HVC
SERIES
HIGH VOLTAGE CERAMIC CAPACITORS
FEATURES:
• Capacitance range: 0.5pF to 2.2uF
• Voltage range: 200V to 5000V
• Ceramic monolithic structure provides excellent reliability
• High-speed automated placement capabilities
PART NUMBER STRUCTURE
C
1808
X7R
202
Ceramic
Capacitor
Size
0603
0805
1206
1210
1808
1812
1825
2220
2225
Temperature
Characteristic
(Dielectric)
C0G
X7R
Rated Voltage
1st two digits
are significant
followed by
number of
zeroes.
201 = 200V
251 = 250V
501 = 500V
601 = 600V
631 = 630V
102 = 1000V
202 = 2000V
302 = 3000V
402 = 4000V
502 = 5000V
102
K
N
E
Capacitance
(picofarads)
1st two digits are
significant, followed by
number of zeroes.
R denotes decimal
e.g:
101 = 100pF
R denotes decimal
6R8 = 6.8pF
Tolerance
*C = ± 0.25pF
*D = ± 0.50pF
F = ± 1%
G = ± 2%
J = ± 5%
K = ± 10%
M = ± 20%
N = ± 30%
For values below
10pF only.
Termination
N = 100% matte Tin (Sn)
over nickel.
P = Palladium Silver
Packaging
E = Embossed Tape
Example P/N: C1808X7R202-102KNE
Standard termination finish is 100% matte Tin (Sn).
DIMENSIONS
Unit: inch (mm)
L
W
C
L
W
T
E/B
0603
0.063 ± 0.0078
(1.60 ± 0.20)
0.0315 ± 0.0078
(0.80 ± 0.20)
See Specific Value
0.0158 ± 0.006
(0.40 ± 0.15)
0805
0.079 ± 0.0078
(2.00 ± 0.20)
0.05 ± 0.0078
(1.25 ± 0.20)
See Specific Value
0.020 ± 0.0078
(0.50 ± 0.20)
1206
0.130 ± 0.012
(3.30 ± 0.30)
0.063 ± 0.0078
(1.60 ± 0.20)
See Specific Value
0.0236 ± 0.0078
(0.60 ± 0.20)
1210
0.130 ± 0.0158
(3.30 ± 0.40)
0.0985 ± 0.012
(2.50 ± 0.30)
See Specific Value
0.0295 ± 0.0138
(0.75 ± 0.35)
1808
0.177 ± 0.0158
(4.50 ± 0.40)
0.080 ± 0.0098
(2.03 ± 0.25)
See Specific Value
0.0295 ± 0.0138
(0.75 ± 0.35)
1812
0.177 ± 0.0158
(4.50 ± 0.40)
0.126 ± 0.0158
(3.20 ± 0.40)
See Specific Value
0.0295 ± 0.0138
(0.75 ± 0.35)
1825
0.177 ± 0.0158
(4.50 ± 0.40)
0.252 ± 0.0158
(6.4 0 ± 0.40)
See Specific Value
0.0295 ± 0.0138
(0.75 ± 0.35)
2220
0.225 ± 0.0158
(5.70 ± 0.40)
0.197 ± 0.0158
(5.00 ± 0.40)
See Specific Value
0.0335 ± 0.0138
(0.85 ± 0.35)
2225
0.225 ± 0.0158
(5.70 ± 0.40)
0.248 ± 0.0158
(6.30 ± 0.40)
See Specific Value
0.0335 ± 0.0138
(0.85 ± 0.35)
C
T
C
SIZE
C
Email: sales@venkel.com
Phone: 512.794.0081 |
Toll Free: 800.950.8365 |
Web: www.venkel.com
Rev: 01/2021-A
1
HVC
SERIES
ELECTRICAL SPECIFICATION
C0G (NP0)
Typical Capacitance Change vs. Temperature
15%
10%
5%
0%
-5%
-10%
-15%
-55˚C
-25˚C
0˚C
25˚C
50˚C
75˚C
100˚C
125˚C
Operating Temperature Range:
-55°C to +125°C
Temperature Coefficient:
0 ±30PPM/°C
Temperature Voltage Coefficient:
0 ±30PPM/°C
Insulation Resistance:
>100 Ω-F or 10 GΩ, whichever is less at 25°C, WDCV.
