GMC21X7R331K100NT
GMC21X7R331K100NT
    CAL-CHIP
    贴片电容(MLCC) 0805 330pF ±10% 100V X7R
GMC21X7R331K100NT 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS - GMC SERIES APPLICATIONS - Can be used on surface mount assembly equipment - Our fully integrated manufacturing and total quality control systems ensure unprecedented high standards of quality and reliability. FEATURES - Large capacitance values in small sizes - Excellent high frequency characteristics CHIP CAPACITOR SELECTION DIELECTRIC TYPE COG (NPO) - Capacitance change with temperature is 0-30ppml°C which is less than -0.3%°C from -55°C to +125°C. Typical capacitance change with life is less than -0.1 % for NPOs, one-fifth that shown by most other dielectrics. NPO formulations show no aging characteristics. Ultra stable class I dielectric: linear temperature coefficient, low loss, negligible change of electrical properties with time, voltage and frequency. OPERATING TEMPERATURE RANGE TEMPERATURE COEFFICIENT DISSIPATION FACTOR -55°C to° +125 C 0±30ppm°C 0.1% Max, 0.02% Typlical DIELECTRIC WITHSTANDING VOLTAGE AGING RATE •>100GΩ or 1000ΩF •125°C VDCW: 10GΩF or 100ΩF whichever is less 3 X VDCW 0% per decade hour INSULATION RESISTANCE TEST PARAMETERS • C1000pF f=1KHz V=1.0Vrms ±0.2Vrms T=25°C Stable class II dielectric OPERATING TEMPERATURE RANGE TEMPERATURE COEFFICIENT DISSIPATION FACTOR INSULATION RESISTANCE DIELECTRIC WITHSTANDING VOLTAGE AGING RATE X7R: -55C to+125C X5R: -55C to+85C X6S: -55C to+105C X7S: -55C to+125C ± 15% ± 15% ± 22% ± 22% 2.5% Max, 1.8% Typical •25°C, VdCW: >100GΩF or 1000ΩF, whichever is less •125°C, VdCW: >100GΩF or1000ΩF whichever is less 2.5 X VDCW or = to 10μF 0.5+/-0.1 VDCW @120Hz Z5U - Despite their capacitance instability, Z5U formulations are very popular because of their small size, temperature range low ESL, low ESR and excellent frequency response. These features are particularly important for decoupling application where only a minimum capacitance value is required. Y5V - Y5V formulations are for general purpose use in a limited temperature range. They have a wide temperature characteristic of +22% - 82% capacitance change over the operating temperature range of -30°C to +85°C. Y5Vs high dielectric constant allows the manufacture of very high capacitance values (up to 100μF) in small physical sizes. High capacitance per unit volume: general purpose product TEMPERATURE OPERATING TEMPERATURE VOLTAGE TEMPERATURE COEFFICIENT COEFFICIENT RANGE (∆c MAX @ VDCW) DISSIPATION FACTOR +22% -82% 3.0% Max, 2.0% Typical -30°C to +85°C N/A INSULATION RESISTANCE •10GΩ or 100ΩF whichever is less, 25°C, VdCW DIELECTRIC WITHSTANDING VOLTAGE 2.5 X VdCW AGING RATE 3.0% per decade hour TEST PARAMETERS • 1 KHz, 1 Vrms 25°C values > or = to 10uF 1.0Vrms 120Hz 1 CONSTRUCTION NO. NAME CLASS I DIELECTRIC CLASS II DIELECTRIC 1 Ceramic Material CaZrO3 BatTi03 2 Inner Electrode Ni Ni Cu Cu 3 Inner layer 3 4 4 5 Termination 5 Middle layer Ni Ni Outer layer Sn Sn 2 1 CAPACITANCE VALUE & TOLERANCE Determined by circuit requirements. Note that chip prices decrease with lower capacitance value and looser tolerance. VOLTAGE CAPACITOR SIZE Select the smallest unit permitted by the circuit constraints that provides the required capacitance and voltage rating. All Cal-Chip capacitors conform to EIA specifications. CAPACITOR TERMINATION Determined by circuit requirements. Nickel barrier is standard and recommended for units exposed to repeated solder cycles, to minimize leaching of the termination. REFLOW SOLDERING CONDITIONS 280 MAX TEMP 260 240 4°C/sec 220 200 The lead-free termination MLCCs are not only to be used on SMT against lead-free solder paste, but also suitable against lead-containing solder paste. If the optimized solder joint is requested, increasing soldering time, temperature and concentration of N2 within oven are recommended. 