MM3855LC1RLE
MM3855LC1RLE
    NMBTECHNOLOGIESCORPORATION
    UFDFN8
    IC, ONE CELL, BATTERY PROTECTION
MM3855LC1RLE 数据手册
1cell Li-ion/Li-polymer battery protection IC MM3825 series Outline The MM3825 series are protection IC using high voltage CMOS process for overcharge, overdischarge and overcurrent protection of the rechargeable Lithium-ion or Lithium-polymer battery. The overcharge, overdischarge, discharging overcurrent, charging overcurrent, and short protection of the rechargeable one-cell Lithium-ion or Lithium-polymer battery can be detected. Each of these IC composed of four voltage detectors, short detection circuit, reference voltage sources, oscillator, counter circuit and logical circuits. Features ・Detection voltage (Unless otherwise specified, Ta=25 degC) Range Accuracy Overcharge detection voltage 3.6V to 5.0V, 5mV steps +/-20mV Overdischarge detection voltage 2.0V to 3.0V, 50mV steps +/-35mV Discharging overcurrent detection voltage 20mV to +300mV, 1mV steps +/-2.5mV Charging overcurrent detection voltage -20mV to -300mV, 1mV steps +/-2.5mV Short detection voltage 70mV to 350mV, 1mV steps +/-8% +/-25mV(Ta=-20 to +60 degC) +/-3.0mV(Ta=-20 to +60 degC) +/-3.0mV(Ta=-20 to +60 degC) 0V battery charge inhibition battery voltage 1.1V to 2.4V, 0.1V steps 0.9V ・0V battery charge function +/-0.1V +/-0.3V Selectable "Permission" or "inhibition" ・Current consumption at Ta=25 degC Normal mode 2.5uA typ. 4.0uA max. Standby mode 0.1uA max. (Overdischarge latch function enable.) 0.5uA max. (Overdischarge latch function disable.) MM3825Txx Series Normal mode 2.0uA typ. 3.0uA max. Standby mode 0.05uA max. (Overdischarge latch function enable.) 0.5uA max. (Overdischarge latch function disable.) Package type ・SSON-6J/6M 1.40 × 1.40 × 0.55 [mm] ・SON-6C 2.00 × 1.60 × 0.55 [mm] ■ All brand names, logos, product names, trade names and service names described here are trademarks or registered trademarks of their respective companies or organizations. ■ Any products mentioned in this leaflet are subject to any modification in their appearance and others for improvements without prior notification. ■ The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications. Oct, 2020 Rev.0 Block Diagram Package and pin configuration SSON-6J/6M Function Pin No. Symbol 1 1 6 2 5 3 4 2 3 SON-6C No connection NC COUT Charge FET control terminal DOUT Discharge FET control terminal 4 VSS Negative power supply voltage input terminal 5 VDD Positive power supply voltage input terminal 6 V- Negative power supply voltage input terminal. Function Pin No. Symbol 1 1 6 2 5 3 4 2 3 NC No connection COUT Charge FET control terminal DOUT Discharge FET control terminal 4 VSS Negative power supply voltage input terminal 5 VDD Positive power supply voltage input terminal 6 V- Negative power supply voltage input terminal. Oct, 2020 Rev.0 Package dimensions Unit:mm SON-6C SSON-6J SSON-6M Top View Top View Top View Bottom View Bottom View Bottom View Marking Contents / S0N-6C Marking Contents / SSON-6J Marking Contents / SSON-6M ← Model No. ← Date Code ← Date Code ← Date Code ← Model No. ← Model No. 1-Pin Mark 1-Pin Mark Oct, 2020 Rev.0 Absolute Maximum Ratings Parameter Supply voltage V- Rating Symbol Unit VDD -0.3 to 12 V V- VDD-28 to VDD+0.3 V COUT terminal terminal VCOUT VDD-28 to VDD+0.3 V DOUTterminal VDOUT VSS-0.3 to VDD+0.3 V Tstg -55 to +125 degC Storage temperature Recommended Operating Conditions Parameter Symbol Rating Operating ambient temperature Topr -40 to +85 Unit degC Operating voltage Vop 1.5 to 5.5 V Electrical characteristics Item Operating voltage Operating Ambient temperature Note (Unless otherwise specified, Ta=25 degC) Min Typ Max Unit Symbol V Vop 1.5 - 5.5 degC Ta -40 - 85 Rshort*0.6 Rshort Rshort*2.0 Rpu*0.5 Rpu Rpu*2.0 0.5 Discharge overcurrent release resistance kohms V- terminal pull-up resistances kohms Rshort VDD=3.6V, V-=2.0V Rpu VDD=2.0V, V-=0V COUT L level output voltage V VcoL Icout=30uA, VDD=4.5V - 0.1 COUT H level output voltage V VcoH Icout=-30uA, VDD=4.0V VDD-0.5 VDD-0.1 - DOUT L level output voltage V VdoL Idout=30uA, VDD=2.0V - 0.1 0.5 Idout=-30uA, VDD=4.0V DOUT