無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。
DATA SHEET
MELF CARBON FILM RESISTORS
High Power
MCP Series
±2%, ±5%
1W AND 2W
Product specification – August 24, 2021 V.0
RoHS compliant & Halogen Free
Through Hole Resistors
Melf Carbon Film Resistors
Product Specification
ORDERING INFORMATION
Part number of the power MELF carbon film resistor is identified by the
series, power rating, tolerance, packing, temperature coefficient and
resistance value.
PART NUMBER
APPLICATIONS
All general purpose
applications
Power applications
Energy meter
MCP
100
J
R
100R
(1)
(2)
(3)
(4)
(5)
(6)
(1) SERIES
MCP Series
(2) POWER RATING
100 = 1W
FEATURES
200 = 2W
(3) TOLERANCE
MELF, SMD package
G = ±2%
Excellent pulse withstanding
capability
J = ±5%
Ultra miniature size
(4) PACKAGING
Higher power rating
R = Reel Pack
RoHS compliant &
halogen-free
- = Based on spec.
(5) TEMPERATURE COEFFICIENT OF RESISTANCE
- = Based on spec.
(6) RESISTANCE VALUE
E24 Series value
Example:
1R = 1Ω, 10K = 10,000Ω, 1M = 1,000,000Ω
www.yageo.com
Aug. 24, 2021
V.0
2
8
MCP
8
MCP
DIMENSIONS
Unit: mm
Ultra Miniature
L
D
C Min.
MCP100
5.9 ± 0.2
2.2 ± 0.1
0.5
MCP200
8.5 ± 1.0
3.0± 0.2
0.5
SUGGESTED PAD LAYOUT
Unit: mm
Ultra Miniature Soldering Mode
L Min.
P
W Min.
Reflow
2.0
3.0 ± 0.1
3.0
Wave
2.5
3.0 ± 0.1
3.0
Reflow
2.3
5.5 ± 0.2
4.0
Wave
2.8
5.5 ± 0.2
4.0
MCP100
MCP200
DERATING CURVE
Rated Power (%)
100
80
60
40
70
100
155
Ambient Temperature (°C)
TABLE I TEMPERATURE COEFFICIENT
TYPE
MAX. VALUE OF TEMP. COEFFICIENT PPM/ °C
under 10KΩ
11KΩ – 150KΩ
160KΩ – 1MΩ
-350 ~0
-600 ~0
-1000 ~0
MCP100, MCP200
www.yageo.com
Aug. 24, 2021
V.0
3
8
MCP
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS
MCP100
MCP200
Power Rating at 70 °C
1W
2W
Maximum Working Voltage
300V
350V
Maximum Overload Voltage
600V
700V
Voltage Proof on Insulation
500V
500V
Resistance Range
1Ω ~ 1MΩ & 0Ω for E24 series value
Operating Temp. Range
- 55°C to +155°C
Temperature Coefficient
see Table I
Note: For resistance value out of above range is by request.
TEST AND REQUIRMENTS
TEST
TEST METHOD
Short Time Overload
IEC 60115-1 4.13
PROCEDURE
2.5 times RCWV for 5 sec.(Not more than
APPRAISE
±1.0%+0.05Ω
maximum overload voltage)
Voltage Proof on
IEC 60115-1 4.7
Insulation
In V-Block for 60 sec. test voltage as
No Breakdown
above table
IEC 60115-1 4.8
Between -55°C to +155°C
By Type
Insulation Resistance
IEC 60115-1 4.6
>10,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
Marking
coatings and markings
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on,
±1.0%+0.05Ω
25 Sec.off)
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C,90-95% RH for 56 days, loaded
±5.0%+0.05Ω
with 0.1 times RCWV
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV(or Umax., whichever
±3.0%+0.05Ω
less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off)
Temperature Cycling
IEC 60115-1 4.19
-55°C
Room Temp.
±0.75%+0.05Ω
+155°C Room Temp.(5 cycles)
Resistance to Soldering
Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a
±1.0%+0.05Ω
point 3±0.5mm from the body
www.yageo.com
Aug. 24, 2021
V.0
4
8
MCP
Note:
RCWV (Rated Continuous Working Voltage ):
The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following
formula:
V=√(P X R)
or max. working voltage whichever is less
Where
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (Ω)
PACKING
TYPE
Unit: piece
Ultra Miniature
Packaging
Quantity Per Reel
MCP100
7”
2,000
MCP200
13”
2,500
www.yageo.com
Aug. 24, 2021
V.0
5
8
MCP
MARKING
3-BAND-CODE
±2%, ±5%
COLOR
BLACK
BROWN
RED
ORANGE
YELLOW
GREEN
BLUE
VIOLET
GREY
WHITE
GOLD
SILVER
1st BAND
2
3
4
5
6
7
8
9
2nd BAND
2
3
4
5
6
7
8
9
MULTIPLIER
1Ω
10Ω
100Ω
1KΩ
10KΩ
100K
1MΩ
10MΩ
0.001Ω
0.0001Ω
0.1Ω
0.01Ω
www.yageo.com
Aug. 24, 2021
V.0
6
8
MCP
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 0
Aug. 2 , 2021
- First issue of this specification
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as
the products itse lf are unchanged. Any product change will be announced by PCN.”
www.yageo.com
Aug. 24, 2021
V.0
7
8
MCP
LEGAL DISCLAIMER
Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors,
inaccuracies or incompleteness contained in any product related information, including but not limited to product
specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or
improvements to product related information at any time and without notice.
Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular
purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo
disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability,
including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties,
including warranties of fitness for a particular purpose, non-infringement and merchantability.
Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s
knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are
neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a
specific customer application or use. They are intended for use only by customers with requisite knowledge and
experience for determining whether Yageo products are the correct products for their application or use. In
addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or
use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective
safeguard measures to ensure that product failure would not result in personal injury or property damage.
Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for
any other application or use in which the failure of Yageo products could result in personal injury or death.
Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at
their own risk and agree to fully indemnify Yageo and hold Yageo harmless.
Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this
content without further notification, as long as products are unchanged. Any product change will be announced by PCN.
www.yageo.com
Aug. 24, 2021
V.0
8
