CX0805MRX7R9BB223
CX0805MRX7R9BB223
    YAGEO(国巨)
    贴片电容(MLCC) 0805 22nF ±20% 50V X7R
CX0805MRX7R9BB223 数据手册
Ru. DATA SHEET SURFACE-MOUNT CERAMIC EMI FILTER CAPACITORS X2Y® Series Product Specification – Nov. 10, 2008 V.13 6.3 V TO 100 V Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series DESCRIPTION X2Y® series is a breakthrough in the design of ceramic multilayer products for decoupling and filtering in an IPD (integrated passive device). X2Y® products comprise two identical Y-capacitors and one X-capacitor, integrated into a 4 terminal device, which is available in standard MLCC sizes. Thanks to the unique multilayer construction the device provides noise cancellation within the device, reducing ESL from nanohenry to picohenry levels. Using the unique balance between the Y-capacitors and the shielded multilayer structure the X2Y® products offer superior decoupling and filtering. The X2Y® device performs as a broadband filter enabling better EMC compliance for electrical equipment in a wide range of applications. FEATURES BENEFITS • Broadband Filtering and Decoupling: X2Y® is effective up to 10 GHz and frequencies beyond • Fewer Component in Filtering: One X2Y® can replace multiple inductors and/or capacitors • Ultra Low ESL: Noise cancellation within X2Y® makes ESL reducing from nanohenry to picohenry levels • Superior Performance in Filtering: One X2Y® can eliminate both differential and common mode noises • Bypass: Unlike feedthrough capacitors, X2Y® is in bypass, so no DC current limitations • Fewer Component in Decoupling: Up to 1:7 replacement of MLCC in power delivering system bypass networks • Matched Y-caps: Two tightly matched line to ground capacitors in one device • Superior Performance in Decoupling: Large or small, X2Y® components exhibit ultra low ESL • Superior Balance: Temperature and voltage variations balanced of two Y-caps • Total Cost Savings: Assembly cost savings through reduced component count and placement costs • Aging Reliability: Aging effects are equal on two Ycaps • Board Level Design Advantages: Dramatically reduces via drills, which blocks routing APPLICATIONS • EMI filtering on DC motors • Filtered connectors (airbag connectors, RJ-45 connectors) SCM049_V • High speed data-line filtering • Decoupling of supply-lines in high speed digital circuits • Broadband filtering. • Amplifier decoupling and EMI suppression. • IC Decoupling, on-package, onPCB. A A G1 A G2 G2 G2 G1 B B B Decoupling application G1 EMI filtering application • DC power line filtering. Fig.1 • Data line filtering. Circuit of typical applications • EMI suppression for DC motors. • Sensors • Audio 2008 Nov. 10 V.13 2 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series QUICK REFERENCE DATA DESCRIPTION VALUE Materials NPO / X7R / X5R Rated voltage NPO 50 / 63 V X7R 10 