(The IR at 125°C is 10% of the value at 25°C)
Withstanding Voltage:
See below
Capacitance Tolerance:
C, D, F, G, J, K
Dielectric Strength is equal to 1.5 times rated voltage (WVDC) for 500 volt capacitors and 1.2 times (WVDC) for 1,000 through
5,000 volt capacitors.
Circuit applications in excess of 1,000 volts may require a surface coating to prevent external arcing.
X7R
15%
10%
5%
0%
-5%
-10%
-15%
-55˚C
-25˚C
0˚C
25˚C
50˚C
75˚C
100˚C
125˚C
-55°C to +125°C
0 ±15%∆°C MAX.
X7R not applicable
>100 ohms F or 10 G ohms, whichever
See below
D.F. Specification:
≥50V, ≤2.5%
J,K,M,N
TEST PARAMETERS
Test parameters for Multilayer Ceramic Capacitors - X7R:
1KHz ± 50Hz at 1.0 ± 0.2 Vrms, 25°C
Test parameters for Multilayer Ceramic Capacitors - C0G (NP0):
1MHz ± 50KHz at 1.0 ± 0.2 Vrms ≤ 1000pF, 25°C
1KHz ± 50Hz at 1.0 ± 0.2 Vrms > 1000pF, 25°C
Note: To ensure proper capacitance readings, the voltage level must be held constant. The HP4284 and Agilent E4980
has a “ALC” (Automatic Level Control) function and should be switched to the “ON” position for accurate
capacitance readings.
Web: www.venkel.com
Rev: 01/2021-A
2
HVC
SERIES
VOLTAGE AND CAPACITANCE RANGE
L
w
E/B
C0G (NP0) DIELECTRIC
Values that are typically available.
T
0603
0805
1206
1210
L
0.063 ± 0.0078
(1.60 ± 0.20)
0.083 ± 0.0078
(2.10 ± 0.20)
0.130 ± 0.012
(3.30 ± 0.30)
0.130 ± 0.0158
(3.30 ± 0.40)
W
0.0315 ± 0.0078
(0.8 ± 0.20)
0.05 ± 0.0078
(1.25 ± 0.20)
0.063 ± 0.0078
(1.60 ± 0.20)
0.0985 ± 0.012
(2.50 ± 0.30)
T (max)
0.0394
(1.0)
0.057
(1.45)
0.075
(1.90)
0.110
(2.80)
E/B
0.0158 ± 0.006
(0.40 ± 0.15)
0.020 ± 0.0078
(0.50 ± 0.20)
0.0236 ± 0.0078
(0.60 ± 0.20)
0.0295 ± 0.0138
(0.75 ± 0.35)
VDCW (MAX)
200V / 250V
0R5
1R0
1R2
1R5
1R8
2R0
2R2
2R7
3R3
3R9
5R0
8R2
100
120
150
180
220
270
330
390
470
560
680
820
101
121
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
< ------------------------------------------------------------------------------------------------ CAPACITANCE VALUE ----------------------------------------------------------------------------------------------->
< ------------------------------------------------------------------------------------------------ CAPACITANCE CODE ----------------------------------------------------------------------------------------------->
All measurements in inches (mm)
SIZE
200V /
250V
500V
600V /
630V
200V /
250V
500V
600V /
630V
1KV
2KV
3KV
200V /
250V
500V
600V /
630V
1KV
0.5pF
1.0pF
1.2pF
1.5pF
1.8pF
2.0pF
2.2pF
2.7pF
3.3pF
3.9pF
5.0pF
8.2pF
10pF
12pF
15pF
18pF
22pF
27pF
33pF
39pF
47pF
56pF
68pF
82pF
100pF
120pF
150pF
180pF
220pF
270pF
330pF
390pF
470pF
560pF
680pF
820pF
1000pF
1200pF
1500pF
1800pF
2200pF
2700pF
3300pF
3900pF
4700pF
5600pF
6800pF
8200pF
0.01uF
0.012uF
0.015uF
0.018uF
0.022uF
0.027uF
Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available.
