Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
74CBTLV3384
10-bit bus switch with 5-bit output enables
Rev. 3 — 11 November 2016
Product data sheet
1. General description
The 74CBTLV3384 is a dual 5-pole, single-throw bus switch. The device features two
output enable inputs (nOE) that each control five switch channels. The switches are
disabled when the associated nOE input is HIGH. Schmitt-trigger action at control inputs
makes the circuit tolerant of slower input rise and fall times. This device is fully specified
for partial power-down applications using IOFF. The IOFF circuitry disables the output,
preventing the damaging backflow current through the device when it is powered down.
2. Features and benefits
Supply voltage range from 2.3 V to 3.6 V
High noise immunity
Complies with JEDEC standard:
JESD8-5 (2.3 V to 2.7 V)
JESD8-B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
CDM AEC-Q100-011 revision B exceeds 1000 V
5 switch connection between two ports
Rail to rail switching on data I/O ports
CMOS low power consumption
Latch-up performance exceeds 250 mA per JESD78B Class I level A
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74CBTLV3384
NXP Semiconductors
3. Ordering information
Table 1.
Type number
Package
Temperature
range
74CBTLV3384DK
Name
40 C to +125 C SSOP24[1]
74CBTLV3384PW 40 C to +125 C TSSOP24
74CBTLV3384BQ
[1]
40 C to +125 C DHVQFN24
Description
Version
plastic shrink small outline package; 24 leads;
body width 3.9 mm; lead pitch 0.635 mm
SOT556-1
plastic thin shrink small outline package; 24 leads;
body width 4.4 mm
SOT355-1
plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 24 terminals;
body 3.5 5.5 0.85 mm
SOT815-1
Also known as QSOP24 package
4. Functional diagram
2(
2(
DDP
Fig 1.
Logic symbol
Q$Q
Q%Q
Q2(
DDL
Fig 2.
Logic diagram (one switch)
74CBTLV3384
Product data sheet
All information provided in this document is subject to legal disclaimers.
© NXP Semiconductors N.V. 2016. All rights reserved.
2 of 19
74CBTLV3384
NXP Semiconductors
5. Pinning information
5.1 Pinning
&%7/9
&%7/9
2(
9&&
2(
9&&
*1'
2(
*1'
2(
DDP
DDP
Fig 3.
Pin configuration for TSSOP24 (SOT355-1)
Fig 4.
Pin configuration for SSOP24 (SOT556-1)
WHUPLQDO
LQGH[DUHD
9&&
2(
&%7/9
*1'
2(
*1'
DDP
7UDQVSDUHQWWRSYLHZ
(1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or
mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to
GND.
Fig 5.
Pin configuration for DHVQFN24 (SOT815-1)
74CBTLV3384
Product data sheet
3 of 19
74CBTLV3384
NXP Semiconductors
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1OE, 2OE
1, 13
output enable input (active LOW)
1A1 to 1A5
3, 4, 7, 8, 11
data input/output (A port)
2A1 to 2A5
14, 17, 18, 21, 22
1B1 to 1B5
2, 5, 6, 9, 10
data input/output (B port)
2B1 to 2B5
15, 16, 19, 20, 23
GND
12
ground (0 V)
VCC
24
positive supply voltage
6. Functional description
Table 3.
Function selection[1]
Input
Input/output
1OE
2OE
1An, 1Bn
2An, 2Bn
L
L
1An = 1Bn
2An = 2Bn
L
H
1An = 1Bn
Z
H
L
Z
2An = 2Bn
H
H
Z
Z
[1]
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+4.6
V
[1]
0.5
+4.6
V
[1]
0.5
VCC + 0.5
V
VI
input voltage
VSW
switch voltage
enable and disable mode
IIK
input clamping current
VI < 0.5 V
50
mA
ISK
switch clamping current
VI < 0.5 V
50
mA
VSW = 0 V to VCC
ISW
switch current
128
mA
ICC
supply current
+100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
500
mW
total power dissipation
Ptot
[1]
[2]
Tamb = 40 C to +125 C
[2]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SSOP24 and TSSOP24 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
For DHVQFN24 package: Ptot derates linearly at 4.5 mW/K above 60 C.
