DIPPED RADIAL LEAD MULTILAYER CERAMIC CAPACITORS
NTD
Series
RoHS2
RoHS
Compliant
◆FEATURES
1. Small in size and wide capacitance range.
Max. 470µF is available.
2. Temperature characteristic is X7R in EIA code.
3. Superior humidity characteristic and long life.
4. Excellent high frequency characteristic due to low ESR.
5. High rated ripple current.
6. 250Vdc items are available.
7. Resin(UL94 V-0) used for coating.
8. Pb-free design(also ceramic dielectric)
◆APPLICATIONS
1. Smoothing circuit of switching mode AC-DC or DC-DC converter.
2. Noise suppressor for various kinds of equipments.
3. By-pass or decoupling circuits.
4. Automotive equipments.
◆CONSTRUCTION
Coating Resin
Ceramic
Dielectric
Termination
Solder (Pb-free)
Internal Electrode
Lead Wire
◆RATINGS
1.
2.
3.
4.
5.
6.
Category Temperature Range
Rated Voltage Range
Rated Capacitance Range
Rated Capacitance Tolerance
Temperature Characteristics
Rated Ripple Current
-55 to +125℃
25, 35, 50, 100, 250, 500Vdc
0.1 to 470µF
M(±20%)
X7R
See No.5 on the following table
◆SPECIFICATIONS
No.
1
Items
Withstand
Voltage
Between
Terminals
Specification
No abnormality.
Terminals to
Coating Resin
Test Condition
Rated voltage
Withstand voltage
Less than 250V
250% of rated voltage
More than 250V
Less than 500V
100V +
150% of rated voltage
More than 500V
130% of rated voltage
Shall be applied for 5 seconds.
2
Insulation Resistance
100/CR(MΩ) or 4000(MΩ)
whichever is less.
3
Rated Capacitance
Within specified tolerance.
Rated voltage shall be applied for 60±5 seconds at
temperature 25±2℃.
Temperature
4
Dissipation Factor
CR>10µF
CR≦10µF
5.0% maximum.
25±2℃
Frequency
1±0.1kHz
120±12Hz
Voltage
1±0.2Vrms
0.5±0.2Vrms
As customer requirement, Chemi-Con has submits the test results according to AEC-Q200 for Multilayer ceramic
capacitors. Please contact us for more information.
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
28
CAT. No. E1002Z
NTD
Series
◆SPECIFICATIONS
No.
Items
Specification
Test Condition
5
See STANDARD RATINGS
10kHz to 1MHz (sine curve)
Ripple voltage Vp shall be less than the rated voltage.
6
Robustness Tension
of
Terminations
No visible damage.
The force applied shall be :
Bending
Lead φ (mm)
0.5 max.
0.6 min.
Tensile(N)
5
10
Lead φ (mm)
Bending(N)
0.5 max.
0.6 min.
(sec.)
10±1
10±1
(kg)
2.5
5
0.25
0.51
Time : 2times.
7
Vibration
Appearance : No abnormality.
Capacitance : To meet the initial
specification.
D.F. : To meet the initial specification.
8
Solderability
Min. 75% of surface of the termination
shall be covered with new solder.
9
Resistance to Soldering Heat
10
Temperature Cycle
11
Humidity Load Life
ΔC/C :±20%
D.F. : 10% maximum
I.R. : 25/CR(MΩ) or 1000(MΩ)
whichever is less.
Temperature : 40±2℃
Humidity
: 90 to 95%RH
Voltage
: Rated voltage
Time
: 500± 24
hours
Endurance
ΔC/C :±20%
D.F. : 10% maximum
I.R. : 50/CR(MΩ) or 1000(MΩ)
whichever is less.
Temperature : 125±3℃
Voltage
: Rated voltage
Time
: 1000± 48
0 hours
Amplitude
: 1.5mm
Frequency range
: 10-55-10Hz (1 min)
Direction and time :
2 hours each to X, Y, Z axis. Total 6 hours.
Solder
Solder Temperature
Dipping Time
Pb Free
245±5℃
2±0.5sec.
ΔC/C :±15%
I.R. : To meet the initial specification.
