GMC10CG3R0B100NTD
GMC10CG3R0B100NTD
    CAL-CHIP
    贴片电容(MLCC) 0603 3pF ±0.1pF 100V C0G(NP0)
GMC10CG3R0B100NTD 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS - GMC SERIES APPLICATIONS - Can be used on surface mount assembly equipment - Our fully integrated manufacturing and total quality control systems ensure unprecedented high standards of quality and reliability. FEATURES - Large capacitance values in small sizes - Excellent high frequency characteristics CONSTRUCTION Solder plate; 100% matte SN; typical thickness 0.003mm to 0.005mm *(Please see note) CHIP CAPACITOR SELECTION DIELECTRIC TYPE COG (NPO) - Capacitance change with temperature is 0-30ppml°C which is less than -0.3%°C from -55°C to +125°C. Typical capacitance change with life is less than -0.1 % for NPOs, one-fifth that shown by most other dielectrics. NPO formulations show no aging characteristics. Nickel Barrier Layer (50 Micro-Inches Electroplated Nickel Min.) Inner Electrodes Ultra stable class I dielectric: linear temperature coefficient, low loss, negligible change of electrical properties with time, voltage and frequency. -55°C to° +125 C 0±30ppm°C 0±30ppm/°C 0.1% Max, 0.02% Typlical •25°C, VDCW: >100GOFor 1000QF, whichever is less •125°C, Vocw: >10GQF or 100QF whichever is less 3 X VDCW 0% per decade hour • C1000pF f=1KHz V=1.0Vrms ±0.2Vrms T=25°C X7R/X5R - Its temperature variation of capacitance is within ±15% from -55°C to +125°C (-55°C to +85° C for X5R). The capacitance change is non-linear. Stable class II dielectric X7R=-55C to+125C X5R=-55C to+85C ±15% X7R/X5R Not Applicable 2.5% Max, 1.8% Typical • 25°C, VDCW: >100GQFor 1000QF, whichever is less •125°C, Vocw: >10GQF or100QF whichever is less 2.5 X VDCW or = to 10uF 1.0Vrms 120Hz 1 CHIP CAPACITOR SELECTION Z5U - Despite their capacitance instability, ZSU formulations are very popular because of their small size, temperature range low ESL, low ESR and excellent frequency response. These features are particularly important for decoupling application where only a minimum capacitance value is required. Y5V - YSV formulations are for general purpose use in a limited temperature range. They have a wide temperature characteristic of +22% - 82% capacitance change over the operating temperature range of -30°C to +85°C. YSVs high dielectric constant allows the manufacture of very high capacitance values (up to 22MF) in small physical sizes. High capacitance per unit volume: general purpose product -30°C to +85°C +22% -82% N/A 3.0% Max, 2.0% Typical 10GQ or 100QF whichever is less, 25°C, Vocw 2.5 X VDCW 3.0% per decade 1 KHz, 1 Vrms 25°C hour values > or = to 10uF 1.0Vrms 120Hz CAPACITANCE VALUE & TOLERANCE Determined by circuit requirements. Note that chip prices decrease with lower capacitance value and looser tolerance. VOLTAGE Determined by circuit requirements. Units are designed to exceed the withstanding voltage specification, i.e., the user need not incorporate an additional safety margin. CAPACITOR SIZE Select the smallest unit permitted by the circuit constraints that provides the required capacitance and voltage rating. All Cal-Chip capacitors conform to EIA specifications. CAPACITOR TERMINATION Nickel barrier is standard and recommended for units exposed to repeated solder cycles, to minimize leaching of the termination. GMC PRODUCT TYPE 21 DIMENSIONS 01: 01005 02: 0201 04: 0402 10: 0603 21: 0805 31: 1206 32: 1210 40: 1808 43: 1812 45: 1825 55: 2220 57: 2225 CG DIELECTRIC CG: COG/NPO X7R X5R Z5U Y5V 102 CAPACITANCE 0R5: 0.5pF 5R0: 5.0pF 100: 10pF 101: 100pF 102: 1000pF 103: .01uF 104: .1uF 105: 1.0uF 106: 10uF 107: 100uF J TOLERANCE A: +/-.05pF B: +/-.1pF C: +/-.25pF D: +/-.5pF F: +/-1% G: +/-2% J: +/-5% K: +/-10% M: +/-20% Z: -20%/+80% 50 VOLTAGE DC 4R0: 4.0V 6R3: 6.3V 10: 10V 16: 16V 25: 25V 35: 35V 50: 50V 63: 63V 100: 100V 200: 200V ..Note: Cal-Chip has completed the Lead-Free transition. All parts shipped will be lead-free. The customer designator of "LF" is no longer available.Lead-Free material will continue to have a green RoHS symbol on the label. 2 NT TERMINATION NT: Sn/Ni PT: Pd/Ag D PACKAGING CODE Blank: 7" reel D: See page 19 & 20 G: See page 19 & 20 Q: See page 19 & 20 DIMENSION (MM) GMC01 L(L1) 0.4 ± 0.02 W 0.2 ± 0.02 H 0.2 ± 0.02 BW(L2/L3) 0.07 ~ 0.14 DIELECTRIC RATED VOLTAGE CAP. RANGE 0.5pF 0.75 1 1.2 1.5 1.8 2 2.2 2.7 3 3.3 3.6 3.9 4 4.7 5 5.6 6 6.8 7 8 8.2 10 11 12 15 18 20 22 27 30 33 39 43 47 51 56 62 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1.0nF 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 12 15 18 22 27 33 39 47 56 68 82 100 120 220 470 1uf NPO/COG 6.3 10/16 6.3 X7R 10 16 6.3 X5R 10 16 0R5 R75 1R0 1R2 1R5 1R8 2R0 2R2 2R7 3R0 3R3 3R6 3R9 4R0 4R7 5R0 5R6 6R0 6R8 7R0 8R0 8R2 100 110 120 150 180 200 220 270 300 330 390 430 470 510 560 620 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 224 474 105 3 GMC02 DIMENSION (MM) 0.6 ± 0.03 L(L1) 0.3 ± 0.03 W H 0.3 ± 0.03 BW(L2/L3) 0.15 ± 0.05 DIELECTRIC RATED VOLTAGE CAP. RANGE 4 0.1pF 0R1 0.2 0R2 0.3 0R3 0.4 0R4 0.47 R47 0.5 0.56 0.6 0.7 0.75 0.8 0.82 0.9 1 1.2 1.3 1.5 1.6 1.8 2 2.2 2.5 2.7 2.8 3.3 3.9 4.3 4.7 5.6 6.8 8.2 10 11 12 15 18 20 22 24 27 30 33 39 43 47 51 56 62 68 75 82 100 120 150 180 220 270 330 390 470 560 680 820 1.0nF 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 12 15 18 22 27 33 39 47 56 68 