74CBTLV3384
Product data sheet
4 of 19
74CBTLV3384
NXP Semiconductors
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VSW
switch voltage
Tamb
ambient temperature
t/V
[1]
Conditions
Min
Max
Unit
2.3
3.6
V
V
input transition rise and fall rate
VCC
V
40
+125
C
200
ns/V
[1]
VCC = 2.3 V to 3.6 V
Applies to control signal levels.
9. Static characteristics
Table 6.
At recommended operating conditions voltages are referenced to GND (ground = 0 V).
Symbol Parameter
HIGH-level
input voltage
VIH
Tamb = 40 C to +85 C
Conditions
Tamb = 40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
VCC = 2.3 V to 2.7 V
1.7
1.7
V
VCC = 3.0 V to 3.6 V
2.0
2.0
V
0.7
V
VIL
LOW-level input VCC = 2.3 V to 2.7 V
voltage
0.7
0.9
0.9
V
II
input leakage
current
1
A
IS(OFF)
OFF-state
VCC = 3.6 V; see Figure 6
leakage current
1
A
IS(ON)
ON-state
VCC = 3.6 V; see Figure 7
leakage current
1
A
IOFF
power-off
VI or VO = 0 V to 3.6 V;
leakage current VCC = 0 V
10
50
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
VSW = GND or VCC;
VCC = 3.6 V
10
50
A
ICC
additional
supply current
pin nOE; VI = VCC 0.6 V;
VSW = GND or VCC;
VCC = 3.6 V
300
2000
A
CI
input
capacitance
pin nOE; VCC = 3.3 V;
VI = 0 V to 3.3 V
0.9
pF
CS(OFF)
OFF-state
capacitance
VCC = 3.3 V; VI = 0 V to 3.3 V
5.2
pF
CS(ON)
ON-state
capacitance
14.3
pF
pin nOE; VI = GND to VCC;
VCC = 3.6 V
[1]
All typical values are measured at Tamb = 25 C.
[2]
One input at 3 V, other inputs at VCC or GND.
74CBTLV3384
Product data sheet
[2]
5 of 19
74CBTLV3384
NXP Semiconductors
9.1 Test circuits
9&&
9&&
Q2(
9,+
,V
Q%Q
Q$Q
,V
*1'
9O
Q2(
9,/
,V
92
Q$Q
Q%Q
*1'
9O
DDP
DDP
VI = VCC or GND and VO = GND or VCC.
Fig 6.
92
VI = VCC or GND and VO = open circuit.
Test circuit for measuring OFF-state leakage
current (one switch)
Fig 7.
Test circuit for measuring ON-state leakage
9.2 ON resistance
Table 7.
Resistance RON
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8.
Symbol Parameter
RON
Conditions
Unit
Min
Typ[1]
Max
Min
Max
ISW = 64 mA; VI = 0 V
4.2
8.0
15.0
ISW = 24 mA; VI = 0 V
4.2
8.0
15.0
ISW = 15 mA; VI = 1.7 V
8.4
40
60.0
4.0
7.0
11.0
4.0
7.0
11.0
ISW = 15 mA; VI = 2.4 V
6.2
15
25.5
ON resistance VCC = 2.3 V to 2.7 V;
see Figure 9 to Figure 11
[2]
VCC = 3.0 V to 3.6 V;
see Figure 12 to Figure 14
[1]
Typical values are measured at Tamb = 25 C and nominal VCC.
[2]
Measured by the voltage drop between the A and B terminals at the indicated current through the switch. ON-state resistance is
determined by the lower of the voltages of the two (A or B) terminals.
74CBTLV3384
Product data sheet
6 of 19
74CBTLV3384
NXP Semiconductors
9.3 ON resistance test circuit and graphs
DDL
521
ȍ
96:
9
9&&
Q2(
9,/
Q$Q
Q%Q
*1'
9O
,6:
9,9
DDP
(1) Tamb = 125 C.
RON = VSW / ISW.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
Fig 8.
Test circuit for measuring ON resistance
(one switch)
DDL
521
ȍ
Fig 9.
ON resistance as a function of input voltage;
VCC = 2.5 V; ISW = 15 mA
DDL
521
ȍ
9,9
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(3) Tamb = 25 C.