Solder Temperature : 350±10℃
Dipping Time
: 3±0.5 sec.
Depth
: 1.5 to 2mm
ΔC/C :±15%
Temperature (℃)
Step
Min. Category temperature ±3
1
Room temperature
2
3
Max. Category temperature ±3
4
Room temperature
For 5 cycles for above temperature cycle.
(min.)
30±3
3 max.
30±3
3 max.
*CR : Rated Capacitance(µF)
29
CAT. No. E1002Z
NTD
Series
◆STANDARD RATINGS
Rated voltage Rated Capacitance
(Vdc)
(µF)
25
35
50
100
3.3
4.7
6.8
10
15
15
22
33
47
68
100
150
220
330
470
3.3
4.7
6.8
10
15
22
33
47
1.0
1.5
2.2
3.3
4.7
6.8
10
15
22
33
47
68
100
150
220
0.33
0.47
0.68
1.0
1.5
2.2
1.5
2.2
3.3
4.7
3.3
4.7
6.8
6.8
10
15
22
33
47
68
100
Lmax.
Wmax.
Tmax.
F±0.8
φd±0.05
Maximum
ripple current
(Arms)
5.0
6.0
3.5
5.0
0.5
0.3
6.5
6.5
4.0
5.0
0.5
0.8
7.5
9.0
4.5
5.0
0.5
1.0
10.0
11.5
13.5
15.0
22.5
20.0
28.5
20.0
5.5
6.0
8.0
6.0
8.0
8.0
11.5
5.0
6.0
6.5
7.5
Dimensions (mm)
5.0
0.5
1.5
10.0
0.6
2.0
20.0
0.8
3.0
25.0
0.8
4.0
3.5
5.0
0.5
0.3
6.5
4.0
5.0
0.5
0.8
9.0
4.5
5.0
0.5
1.0
10.0
11.5
5.0
5.5
5.0
0.5
1.5
5.0
6.0
3.5
5.0
0.5
0.3
6.5
6.5
4.0
5.0
0.5
0.8
7.5
9.0
4.5
5.0
0.5
1.0
10.0
13.5
11.5
15.0
5.0
5.5
5.0
10.0
0.5
0.6
1.5
2.0
22.5
20.0
20.0
0.8
3.0
28.5
20.0
25.0
0.8
4.0
5.0
6.0
3.5
5.0
0.5
0.3
6.5
6.5
4.0
5.0
0.5
0.8
7.5
9.0
5.0
0.5
1.0
10.0
11.5
5.0
0.5
1.5
13.5
15.0
10.0
0.6
2.0
22.5
20.0
20.0
0.8
3.0
28.5
20.0
25.0
0.8
4.0
6.0
7.0
7.5
10.0
4.5
4.7
5.0
5.0
6.0
6.0
7.5
9.0
Part Number
Taping
Quantity per reel
(pcs. / box)
KTD250B335M32A0T00
KTD250B475M32A0T00
KTD250B685M43A0T00
KTD250B106M43A0T00
KTD250B156M43A0T00
KTD250B156M55A0T00
KTD250B226M55A0T00
KTD250B336M55A0T00
KTD250B476M76A0T00
KTD250B686M80A0B00
KTD250B107M80A0B00
KTD250B157M90A0B00
KTD250B227M90A0B00
KTD250B337M99A0B00
KTD250B477M99A0B00
KTD350B335M32A0T00
KTD350B475M32A0T00
KTD350B685M43A0T00
KTD350B106M43A0T00
KTD350B156M55A0T00
KTD350B226M55A0T00
KTD350B336M76A0T00
KTD350B476M76A0T00
KTD500B105M32A0T00
KTD500B155M32A0T00
KTD500B225M32A0T00
KTD500B335M32A0T00
KTD500B475M43A0T00
KTD500B685M43A0T00
KTD500B106M55A0T00
KTD500B156M55A0T00
KTD500B226M76A0T00
KTD500B336M80A0B00
KTD500B476M90A0B00
KTD500B686M90A0B00
KTD500B107M90A0B00
KTD500B157M99A0B00
KTD500B227M99A0B00
KTD101B334M32A0T00
KTD101B474M32A0T00
KTD101B684M32A0T00
KTD101B105M32A0T00
KTD101B155M32A0T00
KTD101B225M32A0T00
KTD101B155M43A0T00
KTD101B225M43A0T00
KTD101B335M43A0T00
KTD101B475M43A0T00
KTD101B335M55A0T00
KTD101B475M55A0T00
KTD101B685M55A0T00
