LCR1206-R150JT
LCR1206-R150JT
    VENKEL
    贴片电阻 1206 150mΩ ±5% 1/2W ±200ppm/℃
LCR1206-R150JT 数据手册
LCR SERIES CURRENT SENSE LOW VALUE RESISTORS FEATURES: • TCR as low as ±100ppm • Low resistance for current sense resistors • Resistance Range: 10mΩ to 900mΩ PART NUMBER STRUCTURE LCR 0805 ☐ Series Size 0402 0603 0805 1206 1210 2010 2512 - Power Rating Leave blank for standard power rating. Insert "-1W" for 2512 1W. R022 J T ☐ Resistance R022=22mΩ R033=33mΩ R120=120mΩ Tolerance F = ± 1% G = ± 2% J = ±5% Packaging T = Tape & Reel Optional Reel Identifier Leave blank if standard reel size. Add "-13" if 13" Reel is required Example P/N: LCR0805-R022JT Standard Termination is 100% matte Tin over Nickel. DIMENSIONS Unit: inches (mm) L C1 C1 w C1 C1 T C2 C2 SIZE L W T C1 C2 0402 0.040 ± 0.002 (1.0 ± 0.05) 0.020 ± 0.001 (0.5 ± 0.02) 0.014 ± 0.002 (0.35 ± .05) 0.010 ± 0.004 (0.25 ± 0.1) 0.008 ± 0.004 (0.20 ± 0.1) 0603 0.063 ± 0.004 (1.6 ± 0.1) 0.031 ± 0.004 (0.8 ± 0.1) 0.018 ± 0.004 (0.45 ± 0.1) 0.012 ± 0.008 (0.30 ± 0.20) 0.012 ± 0.008 (0.30 ± 0.20) 0805 0.079 ± 0.006 (2.0 ± 0.15) 0.050 ± 0.006 (1.25 ± 0.15) 0.018 ± 0.006 (0.45 ± 0.15) 0.012 ± 0.008 (0.30 ± 0.20) 0.016 ± 0.01 (0.40 ± 0.25) 1206 0.126 ± 0.006 (3.2 ± 0.15) 0.063 ± 0.006 (1.6 ± 0.15) 0.022 ± 0.006 (0.56 ± 0.15) 0.020 ± 0.012 (0.50 ± 0.30) 0.016 ± 0.01 (0.40 ± 0.25) 1210 0.126 ± 0.006 (3.2 ± 0.15) 0.098 ± 0.006 (2.50 ± 0.15) 0.022 ± 0.006 (0.56 ± 0.15) 0.020 ± 0.012 (0.50 ± 0.30 0.020 ± 0.012 (0.50 ± 0.30) 2010 0.197 ± 0.006 (5.0 ± 0.15) 0.098 ± 0.006 (2.50 ± 0.15) 0.022 ± 0.006 (0.56 ± 0.15) 0.020 ± 0.014 (0.60 ± 0.35) 0.020 ± 0.012 (0.50 ± 0.30) 2512 (10-100mΩ) 0.248 ± 0.006 (6.3 ± 0.15) 0.126 ± 0.006 (3.2 ± 0.15) 0.029 ± 0.004 (0.74 ± 0.10) 0.024 ± 0.014 (0.60 ± 0.35) 0.0217 ± 0.01 (0.55 ± 0.25) 2512 (110-900mΩ) 0.248 ± 0.006 (6.3 ± 0.15) 0.126 ± 0.006 (3.2 ± 0.15) 0.029 ± 0.004 (0.74 ± 0.10) 0.024 ± 0.014 (0.60 ± 0.35) 0.106 ± 0.004 (2.10 ± 0.10) STRUCTURE 3 5 8 Alumina Substrate 6 Tin Plating 2 Backside Electrode 7 Primary Coating 3 Topside Electrode 8 Secondary Layer 4 Edge Electrode 9 Resistive layer 5 Nickel Plating 10 Marking 4 1 7 1 6 9 2 1 Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 09/2020-A 1 LCR SERIES CURRENT SENSE LOW VALUE RESISTORS ELECTRICAL SPECIFICATION & RANGE SIZE 0402 0603 0805 1206 1210 2010 2512 2512 Power Rating at 70°C (W) 0.125W (1/8W) 0.125W (1/8W) 0.25W (1/4W) 0.50W (1/2W) 0.75W (3/4W) 1W 1W 2W Max. Working Voltage √PR or 50V whichever is less √PR or 50V whichever is less √PR or 150V whichever is less √PR or 200V whichever is less √PR or 200V whichever is less √PR or 200V whichever is less √PR or 200V whichever is less √PR or 200V whichever is less Dielectric Withstanding Voltage 100V 100V 500V 500V 500V 500V 500V 500V Rated Current Range (A) 0.360A - 1.58A 0.360A - 2.50A 0.50A - 3.53A 0.71A - 7.07A 0.91A - 8.66A 0.87A - 8.66A 1.05A - 10A 1.49A - 14.14A Operating Temp. Range -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C TCR Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range ±100ppm 511 - 900mΩ 511 - 900mΩ 511 - 900mΩ 511 - 900mΩ 500 - 900mΩ 