V, 16 V, 25 V, 50 / 63 V, 100 V (IEC) X5R 6.3 V, 10V Capacitance range (Y-capacitor) NPO 0805 series 22 pF, 47 pF X7R 0603 series 1.0 nF to 100 nF 0805 series 4.7 nF to 180 nF 1206 series 15 nF to 820 nF 1210 series 47 nF to 1 µF 1410 series 390 nF 0603 series 220 nF to 470 nF X5R Tolerance on capacitance ±20% (M) Test voltage (DC) for 1 minute 2.5 × Ur Sectional specifications IEC 60384-10, second edition 1989-04; also based on CECC 32 100 Detailed specification based on IEC 60384-10-1 Climatic category (IEC 60068) X7R: 55 / 125 / 56 2008 Nov. 10 V.13 3 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series GENERAL SELECTION CHART C (pF) NPO 0805 X7R 0603 0805 1206 X5R 1210 1410 0603 10 22 47 50 V 100 220 330 1,000 1, 500 2, 200 100 V 4, 700 5, 600 10, 000 50 V / 63 V 15,000 18 ,000 25 V 22 ,000 180, 000 100 V 16 V 50 V / 63 V 16 V 56 ,000 100, 000 50 V / 63 V 25 V 39 ,000 47 ,000 100 V 10 V 10 V 25 V 220, 000 270, 000 50 V / 63 V 10 V 16 V 330, 000 390, 000 25 V 470, 000 50 V 6.3 V 10 V 560, 000 820, 000 16 V 1 000, 000 2008 Nov. 10 V.13 100 V 4 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series MECHANICAL DATA L SCM051 A ground W equivalent circuit configuration line line Cy C ground Cx Cy T line line Component type Simplified type For dimensions see Table 1. Fig.2. Component outline & simplified outline Physical dimensions Table 1 Capacitor dimensions CASE SIZE L W T A MIN. MAX. MIN. MAX. C Dimensions in millimetres 0603 1.6 ±0.15 0.85 ±0.15 0.55 0.75 0.25 0.55 0.40 ±0.20 0805 2.0 ±0.15 1.25 ±0.15 0.75 0.95 0.25 0.55 0.70 ±0.20 1206 3.2 ±0.20 1.65 ±0.20 1.10 1.40 0.25 0.65 1.20 ±0.30 1210 3.2 ±0.20 2.5 ±0.20 1.10 1.70 0.25 0.65 1.20 ±0.30 1410 3.56 ±0.20 2.5 ±0.20 1.10 1.50 0.25 0.65 1.20 ±0.30 Dimensions in inches 0603 0.063 ±0.006 0.032 ±0.006 0.022 0.030 0.010 0.022 0.016 ±0.008 0805 0.079 ±0.006 0.049 ±0.006 0.030 0.037 0.010 0.022 0.028 ±0.008 1206 0.126 ±0.008 0.065 ±0.008 0.043 0.055 0.010 0.026 0.047 ±0.012 1210 0.126 ±0.008 0.098 ±0.008 0.043 0.067 0.010 0.026 0.047 ±0.012 1410 0.140 ±0.008 0.098 ±0.008 0.043 0.059 0.010 0.026 0.047 ±0.012 2008 Nov. 10 V.13 5 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series ELECTRICAL CHARACTERISTICS FOR NPO Class 1 capacitors; NPO dielectric; NiSn terminations VALUE DESCRIPTION Rated voltage Ur (DC) 50 V Capacitance range 22 pF, 47pF Capacitance tolerance ±20% Tanδ; note 1 ≤ 10 x 10-4 Insulation resistance after 1 minute at Ur (DC) Rins > 10 GΩ Temperature Coefficient (0 ± 30) x 10-6 / K Note 1. Measured at 20 °C, 1 V and 1 MHz, using a four-gauge method. ELECTRICAL CHARACTERISTICS FOR X7R / X5R Class 2 capacitors; X7R / X5R dielectric; NiSn terminations Unless otherwise stated all electrical values apply at an ambient temperature of 20 ±1 °C, an atmospheric pressure of 86 to 106 kPa, and a relative humidity