82 100 220 470 1.0uF 2.2 4.7 0R5 R56 0R6 0R7 R75 0R8 R82 0R9 1R0 1R2 1R3 1R5 1R6 1R8 2R0 2R2 2R5 2R7 2R8 3R3 3R9 4R3 4R7 5R6 6R8 8R2 100 110 120 150 180 200 220 240 270 300 330 390 430 470 510 560 620 680 750 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 224 474 105 225 475 NPO/COG 25 50 4/6.3V 10 X5R 16 25 6.3 10 X7R 16 25 50 Y5V/Z5U 6.3 DIMENSION (MM) GMC04 L(L1) 1.0 ± 0.05 W 0.5 ± 0.05 H 0.5 ± 0.1 BW(L2/LW) DIELECTRIC RATED VOLTAGE 0.1 ~ 0.35 6.3/10 16 NPO/COG 25 50 100 200 6.3 10 X5R 16 25 X7R 50 6.3/10 16/25 50 100 Y5V & Z5U 200 6.3 10 16 25 50 CAP. RANGE 0.47 0.5 0.56 0.6 0.68 0.7 0.75 0.8 0.9 1 1.2 1.3 1.5 1.6 1.8 2 2.2 2.4 2.7 3 3.3 3.5 3.6 3.9 4 4.3 4.7 5 5.1 5.6 6 6.2 6.8 7 7.5 8 8.2 9 9.1 10 11 12 13 15 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 110 120 130 150 180 200 220 240 270 300 330 360 390 430 470 560 680 750 820 1.0nF 1.2 1.5 1.8 R47 0R5 R56 0R6 R68 0R7 R75 0R8 0R9 1R0 1R2 1R3 1R5 1R6 1R8 2R0 2R2 2R4 2R7 3R0 3R3 3R5 3R6 3R9 4R0 4R3 4R7 5R0 5R1 5R6 6R0 6R2 6R8 7R0 7R5 8R0 8R2 9R0 9R1 100 110 120 130 150 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 111 121 131 151 181 201 221 241 271 301 331 361 391 431 471 561 681 751 821 102 122 152 182 5 GMC04 DIMENSION (MM) L(L1) 1.0 ± 0.05 W 0.5 ± 0.05 0.5 ± 0.1 H BW(L2/LW) DIELECTRIC RATED VOLTAGE CAP. RANGE 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 12 15 18 22 27 33 39 47 56 68 82 100 150 220 270 390 470 560 680 820 1.0 uF 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 15 22 33 47 0.1 ~ 0.35 NPO/COG 6.3/10 16 25 50 100 200 6.3 10 X5R 16 25 35 50 6.3/10 16 X7R 25 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 154 224 274 394 474 564 684 824 105 225 275 335 395 475 565 685 825 106 156 226 336 476 ****Please note L/W/H deviation for the 10uF is +/-.2mm**** ****Please note L/W/H deviation for the 22uF is +/-.3mm**** 6 Y5V & Z5U 50 100 200 6.3 10 16 25 50 DIMENSION (MM) GMC10 L(L1) 1.6 ± 0.2 W 0.8 ± 0.2 H 1.0 max BW(L2/LW) DIELECTRIC RATED VOLTAGE CAP. RANGE 0.4PF 0.47 0.5 0.6 0.7 0.75 0.8 1 1.2 1.3 1.5 1.8 2 2.2 2.4 2.7 3 3.3 3.6 3.9 4 4.3 4.7 5 5.1 5.6 6 6.2 6.8 7 7.5 8 8.2 9 9.1 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 120 130 150 160 180 200 220 240 270 300 330 390 430 470 510 560 620 680 750 820 910 25 NPO/COG 50 100 200 6.3 X5R 10 16 0.1 ~ 0.4 25 6.3 10 16 X7R 25 50 100 200 6.3 Y5V & Z5U 10 16 25 50 R40 R47 0R5 0R6 R70 R75 0R8 1R0 1R2 1R3 1R5 1R8 2R0 2R2 2R4 2R7 3R0 3R3 3R6 3R9 4R0 4R3 4R7 5R0 5R1 5R6 6R0 6R2 6R8 7R0 7R5 8R0 8R2 9R0 9R1 100 110 120 130 150 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 121 131 151 161 181 201 221 241 271 301 331 391 431 471 511 561 621 681 751 821 911 7 GMC10 