1cell Li-ion/Li-polymer battery protection IC
MM3860 series
Outline
MM3860 series are Li-ion battery protection IC and detect charge current / discharge current with high precision by
current sensing resistor (Rsns). MM3860 have two step discharge overcurrent detection. And system is protected
appropriately in the next 2 state, Normal discharge mode and large current discharge mode.
Features
・Detection voltage
(Unless otherwise specified, Ta=25 degC)
Range
Accuracy
Overcharge detection voltage
4.1V to 5.0V, 5mV steps
+/-20mV(Ta=-20 to +60 degC)
Overdischarge detection voltage
2.1V to 3.0V, 50mV steps
+/-35mV
Discharging overcurrent detection voltage 1
6mV to +50mV, 1mV steps
+/-1mV
Discharging overcurrent detection voltage 2
10mV to +100mV, 1mV steps
+/-2mV
Charging overcurrent detection voltage
-6mV to -50mV, 1mV steps
+/-1mV
Short detection voltage1
30mV to 200mV, 10mV steps
+/-5mV
0V battery charge inhibition battery voltage
0.9V fixed
+/-0.3V
・0V battery charge function
Selectable "Permission" or "inhibition"
・Current consumption at Ta=25 degC
Normal mode
2.5uA 4.0uA
typ. max.
Standby mode
0.1uA max. (Overdischarge latch function enable.)
0.6uA max. (Overdischarge latch function disable.)
Package type
・SON-6F
1.80 × 1.60 × 0.55 [mm]
・SSON-6J/6M
1.40 × 1.40 × 0.55 [mm]
・SSON-6U/6V
1.80 × 1.40 × 0.40 [mm]
■ All brand names, logos, product names, trade names and service names described here are trademarks or registered trademarks of their respective companies or organizations.
■ Any products mentioned in this leaflet are subject to any modification in their appearance and others for improvements without prior notification.
■ The details listed here are not a guarantee of the individual products at the time of ordering. When using the products, you will be asked to check their specifications.
Oct, 2020 Rev.0
Block Diagram
Package and pin configuration
SON-6F
Pin No. Symbol
1
1
6
2
5
3
4
2
3
SSON-6J/6M
Input terminal for charger negative voltage
VM
COUT Control terminal for charge FET
DOUT Control terminal for discharge FET
4
VSS
Input terminal for negative power supply voltage
5
VDD
Input terminal for positive power supply voltage
6
CS
Pin No. Symbol
1
6
2
5
3
4
2
VDD
3
CS
Input terminal for overcurrent detection
4
VM
Pin No. Symbol
6
2
5
3
4
Function
VSS
6
1
1
5
SSON-6U/6V
Function
1
2
3
V-
Function
4
VSS
5
VDD
6
CS
Oct, 2020 Rev.0
Package dimensions
Unit:mm
SON-6F
SSON-6J
SSON-6M
Top View
Top View
Top View
Bottom View
Bottom View
Bottom View
Marking Contents / SON-6F
Marking Contents / SSON-6J
Marking Contents / SSON-6M
← Model No.
← Date Code
← Date Code
← Date Code
← Model No.
← Model No.
1-Pin Mark
1-Pin Mark
Oct, 2020 Rev.0
Package dimensions
Unit:mm
SSON-6U
SSON-6V
Top View
Top View
Bottom View
Bottom View
Marking Contents / SSON-6U
Marking Contents / SSON-6V
1-Pin Mark
Model No.
Model No.
Date
Date
1-Pin Mark
Oct, 2020 Rev.0
Absolute Maximum Ratings
Parameter
V-
Rating
Symbol
Supply voltage
terminal
Unit
VDD
-0.3 to 12
V
V-
VDD-28 to VDD+0.3
V
COUT terminal
VCO
VDD-28 to VDD+0.3
V
DOUTterminal
VDO
-0.3 to VDD+0.3
V
CS
terminal
VCS
-0.3 to VDD+0.3
V
Storage temperature
Tstg
-55 to +125
degC
Recommended Operating Conditions
Symbol
Rating
Operating ambient temperature
Parameter
Topr
-40 to +85
Unit
degC
Operating voltage
Vop
1.5 to 5.5
V
Electrical characteristics
Parameter
Discharge overcurrent release
resistance
V- terminal pull-up resistances
Symbol
Condition
Rshort VDD=3.6V, V-=Vcs=1.0V
Rpu
VDD=2.0V, V-=Vcs=0V
COUT L level output voltage
VcoL
VDD=4.5V, Icout=30uA
COUT H level output voltage
VcoH
VDD=4.0V, Icout=-30uA
DOUT L level output voltage
VdoL
VDD=2.0V, Idout=30uA
DOUT H level output voltage
VdoH
VDD=4.0V, Idout=-30uA
Current consumption
Standby current
Idd
Is
Min.