4°C/sec Sn-Ag-Cu Solder Paste 180 160 140 3°C/sec 120 MIN TEMP 100 80 60 Peal Temperature: 280°C max Duration Time: >260°C, 10 sec max >215°C, 60-90 sec 40 20 60-90 sec 120 sec 120 sec Time 120 sec PART NUMBER GUIDE GMC PRODUCT TYPE 21 DIMENSIONS 01: 1005 02: 0201 04: 0402 10: 0603 21: 0805 31: 1206 2 32: 1210 40: 1808 43: 1812 45: 1825 55: 2220 57: 2225 CG 102 DIELECTRIC CAPACITANCE CG: COG/NPO X7R X5R X7S X6S Y5V Z5U 0R5: 5R0: R75: 100: 101: 102: 103: 104: 105: 106: 107: 0.5pF 5.0pF 0.75pF 10pF 100pF 1000pF .01uF .1uF 1.0uF 10uF 100uF J 50 NT TOLERANCE VOLTAGE DC TERMINATION PACKAGING CODE NT: Sn/Ni PT: Pd/Ag Blank: 7" reel D: See page 19 & 20 G: See page 19 & 20 Q: See page 19 & 20 B: +/-.1pF C: +/-.25pF D: +/-.5pF F: +/-1% G: +/-2% J: +/-5% K: +/-10% M: +/-20% Z: -20%/+80% 4R0: 6R3: 10: 16: 25: 35: 50: 63: 100: 200: 4.0V 6.3V 10V 16V 25V 35V 50V 63V 100V 200V D NPO/COG NPO/COG GMC04 GMC10 GMC21 GMC31 0.6 ± 0.03 1.0 ± 0.05 1.6 ± 0.2 2.0 ± 0.3 3.2 ± 0.3 0.2 ± 0.02 0.3 ± 0.03 0.5 ± 0.05 0.8 ± 0.2 1.25 ± 0.2 1.6 ± 0.2 0.07 ~ 0.14 0.15 ± 0.05 0.1 ~ 0.35 0.1 ~ 0.4 0.25 ~ 0.75 0.25 ~ 0.75 DIMENSION (MM) GMC01 GMC02 L 0.4 ± 0.02 W BW RATED VOLTAGE 6.3 10 16 25 50 16 25 50 100 6.3 10 C C C C H C C C C H 16 25 50 100 200 25 H H H H H H H H 50 100 200 10 16 25 50 100 200 25 50 100 200 CAP. RANGE 0.1pF R10 0.2 R20 A A A A 0.3 R30 A A A A A C C C C H H H H H 0.4 R40 A A A A A C C C C H H H H H H L L L J J J J J J 0.47 R47 C C C C H H H H H H L L L J J J J J J L L 0.5 0R5 C C C C H H H H H H L L L J J J J J J L L 0.56 R56 C C C C H H H H H H L L L J J J J J J L L C C C C A A A A A A A A A 0.6 0R6 0.68 R68 0.7 0R7 A A A A C C C 0.75 R75 A A A A C C C A A A A L L L L L L H H H H H H L L L J J J J J J L L H H H H H H L L L J J J J J J L L C H H H H H H L L L J J J J J J L L L C H H H H H L L L J J J J J J L L L L L L L C C C C H H H H H H L L L J J J J J J C C C C H H H H H H L L L J J J J J J A C C C C H H H H H H L L L J J J J J J L L L L A C C C C H H H H H H L L L J J J J J J L L L L C C C C H H H H H H J J J J J J L L L L A C C C C H H H H H H J J J J J J L L L L A A C C C C H H H H H H J J J J J J L L L L A A A C C C C H H H H H H J J J J J J A A A A C C C C H H H H H H L L L L J J J J J J L L L L A A A A C C C C H H H H H H L L L L J J J J J J L L L L A A A A C C C C H H H H H H L L L L J J J J J J L L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L 0.8 0R8 0.82 R82 0.9 0R9 A A A 1 1R0 A A A 1.1 1R1 A A A A 1.2 1R2 A A A 1.3 1R3 A A 1.4 1R4 A 1.5 1R5 1.6 1R6 1.7 1R7 A A 1.8 1R8 A A A A C C C C H H H H H H 1.9 1R9 A A A A C C C C H H H H H H 2 2R0 A A A A C C C C H H H H H H 2.1 2R1 A A A A C C C C H H H H H H 2.2 2R2 A A A A C C C C H H H H H H 2.3 2R3 A A A A C C C C H H H H H H 2.4 2R4 A A A A C C C C H H H H H H 2.5 2R5 A A A A C C C C H H H H H H 2.6 2R6 A A A A C C C C H H H H H H 2.7 2R7 A A A A C C C C H H H H H H 2.8 2R8 A A A A C C C C H H H H H H 2.9 2R9 A A A A C C C C H H H H H H 3 3R0 A A A A C C C C H H H H H H 3.1 3R1 A A A A C C C C H H H H H H 3.2 3R2 A A A A C C C C H H H H H H 3.3 3R3 A A A A C C C C H H H H H H 3.4 3R4 A A A A C C C C H H H H H H 3.5 3R5 A A A A C C C C H H H H H H 3.6 3R6 A A A A C C C C H H H H H H 3.7 3R7 A A A A C C C C H H H H H H A A A A H H H H L L L L L L L L C C C C H H H H H H C C C C H H H H H H L L L L J J J J J J L L L L A C C C C H H H H H H L L L L J J J J J J L L L L A A C C C C H H H H H H A A A C C C C H H H H H H A A A C C C C H H H H H H L L L L J J J J J J L L L L A A A A C C C C H H H H H H A A A A C C C C H H H H H H 3.8 3R8 A A A A 3.9 3R9 A A A A 4 4R0 A A A 4.1 4R1 A A 4.2 4R2 A 4.3 4R3 A 4.4 4R4 4.5 4R5 A MAX HEIGHT A C H J L 0.22 0.33 0.55 0.7 0.90 3 NPO/COG NPO/COG DIMENSION (MM) GMC01 GMC02 GMC04 GMC10 GMC21 GMC31 L 0.4 ± 0.02 0.6 ± 0.03 1.0 ± 0.05 1.6 ± 0.2 2.0 ± 0.3 3.2 ± 0.3 W 0.2 ± 0.02 0.3 ± 0.03 0.5 ± 0.05 0.8 ± 0.2 1.25 ± 0.2 1.6 ± 0.2 BW 0.07 ~ 0.14 0.15 ± 0.05 0.1 ~ 0.35 0.1 ~ 0.4 0.25 ~ 0.75 0.25 ~ 0.75 RATED VOLTAGE 6.3 10 16 25 50 16 25 50 100 6.3 10 16 25 50 100 200 25 50 100 200 10 16 25 50 100 200 25 50 100 200 CAP. RANGE 4.6pF 4R6 A A A A C C C C H H H H H H L L L 4.7 4R7 A A A A A C C C C H H H H H H L L L 4.8 4R8 A A A A C H H H H H H L L L C C C 4.9 4R9 A A A A C C C C H H H H H H L L L 5 5R0 A A A A C C C C H H H H H H L L L 5.1 5R1 A A A A C C C C H H H H H H L L L 5.2 5R2 A A A A C C C C H H H H H H L L L L L L L L J L L L L J L L L L L L L L L L L L L L L L J J J J J J J J J J J J J J J J J J J J J J 5.3 5R3 A A A A C C C C H H H H H H L L L J J J J J J 5.4 5R4 A A A A C C C C H H H H H H L L L J J J J J J 5.5 5R5 A A A A C C C C H H H H H H L L L J J J J J J 