DIMENSION (MM) 1.6 ± 0.2 0.8 ± 0.2 1.0 max 0.1 ~ 0.4 L(L1) W H BW(L2/LW) DIELECTRIC RATED VOLTAGE CAP. RANGE 1.0nF 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 7.5 8.2 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 220 270 330 470 560 680 820 1.0 uF 2.2 2.7 3.3 3.9 4.7 10 22 47 8 102 122 152 182 222 272 332 392 472 562 682 752 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 224 274 334 474 564 684 824 105 225 275 335 395 475 106 226 476 25 NPO/COG 50 100 200 6.3 10 X5R 16/25 35 6.3 10 16 X7R 25 50 100 200 6.3 Y5V & Z5U 10 16 25 50 GMC21 DIMENSION (MM) L(L1) 2.0 ± 0.3 2.0 ± 0.3 2.0 ± 0.3 2.0 ± 0.3 W 1.25 ± 0.2 1.25 ± 0.2 1.25 ± 0.2 1.25 ± 0.2 H 1.4 1.5 1.5 1.5 BW(L2/L3) 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 DIELECTRIC RATED VOLTAGE CAP. RANGE 0.4pF 16 NPO/COG 25 50 100 200 6.3 10 16 X7R 25 35 50 100 200 4 6.3 10 X5R 16 25 35 50 63 6.3 Y5V/Z5U 10 16 25 50 0R4 0.47 R47 0.5 R50 0.56 R56 0.75 R75 0.8 0R8 0.82 R82 1 1R0 1.1 1R1 1.2 1R2 1.3 1R3 1.5 1R5 1.6 1R6 1.8 1R8 2 2R0 2.2 2R2 2.4 2R4 2.7 2R7 3 3R0 3.3 3R3 3.6 3R6 3.9 3R9 4 4R0 4.3 4R3 4.7 4R7 5 5R0 5.1 5R1 5.6 5R6 6 6R0 6.2 6R2 6.8 6R8 7 7R0 7.5 7R5 8 8R0 8.2 8R2 9 9R0 9.1 9R1 10 100 11 110 12 120 13 130 15 150 16 160 18 180 20 200 22 220 24 240 27 270 30 300 33 330 36 360 39 390 43 430 47 470 51 510 56 560 62 620 68 680 75 750 82 820 91 910 100 101 120 121 130 131 150 151 160 161 180 181 200 201 220 221 240 241 270 271 300 301 9 GMC21 DIMENSION (MM) L(L1) 2.0 ± 0.3 2.0 ± 0.3 2.0 ± 0.3 2.0 ± 0.3 W 1.25 ± 0.2 1.25 ± 0.2 1.25 ± 0.2 1.25 ± 0.2 H 1.4 1.5 1.5 1.5 BW(L2/L3) 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 DIELECTRIC RATED VOLTAGE CAP. RANGE 10 330 331 360 361 390 391 430 431 470 471 510 511 560 561 620 621 680 681 750 751 820 821 910 911 1.0nF 102 1.2 122 1.5 152 1.8 182 2.2 222 2.4 242 2.7 272 3.3 332 3.9 392 4.7 472 5.6 562 6.8 682 8.2 822 10 103 12 123 15 153 18 183 22 223 27 273 33 333 39 393 47 473 56 563 68 683 82 823 100 104 120 124 150 154 180 184 220 224 270 274 330 334 390 394 470 474 560 564 680 684 820 824 1.0 uF 105 1.2 125 1.5 155 1.8 185 2.2 225 3.3 335 4.7 475 4.7 475 6.8 685 10 106 15 156 22 226 33 336 47 476 100 107 150 157 220 227 330 337 16 NPO/COG 25 50 100 200 6.3 10 16 X7R 25 35 50 100 200 4 6.3 10 X5R 16 25 35 50 63 6.3 Y5V/Z5U 10 16 25 50 GMC31 DIMENSION (MM) L(L1) 3.2 ± 0.3 3.2 ± 0.3 3.2 ± 0.3 3.2 ± 0.3 W 1.6 ± 0.2 1.6 ± 0.2 1.6 ± 0.2 1.6 ± 0.2 H 1.8 max 1.8 max 1.8 max 1.8 max BW(L2/L3) 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 DIELECTRIC RATED VOLTAGE CAP. RANGE 0.47pF 0R47 0.5 R50 0.56 R56 0.68 R68 0.75 R75 0.8 0R8 1 1R0 1.1 1R1 1.2 1R2 1.3 1R3 1.5 1R5 1.6 1R6 1.8 1R8 2 2R0 2.2 2R2 