FDATA9 FDATA8 FDATA7 FDATA6 FDATA 5 FDATA4 FDATA3 FDATA2 FDATA1 FDATA0 LD11 LD10 LD9 LD8 LD7 LD6 LD5 LD4 LD3 LD2 LD1 LD0 24-bit Dual Color STN Figure 15: 24-bit Dual Color STN Interface Diagram FPVDDEN 0-t Controls/ Data t VBIASEN t FPEN t is programmed via FPR33 [3:2] Figure 16: Panel Power On Sequencing Timing Diagram Flat Panel Interface 9-7 Silicon Motion®, Inc. LynxEM+ DataBook t FPEN VBIASEN t Controls/ Data 0-t FPVDDEN t is programmed via FPR33 [3:2] Figure 17: Panel Power Off Sequencing Timing Diagram FPR33[3:2] Power On/Off Sequencing Time Select 00 1 vertical frame 01 2 vertical frames 10 4 vertical frames 11 8 vertical frames LVDS Chipset Interface In order to address EMI and cable issues associated with a wide, high speed TTL/CMOS panel interface, designers may choose to use an LVDS (Low Voltage Differential Signaling) chipset or a PanelLink chipset (each chipset type includes a transmitter and a receiver). Examples of the LVDS chipset include National Semiconductor DS90C383/4 (3.3V, 65 MHz) or Texas Instruments' SN75LVDS83/2 (3.3V, 65 MHz); the copyists from these vendors are pin-compatible. The PanelLink chipset is available from Silicon Image (SiI100). LynxEM+ supports a direct interface to the transmitter of either LVDS or PanelLink chipset types. Figure 18 and Figure 19 illustrate the 24-bit interfaces for TFT and DSTN LVDS panels. Figure 21 and Figure 22 illustrate the 24-bit interfaces for TFT and DSTN PanelLink panels. For 36-bit LVDS interface (2 channel LVDS), please refer to Figure 20. 9-8 Flat Panel Interface Silicon Motion®, Inc. LynxEM+ DataBook LynxEM+ LVDS Transmitter TI SN75LVDS83 or NS DS90C383 R[7:0] G[7:0] B[7:0] TxIn TxIn TxIn FHYSNC FVSYNC DE TxIn TxIn TxIn FPSCK TxOut0+ TxOut1+ TxOut2+ TxOut3+ - TxCLKIN TxCLKOut + - 4 LVDS Data Pairs 1 LVDS clock LVDS Receiver TI SN75LVDS82 or NS DS90C384 RxIn0+ RxIn1+ RxIn2+ RxIn3+ - TFT LCD Panel RxOut RxOut RxOut R[7:0] G[7:0] B[7:0] RxOut RxOut RxOut HYSNC VSYNC DE RxCLKOut FPSCK RxCLKIn + - Figure 18: LVDS Interface with TFT LCD Panel LynxEM+ UD[11:0] LD[11:0] LP FP FPSCK LVDS Transmitter TxIn TxIn TxIn TxIn TxIn LVDSCLK TxOut0+ TxOut1+ TxOut2+ TxOut3+ - TxCLKIN TxCLKOut DSTN LCD Panel LVDS Receiver 4 LVDS Data 1 LVDS clock RxIn0+ RxIn1+ RxIn2+ RxIn3+ - RxOut RxOut UD[11:0] LD[11:0] RxOut RxOut RxOut LP FP XCK RxCLKOut open RxCLKIn Figure 19: LVDS Interface with DSTN LCD Panel Flat Panel Interface 9-9 Silicon Motion®, Inc. LynxEM+ DataBook 18-bit x2 TFT interface FDA16 FDA17 FDA18 FDA19 FDA32 FDA33 FDA8 FDA9 FDA10 FDA11 FDA28 FDA29 FDA0 FDA1 FDA2 FDA3 FDA24 FDA25 RA0 RA1 RA2 RA3 RA4 RA5 GA0 GA1 GA2 GA3 GA4 GA5 BA0 BA1 BA2 BA3 BA4 BA5 FDA20 FDA21 FDA22 FDA23 FDA34 FDA35 FDA12 FDA13 FDA14 FDA15 FDA30 FDA31 FDA4 FDA5 FDA6 FDA7 FDA26 FDA27 RB0 RB1 RB2 RB3 RB4 RB5 GB0 GB1 GB2 GB3 GB4 GB5 BB0 BB1 BB2 BB3 BB4 BB5 18-bit LVDS interface Channel 1 SM712 18-bit interface LVDS Channel 2 Figure 20: 36-bit (18x2-bit) TFT Interface Diagram 9 - 10 Flat Panel Interface Silicon Motion®, Inc. LynxEM+ LynxEM+ DataBook PanelLink Transmitter SiI100 R[7:0] G[7:0] B[7:0] TxIn TxIn TxIn FHYSNC FVSYNC DE TxIn TxIn TxIn FPSCK PanelLink Receiver SiI101 TxOut0+ TxOut1+ TxOut2+ - TxCLKOut + TxCLKIN RxIn0+ RxIn1+ RxIn2+ clock TFT LCD Panel RxOut RxOut RxOut R[7:0] G[7:0] B[7:0] RxOut RxOut RxOut HYSNC VSYNC DE RxCLKIn + - RxCLKOut FPSCK Figure 21: PanelLink Interface with TFT LCD Panel LynxEM+ PanelLink Transmitter SiI100 U[11:0] L[11:0] TxIn TxIn FHYSNC FVSYNC DE TxIn TxIn TxIn LVDSCLK PanelLink Receiver SiI101 TxOut0+ TxOut1+ TxOut2+ - TxCLKIN TxCLKOut + - RxOut RxOut RxOut R[7:0] G[7:0] B[7:0] RxOut RxOut RxOut HYSNC VSYNC DE RxCLKIn + - RxCLKOut FPSCK RxIn0+ RxIn1+ RxIn2+ clock TFT LCD Panel Figure 22: PanelLink Interface with DSTN LCD Panel Flat Panel Interface 9 - 11 Silicon Motion®, Inc. LynxEM+ DataBook Table 9 and Table 10 list the pin mapping for an LVDS transmitter with LynxEM+ for LVDS TFT and DSTN panels. Table 11 and Table 12 list the pin mapping for a PanelLink transmitter with LynxEM+ for PanelLink TFT and DSTN panels. Please consult your panel manufacturer to verify the pin mapping between the LVDS receiver and the panel. The pin mapping from the transmitter side must correspond with the pin mapping from the receiver side in order to ensure that the panel will function properly. Table 9: LVDS Transmitter Pin Mapping for TFT Interface LynxEM+ Pin Name TFT interface LVDS Transmitter SN75LVDS83/DS90C383 Pin # LVDS Transmitter Pin Name FPDATA16 R0 51 TxIN0 FPDATA17 R1 52 TxIN1 FPDATA18 R2 54 TxIN2 FPDATA19 R3 55 TxIN3 FPDATA20 R4 56 TxIN4 FPDATA21 R5 3 TxIN6 FPDATA22 R6 50 TxIN27 FPDATA23 R7 2 TxIN5 FPDATA8 G0 4 TxIN7 FPDATA9 G1 6 TxIN8 FPDATA10 G2 7 TxIN9 FPDATA11 G3 11 TxIN12 FPDATA12 G4 12 TxIN13 FPDATA13 G5 14 TxIN14 FPDATA14 G6 8 TxIN10 FPDATA15 G7 10 TxIN11 FPDATA0 B0 15 TxIN15 FPDATA1 B1 19 TxIN18 FPDATA2 B2 20 TxIN19 FPDATA3 B3 22 TxIN20 FPDATA4 B4 23 TxIN21 FPDATA5 B5 24 TxIN22 FPDATA6 B6 16 TxIN16 FPDATA7 B7 18 TxIN17 LP/FHSYNC FHSYNC 27 TxIN24 FP/FVSYNC FVSYNC 28 TxIN25 DE DE 30 TxIN26 - - 25 TxIN23 FPSCLK FPSCLK 31 TxCLKIN 9 - 12 Flat Panel Interface Silicon Motion®, Inc. LynxEM+ DataBook Table 10: LVDS Transmitter Pin Mapping for DSTN Interface LynxEM+ Pin Name STN interface LVDS Transmitter SN75LVDS83/DS90C383 Pin # LVDS Transmitter Pin Name FPDATA12 UD0 12 TxIN13 FPDATA13 UD1 14 TxIN14 FPDATA14 UD2 8 TxIN10 FPDATA15 UD3 10 TxIN11 FPDATA16 UD4 51 TxIN0 FPDATA17 UD5 52 TxIN1 FPDATA18 UD6 54 TxIN2 FPDATA19 UD7 55 TxIN3 FPDATA20 UD8 56 TxIN4 FPDATA21 UD9 3 TxIN6 FPDATA22 UD10 50 TxIN27 FPDATA23 UD11 2 TxIN5 FPDATA0 LD0 15 TxIN15 FPDATA1 LD1 19 TxIN18 FPDATA2 LD2 20 TxIN19 FPDATA3 LD3 22 TxIN20 FPDATA4 LD4 23 TxIN21 FPDATA5 LD5 24 TxIN22 FPDATA6 LD6 16 TxIN16 FPDATA7 LD7 18 TxIN17 FPDATA8 LD8 4 TxIN7 FPDATA9 LD9 6 TxIN8 FPDATA10 LD10 7 TxIN9 FPDATA11 LD11 11 TxIN12 LP/FHSYNC LP 27 TxIN24 FP/FVSYNC FP 28 TxIN25 DE - 30 TxIN26 FPSCLK FPSCLK 25 TxIN23 LVDSCLK LVDSCLK 31 TxCLKIN Flat Panel Interface 9 - 13 Silicon Motion®, Inc. LynxEM+ DataBook Table 11: PanelLink Transmitter Pin Mapping for TFT Interface LynxEM+ Pin Name TFT interface SiI100 Pin # PanelLink Transmitter Pin Name PanelLink Transmitter FPDATA16 R0 63 D0 FPDATA17 R1 62 D1 FPDATA18 R2 61 D2 FPDATA19 R3 60 D3 FPDATA20 R4 59 D4 FPDATA21 R5 58 D5 FPDATA22 R6 57 D6 FPDATA23 R7 56 D7 FPDATA8 G0 55 D8 FPDATA9 G1 54 D9 FPDATA10 G2 52 D10 FPDATA11 G3 51 D11 FPDATA12 G4 50 D12 FPDATA13 G5 49 D13 FPDATA14 G6 48 D14 FPDATA15 G7 47 D15 FPDATA0 B0 46 D16 FPDATA1 B1 44 D17 FPDATA2 B2 43 D18 FPDATA3 B3 42 D19 FPDATA4 B4 41 D20 FPDATA5 B5 40 D21 FPDATA6 B6 38 D22 FPDATA7 B7 37 D23 LP/FHSYNC FHSYNC 2 HSYNC FP/FVSYNC FVSYNC 3 VSYNC DE DE 1 DE FPSCLK FPSCLK 12 IDCK 9 - 14 Flat Panel Interface Silicon Motion®, Inc. LynxEM+ DataBook Table 12: PanelLink Transmitter Pin Mapping for DSTN Interface LynxEM+ Pin Name STN interface PanelLink Transmitter SiI100 Pin # PanelLink Transmitter Pin Name FPDATA12 UD0 50 D12 FPDATA13 UD1 49 D13 FPDATA14 UD2 48 D14 FPDATA15 UD3 47 D15 FPDATA16 UD4 63 D0 FPDATA17 UD5 62 D1 FPDATA18 UD6 61 D2 FPDATA19 UD7 60 D3 FPDATA20 UD8 59 D4 FPDATA21 UD9 58 D5 FPDATA22 UD10 57 D6 FPDATA23 UD11 56 D7 FPDATA0 LD0 46 D16 FPDATA1 LD1 44 D17 FPDATA2 LD2 43 D18 FPDATA3 LD3 42 D19 FPDATA4 LD4 41 D20 FPDATA5 LD5 40 D21 FPDATA6 LD6 38 D22 FPDATA7 LD7 37 D23 FPDATA8 LD8 55 D8 FPDATA9 LD9 54 D9 FPDATA10 LD10 52 D10 FPDATA11 LD11 51 D11 LP/FHSYNC LP 2 HSYNC FP/FVSYNC FP 3 VSYNC DE DE 1 DE LVDSCLK LVDSCLK 12 IDCK Flat Panel Interface 9 - 15 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 10: Miscellaneous Functions This chapter describes functions of LynxEM+ such as the Video ROM BIOS interface, VESA DPMS, and I2C / VESA DDC2B. Video BIOS ROM Interface The Video BIOS contains code for chip power-on initialization, graphics mode setup, and various read/write routines to the frame buffer. The Video BIOS can be burned LynxEM+ into a separate video BIOS EPROM (this is the typical case for add-in cards) or be integrated into the system BIOS ROM (this is the typical case for a motherboard graphics implementation). To support separate video BIOS ROM access, BIOS address decode must be enabled by setting CSR30 (Expansion ROM Enable Base Address Register) bit 0 = 1. For implementations where video BIOS is integrated into the system BIOS ROM, BIOS address decode access must be disabled by clearing CSR30 bit 0. Figure 23 shows the external video BIOS ROM configuration interface for LynxEM+. The ~ROMEN (ROM Enable) signal from LynxEM+ connects to the OE and CE signals of the BIOS ROM. Since video BIOS ROM address and data are shared with the video memory data (MD) lines, programmers must ensure that the memory bus is inactive when reading from the Video BIOS ROM. For this case, the Video BIOS ROM must be read out and shadowed (typically in system memory at C0000) immediately after reset. Direct physical access to the Video BIOS must then be disabled to prevent interference with ensuing graphics operations. 64Kx8 LynxEM+ MD [7:0] MD [47:32] ~ROMEN BIOS ROM D [7:0] A [15:0] ~OE ~CE Figure 23: Video BIOS ROM Configuration Interface Miscellaneous Functions 10 - 1 Silicon Motion®, Inc. LynxEM+ DataBook VESA DPMS Interface LynxEM+ supports the VESA Display Power Management Signaling (DPMS) via direct programming PDR22 (LCD Panel Control Select Register) bits 5, 4, or through implementation of the chip's power down states. Table 13 shows the VESA DPMS states and methods for entering each of the DPMS states. Table 13: DPMS Summary DPMS State HSYNC State VSYNC State RGB State Direct Programming Method Power Down State Method ON Pulses Pulses Active PDR22 [5:4] = 00 - Standby No pulses Pulses Blank PDR22 [5:4] = 01 Automatic Standby DPMS state when enter Standby mode Suspend Pulses No pulses Blank PDR22 [5:4] = 10 CCR69[2]=0 selects Suspend DPMS state when in Sleep mode OFF No pulses No pulses Blank PDR22 [5:4] = 11 CCR69[2]=1 selects OFF DPMS state when in Sleep mode I2C Bus or VESA DDC2B Interface LynxEM+ provides dual ports for I2C-Bus through USR [3:0] I/O pins for various applications such as VESA's DDC2B monitor interface. It is recommended to use USR1 and USR0 as the primary port for SDA and SCL signals on I2C Bus. USR3 and USR2 are reserved as a secondary port. GPR72 (User Defined Register 1) and GPR73 (User Defined Register 2) are defined to support I2C/DDC2 bus protocol. LynxEM+, as an I2C master controller only, is designed to initiate a transfer, generate clock signal, and terminate a transfer to a slave I2C component. LynxEM+'s I2C-Bus interface is designed to interface with NTSC/PAL decoders, Proems, audio decoders, and others. Each of the USR [3:0] I/O pins has an internal pull-up resistor. To enable the data (SDA) and the clock (SCL) from LynxEM+'s primary port, bit 5 and bit 4 of GPR72 (3C5h index 72h) must be set as "11". To drive a logic "0" to SDA line (USR1) and SCL line (USR0), program GPR72 bit 1 and bit 0 to "0". The SDA and SCL can be read back from bit 3 and bit 2 of GPR72. Figure 24 shows the basic I2C-Bus protocol of LynxEM+ as a master transmitter. 10 - 2 Miscellaneous Functions Silicon Motion®, Inc. LynxEM+ DataBook Yes, = 11 Check GPR72 [3:2] = 11 Bus Busy? No Initiate Start Send 7-bit Slave Address with R/~W bit No Check GPR72[3] = 0 Ack from slave? Yes No optional Send 2nd Byte Slave Address Time Out? Yes Abort Transfer Yes No Check GPR72[3] = 0 Ack from slave? No Time Out? Yes Yes Send one Byte Slave Address Abort Transfer No Check GPR72[3] = 0 No Ack from slave? No Time Out? Yes Yes Last Byte? Abort Transfer Yes Stop Transfer Figure 24: LynxEM+ I2C Bus Protocol Flow Chart Miscellaneous Functions 10 - 3 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 11: Clock Synthesizers LynxEM+ integrates three programmable clock synthesizers for memory clock (MCLK), Video Clock 1 (VCLK), and Video Clock 2(VCLK2). VCLK1 is utilized for standard CRT only, LCD only, or CRT/LCD display modes for which the refresh rate for both devices is the same. VCLK2 may be utilized when Virtual Refresh mode is implemented - for this case, VCLK1 is utilized for panel timing and to clock the panel display block within LynxEM+. VCLK2 may be utilized to clock the CRT interface independently for LCD/CRT display modes or to independently clock various functional blocks within the device to save power under LCD only display mode. Please see the Virtual Refresh discussion under the Power Management section for additional details regarding power saving capabilities under Virtual Refresh architecture. Figure 25 illustrates the control logic for MCLK, VCLK, VCLK2. The figure also shows the clock generator module for WFIFO (WFIFOCLK), RFIFO (RFIFOCLK), RAM (RAMCLK), Video Capture (VCMCLK), Drawing Engine (DPMCLK), and Video Processor (VPCLK). TVCLK is used for an external analog TV encoder (this clock is either derived from 14.318MHz base clock - NTSC, or from separate 17.734480MHz clock source connected to input signal PALCLK - PAL). SLEEP STANDBY PD20_4 CCR68_6 CCR69_0 CCR68_7 CCR69_1 FPR31_7 PD20_5 ~EXCKEN VCLK2 CKIN PLL1 0 s1 s0 1 0 CKIN 1 PLL3 0 1 1/8 2 1/16 3 MCLK VCLK VCLK 0 s1 s0 ~EXCKEN MCKIN 1/4 1 1/8 2 MCLK 1/16 3 PDR21[5:0] VCLK2 1/8 2 1/16 WFIFOCLK VCLK SLEEP 0 1 1 3 STANDBY 1/4 0 VRCLK 2 0 1 VCLK 1 VCLK2 1/4 s1 s0 PLL2 0s1 s0 1/2 AUTO_OFF MCLK RFIFOCLK RAMCLK CLOCK GENERATOR VCMCLK DPMCLK VPCLK TVCLK 3 Figure 25: Clocks Generator Block Diagram The VCLK PLL is programmed using the VCLK Numerator Register (VNR), CCR6C, and VCLK Denominator (VDR) and Post Scalar (PS) register, CCR6D. The VCLK frequency is based on the following equation: Clock Synthesizers 11 - 1 Silicon Motion®, Inc. LynxEM+ DataBook VCLK = 14.31818 MHz × VNR 1 × VDR 1 + PS The post scalar is used to support VCLK frequencies which need a large VDR number. With PS enabled, the VDR number can be set to ½ of the original VDR number. This helps to reduce jitter and maintain accuracy. The VCLK2 PLL is programmed using the VCLK2 Numerator Register (VCLK2NR), CCR6E, and VCLK Denominator (VCLK2DR) register CCR6F. The VCLK2 frequency is based on the following equation: VCLK2NR VCLK2 = 14.31818 Mhz ∗ VCLK2DR Table 14: Recommended VNR and VDR Values for Common VCLK Settings CCR68 [6] CCR68 [5] 3C2.3 3C2.2 VCLK (MHZ) VNR VDR [7] 60Hz 0 01 0 0 0 25.180 33h 1Dh (text) 70Hz 0 0 0 0 1 28.325 5Bh 97h2 640x480 85Hz 0 0 1 0 0 31.500 2Ch 14h 800x600 56Hz 0 0 1 0 1 35.484 39h 17h Mode 640x480 Ref. Rate CCR68 720x400 -- -- 1 1 x x x 14.318 x x 800x600 72Hz 0 1 x x x 49.517 53h 18h 1024x768 75Hz 0 1 x x x 78.750 6Eh 14h Notes: 1. VNR and VDR numbers are hard coded in VGA modes. 2. Post scalar enabled. The MCLK PLL is programmed using the MCLK Numerator Register (MNR), CCR6A, and MCLK Denominator Register (MDR), CCR6B. MCLK frequency is based on the following equation: MCLK = 14.31818 MHz × 11 - 2 MNR MDR Clock Synthesizers Silicon Motion®, Inc. LynxEM+ DataBook Chapter 12: Multimedia RAMDAC LynxEM+ contains a multimedia RAMDAC, which supports gamma correction with a maximum frequency of 135 MHz (3.3V power supply). The multimedia RAMDAC includes two 256 x 18 color palette RAMs (RAM0 for CRT display, RAM1 for LCD display), RAM Sequencer, Hardware Cursor Registers (foreground and background), Hardware Pop-up Icon Registers (foreground and background), Data Mixer, Power-On Reset, Bias circuit, Monitor Detect circuit, and three 8-bit DACs (R, G and B). Anti-flicker logic for I/O read/writes is also built in the color palette RAM blocks. Figure 26 shows a block diagram of LynxEM+ Multimedia RAMDAC. LynxEM+ uses an internal band gap voltage reference circuit to supply the reference voltage. This circuit automatically compensates for temperature and power supply variation. The external portion of the circuit consists of a single RSET resistor used to set the full scale voltage of RGB output from DAC. The RAMDAC supports two types of modes, color palette index mode and direct color mode. In color palette index mode, the 8-bit input data of a given pixel goes to the color palette RAM block through VGA mask register. In direct color mode, if gamma correction is off pixel data will bypass the color palette RAM. If gamma correction is on, the pixel data will go through the color palette RAM which is being used as a gamma correction look up. To activate gamma correction refer to CCR65: TV Encoder Control Registers. LCD Backend RAM (RAM1) LynxEM+ includes a separate 18-bit RAM (6 bits each RGB) module for the LCD backend. The RAM allows support for color palette index modes for the LCD display. This RAM module is written concurrently with RAM0. LCD RAM1 P[7:0] ~PDOWN Control Unit RAMCLK Hardware Cursor & Popup Icon R 8 G 256 x 18 Color Palette RAM Or Gamma Correction Look up Table 3 24 Video Select MIXER Band-Gap Voltage Reference B BIAS Monitor Detect Figure 26: LynxEM+ RAMDAC Block Diagram Multimedia RAMDAC 12 - 1 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 13: Signature Analyzer LynxEM+ includes several built-in test features to enhance testability and fault coverage. LynxEM+’s signature analyzer is designed to reduce LSI tester time and manufacturing test time. This signature analyzer resides within the Video Processor block and receives 24-bit RGB data from Multimedia RAMDAC block. It can be used to test CRT graphics modes, TV display modes, and motion video with single frame data. It can also be used to test data combinations such as: graphics, video 1, video 2, HW cursor, and HW pop-up icon at the same time. The primary variables for a the signature analyzer are the length of the internal shift registers and the number of feedback terms. LynxEM+ implements the CRC-CCITT polynomial (X16 + X12 + X5 + 1) on a 16-bit signature shift register. VPR64 (Signature Analyzer Control and Status) register is used to define and control the operation of LynxEM+'s signature analyzer. Bit 3 is used as a Enable/Stop bit. Bit 2 is used as a Reset/Normal bit. Bit 1 and 0 are used to select 8bit Red, Green, or Blue data from the 24-bit outputs of Multimedia RAMDAC. Bit 31 to bit 16 are used to read back the signature from the signature analyzer. To turn on the signature analyzer, both bit 3 and bit 2 must be set as "11". The signature shift register will be reset to "0" as its initial value. On the rising edge of the 1st vertical sync pulse after VPR64 bit [3:2]=11, the state machine will start collecting signature data. Bit 2 is automatically reset to "0" at the same time. On the rising edge of the next vertical sync pulse, the signature analyzer stops and Bit 3 is automatically reset to "0". The test software can read back the 16-bit signature from Bit [31:16] to compare the golden signature for the test patterns. Figure 27 is a block diagram of the signature analyzer. VPR64[1:0] R[7:0] From Multimedia RAMDAC G[7:0] 8 16 X16+X12+X5+1 16 Collector VPR64[31:16] B[7:0] VSYNC State Machine VPR64[3:2] VSYNC VPR64{3:2] = 11 Enable & Reset Signature Analyzer VPR64{3:2] = 10 Start Signature Analyzer VPR64{3:2] = 00 Stop Signature Analyzer Figure 27: Signature Analyzer Block Diagram Signature Analyzer 13 - 1 Silicon Motion®, Inc. LynxEM+ DataBook Chapter 14: Power Management LynxEM+ is designed to support ACPI requirements as defined in the PCI Bus Management Interface Specification 1.0 (PPMI v1.0) and Display device Class Power Management Specification v1.0a. LynxEM+ also supports a variety of adaptive power saving and clock management methods while in full operational mode. Finally, LynxEM+ supports traditional Standby and Suspend mode functionality for operating systems such as Windows 95 which do not have ACPI support built into the OS. A summary of these capabilities follows. ACPI LynxEM+ supports D0-D3 modes of operation via software programming of the Power Management Control/Status Register PMSCR[1:0]. As required by the PCI Bus Management Interface Specification, PCI Configuration Space Status Register (offset 06h) bit 4 is set to "1" to indicate new capabilities have been defined for LynxEM+. At offset 34h, the Cap_Ptr register stores the offset of the new capabilities (this register is hardwired to 40h). The first byte at offset 40h has a value of 01h, which indicates a Power Management capability (supports D1 and D2 states in addition to the required D0 and D3 power states). The second byte has a value of 00h indicating the no additional new capability features (Note: LynxEM+ does not offer support for optional ~PME capabilities as defined in PPMI v1.0). Please refer to the PCI Bus Power Management Interface Specification 1.0 and Display Device Class Power Management Reference Specification v1.0a for additional details. Display driver support for ACPI under Windows 98 and future versions of Windows NT will be provided by Silicon Motion in accordance with PC97 and PC98 requirements. Adaptive Power Management LynxEM+ provides intelligent power saving control during graphics/video operation. Two key methods through which power savings is achieved are Dynamic control of functional blocks, and dynamic clock control through Silicon Motion's Virtual Refresh architecture. Dynamic Control of Functional Blocks All major functional blocks within the device are laid out independently. There is no signal crossover between blocks. Special clock drivers are used to control each of the independent functional blocks. The clock drivers can be turned off by setting Power-Down Registers (PDR20 - PDR22), or by entering the internal auto-standby mode (PDR23 Bit 6). Functional blocks therefore can be turned on/off dynamically in response to how LynxEM+ is being utilized. Since the blocks shut down are unused functional blocks, this power saving feature is transparent to the end user. Below are some programming recommendations for selected display configurations. These auto power saving features are implemented through video BIOS and system PMI. In addition to these display configuration recommendations, the drawing engine, ZV Port, video processor can be turned off through video driver control. Power Management 14 - 1 Silicon Motion®, Inc. LynxEM+ DataBook CRT is the only selected display • • Disable LCD frame buffer write operation (PDR21 bit 5 = 1) Disable LCD frame buffer read operation and DSTN dithering engine (PDR21 bit 4 = 1) Color TFT is the only selected display with normal refresh • • • Disable the 135 MHz DAC (PDR21 bit 7= 1) Disable LCD frame buffer write operation (PDR21 bit 5= 1) Disable LCD frame buffer read operation and DSTN dithering engine (PDR21 bit 4 = 1) Color DSTN is the only selected display with Virtual Refresh • • • Disable the 135 MHz DAC (PDR21 bit 7 = 1) Enable auto shut-down of display memory screen refresh cycle and LCD frame buffer write cycle (FPR31 bit 3 = 1) Set VCLK clock rate to 10 MHz (reduce clock rate to save power) TV is the only selected display • • • Set VCLK clock rate to 14.1 MHz and set interlaced mode (CRT30 bit 7 = 1) Disable LCD frame buffer write operation (PDR21 bit 5= 1) Disable LCD frame buffer read operation and DSTN dithering engine (PDR21 bit 4 = 1) Dynamic Clock Control and Virtual Refresh Dynamic clock control is made possible through Silicon Motion's Virtual Refresh architecture. Virtual Refresh is an intelligent architecture for dynamic clock control in LCD only mode, as well as independent display refresh control when multiple displays are enabled (e.g. CRT/LCD, TV/LCD). Virtual Refresh utilizes two independent clocks (VCLK, VRCLK): one clock, VRCLK drives the panel interface and maintains proper screen refresh. The second clock, VCLK is now independent of the panel and can be scaled according to user needs (e.g. scaled down for power savings, or scaled up to drive a higher refresh rate on CRT). Virtual Refresh is enabled by setting FPR31 bit 7 to "1". When the LCD display is the only display viewed by the user, power saving can achieved via three key functions: • • • Dynamically slows down the video clock (VCLK) to 25%~50% of the original clock rate Auto shut-down display memory screen refresh Auto shut-down the LCD write frame buffer These functions can be automatically implemented when LynxEM+ detects the user has not performed any activity for selectable number of screen refresh cycles. Since a significant percentage of the logic is synchronized with VCLK, the average power consumption of the chip will drop dramatically. The LCD screen remains on with proper screen refresh, so the power savings is transparent to the end user. Note: When multiple displays are used, Virtual Refresh architecture can also be used to simultaneously display CRT/TV and the LCD with different resolutions, and independent refresh rates. Standard Power Management Standby Mode