511 - 900mΩ 511 - 900mΩ 511 - 900mΩ 51 - 500mΩ Tolerance ±1% (F) ±2% (G) ±5% (J) ±200ppm 102 - 500mΩ 102 - 500mΩ 102 - 500mΩ 51 - 500mΩ 50 - 470mΩ 51 - 500mΩ 51 - 500mΩ ±300ppm 51 - 100mΩ 51 - 100mΩ 51 - 100mΩ 21 - 50mΩ 21 - 50mΩ 21 - 50mΩ 21 - 50mΩ 21 - 50mΩ ±450ppm - 20 - 50mΩ 20 - 50mΩ 10 - 20mΩ 10 - 20mΩ 10 - 20mΩ 10 - 20mΩ 10 - 20mΩ ±100ppm 511 - 900mΩ 511 - 900mΩ 511 - 900mΩ 511 - 900mΩ 500 - 900mΩ 511 - 900mΩ 511 - 900mΩ 511 - 900mΩ 51 - 500mΩ ±200ppm 102 - 500mΩ 102 - 500mΩ 102 - 500mΩ 51 - 500mΩ 50 - 470mΩ 51 - 500mΩ 51 - 500mΩ ±300ppm 51 - 100mΩ 51 - 100mΩ 51 - 100mΩ 21 - 50mΩ 21 - 50mΩ 21 - 50mΩ 21 - 50mΩ 21 - 50mΩ ±450ppm - 20 - 50mΩ 20 - 50mΩ 10 - 20mΩ 10 - 20mΩ 10 - 20mΩ 10 - 20mΩ 10 - 20mΩ ±100ppm 511 - 900mΩ 511 - 900mΩ 511 - 900mΩ 511 - 900mΩ 500 - 900mΩ 511 - 900mΩ 511 - 900mΩ 511 - 900mΩ 51 - 500mΩ ±200ppm 102 - 500mΩ 102 - 500mΩ 102 - 500mΩ 51 - 500mΩ 50 - 470mΩ 51 - 500mΩ 51 - 500mΩ ±300ppm 51 - 100mΩ 51 - 100mΩ 51 - 100mΩ 21 - 50mΩ 21 - 50mΩ 21 - 50mΩ 21 - 50mΩ 21 - 50mΩ ±450ppm - 20 - 50mΩ 20 - 50mΩ 10 - 20mΩ 10 - 20mΩ 10 - 20mΩ 10 - 20mΩ 10 - 20mΩ STANDARD RESISTANCE VALUES AND CORRESPONDING CODES Note: 0603 size will only be marked for E-24 values and will have a 3 digit marking. Non E-24 and E-96 values will not be marked. Examples: R10 = 100mΩ or 0.100Ω R01 = 10mΩ or 0.010Ω 102 = 102mΩ or 0.102Ω 022 = 22mΩ or 0.022Ω 0402 size cannot be marked. Resistance 10m ohm P/N P/N P/N P/N P/N P/N P/N (Marking) Resistance (Marking) Resistance (Marking) Resistance (Marking) Resistance (Marking) Resistance (Marking) Resistance (Marking) Code Code Code Code Code Code Code R010 27m ohm R027 50m ohm 12m ohm R012 30m ohm R030 56m ohm 15m ohm R015 33m ohm R033 60m ohm R050 80m ohm R080 160m ohm R160 330m ohm R330 600m ohm R600 R056 90m ohm R090 180m ohm R180 360m ohm R360 650m ohm R650 R060 100m ohm R100 200m ohm R200 400m ohm R400 680m ohm R680 R700 18m ohm R018 35m ohm R035 65m ohm R065 110m ohm R110 220m ohm R220 430m ohm R430 700m ohm 20m ohm R020 40m ohm R040 68m ohm R068 120m ohm R120 250m ohm R250 470m ohm R470 750m ohm R750 22m ohm R022 43m ohm R043 70m ohm R070 130m ohm R130 270m ohm R270 500m ohm R500 800m ohm R800 25m ohm R025 47m ohm R047 75m ohm R075 150m ohm R150 300m ohm R300 560m ohm R560 900m ohm R900 Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 09/2020-A 2 LCR SERIES CURRENT SENSE LOW VALUE RESISTORS DERATINGDERATING CURVECURVE (LCR Only) Rated power (%) 120 100 80 60 40 20 0 -50 -25 -55 0 25 50 75 70 100 125 150 175 Ambient temperature (˚C) 0402 to 2512 REEL SPECIFICATIONS F Label Unit: mm (inch) H M C E C E F G H M 13.0 ± 0.2 (0.51 ± 0.008) 60.0 ± 1.0 (2.36 ± 0.03) 11.4 ± 1.0 (0.45 ± 0.04) 9.0 ± .3 (0.35 ± 0.012) 1.5 ± .3 (0.06 ± 0.012) 180 ± 2.0 (7.09 ± 0.08) Minimum of 30 empty pockets at the beginning of reel, 65 minimum empty pockets at the end. G TAPE SPECIFICATIONS T G B A F W T J Dø Embossed H Paper E Units: mm (inches). Tape Paper Size (inches) A B W E F T G H J Dø 0402 1.15 ± 0.1 0.65 ± 0.1 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.45 ± 0.1 2.0 ± 0.05 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 