MM3474P05VBE
MM3474P05VBE
    NMBTECHNOLOGIESCORPORATION
    TSSOP20
    IC, MULTI CELL, BATTERY PROTECTI
MM3474P05VBE 数据手册
MITSUMI 3 to 5cells lithium-ion/lithium-polymer battery protection IC 3 to 5cells lithium-ion/lithium-polymer battery protection IC Monolithic IC MM3474 Series Outline MM3474 series is an overcharge, overdischarge and overcurrent protection IC for a lithium-ion / lithiumpolymer rechargeable secondary battery. Lithium-ion / lithium-polymer rechargeable secondary battery overcharge each cell, over discharge, and discharge overcurrent, short circuits can be detected. This supports 3 to 5 serial cells connected in series, and switches over to the desired no. of cells by sending High / Low signal to SEL terminal. This also provides the control terminals of output over discharge detection (SDC) and output over charge detection (SOC), which allows configuring an application with fewer external parts for 6 or more cells connected in series. Features (Unless otherwise specified, Topr=+25°C) (1) Range and accuracy of detection / release voltage Overcharge detection voltage 3.6V to 4.5V, 5mV steps Accuracy±25mV (Topr=±0 to +50°C) Overcharge release voltage 3.4V to 4.5V, 50mV steps Accuracy±50mV Overdischarge detection voltage 2.0V to 3.0V, 50mV steps Accuracy±80mV Overdischarge release voltage 2.0V to 3.4V, 50mV steps Accuracy±100mV Overcurrent detect voltage 50mV to 300mV, 5mV steps Accuracy±15mV Short detection voltage 0.2V to 1.0V, 50mV steps Accuracy±100mV (2) Each detection delay time set by the external capacitor (3) The setting for three cell , for four cell , and for five cell protection can be set with the SEL1 pin and the SEL2 pin. (4) The charge and discharge of the battery can be controlled with SDC pin and SOC pin. (5) Low current consumption Consumption current1 (Vdd) , Vcell=4.4V Typ. 10.0µA, Max. 20.0µA Consumption current2 (Vdd) , Vcell=3.5V Typ. 5.0µA, Max. 10.0µA Consumption current3 (Vdd) , Vcell=1.8V Typ. 1.5µA, Max. 3.0µA Consumption current1 (V5) , Vcell=4.4V Consumption current2 (V5) , Vcell=3.5V Typ. 4.0µA, Max. 8.0µA Typ. 3.0µA, Max. 6.0µA Consumption current3 (V5) , Vcell=1.8V Typ. 1.5µA, Max. 3.0µA (6) Absolute maximum ratings VDD pin VSS2−0.3V to +30V V5 pin V4−0.3V to VDD+0.3V Between the input terminals of voltage of battery −0.3V to +10V V− pin, CS pin VDD−30V to VDD+0.3V OV pin, DCHG pin VSS2−0.3V to VDD+0.3V SEL pin VSS2−0.3V to VDD+0.3V SDC pin, SOC pin VSS2−0.3V to VDD+0.3V Storage temperature Operation temperature −55ºC to +125ºC −40ºC to +85ºC • Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification. • The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications. MITSUMI 