of 63 to 67%. VALUE DESCRIPTION Rated voltage Ur (DC) 6.3 V, 10 V, 16 V, 25 V, 50 V/63 V and 100 V Capacitance range 1.0 nF to 1 µF Tolerance on capacitance after 1,000 hours ±20% Dissipation factor (D.F.); note 1 6.3 V 7% 10 V 7% 16 V 7% ≥ 25 V 5% Insulation resistance after 1 minute at Ur (DC) Rins × C > 500 seconds or Rins > 10 GΩ, whichever is less Maximum capacitance change as a function of temperature ±15% Operating temperature range: X5R –55 °C to +85 °C X7R –55 °C to +125 °C Aging Typical 1% per time decade Note 1. Measured at 20 °C, 1 V and 1 kHz, using a four-gauge method. 2008 Nov. 10 V.13 6 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series SELECTION CHART FOR X7R SIZES 0603, 0805, 1206, 1410 (1) Y-CAPACITOR X-CAPACITOR THICKNESS (mm) CTC ORDERING CODE 200 0.60 CX 0603 MR X7R 0BB 102 0.75 200 0.60 CX 0603 MR X7R 0BB 152 100 1.1 200 0.60 CX 0603 MR X7R 0BB 222 4.7 100 2.4 200 0.60 CX 0603 MR X7R 0BB 472 5.6 50 / 63 2.8 100 0.60 CX 0603 MR X7R 9BB 562 10 50 / 63 5 100 0.60 CX 0603 MR X7R 9BB 103 22 25 11 50 0.60 CX 0603 MR X7R 8BB 223 47 16 24 25 0.60 CX 0603 MR X7R 7BB 473 56 16 28 25 0.60 CX 0603 MR X7R 7BB 563 100 10 50 16 0.60 CX 0603 MR X7R 6BB 104 4.7 100 2.4 200 0.85 CX 0805 MR X7R 0BB 472 10 100 5 200 0.85 CX 0805 MR X7R 0BB 103 15 50 / 63 8 100 0.85 CX 0805 MR X7R 9BB 153 18 50 / 63 9 100 0.85 CX 0805 MR X7R 9BB 183 22 25 11 50 0.85 CX 0805 MR X7R 8BB 223 39 25 20 50 0.85 CX 0805 MR X7R 8BB 393 47 16 24 25 0.85 CX 0805 MR X7R 7BB 473 100 16 50 25 0.85 CX 0805 MR X7R 7BB 104 180 10 90 16 0.85 CX 0805 MR X7R 6BB 184 22 100 11 200 1.20 CX 1206 MK X7R 0BB 223 47 50 / 63 24 100 1.20 CX 1206 MK X7R 9BB 473 100 50 / 63 50 100 1.20 CX 1206 MK X7R 9BB 104 180 25 90 50 1.20 CX 1206 MK X7R 8BB 184 220 16 110 25 1.20 CX 1206 MK X7R 7BB 224 390 16 195 25 1.20 CX 1206 MK X7R 7BB 394 470 10 235 20 1.20 CX 1206 MK X7R 6BB 474 820 10 410 20 1.20 CX 1206 MK X7R 6BB 824 47 100 24 200 1.20 CX 1210 MK X7R 0BB 473 100 50/63 50 100 1.20 CX 1210 MK X7R 9BB 104 220 50/63 110 100 1.60 CX 1210 MK X7R 9BB 224 470 25 235 50 1.60 CX 1210 MK X7R 8BB 474 560 25 280 50 1.60 CX 1210 MK X7R 8BB 564 820 16 410 25 1.60 CX 1210 MK X7R 7BB 824 1000 16 500 25 1.60 CX 1210 MK X7R 7BB 105 390 50 195 100 1.30 CX 1410 MK X7R 9BB 394 SIZE CAP. (nF) VOLTAGE RATING (V) CAP. (nF) VOLTAGE RATING (V) 0603 1.0 100 0.5 1.5 100 2.2 0805 1206 1210 1410 2008 Nov. 10 V.13 7 (2) www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series SELECTION CHART FOR X5R SIZES 0603 (1) Y-CAPACITOR X-CAPACITOR SIZE CAP. (nF) VOLTAGE RATING (V) CAP. (nF) VOLTAGE RATING (V) THICKNESS (mm) CTC ORDERING CODE 0603 220 10 110 20 0.60 CX 0603 MR X5R 6BB 224 330 10 165 20 0.60 CX 0603 MR X5R 6BB 334 470 6.3 235 12 0.60 CX 0603 MR X5R 5BB 474 (2) Notes 1. Other values are available on request. 