Product data sheet
(4) Tamb = 40 C.
Fig 10. ON resistance as a function of input voltage;
VCC = 2.5 V; ISW = 24 mA
74CBTLV3384
9,9
(1) Tamb = 125 C.
(4) Tamb = 40 C.
Fig 11. ON resistance as a function of input voltage;
VCC = 2.5 V; ISW = 64 mA
7 of 19
74CBTLV3384
NXP Semiconductors
DDL
DDL
521
ȍ
521
ȍ
9,9
9,9
(1) Tamb = 125 C.
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
(4) Tamb = 40 C.
Fig 12. ON resistance as a function of input voltage;
VCC = 3.3 V; ISW = 15 mA
Fig 13. ON resistance as a function of input voltage;
VCC = 3.3 V; ISW = 24 mA
DDL
521
ȍ
9,9
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
Fig 14. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 64 mA
74CBTLV3384
Product data sheet
8 of 19
74CBTLV3384
NXP Semiconductors
10. Dynamic characteristics
Table 8.
GND = 0 V; for test circuit see Figure 17
Symbol Parameter
Tamb = 40 C to +85 C Tamb = 40 C to +125 C Unit
Conditions
Min
Typ[1]
Max
Min
Max
0.13
0.20
ns
0.20
0.31
ns
1.0
3.0
5.0
1.0
7.0
ns
1.0
2.6
4.3
1.0
6.0
ns
1.0
2.6
5.5
1.0
7.5
ns
1.0
3.2
5.5
1.0
7.5
ns
[2][3]
propagation delay nAn to nBn or nBn to
nAn; see Figure 15
tpd
enable time
ten
[4]
nOE to nAn or nBn;
see Figure 16
disable time
tdis
[5]
nOE to nAn or nBn;
see Figure 16
[1]
All typical values are measured at Tamb = 25 C and at nominal VCC.
[2]
The propagation delay is the calculated RC time constant of the typical on-state resistance of the switch and the load capacitance, when
driven by an ideal voltage source (zero output impedance).
[3]
tpd is the same as tPLH and tPHL.
[4]
ten is the same as tPZH and tPZL.
[5]
tdis is the same as tPHZ and tPLZ.
11. Waveforms
9,
LQSXW
90
90
9
W3+/
W3/+
92+
RXWSXW
90
90
92/
DDL
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig 15. The data input (nAn, nBn) to output (nBn, nAn) propagation delay times
Table 9.
Measurement points
Supply voltage
Input
Output
VCC
VM
VI
tr = tf
VM
VX
VY
2.3 V to 2.7 V
0.5VCC
VCC
2.0 ns
0.5VCC
VOL + 0.15 V
VOH 0.15 V
3.0 V to 3.6 V
0.5VCC
VCC
2.0 ns
0.5VCC
VOL + 0.3 V
VOH 0.3 V
74CBTLV3384
Product data sheet
9 of 19
74CBTLV3384
NXP Semiconductors
9,
90
Q2(LQSXW
90
*1'
W3/=
RXWSXW
/2:WR2))
2))WR/2:
W3=/
9&&
90
9;
92/
W3+=
92+
W3=+
9<
RXWSXW
+,*+WR2))
2))WR+,*+
90
*1'
RXWSXWV
HQDEOHG
RXWSXWV
GLVDEOHG
RXWSXWV
HQDEOHG
DDQ
Fig 16. Enable and disable times
74CBTLV3384
Product data sheet
10 of 19
74CBTLV3384
NXP Semiconductors
W:
9,
QHJDWLYH
SXOVH
90
90
9
WI
WU
WU
WI
9,
SRVLWLYH
SXOVH
90
90
9
W:
9(;7
9&&
9,
5/
92
'87
57
5/
DDH
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 17. Test circuit for measuring switching times
Table 10.
Test data
Supply voltage
Load
VCC
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
2.3 V to 2.7 V
30 pF
500
open
GND
2VCC
3.0 V to 3.6 V
50 pF
500
open
GND
2VCC
74CBTLV3384
Product data sheet
VEXT
11 of 19
74CBTLV3384
NXP Semiconductors
11.1 Additional dynamic characteristics
Table 11. Additional dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); VI = GND or VCC (unless otherwise
specified); tr = tf 2.5 ns.