5.6 5R6 A A A A A C C C C H H H H H H L L L J J J J J J 5.7 5R7 A A A A C C C C H H H H H H L L L J J J J J J 5.8 5R8 A A A A C C C C H H H H H H L L L 5.9 5R9 A A A A C C C C H H H H H H L L L J J J J J J 6 6R0 A A A A C C C C H H H H H H L L L J J J J J J 6.1 6R1 A A A A C C C C H H H H H H L L L J J J J J J 6.2 6R2 A A A A C C C C H H H H H H L L L J J J J J J 6.3 6R3 A A A A C C C C H H H H H H L L L J J J J J J 6.4 6R4 A A A A C C C C H H H H H H L L L 6.5 6R5 A A A A C C C C H H H H H H L L L J J J J J J 6.6 6R6 A A A A C C C C H H H H H H L L L J J J J J J J J J J J J L L L L J J J J J J L L L L J J J J J J J J J J J J J J J J J J L L L L J J J J J J L L L L J J J J J J L L L L L L L L H H 6.7 6R7 A A A A C C C C H H H H H H L L L 6.8 6R8 A A A A A C C C C H H H H H H L L L 6.9 6R9 A A A A C H H H H H H L L L C C C 7 7R0 A A A A A C C C C H H H H H H L L L 7.1 7R1 A A A A C H H H H H H L L L C C C 7.2 7R2 A A A A C C C C H H H H H H L L L 7.3 7R3 A A A A C C C C H H H H H H L L L L L L L 7.4 7R4 A A A A C C C C H H H H H H L L L 7.5 7R5 A A A A C C C C H H H H H H L L L 7.6 7R6 A A A A C C C C H H H H H H L L L 7.7 7R7 A A A A C C C C H H H H H H L L L 7.8 7R8 A A A A C C C C H H H H H H L L L 7.9 7R9 A A A A C C C C H H H H H H L L L 8 8R0 A A A A A C C C C H H H H H H L L L J J J J J J 8.1 8R1 A A A A C C C C H H H H H H L L L J J J J J J 8.2 8R2 A A A A A C C C C H H H H H H L L L J J J J J J 8.3 8R3 A A A A C C C C H H H H H H L L L J J J J J J 8.3 8R3 A A A A C C C C H H H H H H L L L J J J J J J 8.4 8R4 A A A A C C C C H H H H H H L L L J J J J J J J J J J J J H 8.5 8R5 A A A A C C C C H H H H H H L L L 8.6 8R6 A A A A C C C C H H H H H H L L L L L 8.7 8R7 A A A A C C C C H H H H H H L L L 8.8 8R8 A A A A C C C C H H H H H H L L L 8.9 8R9 A A A A C C C C H H H H H H L L L J J J J J J 9 9R0 A A A A C C C C H H H H H H L L L J J J J J J L L L L 9.1 9R1 A A A A C C C C H H H H H H L L L J J J J J J L L L L 9.2 9R2 A A A A C C C C H H H H H H L L L J J J J J J J J J J J J J J J J J J 9.3 9R3 A A A A C C C C H H H H H H L L L 9.4 9R4 A A A A C C C C H H H H H H L L L 9.5 9R5 A A A A C C C C H H H H H H L L L 9.6 9R6 A A A A C C C C H H H H H H L L L 9.7 9R7 A A A A C C C C H H H H H H L L L MAX HEIGHT 4 L A C H J L 0.22 0.33 0.55 0.7 0.90 L NPO/COG NPO/COG GMC04 DIELECTRIC DIMENSION (MM) GMC01 GMC02 L 0.4 ± 0.02 0.6 ± 0.03 GMC10 GMC21 GMC31 1.0 ± 0.05 1.6 ± 0.2 2.0 ± 0.3 3.2 ± 0.3 W 0.2 ± 0.02 0.3 ± 0.03 0.5 ± 0.05 0.8 ± 0.2 1.25 ± 0.2 1.6 ± 0.2 BW 0.07 ~ 0.14 0.15 ± 0.05 0.1 ~ 0.35 0.1 ~ 0.4 0.25 ~ 0.75 0.25 ~ 0.75 RATED VOLTAGE 6.3 10 16 25 50 16 25 50 100 6.3 10 16 25 50 100 200 25 50 100 200 10 16 25 50 100 200 25 50 100 200 CAP. RANGE 9.8pF 9R8 A A A A C C C C H H H H H H L L L L 9.9 9R9 A A A A C C C C H H H H H H L L L L 10 100 A A A A A C C C C H H H H H H 11 110 A A A A A C C C H H H H H 12 120 A A A A A C C C 13 130 A A A A A C C C 15 150 A A A A A C C C H H H H H 16 160 A A A A C C C H H H H H 18 180 A A A A C C C H H H H H 20 200 A A A A C C C H H H H H 22 220 A A A A C C C H H H H H 23 230 H H H H H 24 240 H H H H H 25 250 H H H H H 27 270 A A A A C C C H H H H 30 300 A A A A C C C H H H H 33 330 A A A A C C C H H H 36 360 A A A A C C C H H 38 380 H 39 390 40 400 42 420 43 430 A A A A 47 470 A A A A 50 500 51 510 53 530 56 560 60 600 62 620 A A A A A C C 68 680 A A A A A C C 70 700 75 750 80 800 82 820 A A A A 91 910 A A A A 100 101 A A A A 110 A A A A A A A A A A A A A A A A C A C A A C C C H H H H H H H H H H H L L L J J J J J J L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L H L L L L J J J J J J L L L L H L L L L J J J J J J L L L L H L L L L J J J J J J L L L L H L L L L J J J J J J L L L L H H L L L L J J J J J J L L L L H H L L L L J J J J J J L L L L H H H L L L L J J J J J J L L L L H H H H L L L L J J J J J J L L L L H H H H H H H H H H L L L L J J J J J J L L L L H H H H H L L L H H H H H C C H H H H H H L L L L J J J J J J L L L L C C C H H H H H H L L L L J J J J J J L L L L H H H H H H L L L H H H H H H L L L L J J J J J J L L L L L L L L L L L J J J J J J L L L L L L L C A C C H L L C C A C C H C C C C C H H H H H H H H H H C H H H H H H L L L L J J J J J J L L L L C H H H H H H L L L L J J J J J J L L L L L L L L L L L J J J J J