AF0603FR-075K6L
AF0603FR-075K6L
    YAGEO(国巨)
    贴片电阻 0603 5.6KΩ ±1% 1/10W ±100ppm/℃
AF0603FR-075K6L 数据手册
DATA SHEET ANTI-SULFURATED CHIP RESISTORS AUTOMOTIVE GRADE AF series 5%, 1%, 0.5% sizes 0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 Product specification – March 26, 2021 V.8 RoHS compliant & Halogen free 2 Product specification Chip Resistor Surface Mount AF 10 0100 to 2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes AF0100 to AF2512 chip resistors with anti-sulfuration capabilities. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS  Industrial Equipment  Power Application  Networking Application  High-end Computer & Multimedia Electronics in high sulfur environment  Automotive electronics GLOBAL PART NUMBER AF XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 (2) TOLERANCE D = ± 0.5% F = ± 1% J = ± 5% (for jumper ordering, use code of J) FEATURES  AEC-Q200 qualified  Superior resistance against sulfur containing atmosphere  Halogen free product and production  RoHS compliant  Reduces environmentally hazardous waste  High component and equipment reliability  Saving of PCB space  Moisture sensitivity level: MSL 1  50ppm available (3) PACKAGING TYPE R = Paper taping reel K = Embossed plastic tape reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec E = ± 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point. Detailed resistance rules are displayed in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is system default code for ordering only (Note) Resistance rule of global part number Resistance coding rule Example XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω ORDERING EXAMPLE The ordering code for an AF0402 chip resistor, value 100 KΩ with ± 1% tolerance, supplied in 7-inch tape reel with 10Kpcs quantity is: AF0402FR-07100KL. NOTE 1. All our R-Chip products are RoHS compliant and Halogen free. "LFP" of the internal 2D reel label states "Lead-Free Process" 2. On customized label, "LFP" or specific symbol can be printed www.yageo.com Mar. 26, 2021 V.8 Product specification Chip Resistor Surface Mount AF SERIES 3 10 0100 to 2512 MARKING AF0100 / AF0201 / AF0402 No marking ynsc007 Fig. 1 AF0603 / AF0805 / AF1206 / AF1210 / AF2010 / AF2512 03 Fig. 2 YNSC001 Value=10 KΩ E-24 series: 3 digits, ±5%, ≥10Ω First two digits for significant figure and 3rd digit for number of zeros AF0603 0 YNSC037 Fig. 3 Value = 24 Ω E-24 series: 3 digits, ± 1% One short bar under marking letter E-96 series: 3 digits, ± 1% First two digits for E-96 marking rule and 3rd letter for number of zeros Fig. 4 Value = 12.4 KΩ AF0805 / AF1206 / AF1210 / AF2010 / AF2512 00 YNSC004 Fig. 5 Value = 10 KΩ Both E-24 and E-96 series: 4 digits, ± 1% First three digits for significant figure and 4th digit for number of zeros AF1218 YNSC099-2 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ YNSC103-2 Both E-24 and E-96 series: 4 digits, ± 1% First three digits for significant figure and 4th digit for number of zeros Fig. 7 Value = 10 KΩ NOTE For further marking information, please see special data sheet “Chip resistors marking”. Marking of AF series is the same as RC series www.yageo.com Mar. 26, 2021 V.8 Product specification Chip Resistor Surface Mount AF CONSTRUCTION The resistors are constructed on top of a high grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a glass. The composition of the glaze is adjusted to give the approximate required resistance value and laser trimming of this resistive glaze