2. Ordering codes for preferred versions (20% tolerance, 180 mm reel). For other packing and tolerance see section “Ordering Code Information”. SELECTION CHART FOR NPO SIZES 0805 (1) Y-CAPACITOR X-CAPACITOR SIZE CAP. (nF) VOLTAGE RATING (V) CAP. (nF) VOLTAGE RATING (V) THICKNESS (mm) CTC ORDERING CODE 0805 0.022 50 0.011 100 0.85 CX 0805 MR NPO 9BB 220 0.047 50 0.023 100 0.85 CX 0805 MR NPO 9BB 470 (2) Notes 1. Other values are available on request. 2. Ordering codes for preferred versions (20% tolerance, 180 mm reel). For other packing and tolerance see section “Ordering Code Information”. THICKNESS CLASSIFICATION AND PACKING QUANTITIES FOR X7R QUANTITY PER REEL THICKNESS CLASSIFICATION (mm) 8 mm TAPE WIDTH Ø180 mm; 7" PAPER BLISTER 0.6 ±0.1 4,000 − 0.85 ±0.1 4,000 − 1.2 ±0.15 − 2,500 1.6 ±0.15 − 2,500 1.9 ±0.2 − 2,500 2008 Nov. 10 V.13 8 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series ORDERING INFORMATION Components may be ordered by using either a Yageo part number or Phycomp’s unique 12NC. Ordering code: Yageo part number Example: CX0805MRX7R8BB223 CX 0805 M X7R R 8 B B 223 Code 1 - 2 Code 7 Code 9 - 11 Code 13 Code 15 - 17 Series name Capacitance tolerance TC Material Termination Capacitance value CX = X2Y® series M = ±20% X7R X5R NP0 B = Ni-Barrier Code 3 - 6 Code 8 Code 12 Code 14 Size code Packing style Rated voltage Process code R = Paper tape reel ∅ 7 inch K = Embossed plastic tape reel ∅ 7 inch 5 = 6.3 V 6 = 10 V 7 = 16 V 8 = 25 V 9 = 50 V 0 = 100 V B = BME EIA 0603 0805 1206 1210 1410 1812 mm (1608M) (2012M) (3216M) (3225M) (3625M) (4632M) 2008 Nov. 10 V.13 (2 significant digits + number of zeros; the third digit signifies the multiplying factor, and letter R is decimal point) 0=x1 1 = x 10 2 = x 102 3 = x 103 4 = x 104 5 = x 105 6 = x 106 SCM045 9 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors Table 2 TC X2Y® Series Conversion table for Yageo part number SIZE CAP. VALUE CAP. TOLERANCE RATED VOLTAGE (V) Y-CAP Y-CAP Y-CAP CTC ORDERING CODE QUANTITY PER REEL X7R 0603 1.0 nF ±20% 100 CX 0603 MR X7R 0BB 102 4,000 X7R 0603 1.5 nF ±20% 100 CX 0603 MR X7R 0BB 152 4,000 X7R 0603 2.2 nF ±20% 100 CX 0603 MR X7R 0BB 222 4,000 X7R 0603 4.7 nF ±20% 100 CX 0603 MR X7R 0BB 472 4,000 X7R 0603 5.6 nF ±20% 50 / 63 CX 0603 MR X7R 9BB 562 4,000 X7R 0603 10 nF ±20% 50 / 63 CX 0603 MR X7R 9BB 103 4,000 X7R 0603 22 nF ±20% 25 CX 0603 MR X7R 8BB 223 4,000 X7R 0603 47 nF ±20% 16 CX 0603 MR X7R 7BB 473 4,000 X7R 0603 56 nF ±20% 16 CX 0603 MR X7R 7BB 563 4,000 X7R 0603 100 nF ±20% 10 CX 0603 MR X7R 6BB 104 4,000 X7R 0805 4.7 nF ±20% 100 CX 0805 MR X7R 0BB 472 4,000 X7R 0805 10 nF ±20% 100 CX 0805 MR X7R 0BB 103 4,000 X7R 0805 15 nF ±20% 50 / 63 CX 0805 MR X7R 9BB 153 4,000 X7R 0805 18 nF ±20% 50 / 63 CX 0805 MR X7R 9BB 183 4,000 X7R 0805 22 nF ±20% 25 CX 0805 MR X7R 8BB 223 4,000 X7R 0805 39 nF ±20% 25 CX 