LynxEM+ supports Standby Mode in two ways: internal auto-standby and system standby from system PMI. The internal auto-standby is enabled and controlled by Activity Detection Register (PDR23). When the internal timer matches the selected condition (PDR23 bit [2:0]), LynxEM+ immediately enters standby mode Any CPU Memory or I/O access to 14 - 2 Power Management Silicon Motion®, Inc. LynxEM+ DataBook LynxEM+ will cause the device to exit standby mode, and reset as an internal counter timer. The system PMI can enable system standby mode by pulling LynxEM+'s "~PDOWN" signal low. (Note: To select standby mode, PDR20 bit 7 must be set to 0 before pulling ~PDOWN low) LynxEM+ will exit standby mode when "~PDOWN" goes high. When the system PMI standby is on, the internal auto-standby is ignored. Programming sequences for internal auto-standby and system standby follow. Start Internal Auto-standby Mode • • • PDR23 bit[7:6] = 11b PDR20 bit 7 = 0 to enter standby mode The internal timer count matches the setting from PDR23 bit[2:0] Start System Standby Mode • • PDR20 bit 7 = 0 to enter standby mode "~PDOWN" input pin is driven low Power Saving In Standby Mode The standby mode is designed to provide an automatic power saving mechanism for the portable PC when the graphics display sub-system is idle for a short period of time. There is no need for BIOS or application software to program LynxEM+ registers. All power saving control are done by hardware. Both internal auto-standby and system PMI standby have the same power saving mechanisms listed below. • • • Both memory clock and video clock switch to lower frequencies which are selected by bit [5:4] of PDR20 register LynxEM+ will continuously issue DRAM refresh cycles The following functional blocks are disabled (PDR21 bit 7, 5, 4, 3, 2, and 1) * DAC * LCD frame buffer write * LCD frame buffer read and DSTN dithering engine * Color Palette RAM * ZV Port * Drawing engine * Video processor • • LCD auto-power off sequence enabled VESA DPMS standby mode enabled Sleep Mode Sleep mode is the maximizes power-saving mode while maintaining display memory and register integrity. Sleep mode is selected when the whole system will be idle for a long period of time. All selected displays will be shutdown. PLLs can also be shutdown if the external 32 KHz refresh clock is selected (CCR69 bit 3 = 0) or memory self-refresh mode is selected. LCD panel on/off sequence will be done by simply programming the PDR22 register. The programming sequence for Sleep Mode follows. Setting Before Entering Sleep Mode • • • PDR20 bit 7 = 1 to enter sleep mode Set PDR20 bit 6 to select memory refresh type Set CCR69 bit 3 to select external or internal refresh clock Power Management 14 - 3 Silicon Motion®, Inc. LynxEM+ DataBook Enter Sleep Mode (Suspend) • • Power OFF the LCD panel if the LCD display is enabled. There are two ways to power OFF the LCD panel: hardware or software (selected by FPR34 bit 7). For software approach, the system PMI needs to program FPR34 bit 7 = 0 and PDR22 bit [3:0] to control FPEN, FPVDD, VBIAS,VBKLGT and panel interface pins. For hardware approach, one needs to program FPR34 bit 7 = 1 and panel ON/OFF timing select via FPR33 [3:2], then LynxEM+ will generate the proper panel sequencing. "~PDOWN" input pin is driven low. After ~PDOWN has been asserted for 2 vertical sync cycles, LynxEM+ will automatically shut-down the following blocks: * DAC * LCD frame buffer write * LCD frame buffer read and DSTN dithering engine * Color Palette RAM * ZV Port * 2D drawing engine * Video processor * Memory screen refresh * Start power-down memory refresh cycle Exit Sleep Mode (Resume) • • Drive "~PDOWN" input high. (200 ms after PLLs are turned on) After 200 ms, Power ON the LCD panel by either hardware or software. For software panel sequencing, enable LCD display by programming the PDR22 register. The whole system will be back to original state. For hardware panel sequencing, set FPR34 bit 7 = 1. Activity Detection The activity detection function is used to monitor LynxEM+ I/O and memory activity. System designer can select a fixed time period by programming PDR23 bit [2:0]. An internal timer will count the idle period of memory or I/O operation. If the idle period matches the selected value, LynxEM+ will generate a "Low-High" or "High-Low" signal to system through ACTIVITY output pin. Any Memory or I/O operation can reset the ACTIVITY signal and the internal counter. After receiving the ACTIVITY signal from LynxEM+, the system power management unit can start Standby mode or Sleep Mode by pulling "~PDOWN" signal low. The activity detection function can also be used to enable internal autostandby mode by setting PDR23 bit [7:6]. This power saving feature is independent of software and transparent to the end users. Power-down Sleep Mode States Table 15: Interface Signals Sleep Mode States Signal Name Sleep Mode Host Interface AD [31:0] tri-state C/ ~BE [3:0] tri-state PAR tri-state ~FRAME tri-state ~TRDY tri-state 14 - 4 Power Management Silicon Motion®, Inc. LynxEM+ DataBook Signal Name Sleep Mode ~IRDY tri-state ~STOP tri-state ~DEVSEL tri-state IDSEL x CLK x ~RST H ~REQ tri-state ~GNT x ~INTA tri-state Power Down Interface ~PDOWN L ~CLKRUN open-collector Clock Interface REFCLK/PALCLK x CKIN x LVDSCLK/MCKIN tri-state ~EXCKEN H Memory Interface MA [9:0] H MD [63:0] H or L (note 2) ~WE H ~RAS L ~CAS L ~CS [1:0] L ~DQM [7:0] H DSF L BA H SDCKEN L (self-refresh), H (CAS-b-RAS) SCK depends on PLL ~ROMEN H Flat Panel Interface FDATA [23:0] L FPSCLK L FPEN L FPVDDEN L VBIASEN L LP/FHSYNC L Power Management 14 - 5 Silicon Motion®, Inc. LynxEM+ DataBook Signal Name Sleep Mode FP/FVSYNC L CRT Interface R, G, B 0V CRTVSYNC L CRTHSYNC L Video Port Interface P [15:0] x PCLK H VREF H HREF H BLANK/TVCLK H General Purpose Registers/I2C USR3 H USR2 H USR1/SDA H USR0/SCL H Test Mode Pins TEST [1:0] L Notes: 1. This entry specifies when PDR20 bit 6 = 1 (self-refresh). When PDR20 bit 6 = 0 (CAS before RAS), both ~RAS and ~CAS control are based on 32K Hz refresh clock 2. MD lines have internal pull-up, therefore, without external pulldown resistors, MD lines will be at HIGH. With external pulldown resistors, MD lines will be at LOW. 14 - 6 Power Management Silicon Motion®, Inc. LynxEM+ DataBook Chapter 15: PCI Configuration Space Registers Table 16: PCI Configuration Registers Quick Reference Summary of Registers Page CSR00: Vendor ID 15 - 2 CSR02: Device ID 15 - 2 CSR04: Command 15 - 2 CSR06: Status 15 - 3 CSR08: Revision ID and Class Code 15 - 3 CSR0D: Latency Timer 15 - 4 CSR10: Memory Base Address Register 15 - 4 CSR2C: PCI Configuration Space Subsystem Vendor ID 15 - 5 CSR2E: PCI Configuration Space Subsystem ID 15 - 5 CSR30: Expansion ROM Base Address 15 - 5 CSR30: Expansion ROM Base Address 15 - 5 CSR34: Power Down Capability Pointer 15 - 6 CSR3C: Interrupt Line 15 - 6 CSR3D: Interrupt Pin 15 - 6 CSR40: Power Down Capability Register 15 - 7 CSR44: Power Down Capability Data 15 - 7 Extended SMI Registers LOCK: Extended Register Write Protect Control PCI Configuration Space Registers 15 - 8 15 - 1 Silicon Motion®, Inc. LynxEM+ DataBook PCI Configuration Space Registers The PCI specification defines the configuration space for auto-configuration (plug-and-play), device and memory relocation. CSR00: Vendor ID Read Only Address: 00h Power-on Default: 126Fh This register specifies the vendor ID 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 3 2 1 0 VENDOR ID Bit 15:0 Vendor ID This register is hardwired to 126Fh to identify as Silicon Motion, Inc. CSR02: Device ID Read Only Address: 02h Power-on Default: 0712h This register specifies the device ID. 15 14 13 12 11 10 9 8 7 6 5 4 DEVICE ID Bit 15:0 Device ID This register is hardwired to 0712h to identify the device as a LynxEM+. CSR04: Command Read/Write Address: 04h Power-on Default: 00h Note: Reserved bits are read only This register controls which types of PCI command cycles are supported by LynxEM+. 15 14 13 12 11 10 9 RESERVED Bit 15:6 Reserved Bit 5 Palette Snooping Enable (PSE) 0 = Disable 1 = Enable 15 - 2 8 7 6 5 4 3 2 1 0 PSE MWR R PCI MS IO PCI Configuration Space Registers Silicon Motion®, Inc. LynxEM+ DataBook Bit 4 Memory Write Invalidate Enable for PCI master (MWR) 0 = Disable 1 = Enable Bit 3 Reserved (R) Bit 2 PCI Master Enable (PCI) 0 = Disable 1 = Enable Bit 1 Memory Space Access Enable (MS) (Note: addressing decoding) 0 = Disable 1 = Enable Bit 0 I/O Space Access Enable (IO) 0 = Disable 1 = Enable This bit needs to be set to "1" in order to enable BIOS CSR06: Status Read Only Address: 06h Power-on Default: 20h This register controls device select timing status, detect parity status, and detects target abort status for LynxEM+. In order to clear any bit of this register, you must write a "1" to that particular bit. 15 DPE 14 13 RESERVED 12 11 DTA R 10 9 8 TS Bit 15 Detect Parity Error (DPE) Bit 14:13 Reserved (R) Bit 12 Detect Target Abort for Master Mode (DTA) Bit 11 Reserved (R) Bit 10:9 ~DEVSEL Timing Select (TS) 01 = medium speed (hardwired) Bit 8:0 Reserved 7 6 5 4 3 2 1 0 RESERVED CSR08: Revision ID and Class Code Read Only Address: 08h Power-on Default: 030000A0h PCI Configuration Space Registers 15 - 3 Silicon Motion®, Inc. LynxEM+ DataBook This register specifies the silicon revision ID and the Class Code that the silicon supports. 31 30 29 28 27 26 25 24 23 22 21 BASE CLASS CODE 15 14 13 12 11 20 19 18 17 16 2 1 0 18 17 16 2 1 0 SUBCLASS CODE 10 9 8 7 6 5 REG LEVEL PROGRAMMING INTERFACE 4 3 REVISION ID Bit 31:24 Base Class Code 03h = for Video Controller Bit 23:16 Subclass Code 00h = VGA Bit 15:8 Register Level Programming Interface 00h = hardwired setting Bit 7:0 Revision ID For example, A0h = revision A; B0h = revision B CSR0D: Latency Timer Read Only Address: 0Dh Power-on Default: 00h This register specifies the latency timer that LynxEM+ supports for burst master mode. 7 6 5 4 3 2 1 0 LATENCY TIMER Bit 7:0 Latency Timer for burst capable master CSR10: Memory Base Address Register Read/Write Address: 10h (Note: Reserved bits are read only) Power-on Default: 00h This register specifies the PCI configuration space for address relocation 31 30 29 28 27 26 25 24 23 22 21 LINEAR ADDRESSING MEMORY BASE 15 14 13 12 11 10 9 20 19 RESERVED 8 7 6 5 4 3 RESERVED Bit 31:24 15 - 4 MSI Linear Addressing Memory Base Address. Memory segment allocated within 16 MB boundary PCI Configuration Space Registers Silicon Motion®, Inc. LynxEM+ DataBook Bit 23:1 Reserved Bit 0 Memory Space Indicator (MSI) (Read only) 0 = memory base CSR2C: PCI Configuration Space Subsystem Vendor ID Read/Write Address: 2Ch Power-on Default: 00h This register specifies the Subsystem Vendor ID. 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 SUBSYSTEM VENDOR ID Bit 15:0 Subsystem Vendor ID CSR2E: PCI Configuration Space Subsystem ID Read/Write Address: 2Eh Power-on Default: 712h This register specifies the Subsystem ID. The default setting of MD[22:20] = 111b which configures the system BIOS to load subsystem ID information during POST. 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 SUBSYSTEM ID Bit 15:0 Subsystem ID. This System ID is written by system BIOS during POST CSR30: Expansion ROM Base Address Read/Write Address: 30h Power-on Default: 00h This register specifies the expansion ROM base address. Note: Reserved bits are read only. 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 5 4 3 2 1 0 ROM BASE ADDRESS 15 14 13 12 11 10 9 8 7 6 RESERVED Bit 31:16 BIOS ROM Base Address. Memory segment allocated for BIOS ROM in 64KB boundary [15:0] PCI Configuration Space Registers 15 - 5 Silicon Motion®, Inc. LynxEM+ DataBook Bit 15:1 Reserved Bit 0 BIOS Address Decode Enable. This bit is valid only if memory space access is enabled. (CSR04 bit 1 = 1) 0 = Disable 1 = Enable CSR34: Power Down Capability Pointer Read Only Address: 34h Power-on Default: 40h This register contains the address where PCI power down management registers are located 7 6 5 4 3 2 1 0 CAPABILITY POINTER/PCI POWER DOWN MGMT Bit 7:0 Capability pointer contains the address where PCI Power Down Management Register are located. CSR3C: Interrupt Line Read/Write Address: 3Ch Power-on Default: 00h This register specifies the PCI Interrupt Line. 7 6 5 4 3 2 1 0 2 1 0 INTERRUPT LINE Bit 7:0 Interrupt Line CSR3D: Interrupt Pin Read Only Address: 3Dh Power-on Default: 01h This register specifies the PCI Interrupt Pin. 7 6 5 4 RESERVED Bit 7:1 Reserved Bit 0 Interrupt Pin (IP) (~INTA) 15 - 6 3 IP PCI Configuration Space Registers Silicon Motion®, Inc. LynxEM+ DataBook CSR40: Power Down Capability Register Read Only Address: 40h Power-on Default: 0601h This register contains the address where PCI power down management Capabilities. 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 3 2 1 0 PCI POWER DOWN MANAGEMENT CAPABILITY (0601h) 15 14 13 12 11 10 9 8 7 PCI POWER DOWN MGMT CAPABILITY POINT LINK 6 5 4 PCI POWER DOWN MGMT CAPABILITY (01h) Bit 31:16 PCI Power Down Management Capability = 0601h Offset 2 Bit 15:8 PCI Power Down Management Capability Point Link List = 00h Offset 1 Bit 7:0 PCI Power Down Management Capability ID= 01h Offset 0 CSR44: Power Down Capability Data Read/Write Address: 44h Power-on Default: 00h This register contains the address where PCI power down management Control, Status and Data 31 30 29 28 27 26 25 24 23 22 21 DATA 15 14 13 12 20 19 18 17 16 2 1 0 RESERVED 11 10 9 8 7 6 5 4 3 PCI POWER DOWN MGMT CONTROL/STATUS Bit 31:24 Data Read Only. Offset 7 Bit 23:16 Reserved =00 Offset 6 Bit 15:0 PCI Power Down Management Control/Status Offset 4 PCI Configuration Space Registers 15 - 7 Silicon Motion®, Inc. LynxEM+ DataBook Extended SMI Registers LOCK: Extended Register Write Protect Control Read/Write Address: 3C3h or 3C5h index 1Fh Power-on Default: 00h This register specifies write protect controls for the SMI extended registers. SMI extended registers are write-protected. In order to write to the SMI extended registers, one must write Bit [7:5] = 010b. 7 6 5 WPE 4 3 2 1 RESERVED Bit 7:5 Write Protect Enable (WPE) 101 = All SMI Extended registers are Write-Protected 010 = Enable writes to SMI Extended registers Others = Maintain previous state Bit 4:0 Reserved 15 - 8 0 PCI Configuration Space Registers Silicon Motion®, Inc. LynxEM+ DataBook Chapter 16: Standard VGA Registers Table 17: Standard VGA Registers Quick Reference Summary of Registers Page General Registers MISC: Miscellaneous Output Register 16 - 4 ISR0: Input Status Register 0 16 - 5 ISR1: Input Status Register 1 16 - 5 FCR: Feature Control Register 16 - 5 Sequencer Register SEQX: Sequencer Index Register 16 - 6 SEQ00: Reset Register 16 - 6 SEQ01: Clocking Mode Register 16 - 7 SEQ02: Enable Write Plane Register 16 - 7 SEQ03: Character Map Select Register 16 - 8 SEQ04: Memory Mode Register 16 - 8 CRTC Controller Registers CRTX: CRTC Controller Index Register 16 - 9 CRT00: Horizontal Total Register 16 - 9 CRT01: Horizontal Display End Register 16 - 10 CRT02: Horizontal Blank Start Register 16 - 10 CRT03: Horizontal Blank End Register 16 - 10 CRT04: Horizontal Sync Pulse Start Register 16 - 11 CRT05: End Horizontal Sync Pulse Register 16 - 11 CRT06: Vertical Total Register 16 - 12 CRT07: Overflow Vertical Register 16 - 12 CRT08: Preset Row Scan Register 16 - 13 CRT09: Maximum Scan Line Register 16 - 13 CRT0A: Cursor Start Scan Line Register 16 - 14 CRT0B: Cursor End Scan Line Register 16 - 14 CRT0C: Display Start Address High Register 16 - 15 CRT0D: Display Start Address Low Register 16 - 15 Standard VGA Registers 16 - 1 Silicon Motion®, Inc. LynxEM+ DataBook Summary of Registers Page CRT0E: Cursor Location High Register 16 - 15 CRT0F: Cursor Location Low Register 16 - 16 CRT10: Vertical Sync Pulse Start Register 16 - 16 CRT11: Vertical Sync Pulse End Register 16 - 16 CRT12: Vertical Display End Register 16 - 17 CRT13: Offset Register 16 - 17 CRT14: Underline Location Register 16 - 18 CRT15: Vertical Blank Start Register 16 - 18 CRT16: Vertical Blank End Register 16 - 18 CRT17: CRT Mode Control Register 16 - 19 CRT18: Line Compare Register 16 - 20 CRT22: Graphics Controller Data Latches Readback Register 16 - 20 CRT24: Attribute Controller Toggle Readback Register 16 - 20 CRT26: Attribute Controller Index Readback Register 16 - 21 Graphics Controller Registers GRXX: Graphics Controller Index Register 16 - 21 GRX00: Set/Reset Register 16 - 21 GRX01: Enable Set/Reset Register 16 - 22 GRX02: Color Compare Register 16 - 22 GRX03: Data Rotate/ROP Register 16 - 23 GRX04: Read Plane Select Register 16 - 23 GRX05: Graphics Mode Register 16 - 23 GRX06: Graphics Miscellaneous Register 16 - 24 GRX07: Color Don't Care Plane Register 16 - 25 GRX08: Bit Mask Register 16 - 25 Attribute Controller Registers ATRX: Attribute Controller Index Register 16 - 26 ATR00-0F: Palette Register 16 - 26 ATR10: Attribute Mode Control Register 16 - 27 ATR11: Overscan Color Register 16 - 28 ATR12: Color Plane Enable Register 16 - 28 ATR13: Horizontal Pixel Panning Register 16 - 29 ATR14: Color Select Register 16 - 29 RAMDAC Registers 3C6: DAC Mask Register 16 - 30 3C7W: DAC Address Read Register 16 - 30 3C7R: DAC Status Register 16 - 31 16 - 2 Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook Summary of Registers Page 3C8: DAC Address Write Register 16 - 31 3C9: DAC Data Register 16 - 31 Standard VGA Registers 16 - 3 Silicon Motion®, Inc. LynxEM+ DataBook Standard VGA Registers This chapter describes standard VGA registers. In the following registers description, a '?' in an address stands for a hexadecimal value of either 'B' or 'D'. If Bit 0 of the Miscellaneous Output Register is set to 1, the address is based at 3Dxh for color emulation. If Bit 0 of the Miscellaneous Output Register is set to 0, the address is based at 3Bxh for monochrome emulation. General Registers MISC: Miscellaneous Output Register Write Only Address: 3C2h Read Only Address: 3CCh Power-on Default: 00h 7 6 5 4 VSP HSP OEM R 3 2 VIDEO CLOCK 1 0 EVR IO Bit 7 Vertical Sync Polarity Select (VSP) 0 = positive vertical sync polarity 1 = negative vertical sync polarity Bit 6 Horizontal Sync Polarity Select (HSP) 0 = positive horizontal sync polarity 1 = negative horizontal sync polarity Bit 5 Odd/Even Memory Page Select (OEM) 0 = Select lower 64K page of memory 1 = Select upper 64K page of memory Bit 4 Reserved (R) Bit 3:2 Video Clock Select 00 = Select 25.175MHz for 640 dots/line mode 01 = Select 28.322MHz for 720 dots/line mode 10 = Reserved (enable external clock source) 11 = Reserved (enable external clock source) Bit 1 Enable Video RAM Access from CPU (EVR) 0 = Disable Video RAM access from CPU 1 = Enable Video RAM access from CPU Bit 0 I/O Address Select (IO) 0 = Select monochrome mode. Address based at3Bxh. 1 = Select for color mode. Address based at 3Dxh 16 - 4 Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook ISR0: Input Status Register 0 Read Only Address: 3C2h Power-on Default: Undefined 7 CRT 6 5 RESERVED 4 3 MDS 2 1 0 RESERVED Bit 7 CRT Vertical Retrace Interrupt (CRT) 0 = Vertical Retrace Interrupt is cleared 1 = Vertical Retrace Interrupt is pending. Bit 6:5 Reserved Bit 4 Monitor Detect Status (MDS) 0 = Monochrome display is detected 1 = Color display is detected Bit 3:0 Reserved ISR1: Input Status Register 1 Read Only Address: 3?Ah Power-on Default: Undefined 7 6 RESERVED 5 4 COLOR PLANE 3 2 VRS R 1 0 DISPLAY ENABLE Bit 7:6 Reserved Bit 5:4 Color Plane Diagnostics These bits return two of the 8 video outputs VID0-VID7, as selected by Color Plane Enable Register [5:4] Bit 3 Vertical Retrace Status (VRS) 0 = In display mode 1 = In vertical retrace mode Bit 2:1 Reserved (R) Bit 0 Display Enable 0 = In display mode 1 = Not in display mode. (it is either in horizontal or vertical retrace mode) FCR: Feature Control Register Write Only Address: 3?Ah Standard VGA Registers 16 - 5 Silicon Motion®, Inc. LynxEM+ DataBook Read Only Address: 3CAh Power-on Default: 00h 7 6 5 4 RESERVED 3 2 VSC 1 0 RESERVED Bit 7:4 Reserved Bit 3 Vertical Sync Control 0 = VSYNC output is enabled 1 = VSYNC output is logical 'OR' of VSYNC and Vertical Display Enable Bit 2:0 Reserved Sequencer Register SEQX: Sequencer Index Register Read/ Write Address: 3C4h Power-on Default: Undefined 7 6 5 4 RESERVED 3 2 1 0 SEQUENCER ADDRESS/INDEX Bit 7:4 Reserved Bit 3:0 Sequencer Address/Index The Sequencer address register is written with the index value of the sequencer register to be accessed. SEQ00: Reset Register Read/ Write Address: 3C5h, Index: 00h Power-on Default: 00h 7 6 5 4 RESERVED 3 2 1 0 SR AR Bit 7:2 Reserved Bit 1 Synchronous Reset (SR) 0 = Sequencer is cleared and halted synchronously 1 = Normal operating mode Bit 0 Asynchronous Reset (AR) 0 = Sequencer is cleared and halted asynchronously 1 = Normal operating mode 16 - 6 Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook SEQ01: Clocking Mode Register Read/ Write Address: 3C5h, Index: 01h Power-on Default: 00h 7 6 RESERVED 5 4 3 2 1 0 SO VS DCS SL R DC Bit 7:6 Reserved Bit 5 Screen Off (SO) 0 = Normal operating mode 1 = Screen is turned off but SYNC signals remain active Bit 4 Video Serial Shift Select (VS) 0 = Load video serializer every or every other character or clock, depending on Bit2 of this register. 1 = Load video serializer every 4th character clock Bit 3 Dot Clock Select (DCS) 0 = Normal dot clock select by VCLK input frequency 1 = Dot clock is divided by 2 (320/360 pixel mode) Bit 2 Shift Load (SL) 0 = Load video serializer every character or clock 1 = Load video serializer every other character or clock Bit 1 Reserved (R) Bit 0 8/9 Dot Clock (DC) 0 = 9 dot wide character clock 1 = 8 dot wide character clock SEQ02: Enable Write Plane Register Read/ Write Address: 3C5h, Index: 02h Power-on Default: 00h 7 6 5 RESERVED 4 3 2 1 0 ENABLE WRITING Bit 7:4 Reserved Bit 3:0 Enable Writing to Memory Maps 3 through 0 (respectively) 0 = Disable writing to corresponding plane 1 = Enable writing to corresponding plane Standard VGA Registers 16 - 7 Silicon Motion®, Inc. LynxEM+ DataBook SEQ03: Character Map Select Register Read/ Write Address: 3C5h, Index: 03h Power-on Default: 00h 7 6 RESERVED 5 4 3 2 1 0 SCM SCMB SCMA SCMA SCMB SCMB Bit 7:6 Reserved Bit 5,3,2 Select Character Map A (SCMA) This value select the portion of plane 2 used to generate text character when bit 3 of this register = 0, according to the following table: Bit 5,3,2 Bit 4,1,0 Font Table Location 000 First 8K of plane 2 100 Second 8K of plane 2 001 Third 8K of plane 2 101 Fourth 8K of plane 2 010 Fifth 8K of plane 2 110 Sixth 8K of plane 2 011 Seventh 8K of plane 2 111 Eighth 8K of plane 2 Select Character Map B (SCMB) This value select the portion of plane 2 used to generate text character when bit 3 of this register = 1, according to the same table as character Map A SEQ04: Memory Mode Register Read/ Write Address: 3C5h, Index: 04h Power-on Default: 00h 7 6 5 RESERVED 4 3 2 1 0 CM SSA EVM R Bit 7:4 Reserved Bit 3 Chained 4 Map (CM) 0 = Enable odd/even mode 1 = Enable Chain 4 mode. Uses the two lower bits of CPU address to select plane in video memory as follows: 16 - 8 Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook MA1 MA0 Plane Selected 0 0 0 0 1 1 1 0 2 1 1 3 Bit 2 Select Sequential Addressing Mode (SSA). This bit affects only CPU write data accesses into video memory. Bit 3 of this register must be 0 for this bit to be effective. 0 = Enable the odd/even addressing mode. Even addresses access planes 0 and 2, and odd addresses access plane 1 and 3 1 = Enable system to use a sequential addressing mode Bit 1 Extended Video Memory Enable (EVM) 0 = Memory access restricted to 16/32K 1 = Enable extended video memory access. Allows complete memory access to 256K Bit 0 Reserved (R) CRTC Controller Registers The CRTC registers are located at two locations in I/O address space. These registers are accessed by first writing to the index register (3?4h), then writing to the data register (3?5h). The I/O address is either 3Bxh or 3Dxh depending on bit 0 of the Miscellaneous Output Register at 3C2h. CRTX: CRTC Controller Index Register Read/Write Address: 3?4h Power-on Default: 00h This register is loaded with a binary value that indexes the CRTC controller register where data is to be accessed. 