Web: www.venkel.com
Rev: 01/2021-A
3
HVC
SERIES
L
w
E/B
T
SIZE
1808
1812
1825
L
0.177 ± 0.0158
(4.50 ± 0.40)
0.177 ± 0.0158
(4.50 ± 0.40)
0.177 ± 0.0158
(4.50 ± 0.40)
W
0.080 ± 0.0098
(2.03 ± 0.25)
0.126 ± 0.0158
(3.20 ± 0.40)
0.252 ± 0.0158
(6.40 ± 0.40)
T (max)
0.90
(2.28)
0.118
(3.0)
0.128
(3.25)
E/B
0.0295 ± 0.0138
(0.75 ± 0.35)
0.0295 ± 0.0138
(0.75 ± 0.35)
0.0295 ± 0.0138
(0.75 ± 0.35)
0R5
1R0
1R2
1R5
1R8
2R0
2R2
2R7
3R3
3R9
5R0
8R2
100
120
150
180
220
270
330
390
470
560
680
820
101
121
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
VDCW (MAX)
500V
600V /
630V
1KV
2KV
3KV
5KV
200V /
250V
500V
600V /
630V
1KV
2KV
3KV
200V /
250V
500V
600V /
630V
1KV
0.5pF
1.0pF
1.2pF
1.5pF
1.8pF
2.0pF
2.2pF
2.7pF
3.3pF
3.9pF
5.0pF
8.2pF
10pF
12pF
15pF
18pF
22pF
27pF
33pF
39pF
47pF
56pF
68pF
82pF
100pF
120pF
150pF
180pF
220pF
270pF
330pF
390pF
470pF
560pF
680pF
820pF
1000pF
1200pF
1500pF
1800pF
2200pF
2700pF
3300pF
3900pF
4700pF
5600pF
6800pF
8200pF
0.01uF
0.012uF
0.015uF
0.018uF
0.022uF
0.027uF
Web: www.venkel.com
Rev: 01/2021-A
4
HVC
SERIES
L
w
E/B
T
SIZE
1808
1812
1825
L
0.177 ± 0.0158
(4.50 ± 0.40)
0.177 ± 0.0158
(4.50 ± 0.40)
0.177 ± 0.0158
(4.50 ± 0.40)
W
0.080 ± 0.0098
(2.03 ± 0.25)
0.126 ± 0.0158
(6.40 ± 0.40)
0.252 ± 0.0158
(5.00 ± 0.40)
T (max)
0.90
(2.28)
0.118
(3.0)
.122
(3.10)
E/B
0.0295 ± 0.0138
(0.75 ± 0.35)
0.0295 ± 0.0138
(0.75 ± 0.35)
0.0295 ± 0.0138
(0.75 ± 0.35)
333
VDCW (MAX)
393
473
563
683
104
124
500V
600V /
630V
1KV
2KV
3KV
5KV
200V /
250V
500V
600V /
630V
1KV
2KV
3KV
200V /
250V
500V
600V /
630V
1KV
0.033uF
0.039uF
0.047uF
0.056uF
0.068uF
0.10uF
0.12uF
SIZE
2220
2225
L
0.225 ± 0.0158
(5.70 ± 0.40)
0.225 ± 0.0158
(5.70 ± 0.40)
W
0.197 ± 0.0158
(5.00 ± 0.40)
0.248 ± 0.0158
(6.30 ± 0.40)
T (max)
0.128
(3.25)
0.145
(3.68)
E/B
0.0335 ± 0.0138
(0.85 ± 0.35)
0.0335 ± 0.0138
(0.85 ± 0.35)
0R5
1R0
1R2
1R5
1R8
2R0
2R2
2R7
3R3
3R9
5R0
8R2
100
120
150
180
220
270
330
390
470
560
680
820
101
121
151
181
221
271
331
391
471
561
681
821
VDCW (MAX)
200V / 250V
500V
600V / 630V