achieves the value within tolerance. The whole element is covered by a protective overcoat. Size 0603 and bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added. See fig.8 4 10 0100 to 2512 SERIES OUTLINES For dimensions see Table 1 marking layer overcoat primary glass layer resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode H ceramic substrate I2 overcoat I1 DIMENSIONS Table 1 For outlines see fig. 8 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AF0100 0.40± 0.02 0.20± 0.02 0.14± 0.02 0.10± 0.03 0.10± 0.03 AF0201 0.60± 0.03 0.30± 0.03 0.23± 0.03 0.12± 0.05 0.15± 0.05 AF0402 1.00± 0.05 0.50± 0.05 0.35± 0.05 0.20± 0.10 0.25± 0.10 AF0603 1.60± 0.10 0.80± 0.10 0.45± 0.10 0.25± 0.15 AF0805 2.00± 0.10 1.25± 0.10 0.50± 0.10 0.35± 0.20 AF1206 3.10± 0.10 1.60± 0.10 0.55± 0.10 0.45± 0.20 AF1210 3.10± 0.10 2.60± 0.15 0.57± 0.10 0.45± 0.20 0.25± 0.15 W YNSC086 L Fig. 8 Chip resistor outlines 0.35± 0.20 0.50± 0.20 0.50± 0.20 AF1218 3.10± 0.10 4.60± 0.10 0.57± 0.10 0.45± 0.20 0.50± 0.20 AF2010 5.00± 0.10 2.50± 0.15 0.57± 0.10 0.55± 0.20 0.55± 0.20 AF2512 6.35± 0.10 3.20± 0.15 0.57± 0.10 0.60± 0.20 0.60± 0.20 www.yageo.com Mar. 26, 2021 V.8 Product specification Chip Resistor Surface Mount AF SERIES 5 10 0100 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE AF0100 AF0201 POWER 1/32 W Operating Temperature Range –55 °C to 125°C 1/20 W Max. Max. Dielectric Working Overload Withstanding Voltage Voltage Voltage 15V 25V 30V 50V Resistance Range Temperature Coefficient Jumper Criteria 30V 5% (E24) 10Ω ≤ R ≤ 1MΩ 1% (E24/E96) 10Ω ≤ R ≤ 1MΩ Jumper < 50mΩ 10Ω ≤ R < 100Ω ± 300 ppm/°C 100Ω ≤ R ≤ 1MΩ ± 200 ppm/°C Rated Current 0.5A Max. Current 1.0A 50V 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω -100/+350 ppm/°C 10Ω < R ≤ 10MΩ ± 200 ppm/°C Rated Current 0.5A Max. Current 1.0A 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 1MΩ ± 50 ppm/°C Rated Current 1A Max. Current 2A 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 5% (E24) 1Ω ≤ R ≤ 22MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 10MΩ < R ≤ 22MΩ ± 200 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1%, (E24/E96) 1Ω ≤ R ≤ 10MΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 1/16 W 50V 100V 100V 1/8W 50V 100V 100V AF0402 1/10 W 75V 150V 150V 75V 150V 150V AF0603 1/5 W 1/8 W –55 °C to 155 °C 150V 300V 300V AF0805 1/4 W 1/4 W 150V 200V 300V 400V 300V 500V AF1206 1/2 W 200V 400V 500V Rated Current 1A Max. Current 2A Rated Current 2A Max. Current 5A Rated Current 2A Max. Current 10A www.yageo.com Mar. 26, 2021 V.8 Product specification Chip Resistor Surface Mount AF SERIES 6 10 0100 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE AF1210 AF1218 POWER Operating Temperature Range 1/2 W Max. Max. Dielectric Working Overload Withstanding Voltage Voltage Voltage 200V 1W 200V 500V 500V 500V 500V –55 °C to 155 °C AF2010 AF2512 3/4 W 1W 200V 200V 500V 500V 500V 500V Resistance Range Temperature Coefficient Jumper Criteria 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 1MΩ ± 50 ppm/°C Rated Current 2A Max. Current 10A 5% (E24) 1Ω ≤ R ≤ 1MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 1MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 1MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 2.2MΩ ± 50 ppm/°C Rated Current 2A Max. Current 10A 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C Rated Current 2A Max. Current 10A 5% (E24) 1Ω ≤ R ≤ 10MΩ 0.5%, 1% (E24/E96) 1Ω ≤ R ≤ 10MΩ Jumper < 50mΩ 