7 6 5 4 RESERVED 3 2 1 0 CRTC ADDRESS INDEX Bit 7:5 Reserved Bit 4:0 CRTC Address Index These bits specify the CRTC register to be addressed. Its value is programmed in hexadecimal. CRT00: Horizontal Total Register Read/Write Address: 3?5h, Index 00h Power-on Default: Undefined This register defines the number of character clocks from HSYNC going active to the next HSYNC going active. Standard VGA Registers 16 - 9 Silicon Motion®, Inc. 7 6 LynxEM+ DataBook 5 4 3 2 1 0 HORIZONTAL TOTAL Bit 7:0 Horizontal Total This value = (number of character clocks per scan line) - 5. CRT01: Horizontal Display End Register Read/Write Address: 3?5h, Index 01h Power-on Default: Undefined This register defines the number of character clocks for one horizontal line active display. This register is locked when FPR33 (SC5h, index 33) bit 5 = 1. Please refer to FPR33 register. 7 6 5 4 3 2 1 0 HORIZONTAL DISPLAY ENABLE Bit 7:0 Horizontal Display End This value = (number of character clocks during active display) - 1. CRT02: Horizontal Blank Start Register Read/Write Address: 3?5h, Index 02h Power-on Default: Undefined This register defines the number of character clocks at which horizontal ~Blank is asserted. 7 6 5 4 3 2 1 0 HORIZONTAL BLANK START Bit 7:0 Horizontal Blank Start This value = character value at which ~Blank signal becomes active. CRT03: Horizontal Blank End Register Read/Write Address: 3?5h, Index 03h Power-on Default: Undefined This register defines the display enable skew and pulse width of ~Blank signal. 7 R Bit 7 16 - 10 6 5 DISPLAY ENABLE 4 3 2 1 0 HORIZONTAL BLANK END Reserved Standard VGA Registers Silicon Motion®, Inc. Bit 6:5 LynxEM+ DataBook Display Enable Skew. These 2 bits define the display enable signal skew timing in relation to horizontal synchronization pulses. Bit 4:0 DESKW1 DESKW0 Character Clock Skew 0 0 0 0 1 1 1 0 2 1 1 3 Horizontal Blank End Horizontal Blank End has a 6-bit value. This register contains the least significant 5-bits of this value. Bit 6 of this value is at CRTC index 05 bit 7. CRT04: Horizontal Sync Pulse Start Register Read/Write Address: 3?5h, Index 04h Power-on Default: Undefined This register is used to adjust screen position horizontally and to specify the position at which HSYNC is active. 7 6 5 4 3 2 1 0 HORIZONTAL SYNC PULSE START Bit 7:0 Horizontal Sync Pulse Start This value = character clock count value at which HSYNC becomes active. CRT05: End Horizontal Sync Pulse Register Read/Write Address: 3?5h, Index 05h Power-on Default: Undefined This register defines the horizontal sync skew and pulse width of HSYNC signal. 7 HBE 6 5 HSS 4 3 2 1 0 HORIZONTAL SYNC END Bit 7 Horizontal Blank End Bit 5. This bit is End Horizontal Blank Bit 5. (HBE) Bit 6:5 Horizontal Sync Skew. (HSS) These 2-bits define the HSYNC signal skew timing in relation to horizontal synchronization pulses. Standard VGA Registers 16 - 11 Silicon Motion®, Inc. Bit 4:0 LynxEM+ DataBook HSSKW1 HSSKW0 Character Clock Skew 0 0 0 0 1 1 1 0 2 1 1 3 Horizontal Sync End Horizontal Sync End has a 5-bit value. This value defines the character clock counter value at which HSYNC signal becomes inactive. CRT06: Vertical Total Register Read/Write Address: 3?5h, Index 06h Power-on Default: Undefined This register defines the number of scan lines from VSYNC going active to the next VSYNC going active. Vertical total has a 11-bit value. Bit 8 of this value is located at CRT07 bit 0. Bit 9 of this value is located at CRT07 bit 5. Bit 10 of this value is located at CRT30 bit 3. 7 6 5 4 3 2 1 0 VERTICAL TOTAL Bit 7:0 Vertical Total Vertical Total has a 11-bit value. This register contains the least significant 8-bits of this value. This value = (number of scan lines from VSYNC going active to the next VSYNC) - 2. Bit 8 is in CRT07 bit 0. Bit 9 is in CRT 07 bit 5. Bit 10 is in CRT30 bit 3. CRT07: Overflow Vertical Register Read/ Write Address: 3?5hIndex: 07h Power-on Default: Undefined This register specifies the CRTC vertical overflow registers. 7 6 5 4 3 2 1 0 VSS VDE VT LC VBS VSS VDE VT Bit 7 Vertical Sync Start Bit 9 (VSS) Bit 6 Vertical Display Enable End Bit 9. This bit is locked when FPR33 (SC5h, index 33) bit 5 = 1. Please refer to FPR33 register. (VDE) Bit 5 Vertical Total Bit 9 (VT) Bit 4 Line Compare Bit 8 (LC) 16 - 12 Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook Bit 3 Vertical Blank Start Bit 8 (VBS) Bit 2 Vertical Sync Start Bit 8 (VSS) Bit 1 Vertical Display Enable End Bit 8. This bit is locked when FPR33 (SC5h, index 33) bit 5 = 1. (VDE) Bit 0 Vertical Total Bit 8 (VT) CRT08: Preset Row Scan Register Read/Write Address: 3?5h, Index 08h Power-on Default: Undefined This register is used for panning and text scrolling. 7 R 6 5 4 BYTE PLANNING 3 2 1 0 PRESET ROW SCAN COUNT Bit 7 Reserved (R) Bit 6:5 Byte Panning Control. These 2-bits controls the number of bytes to pan. Bit 4:0 BPC1 BPC0 Operation 0 0 Normal 0 1 1 Byte left shift 1 0 2 Bytes left shift 1 1 3 Bytes left shift Preset Row Scan Count These bits preset the vertical row scan counter once after each vertical retrace. This counter is automatically incremented by 1 after each horizontal sync period. Once the maximum row scan count is reached, this counter is cleared. This is useful for smoothing vertical text scrolling. CRT09: Maximum Scan Line Register Read/Write Address: 3?5h, Index 09h Power-on Default: Undefined This register defines the maximum number of scan lines per character row and provides one scanning control and two overflow bits 7 6 5 EDS LC VB Bit 7 4 3 2 1 0 MAXIMUM SCAN LINE Enable Double Scan (EDS) 0 = Normal Operating Standard VGA Registers 16 - 13 Silicon Motion®, Inc. LynxEM+ DataBook 1 = Enable Double Scan. The row scan counter is clocked at half of the horizontal scan rate. Bit 6 Line Compare Register Bit 9 (LC) Bit 5 Vertical Blank Start Register Bit 9 (VB) Bit 4:0 Maximum Scan Line This value equals to the total number of scan lines per character row - 1 CRT0A: Cursor Start Scan Line Register Read/Write Address: 3?5h, Index 0Ah Power-on Default: Undefined This register defines the row scan of a character line at which the cursor begins and enable/disable cursor. 7 6 RESERVED 5 4 EC 3 2 1 0 CURSOR START SCAN LINE Bit 7:6 Reserved Bit 5 Enable Cursor (EC) 0 = Cursor is on 1 = Cursor is off Bit 4:0 Cursor Start Scan Line This value equals to the starting cursor row within the character box. If this value is programmed with a value greater than the Cursor End Scan Line Register (3?5h, index 0Bh), no cursor will be displayed. CRT0B: Cursor End Scan Line Register Read/Write Address: 3?5h, Index 0Bh Power-on Default: Undefined This register defines the row scan of a character line at which the cursor begins and enable/disable cursor. 7 R 6 5 CURSOR SKEW 4 3 2 1 0 CURSOR END SCAN LINE Bit 7 Reserved (R) Bit 6:5 Cursor Skew. These 2 bits defines the cursor delay skew, which moves the cursor to the right, in character clock. 16 - 14 Standard VGA Registers Silicon Motion®, Inc. Bit 4:0 LynxEM+ DataBook CSKW1 CSKW0 Character Clock Skew 0 0 0 0 1 1 1 0 2 1 1 3 Cursor End Scan Line This value equals to the ending cursor row within the character box. If this value is programmed with a value less than the Cursor Start Scan Line Register (3?5h, index 0Ah), no cursor will be displayed. CRT0C: Display Start Address High Register Read/Write Address: 3?5h, Index 0Ch Power-on Default: Undefined This register defines the high order first address after a vertical retrace at which the display on the screen begins on each screen refresh. This value is a 19-bit value. Bit [18:16] are located in CRT30 bit [6:4]. Bit [7:0] are located in CRT0D. 7 6 5 4 3 2 1 0 DISPLAY START ADDRESS [15:8] Bit 7:0 Display Start Address [15:8] This register is the high order byte of the address [15:8]. CRT0D: Display Start Address Low Register Read/Write Address: 3?5h, Index 0Dh Power-on Default: Undefined This register defines the low order first address after a vertical retrace at which the display on the screen begins on each screen refresh. This value is a 19-bit value. Bit [18:16] are in CRT30 bit [6:4]. Bit [15:8] are in CRT0C. 7 6 5 4 3 2 1 0 START ADDRESS [7:0] Bit 7:0 Start Address [7:0] This register is the low order byte of the address [7:0]. CRT0E: Cursor Location High Register Read/Write Address: 3?5h, Index 0Eh Power-on Default: Undefined Standard VGA Registers 16 - 15 Silicon Motion®, Inc. LynxEM+ DataBook This register defines the high order cursor location address. This value is a 19-bit value along with CRT30 bit[6:4] are the high order bits of the address. 7 6 5 4 3 2 1 0 CURSOR LOCATION HIGH Bit 7:0 Cursor Location High This register is the high order byte of the cursor location address. CRT0F: Cursor Location Low Register Read/Write Address: 3?5h, Index 0Fh Power-on Default: Undefined This register defines the low order cursor location address. 7 6 5 4 3 2 1 0 CURSOR LOCATION LOW Bit 7:0 Cursor Location Low This register is the low order byte of the cursor location address. CRT10: Vertical Sync Pulse Start Register Read/Write Address: 3?5h, Index 10h Power-on Default: Undefined This register is used to adjust screen position vertically and to specify the position at which VSYNC is active. Bit 10 of this value is in CRT30 bit 0. Bit 9 of this value is in CRT07 bit 7. Bit 8 of this value is in CRT07 bit 2. 7 6 5 4 3 2 1 0 VERTICAL SYNC PULSE START Bit 7:0 Vertical Sync Pulse Start Vertical Sync Start has a 11-bit value. This register contains the least significant 8 bits of this value. This value = number of scan lines at which VSYNC becomes active. CRT11: Vertical Sync Pulse End Register Read/Write Address: 3?5h, Index 11h Power-on Default: 0xh. This register is used to control vertical interrupt, vertical sync end CRT0-7 Write protect. 7 6 5 4 LW RCS DVI CVI 16 - 16 3 2 1 0 VERTICAL SYNC PULSE END Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook Bit 7 Lock writing to CRTC registers: CRT00-07. (LW) 0 = Enable writing to CRTC registers are 1 = Disable writing to CRTC registers, except CRT07 bit 4 (line compare) Bit 6 Refresh Cycle Select (3/5) (RCS) 0 = 3 DRAM refresh cycles per horizontal scan line 1 = 5 DRAM refresh cycles per horizontal scan line Bit 5 Disable Vertical Interrupt (DVI) 0 = vertical retrace interrupt enabled 1 = vertical retrace interrupt disabled Bit 4 Clear Vertical Interrupt (CVI) 0 = vertical retrace interrupt is cleared 1 = vertical retrace interrupt. This allows an interrupt to be generated at the end of active vertical display. Bit 3:0 Vertical Sync Pulse End This value = number of scan lines at which VSYNC becomes inactive. CRT12: Vertical Display End Register Read/Write Address: 3?5h, Index 12h Power-on Default: Undefined This register defines the number of scan line where the display on the screen ends. Bit 10 of this value is in CRT30 bit 2. Bit 9 of this value is in CRT07 bit 6. Bit 8 of this value is in CRT07 bit 1. This register is locked when FPR33 (SC5h, index 33) bit 5 = 1. Please refer to FPR33 register. 7 6 5 4 3 2 1 0 VERTICAL DISPLAY END Bit 7:0 Vertical Display End Vertical Display End has a 11-bit value. This register contains the least significant 8-bits of this value. This value = (number of scan lines during active display) - 1. CRT13: Offset Register Read/Write Address: 3?5h, Index 13h Power-on Default: Undefined 7 6 5 4 3 2 1 0 LOGICAL SCREEN WIDTH This register defines the logical line width of the screen. The starting memory address for the next display row is larger than the current row by two (in byte mode), four (in word mode), or eight (in double word mode) times this offset. Standard VGA Registers 16 - 17 Silicon Motion®, Inc. Bit 7:0 LynxEM+ DataBook Logical Screen Width Logical Screen Width has a 10-bit value. This register contains the least significant 8-bits of this value. The addressing mode is specified by bit 6 of CRT14 and bit 3 of CRT17. CRT14: Underline Location Register Read/Write Address: 3?5h, Index 14h Power-on Default: Undefined This register defines the horizontal row scan position of underline and display buffer addressing modes. 7 6 5 4 R DWS CS 3 2 1 0 UNDER LINE LOCATION Bit 7 Reserved (R) Bit 6 Double Word Mode Select (DWS) 0 = the memory address are byte or word addresses 1 = the memory address are double word addresses Bit 5 Count by 4 Select (CS) 0 = the memory address counter depends on bit 3 of CRT17 1 = the memory address counter is incremented every four character clocks Bit 4:0 Under Line Location Under Line Location has a 5-bit value. This value = (scan line count of a character row on which an underline occurs) - 1. CRT15: Vertical Blank Start Register Read/Write Address: 3?5h, Index 15h Power-on Default: Undefined This register defines the number of scan lines at which vertical blank is asserted. Bit 10 of this value is in CRT30 bit 1. Bit 9 of this value is in CRT09 bit 5. Bit 8 of this value is in CRT07 bit 3. 7 6 5 4 3 2 1 0 VERTICAL BLANK START Bit 7:0 Vertical Blank Start Vertical Blank Start has a 11-bit value. This register contains the least significant 8-bits of this value. This value = (scan line count at which vertical blank signal becomes active) - 1. CRT16: Vertical Blank End Register Read/Write Address: 3?5h, Index 16h Power-on Default: Undefined 16 - 18 Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook This register defines the number of scan lines at which vertical blank is de-asserted. 7 6 5 4 3 2 1 0 VERTICAL BLANK END Bit 7:0 Vertical Blank End Vertical Blank End is a 8-bit value. This value = [(scan line count at which vertical blank signal becomes active) -1)] + (desired width of vertical blanking pulse in scan lines) CRT17: CRT Mode Control Register Read/Write Address: 3?5h, Index 17h Power-on Default: Undefined This register defines the controls for CRT mode. 7 6 5 4 3 2 1 0 HR BAS AW R WS HCS EGA CGA Bit 7 ~RST Hardware Reset for Horizontal and Vertical Sync (HR) 0 = horizontal and vertical sync outputs inactive 1 = horizontal and vertical sync outputs active Bit 6 Byte Address Mode Select (BAS) 0 = word address mode. All memory address counter bits shift down by one bit and the MSB of the address counter appears on the LSB 1 = byte address mode Bit 5 Address Wrap is useful in implementing CGA mode. (AW) 0 = In word address mode, memory address counter bit 13 appears on the memory address output signal of the CRT controller and the video memory address wraps around at 16KB. 1 = In word address mode, memory address counter bit 15 appears on the memory address output bit 0 signal of the CRTC controller. Bit 4 Reserved (R) Bit 3 Word Mode Select (WS) 0 = byte mode addressing is selected and memory address counter is clocked by the character clock input 1 = word mode addressing is selected and memory address counter is clocked by the character clock divided by two. Bit 2 Horizontal Retrace Clock Select (HCS) 0 = select horizontal retrace clock rate 1 = select horizontal retrace clock rate divided by two. Bit 1 EGA Emulation (EGA) Standard VGA Registers 16 - 19 Silicon Motion®, Inc. LynxEM+ DataBook 0 = Row scan counter bit 1 is replaced by memory address bit 14 during active display time 1 = Memory address bit 14 appear son the memory address output bit 14 signal of the CRT controller. Bit 0 CGA Emulation (CGA) 0 = Row scan counter bit 0 is replaced by memory address bit 13 during active display time 1 = Memory address bit 13 appears on the memory address output bit 13 signal of the CRT controller. CRT18: Line Compare Register Read/Write Address: 3?5h, Index 18h Power-on Default: Undefined This register is used to implement a split screen function. When the scan line counter value is equal to the content of this register, the memory address counter is cleared to 0. 7 6 5 4 3 2 1 0 LINE COMPARE REGISTER Bit 7:0 Line Compare Register This value = number of scan lines at which the screen is split into screen 1 and screen 2. CRT22: Graphics Controller Data Latches Readback Register Read Only Address: 3?5h, Index 22h Power-on Default: Undefined This register is used to read the CPU latches in the graphics controller. 7 6 5 4 3 2 1 0 GRAPHICS CONTROLLER CPU DATA LATCHES Bit 7:0 Graphics Controller CPU Data Latches Bits 1-0 of GR4 select the latch number N (3-0) of the CPU Latch. CRT24: Attribute Controller Toggle Readback Register Read Only Address: 3?5h, Index 24h Power-on Default: Undefined This register is used to provide access to the attribute controller toggle. 7 ACS Bit 7 16 - 20 6 5 4 3 2 1 0 RESERVED Attribute Controller Index Select (ACS) 0 = the attribute controller reads or writes an index value on the next access Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook 1 = the attribute controller reads or writes a data value on the next access Bit 6:0 Reserved CRT26: Attribute Controller Index Readback Register Read Only Address: 3?5h, Index 26h Power-on Default: Undefined This register is used to provide access to the attribute controller index. 7 6 RESERVED 5 4 VES 3 2 1 0 ATTRIBUTE CONTROLLER INDEX Bit 7:6 Reserved Bit 5 Video Enable Status (VES) This bit provides status of the video display enable bit in Attribute Controller (3C0h) index bit 5. Bit 4:0 Attribute Controller Index This value is the attribute controller index data at 3C0h. Graphics Controller Registers The graphics controller registers are located at a two byte I/O address space. The registers are accessed by first writing an index to 3CEh and followed by writing a data to 3CFh. GRXX: Graphics Controller Index Register Read/Write Address: 3CEh Power-on Default: Undefined This register is loaded with a binary value that indexes the graphics controller register where data is to be accessed. 7 6 5 RESERVED 4 3 2 1 0 GRAPHICS CONTROLLER Bit 7:4 Reserved Bit 3:0 Graphics Controller Address Index These bits specify the graphics controller register to be addressed. hexadecimal. Its value is programmed in GRX00: Set/Reset Register Read/Write Address: 3CFh, Index: 00h. Power-on Default: Undefined Standard VGA Registers 16 - 21 Silicon Motion®, Inc. LynxEM+ DataBook This register represents the value written to all 8-bits of the corresponding memory planes when CPU executes a memory write in write mode 0. 7 6 5 4 3 2 RESERVED 1 0 SET/RESET PLANE Bit 7:4 Reserved Bit 3:0 Set/Reset Plane3:0 In write mode 0, the set/reset data can be enabled on the corresponding bit of the bit of the Enable Set/ Reset Data register. These bits become the color value for CPU memory write operations. GRX01: Enable Set/Reset Register Read/Write Address: 3CFh, Index: 01h. Power-on Default: Undefined This register enable the set/reset register in write mode 0. 7 6 5 4 3 RESERVED 2 1 0 ENABLE SET/RESET PLANE Bit 7:4 Reserved Bit 3:0 Enable Set/Reset Plane3:0 In write mode 0, the enable set/reset bits allow writing to the corresponding planes with the data in set/ reset register. A logical 0 disables the set/reset data in a plane, and that plane is written with the value of CPU write data. GRX02: Color Compare Register Read/Write Address: 3CFhIndex: 02h. Power-on Default: Undefined This register is to used to compare with the CPU memory read data. This register works in conjunction with the Color Don't Care Register. 7 6 5 RESERVED 4 3 2 1 0 COLOR COMPARE PLANE Bit 7:4 Reserved Bit 3:0 Color Compare Plane [3:0] These bits represent the reference color used to compare each pixel in corresponding plane. A logical 1 is returned in each plane bit position when color matches. 16 - 22 Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook GRX03: Data Rotate/ROP Register Read/Write Address: 3CFhIndex: 03h. Power-on Default: Undefined This register is to used to control rotation and raster operations. 7 6 5 4 RESERVED 3 2 ROS 1 0 ROTATE COUNT Bit 7:5 Reserved Bit 4:3 Raster Operations Select (ROS) 00 = No operation 01 = Logical AND with latched data 10 = Logical OR with latched data 11 = Logical XOR with latched data Bit 2:0 Rotate Count These bits specifies the number of bit positions of rotation to the right. Data written by the CPU is rotated in write mode 0. To write non-rotated data, the CPU must present a count with 0. GRX04: Read Plane Select Register Read/Write Address: 3CFhIndex: 04h. Power-on Default: Undefined This register is selects which memory plane the CPU data is reading from in read mode 0. This register has no effect on the color compare read mode (read mode 1). In odd/even mode, bit 0 is ignored. 7 6 5 4 3 RESERVED Bit 7:2 Reserved Bit 1:0 Read Plane Select is as follows: 00 = Plane 0 01 = Plane 1 10 = Plane 2 11 = Plane 3 2 1 0 READ PLANE GRX05: Graphics Mode Register Read/Write Address: 3CFhIndex: 05h. Power-on Default: Undefined Standard VGA Registers 16 - 23 Silicon Motion®, Inc. LynxEM+ DataBook This register is selects which memory plane the CPU data is reading from in read mode 0. This register has no effect on the color compare read mode (read mode 1). In odd/even mode, bit 0 is ignored. 7 6 5 4 3 2 R CS OES OEA ERC R 1 0 WRITING MODE Bit 7 Reserved (R) Bit 6 256 Color Shift Mode Select (CS) 0 = Enable bit 5 of this register to control loading of the shift registers. 1 = The shift registers are loaded in a manner that support the 256 color mode. Bit 5 Odd/Even Shift Mode Select (OES) 0 = Normal shift mode 1 = The video shift registers are directed to format the serial data stream with even numbered bits from both planes on the even numbered planes and odd numbered bits from both planes on the odd planes. Bit 4 Odd/Even Addressing Select (OEA) 0 = Normal addressing 1 = CGA Odd/even addressing mode is selected. Even CPU addresses access plane 0 and 2, while odd CPU addresses access plane 1 and 3. Bit 3 Enable Read Compare (ERC) 0 = System read data from memory planes selected by read map select register (3CFh index 04h). This is called read mode 0. 1 = System read the results of logical comparison between the data in 4 memory planes selected by the Color Don't Care Register and the Color Compare Register. The results is a 1 for a match and 0 for a mismatch on each pixel. This is called read mode 1. Bit 2 Reserved (R) Bit 1:0 Write Mode Select 00 = Write mode 0. Each of four video planes is written with CPU data rotated by the number of counts in rotate register. If Set/Reset register is enabled for any of the four planes, the corresponding planes is written with the data stored in the Set/Reset register. 01 = Write mode 1. Each of four video planes is written with CPU data in the processor latches. These latches are loaded during previous CPU read operations. Raster operation, rotate count, Set/Reset data, enable Set/Reset data and bit mask registers are ignored. 10 = Write mode 2. Video planes [3:0] are written with the value of CPU write data [3:0]. The 32-bit output from the four planes is then operated on by the Bit Mask register and the resulting data are written into the four planes. The Set/Reset, Enable Set/Reset and Rotate Count registers are ignored. 11 = Write mode 3. Each of the four video planes is written with 8-bit of the color value in the Set/Reset register for the corresponding plane. The bit-position-enable field is formed with the logical AND of the Bit Mask register and rotated CPU data. The Enable Set/Reset register is ignored. GRX06: Graphics Miscellaneous Register Read/Write 16 - 24 Address: 3CFhIndex: 06h. Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook Power-on Default: Undefined This register controls video memory addressing. 7 6 5 4 RESERVED 3 2 MEMORY MAP 1 0 OES GMS Bit 7:4 Reserved Bit 3:2 Memory Map Mode. These bits control the address mapping of video memory into the CPU address space. 00 = A0000h to BFFFFh (128KB) 01 = A0000h to AFFFFh (64KB) 10 = B0000h to B7FFFh (32KB) 11 = B8000h to BFFFFh (32KB) Bit 1 Odd/Even Mode Select (OES) 0 = CPU address bit A0 is the memory address bit MA0 1 = CPU address A0 is replaced by a higher order address bit. A0 is then used to select odd or even maps. A0=0, selects Map 2 or 0; A0 = 1, select Map 3 or 1. Bit 0 Graphics Mode Select (GMS) 0 = Select Text mode 1 = Select Graphics mode GRX07: Color Don't Care Plane Register Read/Write Address: 3CFhIndex: 07h. Power-on Default: Undefined This register controls whether the corresponding bit of the Color Compare Register, GRX02, is to be ignored or used for color comparison. This register is used with GRX02 for Read Mode 1 accesses. 7 6 5 4 3 RESERVED 2 1 0 COMPARE PLANE SELECT Bit 7:4 Reserved Bit 3:0 Compare Plane Select 0 = The corresponding color plane becomes a don't care plane when the CPU read from the video memory is performed in read mode 1. 1 = The corresponding color plane is used for color comparison with the data in the Color Compare Register, GRX02. GRX08: Bit Mask Register Read/Write Address: 3CFhIndex: 08h. Power-on Default: Undefined Standard VGA Registers 16 - 25 Silicon Motion®, Inc. LynxEM+ DataBook This register controls bit mask operations which applies simultaneously to all four maps. The data written into memory in this case is the data which was read in the previous cycle, and was stored in the processor latches. Any bit programmed to 1 allows unimpeded writes to the corresponding bits in the plane. 