1KV
5KV
200V / 250V
500V
600V / 630V
1KV
0.5pF
1.0pF
1.2pF
1.5pF
1.8pF
2.0pF
2.2pF
2.7pF
3.3pF
3.9pF
5.0pF
8.2pF
10pF
12pF
15pF
18pF
22pF
27pF
33pF
39pF
47pF
56pF
68pF
82pF
100pF
120pF
150pF
180pF
220pF
270pF
330pF
390pF
470pF
560pF
680pF
820pF
Web: www.venkel.com
Rev: 01/2021-A
5
HVC
SERIES
L
w
E/B
T
SIZE
2220
2225
L
0.225 ± 0.0158
(5.70 ± 0.40)
0.225 ± 0.0158
(5.70 ± 0.40)
W
0.197 ± 0.0158
(5.00 ± 0.40)
0.248 ± 0.0158
(6.30 ± 0.40)
T (max)
0.128
(3.25)
0.145
(3.68)
E/B
0.0335 ± 0.0138
(0.85 ± 0.35)
0.0335 ± 0.0138
(0.85 ± 0.35)
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
104
124
VDCW (MAX)
200V / 250V
500V
600V / 630V
1KV
5KV
200V / 250V
500V
X7R DIELECTRIC
0603
0805
1206
1210
L
0.063 ± 0.0078
(1.60 ± 0.20)
0.079 ± 0.0078
(2.00 ± 0.20)
0.130 ± 0.012
(3.30 ± 0.30)
0.130 ± 0.0158
(3.30 ± 0.40)
W
0.0315 ± 0.0078
(0.80 ± 0.20)
0.05 ± 0.0078
(1.27 ± 0.20)
0.063 ± 0.0078
(1.60 ± 0.20)
0.0985 ± 0.012
(2.50 ± 0.30)
T (max)
0.0315 ± 0.0078
(0.80 ± 0.20)
0.057
(1.45)
0.063 ± 0.0078
(1.60 ± 0.20)
0.0985 ± 0.0197
(2.50 ± 0.50)
E/B
0.0158 ± 0.006
(0.40 ± 0.15)
0.020 ± 0.0078
(0.50 ± 0.20)
0.0236 ± 0.0078
(0.60 ± 0.20)
0.0295 ± 0.0138
(0.75 ± 0.35)
VDCW (MAX)
200V /
250V
101
121
151
181
221
271
331
391
471
561
681
821
102
122
152
1KV
SIZE
600V / 630V
1000pF
1200pF
1500pF
1800pF
2200pF
2700pF
3300pF
3900pF
4700pF
5600pF
6800pF
8200pF
0.01uF
0.012uF
0.015uF
0.018uF
0.022uF
0.027uF
0.033uF
0.039uF
0.047uF
0.056uF
0.068uF
0.10uF
0.12uF
200V /
600V /
500V
250V
630V
1KV
200V /
250V
500V
600V /
630V
1KV
2KV
200V /
250V
500V
600V /
630V
1KV
2KV
100pF
120pF
150pF
180pF
220pF
270pF
330pF
390pF
470pF
560pF
680pF
820pF
1000pF
1200pF
1500pF
Web: www.venkel.com
Rev: 01/2021-A
6
HVC
SERIES
L
w
E/B
X7R DIELECTRIC
T
0603
0805
1206
1210
L
0.063 ± 0.0078
(1.60 ± 0.20)
0.079 ± 0.0078
(2.00 ± 0.20)
0.130 ± 0.012
(3.30 ± 0.30)
0.130 ± 0.0158
(3.30 ± 0.40)
W
0.0315 ± 0.0078
(0.80 ± 0.20)
0.05 ± 0.0078
(1.27 ± 0.20)
0.063 ± 0.0078
(1.60 ± 0.20)
0.0985 ± 0.012
(2.50 ± 0.30)
T (max)
0.0394
(1.0)
0.057