H level output voltage V VdoH Current consumption uA Idd Current consumption at stand-by uA Is VDD-0.5 VDD-0.1 - VDD=4.0V, V-=0V - 2.5 4 VDD=2.0V *3 - - 0.1 VDD=2.0V *4 - 0.3 0.5 Vst=VDD-V-, VDD=0V *1 - - 1.2 Vst=VDD-VSS, V-=0V *2 Vst-0.1 0V battery charge permission charger voltage V 0V battery charge inhibition battery voltage V Overcharge detection voltage V Overcharge release voltage V Vrel1 Overdischarge detection voltage V Vdet2 V-=0V Vst Vst Vst+0.1 Vdet1 Vde1+0.020 Vrel1-0.030 Vrel1 Vrel1+0.030 Vdet1-0.035 Vdet2 Vdet1 Ta=-20 to 60degC, V-=0V Vdet1-0.020 *5 In case Vdet2=Vrel2 *3 *5 Vrel2-0.035 In case Vdet2≠Vrel2 *4 *5 Vdet1-0.065 Vrel2 Vde1+0.035 Vrel2+0.050 Overdischarge release voltage V Vrel2 Discharging overcurrent detection voltage V Vdet3 VDD=3.6V, V-=0V *6 Vdet3-⊿V Vdet3 Vdet3+⊿V Charging overcurrent detection voltage V Vdet4 VDD=3.6V, V-=0V *6 Vdet4-⊿V Vdet4 Vdet4+⊿V Vdet1+0.090 Vshort*0.92 Vshort Vshort*1.08 Overcharge detection delay time ms tVdet1 tVdet1*0.8 tVdet1 tVdet1*1.2 Short detection voltage V Vshort VDD=3.6V Overdischarge detection delay time ms tVdet2 tVdet2*0.8 tVdet2 tVdet2*1.2 Discharging overcurrent detection delay time ms tVdet3 tVdet3*0.8 tVdet3 tVdet3*1.2 Charging overcurrent detection delay time ms tVdet4 tVdet4*0.8 tVdet4 tVdet4*1.2 Short detection delay time us tVshort tVshort*0.7 tVshort tVshort*1.4 *1 In case 0V battery charge function "Permission". *4 Overdischarge mode latch function "Disable". *2 In case 0V battery charge function "inhibition". *5 Please refer to each specifications for release condition. *3 Overdischarge mode latch function "Enable". *6 Current detection voltage Accuracy Oct, 2020 Rev.0 Typical application circuit Symbol Part Min. Typ. Max. R1 Resistor - 100Ω 1.0kΩ For voltage fluctuation, For ESD Purpose C1 Capacitor 0.01uF 0.1uF 1.0uF R2 Resistor - 1.0kΩ 1.0kΩ Current limit for charger reverse connection C2 Capacitor - 0.1uF - For exogenous noise C3 Capacitor - 0.1uF - For exogenous noise Nch MOS FET - - - Charge and discharge control DFET CFET For voltage fluctuation Application hints R1 and C1 stabilize a supply voltage fluctuation. However, the detection voltage rises by the current consumption of IC when R1 is too large, and please use 1kohm or less for R1. Please use 0.01uF or more for C1 to stabilize the operation. Oct, 2020 Rev.0 Overcharge release voltage Overdischarge detection voltage Overdischarge release voltage Discharging overcurrent detection voltage Charging overcurrent detection voltage Short detection voltage1 Overdischarge Hys-Cancel Overcharge Discharge overcurrent Overdischarge PKG Overcharge MODEL 0V charge Protection mode latch function Overcharge detection voltage Lineup Vdet1 [V] Vrel1 [V] Vdet2 [V] Vrel2 [V] Vdet3 [mV] Vdet4 [mV] Vshort [mV] MM3825ACCYLE SON-6C 0.9 Disable Disable Disable Enable Disable 4.475 4.275 2.500 2.900 20.0 -20.0 70.0 MM3825CM1RRE SSON-6J 1.1 Disable Enable Disable Enable Enable 4.275 4.175 2.400 2.400 90.0 -25.0 250.0 MM3825CM3YRE SON-6C 0.9 Disable Enable Disable Enable Enable 4.475 4.275 2.700 2.700 45.0 -45.0 145.0 Permission Disable Enable Disable Enable Enable 4.475 MM3825CN3YRE SON-6C 4.275 2.500 2.500 30.0 -30.0 105.0 MM3825TM3YRE SON-6C 0.9 Disable Disable Disable Enable Disable 4.475 4.275 2.500 2.800 60.0 -60.0 190.0 MM3825TM4RRE SSON-6J 2.1 Disable Enable Disable Enable Enable 4.200 4.000 2.800 2.800 50.0 -50.0 150.0 MM3825TN1YRE SON-6C Permission Disable Enable Disable Enable Enable 4.495 4.295 2.500 2.500 45.0 -45.0 150.0 Delay time MODEL tVdet1 [s] tVrel1 [ms] tVdet2 [ms] tVrel2 [ms] tVdet3 [ms] tVrel3 [ms] tVdet4 [ms] tVrel4 [ms] tshort [us] MM3825ACCYLE 1.024 16.00 64.00 1.00 16.00 1.00 16.00 1.00 280 MM3825CM1RRE 1.024 16.00 32.00 1.00 24.00 1.00 8.00 1.00 250 MM3825CM3YRE 1.024 16.00 32.00 1.00 16.00 1.00 8.00 1.00 280 MM3825CN3YRE 1.024 16.00 32.00 1.00 8.00 1.00 8.00 1.00 280 MM3825TM3YRE 1.024 16.00 20.00 1.00 12.00 1.00 8.00 1.00 280 MM3825TM4RRE 1.024 8.00 128.00 1.00 8.00 1.00 8.00 1.00 280 MM3825TN1YRE 1.024 16.00 32.00 1.00 32.00 1.00 8.00 1.00 280 Oct, 2020 Rev.0
MM3855LC1RLE 价格&库存
很抱歉,暂时无法提供与“MM3855LC1RLE”相匹配的价格&库存,您可以联系我们找货