2.4 2R4 2.7 2R7 3 3R0 3.3 3R3 3.6 3R6 3.9 3R9 4 4R0 4.3 4R3 4.7 4R7 5 5R0 5.1 5R1 5.6 5R6 6 6R0 6.2 6R2 6.8 6R8 7 7R0 7.5 7R5 8 8R0 8.2 8R2 9 9R0 9.1 9R1 10 100 11 110 12 120 13 130 15 150 16 160 18 180 20 200 22 220 24 240 27 270 30 300 33 330 36 360 39 390 43 430 47 470 51 510 56 560 62 620 68 680 75 750 82 820 91 910 100 101 120 121 130 131 150 151 160 161 180 181 200 201 220 221 240 241 270 271 25 NPO/COG 50 100 200 6.3 10 16 X7R 25 50 100 200 4 6.3 X5R 10 16 25 50 6.3 Y5V/Z5U 10 16 25 50 11 GMC31 DIMENSION (MM) L(L1) 3.2 ± 0.3 3.2 ± 0.3 3.2 ± 0.3 3.2 ± 0.3 W 1.6 ± 0.2 1.6 ± 0.2 1.6 ± 0.2 1.6 ± 0.2 H 1.8 max 1.8 max 1.8 max 1.8 max BW(L2/L3) 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 DIELECTRIC RATED VOLTAGE CAP. RANGE 12 300 301 330 331 360 361 390 391 430 431 470 471 510 511 560 561 620 621 680 681 750 751 820 821 910 911 1.0nF 102 1.2 122 1.5 152 1.8 182 2.2 222 2.4 242 2.7 272 3.3 332 3.9 392 4.7 472 5.6 562 6.8 682 8.2 822 10 103 12 123 15 153 18 183 22 223 27 273 33 333 39 393 47 473 56 563 68 683 82 823 100 104 120 124 150 154 180 184 220 224 270 274 330 334 390 394 470 474 560 564 680 684 820 824 1.0 uF 105 1.2 125 1.5 155 1.8 185 2.2 225 2.7 275 3.3 335 4.7 475 4.7 475 6.8 685 10 106 15 156 22 226 33 336 47 476 68 686 100 107 220 227 330 337 25 NPO/COG 50 100 200 6.3 10 16 X7R 25 50 100 200 4 6.3 X5R 10 16 25 50 6.3 10 Y5V/Z5U 16 25 50 DIMENSION (MM) L(L1) W H BW(L2/L3) DIELECTRIC RATED VOLTAGE CAP. RANGE 0.5pF 0R5 0.4 R40 0.47 R47 0.7 R70 0.75 R75 1 1R0 1.1 1R1 1.2 1R2 1.3 1R3 1.5 1R5 1.6 1R6 1.8 1R8 2 2R0 2.2 2R2 2.4 2R4 2.7 2R7 3 3R0 3.3 3R3 3.6 3R6 3.9 3R9 4 4R0 4.3 4R3 4.7 4R7 5 5R0 5.1 5R1 5.6 5R6 6 6R0 6.2 6R2 6.8 6R8 7 7R0 7.5 7R5 8 8R0 8.2 8R2 9 9R0 9.1 9R1 10 100 11 110 12 120 13 130 15 150 16 160 18 180 20 200 22 220 24 240 27 270 30 300 33 330 36 360 39 390 43 430 47 470 51 510 56 560 62 620 68 680 75 750 82 820 91 910 100 101 120 121 130 131 150 151 160 161 180 181 200 201 220 221 240 241 270 271 300 301 330 331 16 GMC32 3.2 ± 0.3 3.2 ± 0.3 3.2 ± 0.3 3.2 ± 0.3 2.5 ± 0.3 2.5 ± 0.3 2.5 ± 0.3 2.5 ± 0.3 2.2 max 2.8 max 2.8 max 2.8 max 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 NPO/COG 25 50 100 200 6.3 10 16 X7R 25 50 100 200 4 6.3 X5R 10 16 25 50 6.3 Y5V/Z5U 10 16 25 50 13 GMC32 DIMENSION (MM) L(L1) 3.2 ± 0.3 3.2 ± 0.3 3.2 ± 0.3 3.2 ± 0.3 W 2.5 ± 0.3 2.5 ± 0.3 2.5 ± 0.3 2.5 ± 0.3 H 2.2 max 2.8 max 2.8 max 2.8 max BW(L2/L3) 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 DIELECTRIC RATED VOLTAGE CAP. RANGE 360 361 390 391 430 431 470 471 510 511 560 561 680 681 750 751 820 821 910 911 1.0nF 102 1.2 122 1.5 152 1.8 182 2.2 222 2.4 242 2.7 272 3.3 332 3.9 392 4.7 472 5.6 562 