(1.45)
0.071
(1.80)
0.110
(2.80)
E/B
0.0158 ± 0.006
(0.40 ± 0.15)
0.020 ± 0.0078
(0.50 ± 0.20)
0.0236 ± 0.0078
(0.60 ± 0.20)
0.0295 ± 0.0138
(0.75 ± 0.35)
VDCW (MAX)
200V /
250V
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
104
124
154
184
224
274
334
394
474
564
684
824
105
155
225
SIZE
200V /
600V /
500V
250V
630V
1KV
200V /
250V
500V
600V /
630V
1KV
2KV
200V /
250V
500V
600V /
630V
1KV
2KV
1800pF
2200pF
2700pF
3300pF
3900pF
4700pF
5600pF
6800pF
8200pF
0.01uF
0.012uF
0.015uF
0.018uF
0.022uF
0.027uF
0.033uF
0.039uF
0.047uF
0.056uF
0.068uF
0.10uF
0.12uF
0.15uF
0.18uF
0.22uF
0.27uF
0.33uF
0.39uF
0.47uF
0.56uF
0.68uF
0.82uF
1.0uF
1.5uF
2.2uF
Web: www.venkel.com
Rev: 01/2021-A
7
HVC
SERIES
L
w
E/B
X7R DIELECTRIC
T
SIZE
1808
1812
1825
L
0.177 ± 0.0158
(4.50 ± 0.40)
0.177 ± 0.0158
(4.50 ± 0.40)
0.177 ± 0.0158
(4.50 ± 0.40)
W
0.080 ± 0.0098
(2.03 ± 0.25)
0.080 ± 0.0098
(2.03 ± 0.25)
0.252 ± 0.0158
(5.00 ± 0.40)
T (max)
0.090
(2.28)
0.118
(3.0)
0.128
(3.25)
E/B
0.0295 ± 0.0138
(0.75 ± 0.35)
0.0295 ± 0.0138
(0.75 ± 0.35)
0.0295 ± 0.0138
(0.75 ± 0.35)
101
121
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
104
124
154
184
224
274
334
394
474
564
684
824
105
155
225
VDCW (MAX)
500V
600V /
630V
1KV
2KV
3KV
4KV
200V /
250V
500V
600V /
630V
1KV
2KV
3KV
200V /
250V
500V
1KV
2KV
100pF
120pF
150pF
180pF
220pF
270pF
330pF
390pF
470pF
560pF
680pF
820pF
1000pF
1200pF
1500pF
1800pF
2200pF
2700pF
3300pF
3900pF
4700pF
5600pF
6800pF
8200pF
0.01uF
0.012uF
0.015uF
0.018uF
0.022uF
0.027uF
0.033uF
0.039uF
0.047uF
0.056uF
0.068uF
0.10uF
0.12uF
0.15uF
0.18uF
0.22uF
0.27uF
0.33uF
0.39uF
0.47uF
0.56uF
0.68uF
0.82uF
1.0uF
1.5uF
2.2uF
Web: www.venkel.com
Rev: 01/2021-A
8
HVC
SERIES
w
L
E/B
X7R DIELECTRIC
T
SIZE
2220
2225
L
0.225 ± 0.0158
(5.70 ± 0.40)
0.225 ± 0.0158
(5.70 ± 0.40)
W
0.197 ± 0.0158
(5.00 ± 0.40)
0.248 ± 0.0158
(6.30 ± 0.40)
T (max)
0.122
(3.10)
0.145
(3.68)
E/B
0.0335 ± 0.0138
(0.85 ± 0.35)
0.0335 ± 0.0138
(0.85 ± 0.35)
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
104