J L L L L L L L L L L L J J J J J J L L L L L L L L J J J J J J L L L L L J J J J J J R R R R L J J J J J J L L L L J J J J J J L L L L J J J J J J L L L L J J J J J J L L L L J J J J J J L L L L J J J J J J L L L L C C H H H H H H H H H H H H C C C H H H H H C C C H H H H H C C C H H H H H H H L L L 111 C C C H H H H H H H L L L 120 121 C C C H H H H H H L L L 130 131 C C C H H H H H L L L 150 151 C C C H H H H H L L L 160 161 H H H H H L L L 180 181 C C C H H H H H L L L 200 201 C C C H H H H H L L L 220 221 A A A C C C H H H H H H L L L L J J J J J J L L L L 240 241 A A A C C C H H H H H H L L L L J J J J J J L L L L 250 251 L L L 270 271 L L L L J J J J J J L L L L 300 301 L L L L J J J J J J L L L L 330 331 L L L L J J J J J J L L L L 360 L L L L J J J J J J L L L L L L L L M M M M M M L L L L L L L M M M M M M L L L L L L L M M M M M M L L L L A A C C C C H H H H H C C C H H H H H C C C H H H H H 361 C C C H H H H H 390 391 C C C H H H H H 430 431 C C C H H H H H 470 471 C C C H H H H H A A A A A A H H H H H H H H L L L MAX HEIGHT A C H J L R 0.22 0.33 0.55 0.7 0.90 1.45 5 NPO/COG NPO/COG GMC04 GMC10 GMC21 GMC31 0.6 ± 0.03 1.0 ± 0.05 1.6 ± 0.2 2.0 ± 0.3 3.2 ± 0.3 0.2 ± 0.02 0.3 ± 0.03 0.5 ± 0.05 0.8 ± 0.2 1.25 ± 0.2 1.6 ± 0.2 0.07 ~ 0.14 0.15 ± 0.05 0.1 ~ 0.35 0.1 ~ 0.4 0.25 ~ 0.75 0.25 ~ 0.75 DIMENSION (MM) GMC01 GMC02 L 0.4 ± 0.02 W BW RATED VOLTAGE 6.3 25 16 25 50 25 50 6.3 10 16 25 50 100 200 25 50 100 200 16 25 50 100 200 25 50 100 200 CAP. RANGE 500pF 501 M M M M 510 511 C H H H H H H L L L L M M M M 560 561 C H H H H H H L L L L M M M M 620 621 C H H H H H H L L L L M M M M 680 681 C H H H H H H L L L L M M M M 750 751 C H H H H H H L L L M M M 820 821 C H H H H H H L L L L M M 910 911 C H H H H H H L L L L M 1000 102 C H H H H H H L L L L 1100 112 H H H H H L L L 1200 122 H H H H H M M M 1300 132 H H H H H M M M 1500 152 H H H H H M M M 1600 162 H H H H M M M 1800 182 H H H H M M M 2000 202 H H H H M M M 2200 222 H H H H M M M 2400 242 M M M 2700 272 M 3000 302 3300 332 3600 362 3900 392 4300 432 4700 472 I I I I I M M 5600 562 I I I I I M M 6200 622 M M 6800 682 M M 7500 752 M M 8200 822 M M 9100 912 M M 0.01uF 103 M M 0.012 123 M 0.015 153 M 0.018 183 0.02 L L L L L L L L L L L M L L L L M M L L L L M M M L L L L M M M M L L L L M M M M M L L L L M M M M M M M M M M L L L L M M M M M M M M M M M L L L L M M M M M M L L L L M M M M M R R R R R L L L L R R R R R L L L L M R R R R R L L L L M M H H H H M M M R R R R R M M M M H H H H M M M R R R R R M M M M R R R R R M M M R R R R R M M M M R R R R R M R R R R R M M M M M R R R R M M M M R R R R R R R O O O R R R R R R R R R R R R R R R R R R R R R R U U U R R R U U U R R R U U U 203 R R R 0.022 223 R R R U U U 0.027 273 R R R U U U 0.03 303 R R 0.033 333 R R U U U 0.039 393 U U U 0.047 473 U U U 0.056 563 U U U 0.068 683 U U U 0.082 823 U U U 0.1 104 U U U 0.12 124 I I I I I I I I I M M M R MAX HEIGHT 6 L M C H I L M Q R U 0.33 0.55 0.65 0.90 0.95 1.40 1.45 1.90 R R R R R R R NPO/COG DIELECTRIC DIMENSION (MM) GMC32 GMC40 NPO/COG GMC43 GMC45 GMC55 GMC57 5.7 ± 0.4 L 3.2 ± 0.3 4.57 ± 0.25 4.5 ± 0.35 4.5 ± 0.35 5.7 ± 0.4 W 2.5 ± 0.3 2.03 ± 0.25 3.2 ± 0.3 6.3 ± 0.4 5.0 ± 0.4 6.3 ± 0.4 BW 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.40 ~ 1.10 0.50 ~ 1.20 0.50 ~ 1.20 RATED VOLTAGE 16 25 50 100 200 50 100 200 50 100 200 50 100 200 50 100 200 50 100 200 CAP. RANGE 10pF 100 R R R R R R R R V V V V V V V V V V V V 11 110 R R R R R R R R V V V V V V V V V V V V 12 120 R R R R R R R R V V V V V V V V V V V V 13 130 R R R R R R R R V V V V V V V V V V V V 15 150 R R R R R R R R V V V V V V V V V V V V 16 160 R R R R R R R R V V V V V V V V V V V V 18 180 R R R R R R R R V V V V V V V V V V V V 20 200 R R R R R R R R V V V V V V V V V V V V 22 220 R R R R R R R R V V V V V V V V V V V V 24 240 R R R R R R R R V V V V V V V V V V V V 27 270 R R R R R R R R V V V V V V V V V V V V 30 300 R R R R R R R R V V V V V V V V V V V V 33 330 R R R R R R R R V V V V V V V V V V V V 36 360 R R R R R R R R V V V V V V V V V V V V 390 R R R R R R R R V V V V V V V V V V V V 43 430 R R R R R R R R V V V V V V V V V V V V 47 470 R R R R R R R R V V V V V V V V V V V V 51 510 R R R R R R R R V V V V V V V V V V V V 56 560 R R R R R