6.8 682 8.2 822 10 103 12 123 15 153 18 183 22 223 27 273 33 333 39 393 47 473 56 563 68 683 82 823 100 104 120 124 150 154 180 184 220 224 270 274 330 334 390 394 470 474 560 564 680 684 820 824 1.0 uF 105 1.2 125 1.5 155 1.8 185 2.2 225 2.7 275 3.3 335 4.7 475 4.7 475 6.8 685 8.2 825 10 106 15 156 22 226 33 336 47 476 68 686 100 107 150 157 220 227 330 337 16 NPO/COG 25 50 100 200 6.3 10 16 X7R 25 50 100 200 4 6.3 X5R 10 16 25 50 6.3 Y5V/Z5U 10 For GMC32X5R (1210) size (L) tolerance for values > 100uf, tolerance increases to 3.2mm +/- 0.4 mm. 14 16 25 50 GMC40 DIMENSION (MM) DIMENSION (MM) L(L1) 4.57 ± 0.25 4.57 ± 0.25 W 2.03 ± 0.25 2.03 ± 0.25 H 2.1 max 3 max BW(L2/L3) 0.25 ~ 0.75 0.25 ~ 0.75 DIELECTRIC RATED VOLTAGE CAP. RANGE NPO/COG 50 100 200 25 50 X7R 100 L(L1) 4.5 ± 0.35 4.5 ± 0.35 H 2.2 max 3 max W 3.2 ± 0.3 BW(L2/L3) Rated Voltage Cap. Range 0.5pF 0R5 0.4 R40 110 0.47 R47 12 120 13 130 0.7 R70 15 150 0.75 R75 16 160 1 1R0 18 180 1.1 1R1 20 200 1.2 1R2 22 220 1.3 1R3 24 240 27 270 1.5 1R5 30 300 1.6 1R6 33 330 1.8 1R8 36 360 2 2R0 39 390 2.2 2R2 43 430 2.4 2R4 47 470 2.7 2R7 51 510 56 560 3 3R0 62 620 3.3 3R3 68 680 3.6 3R6 75 750 3.9 3R9 82 820 4 4R0 91 910 4.3 4R3 100 101 120 121 4.7 4R7 130 131 5 5R0 150 151 5.1 5R1 160 161 5.6 5R6 180 181 6 6R0 200 201 6.2 6R2 220 221 6.8 6R8 240 241 270 271 7 7R0 300 301 7.5 7R5 330 331 8 8R0 360 361 8.2 8R2 390 391 9 9R0 430 431 9.1 9R1 470 471 510 511 10 100 560 561 11 110 620 621 12 120 680 681 13 130 750 751 15 150 820 821 16 160 910 911 18 180 1.0nF 102 1.2 122 20 200 1.5 152 22 220 1.8 182 24 240 2.2 222 27 270 2.4 242 30 300 2.7 272 33 330 3.3 332 3.9 392 36 360 4.7 472 39 390 5.6 562 43 430 6.8 682 47 470 8.2 822 51 510 10 103 56 560 12 123 62 620 15 153 18 183 68 680 22 223 75 750 27 273 82 820 33 333 91 910 39 393 100 101 47 473 120 121 56 563 68 683 130 131 82 823 150 151 100 104 160 161 120 124 180 181 150 154 200 201 180 184 220 221 220 224 240 241 270 274 330 334 270 271 390 394 300 301 470 474 330 331 560 564 360 361 9.1 9R1 10 100 11 3.2 ± 0.3 0.25 ~ 0.75 Dielectric 200 NPO/COG 50 100 200 10 GMC43 0.25 ~ 0.75 16 X7R 25 50 100 200 6.3 4.5 ± 0.35 4.5 ± 0.35 3.2 ± 0.3 3.2 ± 0.3 3 max 3 max 0.25 ~ 0.75 X5R 10 16 0.25 ~ 0.75 25 6.3 Y5V/Z5U 10 16 25 50 15 DIMENSION (MM) L(L1) BW(L2/L3) DIELECTRIC RATED VOLTAGE CAP. RANGE 390 391 430 431 470 471 510 511 560 561 680 681 750 751 820 821 910 911 1.0nF 102 1.2 122 1.5 152 1.8 182 2.2 222 2.4 242 2.7 272 3.3 332 3.9 392 4.7 472 5.6 562 6.8 682 8.2 822 10 103 12 123 15 153 18 183 22 223 27 273 33 333 39 393 47 473 56 563 68 683 82 823 100 104 120 124 150 154 180 184 220 224 270 274 330 334 470 474 560 564 680 684 820 824 1.0 