AC0603FR-072R15L
AC0603FR-072R15L
    YAGEO(国巨)
    贴片电阻 0603 2.15Ω ±1% 1/10W ±200ppm/℃
AC0603FR-072R15L 数据手册
DATA SHEET THICK FILM CHIP RESISTORS AUTOMOTIVE GRADE AC series ±5%, ±1%, ±0.5%, ±0.1% (LOW TCR) Sizes 0201/0402/0603/0805/1206/ 1210/1218/2010/2512 Product specification – November 17, 2023 V.11 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount AC 0201 to 2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes AC0201 to AC2512 chip resistors with leadfree terminations made by thick film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS ⚫ ⚫ All general purpose applications Car electronics, industrial application FEATURES ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ AEC-Q200 qualified Moisture sensitivity level: MSL 1 AC series soldering is compliant with J-STD-020D Halogen free epoxy RoHS compliant - Products with lead-free terminations meet RoHS requirements - Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS Reduce environmentally hazardous waste High component and equipment reliability The resistors are 100% performed by automatic optical inspection prior to taping. GLOBAL PART NUMBER AC XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201/ 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE B = ± 0.1% for low TCR F = ± 1% D = ± 0.5% J = ± 5% (for Jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE = Base on spec E = ± 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel & Standard power 7W = 7 inch dia. Reel & 2 x standard power 13 = 13 inch dia. Reel 3W = 13 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE 1Ω to 22 MΩ There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter B is for bulk AOI ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76Ω) 1R = 1Ω 1R5 = 1.5Ω 9R76 = 9.76Ω XXRX (10 to 97.6Ω) 10R = 10Ω 97R6 = 97.6Ω XXXR (100 to 976Ω) 100R = 100Ω 976R = 976Ω XKXX (1 to 9.76 KΩ) 1K = 1,000Ω 9K76 = 9760Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000Ω 9M76= 9,760,000Ω XXMX (10 MΩ) 10M = 10,000,000Ω O RDERING EXAMPLE The ordering code for an AC0402 chip resistor, value 100 KΩ with ± 1% tolerance, supplied in 7-inch tape reel is: AC0402FR-07100KL. NOTE 1. All our R-Chip products are RoHS compliant and Halogen free. "LFP" of the internal 2D reel label states "Lead-Free Process". 2. On customized label, "LFP" or specific symbol can be printed. 3. AC series with 0.5% tolerance is also available. For further information, please contact sales. www.yageo.com Nov. 17, 2023 V.11 Product specification Chip Resistor Surface Mount AC SERIES 0201 to 2512 MARKING AC0201 / AC0402 No marking Fig. 1 AC0603 / AC0805 / AC1206 / AC1210 / AC2010 / AC2512 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 2 Value=10 KΩ AC0603 YNSC037 Fig. 3 E-24 series: 3 digits, ± 1% & ± 0.5% One short bar under marking letter Value = 24 Ω E-96 series: 3 digits, ± 1% & ± 0.5% First two digits for E-96 marking rule and 3rd letter for number of zeros Fig. 4 Value = 12.4 KΩ AC0805 / AC1206 / AC1210 / AC2010 / AC2512 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ AC1218 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ YNSC103 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 7 Value = 10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. Marking of AC series is the same as RC series. www.yageo.com Nov. 17, 2023 V.11 Product specification Chip Resistor Surface Mount AC SERIES 0201 to 2512 CONSTRUCTION The resistors are constructed on top of an automotive grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a protective glass. The composition of the glaze is adjusted to give the approximately required resistance value and laser trimming of this resistive glaze achieves the value within tolerance. The whole element is covered by a protective overcoat. Size 0603 and bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added, as shown in Fig.8. OUTLINES Fig. 8_1 Fig. 8_2 Chip resistor outlines AC2010/ 2512 double power chip resistor outlines DIMENSIONS Table 1 For outlines, please refer to Fig. 9 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AC0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.03 0.12 ± 0.05 0.15 ± 0.05 AC0402 1.00 ± 0.05 0.50 ± 0.05 0.32 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 AC0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 AC0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 AC1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.45 ± 0.20 AC1210 3.10 ± 0.10 2.60 ± 0.15 0.55 ± 0.10 0.45 ± 0.15 0.50 ± 0.20 AC1218 3.10 ± 0.10 4.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 AC2010 5.00 ± 0.10 2.50 ± 0.15 0.55 ± 0.10 0.55 ± 0.15 0.55 ± 0.20 AC2512 6.35 ± 0.10 3.10 ± 0.15 0.55 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 For dimension, please refer to Table 1 AC0201/0402 0603/0805/1206/1210/ 2010/2512 I1 AC1218 Side view for all type I1 I1 W W Fig. 9 Chip resistor dimensions H W I2 L L L YNSC096 www.yageo.com Nov. 17, 2023 V.11 Product specification Chip Resistor Surface Mount AC SERIES 0201 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE AC0201 POWER 1/20 W Operating Max. Temperature Working Range Voltage -55°C to 155°C 25V Max. Dielectric Overload Withstanding Voltage Voltage 50V 50V Resistance Range Temperature Coefficient Jumper Criteria 5% (E24) 1Ω ≤ R ≤ 10Ω Rated Current 1Ω ≤ R ≤ 10MΩ -100/+350 ppm°C 0.5A 1% (E24/E96) 10Ω < R ≤ 10M Maximum 1Ω ≤ R ≤ 10MΩ ± 200 ppm°C Current 0.5% (E24/E96) 1.0A 10Ω ≤ R ≤ 1MΩ Jumper
AC0603FR-072R15L
物料型号:AC系列,尺寸从0201至2512,公差±5%, ±1%, ±0.5%。
器件简介:YAGEO生产的AC系列芯片电阻,采用无铅端子制造,符合RoHS标准,无卤素,适用于汽车级应用。
引脚分配:文档中未明确提供引脚分配信息,但通常这类电阻为平面贴装,两端为金属电极。
参数特性: - 工作温度范围:-55°C至+155°C。 - 最大电压:根据型号不同,从25V至500V不等。 - 电阻范围:1Ω至22MΩ。 - 温度系数:根据电阻值和公差不同,温度系数在±100ppm/°C至±200ppm/°C之间。
功能详解: - 符合AEC-Q200标准,适合汽车电子和工业应用。 - 湿度敏感度等级为MSL 1。 - 所有产品均通过自动光学检测。 - 提供多种包装方式,包括7英寸、10英寸和13英寸直径的卷带。
应用信息:适用于所有通用应用,包括汽车电子和工业应用。
封装信息:提供多种尺寸的封装,从0201至2512,以及不同的公差和包装类型。
订购信息:通过全球零件编号系统订购,包括尺寸、公差、包装类型、温度系数、卷带直径和电阻值。
AC0603FR-072R15L 价格&库存
很抱歉,暂时无法提供与“AC0603FR-072R15L”相匹配的价格&库存,您可以联系我们找货
AC0603FR-072R15L
  • 100+0.00210
  • 1000+0.00190
  • 3000+0.00170
  • 10000+0.00130
  • 50000+0.00130
库存:4399
AC0603FR-072R15L
    • 1+0.13390
    • 100+0.09090
    • 1000+0.06160
    • 2500+0.04390
    • 5000+0.03170
    库存:25050