R R R V V V V V V V V V V V V 62 620 R R R R R R R R V V V V V V V V V V V V 68 680 R R R R R R R R V V V V V V V V V V V V 75 750 R R R R R R R R V V V V V V V V V V V V 82 820 R R R R R R R R V V V V V V V V V V V V 91 910 R R R R R R R R V V V V V V V V V V V V 100 101 R R R R R R R R V V V V V V V V V V V V 120 121 R R R R R R R R V V V V V V V V V V V V 130 131 R R R R R R R R V V V V V V V V V V V V 150 151 R R R R R R R R V V V V V V V V V V V V 160 161 R R R R R R R R V V V V V V V V V V V V 180 181 R R R R R R R R V V V V V V V V V V V V 200 201 R R R R R R R R V V V V V V V V V V V V 220 221 R R R R R R R R V V V V V V V V V V V V 240 241 R R R R R V V V V V V V V V V V V V V V 270 271 R R R R R V V V V V V V V V V V V V V V 300 301 R R R R R V V V V V V V V V V V V V V V 330 331 R R R R R V V V V V V V V V V V V V V V 360 361 R R R R R V V V V V V V V V V V V V V V 390 391 R R R R R V V V V V V V V V V V V V V V 430 431 R R R R R V V V V V V V V V V V V V V V 470 471 R R R R R V V V V V V V V V V V V V V V 39 MAX HEIGHT R V 1.45 2.20 7 NPO/COG NPO/COG GMC43 GMC45 GMC55 GMC57 4.57 ± 0.25 4.5 ± 0.35 4.5 ± 0.35 5.7 ± 0.4 5.7 ± 0.4 2.5 ± 0.3 2.03 ± 0.25 3.2 ± 0.3 6.3 ± 0.4 5.0 ± 0.4 6.3 ± 0.4 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.40 ~ 1.10 0.50 ~ 1.20 0.50 ~ 1.20 DIELECTRIC DIMENSION (MM) GMC32 GMC40 L 3.2 ± 0.3 W BW RATED VOLTAGE 16 25 50 100 200 50 100 200 50 100 200 50 100 200 50 100 200 50 100 200 CAP. RANGE 510pF 511 R R R R R V V V V V V V V V V V V V V V 560 561 R R R R R V V V V V V V V V V V V V V V 620 621 V V V V V V V V V V V V V V V 680 681 R R R R R V V V V V V V V V V V V V V V 750 751 R R R R R V V V V V V V V V V V V V V V 820 821 R R R R R V V V V V V V V V V V V V V V 910 911 R R R R R V V V V V V V V V V V V V V V 1000 102 R R R R R V V V V V V V V V V V V V V V 1100 112 V V V V V V V V V V V V V V V 1200 1500 1800 2000 122 R R R R R V V V V V V V V V V V V V V V 152 R R R R R V V V V V V V V V V V V V V V 182 R R R R R V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V 202 2200 222 R 2400 242 R R R R R V V V V V V V V V V V V V V 2700 272 R R R R R V V V V V V V V V V V V V V V 3000 302 V V V V V V V V V V V V V V V 3300 332 R R R R R V V V V V V V V V V V V V V V 3900 392 R R R R R V V V V V V V V V V V V V V V 4700 472 R R R R R V V V V V V V V V V V V V V V 5600 562 R R R R R V V V V V V V V V V V V V V V 6800 682 R R R R R V V V V V V V V V V V V V V V 7500 752 R R R R R V V V V V V V V V V V V V V V 8200 822 R R R R R V V V V V V V V V V V V V V .01uF 103 R R R R R V V V V V V V V V V V V V V 0.012 123 P P P P P V V V V V V V V V V V V V 0.015 153 P P P P P V V V V V V V V V V V V 0.018 183 V V V V V V V V V V V V V V V V V 0.022 223 V V V V V V V V V V V V V V V V 0.027 273 V V V V V V V V V V V V V V V V 0.033 333 V V V V V V V V V V V V V V V 0.039 393 V V V V V Y Y Y V V V V V V V 0.047 473 V V V V V Y Y Y V V V V V V V 0.056 563 V V V V Y Y Y V V V V V V Y 683 V V V V Y Y Y V V V V V V Y 823 V V V V Y Y Y V Y Y V V Y 104 V V V V Y Y Y V Y Y V V Y Y Y V V V Y Y Y Y V V V Y V V A2 V V 0.068 0.082 0.1 R R R R V V V V V V V V V V V V V V V V 0.12 124 0.15 154 0.18 184 0.22 224 0.27 274 V V 0.33 334 V V 0.47 474 V W W W W W 1 105 2.2 225 4.7 475 R P V W Y A2 1.45 1.35 2.2 2.3 2.8 3.5 MAX HEIGHT 8 X7R DIMENSION (MM) GMC01 GMC02 GMC04 X7R GMC10 GMC21 GMC31 L 0.4 ± 0.02 0.6 ± 0.03 1.0 ± 0.05 1.6 ± 0.2 2.0 ± 0.3 3.2 ± 0.3 W 0.2 ± 0.02 0.3 ± 0.03 0.5 ± 0.05 0.8 ± 0.2 1.25 ± 0.2 1.6 ± 0.2 BW 0.07 ~ 0.14 0.15 ± 0.05 0.1 ~ 0.35 0.1 ~ 0.4 0.25 ~ 0.75 0.25 ~ 0.75 DIELECTRIC RATED VOLTAGE 6.3 10 16 6.3 10 16 25 50 6.3 10 16 25 50 100 4 6.3 10 16 25 35 50 100 200 6.3 10 16 25 35 50 100 200 6.3 10 16 25 35 50 100 200 CAP. RANGE 56pF 560 A A 68 680 A A 82 820 A A 100 101 A A 120 121 A A 150 151 A A 180 181 A A 200 201 220 221 240 241 270 271 300 301 330 331 360 361 390 391 430 431 470 471 510 511 560 561 620 621 680 681 750 751 820 821 910 911 1000 102 A A C C C C 1200 122 A A C C C C 1500 152 A A C C C C 1800 182 C C C C 2000 202 2200 222 2400 242 2700 272 3000 302 3300 332 3600 362 3900 392 A A A A A A A A A A A A A A C C H H H H H H L L L L L L L L M M M M M M M M R R R R R R R R C C H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M