uF 105 1.2 125 1.5 155 1.8 185 2.2 225 2.7 275 3.3 335 4.7 475 6.8 685 10 106 15 156 22 226 33 336 47 476 68 686 100 107 150 157 220 227 330 337 100 200 0.25 ~ 0.75 X7R 10 16 25 50 100 3 max 0.25 ~ 0.75 X5R 200 6.3 10 16 L(L1) 4.5 ± 0.35 4.5 ± 0.35 W 6.3 ± 0.4 6.3 ± 0.4 H 2.2 max 3.2 max BW(L2/L3) 0.25 ~ 0.75 0.25 ~ 0.75 3.2 ± 0.3 3 max 25 0.25 ~ 0.75 Y5V/Z5U 6.3 10 16 25 GMC45 DIMENSION (MM) 4.5 ± 0.35 3.2 ± 0.3 3 max 0.25 ~ 0.75 NPO/COG 50 4.5 ± 0.35 3.2 ± 0.3 2.2 max H GMC43 4.5 ± 0.35 3.2 ± 0.3 W 16 4.5 ± 0.35 DIELECTRIC RATED VOLTAGE CAP. RANGE 50 9.1 9R1 10 100 11 110 12 120 13 130 15 150 16 160 18 180 20 200 22 220 24 240 27 270 30 300 33 330 36 360 39 390 43 430 47 470 51 510 56 560 62 620 68 680 75 750 82 820 91 910 100 101 120 121 130 131 150 151 160 161 180 181 200 201 220 221 240 241 270 271 300 301 330 331 360 361 390 391 430 431 470 471 510 511 560 561 680 681 750 751 820 821 910 911 1.0nF 102 1.2 122 1.5 152 1.8 182 2.2 222 2.4 242 2.7 272 3.3 332 3.9 392 4.7 472 5.6 562 6.8 682 8.2 822 10 103 12 123 15 153 18 183 22 223 27 273 33 333 39 393 47 473 56 563 68 683 82 823 100 104 120 124 150 154 180 184 220 224 270 274 330 334 470 474 560 564 680 684 820 824 1.0 uF 105 1.2 125 1.5 155 1.8 185 2.2 225 2.7 275 NPO/COG 50 100 200 16 25 X7R 50 100 200 GMC55 DIMENSION (MM) L(L1) 5.7 ± 0.4 5.7 ± 0.4 5.7 ± 0.4 5.7 ± 0.4 W 5.0 ± 0.4 5.0 ± 0.4 5.0 ± 0.4 5.0 ± 0.4 H 2.2 max 3.5 max 3.5 max 3.5 max BW(L2/L3) DIELECTRIC 0.25 ~ 0.75 NPO/COG 0.25 ~ 0.75 X7R 0.25 ~ 0.75 X5R 0.25 ~ 0.75 Y5V/Z5U RATED VOLTAGE CAP. RANGE 270pF 271 300 301 330 331 360 361 390 391 430 431 470 471 510 511 560 561 680 681 750 751 820 821 910 911 1.0nF 102 1.2 122 1.5 152 1.8 182 2.2 222 2.4 242 2.7 272 3.3 332 3.9 392 4.7 472 5.6 562 6.8 682 8.2 822 10 103 12 123 15 153 18 183 22 223 27 273 33 333 39 393 47 473 56 563 68 683 82 823 100 104 120 124 150 154 180 184 220 224 270 274 330 334 390 394 470 474 560 564 680 684 820 824 1.0 uF 105 1.2 125 1.5 155 1.8 185 2.2 225 2.7 275 3.3 335 3.9 395 4.7 475 5.6 565 6.8 685 8.2 825 10 106 15 156 22 226 33 336 47 476 68 686 100 107 150 157 220 227 330 337 50 100 200 16 25 50 100 200 6.3 10 16 25 50 6.3 10 16 25 50 17 GMC57 DIMENSION (MM) L(L1) 5.7 ± 0.4 5.7 ± 0.4 5.7 ± 0.4 W 6.3 ± 0.4 5.0 ± 0.4 5.0 ± 0.4 H 2.2 max 3.5 max 3.5 max BW(L2/L3) 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 NPO/COG BW(L2/L3) DIELECTRIC RATED VOLTAGE CAP. RANGE 18 270 271 300 301 330 331 360 361 390 391 430 431 470 471 510 511 560 561 620 621 680 681 750 751 820 821 910 911 1.0nF 102 1.2 122 1.5 152 1.8 182 2.2 222 2.4 242 2.7 272 3.3 332 3.9 392 4.7 472 5.6 562 6.8 682 7.5 752 8.2 822 10 103 12 123 15 153 18 183 22 223 27 273 