3 to 5cells lithium-ion/lithium-polymer battery protection IC Pin Assignment Top view TSOP-20D Top view TSOP-20C OV 1 20 SOC OV 1 20 SOC V- 2 19 SDC V- 2 19 SDC CS 3 18 VDD CS 3 18 VDD DCHG 4 17 V5 DCHG 4 17 V5 COV 5 16 V4 COV 5 16 V4 CDC 6 15 V3 CDC 6 15 V3 COL1 7 14 V2 COL1 7 14 V2 COL2 8 13 V1 COL2 8 13 V1 VSS1 9 12 SEL2 VSS1 9 12 SEL2 VSS2 10 11 SEL1 VSS2 10 11 SEL1 • Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification. • The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications. MITSUMI 3 to 5cells lithium-ion/lithium-polymer battery protection IC Selection Guide (2000pcs/Reel) Overcharge detection dead time Overcharge release dead time Overdischarge detection dead time VCELLD VOC VSHORT tOV1 tOV2 tDC1 tDC2 tOC1 tOC2 V V mV V sec msec sec msec msec msec MM3474C01VBE 4.25 4.15 2.8 3 250 1 1 0.1 1 Max.15 10 10 Non Latch MM3474C02VBE 4.25 4.15 2.4 2.6 250 1 1 0.1 1 Max.15 10 10 Non Latch MM3474C03VBE 4.25 4.15 2.8 3 250 0.8 1 0.1 1 Max.15 10 10 Non Latch MM3474C04VBE 4.25 4.15 2.8 3 150 0.25 1 0.1 1 Max.15 10 10 Latch MM3474C05VBE 4.25 4.15 2.8 3 150 0.25 1 0.1 1 Max.15 10 10 Non Latch MM3474D01VBE 3.85 3.65 2.3 2.5 150 1 1 0.1 1 Max.15 10 10 Non Latch MM3474D03VBE 3.8 3.6 2 2.5 150 0.6 1 0.1 1 Max.15 10 10 Non Latch MM3474E01VBE 4.25 4.15 2.8 3 150 1 1 0.1 1 Max.15 10 10 Non Latch MM3474E02VBE 4.2 4.1 2.8 3 150 1 1 0.1 1 Max.15 10 10 Non Latch MM3474E03VBE 4.175 4.1 2.8 3 150 0.5 1 0.1 1 Max.15 10 10 Non Latch MM3474E04VBE 4.25 4.15 2.8 3 100 0.5 1 0.1 1 Max.15 10 10 Non Latch MM3474E05VBE 4.25 4.15 2.8 3 50 0.4 1 0.1 1 Max.15 10 10 Non Latch MM3474F01VBE 4.25 4.15 2.5 3 150 1 1 0.1 1 Max.15 10 10 Non Latch Non Latch Overdischarge release Short detection voltage VCELLS V Overcurrent release dead time Overcurrent detection voltage VCELLO V name Overcurrent detection dead time Overdischarge release voltage VCELLU Product Overdischarge release dead time Overdischarge detection voltage Optional function Overcharge release voltage Detection / Release voltage Overcharge detection voltage Detection / Release voltage *1 MM3474F02VBE 4.2 4.1 2.5 3 100 1 1 0.1 1 Max.15 10 10 MM3474F03VBE 4.25 4.15 2.5 3 100 0.3 1 0.1 1 Max.15 10 10 Latch MM3474F04VBE 4.25 4.21 2.5 3 100 0.8 1 0.1 1 Max.15 10 10 Non Latch MM3474F05VBE 4.25 4.15 2.5 3 100 0.25 1 0.1 1 Max.15 10 10 Non Latch MM3474F06VBE 4.225 4.15 2 3 50 0.2 1 0.1 1 Max.15 10 10 Non Latch MM3474F08VBE 4.4 4.3 2.5 3 120 0.25 1 0.1 1 Max.15 10 10 Non Latch MM3474F11VBE 4.4 4.3 2.5 3 150 0.5 1 0.1 1 Max.15 10 10 Non Latch MM3474F12VBE 4.25 4.15 