MM3220U01NRH
MM3220U01NRH
    NMBTECHNOLOGIESCORPORATION
    SOT23-6
    IC, TWO CELL, BATTERY PROTECTION
MM3220U01NRH 数据手册
MITSUMI 2 cells lithium-ion/lithium-polymer battery protection IC 2 cells lithium-ion/lithium-polymer battery protection IC MM3220 Series Outline MM3220 series are protection IC using high voltage CMOS process for overcharge, overdischarge and overcurrent protection of the rechargeable Lithium-ion or Lithium-polymer battery. The overcharge, overdischarge, discharging overcurrent, short, charging, and overcurrent(optional) of the rechargeable one-cell Lithium-ion or Lithium-polymer battery can be detected. Each of these IC composed of four voltage detectors, short detection circuit, reference voltage sources, oscillator, counter circuit and logical circuits. Features (Unless otherwise specified, Topr=+25°C) (1) Range and accuracy of detection / release voltage Overcharge detection voltage 4.0V to 4.5V, 5mV steps Overcharge release voltage Overdischarge detection voltage Overdischarge release voltage Discharging overcurrent detection voltage 1 Discharging overcurrent detection voltage 2 *1 Charging overcurrent detection voltage *1 Short detection voltage 3.9V to 4.5V, 50mV steps 2.0V to 3.0V, 50mV steps 2.0V to 3.5V, 50mV steps +50mV to +300mV, 5mV steps +50mV to +700mV, 50mV steps −300mV to −50mV, 5mV steps 0.9V fixed Accuracy±20mV Accuracy±25mV (Topr=−5 to +60°C) Accuracy±30mV Accuracy±35mV Accuracy±100mV Accuracy±10mV Accuracy TYP±20% Accuracy±20mV Accuracy±100mV Accuracy±300mV *2 (2) Range of detection delay time Overcharge detection delay time Overdischarge detection delay time Discharging overcurrent detection delay time 1 Discharging overcurrent detection delay time 2 Charging overcurrent detection delay time Short detection delay time Selection from 0.25s, 1.0s, 1.2s, 4.5s Selection from 20ms, 24ms, 96ms, 125ms, 144ms Selection from 8ms, 12ms, 16ms, 20ms, 48ms Selection from 0.5ms, 1ms , 1.5ms , 2ms , 4ms Selection from 4ms, 6ms, 8ms, 16ms 400µs fixed (3) Low current consumption Normal mode Stand-by mode Typ. 4.0µA, Max. 8.0µA Max. 0.1µA (4) Absolute maximum ratings VDD pin COUT pin and V− pin DOUT pin Storage temperature Operation temperature *1 *2 VSS−0.3V to +12V VDD−28V to VDD+0.3V VSS−0.3V to VDD+0.3V −55°C to +125°C −40°C to +85°C Optional function When the discharging overcurrent detection voltage 2 function having • Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification. • The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications. MITSUMI 2 cells lithium-ion/lithium-polymer battery protection IC Pin Assignment Top view SOT-26A Pin No. 3 Output of overdischarge detection (Output type is CMOS) Output of overcharge detection (Output type is CMOS) Input terminal connected to charger negative voltage 4 Input terminal of the low side cell 5 Input terminal of the high side cell (Supply terminal) 6 VSS terminal (Connected to ground) 1 VSS VDD VBL 6 5 4 1 2 DOUT COUT 2 3 V- Selection Guide Function (3000pcs/Reel) Overdischarge detection voltage [V] Overdischarge release voltage [V] Overcurrent detection voltage on discharging 1 [V] Overcurrent detection voltage on discharging 2 [V] Charging Overcurrent Detection voltage[V] Short detection voltage [V] Package Overcharge release voltage [V] Product name Overcharge detection voltage [V] Detection / Release voltage Vdet1H Vdet1L Vrel1H Vrel1L Vdet2H Vdet2L Vrel2H Vrel2L Vdet3-1 Vdet3-2 Vdet4 Vshort 0V battery Delay time charge combination function *1 MM3220B01NRH SOT-26A 4.300 4.100 2.000 2.000 0.220 0.90 Permission 3 MM3220C01NRH SOT-26A 4.300 4.100 2.000 2.000 0.085 0.450 0.90 Permission 4 MM3220C02NRH SOT-26A 4.300 4.100 2.000 2.000 0.100 0.200 0.90 Permission 5 MM3220C03NRH SOT-26A 4.300 4.100 2.000 2.000 0.100 0.200 0.90 Permission 6 MM3220D01NRH SOT-26A 4.250 4.100 3.000 3.000 0.200 0.90 Permission 7 MM3220D05NRH SOT-26A 4.250 4.100 2.500 2.500 0.150 0.90 Permission 7 MM3220F01NRH SOT-26A 4.225 4.075 2.550 2.550 0.200 0.90 Permission 7 MM3220G01NRH SOT-26A 4.290 4.050 3.000 3.200 0.200 −0.200 1.10 Permission 2 MM3220G06NRH SOT-26A 4.250 