C C C C C H H H H H L L L L L L L L M M M M M M M M M M M M M M M M C C C C C H H H H H L L L L L L L L M M M M M M M M M M M M M M M M C C C C C H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M C C C C C H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M H H H H H L L L L L L L L M M M M M M M M M M M M M M M M H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M H H H H H L L L L L L L L M M M M M M M M M M M M M M M M H H H H H L L L L L L L L M M M M M M M M M M M M M M M M L L L L L L L L M M M M M M M M M M M M M M M M L L L L L L L L M M M M M M M M M M M M M M M M L L L L L L L L M M M M M M M M M M M M M M M M C A A C C A A A C C C A A C C C A A C C C C A C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C H H H H H H H H H H H H H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M H H H H H H L L L L L L L L M M M M M M M M M M M M M M M M L L L L L L L L M M M M M M M M M M M M M M M M L L L L L L L L M M M M M M M M M M M M M M M M H H H H H H H H H H H H L L L L L L M M M M M M M M M M M M M M M M H H H H H H L L L L L L M M M M M M M M M M M M M M M M H H H H H L L L L L L M M M M M M M M M M M M M M M M H H H H H L L L L L L M M M M M M M M M M M M M M M M H H H H H L L L L L L M M M M M M M M M M M M M M M M L L L L L M M M M M M M M M M M M M M M M L L L L L M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M R R R R R R R R M M M M M M M M R R R R R R R R M M M M M M M M R R R R R R R R H H H H H H H H H H H H H H H H H H H L L L L L L L L L L L L MAX HEIGHT A C H L M R 0.22 0.33 0.55 0.90 0.95 1.45 9 X7R DIMENSION (MM) GMC01 GMC02 GMC04 X7R GMC10 GMC21 L(L1) 0.4 ± 0.02 0.6 ± 0.03 1.0 ± 0.05 1.6 ± 0.2 2.0 ± 0.3 3.2 ± 0.3 W 0.2 ± 0.02 0.3 ± 0.03 0.5 ± 0.05 0.8 ± 0.2 1.25 ± 0.2 1.6 ± 0.2 DIELECTRIC BW(L2/LW) RATED VOLTAGE 0.07 ~ 0.14 6.3 10 16 0.15 ± 0.05 6.3 10 16 25 0.1 ~ 0.35 50 6.3 10 16 25 35 0.1 ~ 0.4 50 100 4 H 6.3 10 GMC31 0.25 ~ 0.75 16 25 35 50 100 200 0.25 ~ 0.75 6.3 10 16 25 35 50 100 200 6.3 10 16 25 35 50 100 200 CAP. RANGE 4700pF 472 C C C C H H H H H H L L L L L L L L M M M M M M M M R R R R R R R R 5600 562 C C C C H H H H H H L L L L L L L L M M M M M M M M R R R R R R R R 6800 682 C C C C H H H H H H L L L L L L L L M M M M M M M M R R R R R R R R 8200 822 C C C C H H H H H H H L L L L L L L L M M M M M M M M R R R R R R R R 0.01uF 103 C C C C H H H H H H H L L L L L L L L M M M M M M M M R R R R R R R R 0.012 123 H H H H H H L L L L L L L L M M M M M M M M R R R R R R R R 0.015 153 H H H H H H L L L L L L L L M M M M M M M M R R R R R R R R 0.018 183 H H H H H H L L L L L L L L M M M M M M M M R R R R R R R R 0.02 203 L L L L L L L M M M M M M M M R R R R R R R R 0.022 223 L L L L L L L L M M M M M M M M R R R R R R R R 0.027 H H H H H H 273 H H H H H H L L L L L L L L M M M M M M M M R R R R R R R R 0.033 333 H H H H H H M M M M M M M M M M M M M M M M R R R R R R R R 0.039 393 H H H H H H M M M M M M M M M M M M M M M M R R R R R R R T 0.047 473 H H H H H H M M M M M M M M M M M M M M R R R R R R R R R T 0.056 563 H H H H H J M M M M M M M M M M M M M M R R R R R R R R R T 0.068 683 H H H H H J M M M M M M M M M M M M M M R R R R R R R R R T 0.082 823 H H H H H J M M M M M M M M M M M M M R R R R R R R R T 0.1 104 H H H H H J M M M M M M M M M M M M M R M M M M M M M M 0.12 124 M M M M M M M M M M M M M R M M M M M M M 0.15 154 H H H H M M M M M M M R R R R R R R P P P P P P T 0.18 184 M M M M M M M R R R R R R R P P P P P P T 0.22 224 M M M M M M M R R R R R R R Q Q Q Q Q Q T 0.27 274 M M M M M M M R R R R R R Q Q Q Q Q Q T 0.33 334 M M M M M M M R R R R R R Q Q Q Q Q Q T 0.39 394 M M M M M M M R R R R R R U U U U U U U 0.47 474 M M M M M M M R R R R R R U U U U U U U 0.56 564 M M M M R R R R R R U U U U U U U 0.68 684 M M M M R R R R R R U U U U U U U 0.82 824 M M M M R R R R U U U U U U U 1 105 M M M M R R R R R R T T T T T T T 1.5 155 N N N R R R R R R U U U U U U N N N R R 2.2 225 3.3 335 4.7 475 6.8 685 10 106 22 226 33 336 47 476 100 107 150 157 220 227 * L 1.0±0.10 | W 0.5±0.10 *1L 1.0±0.15 | W 0.5±0.15 10 C C C C H H H H H H H H* H* I* I* N N N N N N M M M M M M N N N R R R R R R R R R R R R R R R Q Q Q R R R R R R A3 A3 A3 A3 A3 A3 R R U U U U U U U U U U U U U U U U U U U U U U U U U U U U MAX