7 6 5 4 3 2 1 0 BIT MASK Bit 7:0 Bit Mask 0 = corresponding bit of each plane in memory is set to the corresponding bit in the processor latches. 1 = corresponding bit of each plane in memory is set as specified by other conditions. Attribute Controller Registers The attribute controller registers are located at the same byte I/O address for writing address and data. The Attribute Index Register has an internal flip-flop rather than an input bit to control the selection of the address and data registers. Reading the Input Status Register 1 at Port 3?Ah clears the flip-flop and selects the Address Register, which is read at address 3C1h and written at address 3C0h. Once the Address Register has been loaded with an index, the next write operation to 3C0h loads the Data Register. The flip-flop toggles between the Address and the Data Register after every write to address 3C0h, but does not toggle for reads from address 3C1h. Furthermore, the attribute controller index register is read at 3C0h, and the attribute controller data register is read at address 3C1h. ATRX: Attribute Controller Index Register Read/Write Address: 3C0h Power-on Default: Undefined This register is loaded with a binary value that indexes the attribute controller register where data is to be accessed. 7 6 RESERVED 5 PAS 4 3 2 1 0 ATTRIBUTE CONTROLLER ADDRESS Bit 7:6 Reserved Bit 5 Palette Address Source (PAS) 0 = Disable internal color palette outputs and video outputs to allow CPU access to color palette registers 1 = Enable internal color palette and normal video translation. Bit 4:0 Attribute Controller Address A binary value that points to the attribute controller register where data is to be written. ATR00-0F: Palette Register Read/Write Address: 3C1h/3C0hIndex 00h - 0Fh. Power-on Default: Undefined This register is loaded with a binary value that indexes the attribute controller register where data is to be accessed. 16 - 26 Standard VGA Registers Silicon Motion®, Inc. 7 6 LynxEM+ DataBook 5 4 RESERVED 3 2 1 0 PALETTE COLORS Bit 7:6 Reserved Bit 5:0 Palette Colors 0 = corresponding pixel color is de-selected 1 = corresponding pixel color is enabled ATR10: Attribute Mode Control Register Read/Write Address: 3C1h/3C0hIndex: 10h. Power-on Default: 00h This register controls the attribute mode of the display function. 7 6 5 4 3 2 1 0 VID CS PPE R BIS LGC MCE TGM Bit 7 VID5, VID4 Select (VID) 0 = VID5 and VID4 palette register outputs are selected 1 = Color Select Register Port 3C1h/3C0h, Index 14h, bit 1 and bit 0 are selected for outputs. Bit 6 256 Color Select (CS) 0 = Disable 256 color mode pixel width. PCLK rate = internal dot clock rate. 1 = Enable 256 color mode pixel width. PCLK rate = internal dot clock rate / 2 Bit 5 Pixel Panning Enable (PPE) 0 = Line compare will have no effect on the output of the pixel panning register 1 = Forces the output of the pixel panning register to 0 after matching line compare until VSYNC is active Bit 4 Reserved (R) Bit 3 Blinking and Intensity Select (BIS) 0 = Select background intensity from the text attribute byte. 1 = Select blink attribute in text modes Bit 2 Line Graphics Character Enable (LGC) 0 = Forces the ninth dot to be the same color as the background in line graphics character codes. 1 = Enable special line graphics character codes. Bit 1 Mono/Color Emulation (MCE) 0 = Select color display text attributes 1 = Select monochrome display text attributes Standard VGA Registers 16 - 27 Silicon Motion®, Inc. Bit 0 LynxEM+ DataBook Text /Graphics Mode Select (TGM) 0 = Select text attribute control mode 1 = Select graphics control mode ATR11: Overscan Color Register Read/Write Address: 3C1h/3C0hIndex: 11h. Power-on Default: 00h This register controls the overscan or border color. This register will be locked if CRT3C register (3?5h, index 3Ch) bit 5 is set to 1. Please refer to CRT3C register for details. 7 6 5 4 3 2 1 0 OVERSCAN COLOR REGISTER Bit 7:0 OverScan Color register determines the overscan or border color displayed on the CRT screen. ATR12: Color Plane Enable Register Read/Write Address: 3C1h/3C0hIndex: 12h. Power-on Default: 00h This register enables the respective video memory color plan 0-3 and selects the video color outputs to be read back in the display status. 7 6 RESERVED 5 4 3 VIDEO SATUS 2 1 0 COLOR PLANE ENABLE Bit 7:6 Reserved Bit 5:4 Video Status Multiplexer. These bits select two out of the 8 color outputs which can be read by the Input Status Register 1 at port 3?Ah, bit 5 and bit 4. Color Plane Register Bit 3:0 16 - 28 Input Status Register 1 Bit 5 Bit 4 Bit 5 Bit 4 0 0 VID2 VID0 0 1 VID5 VID4 1 0 VID3 VID1 1 1 VID7 VID7 Color Plane Enable 0 = disable the corresponding color planes. Forces pixel bit to be 0 before it address palette. 1 = enables the corresponding color planes. Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook ATR13: Horizontal Pixel Panning Register Read/Write Address: 3C1h/3C0hIndex: 13h. Power-on Default: 00h This register specifies the number of pixels to shift the display data horizontally to the left. Horizontal pixel panning is available in text and graphics modes. 7 6 5 4 RESERVED 3 2 1 0 HORIZONTAL PIXEL PLANNING Bit 7:4 Reserved Bit 3:0 Horizontal Pixel Panning. These 4 bits determine the horizontal left shift of the video data in number of pixels. In the 9 pixel/character text mode, the output can be shifted a maximum shift of 8 pixels. In the 8 pixel/character text mode and all graphics modes, except for 256 color mode, a maximum shift of 7 pixels is allowed. In the 256 color mode, bit 0 of this register must be 0 resulting in only 4 panning positions per display byte. The panning is controlled as follows: Bits 3:0 9 pixel/character 8 pixel/character 256 color modes 0000 1 0 0 0001 2 1 - 0010 3 2 1 0011 4 3 - 0100 5 4 2 0101 6 5 - 0110 7 6 3 0111 8 7 - 1000 0 - - ATR14: Color Select Register Read/Write Address: 3C1h/3C0h, Index: 14h. Power-on Default: 00h This register specifies the high-order bits of video output when pixel padding is enable/disabled for 256 color modes. 7 6 5 RESERVED 4 3 2 SC7/6 Bit 7:4 Reserved Bit 3:2 Select Color 7 and Color 6 (SC7/6) Standard VGA Registers 1 0 SC5/4 16 - 29 Silicon Motion®, Inc. LynxEM+ DataBook These are the two most significant bits of the 8 bits color value for video DAC. These are normally used in all modes except 256 color modes. Bit 1:0 Select Color 5 and Color 4 (SC5/4) These bits can be substituted for VID5 and VID4 from the palette registers to form the 8-bit color value for video DAC. RAMDAC Registers The section describes the RAMDAC registers. Special programming sequences are used to read or write data to and from the RAMDAC. Writing data to DAC: Write the color code to DAC Write Address Register at 3C8h. Three bytes: Red, Green, Blue values are written into DAC Data Register at 3C9h. Following the third write, the values are transferred to Color Lookup Table. • The DAC Write Address Register is auto incremented by 1. Reading data from DAC: • • Write the color code to DAC Read Address Register at 3C7h. Three bytes: Red, Green, Blue values are read from the DAC Data Register at 3C9h. 3C6: DAC Mask Register Read/Write Address: 3C6h Power-on Default: Undefined This register is the pixel read mask register to select pixel video output. 7 6 5 4 3 2 1 0 DAC ADDRESS MASK Bit 7:0 DAC Address Mask This field is the pixel mask for palette DAC. When a bit in this field is programmed to 0, the corresponding bit in the pixel data is ignored in looking up an entry I the Color Lookup Table. This register is initialized to FFh by the BIOS during a video mode set. 3C7W: DAC Address Read Register Write Only Address: 3C7h Power-on Default: Undefined This register contains the pointer to one of the 256 palette data registers and is used when reading the color palette. A write to this register causes 11b to be driven out to the RAMDAC output. 16 - 30 Standard VGA Registers Silicon Motion®, Inc. 7 6 LynxEM+ DataBook 5 4 3 2 1 0 DAC READ ADDRESS Bit 7:0 DAC Read Address After a color code is written into this register, the chip will identifies that a DAC read sequence will occur. A read sequence consists of three consecutive byte reads from the RAMDAC data register at 3C9h. 3C7R: DAC Status Register Read Only Address: 3C7h Power-on Default: Undefined This register specifies the DAC Status: read or write cycles. 7 6 5 4 3 2 RESERVED 1 0 DAC STATUS Bit 7:2 Reserved Bit 1:0 DAC Status bits 00 = DAC write operation in progress 11 = DAC read operation in progress 3C8: DAC Address Write Register Read/Write Address: 3C8h Power-on Default: Undefined This register contains the pointer to one of the 256 palette data registers and is during a palette load. A write to this register causes 11b to be driven out to the RAMDAC output. 7 6 5 4 3 2 1 0 DAC WRITE ADDRESS Bit 7:0 DAC Write Address After a color code is written into this register, the chip identifies that a DAC write sequence will occur. A write sequence consists of three consecutive byte reads from the RAMDAC data register at 3C9h. 3C9: DAC Data Register Read/Write Address: 3C9h Power-on Default: Undefined Standard VGA Registers 16 - 31 Silicon Motion®, Inc. LynxEM+ DataBook This register is the data port to read or write the contents of the location in the Color Lookup Table pointed to by the DAC Read Address or the DAC Write Address registers. An access to this register will cause 01b to be driven to RAMDAC outputs. 7 6 5 4 3 2 1 0 DAC READ/WRITE DATA Bit 7:0 16 - 32 DAC Read/Write Data These read/write register bits store the Pixel data for the Palette DAC. Standard VGA Registers Silicon Motion®, Inc. LynxEM+ DataBook Chapter 17: Extended SMI Registers Table 18: PCI Configuration Registers Quick Reference Summary of Registers Page System Control Registers SCR10: PCI Master Starting Address 7:0 17 - 6 SCR11: PCI Master Starting Address 15:8 17 - 6 SCR12: PCI Master Starting Address 23:16 17 - 7 SCR13: PCI Master Starting Address 31:24 17 - 7 SCR15: PCI Miscellaneous Control Register 17 - 7 SCR16: Status for Drawing Engine and Video Processor 17 - 8 SCR17: General Graphics Command Register 1 17 - 9 SCR18: General Graphics Command Register 2 17 - 10 SCR19: Interrupt Enable and Mask I 17 - 11 SCR1A: Interrupt Status 17 - 12 SCR1C: Interrupt Status USR 0-3 17 - 12 SCR1F: Interrupt Mask & Interrupt Status USR 0-3 17 - 13 Power Down Control Registers PDR20: Power Down Control for Memory, Flat Panel, PLL, and Video Port 17 - 14 PDR21: Functional Blocks Disable Control 17 - 15 PDR22: LCD Panel Control Select 17 - 16 PDR23: Activity Detection Control Register 17 - 17 PDR24: Power Down Register Select 17 - 18 Flat Panel Registers FPR30: Flat Panel Type Select 17 - 18 FPR31: Virtual Refresh and Auto Shut Down Control 17 - 19 FPR32: Dithering Engine Select, Polarity, and Expansion Control 17 - 20 FPR33: Panel Power Sequence and LCD Character/Cursor Blink Control 17 - 21 FPR34: LCD Panel ON/OFF Sequence Select and DSTN LCD Control 17 - 22 FPR3E: DSTN LCD Panel Height - High 17 - 23 FPR3F: DSTN LCD Panel Height- Low 17 - 23 FPR40: Read FIFO1 Start Address Low for LCD Frame Buffer 17 - 23 Extended SMI Registers 17 - 1 Silicon Motion®, Inc. LynxEM+ DataBook Summary of Registers (Continued) Page FPR41: Read FIFO1 Start Address High for LCD Frame Buffer 17 - 24 FPR42: Read FIFO2 Start Address Low for LCD Frame Buffer 17 - 24 FPR43: Read FIFO2 Start Address High for LCD Frame Buffer 17 - 25 FPR44: Read FIFO1 Offset Value of LCD Frame Buffer 17 - 25 FPR45: Read FIFO1 Address Offset for LCD Frame Buffer Overflow 17 - 25 FPR46: Write Start Address Low of LCD Frame Buffer 17 - 26 FPR47: Write Start Address High of LCD Frame Buffer 17 - 26 FPR48: Write Offset Value of LCD Frame Buffer 17 - 26 FPR49: LCD Frame Buffer Write Overflow 17 - 27 FPR4A: LCD Read and Write FIFOs Request Level Control 17 - 27 FPR4B: Read FIFO2 Offset Value of LCD Frame Buffer 17 - 28 FPR4C: Read FIFO Offset Value of LCD Frame Buffer Overflow 17 - 28 FPR50: LCD Overflow Register 1 for Virtual Refresh 17 - 28 FPR51: LCD Overflow Register 2 for Virtual Refresh 17 - 29 FPR52: LCD Horizontal Total for Virtual Refresh 17 - 29 FPR53: LCD Horizontal Display Enable for Virtual Refresh 17 - 29 FPR54: LCD Horizontal Sync Start for Virtual Refresh 17 - 30 FPR55: LCD Vertical Total for Virtual Refresh 17 - 30 FPR56: LCD Vertical Display Enable for Virtual Refresh 17 - 31 FPR57: LCD Vertical Sync Start for Virtual Refresh 17 - 31 FPR58: EMI Control Register 17 - 31 FPR59: Panel M-Signal Control Register 17 - 32 FPR5A: SYNC Pulse-widths Adjustment 17 - 32 FPRA0: Panel HW Video Control 17 - 33 FPRA1: Panel Video Color Key 17 - 33 FPRA2: Panel Video Color Key 17 - 34 FPRA3: Panel Video Color Key Mask 17 - 34 FPRA4: Panel Video Color Key Mask 15:8 17 - 34 FPRA5: Panel Video Red Constant 17 - 34 FPRA6: Panel Video Green Constant 17 - 35 FPRA7: Panel Video Blue Constant 17 - 35 FPRA8: Panel Video Top Boundary 17 - 35 FPRA9: Panel Video Left Boundary 17 - 35 FPRAA: Panel Video Bottom Boundary 17 - 36 FPRAB: Panel Video Right Boundary 17 - 36 FPRAC: Panel Video Top and Left Boundary Overflow 17 - 36 FPRAD: Panel Video Bottom and Right Boundary Overflow 17 - 37 17 - 2 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook Summary of Registers (Continued) Page FPRAE: Panel Video Vertical Stretch Factor 17 - 37 FPRAF: Panel Video Horizontal Stretch Factor 17 - 37 Memory Control Registers MCR60: Memory Control 17 - 38 MCR61: Memory Bank Address High 17 - 38 MCR62: Memory Type and Timing Control 17 - 39 Clock Control Registers CCR65: TV Encoder Control Register 17 - 40 CCR66: RAM LUT On/Off Control 17 - 40 CCR68: Clock Control 1 17 - 41 CCR69: Clock Control 2 17 - 42 CCR6A: MCLK Numerator Register 17 - 43 CCR6B: MCLK Denominator Register 17 - 44 CCR6C: VCLK Numerator Register 17 - 44 CCR6D: VCLK Denominator Register 17 - 44 CCR6E: VCLK2 Numerator Register 17 - 45 CCR6F: VCLK2 Denominator Register 17 - 45 General Purpose Registers GPR70: Scratch Pad Register 1 17 - 46 GPR71: Scratch Pad Register 2 17 - 46 GPR72: User Defined Register 1 for DDC2/ I2C 17 - 47 GPR73: User Defined Register 2 17 - 47 GPR74: Scratch Pad Register 3 17 - 48 GPR75: Scratch Pad register 4 17 - 48 Pop-up Icon Registers 17 - 50 PHR81: Hardware Cursor Enable & PI/HWC Pattern Location High 17 - 49 Pop-up Icon Registers POP82: Pop-up Icon Control 17 - 50 POP83: Reserved 17 - 50 POP84: Pop-up Icon Color 1 17 - 50 POP85: Pop-up Icon Color 2 17 - 51 POP86: Pop-up Icon Color 3 17 - 51 POP90: Pop-up Icon Start X - Low 17 - 51 POP91: Pop-up Icon Start X - High 17 - 51 POP92: Pop-up Icon Start Y - Low 17 - 52 POP93: Pop-up Icon Start Y - High 17 - 52 Hardware Cursor Registers Extended SMI Registers 17 - 3 Silicon Motion®, Inc. LynxEM+ DataBook Summary of Registers (Continued) Page HCR88: Hardware Cursor Upper Left X Position - Low 17 - 52 HCR89: Hardware Cursor Upper Left X Position- High 17 - 53 HCR8A: Hardware Cursor Upper Left Y Position - Low 17 - 53 HCR8B: Hardware Cursor Upper Left Y Position - High 17 - 53 HCR8C: Hardware Cursor Foreground Color 17 - 54 HCR8D: Hardware Cursor Background Color 17 - 54 Extended CRT Control Registers CRT30: CRTC Overflow and Interlace Mode Enable 17 - 54 CRT31: Interlace Retrace 17 - 55 CRT32: TV Vertical Display Enable Start 17 - 55 CRT33: TV Vertical Display Enable End - High 17 - 56 CRT34: TV Vertical Display Enable End - Low 17 - 56 CRT35: Vertical Screen Expansion DDA Control Constant - Low 17 - 56 CRT36: Vertical Screen Expansion DDA Control Constant - High 17 - 57 CRT38: TV Equalization Pulse Control For External TV Encoder 17 - 57 CRT39: TV Serration Pulse Control For External TV Encoder 17 - 58 CRT3A: HSync and Character Clock Fine Turn Control Register 17 - 58 CRT3B: Hardware Testing Register 2 17 - 58 CRT3C: Hardware Testing Register 3 17 - 58 CRT3C: Hardware Testing Register 3 17 - 59 CRT3D: Scratch Register Bits 17 - 59 CRT3E: Scratch Register Bits 17 - 59 CRT3F: Scratch Register Bits 17 - 60 CRT9E: Expansion/Centering Control Register 2 17 - 60 CRT9F: Expansion/Center Control Register 1 17 - 61 CRT90-9B Vertical DDA Look Up Table & CRTA0-A5: Vertical Centering Offset Look Up Table 17 - 61 CRTA0-A5: Vertical Centering Offset Look Up Table 17 - 62 CRTA6: Vertical Centering Offset Register 17 - 63 CRTA7: Horizontal Centering Offset Register 17 - 63 Shadow VGA Registers SVR40: Shadow VGA Horizontal Total 17 - 64 SVR41: Shadow VGA Horizontal Blank Start 17 - 64 SVR42: Shadow VGA Horizontal Blank End 17 - 64 SVR43: Shadow VGA Horizontal Retrace Start 17 - 65 SVR44: Shadow VGA Horizontal Retrace End 17 - 65 SVR45: Shadow VGA Vertical Total 17 - 65 17 - 4 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook Summary of Registers (Continued) Page SVR46: Shadow VGA Vertical Blank Start 17 - 66 SVR47: Shadow VGA Vertical Blank End 17 - 66 SVR48: Shadow VGA Vertical Retrace Start 17 - 66 SVR49: Shadow VGA Vertical Retrace End 17 - 66 SVR4A: Shadow VGA Vertical Overflow 17 - 67 SVR4B: Shadow VGA Maximum Scan Line 17 - 67 SVR4C: Shadow VGA Horizontal Display End 17 - 68 SVR4D: Shadow VGA Vertical Display End 17 - 68 Extended SMI Registers 17 - 5 Silicon Motion®, Inc. LynxEM+ DataBook Extended SMI Registers This chapter describes the extended SMI registers including: • System control registers • Power down control register • Flat panel registers • Memory control registers • Clock control registers • General purpose registers • Popup-Icon and hardware cursor registers • Extended CRT registers • Shadow VGA registers All extended SMI registers are accessed through 3C3h, 3C5h, or 3?5h address. (? = B for monochrome mode and D for color mode). In order to access extended SMI registers, one must unlock the extended SMI register by writing 010xxxxxb to Lock register (3C3h). The name of the register consists of the index which the register resides in. For example, SCR10 can be accessed through index 10h of 3C5h. System Control Registers All system control registers are controlled by PCI system clock, rather than memory clock (MCLK) or video clock (VCLK). During LynxEM+ power down (when MCLK and VCLK are shutdown), the system control registers can still be accessed through PCI bus. SCR10: PCI Master Starting Address 7:0 Read/Write Address: 3C5h, Index: 10h Power-on Default: Undefined This register specifies the starting read/write address [7:1] in PCI master mode and Bi-Endian Mode Select. 7 6 5 4 3 2 STARTING ADDRESS [7:1] PCI MASTER MODE Bit 7:1 Starting Address [7:1] in PCI Master Mode Bit 0 Bi-Endian Select (BES) 0 = Normal 1 = Select Bi-Endian mode 1 0 BES SCR11: PCI Master Starting Address 15:8 Read/Write Address: 3C5h, Index: 11h Power-on Default: Undefined This register specifies the starting read/write address [15:8] in PCI master mode. 17 - 6 Extended SMI Registers Silicon Motion®, Inc. 7 LynxEM+ DataBook 6 5 4 3 2 1 0 STARTING ADDRESS [15:8] PCI MASTER MODE Bit 7:0 Starting Address [15:8] in PCI Master Mode SCR12: PCI Master Starting Address 23:16 Read/Write Address: 3C5h, Index: 12h Power-on Default: Undefined This register specifies the starting read/write address [23:16] in PCI master mode. 7 6 5 4 3 2 1 0 STARTING ADDRESS [23:16] PCI MASTER MODE Bit 7:0 Starting Address [23:16] in PCI Master Mode SCR13: PCI Master Starting Address 31:24 Read/Write Address: 3C5h, Index: 13h Power-on Default: Undefined This register specifies the starting read/write address [31:24] in PCI master mode. 7 6 5 4 3 2 1 0 STARTING ADDRESS [31:24] PCI MASTER MODE Bit 7:0 Starting Address [31:24] in PCI Master Mode SCR15: PCI Miscellaneous Control Register Read Only Address: 3C5h, Index: 15h Power-on Default: 00h This register defines the various PCI control registers. 7 6 5 4 3 BRE R SDE DEA PCI Bit 7 2 1 RESERVED 0 DS PCI Burst Read Enable (BRE) 0 = Disable 1 = Enable. SCR17 bit 5 needs to be set to 1 in order for this bit to take effect. For example, if SCR17 bit 5 = 0, even this bit is set to 1, PCI burst read will not be enabled. Extended SMI Registers 17 - 7 Silicon Motion®, Inc. LynxEM+ DataBook Bit 6 Reserved (R) Bit 5 Software Abort Drawing Engine Enable (SDE) 0 = Normal 1 = Enable. This bit has no effect unless bit 4 is set to 1. Bit 4 Drawing Engine Abort Enable (DEA) 0 = Normal 1 = Enable Bit 3 PCI Configuration Space: Subsystem ID Lock Enable (PCI) 0 = Disable 1 = Enable Bit 2:1 Reserved Bit 0 LynxEM+ device select (DS) 0 = SM810 1 = SM811 SCR16: Status for Drawing Engine and Video Processor Read Only Address: 3C5h, Index: 16h Power-on Default: Undefined This register specifies status of LynxEM+ including Drawing Engine Status, Video Processor Status, and Drawing Engine FIFO Available. 7 6 5 4 3 GES VWI VWII FIFO DEBS 2 1 0 DEFIFO Bit 7 Graphics Engine Status (GES) 0 = Indicate current display frame is using the source starting address 1 = Indicate current display frame is not using the source starting address Bit 6 Video Window I Status (VWI) 0 = Indicate current display frame is using the source starting address 1 = Indicate current display frame is not using the source starting address Bit 5 Video Window II Status (VWII) 0 = Indicate current display frame is using the source starting address 1 = Indicate current display frame is not using the source starting address Bit 4 Drawing Engine FIFO Empty Status (FIFO) 0 = Drawing Engine FIFO empty 1 = Drawing Engine FIFO not empty 17 - 8 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook Bit 3 2D Drawing Engine Busy Status (DEBS) 0 = Drawing Engine Idle 1 = Drawing Engine Busy Bit 2:0 # of Drawing Engine FIFO entries available in 32-bit quantity (DEFIFO) 000 = 1 entry available 001 = 2 entry available 010 = 3 entry available 011 = 4 entry available 100 = 5 entry available 101 = 6 entry available 110 = 7 entry available 111 = FIFO empty (if bit 4=0) or FIFO full (if bit 4=1) SCR17: General Graphics Command Register 1 Read/Write Address: 3C5h, Index: 17h Power-on Default: 00h This register specifies command controls for Memory Access Disable, PCI bus master status, PCI bus burst write and burst read enable, Big-Endian Swap mode Select, Memory mapped access enable and BIOS ROM size select. 7 6 5 4 MAD R PCI BESM 3 2 DIRECT3D 1 0 MMA DLT Bit 7 Memory Access Disable when Drawing Engine Busy (MAD) 0 = Normal 1 = Disable memory access when Drawing Engine is busy Bit 6 Reserved (R) Bit 5 PCI burst read and write enable. (PCI) 0 = Disable 1 = Enable Bit 4 Big Endian Swap Mode Select (BESM) Before [31:24] [23:16] [15:8] [7:0} [23:16] [31:24] ↓ 0 = Big Endian with byte swap After [7:0] [15:8] 1 = Big Endian with word swap Before [31:16] [15:0] [15:0] 31:16] ↓ Bit 3:2 Direct3D Z-Buffer Data Select After 00 = Normal (use all 32-bit data) 01 = Use low word [15:0] 10 = Use high word [31:16] Extended SMI Registers 17 - 9 Silicon Motion®, Inc. LynxEM+ DataBook 11 = Normal (use all 32-bit data) Bit 1 Memory Mapped Aperture Select (MMA) 0 = Select Banking Aperture. No Memory Mapped registers access allowed. 1 = Select Memory Mapped Aperture Bit 0 Disable Latency Timer (DLT) 0 = Normal 1 = Disable latency timer count SCR18: General Graphics Command Register 2 Read/Write Address: 3C5h, Index: 18h Power-on Default: 00h This register specifies command control for aperture select, graphics modes select, 32/64 memory data path select and linear addressing mode enable. 7 6 5 SCLK ECLK AS 4 3 GRAPHICS MODE 2 1 0 MDP ERH LMM Bit 7 Select ~CLKRUN or ACTIVITY (SCLK) 0 = Select ~CLKRUN as input for Pin 161 1 = Select ACITIVITY as output for Pin 161 Bit 6 Enable ~CLKRUN Function (ECLK) 0 = disable 1 = enable Bit 5 Aperture Select. This bit is only valid in linear memory mode (bit 0 = 1) (AS) 0 = Select dual aperture. Allow 0A0000h-0AFFFFh and linear aperture to coexist. 1 = Select single aperture. Only linear aperture can be used. Bit 4:3 Graphics Modes Select for Memory Access 00 = Standard VGA mode. The memory access only uses the lower 32-bit of the 64-bit internal memory bus. The memory address wraps after 256 KB. 01 = VESA Super VGA 16 color (4-bit) mode. The memory access only uses the low 32-bit of the 64bit internal memory bus. The memory address does not wrap after 256 KB. 1x = Extended packed pixel graphics modes (8/16/24/32-bit). The memory access always use the internal 64-bit memory bus. Bit 2 32/64 memory data path select. This bit is only valid in VGA or VESA Super VGA 16 color modes (bit 4 of this register = 0) (MDP) 0 = CPU access VGA memory. All host memory access goes through VGA aperture: 0A0000h 0BFFFFh (controlled by 3CFh index 6 Bit [3:2]). The memory access only uses the low 32-bit of the 64-bit memory bus. 1 = CPU access graphics memory. All host memory access does not goes through VGA aperture. This bit is used to allow 64-bit memory access even in VGA or super VGA 16 color modes. 