0805 MR X7R 8BB 393 4,000 X7R 0805 47 nF ±20% 16 CX 0805 MR X7R 7BB 473 4,000 X7R 0805 100 nF ±20% 16 CX 0805 MR X7R 7BB 104 4,000 X7R 0805 180 nF ±20% 10 CX 0805 MR X7R 6BB 184 4,000 X7R 1206 22 nF ±20% 100 CX 1206 MK X7R 0BB 223 2,500 X7R 1206 47 nF ±20% 50 / 63 CX 1206 MK X7R 9BB 473 2,500 X7R 1206 100 nF ±20% 50 / 63 CX 1206 MK X7R 9BB 104 2,500 X7R 1206 180 nF ±20% 25 CX 1206 MK X7R 8BB 184 2,500 X7R 1206 220 nF ±20% 16 CX 1206 MK X7R 7BB 224 2,500 X7R 1206 390 nF ±20% 16 CX 1206 MK X7R 7BB 394 2,500 X7R 1206 470 nF ±20% 10 CX 1206 MK X7R 6BB 474 2,500 X7R 1206 820 nF ±20% 10 CX 1206 MK X7R 6BB 824 2,500 X7R 1210 47 nF ±20% 100 CX 1210 MK X7R 0BB 473 2,500 X7R 1210 100 nF ±20% 50 / 63 CX 1210 MK X7R 9BB 104 2,500 X7R 1210 220 nF ±20% 50 / 63 CX 1210 MK X7R 9BB 224 2,500 X7R 1210 470 nF ±20% 25 CX 1210 MK X7R 8BB 474 2,500 X7R 1210 560 nF ±20% 25 CX 1210 MK X7R 8BB 564 2,500 X7R 1210 820 nF ±20% 16 CX 1210 MK X7R 7BB 824 2,500 X7R 1210 1 µF ±20% 16 CX 1210 MK X7R 7BB 105 2,500 X7R 1410 390 nF ±20% 50 CX 0603 MR X5R 9BB 394 2,500 2008 Nov. 10 V.13 10 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors Table 2 TC X2Y® Series Conversion table for Yageo part number SIZE CAP. VALUE CAP. TOLERANCE RATED VOLTAGE (V) Y-CAP Y-CAP Y-CAP CTC ORDERING CODE QUANTITY PER REEL X5R 0603 220 nF ±20% 10 CX 0603 MR X5R 6BB 224 4,000 X5R 0603 330 nF ±20% 10 CX 0603 MR X5R 6BB 334 4,000 X5R 0603 470 nF ±20% 6.3 CX 0603 MR X5R 5BB 474 4,000 NPO 0805 22 pF ±20% 50 CX 0805 MR NPO 9BB 220 4,000 NPO 0805 47 pF ±20% 50 CX 0805 MR NPO 9BB 470 4,000 RECOMMENDED DIMENSIONS OF SOLDER LANDS Table 3 Reflow soldering Footprint dimensions (mm) A B C D E Placement Accuracy (mm) 0603 2.30 0.76 0.64 0.51 1.52 ±0.20 0805 3.05 1.27 0.89 0.56 2.03 ±0.20 1206 4.06 1.65 1.00 1.02 3.05 ±0.25 1210 4.57 2.55 1.00 1.14 4.06 ±0.25 1410 4.57 2.55 1.00 1.14 4.06 ±0.25 CASE SIZE (EIA) A D C E B HBK085 Fig.3 2008 Nov. 10 V.13 Recommended dimensions of solder lands 11 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series MEASUREMENT SETUP network analyzer SCM048 19.2 A 0.8 B 1.6 0.8 G2 G1 B A SCM046 12.55 12.55 25.6 Via Fig.4 • X2Y® series through measurement Ground plane 50 Ω microstrip line with CPW design method X2Y® are soldered on a printed circuit board • PCB: FR-4 substrate, with 50 Ω microstrip line • Network Analyzer: Agilent E5071b Size 0603: A=0.5 mm, B=1.2 mm • Calibration: full 2-port calibration with 85033E kit For other dimensions see Table 4 Fig.5 Table 4 2008 Nov. 10 V.13 12 Testing board for measurement Recommended dimensions of measurement CASE SIZE A (mm) B (mm) 0603 0.5 ±0.10 1.2 ±0.10 0805 0.8 ±0.10 1.6 ±0.10 1206 1.2 ±0.10 2.8 ±0.15 1210 2.1 ±0.15 2.8 ±0.15 1410 2.1 ±0.15 3.1 ±0.15 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series TESTS AND REQUIREMENTS Table 5 Test procedures and