4.100 2.500 3.000 0.150 −0.100 0.90 Permission 9 MM3220G07NRH SOT-26A 4.400 4.250 2.500 3.000 0.150 −0.100 0.90 Permission 9 MM3220H01NRH SOT-26A 4.225 4.075 3.000 3.000 0.200 −0.200 1.10 Permission 11 MM3220H02NRH SOT-26A 4.300 4.150 2.400 2.400 0.200 −0.200 1.10 Prohibition 11 MM3220H03NRH SOT-26A 4.250 4.100 3.200 3.200 0.200 −0.200 1.10 Permission 11 MM3220H04NRH SOT-26A 4.230 4.080 2.400 2.400 0.200 −0.200 1.10 Prohibition 11 MM3220H06NRH SOT-26A 4.230 4.080 2.865 2.865 0.200 −0.200 1.10 Prohibition 11 MM3220H09NRH SOT-26A 4.225 4.150 2.600 2.600 0.250 −0.200 1.10 Prohibition 12 MM3220H10NRH SOT-26A 4.250 4.175 2.600 2.600 0.250 −0.200 1.10 Prohibition 12 MM3220H11NRH SOT-26A 4.300 4.150 2.300 2.300 0.150 −0.150 0.90 Permission 13 MM3220H13NRH SOT-26A 4.250 4.050 2.400 2.400 0.200 −0.200 1.10 Permission 2 MM3220H15NRH SOT-26A 4.280 4.130 2.800 2.800 0.150 −0.150 0.50 Prohibition 1 MM3220J01NRH SOT-26A 4.275 4.275 2.500 2.500 0.085 −0.060 0.30 Prohibition 8 MM3220K01NRH SOT-26A 4.300 4.100 2.000 2.000 0.125 −0.090 0.90 Permission 10 MM3220M01NRH SOT-26A 4.280 4.080 2.000 2.000 0.200 −0.100 1.00 Prohibition 2 MM3220M04NRH SOT-26A 4.280 4.080 2.600 2.600 0.135 −0.085 0.80 Prohibition 2 MM3220N01NRH SOT-26A 4.250 4.100 2.500 3.000 0.150 0.90 Permission 7 MM3220Z01NRH SOT-26A 4.300 4.100 2.000 2.000 0.100 0.90 Permission 6 0.300 0.180 Delay time combination Overcharge detection delay time Overdischarge detection delay time Overcurrent detection delay time on discharging 1 Overcurrent detection delay time on discharging 2 Charging overcurrent detection delay time Short detection delay time 1 2 3 4 5 6 7 tVdet1 1.0s 1.0s 1.0s 1.13s 1.0s 1.0s 1.15s tVdet2 128ms 128ms 12ms 10.8ms 12ms 12ms 144ms tVdet3-1 9ms 12ms 12ms 10.8ms 48ms 256ms 9ms tVdet3-2 0.5ms 4ms 2.5ms tVdet4 8ms 8ms tshort 280µs 300µs 400µs 400µs 400µs 400µs 300µs 8 9 10 11 12 13 0.25s 1.0s 1.15s 1.15s 1.15s 1.0s 20ms 12ms 144ms 144ms 1.15s 96ms 6ms 256ms 12ms 9ms 9ms 20ms 0.5ms 16ms 8ms 8ms 8ms 8ms 8ms 400µs 400µs 400µs 300µs 300µs 300µs Please inquire to us, if you request a rank other than the above. • Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification. • The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications. MITSUMI 2 cells lithium-ion/lithium-polymer battery protection IC Application Circuit Pack+ R1 330 Cell 1 Cell 2 R2 330 VDD V− VBL COUT VSS DOUT C1 0.1μF C3 0.1μF C2 0.1μF R3 2.2k Pack− C4 0.1μF R1 , C1 , R2 , C2 stabilize a supply voltage ripple. However, R1 is enlarged, the detection voltage shifts by voltage when current consumption flows into R1. Please decide it after confirming the characteristic. Moreover, adjust the value of C1 , C2 to 0.01µF or more to do the stability operation, please. R1 and R3 resistors are current limit resistance if a charger is connected reversibly or a high-voltage charger that exceeds the absolute maximum rating is connected. R1 and R3 may cause a power consumption will be over rating of power dissipation, therefore the `R1+R3` should be more than 1k . Moreover, if R3 is too enlarged, the charger connection release cannot be occasionally done after the overdischarge is detected, so adjust the value of R3 to 10k or less, please. In the state of overdischarge, The current flows through overdischarge pull-up resistance built into between VDD terminal and V- terminal when the charger is connected. As a result, current that flows into VDD terminal increases. When current increases, the voltage is generated in R1. And hysteresis might be caused. Please use it after confirming the characteristic. C3 and C4 capacitors have effect that the system stability about voltage ripple or imported noise. After check characteristics, decide that these capacitors should be inserted or not, where should be inserted, and capacitance value, please. • Any products mentioned in this catalog are subject to any modification in their appearance and others for improvements without prior notification. • The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications.
MM3220U01NRH 价格&库存
很抱歉,暂时无法提供与“MM3220U01NRH”相匹配的价格&库存,您可以联系我们找货