33 333 39 393 47 473 56 563 68 683 82 823 100 104 120 124 150 154 180 184 220 224 270 274 330 334 390 394 470 474 560 564 680 684 820 824 1.0 uF 105 1.2 125 1.5 155 1.8 185 2.2 225 2.7 275 3.3 335 4.7 475 5.6 565 6.8 685 8.2 825 10 106 15 156 22 226 33 336 47 476 68 686 100 107 150 157 220 227 330 337 50 100 X7R 200 16 25 50 Y5V/Z5U 100 200 6.3 10 16 25 50 PACKAGING (TAPING) Per EIA-481 - Reel Type Size t SYMBOL 7” Reel A E min 10” Reel 13” Reel B C TAPE WIDTH A B C D E W t 4mm φ178±2.0 MINφ50 φ13±0.5 21±0.8 2.0±0.5 5±0.5 1.2±0.2 8mm φ178±2.0 MINφ50 φ13±0.5 21±0.8 2.0±0.5 10±0.5 0.9±0.2 12mm φ178±2.0 MINφ50 φ13±0.5 21±0.8 2.0±0.5 13±0.5 1.2±0.2 8mm φ258±2.0 MINφ70 φ13±0.5 21±0.8 2.0±0.5 10±0.5 1.8±0.2 8mm φ330±2.0 MINφ70 φ13±0.5 21±0.8 2.0±0.5 10±0.5 1.8±0.2 12mm φ330±2.0 MINφ70 φ13±0.5 21±0.8 2.0±0.5 13±0.5 2.2±0.2 D W - To peel off the cover tape by the method shown in the right figure apply a peel-off force of 20GF - 60GF (card board); 10GF - 75GF (plastic tape). -The cover tape should not touch the top or bottom ofthe chip. - If the cover tape has been peeled off it may be difficult to remove the chip due to punch-hole clearance, dirt, and debris. Make sure therefore that no paper waste will adhere to and block the absorption nozzle. - If the cover tape has been peeled off from the top, stick it back on with a suitable adhesive. - Follow the illustration for the start and end of the winding operation. DIMENSION OF PAPER TAPE CARDBOARD CARRIER TAPE FOR 01005, 0201, 0402, 0603, 0805, 1206 UNIT=mm 19 PACKAGING (TAPING) Tape & Reel Dimensions • Embossed plastic carrier tape for 0805/1206/1210/1808/1812/1825/2220 AND 2225 type TYPE A0 B0 T K0 W P0 10XPo P1 P2 D0 D1 E F MOUNTING STD. REEL HOLE QTY 7” 0805
GMC10CG3R0B100NTD
物料型号:MULTILAYER CERAMIC CHIP CAPACITORS - GMC SERIES
器件简介: - 适用于表面贴装装配设备 - 完全集成的制造和全面质量控制系统确保了前所未有的高质量和可靠性标准
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 大容量值在小尺寸中 - 出色的高频特性
功能详解: - 提供了不同类型陶瓷电容器的详细介绍,包括其电容随温度变化、电容随电压变化、耗散因子、绝缘电阻、耐电压、老化率和测试参数。
应用信息: - 主要用于需要高容量、小尺寸和良好高频特性的应用场合。
封装信息: - 提供了多种尺寸的封装信息,如01005、0201、0402、0603、0805、1206、1210、1808、1812、1825、2220、2225等,并给出了详细的尺寸和额定电压信息。
GMC10CG3R0B100NTD 价格&库存
很抱歉,暂时无法提供与“GMC10CG3R0B100NTD”相匹配的价格&库存,您可以联系我们找货
GMC10CG3R0B100NTD
  • 1+1.947441+0.25208
  • 10+1.1064110+0.14322
  • 50+0.7911850+0.10241
  • 100+0.69466100+0.08992
  • 500+0.53358500+0.06907
  • 1000+0.483771000+0.06262
  • 2500+0.431332500+0.05583
  • 5000+0.399775000+0.05175
库存:20000
GMC10CG3R0B100NTD
  • 10000+0.3738210000+0.04839
  • 20000+0.3524520000+0.04562
  • 30000+0.3417630000+0.04424
  • 50000+0.3299050000+0.04271
  • 70000+0.3229770000+0.04181
  • 100000+0.31630100000+0.04095
库存:20000