17 - 10 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook For example, when programming pop-up icon in VGA mode or VESA super VGA 16 color mode, one must set bit 2 = 1 and bit 4 = 0 of this register, in order to access full range of the display memory. Bit 1 Enable Repeat Hardware Rotation BLT function (ERH) 0 = disable 1 = enable Bit 0 Linear Memory Mode Enable (LMM) 0 = disable. Nonlinear addressing (banking) mode is selected, and MCR61 register will be used for memory bank select. Memory will be accessed according to 3CF index 6 Bit [3:2]: Memory Range 3CF.6 Bit [3:2] 00 0A0000-0BFFFF 01 0A0000-0AFFFF 10 0B0000-0B7000 11 0B8000-0BFFFF 1 = enable. Linear memory mode is selected, and memory will be accessed according to the PCI base address register. To enable MMIO the following must be set prior to setting SCR18 [0]: SCR17 [1] = 1. SCR19: Interrupt Enable and Mask I Read/Write Address: 3C5h, Index: 19h Power-on Default: 00h This register specifies interrupt enables and interrupt masks for PCI master, Zoom Video Port, and Drawing Engine. Each interrupt mask will block out its particular interrupt when the interrupt mask is enabled. When the interrupt mask is disabled, the corresponding interrupt will be generated when its particular interrupt is enabled. 7 6 5 4 3 2 1 0 R IEPCI IEZVP IEDE R IMPCI IMZVP IMDE Bit 7 Reserved (R) Bit 6 Interrupt Enable for PCI Master (IEPCI) 0 = Disable 1 = Enable Bit 5 Interrupt Enable for Zoom Video Port (IEZVP) 0 = Disable 1 = Enable Bit 4 Interrupt Enable for Drawing Engine (IEDE) 0 = Disable 1 = Enable Bit 3 Reserved Bit 2 Interrupt Mask for PCI Master (IMPCI) 0 = Disable 1 = Enable Extended SMI Registers 17 - 11 Silicon Motion®, Inc. LynxEM+ DataBook Bit 1 Interrupt Mask for Zoom Video Port (IMZVP) 0 = Disable 1 = Enable Bit 0 Interrupt Mask for Drawing Engine (IMDE) 0 = Disable 1 = Enable SCR1A: Interrupt Status Read Only Address: 3C5h, Index: 1Ah Power-on Default: Undefined This register specifies Interrupt Status of Drawing Engine, Video Port, PCI Master, and VGA. The interrupt enable and mask bits for these interrupts are located in SCR19 register, with the exception of VGA's enable and mask bits which reside within the VGA block. 7 6 5 RESERVED 4 3 2 1 0 VGA R PCI ZVP DEI Bit 7:5 ReservedI Bit 4 VGA Interrupt Status. VGA's interrupt enable and mask bits are in the VGA block. (VGA) 0 = No interrupt 1 = VGA Interrupt is detected Bit 3 Reserved (R) Bit 2 PCI Master Interrupt Status (PCI) 0 = No interrupt 1 = PCI Master Interrupt is generated Bit 1 Zoom Video Port Interrupt Status (ZVP) 0 = No interrupt 1 = Zoom Video Port Interrupt is detected Bit 0 Drawing Engine Interrupt Status (DEI) 0 = No interrupt 1 = Drawing Engine Interrupt is detected SCR1C: Interrupt Status USR 0-3 Read Only Address: 3C5h, Index: 1Ch Power-on Default: Undefined This register specifies the Interrupt Status for USR 0-3 17 - 12 Extended SMI Registers Silicon Motion®, Inc. 7 LynxEM+ DataBook 6 5 4 RESERVED 3 2 1 0 USR3 USR2 USR1 USR0 Bit 7:4 ReservedI Bit 3 Interrupt Status for USR3 Bit 2 Interrupt Status for USR2 Bit 1 Interrupt Status for USR1 Bit 0 Interrupt Status for USR0 SCR1F: Interrupt Mask & Interrupt Status USR 0-3 Read Only Address: 3C5h, Index: 1Fh Power-on Default: Undefined This register specifies Interrupt Mask and Interrupt enable register for USR 0-3. 7 6 5 4 3 2 1 0 HUSR3 HUSR2 HUSR1 HUSR0 MUSR3 MUSR2 MUSR1 MUSR0 Bit 7 Enable hardware interrupt for USR3 (HUSR3) 0 = Disable 1 = Enable USR3 PIN as Interrupt input Bit 6 Enable hardware interrupt for USR2 (HUSR 2) 0 = Disable 1 = Enable USR2 PIN as Interrupt input Bit 5 Enable hardware interrupt for USR1 (HUSR1) Bit 4 Enable hardware interrupt for USR0 (HUSR0) Bit 3 Mask out interrupt for USR3 (MUSR3) Bit 2 Mask out interrupt for USR2 (MUSR2) Bit 1 Mask out interrupt for USR1 (MUSR1) Bit 0 Mask out interrupt for USR0 (MUSR0) Power Down Control Registers The power down control registers are controlled by system clock only. The power down control registers can still be read or written by CPU even when internal PLL is off. Extended SMI Registers 17 - 13 Silicon Motion®, Inc. LynxEM+ DataBook PDR20: Power Down Control for Memory, Flat Panel, PLL, and Video Port Read/Write Address: 3C5h, Index: 20h Power-on Default: 04h This register defines the different power down control for Memory, Flat Panel Interface, PLL, and Video Port. This register can still be read or written by CPU even when PLL is off. 7 6 SPDM SMR 5 4 SICLK 3 2 1 0 LVDS VPO FPI DMI Bit 7 Select Power Down Mode. External "~PDOWN" pin needs to be pulled "Low" to enable the selected power down mode. For more details on power down modes, please refer to the power down management chapter of this data book. (SPDM) 0 = Standby mode 1 = Sleep mode Bit 6 Select Memory Refresh Type During Sleep Mode (Bit 7 of this register = 1). (SMR) 0 = Auto Refresh 1 = Self Refresh Bit 5:4 Select internal VCLK and MCLK frequencies to control DRAM refresh during standby or sleep mode (CCR69 bit 3 = 1). This register setting will be ignored when the chip is in operation mode. (SICLK) 00 = No change. 01 = Both VCLK and MCLK are divided by 4 (standby and sleep mode) 10 = Both VCLK and MCLK are divided by 8 (standby and sleep mode) 11 = Both VCLK and MCLK are divided by 16 (sleep mode only) Bit 3 Tri-state LVDSCLK output pin. When ~EXCKEN = 0, Pin 159 (MCKIN) becomes an input pin. When ~EXCKEN = 1, Pin 159 (LVDSCLK) becomes an output pin. This register is only valid when ~EXCKEN = 1. This bit is used to test the silicon. (LVDS) 0 = Enable LVDSCLK output pin 1 = Tri-state LVDSCLK output pin Bit 2 Tri-state Video Port Output. When this bit = 0, 20-bit outputs (R[7:2], G[7:2], B[7:2], BLANK, and PCLK) will be driven out. When Video Capture is enabled (CPR00 [0] = 1), video port output will be tri-stated automatically, except for BLANK/TVCLK output pin. This bit is used to test the silicon. (VPO) 0 = Enable output pins 1 = Tri-state output pins (default) Bit 1 Tri-state Flat Panel Interface Output Pins. This bit is used to test the silicon (FPI) 0 = Enable output pins 1 = Tri-state output pins Bit 0 Tri-state Display Memory Interface output pins. This bit can also be used to isolate LynxEM+ from display memory. All display memory interface pins: control signals, output clock, data bus and address bus are tri-stated. This bit is used to test the silicon. (DMI) 0 = Enable display memory interface output pins 17 - 14 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook 1 = Tri-state display memory interface output pins PDR21: Functional Blocks Disable Control Read/Write Address: 3C5h, Index: 21h Power-on Default: 00h This register is designed to achieve optimum power saving in operation mode. Special clock drivers are built-in to control major functional blocks independently. This power saving feature will not affect the graphics and video performance, or LCD display quality. This register could be read or written by CPU even when PLL is off. 7 6 5 4 3 2 1 0 MHZ PLLS FBWO FBRO CPR ZVP DE VP Bit 7 Disable 135 MHz DAC (MHZ) 0 = Enable DAC 1 = Disable DAC Bit 6 Disable PLLs (PLLS) 0 = Enable PLLs 1 = Disable PLLs Bit 5 Disable LCD Frame Buffer Write Operation. This bit is used to shut-down the 64 x 8 LCD write FIFO and remove the display memory bus request for LCD frame buffer write from arbitration control. (FBWO) This bit needs to be set to "1" in Dual View Mode -- displaying different graphics data on CRT (or TV) and LCD. This bit should be set to "1" when LCD display is not enabled or when TFT is selected in standard refresh mode in order to obtain optimum power saving. 0 = Enable LCD frame buffer write 1 = Disable LCD frame buffer write Bit 4 Disable LCD Frame Buffer Read Operation and DSTN Dithering Engine. This bit is used to shut-down the 64 x 8 LCD read FIFO1 and LCD read FIFO2, turn off DSTN dithering engine and remove the display memory bus request from LCD Read FIFO1 and LCD read FIFO2. (FBRO) This bit should be set to "1" when LCD display is not enabled, or when TFT is selected in standard refresh mode. 0 = Enable LCD frame buffer read and DSTN dithering engine 1 = Disable LCD frame buffer read and DSTN dithering engine Bit 3 Disable 256 x 18 Color Palette RAM. Color Palette RAM will be automatically disabled by hardware in standby mode or sleep mode. (CPR) 0 = Enable Color Palette RAM 1 = Disable Color Palette RAM Extended SMI Registers 17 - 15 Silicon Motion®, Inc. LynxEM+ DataBook Bit 2 Disable Zoom Video Port. This bit is used when there is no external video source which is connected to the LynxEM+. The LynxEM+ will block input data from external video port, turn off the clock driver of ZV Port, and remove the ZV Port display memory bus request from memory controller. (ZVP) 0 = Enable Zoom Video Port 1 = Disable Zoom Video Port Bit 1 Disable 2D Drawing Engine. This bit is used to turn-off the 2D drawing engine block. For optimum power saving, this bit should be set to "1" in standard VGA mode since 2D drawing engine is not in use. (DE) 0 = Enable 2D drawing engine 1 = Disable 2D drawing engine Bit 0 Disable Video Processor. This bit is used to turn-off the video processor block which includes graphics FIFO, V0FIFO, V1FIFO, horizontal/vertical color interpolation, YUV-to-RGB conversion, TV flicker reduction, HW pop-up icon, and related control logic. For optimum power saving, This bit could be set to "1" in standard VGA mode since video processor is not in use. (VP) 0 = Enable video processor 1 = Disable video processor PDR22: LCD Panel Control Select Read/Write Address: 3C5h, Index: 22h Power-on Default: x0h This register specifies the flat panel control and data: FPEN, VBIASEN, FPVDDEN. This register is not valid when panel S/W power ON/OFF sequence is selected during display switching - FPR34 bit 7 = 0. For panel power ON/OFF sequence, please refer to the flat panel interface chapter of this data book. 7 6 RESERVED 5 4 DPMS CONTROL Bit 7:6 Reserved Bit 5:4 DPMS Control 3 2 1 0 FPEN VOP FP FOP DPMS State VSYNC HSYNC 00 = Normal Pulses Pulses 01 = Standby Pulses No Pulse 10 = Suspend No Pulse Pulses 11 = Off No Pulse No Pulse Bit 3 Control FPEN output pin. This function is disabled when LCD H/W auto-power ON/OFF sequence is enabled (FPR34 bit 7 = 1). This pin can also be used to control LCD back light (VBKLGT) at the same time. FPEN is part of the VESA FDPI-1B specification. (FPEN) 0 = Driven low 1 = Driven high Bit 2 Control VBIASEN output pin. This function is disabled when LCD H/W auto-power ON/OFF sequence is enabled (FPR34 bit 7 = 1). (VOP) 17 - 16 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook 0 = Driven low 1 = Driven high Bit 1 Disable Flat Panel control signals and data lines. All Control signals and data lines from output pins will be forced to logic "Low". (FP) 0 = Enable Flat Panel control signals and data 1 = Disable Flat Panel control signals and data Bit 0 Control FPVDDEN output pin. This function is disabled when LCD H/W auto-power ON/OFF sequence is enabled (FPR34 bit 7 = 1). (FOP) 0 = Driven low 1 = Driven high PDR23: Activity Detection Control Register Read/Write Address: 3C5h, Index: 23h Power-on Default: 00h The activity detection function is used to monitor I/O write and memory write activities. System designer can select a fixed time period by programming bit [2:0] of this register. An internal timer will count the idle period of memory write or I/O write operation. If the idle period is equal or greater than the selected value, a "Low-High" or "High-Low" on the ACTIVITY output signal will generate to the system. Any Memory write or I/O write operation will reset the ACTIVITY output signal and the internal counter. Please note that the internal counter will not start unless video capture is disabled (VPR3C bit 0 = 0). The activity detection can also be used to enable internal auto-standby mode. 7 6 5 ECAD EIAS SA 4 3 SELECT I/O 2 1 0 INTERNAL TIMER SELECT Bit 7 Enable chip activity detection (ECAD) 0 = Disable 1 = Enable Bit 6 Enable internal auto-standby mode. This bit has no effect if chip activity detection is disabled (PDR23 bit 7 = 0). This bit is used to enable internal auto-standby mode through activity detection function. Before enabling this function, the internal timer bit [2:0] of this register needs to be programmed first. (EIAS)0 = Disable 1 = Enable Bit 5 Select active "LOW" or "HIGH" signal for the ACTIVITY output (SA) 0 = Select active "LOW" 1 = Select active "HIGH" Bit 4:3 Select I/O Write Activity Detection or Host Memory Write Activity Detection 00 = No detection 01 = Enable Host Memory Write detect 10 = Enable I/O Write detect 11 = Enable both I/O Write and Host Memory Write detect Bit 2:0 Internal Timer Select Extended SMI Registers 17 - 17 Silicon Motion®, Inc. LynxEM+ DataBook 000 = Select 0 minute 001 = Select 1 minute (4K vertical frames period in standard setting) 010 = Select 2 minutes ........................................ 110 = Select 32 minutes 111 = Select 64 minutes (256K vertical frames period) PDR24: Power Down Register Select Read/Write Address: 3C5h, Index: 24h Power-on Default: 00h 7 6 5 4 3 2 1 RESERVED 0 PDMS Bit 7:1 Reserved Bit 0 Power Down Mode Select (PDMS) 0 = VESA Compliance power down mode 1 = PCI power down Spec 1.0 compliance Flat Panel Registers FPR30: Flat Panel Type Select Read/Write Address: 3C5h, Index: 30h Power-on Default: This is a power-on configurable register (by RESET) This register specifies different types of flat panel. 7 DSTN 6 5 COLOR TFT 4 3 2 LCD DISPLAY 1 0 TFT LCD Bit 7 Color DSTN interface type select. This bit is power-on configurable by MD15. (DSTN) 0 = 16-bit interface 1 = 24-bit interface Bit 6:4 Color TFT interface type select. This is a power-on configurable bit by MD [14:12]. For detailed interconnection for different type of LCD panels, please refer to the Flat Panel Interface Chapter of this data book. 000 = 9-bit, 3-bit per R, G, B 001 = 12-bit, 4-bit per R, G, B 010 = 18-bit, 6-bit per R, G, B 011 = 24-bit, 8-bit per R, G, B 100 = 12+12-bit, or 24-bit (two pixels/clock) 101 = analog TFT interface 110 = 18+18-bit, or 36-bit (two pixels/clock) 17 - 18 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook others = reserved Bit 3:2 LCD display size select for DSTN and TFT LCD. This is a power-on configurable bit by MD [11:10]. 00 = 640 x 480 01 = 800 x 600 10 = 1024 x 768 Bit 1 TFT FPSCLK Clock Phase Select. To adjust TFT flat panel data timing, one may wish to change the TFT FPSCLK phase by inverting the TFT FPSCLK. This register is only valid for TFT panel in single pixel/clock mode and 2 pixels/clock mode. (TFT) This is a power-on configurable bit by MD9. 0 = Normal 1 = Inverted clock Bit 0 Color LCD type select. This is a power-on configurable bit by MD8. (LCD) 0 = color TFT 1 = color DSTN FPR31: Virtual Refresh and Auto Shut Down Control Read/Write Address: 3C5h, Index: 31h Power-on Default: 00h This register defines the control for display select, Virtual Refresh mode enable and auto shut-down. 7 VRE 6 5 4 3 VRES SELECT AUTO S/D EASD 2 1 0 DISPLAY SELECT Bit 7 Virtual Refresh Enable. This bit is independent of FPR31 bit [2:0]. (VRE) 0 = Disable 1 = Enable Bit 6 Virtual Refresh Encode Select (VRES) 0 = Select 8-bit per pixel encode, RGB = 3:3:2 1 = Select 16-bit per pixel encode, RGB = 5:6:5 Bit 5:4 Select Auto Shut-Down Period. Define a period to start auto shut-down of display memory screen refresh cycle and LCD frame buffer write cycle. Auto shut-down mode can only be used when the display is in LCD mode only and Virtual Refresh is enabled. This function is only valid when auto shutdown of memory screen refresh and LCD frame buffer write cycles are enabled (bit 3 of this register = 1). 00 = 8 frames 01 = 16 frames 10 = 32 frames 11 = 64 frames Bit 3 Enable auto shut-down of display memory screen refresh cycle and LCD frame buffer write cycle in Virtual Refresh mode. This bit is only valid when Virtual Refresh mode is enabled (FPR31 bit 7 = "1"). If the display memory write operation is idle for more than the selected period specified by FPR31 bit Extended SMI Registers 17 - 19 Silicon Motion®, Inc. LynxEM+ DataBook [5:4], the display memory screen refresh cycle and LCD frame buffer write cycle will be automatically shut-down when auto shut-down is enabled. The graphics FIFO and video FIFO are also shut-down. Any Host memory write operation to LynxEM+ will turn on the display memory screen refresh and LCD frame buffer write cycle at the end of a vertical sync signal. (EASD) 0 = Disable auto shut-down 1 = Enable auto shut-down Bit 2:0 Display Select. (Note: TV and CRT can not be enabled at the same time.) 000 = Disable all displays (default value) 001 = Enable LCD display 010 = Enable CRT display 011 = Enable both CRT and LCD display 100 = Enable TV display 101 = Enable both TV and LCD display others = Reserved FPR32: Dithering Engine Select, Polarity, and Expansion Control Read/Write Address: 3C5h, Index: 32h Power-on Default: 00h This register defines the TFT and DSTN dithering engines select, LCD signal polarities, and screen auto-centering or vertical expansion select. 7 6 TFT DITHERING Bit 7:6 5 4 3 2 1 0 STN LCDV LCDH ACE VLEE HPEE TFT Dithering Engine Select 00 = No dithering 01 = 4-gray level dithering patterns (for 9-bit, 12-bit, and 18-bit TFT only) 10 = 8-gray level dithering patterns (for 9-bit and 12-bit TFT only) 11 = Reserved FPR30 [6:4] = 000 = 001 or 100 = 010 or 110 = 011 Bit [7:6] 9-bit 12-bit 18-bit 24-bit 00 512 colors 4K colors 256K colors 16M colors 01 24,389 colors 226,981 colors 16M colors 16M colors 10 185,193 colors 1,771,561 colors 16M colors 16M colors Bit 5 STN Dithering Engine Select (STN) 0 = Select 64 gray levels for each R, G, and B 1 = Select 256 gray levels for each R, G, and B Bit 4 LCD VSYNC/FP Polarity Select (LCDV) 0 = Select active "LOW" 1 = Select active "HIGH" 17 - 20 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook Bit 3 LCD HSYNC/LP polarity Select (LCDH) 0 = Select active "LOW" 1 = Select active "HIGH" Bit 2 Auto Centering Enable. This register is used to control screen centering for VGA modes. (ACE) 0 = Disable 1 = Enable. This bit needs to be set to "1" and CRT shadow registers need to be reprogrammed to allow screen centering. Bit 1 Vertical Line Expansion Enable for VGA modes (VLEE) 0 = Disable 1 = Enable Bit 0 Horizontal Pixel Expansion Enable for VGA modes (HPEE) 0 = Disable 1 = Enable. Character clock is forced to 10-dot timing. FPR33: Panel Power Sequence and LCD Character/Cursor Blink Control Read/Write Address: 3C5h, Index: 33h Power-on Default: 05h This register defines the control for LCD power ON/OFF sequence timing, lock VGACRT horizontal and vertical display enable, and blinking rate for LCD character/cursor. 7 6 RESERVED 5 4 VDE R 3 2 PANEL ON/OFF 1 0 SELECT LCD Bit 7:6 Reserved Bit 5 Lock VGA CRT Vertical and Horizontal Display Enable registers used in Virtual Refresh mode (FPR31 bit 7 = 1) to lock the control signals to LCD BKEND. When this bit is set to 1, it will lock the following registers: CRT01 (3?5h, index1) [Horizontal Display Enable], CRT07 (3?5h, index 07) bit 6 [Vertical Display Enable bit 9] and bit 1[Vertical Display Enable bit 8], CRT12 (3?5h, index12) [Vertical Display Enable]. (VDE) This register is also used to lock Shadow VGA CRT Horizontal Display Enable and Vertical Display Enable Registers. 0 = unlock (default) 1 = lock Bit 4 Reserved (R) Bit 3:2 Panel ON/OFF timing select. These two bits are used to control the time period from FPEN to VBIASEN, from VBIASEN to LCD control signals, and from LCD control signals to FPVDDEN. These two bits are only valid when LCD H/W auto-power ON/OFF sequence is selected (FPR34 bit 7 =1). 00 = 1 vertical frame 01 = 2 vertical frames Extended SMI Registers 17 - 21 Silicon Motion®, Inc. LynxEM+ DataBook 10 = 4 vertical frames 11 = 8 vertical frames Bit 1:0 Select LCD character/cursor blink rate Bit [1:0] Cursor Character 00 16 frames 32 frames 01 32 frames 64 frames 10 64 frames 128 frames FPR34: LCD Panel ON/OFF Sequence Select and DSTN LCD Control Read/Write Address: 3C5h, Index: 34h Power-on Default: 80h This register defines LCD panel ON/OFF sequence select during display switching and color DSTN panel control, such as: LP pulse width, additional line pulse in odd and even frame. 7 6 SHS SLP 5 4 SELPO 3 2 1 0 SELECT EXTRA LP EVEN FRAME Bit 7 Select Hardware or Software LCD auto-power ON/OFF sequence during display switching in operation or power down modes. This bit can be used to select two different ways to turn ON/OFF LCD panel. For special programming sequences, please refer to the Power Down Management chapter of this data book. (SHS) 0 = Select software LCD power sequencing 1 = Select hardware LCD power sequencing Bit 6 Select LP (DSTN) Pulse Width in Pixel Clocks (SLP) 0 = 16 pixel clocks 1 = 32 pixel clocks Bit 5:4 Select Extra LP in Odd Frame for DSTN LCD in Standard Refresh Mode (SELPO) 00 = 0 extra line pulses 01 = 1 extra line pulses 10 = 2 extra line pulses 11 = 3 extra line pulses Bit 3:0 Select Extra LP in Even Frame for DSTN LCD in Standard Refresh Mode, or Extra LP in Every Frame for DSTN LCD in Virtual Refresh Mode. 0000 = 0 extra line pulses 0001 = 1 extra line pulses 0010 = 2 extra line pulses ......................................... 1111 = 15 extra line pulses 17 - 22 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook FPR3E: DSTN LCD Panel Height - High Read/Write Address: 3C5h, Index: 3Eh Power-on Default: 00h This register defines bit 9 and bit 8 of DSTN LCD panel height register. This 10-bit register needs to be programmed as "DSTN LCD panel height ÷ 2". This 10-bit register also has to be an even number. For example, DSTN LCD panel height register equals to "12Ch" for a 800x600 DSTN. 7 6 5 4 3 2 DES R GFIFO VFIFO FPD LP 1 0 DSTN LCD PANEL Bit 7 M-Signal or Display Enable Select (DES) 0 = Select Display Enable as output for Pin 81 1 = Select M-Signal as output for Pin 81 Bit 6 Reserved (R) Bit 5 Graphic FIFO flipping - Software sets this bit and continues to sample until = 0 (GFIFO) Bit 4 Video FIFO flipping - Software sets this bit and continues to sample until = 0 (VFIFO) Bit 3 Frame pulse detection - Software sets this bit and continues to sample until = 0 (FPD) Bit 2 Free running LP enable for DSTN (LP) 0 = Disable 1 = Enable Bit 1:0 Bit 9 and bit 8 of the 10-bit DSTN LCD Panel Height Register. FPR3F: DSTN LCD Panel Height- Low Read/Write Address: 3C5h, Index: 3Fh Power-on Default: 00h 7 6 5 4 3 2 1 0 BIT [7:0] OF THE 10-BIT DSTN LCD PANEL HEIGHT REGISTER This register defines lower 8-bit of DSTN LCD panel height register. This 10-bit register needs to be programmed as "DSTN LCD panel height ÷ 2". This 10-bit register also has to be an even number. For example, DSTN LCD panel height register equals to "180h" for a 1024x768 DSTN LCD. Bit 7:0 Bit [7:0] of the 10-bit DSTN LCD Panel Height Register. FPR40: Read FIFO1 Start Address Low for LCD Frame Buffer Read/Write Address: 3C5h, Index: 40h Extended SMI Registers 17 - 23 Silicon Motion®, Inc. LynxEM+ DataBook Power-on Default: Undefined This register defines the lower 8-bit of the read FIFO1 start address for LCD frame buffer. This Read FIFO1 start address is used for DSTN LCD in standard refresh mode or TFT LCD in Virtual Refresh mode. When DSTN LCD is selected and in Virtual Refresh mode, this register defines the lower 8-bit of the read FIFO1 start address for upper panel of the DSTN LCD. 7 6 5 4 3 2 1 0 BIT [7:0] OF DISPLAY MEMORY READ FIFO1 Bit 7:0 Select bit [7:0] of display memory read FIFO1 address bus for the LCD frame buffer of DSTN LCD in standard refresh mode or for TFT LCD in Virtual Refresh mode. When Virtual Refresh is enabled (FPR31 bit 7 = 1) and when DSTN LCD is selected (FPR30 [1:0] = 01b), this register selects bit [7:0] of the display memory read FIFO1 address for the upper panel of DSTN LCD. FPR41: Read FIFO1 Start Address High for LCD Frame Buffer Read/Write Address: 3C5h, Index: 41h Power-on Default: Undefined This register defines the higher 8-bit of the read FIFO1 start address for LCD frame buffer. This Read FIFO1 start address is used for DSTN LCD in standard refresh mode or TFT LCD in Virtual Refresh mode. When DSTN LCD is selected and in Virtual Refresh mode, this register defines the higher 8-bit of the read FIFO1 start address for upper panel of the DSTN LCD. 7 6 5 4 3 2 1 0 BIT [15:8] OF DISPLAY MEMORY READ FIFO1 Bit 7:0 Select bit [15:8] of display memory read FIFO1 address bus for the LCD frame buffer of DSTN LCD in standard refresh mode or for TFT LCD in Virtual Refresh mode. When Virtual Refresh is enabled (FPR31 bit 7 = 1) and when DSTN LCD is selected (FPR30 [1:0] = 01b), this register selects bit [15:8] of the display memory read FIFO1 address for the upper panel of DSTN LCD. FPR42: Read FIFO2 Start Address Low for LCD Frame Buffer Read/Write Address: 3C5h, Index: 42h Power-on Default: Undefined This register defines the lower 8-bit of the read FIFO2 start address for LCD frame buffer. This register is only valid when DSTN LCD is selected (FPR30 [1:0] = 01b) and Virtual Refresh is enabled (FPR31 bit 7 = 1). 