THGBMHG9C4LBAIR
THGBMHG9C4LBAIR
    KIOXIA(铠侠)
    P-WFBGA-153_11.5X13MM
    THGBMHG9C4LBAIR
THGBMHG9C4LBAIR 数据手册
2%2(*0%7,1)136= I 11' 'SWX)JJIGXMZI1EWW7XSVEKI %440-'%8-327 Industrial Consumer Electronics Multimedia Smart Metering & Intelligent Lighting *)%896)7 4GB – 128GB 15nm MLC technology Conforms to the latest JEDEC Version 5.0 and 5.1 Integrated memory management Error correction code Bad block management Wear-leveling Garbage collection Standard and extended temperature range FBGA package %(:%28%+)7 &)2)*-87 High Interface speed HS400 according to JEDEC 5.x Managed memory Package, interface, features, commands etc. are standard Utiliz high quality Toshiba MLC NAND flash memory in combination with a Toshiba developed controller Produced in dge technology flash factory Easy to integrate storage solution due to established standards Cost efficient design n relation between price, density and performance Reliable storage solution based on high quality NAND memory and optimized controller Extended production capacity to customer demand 74)'-*-'%8-327 Product / Features Density Technology JEDEC Version Temperature Package MMC Extended Temp. ·MMC 4GB – 128GB 8GB – 64GB 15nm 15nm 5.0 / 5.1 5.1 -25°C to +85°C -40°C to +85°C FBGA www.toshiba.semicon-storage.com www.toshiba.semicon-storage.com 11'z463(9'80-78 Density Item Name Technology JEDEC Standard Temperature Package 4GB THGBMDG5D1LBAIT 15nm JEDEC 5.0 -25°C to 85°C 153FBGA 11x10 THGBMHG6C1LBAIL 15nm JEDEC 5.1 -25°C to 85°C 153FBGA 11.5x13 THGBMHG6C1LBAWL 15nm JEDEC 5.1 -40°C to 85°C 153FBGA 11.5x13 THGBMHG7C1LBAIL 15nm JEDEC 5.1 -25°C to 85°C 153FBGA 11.5x13 THGBMHG7C2LBAWR 15nm JEDEC 5.1 -40°C to 85°C 153FBGA 11.5x13 THGBMHG8C2LBAIL 15nm JEDEC 5.1 -25°C to 85°C 153FBGA 11.5x13 THGBMHG8C4LBAWR 15nm JEDEC 5.1 -40°C to 85°C 153FBGA 11.5x13 THGBMHG9C4LBAIR 15nm JEDEC 5.1 -25°C to 85°C 153FBGA 11.5x13 THGBMHG9C8LBAWG 15nm JEDEC 5.1 -40°C to 85°C 153FBGA 11.5x13 THGBMHT0C8LBAIG 15nm JEDEC 5.1 -25°C to 85°C 153FBGA 11.5x13 8GB 16GB 32GB 64GB 128GB I z74)'-%0->)(:)67-327 oshiba offers demand. Please contact your Toshiba representative or qualified distributor for 16GB and 32GB information. I z()7-+2+9-()0-2) ()7-+2',)'/7,))8 I z)2,%2')(97)6(%8%%6)% To support your ·MMC design, Toshiba offers a design guideline and a design check sheet The design guideline highlights some of the key topics to be considered when selecting and utilizing a Toshiba ·MMC. The design check sheet can be used to give more detailed information about the individual usage scenario for the ·MMC. Both files are available at your local Toshiba representative or qualified distributor. Toshiba ·MMC products support the JEDEC compliant “Enhanced User Data Area also called “pseudo-SLC ” or applications requiring the memory to perform with higher write/erase cycles than MLC NAND can offer, the ·MMC provides the option to build a partition which offers “pseudo-SLC“ performance. -223:%8-32-739686%(-8-32*0%7,1)136=%2(136) In 1984, Toshiba developed a new type of semiconductor memory called flash memory, leading the industry into the next generation ahead of its competitors. Some time later in 1987, NAND flash memory was developed, and this has since been used in a variety of memory cards and electronic equipment. The NAND flash market has the inventor of grown rapidly, with flash memory becoming an internationally standardized memory device. has carved out a path to a new era in which we are all able to carry videos, music and data flash memory, with us wherever we go. www.toshiba.semicon-storage.com
THGBMHG9C4LBAIR 价格&库存
很抱歉,暂时无法提供与“THGBMHG9C4LBAIR”相匹配的价格&库存,您可以联系我们找货
THGBMHG9C4LBAIR
    • 1+165.61800
    • 30+157.48560