HEIGHT C H I J L M N P Q R S A3 T U 0.33 0.55 0.65 0.70 0.90 0.95 1.00 1.35 1.40 1.45 1.50 1.70 1.80 1.90 X7R X7R DIELECTRIC DIMENSION (MM) GMC32 GMC40 GMC43 GMC45 GMC55 GMC57 L 3.2 ± 0.3 4.57 ± 0.25 4.5 ± 0.35 4.5 ± 0.35 5.7 ± 0.4 5.7 ± 0.4 W 2.5 ± 0.3 2.03 ± 0.25 3.2 ± 0.3 6.3 ± 0.4 5.0 ± 0.4 6.3 ± 0.4 BW 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.40 ~ 1.10 0.50 ~ 1.20 0.50 ~ 1.20 RATED VOLTAGE 6.3 10 16 25 35 50 100 200 50 100 200 10 16 25 50 100 200 16 25 50 100 200 16 25 50 100 200 16 25 50 100 200 CAP. RANGE 1000pF 102 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 1200 122 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 1500 152 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 1800 182 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 2200 222 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 2400 242 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 2700 272 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 3000 302 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 3300 332 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 3600 362 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 3900 392 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 4300 432 O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V MAX HEIGHT O R V 1.10 1.45 2.20 11 X7R X7R DIELECTRIC DIMENSION (MM) GMC32 GMC40 GMC43 GMC45 GMC55 L(L1) 3.2 ± 0.3 4.57 ± 0.25 4.5 ± 0.35 4.5 ± 0.35 5.7 ± 0.4 5.7 ± 0.4 W 2.5 ± 0.3 2.03 ± 0.25 3.2 ± 0.3 6.3 ± 0.4 5.0 ± 0.4 6.3 ± 0.4 0.25 ~ 0.75 BW(L2/LW) RATED VOLTAGE 0.25 ~ 0.75 0.25 ~ 0.75 0.40 ~ 1.10 GMC57 0.50 ~ 1.20 0.50 ~ 1.20 6.3 10 16 25 35 50 63 100 200 50 100 200 10 16 25 50 100 200 16 25 50 100 200 16 25 50 100 200 16 25 50 100 200 CAP. RANGE 4700pF 472 O O O O O O O O O R R R R R R R R R V V V V V V V V V V V V V V V 5600 562 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 6800 682 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 8200 822 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.01uF 103 R R R R R R R R R V V V R R R R R R V V V V V V V V V V V V V V V 0.012 123 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.015 153 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.018 183 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.022 223 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.027 273 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.033 333 O O O O O O T T T V V V R R R R R R V V V V V V V V V V V V V V V 0.039 393 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.04 473 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.056 563 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.068 683 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.082 823 O O O O O O O O O V V V R R R R R R V V V V V V V V V V V V V V V 0.1 104 V V V V V V V V V V V V R R R R R R V V V V V V V V V V V V V V V 0.12 124 O O O O O O O O O A1 A1 V R R R R R R V V V V V V V V V V V V V V V 0.15 154 O O O O O O O Y Y A1 A1 V R R R R R R V V V V V V V V V V V V V V V 0.18 184 O O O O O O O Y Y A1 A1 V R R R R R R V V V V V V V V V V V V V V V 0.22 224 O O O O O O O O R A1 A1 R R R R R R V V V V V V V V V V V V V V V 0.27 274 O O O O O O O T Y A1 A1 R R R R R R V V V V V V V V V V V V V V V 0.33 334 O O O O O O O O T A1 A1 R R R R R R V V V V V V V V V V V V V V V 0.39 394 O O O O R R Z Z Z A1 R R R R R R V V V V V V V V V V V V V V V 0.47 474 O O O O O O O O V A1 R R R R R R V V V V V V V V V V V V V V V 0.56 564 R R R R R R R Y Y A1 R R R R V V V V V V V V V V V V V V V V 0.68 684 O O O O O O O T Y A1 R R R V V V V V V V V V V V V V V V V V 0.82 824 O O O O O O O V R R R V V V V V V V V V V V V V V V V V 1 105 T T T T T T T Y V V V V V R R R R V X X X X X V V V V V 1.5 155 Z Z Z Z Z Z Z Z V V V V V V V V V Y V V V V V Y Y Y Y Y 2.2 225 Z Z Z Z Z Z Z Z Y Y Y Y Y V V V V Y V V V V V Y Y Y Y Y 3.3 335 Z Z Z Z Z Z Z Z Y Y Y Y Y V V V V V V V V V V V V 4.7 475 Z Z Z Z Z Z Z Z V V V V Y V V V V V V V V V V V V 6.8 685 Z Z Z Z Z Y Y Y Y V V V V V V V V V V V V 10 106 Z Z Z Z Z Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y 15 156 Y Y Y 22 226 Y Y Y 33 336 47 476 100 107 150 157 220 227 330 337 Y Z Y Y A1 A1 A1 Y Y Y Y Y A1 A1 Y A4 Y Y Y V V X X Y MAX HEIGHT 12 O R T V