2.5 3 200 0.5 1 0.1 1 Max.15 10 10 Non Latch MM3474G01VBE 4.2 4.1 2.75 3 100 1 1 0.1 1 Max.15 10 10 Non Latch MM3474G02VBE 4.25 4.15 2.75 3 100 1 1 0.1 1 Max.15 10 10 Non Latch MM3474G03VBE 4.2 4.1 2.75 3 100 0.4 1 0.1 1 Max.15 10 10 Non Latch MM3474G05VBE 4.25 4.15 2.75 3 100 0.4 1 0.1 1 Max.15 10 10 Non Latch MM3474G06VBE 4.225 4.1 2.75 3 100 0.8 1 0.1 1 Max.15 10 10 Non Latch MM3474G07VBE 4.25 4.15 2.75 3 100 0.2 1 0.1 1 Max.15 10 10 Non Latch MM3474J01VBE 4.25 4.1 2.8 3 50 1 1 0.1 1 Max.15 10 10 Non Latch MM3474K02VBE 4.25 4.1 3 3.225 100 0.4 1 0.1 1 Max.15 10 10 Non Latch MM3474K03VBE 4.25 4.19 3 3.2 80 0.7 1 0.1 1 Max.15 10 10 Latch MM3474K04VBE 4.175 4.1 3 3.2 100 0.5 1 0.1 1 Max.15 10 10 Non Latch MM3474L02VBE 3.75 3.55 2.2 2.7 100 0.4 1 0.1 1 Max.15 10 10 Non Latch MM3474L03VBE 3.65 3.5 2 2.7 200 0.25 1 0.1 1 Max.15 10 10 Non Latch MM3474L04VBE 3.75 3.55 2.2 2.7 100 0.4 1 0.1 1 Max.15 10 10 Latch MM3474M01VBE 4.35 4.15 2.3 3 150 0.5 1 0.1 1 Max.15 10 10 Non Latch MM3474N01VBE 3.9 3.6 2 3 100 0.2 1 0.1 1 Max.15 10 10 Latch MM3474P03VBE 4.23 4.22 2.8 3.4 100 0.8 1 0.1 1 Max.15 10 10 Non Latch MM3474P04VBE 4.2 4.17 2.75 2.8 100 1 1 0.1 1 Max.15 10 10 Non Latch MM3474P05VBE 4.2 4.14 2.75 2.81 100 0.5 1 0.1 1 Max.15 10 10 Latch MM3474P06VBE 4.23 4.22 2.8 3 100 0.8 1 0.1 1 Max.15 10 10 Non Latch MM3474S01VBE 3.6 3.5 2.8 3 100 0.4 1 0.1 1 Max.15 10 10 Non Latch 1 Non Latch Latch : voltage release : voltage release + load remove Please inquire to us, if you request a rank other than the above. • Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification. • The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications. MITSUMI 3 to 5cells lithium-ion/lithium-polymer battery protection IC Application Circuit · 5 cells protection circuit SC Protector P+ MM3474 D2 G D S RVM1 2.2k QVM1 CCOV1 0.1µF RCS 2.2k TH Thermistor G QDV CCOL1 0.001µF S CCOL2 0.001µF ROV1 4.3m ROV2 5.6m RDV 10m RDG2 RDG1 100 100 G P− CCDC1 0.1µF D D1 S SOC 20 2 V− SDC 19 3 CS VDD 18 4 DCHG V5 17 5 COV V4 16 6 CDC V3 15 7 COL1 V2 14 8 COL2 V1 13 9 VSS1 SEL2 12 10 VSS2 SEL1 11 ZD1 CSOC1 RSOC11 0.1µF 470k CSDC1 RSDC11 RVDD1 100 0.1µF 470k CVDD1 RV51 1k 10.0µF CV51 1.0µF RV41 1k CV41 1.0µF RV31 1k CV31 1.0µF RV21 1k CV21 1.0µF RV11 1k CV11 RSEL21 1.0µF 1k V5 V4 V3 V2 V1 RSEL11 1k G D D G S 1 OV S RSENSE 5m G D Charge control FET D D S Discharge control FET S G 2nd Protection This circuit is shown as an example of typical application for reference. According to the conditions which are actually used, the maximum rating (voltage, power dissipation, ESD tolerance, etc.) of each parts should be