7 6 5 4 3 2 1 0 BIT [7:0] OF DISPLAY MEMORY READ FIFO2 Bit 7:0 17 - 24 Select bit [7:0] of display memory read FIFO2 address bus for lower panel of DSTN LCD. Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook FPR43: Read FIFO2 Start Address High for LCD Frame Buffer Read/Write Address: 3C5h, Index: 43h Power-on Default: Undefined This register defines the higher 8-bit of the read FIFO2 start address for LCD frame buffer. This register is valid only when DSTN LCD is selected (FPR30 [1:0] = 01b) and Virtual Refresh is enabled (FPR31 bit 7 = 1). 7 6 5 4 3 2 1 0 BIT [15:8] OF DISPLAY MEMORY READ FIFO2 Bit 7:0 Select bit [15:8] of display memory read FIFO2 address bus for lower panel of DSTN LCD. FPR44: Read FIFO1 Offset Value of LCD Frame Buffer Read/Write Address: 3C5h, Index: 44h Power-on Default: Undefined This register defines the read FIFO1 offset value of LCD Frame buffer. This offset value is used to calculate the read start address of the next line of LCD Frame buffer from the current line. The offset register is a 10-bit register. Bit [9:8] of Read Offset Value Register are in FPR45 register. 7 6 5 4 3 2 1 0 BIT [7:0] OF READ FIFO1 Bit 7:0 Bit [7:0] of read FIFO1 offset value for LCD frame buffer. This offset value is a direct mapping from bit [10:3] of display memory read address bus. FPR45: Read FIFO1 Address Offset for LCD Frame Buffer Overflow Read/Write Address: 3C5h, Index: 45h Power-on Default: Undefined This register defines the MSB of the read FIFO1 start address. In additional, this register specifies the MSB of the LCD frame buffer read offset value. 7 6 5 RFIFO1 4 DMFIFO1 3 2 1 0 DISPLAY MEM READ FIFO2 Bit 7:6 Bit [9:8] of Read FIFO1 offset value register of LCD Frame buffer. These two bits are mapped to bit [12:11] of display memory address bus. The lower 8 bits are in FPR44 register. (RFIFO1) Bit 5:3 Bit [18:6] of display memory read FIFO1 address bus. The lower [15:0] of display memory read FIFO1 address is located in FPR41 and FPR40 registers. (DMFIFO1) Extended SMI Registers 17 - 25 Silicon Motion®, Inc. LynxEM+ DataBook When TFT LCD is in Virtual Refresh mode, or DSTN LCD is in standard refresh mode, this register specifies bit [18:16] of display memory read address. This register is used for upper panel of DSTN LCD when Virtual Refresh is enabled (FPR 31 bit 7 = 1) and DSTN LCD (FPR30 [1:0] = 01b) is selected. Bit 2:0 Bit [18:16] of display memory read FIFO2 address bus for lower panel of DSTN LCD. The lower [15:0] of display memory read FIFO1 address is located in FPR43 and FPR42 registers. This register is valid only when DSTN LCD is selected (FPR30 [1:0] = 01b) and Virtual Refresh is enabled (FPR31 bit 7 = 1). FPR46: Write Start Address Low of LCD Frame Buffer Read/Write Address: 3C5h, Index: 46h Power-on Default: Undefined This register defines the lower 8-bit of the start address for LCD Write Frame Buffer. 7 6 5 4 3 2 1 0 BIT [7:0] OF START ADDRESS LCD Bit 7:0 Bit [7:0] of start address for LCD write frame buffer. This register is a direct mapping from bit [10:3] of display memory write address bus. FPR47: Write Start Address High of LCD Frame Buffer Read/Write Address: 3C5h, Index: 47h Power-on Default: Undefined This register defines the high byte start address of LCD Write Frame Buffer. 7 6 5 4 3 2 1 0 BIT [7:0] OF START ADDRESS LCD WRITE FRAME BUFFER Bit 7:0 Bit [15:8] of start address for LCD write frame buffer. This register is a direct mapping from bit [18:11] of display memory write address bus. FPR48: Write Offset Value of LCD Frame Buffer Read/Write Address: 3C5h, Index: 48h Power-on Default: Undefined This register defines the offset value of LCD Write Frame Buffer. This offset value is used to calculate the start address of the next line of LCD Write Frame Buffer from the current line. The offset register is a 10-bit register. Bit [9:8] of the write offset value is in FPR49 register. 7 6 5 4 3 2 1 0 BIT [7:0] OF OFFSET VALUE LCD WRITE FRAME BUFFER 17 - 26 Extended SMI Registers Silicon Motion®, Inc. Bit 7:0 LynxEM+ DataBook Bit [7:0] of offset value for LCD write frame buffer. This offset value is a direct mapping from bit [10:3] of display memory write address bus. FPR49: LCD Frame Buffer Write Overflow Read/Write Address: 3C5h, Index: 49h Power-on Default: Undefined This register specifies the MSB of the LCD frame buffer write offset address. The lower 8-bit of the LCD frame buffer write offset address is in FPR48. 7 6 5 RESERVED 4 3 2 1 START ADDRESS LCD 0 OVR Bit 7:5 Reserved Bit 5:2 Bit [18:16] of start address for LCD Write Frame Buffer. This register is a direct mapping from bit [21:19] of display memory write address bus. Bit 1:0 Bit [9:8] of offset value register of LCD Write Frame Buffer. These two bits are mapped to bit 12 and 11 of display memory write address bus. The lower 8 bits are in FPR48. (OVR) FPR4A: LCD Read and Write FIFOs Request Level Control Read/Write Address: 3C5h, Index: 4Ah Power-on Default: 44h This register controls the LCD Read and Write FIFOs Request Level. These bits can be used to maximize the available memory bandwidth. 7 6 5 4 LCD READ FIFO2 LCD READ FIFO1 3 2 RESERVED 1 0 LCD WRITE FIFO Bit 7:6 LCD Read FIFO2 Request Level. When the LCD Read FIFO2 empty level reaches the level specified by this register, a LCD Read FIFO2 Request will be generated. 00 = RFIFO2 has 4 or more entries empty 01 = RFIFO2 has 8 or more entries empty 1x = RFIFO2 has 12 or more entries empty Bit 5:4 LCD Read FIFO1 Request Level. When the LCD Read FIFO1 empty level reaches the level specified by this register, a LCD Read FIFO1 Request will be generated. 00 = RFIFO1 has 4 or more entries empty 01 = RFIFO1 has 8 or more entries empty 1x = RFIFO1 has 12 or more entries empty Bit 3:2 Reserved Extended SMI Registers 17 - 27 Silicon Motion®, Inc. Bit 1:0 LynxEM+ DataBook LCD Write FIFO Request Level. When the LCD Write FIFO filled level reaches the level specified by this register, a LCD Write Request will be generated. 00 = WFIFO has 4 or more entries filled 01 = WFIFO has 8 or more entries filled 1x = WFIFO has 12 or more entries filled FPR4B: Read FIFO2 Offset Value of LCD Frame Buffer Read/Write Address: 3C5h, Index: 4Bh Power-on Default: Undefined This register defines the read FIFO2 offset value of LCD Frame buffer. This offset value is used to calculate the read start address of the next line of LCD Frame buffer from the current line. The offset register is a 10-bit register. 7 6 5 4 3 2 1 0 BIT [7:0] OF READ FIFO2 OFFSET VALUE Bit 7:0 Bit [7:0] of read FIFO2 offset value for LCD frame buffer. This offset value is a direct mapping from bit [10:3] of display memory read address bus. The upper two bits are in FPR4C register. FPR4C: Read FIFO Offset Value of LCD Frame Buffer Overflow Read/Write Address: 3C5h, Index: 4Ch Power-on Default: Undefined This register defines the read FIFO offset value of LCD Frame buffer. This offset value is used to calculate the read start address of the next line of LCD Frame buffer from the current line. 7 6 5 4 READ FIFO2 3 2 1 0 RESERVED Bit 7:6 Bit [9:8] of Read FIFO2 offset value register of LCD Frame buffer. These two bits are mapped to bit [12:11] of display memory address bus. The lower 8 bits are in FPR4B register. Bit 5:0 Reserved FPR50: LCD Overflow Register 1 for Virtual Refresh Read/Write Address: 3C5h, Index: 50h Power-on Default: Undefined This register defines the high order MSB bits of LCD Horizontal Sync Start (FPR54), and LCD Vertical Total (FPR55) registers which are used to control Virtual Refresh timing. 7 6 5 RESERVED 17 - 28 4 3 2 [10:8] FPR55 1 0 FPR54 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook Bit 7:4 Reserved Bit 3:1 Bit [10:8] of FPR55, Vertical Total of LCD in Virtual Refresh mode Bit 0 Bit 8 of FPR54, Horizontal Sync Start of LCD in Virtual Refresh mode (FPR54) FPR51: LCD Overflow Register 2 for Virtual Refresh Read/Write Address: 3C5h, Index: 51h Power-on Default: Undefined This register defines the overflow bits of FPR52, FPR53, FPR56, and FPR57 registers which are used to control Virtual Refresh timing. 7 6 5 4 [10:8] FPR57 3 2 [10:8] FPR 56 1 0 FPR53 FPR4\52 Bit 7:5 Bit [10:8] of FPR57, Vertical Sync Start of LCD in Virtual Refresh mode Bit 4:2 Bit [10:8] of FPR56, Vertical Display End of LCD in Virtual Refresh mode Bit 1 Bit 8 of FPR53, Horizontal Display End of LCD in Virtual Refresh mode (FPR53) Bit 0 Bit 8 of FPR52, Horizontal Total of LCD in Virtual Refresh mode (FPR52) FPR52: LCD Horizontal Total for Virtual Refresh Read/Write Address: 3C5h, Index: 52h Power-on Default: Undefined This register defines the bit [7:0] of LCD Horizontal Total. This register is used in Virtual Refresh mode only. It represents one line in TFT LCD and two lines in DSTN LCD. The LSB bit represents a 8-pixel period. The equation to calculate the LCD horizontal total in Virtual Refresh mode is as follows: LCDHT = (LCD panel width + horizontal blanking pixels) ÷ 8 - 1 LCDHT = (LCD panel width * 2 + horizontal blanking pixels) ÷ 8 - 1 For TFT: For DSTN: 7 6 5 4 3 2 1 0 LCD HORIZONTAL TOTAL Bit 7:0 LCD Horizontal Total [7:0] in Virtual Refresh mode. Bit 8 of LCD horizontal total is in FPR51 register. FPR53: LCD Horizontal Display Enable for Virtual Refresh Read/Write Address: 3C5h, Index: 53h Power-on Default: Undefined Extended SMI Registers 17 - 29 Silicon Motion®, Inc. LynxEM+ DataBook This register defines the active horizontal display period of LCD in Virtual Refresh mode. It represents one line in TFT LCD and two lines in DSTN LCD. The equation to calculate the LCD horizontal display enable in Virtual Refresh mode: LCDHDE = (LCD panel width pixels) ÷ 8 - 1 LCDHDE = (LCD panel width * 2) ÷ 8 - 1 For TFT: For DSTN: 7 6 5 4 3 2 1 0 LCD HORIZONTAL DISPLAY ENABLE PERIOD Bit 7:0 LCD Horizontal display enable period [7:0] in Virtual Refresh mode. Bit 8 of LCD horizontal display enable is in FPR51 register. FPR54: LCD Horizontal Sync Start for Virtual Refresh Read/Write Address: 3C5h, Index: 54h Power-on Default: Undefined This register defines the LCD horizontal sync start in Virtual Refresh mode. This register is used to generate the start timing of HYSNC for TFT LCD, or the start timing of LP for DSTN LCD. The value in LCDHSS needs to be larger than the value in LCDHDE. The horizontal sync pulse width is 8 pixels or 16 pixels wide, which is dependent on FPR34 bit 6. 7 6 5 4 3 2 1 0 LCD HORIZONTAL SYNC START PERIOD Bit 7:0 LCD Horizontal sync start period [7:0] in Virtual Refresh mode. Bit 8 of LCD horizontal sync start is in FPR50 register. FPR55: LCD Vertical Total for Virtual Refresh Read/Write Address: 3C5h, Index: 55h Power-on Default: Undefined This register defines the bit [7:0] of LCD Vertical Total. This register is used in Virtual Refresh mode only. The calculation equation of LCD vertical total in Virtual Refresh mode is as follows: For TFT: LCDVT = (LCD panel height + vertical blank lines) - 1 For DSTN: LCDVT = ((LCD panel height ÷ 2) + vertical blank lines) - 1 7 6 5 4 3 2 1 0 LCD VERTICAL TOTAL Bit 7:0 LCD Vertical Total [7:0] in Virtual Refresh mode. Bit [10:8] of LCD vertical total are in FPR50 register. 17 - 30 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook FPR56: LCD Vertical Display Enable for Virtual Refresh Read/Write Address: 3C5h, Index: 56h Power-on Default: Undefined This register defines the LCD active vertical display period in Virtual Refresh mode. The calculation equation of LCD vertical display enable in Virtual Refresh mode is as follows: For TFT: LCDVDE = (LCD panel height) - 1 For DSTN: LCDVDE = (LCD panel height ÷ 2) - 1 7 6 5 4 3 2 1 0 LCD VERTICAL DISPLAY ENABLE PERIOD Bit 7:0 LCD vertical display enable period [7:0] in Virtual Refresh mode. Bit [10:8] of LCD vertical display enable are in FPR51 register. FPR57: LCD Vertical Sync Start for Virtual Refresh Read/Write Address: 3C5h, Index: 57h Power-on Default: Undefined This register defines the LCD vertical sync start in Virtual Refresh mode. This register is used to generate the start timing VSYNC for TFT LCD, or the start timing of FP for DSTN LCD. The value in LCDVSS needs to be larger than the value in LDVDE. The vertical sync pulse width is equal to one horizontal scan line. 7 6 5 4 3 2 1 0 LCD VERTICAL SYNC START PERIOD Bit 7:0 LCD Vertical sync start period [7:0] in Virtual Refresh mode. Bit [10:8] of LCD vertical sync start are in FPR51 register. FPR58: EMI Control Register Read/Write Address: 3C5h, Index: 58h Power-on Default: 00h This register defines the EMI control register for LCD flat panels, including LCD Panel I/O pad drive strength, FSPCLK clock delay control. 7 6 5 RESERVED Bit 7:4 4 3 2 EMIRC LCD 1 0 FPSCLK Reserved Extended SMI Registers 17 - 31 Silicon Motion®, Inc. LynxEM+ DataBook Bit 3 EMI reduction control (EMIRC) 0 = disable 1 = enable Bit 2 LCD Panel I/O pad drive strength select (LCD) 0 = 8 mA 1 = 6 mA Bit 1:0 FPSCLK Clock Control. Each unit of clock is approximately 1.2ns best case or 2.0ns best case. 00 = normal 01 = FPSCLK delays by 1 unit of clock 10 = FPSCLK delays by 2 unit of clock 11 = FPSCLK delays by 3 unit of clock FPR59: Panel M-Signal Control Register Read/Write Address: 3C5h, Index: 59h Power-on Default: 00h This register defines the panel M-signal control such as modulation clock and modulation count. 7 6 5 MCS 4 3 2 1 0 MODULATION COUNT Bit 7 Modulation Clock Select (MCS) 0 = Select Frame Clock 1 = Select Line Clock Bit 6:0 Modulation Count. The modulation is generated at a rate that is specified by the modulation count and modulation clock. FPR5A: SYNC Pulse-widths Adjustment Read/Write Address: 3C5h, Index: 5Ah Power-on Default: 00h This register allows adjust to the HSYNC and VSYNC Pulsewidths. 7 6 5 HSYNC 4 3 2 1 VSYNC Bit 7:3 Additional HSYNC pulse width in # of character clocks Bit 2:0 Additional VSYNC pulse width in # of HSYNCs 17 - 32 0 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook FPRA0: Panel HW Video Control Read/Write Address: 3C5h, Index: A0h Power-on Default: 00h This register defines the panel video display logic during Virtual Refresh mode. The video display logic will only be activated during Virtual Refresh mode with TFT panel. 7 6 5 4 3 2 EPV EHPD ECK RGB EFS EIC 1 0 RESERVED Bit 7 Enable Panel Video (EPV) 0 = Disable 1 = Enable Bit 6 Enable Horizontal Pixel Duplication (EHPD) 0 = Disable 1 = Enable Bit 5 Enable Color Key (ECK) 0 = Disable 1 = Enable Bit 4 RGB Format (RGB) 0 = YUV Format 1 = RGB Format Bit 3 Enable Full screen video (EFS) 0 = Disable 1 = Enable Bit 2 Enable 8-bit index color mode (only works in Virtual Refresh mode) (EIC) 0 = Disable 1 = Enable Bit 1:0 Reserved FPRA1: Panel Video Color Key Read/Write Address: 3C5h, Index: A1h Power-on Default: 00h This register defines the panel video color key [7:0] 7 6 5 4 3 2 1 0 PANEL VIDEO COLOR KEY [7:0] Extended SMI Registers 17 - 33 Silicon Motion®, Inc. Bit 7:0 LynxEM+ DataBook Panel Video Color Key[7:0] FPRA2: Panel Video Color Key Read/Write Address: 3C5h, Index: A2h Power-on Default: 00h This register defines the panel video color key [15:8] 7 6 5 4 3 2 1 0 1 0 1 0 PANEL VIDEO COLOR KEY [15:8] Bit 7:0 Panel Video Color Key[15:8] FPRA3: Panel Video Color Key Mask Read/Write Address: 3C5h, Index: A3h Power-on Default: 00h This register defines the panel video color key mask [7:0] 7 6 5 4 3 2 PANEL VIDEO COLOR KEY MASK [7:0] Bit 7:0 Panel Video Color Key Mask[7:0] FPRA4: Panel Video Color Key Mask 15:8 Read/Write Address: 3C5h, Index: A4h Power-on Default: 00h This register defines the panel video color key mask [15:8] 7 6 5 4 3 2 PANEL VIDEO COLOR KEY MASK [15:8] Bit 7:0 Panel Video Color Key Mask[15:8] FPRA5: Panel Video Red Constant Read/Write Address: 3C5h, Index: A5h Power-on Default: EDh This register defines the panel video Red Constant 17 - 34 Extended SMI Registers Silicon Motion®, Inc. 7 6 LynxEM+ DataBook 5 4 3 2 1 0 1 0 1 0 1 0 PANEL VIDEO RED CONSTANT [7:0] Bit 7:0 Panel Video Red Constant [7:0] FPRA6: Panel Video Green Constant Read/Write Address: 3C5h, Index: A6h Power-on Default: EDh This register defines the panel video green constant 7 6 5 4 3 2 PANEL VIDEO GREEN CONSTANT [7:0] Bit 7:0 Panel Video Green Constant [7:0] FPRA7: Panel Video Blue Constant Read/Write Address: 3C5h, Index: A7h Power-on Default: EDh This register defines the panel video Blue Constant 7 6 5 4 3 2 PANEL VIDEO BLUE CONSTANT [7:0] Bit 7:0 Panel Video Blue Constant [7:0] FPRA8: Panel Video Top Boundary Read/Write Address: 3C5h, Index: A8h Power-on Default: 00h This register defines the panel video top boundary 7 6 5 4 3 2 PANEL VIDEO TOP BOUNDARY [7:0] Bit 7:0 Panel Video Top Boundary [7:0] FPRA9: Panel Video Left Boundary Read/Write Address: 3C5h, Index: A9h Extended SMI Registers 17 - 35 Silicon Motion®, Inc. LynxEM+ DataBook Power-on Default: 00h This register defines the panel video left boundary 7 6 5 4 3 2 1 0 1 0 1 0 PANEL VIDEO LEFT BOUNDARY [7:0] Bit 7:0 Panel Video Left Boundary [7:0] FPRAA: Panel Video Bottom Boundary Read/Write Address: 3C5h, Index: AAh Power-on Default: 00h This register defines the panel video bottom boundary 7 6 5 4 3 2 PANEL VIDEO BOTTOM BOUNDARY [7:0] Bit 7:0 Panel Video Bottom Boundary [7:0] FPRAB: Panel Video Right Boundary Read/Write Address: 3C5h, Index: ABh Power-on Default: 00h This register defines the panel video Right boundary 7 6 5 4 3 2 PANEL VIDEO RIGHT BOUNDARY [7:0] Bit 7:0 Panel Video Right Boundary [7:0] FPRAC: Panel Video Top and Left Boundary Overflow Read/Write Address: 3C5h, Index: ACh Power-on Default: 00h This register defines the panel video top and left boundary overflow 7 6 5 PVLB Bit 7:5 17 - 36 4 3 2 RESERVED 1 0 PVTB Panel Video Left Boundary [10:8] (PVLB) Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook Bit 4:3 Reserved Bit 2:0 Panel Video Top Boundary [10:8] (PVTB) FPRAD: Panel Video Bottom and Right Boundary Overflow Read/Write Address: 3C5h, Index: ADh Power-on Default: 00h This register defines the panel video bottom and right boundary overflow 7 6 5 PVRB 4 3 2 RESERVED 1 0 PVBB Bit 7:5 Panel Video Right Boundary [10:8] (PVRB) Bit 4:3 Reserved Bit 2:0 Panel Video Bottom Boundary [10:8] (PVBB) FPRAE: Panel Video Vertical Stretch Factor Read/Write Address: 3C5h, Index: AEh Power-on Default: 00h This register defines the panel video vertical stretch factor. 7 6 5 4 3 2 1 0 PANEL VIDEO VERTICAL STRETCH FACTOR [7:0] Bit 7:0 Panel Video Vertical Stretch Factor [7:0]. The stretch factor equals to: S/D * 256. note: when stretch factor is set to 0, it becomes a 1-to-1 stretch. FPRAF: Panel Video Horizontal Stretch Factor Read/Write Address: 3C5h, Index: AFh Power-on Default: 00h This register defines the panel video horizontal stretch factor 7 6 5 4 3 2 1 0 PANEL VIDEO HORIZONTAL STRETCH FACTOR [7:0] Bit 7:0 Panel Video Horizontal Stretch Factor [7:0] The stretch factor equals to: S/D * 256. Note: when stretch factor is set to 0, it becomes a 1-to-1 stretch. Extended SMI Registers 17 - 37 Silicon Motion®, Inc. LynxEM+ DataBook Memory Control Registers MCR60: Memory Control Read/Write Address: 3C5h, Index: 60h Power-on Default: 00h This register specifies memory control for Memory Address Wrap Around, DRAM refresh, VGA to memory burst write, and synchronization. This register also includes RAMDAC Write/Read Command Pulse Width select. 7 6 RESERVED 5 4 3 2 1 0 RAM DVGA VGAF R DDRR DRC Bit 7:6 Reserved Bit 5 RAMDAC Write/Read Command Pulse Width Select (RAM) 0 = Command Pulse is 4 MCLK high and 12 MCLK low 1 = Command Pulse is 8 MCLK high and 24 MCLK low Bit 4 Disable VGA to memory burst write (DVGA) 0 = Enable 1 = Disable Bit 3 VGA FIFO Empty Level Request Select. VGA FIFO is 8 level deep. (VGAF) 0 = VGA FIFO request if VGA FIFO is two level empty 1 = VGA FIFO request if VGA FIFO is four level empty Bit 2 Reserved (R) Bit 1 Disable DRAM Refresh Request (DDRR) 0 = Enable 1 = Disable Bit 0 DRAM Refresh Control (DRC) 0 = Normal DRAM refresh 1 = Force to 1 DRAM refresh per scan line MCR61: Memory Bank Address High Read/Write Address: 3C5h, Index: 61h Power-on Default: 00h This register specifies the high order memory bank address for non-linear addressing (or banking) mode (SCR18 bit 0 = 0). 17 - 38 Extended SMI Registers Silicon Motion®, Inc. 7 LynxEM+ DataBook 6 5 4 3 2 1 0 MEMORY BANK ADDRESS HIGH Bit 7:0 Memory Bank Address High Specifies the high-order address for memory access in non-linear addressing (or banking) mode. The host will take these bits append with address [15:0] to form a 22 bits address (4Mbyte). MCR62: Memory Type and Timing Control Read/Write Address: 3C5h, Index: 62h Power-on Default: This is a power-on configurable register (by RESET) LynxEM+ supports both internal and external memory. This register specifies the memory type and memory timing control. This register is power-on configurable by MD [7:0] of memory data bus. 7 6 IL EMD 5 4 MD[5:4] 3 2 1 0 MD3 ME MD1 MD0 Bit 7 Internal Logic (IL) 0 = Internal logic will be running 1/2X MCLK 1 = Internal logic will be running 1X MCLK Bit 6 Enable Memory Data Bus (EMD) 0 = Enable 32-bit memory data bus 1 = Enable 64-bit memory data bus Bit 5:4 External Memory Column Address Control Select. Power-on configurable by MD [5:4]. (MD[5:4]) 10 = 8 column address 11 = 9 column address 0x = 10 column address Bit 3 Bit 2 Reserved External Memory Enable (ME) 0 = Enable external 32-bit memory 1 = Disable external 32-bit memory Bit 1 External SDRAM/SGRAM Memory Active to Precharge delay Control. Power-on configurable by MD1. (MD1) 0 = 7 MCLK 1 = 6 MCLK Bit 0 External SDRAM/SGRAM Memory refresh to command delay. Power-on configurable bit by MD0. (MD0) 0 = 10 MCLK 1 = 9 MCLK Extended SMI Registers 17 - 39 Silicon Motion®, Inc. LynxEM+ DataBook Clock Control Registers CCR65: TV Encoder Control Register Read/Write Address: 3C5h, Index: 65h Power-on Default: 00h This register specifies the various TV controls. 7 6 5 RESERVED 4 3 2 1 0 SRAM TVSC TVSS CHOS Bit 7:4 Reserved Bit 3 Select which SRAM to read from index color modes. (SRAM) 0 = Read from CRT SRAM 1 = Read from LCD SRAM Bit 2 TV Sub-carrier Select. (TVSC) 0 = Set ALT per field clock 1 = Set free running clock Bit 1 TVCLK Source Select (TVSS) 0 = TVCLK source is from “CKIN” input pin. Normally “CLKIN” input is connected with 14.31818 MHZ clock for NTSC TV. TVCLK for NTSC is derived from 14.31818 MHz divided by 4. 1 = TVCLK source is from “REFCLK” input pin. If “REFCLK” input is connected with 17.734480 MHz clock for PAL TV. TVCLK for PAL is derived from 17.734480 MHz divided by 4. Bit 0 CRT HSYNC output select (CHOS) 0 = CRTHYSNC output to CRTHSYNC pin 1 = CRT composite SYNC to CRTHSYNC pin CCR66: RAM LUT On/Off Control Read/Write Address: 3C5h, Index 66h Power-on Default: 00h RAM control and function ON/OFF register. Bit 7:6 RAM operation control bits 00 = Both RAM on 10 = LCD RAM off 01 = CRT RAM off 11 = Both RAM off Bit 5:4 RAM write control bits 00 = Write both RAM (CRT/LCD) 10 = Write CRT RAM only 17 - 40 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook 01 = Write LCD RAM only 11 = Reserved Bit 3:2 CRT RAM 8/6 bits and gamma control 00 = 6 bits RAM 10 = 8 bits RAM x1 = Gamma correction on 01 = 8 bits RAM CCR67: Reserved This register is reserved for simulation purposes. CCR68: Clock Control 1 Read/Write Address: 3C5h, Index: 68h Power-on Default: C0h This register is used to select clock frequencies and pulse-width control. 