Typ.
Max.
Unit
5.0
10.0
15.0
kohm
150
300
600
kohm
0.1
0.5
V
V
0.5
V
VDD-0.5 VDD-0.1
0.1
V
2.5
4.0
uA
VDD-0.5 VDD-0.1
VDD=4.0V, V-=Vcs=0V
VDD=2.0V,Vcs=0V,V-=VDD※1
0.1
VDD=2.0V,Vcs=0V,V-=VDD※2
0.3
0.6
uA
※1 Overdischarge latch function enable.
※2 Overdischarge latch function disable.
Oct, 2020 Rev.0
Parameter
Symbol
Vdet1
Condition
Min.
Typ.
Max.
Unit
Ta=25 degC
Ta=-20 to +60 degC
-0.020
Vdet1
+0.020
V
Overcharge release voltage
Vrel1
-0.030
Vrel1
+0.030
V
Vdet2
-0.035
Vdet2
+0.035
V
Overdischarge release voltage
Vrel2
-0.065
Vrel2
+0.090
V
detection voltage 1
detection voltage 2
detection voltage
Vdet3-1
Vdet3-2
Vdet4
Short detection voltage 1
Vshort 1
Short detection voltage 2
Vshort 2
0V battery charge
permission charger voltage
0V battery charge
Monitor voltage for
the charger connection
Release voltage from
discharging overcurrent mode
Ta=25 degC
-1.0
Ta=-20 to +60 degC
-1.5
Ta=25 degC
-2.0
Ta=-20 to +60 degC
-2.5
Ta=25 degC
-1.0
Ta=-20 to +60 degC
-1.5
Ta=25 degC
-5.0
Ta=-20 to +60 degC
-5.5
Vdet3-1
Vdet3-2
+1.0
+1.5
+2.0
+2.5
+1.0
Vdet4
+1.5
Vshort 1
+5.0
+5.5
-0.300 VDD-0.9 +0.300
mV
mV
mV
mV
V
Vst
1.2
V
Vst
-0.300
0.900
+0.300
V
VrelVM
0.150
0.250
0.350
V
VrelVM2
VDD=3.7V
VCS=0V
-0.300 VDD-1.1 +0.300
V
Overcharge detection delay time
tVdet1
-20%
tVdet1
+20%
s
Overdischarge detection delay time
tVdet2
-20%
tVdet2
+20%
ms
tVdet3-1
-20%
tVdet3-1 +20%
ms
tVdet3-2
-20%
tVdet3-2 +20%
ms
tVdet4
-20%
tVdet4
+20%
ms
tshort
-30%
tshort
+40%
us
Discharging overcurrent detection1
delay time
Discharging overcurrent detection2
delay time
delay time
Short detection delay time
Oct, 2020 Rev.0
Typical application circuit
Unit:ohm ,F
Symbol
Part
Min.
Typ.
Max.
R1
Resistor
100
1k
R2
Resistor
1k
10k
Purpose
For voltage fluctuation and ESD
For current limit of charger reverse connection
Rsns
Resistor
C1
Capacitor
0.01u
0.1u
1.0u
C2
Capacitor
0.1u
For exogenous noise
C3
Capacitor
0.1u
For exogenous noise
C4
Capacitor
0.1u
For exogenous noise
Nch MOS FET
Charge and discharge control
DFET
CFET
Charge and discharge curent sensing
*The above application circuit and constant value do not guarantee proper operation.
*Please evaluate thoroughly by actual application to set up constants.