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 10Ω < R ≤ 10MΩ ± 100 ppm/°C 100Ω ≤ R ≤ 10MΩ ± 50 ppm/°C Rated Current 2A Max. Current 10A www.yageo.com Mar. 26, 2021 V.8 Product specification Chip Resistor Surface Mount AF SERIES 7 10 0100 to 2512 FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles of AF-series is the same as RC-series. Please see the special data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE Paper taping reel (R) Embossed taping reel (K) REEL DIMENSION AF0100 AF0201 AF0402 AF0603 AF0805 AF1206 AF1210 AF1218 AF2010 AF2512 7" (178 mm) 20,000 10,000/20,000 10,000/20,000 5,000 5,000 -- 13" (330 mm) -- 50,000 50,000 20,000 20,000 -- 7" (178 mm) -- -- -- -- -- 4,000 NOTE 1. For paper/embossed tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”. TEMPERATURE COEFFICIENT OF RESISTANCE RESISTANCE RANGE 100 mΩ to 910 mΩ PT040 FUNCTIONAL DESCRIPTION 2 ± 200 ppm/°C OPERATING TEMPERATURE RANGE PT060 AF0100 Range: -55°C to + 125°C ± 200 ppm/°C 3 AF0201 - AF2512 Range: -55°C to + 155°C PT080 ± 200 ppm/°C 5 POWER100 RAMΩ TINTO G 910 MΩ PT120 Each type rated power at 70°C: 100 mΩ 6 AF0100=1/32W (0.03125W) PT201 AF0201=1/20W (0.05W) ± 100 ppm/°C 0 AF0402=1/16 W (0.0625W); 1/8W (0.125W) PT251 AF0603=1/10 W (0.1W); 1/5W (0.2W) ± 100 ppm/°C 2 AF0805=1/8 W (0.125W); 1/4W (0.25W) AF1206=1/4 W (0.25W); 1/2W (0.5W) P (%Prated) MLB206_9-1 100 0201 to 2512 > 100 mΩ 50 0100 ± 75 ppm/°C 0 55 0 ± 75 ppm/°C 50 70 100 125 155 o Tamb ( C) Fig. 9 Maximum dissipation (P max ) in percentage of rated power as a function of the operating ambient temperature (T amb ) AF1210=1/2W (0.5W) AF1218=1W AF2010=3/4W (0.75W) AF2512=1W RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= Where R V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) www.yageo.com Mar. 26, 2021 V.8 Product specification Chip Resistor Surface Mount AF SERIES 8 10 0100 to 2512 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE Temperature Coefficient of Resistance (T.C.R.) IEC 60115-1 4.8 MIL-STD-202 Method 304 At +25/–55°C and +25/+125°C REQUIREMENTS Refer to table 2 Formula: R2–R1 T.C.R= ------------------------× 106 (ppm/°C) R1(t2–t1) Where t1=+25°C or specified room temperature t2=–55°C or +125°C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Life/Endurance IEC 60115-1 4.25 MIL-STD-202 Method 108 At 70± 2°C for 1,000 hours, RCWV applied for 1.5 hours on, 0.5 hour off, still-air required 0100: ± (3.0%+0.05 Ω) Others: ± (1.0%+0.05 Ω)
AF0603FR-075K6L AI解析
物料型号:AF系列,包括AF0100至AF2512,表示尺寸从0100到2512的贴片电阻。
器件简介:AF系列是具有抗硫化能力的贴片电阻,符合汽车级标准,适用于高硫环境的高端计算机和多媒体电子设备、汽车电子等。
引脚分配:文档中没有明确指出引脚分配,但提到了尺寸0603及以上的电阻会在顶部标记电阻值。
参数特性: - 符合AEC-Q200标准 - 优越的抗硫化气氛能力 - 无卤产品和生产 - 符合RoHS标准 - 减少环境有害废物 - 提高组件和设备的可靠性 - 节省PCB空间 - 湿度敏感度等级:MSL 1 - 50ppm精度的电阻值可用
功能详解:文档详细描述了电阻的构造,包括高级陶瓷基底、内部金属电极、电阻性釉料、覆盖玻璃等,并说明了电阻值的调整和激光修调过程。
应用信息:适用于工业设备、电源应用、网络应用、高端计算机和多媒体电子设备,尤其是在高硫环境中。
封装信息:提供了不同尺寸的详细尺寸数据,包括长度、宽度、高度等,并附有图表说明。
*介绍内容由AI识别生成
AF0603FR-075K6L 价格&库存
很抱歉,暂时无法提供与“AF0603FR-075K6L”相匹配的价格&库存,您可以联系我们找货
AF0603FR-075K6L
    • 25000+0.0202125000+0.00243
    • 50000+0.0193750000+0.00233
    • 150000+0.01937150000+0.00233
    库存:15000
    AF0603FR-075K6L
    • 1+0.02951
    • 100+0.02742
    • 300+0.02532
    • 500+0.02323
    • 2000+0.02218
    • 5000+0.02156
    库存:94
    AF0603FR-075K6L
      • 100+0.02572
      • 1000+0.02045
      • 5000+0.01717
      库存:392
      AF0603FR-075K6L
        • 1+0.06970
        • 100+0.04500
        • 1000+0.03200
        • 2500+0.02380
        • 5000+0.01770
        库存:24770