7 6 VCLKF Bit 7:6 5 4 ISO CLK 3 2 1 SELECT VCLK 0 SELECT MCLK Select VCLK frequency based on the following table (VCLKF) Bit [7:6] ~EXCKEN VCLK frequency Bit 5 00 1 VCLK is selected from VGA 3C2h register 01 1 VCLK is selected from programmable VCLK registers: CCR6C and CCR6D 10 1 VCLK is selected from 17.734 MHz (Reserve) 11 1 VCLK is selected from 14.131818 MHz xx 0 VCLK is selected from CKIN input Enable ISO standard at VGA modes. This bit is designed to increase the CRT screen refresh rate to ISO standard at VGA modes. This bit is used only when CCR68 bit [7:6] = 00b. (ISO) 0 = Standard VGA frequency which controlled by 3C2h bit [3:2] 1 = ISO frequency which selected by 3C2h bit [3:2] CCR68 Bit 5 3C2h Bit [3:2] VCLK frequency 0 00 25.180 MHz 0 01 28.325 MHz 1 00 31.500 MHz 1 01 35.484 MHz Extended SMI Registers 17 - 41 Silicon Motion®, Inc. LynxEM+ DataBook Bit 4 Select 8-dot character clock and disable dot clock divided by 2 function. This bit is used when LCD or TV is selected (determined by FPR31 [2:0]). When this bit set to "1", the bit 3 and bit 0 setting of VGA Clocking Mode Register will be ignored. (CLK) 0 = Character clock and dot clock are controlled by VGA clocking mode register 1 = Select 8-dot character clock and non-divided by 2 dot clock Bit 3:2 Select VCLK high/low pulse width 00 = default value 01 = reduce 1 ns low time 10 = increase 1 ns low time 11 = increase 2 ns low time Bit 1:0 Select MCLK high/low pulse width 00 = default value 01 = reduce 1 ns low time 10 = increase 1 ns low time 11 = increase 2 ns low time CCR69: Clock Control 2 Read/Write Address: 3C5h, Index: 69h Power-on Default: 80h This register is used to select Virtual Refresh clock frequency, DRAM refresh clock frequency during sleep mode and standby mode, and HSYNC & VSYNC control during sleep mode. 7 6 5 TVCLK TDSS 4 LVDSCLK 3 2 DRAM SHVSM 1 0 SELECT VRCLK Bit 7 TVCLK or BLANK Select (TVCLK) 0 = Select BLANK output 1 = Select TVCLK to external analog NTSC/PAL TV encoder. TVCLK is equal to ¼ of VCLK, where VCLK is programmable by CCR6C and CCR6D registers. Bit 6 Test Data Source Select. This bit is used for LSI testing only. (TDSS) 0 = Select index color data for test data 1 = Select direct color data for test data Bit 5:4 Select LVDSCLK output clock source when ~EXCKIN = 1. LVDSCLK can be used to drive National's FPD Link transmitter for color DSTN panel LCD. For more detailed information on how to interface with the FPD Link transmitter, please refer to the Flat Panel Interface chapter of this data book. (LVDSCLK) 00 = Select VRCLK (VRCLK is defined by bit [1:0] of this register) 01 = Select inverted VRCLK 10 = Select ½ VRCLK 11 = Select inverted ½ VRCLK Bit 3 Select refresh clock source to control DRAM refresh during sleep mode and standby mode. It is recommended to select external 32 KHz refresh clock to achieve highest power saving. (DRAM) 17 - 42 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook 0 = Select external 32 KHz refresh clock 1 = Select internal PLL. During standby or sleep mode, the VCLK and MCLK frequency are selected by PDR20 [5:4]. MCLK is used to replace external 32 KHz refresh clock to control DRAM refresh. Bit 2 Select HSYNC and VSYNC during Sleep Mode. (PDR20 bit 7 = 1) This bit is used to support VESA DPMS during Sleep Mode. LynxEM+ will automatically support VESA DPMS Standby Mode during its internal Standby Mode. (SHVSM) Bit 1:0 Bit 2 DPMS STATE HSYNC VSYNC 0 Suspend Pulses No Pulses 1 Off No Pulses No Pulses Select Virtual Refresh clock (VRCLK). The VRCLK is used to generate the timing sequence of LCD interface signals and control logic during Virtual Refresh mode. Bit [1:0] VRCLK Frequency 00 VCLK2 01 ½ MCLK 10 MCLK 11 programmable Video Clock¹ Notes: 1. In TV display mode, VCLK is set up as 14.31818 MHz clock from CKIN input (CCR68 [7:6] = 11b) to control TV timing. VRCLK could be chosen from programmable Video Clock which is selected by CCR6C and CCR6D registers by programming CCR69 [1:0] = 11b. 2. In non-Virtual Refresh mode (FPR31 bit 7 = 0), VRCLK is the same as VCLK. CCR6A: MCLK Numerator Register Read/Write Address: 3C5h, Index: 6Ah Power-on Default: 5Ah This register specifies the 8-bit numerator value of MCLK frequency (MNR). The MNR value is used to calculate the programmable MCLK frequency as follows: MNR MCLK = 14.31818 MHz * 7 6 5 MDR 4 3 2 1 0 CALCULATE MCLK FREQUENCY [8] Bit 7:0 Specify the 8-bit numerator value to calculate the selected MCLK frequency. The power-on default of this register is 5Ah. Along with CCR6B, the default frequency is set to 40.27 MHz. Extended SMI Registers 17 - 43 Silicon Motion®, Inc. LynxEM+ DataBook CCR6B: MCLK Denominator Register Read/Write Address: 3C5h, Index: 6Bh Power-on Default: 20h This register specifies the 6-bit denominator value of MCLK frequency (MDR). The MDR value is used to calculate the programmable MCLK frequency as follows: MNR MCLK = 14.31818 MHz * 7 6 MDR 5 RESERVED 4 3 2 1 0 CALCULATE MCLK FREQUENCY [6] Bit 7:6 Reserved Bit 5:0 Specify the 6-bit denominator value to calculate the selected MCLK frequency. The power-on default of this register is 20h. Along with CCR6A, the default frequency is set to 40.27 MHz. CCR6C: VCLK Numerator Register Read/Write Address: 3C5h, Index: 6Ch Power-on Default: 5Bh This register specifies the numerator value of VCLK frequency (VNR). The VNR value is used to calculate the programmable VCLK frequency as follows: VNR VCLK = 14.31818 MHz * 7 6 5 1 * VDR 4 (1+PS) 3 2 1 0 CALCULATE VCLK FREQUENCY Bit 7:0 Specify the numerator value to calculate the selected VCLK frequency. The power-on default setting of this register is 5Bh. Along with CCR6D, the default frequency is set to 28.325 MHz. CCR6D: VCLK Denominator Register Read/Write Address: 3C5h, Index: 6Dh Power-on Default: 2Eh This register specifies the 6-bit denominator (VDR) value of and 1 bit post scalar (PS) value of VCLK frequency. The VDR value is used to calculate the programmable VCLK frequency. The post scalar is used to support VCLK frequencies which originally need high and even VDR value. With PS enabled, the revised VDR value should be set half of the original VDR value in order to reduce potential jitters. 17 - 44 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook CCR68_[7] or CCR68[6] CCR6D_[6] CCR6D_[7] VCLK Frequency x 0 0 VCLK x 0 1 1/2 VCLK 1 1 0 1/4 VCLK 1 1 1 1/8 VCLK VNR VCLK = 14.31818 MHz * 7 6 5 1 * VDR 4 POST SCALAR (1+PS) 3 2 1 0 VCLK FREQUENCY [6] Bit 7:6 Enable Post Scalar. 0 0 Post Scalar not enable, vclk = programmed vclk 1 0 Post Scalar enable, vclk = 1/2 programmed vclk 0 1 Post Scalar enable, vclk = 1/4 programmed vclk 1 1 Post Scalar enable, vclk = 1/8 programmed vclk Bit 5:0 Specify the 6-bit denominator value to calculate the selected VCLK frequency. The power-on default setting of this register is 2Eh. Along with CCR6C, the default frequency is set to 28.325 MHz. CCR6E: VCLK2 Numerator Register Read/Write Address: 3C5h, Index: 6Eh Power-on Default: 5Ah This register specifies the 8-bit numerator value of VCLK2 frequency (VCKL2NR). The VCLK2NR value is used to calculate the programmable VCLK2 frequency as follows: VCLK2NR VCLK2 = 14.31818 MHz * 7 6 5 VCLK2DR 4 3 2 1 0 VCLK2 FREQUENCY [8] Bit 7:0 Specify the 8-bit numerator value to calculate the selected VCLK2 frequency. Along with CCR6F, the default frequency is set to 40.27 MHz. CCR6F: VCLK2 Denominator Register Read/Write Address: 3C5h, Index: 6Fh Power-on Default: 20h Extended SMI Registers 17 - 45 Silicon Motion®, Inc. LynxEM+ DataBook This register specifies the 6-bit denominator value of VCLK2 frequency (VCLK2DR). The VCLK2DR value is used to calculate the programmable VCLK2 frequency as follows: VCLK2NR VCLK2 = 14.31818 MHz * 7 6 VCLK2DR 5 RESERVED 4 3 2 1 0 CALCULATE VCLK2 FREQUENCY [6] Bit 7:6 Reserved Bit 5:0 Specify the 6-bit denominator value to calculate the selected VCLK2 frequency. Along with CCR6E, the default frequency is set to 40.27 MHz. General Purpose Registers GPR70: Scratch Pad Register 1 Read/Write Address: 3C5h, Index: 70h Power-on Default: Undefined except for bit [3:0] which are power-on configurable (by RESET) This register can be used as general purpose scratch bits. 7 6 5 4 SCRATCH PAD REG BITS 3 2 1 0 SCRATCH PAD REG BITS MD [19:16] Bit 7:4 Scratch pad register bits. This register can be used as general purpose bits. Bit 3:0 Scratch pad register bits. These lower 4 bits are also connected to MD [19:16] of memory data bus. The external pull-down on MD lines will generate a logic "0", and internal pull-up will generate a logic "1" during power-on reset period. For power-on configuration, please refer to Initialization chapter of this data book. GPR71: Scratch Pad Register 2 Read/Write Address: 3C5h, Index: 71h Power-on Default: Undefined This register can be used as general purpose scratch bits. 7 6 5 4 3 2 1 0 SCRATCH PAD 2 REGISTER Bit 7:0 17 - 46 Scratch Pad 2 register. This register can be used as general purpose scratch bits. Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook GPR72: User Defined Register 1 for DDC2/ I2C Read/Write Address: 3C5h, Index: 72h Power-on Default: 00h This register is used for user defined registers: USR1/SDA and USR0/SCL. The SDA and SCL can be used for VESA DDC2 / I2C serial communication port. 7 6 RESERVED 5 4 3 2 1 0 EUSR1 EUSR0 USR1S USR0S USR1W USR0W Bit 7:6 Reserved Bit 5 Enable USR1/SDA Port (EUSR1) 0 = Disable use of bit 1 of this register 1 = Enable use of bit 1 of this register Bit 4 Enable USR0/SCL Port (EUSR0) 0 = Disable use of bit 0 of this register 1 = Enable use of bit 0 of this register Bit 3 USR1/SDA Status (Read only). This bit can be used for DDC2/I2C Data. (USR1S) 0 = pin USR1/SDA is low 1 = pin USR1/SDA is tri-stated Bit 2 USR0/SCL Status (Read only). This bit can be used for DDC2/I2C Clock. (USR0S) 0 = pin USR0/SCL is low 1 = pin USR0/SCL is tri-stated Bit 1 USR1/SDA Write. Pin 131 can be used for DDC2/I2C Data. When pin USR1/SDA is tri-stated, other devices may drive this line. The actual state of the pin USR1/SDA is read via bit 3 of this register. (USR1W) 0 = pin USR1/SDA is driven low 1 = pin USR1/SDA is tri-stated Bit 0 USR0/SCL Write. Pin 132 can be used for DDC2/I2C Clock. When pin USR0/SCL is tri-stated, other devices may drive this line. The actual state of the pin USR0/SCL is read via bit 2 of this register. (USR0W)0 = pin USR0/SCL is driven low 1 = pin USR0/SCL is tri-stated GPR73: User Defined Register 2 Read/Write Address: 3C5h, Index: 73h Power-on Default: 00h This register can be used to control user programmable outputs: USR2 and USR3 pins. Extended SMI Registers 17 - 47 Silicon Motion®, Inc. 7 6 RESERVED LynxEM+ DataBook 5 4 3 2 1 0 USR3P USR2P USER3 USER2 USR3W USR2W Bit 7:6 Reserved Bit 5 Enable USR3 Port (USR3P) 0 = Disable use of bit 1 of this register 1 = Enable use of bit 1 of this register Bit 4 Enable USR2 Port (USR2P) 0 = Disable use of bit 0 of this register 1 = Enable use of bit 0 of this register Bit 3 USER3 Status (Read only) (USER3) 0 = pin USR3 is low 1 = pin USR3 is tri-stated Bit 2 USER2 Status (Read only) (USER2) 0 = pin USR2 is low 1 = pin USR2 is tri-stated Bit 1 USR3 Write. When pin USR3 is tri-stated, other devices may drive this line. The actual state of the pin USR3 is read via bit 3 of this register. (USR3W) 0 = pin USR3 is driven low 1 = pin USR3 is tri-stated Bit 0 USR2 Write. When pin USR2 is tri-stated, other devices may drive this line. The actual state of the pin USR2 is read via bit 2 of this register. (USR2W) 0 = pin USR2 is driven low 1 = pin USR2 is tri-stated GPR74: Scratch Pad Register 3 Read/Write Address: 3C5h, Index: 74h Power-on Default: Undefined This register can be used as general purpose scratch bits. 7 6 5 4 3 2 1 0 SCRATCH PAD 3 REGISTER Bit 7:0 Scratch Pad 3 register. This register can be used as general purpose scratch bits. GPR75: Scratch Pad register 4 Read/Write 17 - 48 Address: 3C5h, Index: 75h Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook Power-on Default: Undefined This register can be used as general purpose scratch bits. 7 6 5 4 3 2 1 0 SCRATCH PAD 4 REGISTER Bit 7:0 Scratch Pad 4 register. This register can be used as general purpose scratch bits. Pop-up Icon and Hardware Cursor Registers PHR80: Pop-up Icon and Hardware Cursor Pattern Location Low Read/Write Address: 3C5h, Index: 80h Power-on Default: Undefined This register specifies the low 8 bits of the address for pop-up icon and Hardware Cursor Pattern Location, which is a 11bit register. The high order 3 bits are specified in the PHR81 [2:0] register. 7 6 5 4 3 2 1 0 POP-UP ICON AND HARDWARE CURSOR PATTERN Bit 7:0 Pop-up Icon and Hardware Cursor Pattern Location Low. The PHR80 and PHR81 [2:0] registers allocate 2KB off-screen memory within the maximum 4MB of physical memory. The lower 1KB is used to store Pop-up Icon image. The upper 1KB is used to store Hardware Cursor image PHR81: Hardware Cursor Enable & PI/HWC Pattern Location High Read/Write Address: 3C5h, Index: 81h Power-on Default: 0xh This register specifies the hardware cursor enable and the high-order 3 bits of the address for pop-up icon and Hardware Cursor Pattern Location, which is a 11-bit register. The low order 8 bits are specified in the PHR80 register. 7 HCE 6 5 4 3 RESERVED 2 1 0 POP-UP ICON Bit 7 Hardware Cursor Enable (HCE) 0 = Disable (default) 1 = Enable Bit 6:3 Reserved Bit 2:0 Pop-up Icon and Hardware Cursor Pattern Location High. The PHR80 and PHR81 [2:0] registers allocate 2KB off-screen memory within the maximum 4MB of physical memory. The lower 1KB is used to store Pop-up Icon image. The upper 1KB is used to store Hardware Cursor image. Extended SMI Registers 17 - 49 Silicon Motion®, Inc. LynxEM+ DataBook Pop-up Icon Registers POP82: Pop-up Icon Control Read/Write Address: 3C5h, Index: 82h Power-on Default: 00h This register specifies the control for pop-up icon. 7 6 5 PUIE PUIZE 4 3 2 1 0 RESERVED Bit 7 Pop-up Icon Enable (PUIE) 0 = Disable 1 = Enable Bit 6 Pop-up Icon Zoom Enable (PUIZE) 0 = Normal. (Pop-up Icon size is 64x64x2) 1 = zoom up the Pop-up Icon size by 2. (Pop-up Icon size is 128x128x2) Bit 5:0 Reserved POP83: Reserved Read/Write Address: 3C5h, Index: 83h Power-on Default: Undefined This register is reserved. 7 6 5 4 3 2 1 0 2 1 0 RESERVED Bit 7:0 Reserved POP84: Pop-up Icon Color 1 Read/Write Address: 3C5h, Index: 84h Power-on Default: Undefined This register specifies the color1 for pop-up icon. 7 6 5 4 3 POP-UP ICON COLOR1 Bit 7:0 17 - 50 Pop-up icon color1. Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook POP85: Pop-up Icon Color 2 Read/Write Address: 3C5h, Index: 85h Power-on Default: Undefined This register specifies the color2 for pop-up icon. 7 6 5 4 3 2 1 0 2 1 0 1 0 1 0 POP-UP ICON COLOR2 Bit 7:0 Pop-up icon color2. POP86: Pop-up Icon Color 3 Read/Write Address: 3C5h, Index: 86h Power-on Default: Undefined This register specifies the color3 for pop-up icon. 7 6 5 4 3 POP-UP ICON COLOR3 Bit 7:0 Pop-up icon color3. POP90: Pop-up Icon Start X - Low Read/Write Address: 3C5h, Index: 90h Power-on Default: Undefined This register specifies Pop-up icon location X start [7:0] 7 6 5 4 3 2 POP-UP ICON X START [7:0] Bit 7:0 Pop-up icon X start [7:0] POP91: Pop-up Icon Start X - High Read/Write Address: 3C5h, Index: 91h Power-on Default: Undefined This register specifies Pop-up icon location X start [11:8] 7 6 5 RESERVED Extended SMI Registers 4 3 2 POP-UP ICON X START 17 - 51 Silicon Motion®, Inc. LynxEM+ DataBook Bit 7:3 Reserved Bit 2:0 Pop-up icon X start [10:8] POP92: Pop-up Icon Start Y - Low Read/Write Address: 3C5h, Index: 92h Power-on Default: Undefined This register specifies Pop-up icon location Y start [7:0] 7 6 5 4 3 2 1 0 1 0 POP-UP ICON Y START Bit 7:0 Pop-up icon Y start [7:0] POP93: Pop-up Icon Start Y - High Read/Write Address: 3C5h, Index: 93h Power-on Default: Undefined This register specifies Pop-up icon location Y start [11:8] 7 6 5 4 3 RESERVED 2 POP-UP ICON Y START Bit 7:3 Reserved Bit 2:0 Pop-up icon Y start [10:8] Hardware Cursor Registers HCR88: Hardware Cursor Upper Left X Position - Low Read/Write Address: 3C5h, Index: 88h Power-on Default: 00h This register specifies the lower 8-bit upper left X position for hardware cursor. 7 6 5 4 3 2 1 0 HARDWARE CURSOR X POSITION LOW ORDER Bit 7:0 17 - 52 Hardware Cursor X position low order 8 bits. The high order 3 bits are in HCR89[2:0]. Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook HCR89: Hardware Cursor Upper Left X Position- High Read/Write Address: 3C5h, Index: 89h Power-on Default: 00h This register specifies the upper left X position for hardware cursor. 7 6 5 4 RESERVED 3 2 HCUL 1 0 HCXP Bit 7:4 Reserved Bit 3 Hardware Cursor Upper Left X Position Boundary Select (HCUL) 0 = hardware cursor is within the screen left side boundary. {HCR89[2:0], HCR88[7:0]} specify the X position of the hardware cursor from the left side boundary. 1 = hardware cursor is partially or totally outside of the left side screen boundary. HCR88 [4:0] specify how many pixels of the hardware cursor are outside the left side screen boundary. Bit 2:0 Hardware Cursor X position high-order 3 bits. The low order 8 bits are specified in the HCR88 register. (HCXP) HCR8A: Hardware Cursor Upper Left Y Position - Low Read/Write Address: 3C5h, Index: 8Ah Power-on Default: 00h This register specifies the upper left Y position for hardware cursor. 7 6 5 4 3 2 1 0 HARDWARE CURSOR Y POSITION LOW ORDER Bit 7:0 Hardware Cursor Y position low order 8 bits. The high order 3 bits are in HCR8B [2:0]. HCR8B: Hardware Cursor Upper Left Y Position - High Read/Write Address: 3C5h, Index: 8Bh Power-on Default: 00h This register specifies the upper left Y position for hardware cursor. 7 6 5 RESERVED 4 3 HCUL 2 1 0 HCYP Bit 7:4 Reserved Bit 3 Hardware Cursor Upper Left Y Boundary Select (HCUL) Extended SMI Registers 17 - 53 Silicon Motion®, Inc. LynxEM+ DataBook 0 = hardware cursor is within the screen top side boundary. {HCR8B[2:0], HCR8A[7:0]} specify the Y position of the hardware cursor from the top side boundary. 1 = hardware cursor is partially or totally outside of the top side screen boundary. HCR8A [4:0] specify how many pixels of the hardware cursor are outside the top side screen boundary. Bit 2:0 Hardware Cursor Y position high-order 3 bits. The low order 8 bits are specified in the HCR8A register. (HCYP) HCR8C: Hardware Cursor Foreground Color Read/Write Address: 3C5h, Index: 8Ch Power-on Default: 00h This register specifies the foreground color for hardware cursor. Hardware Cursor is always in 24-bit color. The 24-bit color is the expansion of 3:3:2 RGB into 8:8:8 RGB color. 7 6 5 4 3 2 1 0 HARDWARE CURSOR FOREGROUND COLOR Bit 7:0 Hardware Cursor foreground color This register defines 3:3:2 8-bit RGB of the Hardware Cursor foreground color. HCR8D: Hardware Cursor Background Color Read/Write Address: 3C5h, Index: 8Dh Power-on Default: 00h This register specifies the background color for hardware cursor. Hardware Cursor is always in 24-bit color. The 24-bit color is the expansion of 3:3:2 RGB into 8:8:8 RGB color. 7 6 5 4 3 2 1 0 HARDWARE CURSOR BACKGROUND COLOR Bit 7:0 Hardware Cursor background color This register defines 3:3:2 8-bit RGB of the Hardware Cursor background color. Extended CRT Control Registers CRT30: CRTC Overflow and Interlace Mode Enable Read/Write Address: 3?5h, Index: 30h Power-on Default: 00h This register specifies the CRTC overflow registers and Interlace Mode Enable. 17 - 54 Extended SMI Registers Silicon Motion®, Inc. 7 LynxEM+ DataBook 6 IME 5 4 CRT DISPLAY 3 2 1 0 CVTR CVDER CVBS CVRS Bit 7 Interlace Mode Enable (IME) 0 = Disable 1 = Enable Bit 6:4 Bit [18:16] of the CRT display starting address. The lower order 16-bit are located in CRTC register index 0Ch and 0Dh. Bit 3 Bit 10 of the CRT vertical total register. The lower bit [9:0] are defined in CRTC register index 07h and 06h. (CVTR) Bit 2 Bit 10 of the CRT vertical display end register. The lower bit [9:0] are defined in CRTC register index 12h and 07h. (CVDER) Bit 1 Bit 10 of the CRT vertical blank start. The lower bit [9:0] are defined in CRTC register index 15h, 09h, and 07h. (CVBS) Bit 0 Bit 10 of the CRT vertical retrace start. The lower bit [9:0] are defined in CRTC register index 10h and 07h. (CVRS) CRT31: Interlace Retrace Read/Write Address: 3?5h, Index: 31h Power-on Default: 00h This register specifies when vertical retrace begins. This register is only valid if interlace mode is enabled (CRT30 Bit 7 = 1). 7 6 5 4 3 2 1 0 SPECIFIC # CHARACTER UNITS IN HORIZONTAL TIMING Bit 7:0 Specify the number of character units in horizontal timing when vertical retrace begins. CRT32: TV Vertical Display Enable Start Read/Write Address: 3?5h, Index: 32h Power-on Default: 00h This register specifies the vertical display enable start for TV timing. 7 6 5 4 3 2 1 0 TV VERTICAL DISPLAY ENABLE Bit 7:0 When CRT vertical count = CRT32 [7:0], TV vertical display enable become active. Extended SMI Registers 17 - 55 Silicon Motion®, Inc. LynxEM+ DataBook CRT33: TV Vertical Display Enable End - High Read/Write Address: 3?5h, Index: 33h Power-on Default: 00h This register specifies the vertical display enable end for TV timing. This register is a 11-bit register. The lower 8-bit of this register resides in CRT34. 7 6 ITE 5 4 HBE 3 VBE 2 1 0 CRT VERTICAL COUNT Bit 7 Interlace Timing Enable for double scan modes (i.e.: mode 13, etc.) (ITE) 0 = Disable 1 = Enable Bit 6:5 Bit [7:6] of Horizontal Blank End. Bit 5 is located in bit 7 of CRTC register, 3?5h, index 5. Bit [4:0] is located in CRTC register, 3?5h, index 3. (HBE) Bit 4:3 Bit [9:8] of Vertical Blank End. Bit [7:0] of Vertical Blank End is located in CRTC register, 3?5h, index 16. (VBE) Bit 2:0 When CRT vertical count = {CRT33 [2:0],CRT34 [7:0]}, TV vertical display enable becomes inactive. CRT34: TV Vertical Display Enable End - Low Read/Write Address: 3?5h, Index: 34h Power-on Default: 00h This register specifies the vertical display enable end for TV timing. 7 6 5 4 3 2 1 0 CRT VERTICAL COUNT Bit 7:0 When CRT vertical count = {CRT33 [2:0],CRT34 [7:0]} TV vertical display enable becomes inactive. CRT35: Vertical Screen Expansion DDA Control Constant - Low Read/Write Address: 3?5h, Index: 35h Power-on Default: 00h This register specifies bit [7:0] the DDA control constant (DDACC) which is used for vertical screen expansion in VGA modes. Bit [9:8] of the DDACC is located in CRT36. To enable vertical screen expansion in VGA graphics modes, one needs to program the DDA control constant (DDACC) equal to: 17 - 56 Extended SMI Registers Silicon Motion®, Inc. DDACC = LynxEM+ DataBook 1024 * actual vertical size expanded vertical size To enable vertical expansion in VGA text mode, one must program DDACC [2:0] = # of times the last character row should be repeated. 7 6 5 4 3 2 1 0 VERTICAL SCREEN EXPANSION Bit 7:0 This register defines the lower 8 bits of the vertical screen expansion DDA control constant. The upper 2 bits of the DDACC register is located in CRT36. For VGA text modes, only the lower [2:0] are valid. CRT36: Vertical Screen Expansion DDA Control Constant - High Read/Write Address: 3?5h, Index: 36h Power-on Default: 00h This register the vertical screen expansion DDA control constant lower 8 bits. 7 6 5 4 3 2 1 RESERVED 0 VSE Bit 7:2 Reserved Bit 1:0 This register defines bit [9:8] of the vertical screen expansion DDA control constant. The lower 8-bit are located in CRT35. (VSE) CRT38: TV Equalization Pulse Control For External TV Encoder Read/Write Address: 3?5h, Index: 38h Power-on Default: 00h 7 6 CSS R 5 4 3 2 1 0 EQUALIZATION PULSE WIDTH Bit 7 Composite Sync Select (CSS) 0 = CSYNC is generated by SYNCs (HSYNC NOR VSYNC) 1 = CSYNC is generated by equalizer state machine Bit 6 Reserved (R) Bit 5:0 Equalization pulse width in units of four VCLK Extended SMI Registers 17 - 57 Silicon Motion®, Inc. LynxEM+ DataBook CRT39: TV Serration Pulse Control For External TV Encoder Read/Write Address: 3?5h, Index: 39h Power-on Default: 00h 7 6 5 RESERVED 4 3 2 1 0 SERRATION PULSE WIDTH Bit 7:6 Reserved Bit 5:0 Serration pulse width in units of four VCLK CRT3A: HSync and Character Clock Fine Turn Control Register Read/Write Address: 3?4, Index: 3Ah Power-on Default: 00h 7 6 RESERVED 5 4 3 PIXEL CLOCK DELAY 2 1 0 CHARACTER DOT Bit 7:6 Reserved Bit 5:3 Pixel clock delay selection 00 = Normal 01 = Hsync delayed by one pixel clock 02 = Hsync delayed by two pixel clocks 03 = Hsync delayed by three pixel clocks 04 = Hsync delayed by four pixel clocks 05 = Hsync delayed by five pixel clocks Bit 2:0 Character clock dot selection 07 = one character clock contains 7 dot clocks 06 = one character clock contains 6 dot clocks 05 = one character clock contains 5 dot clocks 04 = one character clock contains 4 dot clocks 03 = one character clock contains 3 dot clocks 02 = one character clock contains 2 dot clocks Example: to program the 910 pixel horizontal total for 4FC NTSC TV mode: Program CRT horizontal total register to be 109 character clock. Program 3?4, Index 3A, bit [2:0] = 06. The actual total number of character per horizontal line is 109+5=114. The horizontal total in pixel clock is : 113x8+6=910. CRT3B: Hardware Testing Register 2 Read/Write Address: 3?5h, Index: 3Bh Power-on Default: 00h 17 - 58 Extended SMI Registers Silicon Motion®, Inc. 7 LynxEM+ DataBook 6 5 4 3 2 1 0 2 1 0 RESERVED Bit 7:0 Reserved for VGA hardware testing CRT3C: Hardware Testing Register 3 Read/Write Address: 3?4h, Index: 3Ch Power-on Default: 00h 7 6 VGA DEBUG 5 4 BSS LCB 3 VGA DEBUG AND TESTING Bit 7:6 VGA debug test bus selection Bit 5 Blanking signal selection (BSS) 0 = The blanking signal sent to RAMDAC is reversed active display. Outside of active display the blanking is active (black color). The border color register has no effect. 