Oct, 2020 Rev.0
Vdet2
Vrel2
[V]
[V]
[V]
[mV]
[mV]
[mV]
[mV]
Vdet3-1 Vdet3-2 Vdet4 Vshort1
Delay time *1
Vrel1
[V]
Vdet1
voltage
voltage
Overdischarge
Hys-Cancel
Overcharge
Overdischarge
Overcharge
PKG
0V charge
MODEL
Protection mode latch
function
voltage
Lineup
MM3860AC5ZRE
SON-6F
0.9
Disable Disable Disable Enable Enable 4.475
4.275
2.500
2.900
7.0
-11.0
25.0
L
MM3860AC6ZRE
SON-6F
0.9
Disable Disable Disable Enable Enable 4.520
4.320
2.300
2.500
7.0
-11.0
30.0
N
MM3860AC7ZRE
SON-6F
0.9
Disable Disable Disable Enable Enable 4.540
4.340
2.300
2.500
7.0
-11.0
30.0
N
MM3860ACAZRE
SON-6F
0.9
4.340
2.300
2.500
7.0
-13.0
30.0
N
MM3860AF4RR4
SSON-6UorV
0.9
Disable Disable Disable Enable Enable 4.580
4.405
2.300
2.500
15.0
22.0
-20.0
40.0
O
MM3860AF5RR4
SSON-6UorV
0.9
4.405
2.300
2.500
7.0
11.0
-13.0
22.0
O
MM3860AL1ZRE
SON-6F
Permission Disable Disable Disable Enable Enable 4.475
4.275
2.500
2.900
7.0
20.0
-7.0
70.0
A
MM3860AL2ZRE
SON-6F
Permission Disable Disable Disable Enable Enable 4.530
4.330
2.100
2.300
14.0
20.0
-20.0
55.0
B
MM3860AL3ZRE
SON-6F
4.330
2.100
2.300
10.5
15.0
-15.0
40.0
B
MM3860AL4ZRE
SON-6F
Permission Disable Disable Disable Enable Enable 4.550
4.350
2.100
2.300
7.0
10.0
-10.0
27.0
B
MM3860AL5ZRE
SON-6F
-15.0
32.0
C
MM3860AL6ZRE
SON-6F
MM3860AL7ZRE
SON-6F
MM3860ALDZRE
SON-6F
MM3860ALEZRE
SON-6F
MM3860ALFZRE
0.9
4.275
2.500
2.900
15.0
0.9
4.320
2.300
2.500
15.0
-15.0
36.0
D
Permission Disable Disable Disable Enable Enable 4.500
4.300
2.100
2.300
7.0
10.0
-13.0
27.0
B
4.330
2.350
2.550
21.0
33.0
-24.0
80.0
I
4.350
2.100
2.300
21.0
33.0
-30.0
80.0
I
SON-6F
4.330
2.350
2.550
7.0
12.0
-12.0
28.0
I
MM3860ALGZRE
SON-6F
4.350
2.100
2.300
7.0
12.0
-14.0
28.0
I
MM3860ALHZRE
SON-6F
Permission Disable Disable Disable Enable Enable 4.250
4.150
2.800
3.000
35.0
55.0
-8.0
80.0
M
MM3860ALJRR4
SSON-6UorV
Permission Disable Disable Disable Enable Enable 4.555
4.380
2.600
2.800
15.0
22.0
-20.0
40.0
O
MM3860ALKRR4
SSON-6UorV
4.380
2.600
2.800
7.0
11.0
-13.0
22.0
O
MM3860AN1ZRE
SON-6F
Permission Disable Disable Disable Enable Enable 4.445
4.245
2.500
2.900
21.0
-16.0
60.0
G
MM3860AN2ZRE
SON-6F
Permission Disable Disable Disable Enable Enable 4.480
4.380
2.300
2.700
23.0
-18.0
60.0
H
MM3860AN3ZRE
SON-6F
4.245
2.500
2.900
21.0
-22.0
60.0
G
MM3860AN4ZRE
SON-6F
4.380
2.300
2.700
23.0
-24.0
60.0
H
MM3860AN5ZRE
SON-6F
4.245
2.500
2.900
11.0
-12.5
30.0
G
MM3860AN6ZRE
SON-6F
4.380
2.300
2.700
13.0
-14.0
30.0
H
MM3860AN7ZRE
SON-6F
4.380
2.300
2.700
7.0
-7.5
18.0
H
MM3860AN8ZRE
SON-6F