Symbol Parameter
f(3dB)
[1]
Tamb = 25 C
Conditions
3 dB frequency response VCC = 3.3 V; RL = 50 ; see Figure 18
[1]
Unit
Min
Typ
Max
406
MHz
fi is biased at 0.5VCC.
11.2 Test circuits
9&&
9&&
Q2(
9,/
5/
Q%Q
IL
Q$Q
*1'
G%
DDD
nOE connected to GND; Adjust fi voltage to obtain 0 dBm level at output. Increase fi frequency until dB meter reads 3 dB.
Fig 18. Test circuit for measuring the frequency response when channel is in ON-state
74CBTLV3384
Product data sheet
12 of 19
74CBTLV3384
NXP Semiconductors
12. Package outline
6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPPOHDGSLWFKPP
627
F
Y 0 $
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
',0(16,216PLOOLPHWUHGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOLQFKGLPHQVLRQV
81,7
PD[
ES
F
H
/S
Y
Z
ș
PP
R
R
R
R
LQFKHV
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
02
(8523($1
352-(&7,21
,668('$7(
Fig 19. Package outline SOT556-1 (SSOP24)
74CBTLV3384
Product data sheet
13 of 19
74CBTLV3384
NXP Semiconductors
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
ES
H
GHWDLO;
Z 0
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
02
(8523($1
352-(&7,21
,668('$7(
Fig 20. Package outline SOT355-1 (TSSOP24)
74CBTLV3384
Product data sheet
14 of 19
74CBTLV3384
NXP Semiconductors
'+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJH
QROHDGVWHUPLQDOVERG\[[PP
627
F
GHWDLO;
WHUPLQDO
LQGH[DUHD
H
WHUPLQDO
LQGH[DUHD
H
Y 0 & $ %
Z 0 &
E
H
(K
'K
PP
VFDOH
81,7
PD[
E
F
' K
( K
H
H
H
Y
Z
PP
1RWH
5()(5(1&(6
287/,1(
9(56,21
-(,7$
627
(8523($1
352-(&7,21
,668('$7(
Fig 21. Package outline SOT815-1 (DHVQFN24)
74CBTLV3384
Product data sheet
15 of 19
74CBTLV3384
NXP Semiconductors
13. Abbreviations
Table 12.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 13.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74CBTLV3384 v.3
20161111
Product data sheet
74CBTLV3384 v.2
74CBTLV3384 v.1
Modifications:
74CBTLV3384 v.2
Modifications:
74CBTLV3384 v.1
74CBTLV3384
Product data sheet
Section 11.1 and Section 11.2 added.
20111216
Product data sheet
Legal pages updated.
20101230
Product data sheet
16 of 19
74CBTLV3384
NXP Semiconductors
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, NXP Semiconductors does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. NXP Semiconductors takes no
responsibility for the content in this document if provided by an information
source outside of NXP Semiconductors.
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74CBTLV3384
Product data sheet
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors and its suppliers accept no liability for
inclusion and/or use of NXP Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using NXP Semiconductors products, and NXP Semiconductors
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the NXP
Semiconductors product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
17 of 19
74CBTLV3384
NXP Semiconductors
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific NXP Semiconductors product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. NXP
Semiconductors accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without NXP Semiconductors’ warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
NXP Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies NXP Semiconductors for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond NXP Semiconductors’
standard warranty and NXP Semiconductors’ product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
74CBTLV3384
Product data sheet
18 of 19
NXP Semiconductors
74CBTLV3384
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
9.1
9.2
9.3
10
11
11.1
11.2
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Test circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
ON resistance . . . . . . . . . . . . . . . . . . . . . . . . . . 6
ON resistance test circuit and graphs. . . . . . . . 7
Dynamic characteristics . . . . . . . . . . . . . . . . . . 9
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Additional dynamic characteristics . . . . . . . . 12
Test circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16
Legal information. . . . . . . . . . . . . . . . . . . . . . . 17
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Contact information. . . . . . . . . . . . . . . . . . . . . 18
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
Date of release: 11 November 2016
Document identifier: 74CBTLV3384