requirements TEST METHOD IEC60384-21/22 TEST PROCEDURE REQUIREMENTS 4.3 mounting The capacitors may be mounted on printedcircuit boards or ceramic substrates no visible damage 4.4 visual inspection and dimension check any applicable method using ×10 magnification in accordance with specification 4.5.1 capacitance NP0: within specified tolerance f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C; f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C X5R/X7R/Y5V: f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C 4.5.2 Dissipation factor (D.F.) NP0: f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C; in accordance with specifications f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C X5R/X7R/Y5V: f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C 4.5.3 insulation resistance at Ur (DC) for 1 minute in accordance with specification 4.5.4.2 voltage proof Test voltage (DC) applied for 1 minute Ur ≤ 100 V: 2.5 × Ur applied to NP0/X5R/X7R/Y5V series 100 V < Ur ≤ 200 V: 1.5 × Ur + 100 V applied to NP0/X7R series 200 V < Ur ≤ 500 V: 1.3 × Ur + 100 V applied to NP0/X7R series Ur > 500 V: 1.3 × Ur applied to NP0/X7R series no breakdown or flashover I: 7.5 mA 2008 Nov. 10 V.13 13 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors Table 5 X2Y® Series Test procedures and requirements (continued) TEST METHOD IEC 60384-21/22 4.6 TEST temperature characteristic PROCEDURE Between minimum and maximum temperature REQUIREMENTS NP0: ΔC/C: ±30 ppm/°C X5R/X7R: ΔC/C: ±15% Y5V: ΔC/C: +22% ~ −82% 4.15 adhesion A force applied for 10 seconds to the line joining the terminations and in a plane parallel to the substrate no visible damage for size ≥ 0603: a force of 5 N applied for size 0402: a force of 2.5 N applied for size 0201: a force of 1 N applied 4.8 bond strength of plating on end face Mounting in accordance with IEC 60384-22 paragraph 4.3 no visible damage Conditions: bending 1 mm at a rate of 1 mm/s, radius jig 340 mm NP0: lΔC/Cl: ≤ 1% or 0.5 pF whichever is greater X5R/X7R/Y5V: lΔC/Cl: ≤ 10% 4.9 Resistance to soldering heat Precondition: 150 +0/−10 °C for 1 hour, then keep for 24 ±1 hours at room temperature Preheating: for size ≤ 1206: 120 to 150 °C for 1 minute Preheating: for size >1206: 100 to 120 °C for 1 minute and 170 to 200 °C for 1 minute X5R/X7R: lΔC/Cl: ≤ 10% Y5V: lΔC/Cl: ≤ 20% Recovery time: 24 ±2 hours Unmounted chips completely immersed in a solder bath at 235 ±5 °C The termination shall be well tinned Dipping time: 10 ±0.5 seconds Solderability NP0: lΔC/Cl: ≤ 0.5% or 0.5 pF whichever is greater D.F.: within initial specified value Rins: within initial specified value Solder bath temperature: 260 ±5 °C 4.10 The termination shall be well tinned Dipping time: 2 ±0.5 seconds Depth of immersion: 10 mm 2008 Nov. 10 V.13 14 www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors Table 5 X2Y® Series Test procedures and requirements (continued) TEST METHOD IEC 60384-21/22 4.11 TEST Rapid change of temperature PROCEDURE Preconditioning; No visual damage 150 +0/−10 °C for 1 hour, then keep for 24 ±1 hours at room temperature NP0: lΔC/Cl: ≤ 1% or 1 pF whichever is greater 5 cycles with following detail: X5R/X7R: lΔC/Cl: ≤ 15% 30 minutes at lower category temperature; Y5V: lΔC/Cl: ≤ 20% 30 minutes at upper category temperature D.F.: within initial specified value Rins: within initial specified value Recovery time 24 ±2 hours 4.13 Damp heat, with Ur load Initial measurements; after 150 +0/−10 °C for 1 hour, then keep for 24 ±1 hours at room temperature NP0: lΔC/Cl: ≤ 2% or 1 pF whichever is greater Duration and conditions: 500 ±12 hours at 40 ±2 °C; 90 to 95% RH; Ur applied Y5V: lΔC/Cl: ≤ 30% Final measurement: perform a heat treatment at 150 +0/−10 °C for 1 hour, final measurements shall be carried out 24 ±1 hours after recovery at room temperature without load 4.14 Endurance Preconditioning; Initial measurements; after 150 +0/−10 °C for 1 hour, then keep for 24 ±1 hours at room temperature Duration and conditions: 1,000 ±12 hours at upper category temperature with 1.5 × Ur voltage applied Final measurement: perform a heat treatment at 150 +0/−10 °C for 1 hour, final measurements shall be carried out 24 ±1 hours after recovery at room temperature without load 2008 Nov. 10 V.13 REQUIREMENTS 15 X5R/X7R: lΔC/Cl: ≤ 20% NP0/X5R/X7R/Y5V: D.F.: 2 × initial value max. NP0: Rins ≥ 2,500 MΩ or Rins × Cr ≥ 25 seconds, whichever is less X5R/X7R/Y5V: Rins ≥ 500 MΩ or Rins × Cr ≥ 25 seconds, whichever is less NP0: lΔC/Cl: ≤ 2% or 1 pF whichever is greater X5R/X7R: lΔC/Cl: ≤ 20% Y5V: lΔC/Cl: ≤ 30% NP0/X5R/X7R/Y5V: D.F.: 2 × initial value max. NP0: Rins ≥ 4,000 MΩ or Rins × Cr ≥ 40 seconds, whichever is less X5R/X7R/Y5V: Rins ≥ 1,000 MΩ or Rins × Cr ≥ 50 seconds, whichever is less www.yageo.com Phycomp Product specification Surface-mount ceramic EMI filter capacitors X2Y® Series REVISION HISTORY Revision Date Change Notification Description Rev.5 2001 Sep 25 - - Published on web Rev.6 2002 Jul 10 - - Product range extended in all materials and sizes; - Insertion loss measurements added. Rev.7 2003 Apr 02 - - Updated company logo Rev.8 2003 Jul 23 - - Cover page revised Rev.9 2003 Sep 09 - - Cover page corrected Rev.10 2004 Apr 21 - - Product range updated - NP0, Y5V and size 1812 removed. Rev.11 2006 Nov 21 - - Size 1410 extended - Product applications, features and benefits update - Measurement setup added - Updated tests and requirements Rev.12 2006 Dec 22 - - 12 NC revised Rev.13 2008 Nov 10 - - Product range extended in materials of NP0 and X5R 2008 Nov. 10 V.13 16 www.yageo.com
CX0805MRX7R9BB223 价格&库存
很抱歉,暂时无法提供与“CX0805MRX7R9BB223”相匹配的价格&库存,您可以联系我们找货
