MCP100JR-1K8
MCP100JR-1K8
    YAGEO(国巨)
    MELF_D2.2X5.9MM_SM
    贴片电阻 0207 1.8KΩ ±5% 1W 0/-350ppm/℃
MCP100JR-1K8 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET MELF CARBON FILM RESISTORS High Power MCP Series ±2%, ±5% 1W AND 2W Product specification – August 24, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors Melf Carbon Film Resistors Product Specification ORDERING INFORMATION Part number of the power MELF carbon film resistor is identified by the series, power rating, tolerance, packing, temperature coefficient and resistance value. PART NUMBER APPLICATIONS  All general purpose applications  Power applications  Energy meter MCP 100 J R - 100R (1) (2) (3) (4) (5) (6) (1) SERIES MCP Series (2) POWER RATING 100 = 1W FEATURES 200 = 2W (3) TOLERANCE  MELF, SMD package G = ±2%  Excellent pulse withstanding capability J = ±5%  Ultra miniature size (4) PACKAGING  Higher power rating R = Reel Pack  RoHS compliant & halogen-free - = Based on spec. (5) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (6) RESISTANCE VALUE E24 Series value Example: 1R = 1Ω, 10K = 10,000Ω, 1M = 1,000,000Ω www.yageo.com Aug. 24, 2021 V.0 2 8 MCP Through Hole Resistors Product Specification Melf Carbon Film Resistors 8 MCP DIMENSIONS Unit: mm Ultra Miniature L D C Min. MCP100 5.9 ± 0.2 2.2 ± 0.1 0.5 MCP200 8.5 ± 1.0 3.0± 0.2 0.5 SUGGESTED PAD LAYOUT Unit: mm Ultra Miniature Soldering Mode L Min. P W Min. Reflow 2.0 3.0 ± 0.1 3.0 Wave 2.5 3.0 ± 0.1 3.0 Reflow 2.3 5.5 ± 0.2 4.0 Wave 2.8 5.5 ± 0.2 4.0 MCP100 MCP200 DERATING CURVE Rated Power (%) 100 80 60 40 20 20 40 70 100 155 Ambient Temperature (°C) TABLE I TEMPERATURE COEFFICIENT TYPE MAX. VALUE OF TEMP. COEFFICIENT PPM/ °C under 10KΩ 11KΩ – 150KΩ 160KΩ – 1MΩ -350 ~0 -600 ~0 -1000 ~0 MCP100, MCP200 www.yageo.com Aug. 24, 2021 V.0 3 Through Hole Resistors Melf Carbon Film Resistors Product Specification 8 MCP ELECTRICAL CHARACTERISTICS CHARACTERISTICS MCP100 MCP200 Power Rating at 70 °C 1W 2W Maximum Working Voltage 300V 350V Maximum Overload Voltage 600V 700V Voltage Proof on Insulation 500V 500V Resistance Range 1Ω ~ 1MΩ & 0Ω for E24 series value Operating Temp. Range - 55°C to +155°C Temperature Coefficient see Table I Note: For resistance value out of above range is by request. TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 PROCEDURE 2.5 times RCWV for 5 sec.(Not more than APPRAISE ±1.0%+0.05Ω maximum overload voltage) Voltage Proof on IEC 60115-1 4.7 Insulation In V-Block for 60 sec. test voltage as No Breakdown above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >10,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, ±1.0%+0.05Ω 25 Sec.off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±5.0%+0.05Ω with 0.1 times RCWV Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±3.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19  -55°C  Room Temp.  ±0.75%+0.05Ω +155°C Room Temp.(5 cycles) Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body www.yageo.com Aug. 24, 2021 V.0 4 Through Hole Resistors Melf Carbon Film Resistors Product Specification 8 MCP Note: RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) PACKING TYPE Unit: piece Ultra Miniature Packaging Quantity Per Reel MCP100 7” 2,000 MCP200 13” 2,500 www.yageo.com Aug. 24, 2021 V.0 5 Through Hole Resistors Melf Carbon Film Resistors Product Specification 8 MCP MARKING 3-BAND-CODE ±2%, ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100K 1MΩ 10MΩ 0.001Ω 0.0001Ω 0.1Ω 0.01Ω www.yageo.com Aug. 24, 2021 V.0 6 Through Hole Resistors Melf Carbon Film Resistors Product Specification 8 MCP REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug. 2 , 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 24, 2021 V.0 7 Through Hole Resistors Melf Carbon Film Resistors Product Specification 8 MCP LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 24, 2021 V.0 8
MCP100JR-1K8 价格&库存
很抱歉,暂时无法提供与“MCP100JR-1K8”相匹配的价格&库存,您可以联系我们找货
