MITSUMI
1 to 3cell Li-ion/Li-polymer battery Secondary protection IC
MM3563B Series
Outline
MM3563B series are secondary protection IC using high voltage CMOS process for overcharge protection of
the rechargeable Lithium-ion or Lithium-polymer battery. The high accuracy overcharge detection of each cell
of the rechargeable 1~3-cell Lithium-ion or Lithium-polymer battery is possible. Each of these IC composed
of four voltage detectors, reference voltage sources, oscillator, counter circuit and logical circuits.The ultrasmall package SSON-6A is used to minimize footprints.
Features
(Unless otherwise specified, Topr=+25°C)
1. Range and accuracy of overcharge detection/hysteresis voltage
Overcharge detection voltage
4.0V to 4.5V, 5mV step
Accuracy±25mV (Topr=0 to +60°C)
Overcharge hysteresis voltage
-500mV to -50mV
Accuracy±50mV to 100mV
2. Range of detection delay time
Overcharge detection delay time
1ms to (1ms×2n1)+(1ms×2n2)
n1 and n2 can select two arbitrary integers between 0 to 13. (However n1 n2)
3. Low current consumption
Typ. 1.5µA, Max. 3.0µA (Vcell=4.0V)
Typ. 0.15µA, Max. 0.30µA (Vcell=2.3V)
4. Absolute maximum ratings
VDD pin
VSS-0.3 to VSS+18V
OV pin
VSS-0.3V to VDD+0.3V
Storage temperature
-55°C to +125°C
Operation temperature
-40°C to +110°C
• Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification.
• The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications.
MITSUMI
Pin Assignment
Top view
SSON-6A
OV
VSS
V1
6
5
4
1
2
3
VDD
V3
V2
Top view
SSON-6A
OV
VSS
V1
6
5
4
1
2
3
VDD
V3
V2
Selection Guide
Pin No. Input / Output
Function
1
2
INPUT
INPUT
The input terminal of the power supply of IC
The input terminal of the positive voltage of V3 cell
The input terminal of the positive voltage of V2 cell, and the
negative voltage of V3 cell
The input terminal of the positive voltage of V1 cell, and the
negative voltage of V2 cell
3
INPUT
4
INPUT
5
INPUT
The input terminal of the ground of IC, and the negative
voltage of V1 cell
6
OUTPUT
Output of over charge detection. Output type is CMOS.
· Normal mode : ”Low”
· Overcharge mode : ”High”
Function
1
INPUT
2
3
INPUT
INPUT
4
OUTPUT
5
INPUT
voltage of V1 cell
6
INPUT
(3000pcs/Reel)
Product name
Package
voltage
Overcharge
detection
voltage[mV]
dead time
[V]
[s]
Stand by
PTC
function
function
VCELLU
VHYS
TOV
MM3563B02NRH
SOT-26A
4.350±0.025
100±50
2.0±30
MM3563B02RRE
SSON-6A
4.350±0.025
100±50
2.0±30
MM3563B03NRH
SOT-26A
4.350±0.025
100±50
6.0±30
MM3563B03RRE
SSON-6A
4.350±0.025
100±50
6.0±30
MM3563B04NRH
SOT-26A
4.450±0.025
200±70
2.0±30
MM3563B04RRE
SSON-6A
4.450±0.025
200±70
2.0±30
MM3563B05RRE
SSON-6A
4.350±0.025
500±100
4.1±30
MM3563B06RRE
SSON-6A
4.450±0.025
500±100
4.1±30
MM3563B07RRE
SSON-6A
4.300±0.025
100±50
2.0±30
MM3563B08RRE
SSON-6A
4.400±0.025
200±70
2.0±30
MM3563B09RRE
SSON-6A
4.220±0.025
500±100
4.1±30
MM3563B11RRE
SSON-6A
4.350±0.025
300±80
6.0±30
MM3563B13RRE
SSON-6A
4.500±0.025
500±100
4.1±30
MM3563B15RRE
SSON-6A
4450±0.025
300±80
6.0±30
Please inquire to us, if you request a rank other than the above.
MITSUMI
Application Circuit
(1) When using it for 3 cells
SC Protector
P+
330
VDD
0.1µF
1k
0.1µF
V3
1k
0.1µF
V2
1k
0.1µF
V1
0V
VSS
P−
The voltage change becomes big according to an excessive current, and the current of the bias in IC is
turned off temporarily. It is this influence, and there is a possibility that the output logic becomes unstable.
In that case, please set the time constant of CR connected with the power supply terminal so that the variation
in power source may become 1V/100µsec or more.
The constant of the mark is a standard.
很抱歉,暂时无法提供与“MM3563B06RRE”相匹配的价格&库存,您可以联系我们找货
