HVCB2512JDL33M0
HVCB2512JDL33M0
    SEI
    贴片电阻 2512 33mΩ ±5% 2W ±200ppm/℃
HVCB2512JDL33M0 数据手册
HVC Series Stackpole Electronics, Inc. High Voltage Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • • • • • • • • • • Ohmic values to 50G Available with wire bondable terminations Tight tolerances to 0.1% Utilizes fine film resistor deposition technology Superior pulse handling capabilities Low TCR to 25 ppm/ºC Low VCR to 1 ppm/volt Very low noise Ultra-high stability Custom sizes available Higher (up to 1TΩ) or lower resistance values may be available (contact Stackpole) Standard HVC parts are unmarked 100% RoHS compliant, lead free without exemption and halogen free REACH compliant Electrical Specifications Type / Code Power Rating (W) @ 70ºC Maximum Working Voltage (V) Ohmic Range (Ω) and Tolerance TCR (ppm/ºC) (1) 0.1% 0.25% 0.5% 1% 2% 5% 10% 20% ±50 10K - 100M 10K - 500M HVC0603 0.06 400 ±100 10K - 10M 10K - 1G 10K - 500M 10K - 1G ±200 10K - 10G 10K - 50G ±50 10K - 500M HVC0805 0.2 600 ±100 10K - 10M 10K - 1G 10K - 1G ±200 10K - 10G 10K - 50G ±25 1M - 100M 1M - 100M ±50 100K - 100M 100K - 100M 100K - 500M HVC1206 0.33 1500 ±100 10K - 1G 10K - 100M 10K - 100M 10K - 500M 10K - 1G ±200 10K - 10G 10K - 50G ±25 1M - 100M 1M - 100M ±50 100K - 100M 100K - 100M 100K - 500M HVC2010 1 2000 ±100 10K - 1G 10K - 100M 10K - 100M 10K - 500M 10K - 1G ±200 10K - 10G 10K - 50G ±25 1M - 100M 1M - 500M ±50 100K - 100M 100K - 500M 100K - 1G HVC2512 2 3000 ±100 100K - 10G 10K - 100M 10K - 500M 10K - 1G 10K - 10G ±200 100K - 50G ±25 1M - 100M 1M - 500M ±50 100K - 100M 100K - 500M 100K - 1G HVC3512 3 3500 ±100 100K - 10G 10K - 100M 10K - 500M 10K - 1G 10K - 10G ±200 100K - 50G Proper terminal isolation is required to achieve the voltage ratings for each given size. (1) The continuous maximum voltage applied cannot exceed the maximum power rating and is ohmic value dependent. Note: Other case sizes and tolerances are available. Mechanical Specifications Type / Code HVC0603 HVC0805 HVC1206 L Body Length 0.063 ± 0.01 1.60 ± 0.25 0.079 ± 0.01 2.01 ± 0.25 0.126 ± 0.01 3.20 ± 0.25 W Body Width 0.031 ± 0.005 0.79 ± 0.13 0.050 ± 0.005 1.27 ± 0.13 0.063 ± 0.005 1.60 ± 0.13 Rev Date: 11/18/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. H Body Height (Max.) 0.020 0.51 0.025 0.64 0.030 0.76 1 a Top Termination 0.010 ± 0.005 0.25 ± 0.13 0.010 ± 0.005 0.25 ± 0.13 0.010 ± 0.005 0.25 ± 0.13 b Bottom Termination 0.012 ± 0.008 0.30 ± 0.20 0.013 ± 0.008 0.33 ± 0.20 0.020 ± 0.010 0.51 ± 0.25 Unit inches mm inches mm inches mm www.seielect.com marketing@seielect.com HVC Series Stackpole Electronics, Inc. High Voltage Thick Film Chip Resistor Resistive Product Solutions Mechanical Specifications (cont.) L Body Length 0.200 ± 0.01 5.08 ± 0.25 0.250 ± 0.01 6.35 ± 0.25 0.350 ± 0.01 8.89 ± 0.25 Type / Code HVC2010 HVC2512 HVC3512 W Body Width 0.100 ± 0.005 2.54 ± 0.13 0.125 ± 0.005 3.18 ± 0.13 0.125 ± 0.005 3.18 ± 0.13 H Body Height (Max.) 0.030 0.76 0.030 0.76 0.030 0.76 a Top Termination 0.018 ± 0.010 0.46 ± 0.25 0.020 ± 0.010 0.51 ± 0.25 0.020 ± 0.010 0.51 ± 0.25 b Bottom Termination 0.020 ± 0.010 0.51 ± 0.25 0.024 ± 0.010 0.61 ± 0.25 0.024 ± 0.010 0.61 ± 0.25 Unit inches mm inches mm inches mm Performance Characteristics Test Typical Performance Short Time Overload Load Life Temperature Cycle Moisture Resistance Shock Vibration Dielectric Withstanding Voltage Resistance to Soldering Heat Parameter 0.1% 0.1% 0.1% 0.1% 0.05% 0.05% 0.05% 0.05% Typical TCR measured from 25°C to 75°C 10X rated wattage Consult