124
154
184
224
274
334
394
474
564
684
824
105
155
225
VDCW (MAX)
200V / 250V
500V
1KV
2KV
200V / 250V
500V
1KV
2KV
150pF
180pF
220pF
270pF
330pF
390pF
470pF
560pF
680pF
820pF
1000pF
1200pF
1500pF
1800pF
2200pF
2700pF
3300pF
3900pF
4700pF
5600pF
6800pF
8200pF
0.01uF
0.012uF
0.015uF
0.018uF
0.022uF
0.027uF
0.033uF
0.039uF
0.047uF
0.056uF
0.068uF
0.10uF
0.12uF
0.15uF
0.18uF
0.22uF
0.27uF
0.33uF
0.39uF
0.47uF
0.56uF
0.68uF
0.82uF
1.0uF
1.5uF
2.2uF
Web: www.venkel.com
Rev: 01/2021-A
9
HVC
SERIES
TAPE & REEL SPECIFICATIONS
G
B
All tape and reel
specifications must
A
be adhered to per
EIA-481-1-A.
D
N
C
FULL RADIUS
T
TAPING SPECIFICATIONS
To
T
D
10 Pitches
Cumulative
Tolerance
0.008
( 0.2)
REEL DIMENSIONS
B min
C
A (7”)
A (13”)
D min
N mIn
G
T max
8mm
0.3
(.012)
13 ± .05
(.512 ± .02)
178 ± 2.0
(7± .079)
330 ± 2.0
(13 ± .08)
20.2
(.795)
50
(1.97)
10 ± 1.5
(.394 ± 1.059)
14.9
(.587)
12mm
0.3
(.012)
13 ± .05
(.512 ± .02)
178 ± 2.0
(7± .079)
330 ± 2.0
(13 ± .08)
20.2
(.795)
50
(1.97)
10 ± 1.5
(.394 ± 1.059)
14.9
(.587)
7 IN. REEL QUANTITIES*
SIZE
0603
0805
1205
1210
1812
2221
Tape Size
8mm
8mm
8mm
8mm
12mm
12mm
Min Qty
per Reel
3000
2000
2000
1000
1000
1000
Max Qty
per eel
4000
5000
5000
5000
3000
1000
Po
Pz
A
E
F
W
B
T
Paper
Embossed
Top Tape
P
Unit: mm (inch)
TAPE
* Quantity dependent on thickness
Center
Of Cavity
Direction Of Feed
Unit: mm (inch)
PAPER TAPE
CARRIER DIMENSIONS
(8mm)
EMBOSSED
CARRIER
DIMENSIONS
(8mm
& 12mm)
SIZE
(inches)
SIZE
(inches)
A
B
W
F
E
P0
Pz
D
t
P
0603
2.0 ± 0.05
1.10 ± 0.2
1.90 ± 0.2
8.0 ± 0.2
3.5 ± 0.1
1.75 ± 0.1
4.0 ± 0.1
- 0.0
1.5 ± 0.1
1.15 MAX
(.043 ± .008) (.075 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.045 MAX)
- .000
4.0 ± 0.1
(.157 ± .004)
0805
2.0 ± 0.05
1.16 ± 0.2
2.4 ± 0.2
8.0 ± 0.2
3.5 ± 0.1
1.75 ± 0.1
4.0 ± 0.1
- 0.0
1.5 ± 0.1
1.15 MAX
(.046 ± .008) (.095 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.045 MAX)
- .000
4.0 ± 0.1
(.157 ± .004)
1206
2.0 ± 0.05
2.0 ± 0.2
3.6 ± 0.2
8.0 ± 0.2
3.5 ± 0.1
1.75 ± 0.1
4.0 ± 0.1
- 0.0
1.5 ± 0.1
