MITSUMI
2 to 4cell Li-ion/Li-polymer battery Secondary protection IC
MM3508A Series
Outline
MM3508A series is a double protection IC for 1 to 4 serial cells lithium-ion / lithium-polymer rechargable
battery for secondary protection IC. It detects battery voltage for each cell.
The FUSE cutting signal is the output between period of time. And the CELL voltage is released by electric
discharge after FUSE was cut.
Features
(Unless otherwise specified, Topr=+25°C)
1. Range and accuracy of overcharge detection/hysteresis voltage
Overcharge detection voltage
Overcharge hysteresis voltage
4.0V to 4.5V, 5mV step
-500mV to -50mV, 50mV step
Accuracy±20mV (Topr=0 to +50°C)
Accuracy±20%
2. Range of detection delay time
1ms to (1ms×2n1)+(1ms×2n2)
n1 and n2 can select two arbitrary integers between 0 to 13. (However n1 n2)
Overcharge detection delay time
3. Low current consumption
Typ. 3.5µA, Max. 5.0µA (Vcell=4.0V)
Typ. 0.15µA, Max. 0.30µA (Vcell=2.3V)
4. Absolute maximum ratings
VDD pin
OV pin
Storage temperature
Operation temperature
VSS-0.3 to VSS+28V
VSS-0.3V to VDD+0.3V
-55°C to +125°C
-40°C to +110°C
5. The FUSE cutting signal is the output between period of time. And the CELL voltage is released by electric
discharge resistance of "60K " after FUSE was cut.
And CELL stops an electric discharge if the CELL voltage becomes less than the electric discharge release
voltage.
Pin Assignment
Top view
SOT-26A
V1
VSS
OV
6
5
4
1
2
3
V2
V3
VDD
Top view
SSON-6A
OV
VSS
V1
6
5
4
1
2
3
VDD
V3
V2
Pin No.
Function
1
The input terminal of the positive voltage of V2 cell and the negative voltage of V3 cell
2
The input terminal of the positive voltage of V3 cell and the negative voltage of V4 cell
3
The input terminal of the power supply of IC and the positive voltage of V4 cell
4
Output of over charge detection (Output type is CMOS)
5
The input terminal of the ground of IC and the negative voltage of V1 cell
6
The input terminal of the positive voltage of V1 cell and the negative voltage of V2 cell
Pin No.
Function
1
2
3
4
5
6
• Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification.
• The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications.
MITSUMI
MM3508B Series
Outline
MM3508B series is a double protection IC for 1 to 4 serial cells lithium-ion / lithium-polymer rechargable
secondary battery.It detects battery voltage for each cell.
Each of these IC composed of four voltage detectors, reference voltage sources, oscillator, counter circuit
and logical circuits.
Features
Accuracy±20%
VDD pin
VSS-0.3 to VSS+28V
OV pin
Storage temperature
-55°C to +125°C
-40°C to +110°C
Pin Assignment
Top view
SOT-26A
V1
VSS
OV
6
5
4
1
2
3
V2
V3
VDD
Top view
SSON-6A
OV
VSS
V1
6
5
4
1
2
3
VDD
V3
V2
Pin No.
Function
1
2
3
4
5
6
Pin No.
Function
1
2
3
4
5
6
MITSUMI
1 to 3cell Li-ion/Li-polymer battery Secondary protection IC
2 to 3cell Li-ion/Li-polymer battery Secondary protection IC
MM3508C Series
Outline
MM3508C series is a double protection IC for 2-4 cell Li batteries.
The terminal CT is used to control the output voltage of the terminal OV.
Features
Accuracy±20%
Typ. 3.0µA, Max. 5.0µA (Vcell=4.0V)
Typ. 2.5µA, Max. 4.0µA (Vcell=2.3V)
VDD pin
OV pin
VSS-0.3 to VSS+28V
Storage temperature
-55°C to +125°C
-40°C to +110°C
5. The terminal CT is used to control the output voltage of the terminal OV.
Pin Assignment
Top view
SOT-26A
CT
VSS
OV
6
5
4
1
2
3
V1
V2
VDD
Top view
SSON-6A
OV
VSS
CT
6
5
4
1
2
3
VDD
V2
V1
Pin No.
Function
1
2
3
4
5
6
The input terminal of OV output control signal
Pin No.
