CC1812KKX7RDBB102
CC1812KKX7RDBB102
    YAGEO(国巨)
    贴片电容(MLCC) 1812 1nF ±10% 2KV X7R
CC1812KKX7RDBB102 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS High-Voltage NP0/X7R 500 V TO 3 KV 0.47 pF to 33 nF Product Specification – October 26, 2021 V.14 RoHS compliant & Halogen Free Product specification Surface-Mount Ceramic Multilayer Capacitors SCOPE This specification describes HighVoltage NP0/X7R series chip capacitors with lead-free terminations. APPLICATIONS NP0/X7R 2 20 500 V to 3 KV ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP CTC & 12NC All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED) PCs, Hard disk, Game PCs Power supplies LCD panel ADSL, Modem CC FEATURES (2) TOLERANCE RoHS compliant Halogen Free compliant MSL class MSL I Soldering is compliant with J-STD-020D High-Voltage XXXX X X XXX X X X XXX (1) (2) (3) (4) (5) (6) (7) (8) (1) SIZE – INCH BASED (METRIC) 0805 (2012) / 1206 (3216) / 1210 (3225) / 1808 (4520) / 1812 (4532) / 2220 (5750) C = ± 0.25 pF D = ± 0.5 pF G = ± 2% J = ± 5% K = ± 10% M = ± 20% (3) PACKING STYLE R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch (4) TC MATERIAL NPO = NP0 X7R = X7R (5) RATED VOLTAGE B = 500V D = 2 KV Z = 630V S = 2.5KV C = 1KV E = 3 KV (6) CONTROL CODE A: Anti-arc coating B: Standard Type (7) PROCESS N = NP0 B = X7R (8) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Oct. 26, 2021 V.14 3 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 20 500 V to 3 KV CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (NiSn). The terminations are lead-free. A cross section of the structure is shown in Fig.1. terminations electrodes MLB457 ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction DIMENSION OUTLINES Table 1 For outlines see fig.2 TYPE 0805 1206 L1 (mm) W (mm) T (MM) 2.0 ± 0.10 1.25 ± 0.10 0.60 ± 0.10 0.85 ± 0.10 2.0 ± 0.20 1.25 ± 0.20 1.25 ± 0.20 3.2 ± 0.15 1.60 ± 0.15 0.60 ± 0.10 1.60 ± 0.20 0.85 ± 0.10 1.25 ± 0.20 3.2 ± 0.30 L2 / L3 (mm) L4 (mm) min. max. min. 0.25 0.75 0.70 2.50 ± 0.20 1210 3.2 ± 0.30 1808 4.5 ± 0.40 2.50 ± 0.20 2.00 ± 0.30 W T L2 L4 L1 0.25 0.75 1.40 0.25 0.75 1.40 0.25 0.75 2.20 0.25 0.75 2.20 0.25 0.75 3.40 1.60 ± 0.20 3.2 ± 0.20 For dimension see Table 1 L3 MBB211 Fig. 2 Surface mounted multilayer ceramic capacitor dimension 0.85 ± 0.10 1.25 ± 0.20 1.60 ± 0.20 2.00 ± 0.20 1.25 ± 0.20 1.35 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 0.85 ± 0.10 1.25 ± 0.20 1812 4.5 ± 0.40 3.20 ± 0.20 1.35 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 2220 5.7 ± 0.40 5.0 ± 0.3. 2.00 ± 0.20 www.yageo.com Oct. 26, 2021 V.14 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 4 20 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR NP0 Table 2 Sizes from 0805 to 1210 CAP. 0805 500 V 1206 630 V 1 KV 500 V 1210 630 V 1 KV 2 KV 3 KV 500 V 630 V 1 KV 2 KV 1.0 pF 1.2 pF 1.5 pF 1.8 pF 2.2 pF 2.7 pF 3.3 pF 3.9 pF 4.7 pF 5.6 pF 6.8 pF 8.2 pF 0.85± 0.1 1.25± 0.2 10 pF 12 pF 15 pF 18 pF 22 pF 0.85± 0.1 1.25± 0.2 27 pF 33 pF 39 pF 0.6± 0.1 1.25± 0.2 47 pF 1.25± 0.2 1.25± 0.2 56 pF 68 pF 1.25± 0.2 82 pF 100 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 120 pF 150 pF 180 pF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Oct. 26, 2021 V.14 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 5 20 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR NP0 Table 3 Sizes from 0805 to 1210 (continued) CAP. 0805 500 V 1206 630 V 1 KV 500 V 1210 630 V 1 KV 220 pF 2 KV 3 KV 500 V 630 V 1 KV 1.25± 0.2 2 KV 1.25± 0.2 270 pF 330 pF 0.85± 0.1 0.85± 0.1 390 pF 0.6± 0.1 470 pF 1.25± 0.2 560 pF 680 pF 820 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.0 nF 1.2 nF 0.85± 0.1 1.5 