1.15 MAX
(.079 ± .008) (.142 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.045 MAX)
- .000
4.0 ± 0.1
(.157 ± .004)
A
B
W
F
E
P0
Pz
D
T0
T
P
0805
1.5 ± 0.1
1.48 ± 0.2
2.3 ± 0.2
8.0 ± 0.2
3.5 ± 0.1
1.75 ± 0.1
4.0 ± 0.1
2.0 ± 0.05
- 0.0
2.5 MAX
(.058 ± .008) (.091 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.098 MAX)
- .000
0.6 MAX
(.024 MAX)
4.0 ± 0.1
(.157 ± .004)
1206
1.5 ± 0.1
2.0 ± 0.2
3.6 ± 0.2
8.0 ± 0.2
3.5 ± 0.1
1.75 ± 0.1
4.0 ± 0.1
2.0 ± 0.05
- 0.0
2.5 MAX
(.079 ± .008) (.142 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.098 MAX)
- .000
0.6 MAX
(.024 MAX)
4.0 ± 0.1
(.157 ± .004)
1210
1.5 ± 0.1
2.9 ± 0.2
3.6 ± 0.2
8.0 ± 0.2
3.5 ± 0.1
1.75 ± 0.1
4.0 ± 0.1
2.0 ± 0.05
- 0.0
2.5 MAX
(.114 ± .008) (.142 ± .008) (.315 ± .008) (.138 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004) (.098 MAX)
- .000
0.6 MAX
(.024 MAX)
4.0 ± 0.1
(.157 ± .004)
1808
2.5 ± 0.2
4.9 ± 0.2
12.0 ± 0.3
(.098 ± .008) (.193 ± .008) (.472 ± .012)
1.5 ± 0.1
5.5 ± 0.5
1.75 ± 0.1
4.0 ± 0.1
2.0 ± 0.05
- 0.0
(.22 ± .002) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004)
- .000
4.0 MAX
(.16 MAX)
0.6 MAX
(.024 MAX)
4.0 ± 0.1
(.157 ± .004)
1812
1.5 ± 0.1
3.6 ± 0.2
4.9 ± 0.2
12.0 ± 0.3
5.6 ± 0.1
1.75 ± 0.1
4.0 ± 0.1
2.0 ± 0.05
- 0.0
(.142 ± .008) (.193 ± .008) (.472 ± .012) (.221 ± .004) (.069 ± .004) (.157 ± .004) (.079 ± .002) (.064 ± .004)
- .000
4.0 MAX
(.16 MAX)
0.6 MAX
(.024 MAX)
8.0 ± 0.1
(.315 ± .004)
2220
5.4 ± 0.2
(.21 ± .008)
6.1 ± 0.2
(.24 ± .008)
12.0 ± 0.3
(.472 ± .012)
1.5 ± 0.1
5.5 ± 0.5
1.75 ± 0.1
4.0 ± 0.1
2.0 ± 0.05
- 0.0
- .000
4.0 MAX
(.16 MAX)
0.6 MAX
(.024 MAX)
8.0 ± 0.1
(.315 ± .004)
2225
6.9 ± 0.2
(.27 ± .008)
6.1 ± 0.2
(.24 ± .008)
12.0 ± 0.3
(.472 ± .012)
1.5 ± 0.1
5.5 ± 0.5
1.75 ± 0.1
4.0 ± 0.1
2.0 ± 0.05
- 0.0
- .000
4.0 MAX
(.16 MAX)
0.6 MAX
(.024 MAX)
8.0 ± 0.1
(.315 ± .004)
Web: www.venkel.com
Rev: 01/2021-A
10
很抱歉,暂时无法提供与“C0805X7R251-121KNE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19948
- 200+0.15596
- 600+0.13166
- 4000+0.11718