Function
1
2
3
4
5
6
MITSUMI
Selection Guide
(3000pcs/Reel)
Overcharge
detection
Product name
Package
Function
voltage
[V]
Overcharge
hysteresis
voltage[mV]
Overcharge
detection
dead time
Output type
[s]
Latch
Stand by
PTC
function function function
VCELLU
VHYS
TOV
MM3508A01RRE
SSON-6A
1 to 4 cells
4.220±0.02
500±100
4.10±0.9
MM3508A02RRE
SSON-6A
1 to 4 cells
4.350±0.02
500±100
4.10±0.9
MM3508A03RRE
SSON-6A
1 to 4 cells
4.450±0.02
500±100
4.10±0.9
MM3508A04RRE
SSON-6A
1 to 4 cells
4.320±0.02
500±100
4.10±0.9
MM3508A05RRE
SSON-6A
1 to 4 cells
4.370±0.02
500±100
4.10±0.9
MM3508A06RRE
SSON-6A
1 to 4 cells
4.500±0.02
500±100
4.10±0.9
MM3508A07RRE
SSON-6A
1 to 4 cells
4.375±0.02
500±100
4.10±0.9
MM3508B01RRE
SSON-6A
1 to 4 cells
4.450±0.02
500±100
5.00±1.5
MM3508B06RRE
SSON-6A
1 to 4 cells
4.350±0.02
4.00±1.2
MM3508B07RRE
SSON-6A
1 to 4 cells
4.300±0.02
4.00±1.2
4.00±1.2
4.00±1.2
MM3508B08RRE
SSON-6A
1 to 4 cells
4.450±0.02
MM3508B09RRE
SSON-6A
1 to 4 cells
4.500±0.02
MM3508C01RRE
SSON-6A
1 to 3 cells
4.350±0.02
V4 : 620±100
V3 to V1 : 270±100
V4 : 620±100
V3 to V1 : 270±100
V4 : 620±100
V3 to V1 : 270±100
V4 : 620±100
V3 to V1 : 270±100
390±160
4.00±1.2
CMOS Output
Active High
MM3508C01NRH
SOT-26A
1 to 3 cells
4.350±0.02
390±160
4.00±1.2
MM3508C02RRE
SSON-6A
1 to 3 cells
4.350±0.02
390±160
5.65±1.7
MM3508C02NRH
SOT-26A
1 to 3 cells
4.350±0.02
390±160
5.65±1.7
MM3508C03RRE
SSON-6A
1 to 3 cells
4.450±0.02
390±160
5.65±1.7
MM3508C03NRH
SOT-26A
1 to 3 cells
4.450±0.02
390±160
5.65±1.7
MM3508C04RRE
SSON-6A
1 to 3 cells
4.450±0.02
390±160
4.00±1.7
Please inquire to us, if you request a rank other than the above.
MITSUMI
Application Circuit
3508A/3508B
(1) When using it for 4 cells
SC Protector
P+
330
VDD
0.1µF
1k
0.1µF
V3
1k
0.1µF
V2
1k
0.1µF
V1
0V
VSS
P−
(2) When using it for 3 cells
SC Protector
SC Protector
P+
330
P+
330
VDD
0.1µF
VDD
1k
0.1µF
V3
V3
0.1µF
1k
1k
0.1µF
V2
0.1µF
V2
1k
V1
0V
0.1µF
VSS
V1
0V
VSS
P−
P−
(3) When using it for 2 cells
SC Protector
SC Protector
P+
330
P+
330
0.1µF
VDD
VDD
V3
V3
1k
0.1µF
V2
V2
0.1µF
1k
V1
0V
0.1µF
VSS
V1
0V
VSS
P−
P−
The voltage change becomes big according to an excessive current, and the current of the bias in IC is
turned off temporarily. It is this influence, and there is a possibility that the output logic becomes unstable.
In that case, please set the time constant of CR connected with the power supply terminal so that the variation
in power source may become 1V/100µsec or more.
The constant of the mark is a standard.
MITSUMI
3508C
(1) When using it for 3 cells
SC Protector
P+
330
VDD
0.1µF
1k
0.1µF
V2
1k
0.1µF
External
input
V1
CT
0V
VSS
P−
(2) When using it by the overheat protection by PTC
SC Protector
P+
330
VDD
0.1µF
1k
0.1µF
V2
1k
0.1µF
V1
PTC
CT
0V
VSS
P−
When connecting a battery, it is recommended to make a short circuit by connecting a jumper between the
output and VSS and then remove the output jumper at the completion of installing all the cells.
很抱歉,暂时无法提供与“MM3508B06RRE”相匹配的价格&库存,您可以联系我们找货