KTD101B685M76A0T00
KTD101B106M80A0B00
KTD101B156M80A0B00
KTD101B226M90A0B00
KTD101B336M90A0B00
KTD101B476M99A0B00
KTD101B686M99A0B00
KTD101B107M99A0B00
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
1,000
2,000
2,000
2,000
2,000
2,000
2,000
1,000
1,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
1,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
1,000
30
CAT. No. E1002Z
1.5
2.2
1.5
2.2
3.3
4.7
3.3
4.7
6.8
6.8
10
15
22
Series
33
47
68
100
0.1
0.15
0.22
0.33
0.47
0.68
1.0
1.5
2.2
2.2
3.3
4.7
6.8
10
15
0.47
0.56
0.68
1.0
1.2
DIPPED RADIAL
LEAD4.5 MULTILAYER
CERAMIC
CAPACITORS
7.5
9.0
5.0
1.0
0.5
NTD
250
500
10.0
11.5
13.5
15.0
22.5
20.0
28.5
20.0
5.0
6.0
6.5
6.5
4.7
5.0
5.0
6.0
5.0
0.5
1.5
10.0
0.6
2.0
20.0
0.8
3.0
25.0
0.8
4.0
3.5
5.0
0.5
0.3
4.0
5.0
0.5
0.8
6.0
7.5
9.0
7.5
9.0
4.5
5.0
0.5
1.0
10.0
13.5
11.5
15.0
6.0
5.0
5.0
10.0
0.5
0.6
1.5
2.0
22.5
20.0
6.0
20.0
0.8
3.0
28.5
20.0
7.5
25.0
0.8
4.0
7.5
9.0
3.5
5.0
0.5
0.8
11.5
3.4
3.8
4.2
5.0
0.5
1.0
10.0
※Please consult with us when you consider the rating other than a standard table.
2
3
4
5
6
7
8
9
10
11
12
13
14
15
◆DIMENSIONS
16
Crimped lead
32 to 76 Size
17 18
K TD 5 0 0 B 1 0 6 M 5 5 A0 T 0 0
L
T
W
L
F
15min.
Supplement code
Taping code
Terminal code
Size code
Capacitance tolerance code
Nominal Capacitance code
Temperature characteristics code
Rated voltage code
Series code
Category
Straight lead
For all size
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
1,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
1,000
2,000
2,000
1,500
1,500
1,500
T
W
◆PART NUMBERING SYSTEM
F
d
15min.
100
1
KTD101B155M32A0T00
KTD101B225M32A0T00
KTD101B155M43A0T00
KTD101B225M43A0T00
KTD101B335M43A0T00
KTD101B475M43A0T00
KTD101B335M55A0T00
KTD101B475M55A0T00
KTD101B685M55A0T00
KTD101B685M76A0T00
KTD101B106M80A0B00
KTD101B156M80A0B00
KTD101B226M90A0B00
KTD101B336M90A0B00
KTD101B476M99A0B00
KTD101B686M99A0B00
KTD101B107M99A0B00
KTD251B104M32A0T00
KTD251B154M32A0T00
KTD251B224M32A0T00
KTD251B334M32A0T00
KTD251B474M43A0T00
KTD251B684M43A0T00
KTD251B105M55A0T00
KTD251B155M55A0T00
KTD251B225M76A0T00
KTD251B225M80A0B00
KTD251B335M90A0B00
KTD251B475M90A0B00
KTD251B685M99A0B00
KTD251B106M99A0B00
KTD251B156M99A0B00
KTD501B474M55A0T00
KTD501B564M55A0T00
KTD501B684M76A0T00
KTD501B105M76A0T00
KTD501B125M76A0T00
d
Please refer to"Part Numbering System" of the beginning of a catalog for the details.
31
CAT. No. E1002Z