Stackpole for custom pulse applications Measured at 100V Consult Stackpole for custom test voltages Pulse Capability Resistance Value Operating temperature range is -55ºC to +150ºC Power Derating Curve: Percent Rated Power (%) 100 -55ºC 70ºC 80 60 40 20 0 -60 150ºC 0 20 40 60 80 100 120 Ambient Temperature (ºC) 140 160 180 Recommended Pad Layouts Type / Code HVC0603 HVC0805 A 0.031 0.80 0.047 1.20 Rev Date: 11/18/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. B 0.083 2.10 0.118 3.00 2 C 0.035 0.90 0.051 1.30 Unit inches mm inches mm www.seielect.com marketing@seielect.com HVC Series Stackpole Electronics, Inc. High Voltage Thick Film Chip Resistor Resistive Product Solutions Recommended Pad Layouts (cont.) Type / Code HVC1206 HVC2010 HVC2512 A B C Unit 0.087 2.20 0.138 3.50 0.150 3.80 0.165 4.20 0.240 6.10 0.315 8.00 0.063 1.60 0.110 2.80 0.138 3.50 inches mm inches mm inches mm Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 11/18/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com HVC Series Stackpole Electronics, Inc. High Voltage Thick Film Chip Resistor Resistive Product Solutions Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type High Voltage Thick Film SMD Surface Mount Chip Resistor Note (1): RoHS Compliant by means of exemption 7c-I. HVC Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) YES(1) 100% Matte Sn ("T") Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 11/18/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com HVC Series Stackpole Electronics, Inc. High Voltage Thick Film Chip Resistor Resistive Product Solutions Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order Code HVCB HVCG HVCS HVCZ 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 H V C B 2 5 1 2 F K C 1 0 M 0 Product Series Description Solderable wraparound (100% matte tin) Wire bondable (gold) Solderable single surface (Sn/Pb) Solderable single surface (100% matte tin) Size Code W 0603 0.06 0805 0.2 1206 0.33 2010 1 2512 2 3512 3 Tolerance Code Tol B 0.1% C 0.25% D 0.5% F 1% G 2% J 5% K 10% M 20% Packaging Code 7" Reel - Paper Tape T 7" Reel - Plastic Tape K D B Rev Date: 11/18/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Description 7" Reel - Paper Tape 7" Reel - Plastic Tape 7" Reel - Paper Tape 7" Reel - Plastic Tape Bulk 5 TCR Size Quantity Code ppm 0603, 0805 5000 E 25 1206 4000 C 50 2010 4000 D 100 2512 2000 L 200 0603, 0805, 1206 1000 M 300 2010, 2512, 3512 1000 0603, 0805, 1206 500 2010, 2512, 3512 500 All Sizes 1000 Resistance Value Four characters with the multiplier used as the decimal holder. 10 Kohm = 10K0 1 Mohm = 1M00 10 Gohm = 10G0 www.seielect.com marketing@seielect.com
HVCB2512JDL33M0
物料型号:HVC系列
器件简介:HVC系列是高压厚膜芯片电阻器,提供多种特性,包括高达50G的欧姆值,可焊线端子,紧密的公差到0.1%,使用薄膜电阻沉积技术,具有优越的脉冲处理能力,低温度系数(TCR)到25ppm/℃,低电压系数(VCR)到1ppm/伏特。
引脚分配:文档中未明确列出引脚分配,但提到了需要适当的终端隔离以达到每个尺寸的电压等级。
参数特性:包括功率额定值、最大工作电压、温度系数、欧姆范围和公差、TCR等。
功能详解:电阻器具有非常低的噪音、超高的稳定性,并且可提供定制尺寸。标准HVC部件未标记,完全符合RoHS标准,无铅且无卤素,符合REACH标准。
应用信息:适用于需要高电压和稳定性的应用场合。
封装信息:提供了不同尺寸的机械规格,包括0603、0805、1206、2010、2512和3512等尺寸的详细尺寸数据。
HVCB2512JDL33M0 价格&库存
很抱歉,暂时无法提供与“HVCB2512JDL33M0”相匹配的价格&库存,您可以联系我们找货
HVCB2512JDL33M0
  • 500+19.92237500+2.57495
  • 1000+19.469231000+2.51639
  • 1500+19.248211500+2.48782
  • 2500+19.008402500+2.45682
  • 3500+18.871023500+2.43907
  • 5000+18.741095000+2.42227
库存:500
HVCB2512JDL33M0
    HVCB2512JDL33M0
    • 1+34.890071+4.50952
    • 10+25.4217310+3.28574
    • 25+23.6204825+3.05293
    • 50+22.4384650+2.90016
    • 100+21.47193100+2.77523
    • 250+20.49088250+2.64843
    库存:500