Permission Disable Disable Disable Enable Enable 4.450
4.250
2.500
2.900
14.5
22.0
-16.0
60.0
J
MM3860AN9ZRE
SON-6F
Permission Disable Disable Disable Enable Enable 4.485
4.385
2.300
2.700
14.5
24.0
-18.0
60.0
K
Oct, 2020 Rev.0
Vdet2
Vrel2
[V]
[V]
[V]
[mV]
[mV]
[mV]
[mV]
Delay time *1
Vrel1
[V]
Vdet1
voltage
voltage
Overdischarge
Hys-Cancel
Overcharge
Overdischarge
Overcharge
PKG
0V charge
MODEL
function
voltage
Lineup
MM3860ANAZRE
SON-6F
4.250
2.500
2.900
7.5
12.0
-12.5
30.0
J
MM3860ANBZRE
SON-6F
4.385
2.300
2.700
7.5
14.0
-14.0
30.0
K
MM3860ANCZRE
SON-6F
Permission Disable Disable Disable Enable Enable 4.490
4.290
2.500
2.900
11.0
-8.5
30.0
G
MM3860ANDZRE
SON-6F
Permission Disable Disable Disable Enable Enable 4.525
4.425
2.300
2.700
13.0
-10.0
30.0
H
MM3860ANEZRE
SON-6F
4.290
2.500
2.900
11.0
-12.5
30.0
G
MM3860ANFZRE
SON-6F
4.425
2.300
2.700
13.0
-14.0
30.0
H
MM3860ANGZRE
SON-6F
4.290
2.500
2.900
7.5
12.0
-8.5
30.0
P
MM3860ANHZRE
SON-6F
4.425
2.300
2.700
7.5
14.0
-10.0
30.0
K
MM3860ANJZRE
SON-6F
4.290
2.500
2.900
7.5
12.0
-12.5
30.0
P
MM3860ANKZRE
SON-6F
4.425
2.300
2.700
7.5
14.0
-14.0
30.0
K
MM3860BC3ZRE
SON-6F
4.295
2.500
2.900
7.0
-11.0
25.0
L
0.9
Disable Disable Disable Enable Enable 4.495
*1 Delay time
tVdet1 [s]
tVrel1 [ms]
tVdet2 [ms]
tVrel2 [ms]
tVdet3-1 [ms]
tVdet3-2 [ms]
tVrel3 [ms]
tVdet4 [ms]
tVrel4 [ms]
tshort [us]
A
1.024
1.00
64.00
1.00
4096.00
16.00
8.00
16.00
4.00
280
B
1.024
1.00
64.00
1.00
3584.00
16.00
8.00
16.00
1.00
280
C
1.024
1.00
32.00
1.00
64.00
8.00
16.00
4.00
250
D
1.024
1.00
64.00
1.00
128.00
8.00
64.00
4.00
250
E
1.024
16.00
20.00
1.00
12.00
2.00
16.00
1.00
250
F
1.024
16.00
32.00
1.00
3584.00
32.00
8.00
32.00
1.00
250
G
1.024
16.00
128.00
4.00
16.00
4.00
8.00
4.00
280
H
1.024
16.00
128.00
1.00
32.00
4.00
32.00
4.00
530
I
1.024
1.00
64.00
1.00
3584.00
16.00
8.00
16.00
4.00
280
J
1.024
16.00
128.00
4.00
3584.00
16.00
4.00
8.00
4.00
280
K
1.024
16.00
128.00
1.00
3584.00
32.00
4.00
32.00
4.00
530
L
0.512
1.00
64.00
1.00
128.00
8.00
32.00
1.00
280
N
1.024
1.00
64.00
1.00
256.00
8.00
64.00
1.00
280
M
1.024
16.00
128.00
1.00
2048.00
4.00
2.00
16.00
1.00
280
O
1.024
1.00
64.00
1.00
3072.00
256.00
8.00
16.00
4.00
280
P
1.024
16.00
128.00
4.00
2048.00
16.00
4.00
8.00
4.00
280
Q
1.024
1.00
32.00
1.00
16.00
1.00
16.00
1.00
250
R
1.024
16.00
20.00
1.00
12.00
1.00
16.00
1.00
250
S
1.024
16.00
32.00
1.00
20.00
1.00
32.00
1.00
500
T
1.024
16.00
96.00
4.00
12.00
2.00
8.00
4.00
250
U
2.048
16.00
128.00
4.00
512.00
8.00
32.00
8.00
400
Oct, 2020 Rev.0
很抱歉,暂时无法提供与“MM3860AL2ZRE”相匹配的价格&库存,您可以联系我们找货