nF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Oct. 26, 2021 V.14 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 6 20 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR NP0 Table 4 Sizes from 1808 to 1812 1808 CAP. 1 KV 1812 2 KV 3 KV 500 V 630 V 1 KV 2 KV 3 KV 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.47 pF 0.56 pF 0.68 pF 0.82 pF 1.0 pF 1.2 pF 1.5 pF 1.8 pF 2.2 pF 2.7 pF 3.3 pF 3.9 pF 4.7 pF 5.6 pF 6.8 pF 8.2 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 1.6± 0.2 39 pF 47 pF 56 pF 68 pF 82 pF 1.25± 0.2 1.25± 0.2 100 pF 1.25± 0.2 1.25± 0.2 120 pF 150 pF 180 pF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Oct. 26, 2021 V.14 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 7 20 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR NP0 Table 5 Sizes from 1808 to 1812 (continued) CAP. 1812 1 KV 2 KV 3 KV 500 V 630 V 1 KV 2 KV 220 pF 3 KV 1.25± 0.2 270 pF 330 pF 390 pF 1.25± 0.2 1.25± 0.2 470 pF 560 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 680 pF 820 pF 1.0 nF 1.2 nF 1.5 nF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Oct. 26, 2021 V.14 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 8 20 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR X7R Table 6 Sizes from 0805 to 1210 0805 CAP. 500 V 630 V 1 KV 1206 500 V 1210 630 V 1 KV 2 KV 2.5KV 500 V 630 V 1 KV 2 KV 100 pF 150 pF 220 pF 330 pF 0.85± 0.1 470 pF 1.25± 0.2 1.25± 0.2 680 pF 1.0 nF 0.85± 0.1 0.85± 0.1 1.6± 0.2 1.5 nF 2.2 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.60± 0.2 3.3 nF 4.7 nF 6.8 nF 10 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 15 nF 1.25± 0.2 22 nF 33 nF 1.60± 0.2 1.6± 0.2 1.60± 0.2 2.0± 0.2 47 nF 68 nF 100 nF 1.6± 0.2 2.0± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For products with 5% tolerance, please contact local sales force before ordering www.yageo.com Oct. 26, 2021 V.14 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 9 20 500 V to 3 KV CAPACITANCE RANGE & THICKNESS FOR X7R Table 7 Sizes from 1808 to 1812 1808 CAP. 1 KV 1812 2 KV 3 KV 500 V 2020 630 V 1 KV 2 KV 3 KV 630 V 100 pF 150 pF 220 pF 330 pF 1.6± 0.2 470 pF 680 pF 1.35± 0.15 1.0 nF 1.5 nF 1.35± 0.15 2.2 nF 1.6± 0.2 2.0± 0.2 1.6± 0.2 1.35± 0.15 3.3 nF 4.7 nF 6.8 nF 10 nF 1.35± 0.2 1.6± 0.2 1.35± 0.15 1.25± 0.2 15 nF 22 nF 33 nF 1.6± 0.2 47 nF 1.35± 0.2 68 nF 100 nF 1.6± 0.2 150 nF 220 nF 2.0± 0.2 330 nF 470 nF 680 nF 1 µF NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request 3. For products with 5% tolerance, please contact local sales force before ordering www.yageo.com Oct. 26, 2021 V.14 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV 10 20 THICKNESS CLASSES AND PACKING QUANTITY Table 8 Ø 180 MM / SIZE CODE THICKNESS CLASSIFICATION 7 INCH 13 INCH QUANTITY Blister Paper Blister PER BULK CASE R P 8 mm 4,000 --- 20,000 --- 10,000 R P 8 mm 4,000 --- 15,000 --- 8,000 1.00 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 --- 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 5,000 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- --- 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- --- 1.00 / 1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 --- 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 --- 1.6 ± 0.2 mm K F 8 mm --- 2,000 --- 8,000 --- 0.85 ± 0.1 mm K F 8 mm --- 4,000 --- 10,000 --- 1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 --- 1.15 ± 0.15 mm K F 8 mm --- 3,000 --- 10,000 --- 1.25 ± 0.2 mm K 8 mm --- 3,000 --- --- --- 1.5 ± 0.1 mm K 8 mm --- 2,000 --- --- --- 1.6± 0.2 mm K 8 mm --- 2,000 --- --- --- 8 mm --- 2,000 1,000 --- --- --- 8 mm --- 1,000 500 --- --- --- 2.0 ± 0.2 mm 2.5 ± 0.2 mm 1812 Paper 0.6 ± 0.1 mm 1210 1808 7 INCH 