verified enough. Mitsumi Electric Co., Ltd. assumes no responsibility for any trouble or damage as a result of the use beyond standard range of this product indicated to the electrical characteristics of this specifications. • Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification. • The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications. MITSUMI 3 to 5cells lithium-ion/lithium-polymer battery protection IC Application Circuit · 10 cells protection circuit SC Protector P+ MM3474 (2) RSOC12 10m CCOV2 0.1µF RSDC12 10m CCDC2 0.1µF RVM2 2.2k RCOL 1k 1 OV SOC 20 2 V− SDC 19 3 CS VDD 18 4 DCHG V5 17 5 COV V4 16 6 CDC V3 15 7 COL1 V2 14 8 COL2 V1 13 9 VSS1 SEL2 12 10 VSS2 D2 G D RVM1 2.2k S QVM1 CCOV1 0.1µF RCS 2.2k TH Thermistor G QDV CCOL1 0.001µF S CCOL2 0.001µF ROV1 4.3m ROV2 5.6m RDG2 RDG1 100 100 G P− CCDC1 0.1µF D D1 S D D G S RDV 10m G Charge control FET D V10 V9 V8 V7 V6 RSEL12 1k SEL1 11 MM3474 (1) 1 OV SOC 20 2 V− SDC 19 3 CS VDD 18 4 DCHG V5 17 5 COV V4 16 6 CDC V3 15 7 COL1 V2 14 8 COL2 V1 13 9 VSS1 SEL2 12 10 VSS2 SEL1 11 CSOC1 0.1µF CSDC1 0.1µF ZD1 RSEL21 1k RVDD1 100 CVDD1 RV51 1k 10.0µF CV51 RV41 1k 1.0µF CV41 RV31 1k 1.0µF CV31 1.0µF RV21 1k CV21 1.0µF RV11 1k CV11 1.0µF V5 V4 V3 V2 V1 RSEL11 1k S RSENSE 5m G D ZD2 CSOC2 RSOC21 0.1µF 470k RSDC21 CSDC2 RVDD2 100 0.1µF 470k CVDD2 RV52 1k 10.0µF CV52 RV42 1k 1.0µF CV42 RV32 1k 1.0µF CV32 1.0µF RV22 1k CV22 1.0µF RV12 1k CV12 RSEL22 1.0µF 1k S Discharge control FET D S G 2nd Protection This circuit is shown as an example of typical application for reference. According to the conditions which are actually used, the maximum rating (voltage, power dissipation, ESD tolerance, etc.) of each parts should be verified enough. Mitsumi Electric Co., Ltd. assumes no responsibility for any trouble or damage as a result of the use beyond standard range of this product indicated to the electrical characteristics of this specifications. • Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification. • The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications.
MM3474P05VBE
物料型号:MM3474系列
器件简介:该系列IC专为锂离子/锂聚合物可充电二次电池设计,能够检测每个电池单元的过充、过放、放电过流和短路。
引脚分配:文档提供了TSOP-20D和TSOP-20C两种封装的顶视图,列出了各引脚的功能。
参数特性: - 检测/释放电压范围和精度:3.6V至4.5V,步进5mV,精度±25mV(Topr=±0至+50°C)等。 - 过流检测电压和短路检测电压的精度也在文档中有详细说明。 - 每种检测的延迟时间可通过外部电容设置。 - 通过SEL1和SEL2引脚设置三、四、五节电池保护。 - SDC引脚和SOC引脚用于控制电池的充放电。
功能详解: - 提供了输出过放检测(SDC)和输出过充检测(SOC)的控制端,允许为6个或更多串联电池单元配置应用,减少外部部件。 - 低功耗运行,具体电流消耗量在不同条件下有具体数值。
应用信息:文档提供了5节和10节电池保护电路的示例,说明了如何使用MM3474 IC进行电池保护。
封装信息:IC采用TSOP-20D和TSOP-20C封装,文档中提供了详细的封装视图。
MM3474P05VBE 价格&库存
很抱歉,暂时无法提供与“MM3474P05VBE”相匹配的价格&库存,您可以联系我们找货