0603 1.9 ± 0.1 1.1 ± 0.1 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.70 ± 0.1 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 0805 2.4 ± 0.1 1.65 ± 0.1 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.85 ± 0.1 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 1206 3.5 ± 0.1 1.9 ± 0.1 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.85 ± 0.1 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 1210 3.5 ± 0.1 2.8 ± 0.1 8.0 ± 0.2 1.75 ± 0.1 3.5 ± 0.05 0.85 ± 0.1 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 2010 5.4 ± 0.2 2.9 ± 0.2 12.0 ± 0.1 1.75 ± 0.1 5.5 ± 0.5 1.00 ± 0.2 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 2512 6.9 ± 0.2 3.6 ± 0.2 12.0 ± 0.1 1.75 ± 0.1 5.5 ± 0.5 1.00 ± 0.2 8.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.5 + 0.1-0 Embossed PEEL BACK FORCE AND DIRECTION DIAGRAM Direction of pull Top cover tape Carrier tape Peel back force and direction of peel back angle should follow EIA481-1-A. Peel back force should be between 0.1N – 1.3N and peel back angle of 165˚ – 180˚. 165 ~ 180˚ Direction of unreeling Bottom cover tape Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 09/2020-A 3 LCR SERIES CURRENT SENSE LOW VALUE RESISTORS ENVIRONMENTAL CHARACTERISTICS TEST REQUIREMENT Temperature Coefficient of Resistance (T.C.R.) TEST METHOD JIS-C-5201-1 4.8 IEC60115-1 4.8 At 25˚C/-55˚C and 25˚C/+125˚C, 25˚C is the reference temperature As Spec. ±(0.5%+0.05Ω) Short Time Overload ±(1.0%+0.05Ω) For High power rating JIS C 5201-1 4.13 IEC 60115-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds CS06 1W: 5*rated power for 5 seconds Insulation Resistance ≥10G JIS-C-5201-1 4.6 IEC-60115-1 4.6 Max. Overload Voltage for 1 minute Endurance ±(1.0%+0.05Ω) JIS-C-5201-1 4.25.1 IEC60115-1 4.25 70±2˚C, rated power for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” ±(0.5%+0.05Ω) Damp Heat with Load 1W : ±(1.0%+0.05Ω) JIS-C-5201-1 4.24 IEC-60115-1 4.24 40±2˚C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” ±(0.5%+0.05Ω) JIS-C-5201-1 4.23.2 IEC60115-1 4.23.2 at +155˚C for 1000 hrs Dry Heat 1W : ±(1.0%+0.05Ω) Bending Strength ±(1.0%+0.05Ω) JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending once for 5 seconds with 3mm 2010, 2512 sizes: 2mm Solderability 95% min. coverage JIS-C-5201-1 4.17 IEC-60115-1 4.17 245±5˚C for 3 seconds ±(0.5%+0.05Ω) JIS-C-5201-1 4.18 IEC-60115-1 4.18 260±5˚C for 10 seconds Resistance to Soldering Heat 1W : ±(1.0%+0.05Ω) Voltage Proof No breakdown or flashover JIS-C-5201-1 4.7 IEC-60115-1 4.7 1.42 times Max. Operating Voltage for 1 minute Leaching Individual leaching area ≤5% Total leaching area ≤10% JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 260±5˚C for 30 seconds ±(0.5%+0.05Ω) Rapid Change of Temperature JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55˚C to +155˚C, 5 cycles 1W : ±(1.0%+0.05Ω) RCWV (Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. Storage Temperature: 15~28°C; Humidity: < 80%RH Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 09/2020-A 4
LCR1206-R150JT 价格&库存
很抱歉,暂时无法提供与“LCR1206-R150JT”相匹配的价格&库存,您可以联系我们找货