1 = The blank signal sent to RAMDAC is the normal blank signal from CRT. When both the blank and dispen are inactive the border color is displayed. Bit 4 Line compare bit selection (LCB) 0 = No effect 1 = Line compare bit [9:8] (CRT09 - [6], CRT07 - [4]) has no effect to line compare logic Bit 3:0 VGA debug and testing CRT3D: Scratch Register Bits Read/Write Address: 3?4h, Index: 3Dh Power-on Default: 00h 7 6 5 4 3 2 1 0 2 1 0 SCRATCH REGISTER BITS Bit 7:0 Scratch Register Bits CRT3E: Scratch Register Bits Read/Write Address: 3?4h, Index: 3Eh Power-on Default: 00h 7 6 5 4 3 SCRATCH REGISTER BITS Extended SMI Registers 17 - 59 Silicon Motion®, Inc. Bit 7:0 LynxEM+ DataBook Scratch Register Bits CRT3F: Scratch Register Bits Read/Write Address: 3?4h, Index: 3Fh Power-on Default: 00h 7 6 5 4 3 2 1 0 SCRATCH REGISTER BITS Bit 7:0 Scratch Register Bits CRT9E: Expansion/Centering Control Register 2 Read/Write Address: 3?4h, Index: 9Eh Power-on Default: 00h 7 6 5 4 3 2 1 0 FE HSCRT HSRW VE VC VEE VCE HCE Bit 7 Font expansion control bit (FE) This bit is effective if the following is true: CRT9E_[4] = 0 and the text mode plus the vertical expansion is on and CRT09_[4:0] < H0F 0 = The font vertical expansion will repeat the last character row 1 = The font vertical expansion will insert lines (with screen background color) between the last scan line of the current character row and the first scan of the next character row. Bit 6 Horizontal shadow register selection for CRT timing control (HSCRT) 0 = There are two sets of horizontal shadow registers (primary and secondary). The selection switch is at the beginning of the vsync. If CR9F_[0] or CR9F [1] or FPR32_[0] is equal to 1 the second set is selected. If these registers are not equal to 1 then the primary set is selected. 1 = To force the selection of the second set of horizontal shadow register Bit 5 Horizontal shadow register read/write selection (HSRW) The following register update are effected SVR40_[7:0] - Horizontal total shadow SVR41_[7:0] - Horizontal blank start shadow SVR42_[4:0] - Horizontal blank end shadow SVR44_[7] - Horizontal blank end bit 5 shadow CRT33_[6:5] - Horizontal blank end bit 7 & 6 SVR43_[7:0] - Horizontal sync start shadow SVR44_[4:0] - Horizontal sync end CRT9F_[0] - 10 dots expansion CRT9F_[1] - 12 dots expansion These registers have two sets - primary and secondary. 17 - 60 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook Bit 5=0: The primary registers are selected for W/R and control crt Bit 5=1: The secondary registers are selected for W/R and control crt Bit 4 Vertical expansion DDA value selection (VE) 0 = Vertical expansion will select the DDA value from the DDA look up table (3?4.35&36). This bit has no effect if bit 2 of this register = 0. 1 = Vertical expansion will select the DDA value from the DDA look up table (3?4.90-91B). Bit 3 Vertical centering offset value selection (VC) 0 = Select vertical centering offset value from vertical center offset register (3?4, Index A6). This bit has no effect if bit 1 of this register = 0 1 = Select vertical centering offset value from a look-up table (look up by vdispend) Bit 2 Vertical expansion enable selection (VEE) 0 = Vertical expansion disable 1 = Vertical expansion enable Bit 1 Vertical centering enable selection (VCE) 0 = Vertical centering disable 1 = Vertical centering enable Bit 0 Horizontal centering enable selection (HCE) 0 = Horizontal centering disable 1 = Horizontal centering enable CRT9F: Expansion/Center Control Register 1 Read/Write Address: 3?4h, Index: 9Fh Power-on Default: 00h 7 6 5 4 3 2 RESERVED 1 0 CC12 CC10 Bit 7:2 Reserved Bit 1 12 dot expansion (CC12) 0 = 12 dots expansion disabled 1 = Character clock expand to 12 dots regardless of bit 0 of this register Bit 0 10 dot expansion (CC10) 0 = 10 dots expansion 1 = Character clock expand to 10 dots CRT90-9B Vertical DDA Look Up Table & CRTA0-A5: Vertical Centering Offset Look Up Table Read/Write Address: 3?4, Index A0h-A5h Power-on Default: 00h Extended SMI Registers 17 - 61 Silicon Motion®, Inc. LynxEM+ DataBook 3?4.90 7 6 5 4 3 3?4.91 2 1 0 7 6 FIELD 3 5 4 3 3?4.A0 2 1 0 5 4 FIELD 2 3 2 1 0 FIELD 1 Field 3: This field compared with Vdisp_end (3?4.12 bit_[7:2]) Field 2: This field is selected DDA value if field 3 compares Field 1: This field is selected vertical centering offset value if field 3 compares. The actual offset value = 3?4.A0_[5:0] x 4 The vertical expansion/centering using look up table is enabled only if the following conditions are true: CR9E_[3:1] = 111; if the compare fails to match with any entry, the value from 3?4.A6 will be used for vertical centering and the 3?4.35&36 will be used for DDA. The following register groups behave the same: 3?4.92; 3?4.93; 3?4.A1 3?4.94; 3?4.95; 3?4.A2 3?4.96; 3?4.97; 3?4.A3 3?4.98; 3?4.99; 3?4.A4 3?4.9A; 3?4.9B; 3?4.A5 CRTA0-A5: Vertical Centering Offset Look Up Table Read/Write Address: 3?4, Index A0h-A5h Power-on Default: 00h 3?4.90 7 6 5 4 3 3?4.91 2 1 0 7 FIELD 3 6 5 4 3 3?4.A0 2 FIELD 2 1 0 5 4 3 2 1 0 FIELD 1 Field 3: This field compared with Vdisp_end (3?4.12 bit_[7:2]) Field 2: This field is selected DDA value if field 3 compares Field 1: This field is selected vertical centering offset value if field 3 compares. The actual offset value = 3?4.A0_[5:0] x 4 The vertical expansion/centering using look up table is enabled only if the following conditions are true: CR9E_[3:1] = 111; if the compare fails to match with any entry, the value from 3?4.A6 will be used for vertical centering and the 3?4.35&36 will be used for DDA. The following register groups behave the same: 3?4.92; 3?4.93; 3?4.A1 17 - 62 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook 3?4.94; 3?4.95; 3?4.A2 3?4.96; 3?4.97; 3?4.A3 3?4.98; 3?4.99; 3?4.A4 3?4.9A; 3?4.9B; 3?4.A5 CRTA6: Vertical Centering Offset Register Read/Write Address: 3?4, Index: A6h Power-on Default: 00h 7 6 5 4 RESERVED 3 2 1 0 LINE SHIFT DOWN Bit 7:6 Reserved Bit 5:0 Specifies how many lines the screen image will shift down. This register will have no effect if 3?4.9E bit_[1]=1 CRTA7: Horizontal Centering Offset Register Read/Write Address: 3?4h, Index: A7h Power-on Default: 00h 7 6 5 R 4 3 2 1 0 CHARACTER UNIT SHIFT RIGHT Bit 7 Reserved (R) Bit 6:0 Specifies how many character units the screen image will shift to the right. This register has no effect if 3?4.9E BIT_[0] = 0 Shadow VGA Registers The Shadow VGA Registers are designed to control CRT, LCD and TV timing, and maintain VGA compatibility. LynxEM+ shadows 12 VGA CRT registers. When these shadow registers are unlocked, the CPU I/O write operation can write into both standard CRT registers and shadow registers through standard VGA CRTC I/O location. When these shadow registers are locked, the CPU I/O write can only write into the standard CRT registers through CRTC I/O location. These 12 shadow registers also have specific I/O location which is not controlled by Shadow Lock/Unlock Register. SVR40 - Horizontal Total SVR45 - Vertical Total SVR4A - Overflow (bit 7, 6,5, 3, 2, 1,and 0) SVR41 - Start Horizontal Blanking SVR46 - Start Vertical Blank SVR4B - Maximum Scan Line (bit 5 only) SVR42 - End Horizontal Blanking SVR47 - End Vertical Blank SVR4C - Horizontal Display End SVR43 - Start Horizontal Retrace SVR48 - Vertical Retrace Start SVR4D - Vertical Display End SVR44 - End Horizontal Retrace SVR49 - Vertical Retrace End Extended SMI Registers 17 - 63 Silicon Motion®, Inc. LynxEM+ DataBook Automatic Lock/Unlock Scheme for Shadow Registers There are two ways to access shadow registers. One is through standard VGA CRTC I/O location when CRT is the only selected display. These VGA CRT I/O write operations will write to both standard VGA CRT registers and shadow registers. The other way to access shadow registers is through their dedicated I/O locations. The shadow registers can only be read through their dedicated I/O locations. When LCD or TV display is selected, the shadow registers will be automatically locked. The VGA CRT I/O write operation will write only to the standard VGA CRT registers. The shadow registers have to be accessed from their dedicated I/O location. This approach will reduce programming difficulty and maintain VGA compatibility. SVR40: Shadow VGA Horizontal Total Read/Write Address: 3?5h, Index: 40h Power-on Default: 00h This register shadows VGA CRT Horizontal Total register. 7 6 5 4 3 2 1 0 SHADOW VGA HORIZONTAL TOTAL Bit 7:0 Defines the total character count minus 5 characters per horizontal scan line. depends on the resolution of LCD, not the type of LCD. This register only SVR41: Shadow VGA Horizontal Blank Start Read/Write Address: 3?5h, Index: 41h Power-on Default: 00h This register shadows VGA CRT Horizontal Blank Start register. 7 6 5 4 3 2 1 0 SHADOW VGA HORIZONTAL BLANK Bit 7:0 When the horizontal character = SVR41 [7:0], shadow VGA horizontal blank become active. SVR42: Shadow VGA Horizontal Blank End Read/Write Address: 3?5h, Index: 42h Power-on Default: 00h This register shadows VGA CRT Horizontal Blank End register. 7 R 17 - 64 6 5 SDES 4 3 2 1 0 SHADOW VGA HORIZONTAL BLANK INACTIVE Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook Bit 7 Reserved (R) Bit 6:5 Shadows display enable skew control (SDES) Bit 4:0 When the horizontal character = {SVR44 [7],SVR42 [4:0]}, shadow VGA horizontal blank become inactive. SVR43: Shadow VGA Horizontal Retrace Start Read/Write Address: 3?5h, Index: 43h Power-on Default: 00h This register shadows VGA CRT Horizontal Retrace Start register. 7 6 5 4 3 2 1 0 SHADOW VGA HORIZONTAL RETRACE INACTIVE Bit 7:0 When the horizontal character = SVR43 [7:0], shadow VGA horizontal retrace become active. SVR44: Shadow VGA Horizontal Retrace End Read/Write Address: 3?5h, Index: 44h Power-on Default: 00h This register shadows VGA CRT Horizontal Retrace End register. 7 6 SVHB 5 4 3 2 1 0 SHADOW VGA HORIZONTAL RETRACE INACTIVE SHRD Bit 7 When the horizontal character = {SVR44 [7], SVR41 [4:0]}, shadow VGA horizontal blank become inactive. (SVHB) Bit 6:5 Shadows horizontal retrace delay (SHRD) Bit 4:0 When the horizontal character = SVR44 [4:0], shadow VGA horizontal retrace become inactive. SVR45: Shadow VGA Vertical Total Read/Write Address: 3?5h, Index: 45h Power-on Default: 00h This register shadows VGA CRT Vertical Total register. 7 6 5 4 3 2 1 0 SHADOW VGA VERTICAL TOTAL Extended SMI Registers 17 - 65 Silicon Motion®, Inc. Bit 7:0 LynxEM+ DataBook Shadows the least significant 8 bits of 11 bits count of raster scan lines for display frame. SVR46: Shadow VGA Vertical Blank Start Read/Write Address: 3?5h, Index: 46h Power-on Default: 00h This register shadows VGA CRT Vertical Blank Start register. 7 6 5 4 3 2 1 0 SHADOW VGA VERTICAL BLANK START Bit 7:0 Shadows the least significant 8-bit of the 11-bit VGA CRT vertical blank start register. SVR47: Shadow VGA Vertical Blank End Read/Write Address: 3?5h, Index: 47h Power-on Default: 00h This register shadows VGA CRT Vertical Blank End register. 7 6 5 4 3 2 1 0 SHADOW VGA VERTICAL BLANK END Bit 7:0 Shadows the least significant 8-bit VGA CRT vertical blank end register. SVR48: Shadow VGA Vertical Retrace Start Read/Write Address: 3?5h, Index: 48h Power-on Default: 00h This register shadows VGA CRT Vertical Retrace Start register. 7 6 5 4 3 2 1 0 SHADOW VGA VERTICAL RETRACE START Bit 7:0 Shadows the least significant 8-bit of the 11-bit vertical retrace start register. SVR49: Shadow VGA Vertical Retrace End Read/Write Address: 3?5h, Index: 49h Power-on Default: 00h This register shadows VGA CRT Vertical Retrace End register. 17 - 66 Extended SMI Registers Silicon Motion®, Inc. 7 LynxEM+ DataBook 6 5 4 3 2 1 0 SHADOW VGA/CRT VERTICAL RETRACE RESERVED Bit 7:4 Reserved Bit 3:0 Shadows bit [3:0] of VGA CRT vertical retrace end register. SVR4A: Shadow VGA Vertical Overflow Read/Write Address: 3?5h, Index: 4Ah Power-on Default: 00h This register shadows VGA CRT Vertical Overflow register. 7 6 5 4 3 2 1 0 SVRS9 SVDE9 SVTB9 R SVBS SVRS8 SVDE8 SVTB8 Bit 7 Shadows vertical retrace start bit 9 (SVRS9) Bit 6 Shadow vertical display enable bit 9 (3?5h, index 7 [6]). When FPR33[5] = 1, can only access this bit through 3?5h, index 4Ah. (SVDE9) Bit 5 Shadows vertical total bit 9 (SVTB9) Bit 4 Reserved (R) Bit 3 Shadows vertical blank start bit 8 (SVBS) Bit 2 Shadows vertical retrace start bit 8 (SVRS8) Bit 1 Shadow vertical display enable bit 8 (3?5h, index 7 [1]). When FPR33[5] = 1, can only access this bit through 3?5h, index 4Ah. (SVDE8) Bit 0 Shadows vertical total bit 8 (SVTB8) SVR4B: Shadow VGA Maximum Scan Line Read/Write Address: 3?5h, Index: 4Bh Power-on Default: 00h This register shadows VGA CRT Maximum Scan Line register. 7 6 SSP 5 SVBS Extended SMI Registers 4 3 2 1 0 RESERVED 17 - 67 Silicon Motion®, Inc. LynxEM+ DataBook Bit 7:6 Shadow 3C2 bit_[7:6] for sync polarity (SSP) Bit 5 Shadows vertical blank start bit 9 (SVBS) Bit 4:0 Reserved SVR4C: Shadow VGA Horizontal Display End Read/Write Address: 3?5h, Index: 4Ch Power-on Default: 00h This register shadows VGA CRT Horizontal Display end. 7 6 5 4 3 2 1 0 SHADOW HORIZONTAL DISPLAY END Bit 7:0 Shadows Horizontal Display End register (3?5h, index 01). When FPR33[5] = 1, it locks access to this register only through 3?5h, index 4Ch. SVR4D: Shadow VGA Vertical Display End Read/Write Address: 3?5h, Index: 4Dh Power-on Default: 00h This register shadows VGA CRT Vertical Display end. 7 6 5 4 3 2 1 0 SHADOW VERTICAL DISPLAY END Bit 7:0 Shadows Vertical Display End register [7:0] (3?5h, index 12) When FPR33[5] = 1, it locks access to this register only through 3?5h, index 4Dh. 17 - 68 Extended SMI Registers Silicon Motion®, Inc. LynxEM+ DataBook Chapter 18: Memory Mapped Registers Table 19: Memory Mapped Registers Quick Reference Summary of Registers Page Drawing Engine Control Registers DPR00: Source Y or K2 18 - 4 DPR02: Source X or K1 18 - 4 DPR04: Destination Y or Start Y 18 - 5 DPR06: Destination X or Start X 18 - 6 DPR08: Dimension Y or Error Term 18 - 6 DPR0A: Dimension X or Vector Length 18 - 7 DPR0C: ROP and Miscellaneous Control 18 - 7 DPR0E: Drawing Engine Commands and Control 18 - 9 DPR10: Source Row Pitch 18 - 10 DPR12: Destination Row Pitch 18 - 11 DPR14: Foreground Colors 18 - 11 DPR18: Background Colors 18 - 12 DPR1C: Stretch Source Height Y 18 - 13 DPR1E: Drawing Engine Data Format and Location Format Select 18 - 13 DPR20: Color Compare 18 - 14 DPR24: Color Compare Masks 18 - 15 DPR28: Bit Mask 18 - 15 DPR2A: Byte Mask Enable 18 - 16 DPR2C: Scissors Left and Control 18 - 16 DPR2E: Scissors Top 18 - 17 DPR30: Scissors Right 18 - 17 DPR32: Scissors Bottom 18 - 17 DPR34: Mono Pattern Low 18 - 18 DPR38: Mono Pattern High 18 - 18 DPR3C: XY Addressing Destination & Source Window Widths 18 - 18 DPR40: Source Base Address 18 - 19 DPR44: Destination Base Address 18 - 19 Memory Mapped Registers 18 - 1 Silicon Motion®, Inc. Summary of Registers (Continued) LynxEM+ DataBook Page Video Processor Control Registers VPR00: Miscellaneous Graphics and Video Control 18 - 20 VPR04: Color Keys 18 - 22 VPR08: Color Key Masks 18 - 23 VPR0C: Data Source Start Address for Extended Graphics Modes 18 - 24 VPR10: Data Source Width and Offset for Extended Graphics Modes 18 - 24 VPR14: Video Window I Left and Top Boundaries 18 - 24 VPR18: Video Window I Right and Bottom Boundaries 18 - 25 VPR1C: Video Window I Source Start Address 18 - 25 VPR20: Video Window I Source Width and Offset 18 - 26 VPR24: Video Window I Stretch Factor: 18 - 26 VPR2C: Video Window II Right and Bottom Boundaries 18 - 27 VPR30: Video Window II Source Start Address 18 - 28 VPR34: Video Window II Source Width and Offset 18 - 28 VPR38: Video Window II Stretch Factor 18 - 29 VPR3C: Graphics and Video Control II 18 - 29 VPR40: Graphic Scale Factor 18 - 30 VPR54: FIFO Priority Control 18 - 31 VPR58: FIFO Empty Request level Control 18 - 33 VPR5C: YUV to RGB Conversion Constant 18 - 34 VPR60: Current Scan Line Position 18 - 34 VPR64: Signature Analyzer Control and Status 18 - 34 VPR68: Video Window I Stretch Factor: 18 - 35 VPR6C: Video Window II Stretch Factor 18 - 36 Capture Processor Control Registers CPR00: Capture Port Control 18 - 36 CPR04: Video Source Clipping Control 18 - 39 CPR08: Video Source Capture Size Control 18 - 39 CPR0C: Capture Port Buffer I Source Start Address 18 - 40 CPR10: Capture Port Buffer II Source Start Address 18 - 40 CPR14: Capture Port Source Offset Address 18 - 40 CPR18: Capture FIFO Empty Request level Control 18 - 41 18 - 2 Memory Mapped Registers Silicon Motion®, Inc. LynxEM+ DataBook The drawing processor and video processor registers are all memory mapped. The following diagram illustrates the memory mapped register address assignment. 1. Drawing Processor Data Register The drawing processor data port for HOSTBLT is a memory-mapped and is located at DP_Port = PCI graphics base address + 4MB + 0KB. 2. Drawing Processor Control Registers Drawing Processor Control Registers are memory-mapped. The drawing processor control registers address start at DP_Base = PCI graphics base address + 4MB+32K. 3. Video Processor Control Registers Video Processor Control Registers are memory-mapped. The video processor control registers address start at VP_Base = PCI VGA graphics base address + 4MB + 48K. 4. Capture Processor Control Registers Capture Processor Control Registers are memory-mapped. The capture processor control registers address start at CP_Base = PCI VGA graphics base address + 4MB + 56K. PCI graphics base address 0 MB Display Memory DP_Port 4 MB Drawing Processor Data 64K DP_Base VP_Base CP_Base Drawing Processor Reg Video Processor Reg Capture Reg Processor Additional DP Data Port 4 MB + 32KB 4 MB + 48KB 4 MB + 56KB 4 MB + 64KB > anything in between = memory hole 5 MB 7 MB 7 MB 8 MB Memory Map IO Port Figure 28: Memory Mapped Address Diagram Memory Mapped Registers 18 - 3 Silicon Motion®, Inc. LynxEM+ DataBook Drawing Engine Control Registers The Drawing Engine supports various drawing functions, including Bresenham line draw (8-bit and 16-bit only), short stroke line draw, BITBLT, rectangle fill (8-bit and 16-bit only), HOSTBLT, Rotation Blit, and others. Hardware clipping is supported by 4 registers, DPR2C-DPR32, which defines a rectangular clipping area. The drawing engine supports two types of format for its source and destination locations. One can specify location format in X-Y coordinate, where the upper left corner of the screen is defined to be (0,0); this method is referred as X-Y addressing. Also, one can specify the location format based on its position in the display memory sequentially from the first pixel of the visible data; this method is referred as DE linear addressing. To select DE linear addressing, one must set DPR1E bit [3:0] = 11xx. All Drawing Engine control registers can be accessed via memory-mapped. The address is at DP_Base + XXXh; where DP_Base is at PCI graphics base address + 4MB + 32K. DPR00: Source Y or K2 Read/Write Address: DP_Base+00h Power-on Default: Undefined This register specifies the 12-bit Source Y position in x-y addressing mode, or low-order source address in DE linear addressing mode (when DPR1E bit [3:0] = 11xxb). This register is also used to specify the 14-bit for K2 constant of Bresenham line when DPR0E bit [3:0] = 0111b to select Bresenham line command function. 15 14 13 12 11 10 9 8 RESERVED 7 6 5 4 3 2 1 0 SOURCE Y FOR X-Y ADDRESSING Bit 15:12 Reserved Bit 11:0 Source Y for X-Y addressing. In 24-bit packed modes, Source Y needs to be multiplied by 3. OR High-order source address SA[23:12] for DE linear addressing. Low-order 12-bit are in DPR02. Bresenham Line (DPR0E bit [3:0] = 0111b) 15 14 13 12 11 10 RESERVED 9 8 7 6 5 4 3 2 1 0 AXIAL DIAGONAL CONSTANT (K2) Bit 15:14 Reserved Bit 13:0 Axial Diagonal Constant (K2) = 2 * (min(|dx|,|dy|) - max(|dx|,|dy|)) DPR02: Source X or K1 Read/Write Address: DP_Base+02h Power-on Default: Undefined This register specifies the 12-bit Source X position in x-y addressing mode, or low-order source address in linear addressing mode (when DPR1E bit [3:0] = 11xxb). This register is also used to specify the 14-bit for K1 constant of 18 - 4 Memory Mapped Registers Silicon Motion®, Inc. LynxEM+ DataBook Bresenham line when DPR0E bit [3:0] = 0111b to select Bresenham line command function. For HOSTBLT write command function (when DPR0E bit [3:0] = 1000b), this register is also used to specify the 3-bit HOST mono source for alignment. 15 14 13 12 11 10 9 8 RESERVED 7 6 5 4 3 2 1 0 SOURCE X FOR X-Y ADDRESSING Bit 15:12 Reserved Bit 11:0 Source X for X-Y addressing mode. In 24-bit packed modes, Source X needs to be multiplied by 3. OR Low-order source address SA [11:0] for DE linear addressing mode. Higher order 12-bit are in DPR00. Note: For 24-bit color pattern, Xs = (PatXs * 3) LOGIC_OR (Yd[2:0] *3, shift 3 bits to left) For 32-bit color pattern, Xs = (PatXs) LOGIC_OR (Yd[2:0], shift 3 bits to left) Bresenham Line (DPR0E bit [3:0] = 0111b) 15 14 13 12 11 10 9 RESERVED 8 7 6 5 4 3 2 1 0 4 3 2 1 0 AXIAL STEP CONSTANT K1 Bit 15:14 Reserved Bit 13:0 Axial Step Constant (K1) = 2 * min (|dx|, |dy|) HOSTBLT Write (DPR0E bit [3:0] = 1000b) 15 14 13 12 11 10 9 8 7 6 5 RESERVED HMSA Bit 15:3 Reserved Bit 2:0 Host mono source alignment for 8, 16, or 32-bit color modes. For 24-bit color mode, software needs to adjust for alignment. (HMSA) DPR04: Destination Y or Start Y Read/Write Address: DP_Base+04h Power-on Default: Undefined This register specifies the 12-bit Destination Y position in x-y addressing mode or higher-order destination address for DE linear addressing mode (when DPR1E bit [3:0] = 11xxb). This register is also used to specify Vector Y start address for Bresenham Line when DPR0E bit [3:0] = 0111b to select Bresenham line command function. 15 14 13 12 RESERVED Memory Mapped Registers 11 10 9 8 7 6 5 4 3 2 1 0 DESTINATION Y OR START Y 18 - 5 Silicon Motion®, Inc. Bit 15:12 LynxEM+ DataBook Reserved Bit 13:0 Bresenham Line (DPR0E bit [3:0] = 0111b Vector Y start address Destination Y for X-Y addressing. In 24-bit packed modes, Destination Y needs to be multiplied by 3. OR High-order 12 bits destination address DA[23:12] for DE linear addressing. DPR06: Destination X or Start X Read/Write Address: DP_Base+06h Power-on Default: Undefined This register specifies 12-bit Destination X position in x-y addressing mode or low-order 12-bit destination address in DE linear addressing mode (when DPR1E bit [3:0] = 11xxb). This register is also used to specify Vector X start address for Bresenham Line when DPR0E bit [3:0] = 0111b to select Bresenham line command function. 15 14 13 12 11 10 9 8 RESERVED 7 6 5 4 3 2 1 0 DESTINATION X OR START X Bit 15:12 Reserved Bit 11:0 Destination X for X-Y addressing. In 24-bit packed modes, Destination X needs to be multiplied by 3. OR Low-order 12 bits destination address DA[11:0] for DE linear addressing. Bresenham Line (DPR0E bit [3:0] = 0111b Vector X start address DPR08: Dimension Y or Error Term Read/Write Address: DP_Base+08h Power-on Default: Undefined This register specifies the rectangle height or Dimension Y in pixels. When Bresenham line command function is selected (DPR0E bit [3:0] = 0111b), this register specifies the Vector Error Term. When Short Stroke Line command function is selected (DPR0E bit [3:0] = 0110b), this register specifies the short stroke line length for non-horizontal short stroke line 15 14 13 12 11 RESERVED 10 9 8 7 6 5 4 2 1 0 DIMENSION Y OR ERROR TERM Short Stroke (DPR0E bit [3:0] = 0110b) Bresenham Line (DPR0E bit [3:0] = 0111b) Bit 15:14 Reserved Reserved Reserved Bit 13:12 Reserved Reserved Vector Error Term 18 - 6 3 Memory Mapped Registers Silicon Motion®, Inc. Bit 11:0 LynxEM+ DataBook Dimension Y Short Stroke (DPR0E bit [3:0] = 0110b) Bresenham Line (DPR0E bit [3:0] = 0111b) Short Stroke Length if not a horizontal line (≠ 0° or ≠ 180°) (ET)* * Vector Error Term is determined based on the following logic: ET = 2 * min (|dx|,|dy|) - max (|dx|,|dy|) if starting X > ending X ET = 2 * min (|dx|,|dy|) - max (|dx|,|dy|) -1 if starting X
SM712GX04LF04-BA 价格&库存
很抱歉,暂时无法提供与“SM712GX04LF04-BA”相匹配的价格&库存,您可以联系我们找货
SM712GX04LF04-BA
    • 1+379.76040
    • 200+151.52400
    • 500+146.46960
    • 1000+143.96400