13 INCH TAPE WIDTH QUANTITY PER REEL 0.85 ± 0.1 mm 0805 1206 PACKING CODE. Ø 330 MM / K K 1.15 ± 0.15 mm K 12 mm --- 3,000 --- --- --- 1.25 ± 0.2 mm K 12 mm --- 3,000 --- --- --- 1.35 ± 0.15 mm K 12 mm --- 2,000 --- --- --- 1.5 ± 0.1 mm K 12 mm --- 2,000 --- --- --- 1.6 ± 0.2 mm K 12 mm --- 2,000 --- --- --- 2.0 ± 0.2 mm K 12 mm --- 2,000 --- --- --- 0.6 / 0.85 ± 0.1 mm K 12 mm --- 2,000 --- --- --- 1.15 ± 0.1 mm K 12 mm --- 1,000 --- --- --- 1.15 ± 0.15 mm K 12 mm --- 1,000 --- --- --- 1.25 ± 0.2 mm K 12 mm --- 1,000 --- --- --- 1.35 ± 0.15 mm K 12 mm --- 1,000 --- --- --- 1.5 ± 0.1 mm K 12 mm --- 1,000 --- --- --- 1.6 ± 0.2 mm K 12 mm --- 1,000 --- --- --- 2.0 ± 0.2 mm K 12 mm --- 1,000 --- --- --- 2.5 ± 0.2 mm K 12 mm --- 500 --- --- --- 2.0 ± 0.2 mm K 12 mm --- 1000 --- --- --- 2220 www.yageo.com Oct. 26, 2021 V.14 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 11 20 500 V to 3 KV PAPER/PE TAPE SPECIFICATION P0 D0 T P2 E F cover tape W B0 K0 A0 P1 MBG251-1 Fig. 3 Paper/PE tape Table 9 Dimensions of paper/PE tape for relevant chip size; see Fig.3 SIZE Unit: mm SYMBOL CODE A0 B0 W E F P0 (1) P1 P2 Ø D0 K0 T 0.38 ± 0.05 (0.47 / 0.55)±0.10 0201 0.39 ± 0.06 0.70 ± 0.06 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.55 ± 0.03 0402 0.70 ± 0.15 1.21 ± 0.12 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.50 +0.1 /-0 (0.75 / 0.60)±0.10 (0.85 / 0.70)±0.10 0603 1.05 ± 0.14 1.86 ± 0.13 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 0805 1.50 ± 0.15 2.26 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 1206 1.90 ± 0.15 3.50 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (0.95 / 0.75)±0.10 (1.05 / 0.85)± 0.10 NOTE 1. P0 pitch tolerance over any 10 pitches is 0.2 mm www.yageo.com Oct. 26, 2021 V.14 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 12 20 500 V to 3 KV BLISTER TAPE SPECIFICATION P0 D0 K0 P2 E F cover tape W B0 A0 T2 SCM015 D1 P1 K0: so chosen that the orientation of the component cannot change For W = 8 mm: T2 = 3.5 mm max. For W = 12 mm: T2 = 6.5 mm max. direction of unreeling Fig. 4 Blister tape Table 10 Dimensions of blister tape for relevant chip size; see Fig.4 SYMBOL SIZE A0 B0 CODE Unit: mm K0 W E F Min. Max. Min. Max. Min. Max. Ø D0 Ø D1 P0 (2) P1 P2 T2 Min. Min. Max. 0805 1.29 1.65 2.09 2.60 1.25 1.62 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.30 1.67 1206 1.65 2.12 3.30 3.75 1.22 2.15 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.27 2.20 1210 2.55 3.02 3.31 3.88 0.97 2.92 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.02 2.97 1808 2.05 2.55 4.80 5.45 1.30 2.45 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.35 2.50 1812 3.35 3.75 4.70 5.33 0.70 2.40 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 0.75 2.45 2220 5.12 5.32 5.84 6.04 1.28 1.48 12.0 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 1.33 1.53 NOTE 1. Typical capacitor displacement in pocket 2. P0 pitch tolerance over any 10 pitches is ±0.2 mm www.yageo.com Oct. 26, 2021 V.14 Product specification Surface-Mount Ceramic Multilayer Capacitors High-Voltage NP0/X7R 500 V to 3 KV 13 20 REEL SPECIFICATION W2 C N A HBK039 W1 Fig. 5 Reel Table11 Reel dimensions; see Fig.5 TAPE WIDTH SYMBOL Unit: mm A N C W1 W2max. 8 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 9.4 ± 1.5 14.4 8 (Ø 330 mm/13") 330 ± 1.0 100 ± 1.0 13 +0.50/-0.20 9.0 ± 0.2 14.4 12 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 13.4 ± 1.5 18.4 P ROPERTIES OF REEL Material: polystyrene Surface resistance:
CC1812KKX7RDBB102 价格&库存
很抱歉,暂时无法提供与“CC1812KKX7RDBB102”相匹配的价格&库存,您可以联系我们找货
CC1812KKX7RDBB102
  • 5+1.67609
  • 50+1.44609
  • 200+1.34750
  • 400+1.32729
  • 1000+1.22451
库存:4151