X Y Z A1 A4 1.10 1.45 1.80 2.2 2.5 2.8 2.9 3.1 3.4 X7S X7S DIELECTRIC DIMENSION (MM) GMC02 GMC04 GMC10 GMC21 GMC31 GMC32 GMC55 L(L1) 0.6 ± 0.03 1.0 ± 0.05 1.6 ± 0.2 2.0 ± 0.3 3.2 ± 0.3 3.2 ± 0.3 5.7 ± 0.4 W 0.3 ± 0.03 0.5 ± 0.05 0.8 ± 0.2 1.25 ± 0.2 1.6 ± 0.2 2.5 ± 0.3 6.3 ± 0.4 BW(L2/LW) 0.15 ± 0.05 0.1 ~ 0.35 0.1 ~ 0.4 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.50 ~ 1.2 RATED VOLTAGE 4 6.3 10 16 4/6.3 10 16 25 50 100 4/6.3 10 16 25 35 50 100 4 6.3 10 16 25 35 50 100 4 6 10 16 25 35 50 100 4 6.3 10 16 25 50 63 100 4 6.3 10 16 25 50 100 CAP. RANGE 1000pF 102 H H H H H H L L L L L L L 1500 152 H H H H H H L L L L L L L 2200 222 H H H H H H L L L L L L L 3300 332 H H H H H H L L L L L L L 4700 472 H H H H H H L L L L L L L L 6800 682 H H H H H H L L L L L L .01uF 103 H H H H H H L L L L L L L 0.022 223 H H H H H H L L L L L L L 0.033 333 H H H H H M M M M M M M 0.039 393 H H H H H M M M M M M M 0.047 473 H H H H H M M M M M M M 0.056 563 H H H H H M M M M M M M 0.068 683 H H H H H M M M M M M M 0.082 823 H H H H M M M M M M M 0.1 104 H H H H M M M M M M M 0.15 154 M M M M M M 0.22 224 0.33 0.47 0.56 564 0.68 684 0.82 824 C C C C C C C C C C R R R R R R R R H H H M M M M M M R R R R R R R R 334 H H H M M M M M M R R R R R R R R 474 H H H M M M M M M R R R R R R R R M M M R R R R R M M M R R R R R R R M M M R R R R R R R R R R R R R R R R R R R U U U U U U U U R R R R R R R U U U U U U U U Z Z Z Z Z Z Z Z R R R R R T T T T T T T T Z Z Z Z Z Z Z Z R R R R R U U U U U U U U Z Z Z Z Z Z U U U U U U Z Z Z Z Z Z Z Z Z Z V V U U U U U U Z Z Z Z Z Z Y Y X X D D H H M M M 1 105 H H M M M 1.5 155 I I N N N M 2.2 225 J J N N N 3.3 335 N N 4.7 475 N N 6.8 685 N R R R R 10 106 N R R R R 15 156 R R R 22 226 R R R 33 336 47 476 100 107 N N R R R R U U U U U Y Y Y U U Y Y Y U U Y Y Y Z Z Z Y Y Y Y Y Y MAX HEIGHT C D H I J L M N P R T U V X Y Z 0.33 0.35 0.55 0.65 0.7 0.90 0.95 1.00 1.35 1.45 1.80 1.90 2.2 2.5 2.8 2.9 13 X6S DIMENSION (MM) GMC02 GMC04 X6S GMC10 GMC21 GMC31 L 0.6 ± 0.03 1.0 ± 0.05 1.6 ± 0.2 2.0 ± 0.3 3.2 ± 0.3 W 0.3 ± 0.03 0.5 ± 0.05 0.8 ± 0.2 1.25 ± 0.2 1.6 ± 0.2 BW 0.15 ± 0.05 0.1 ~ 0.35 0.1 ~ 0.4 0.25 ~ 0.75 0.25 ~ 0.75 DIELECTRIC RATED VOLTAGE 4 6.3 10 16 25 C 35 4 6.3 10 16 25 35 50 4 6.3 10 16 25 35 50 4 6.3 10 16 25 35 50 M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M N N N N N N N N N 4 6.3 10 16 25 35 50 100 R R R R R R R R R R R R R R R R R R R R R R R R R R R R R T T T T T T T T R R R R R R R U U U U U U U U N R R R R R R R U U U U U U U U N N R R R R R R R U U U U U U U N R R R U U U U CAP. RANGE 2200pF 222 C C C C 4700 472 C C C C C .01uf 103 C C C C C H H H H H H H 0.012 123 C C H H H H H H H 0.015 153 C C H H H H H H H 0.018 183 C C H H H H H H H 0.022 223 C C C C H H H H H H H 0.027 273 C C C C H H H H H 0.033 333 C C C C H H H H H H H 0.039 393 C C 0.047 473 C C C C H H H H H H H 0.056 563 C C H H H H H J J 0.068 683 C C H H H H H J J 0.082 823 C C H H H H H J J 0.1 104 C C H H H H H J J 0.12 124 H H 0.15 154 H H H H H 0.18 184 H H 0.22 224 H H 0.27 274 H H 0.33 334 H H 0.39 394 H H 0.47 474 H H 0.56 564 H H 0.68 684 H H 0.82 824 H H J J C E E C C C C C C C E E E E E E H H H H J H H H H H H J J J M M M M M M 1 105 1.5 155 2.2 225 2.7 275 3.3 335 3.9 395 4.7 475 6.8 685 10 106 15 156 22 226 33 336 47 476 68 686 100 107 150 157 U 220 227 U J I J J J J J I J K N N N N N N N N N N N N N N R R R R R R R R R R R R R R R R R R R R R R R N R R U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U R U U MAX HEIGHT 14 C E H I J K M N R T U 0.33 0.39 0.55 0.65 0.7 0.8 0.95 1.00 1.45 1.80 1.90 U X6S X6S DIMENSION (MM) GMC32 GMC43 L(L1) 3.2 ± 0.30 4.5 ± 0.35 W 2.5 ± 0.30 3.2 ± 0.30 BW(L2/LW) 0.75 ± 0.25 0.25 ~ 0.75 RATED VOLTAGE 2.5 4 6.3 10 16 25 35 50 4 6.3 10 16 25 35 50 CAP. RANGE 3.3uF 335 Z Z Z 4.7 475 Z Z Z 6.8 685 Z Z Z 10 106 Z Z Z Z Z 22 226 Y Y Y 33 336 47 476 Y Y Y 68 686 Z Z 100 107 Z Z 150 157 Z Z 220 227 Z Z 330 337 Z Z A1 A1 Z MAX HEIGHT Y Z A1 2.8 2.9 3.1 15 X5R X5R DIELECTRIC DIMENSION (MM) GMC01 GMC02 GMC04 GMC10 L(L1) 0.4 ± 0.02 0.6 ± 0.03 1.0 ± 0.05 1.6 ± 0.2 2.0 ± 0.3 W 0.2 ± 0.02 0.3 ± 0.03 0.5 ± 0.05 0.8 ± 0.2 1.25 ± 0.2 BW(L2/LW) RATED VOLTAGE 0.07 ~ 0.14 0.15 ± 0.05 4V 6.3 10 16 4 6.3 10 A A C C C C C 0.1 ~ 0.35 GMC21 0.1 ~ 0.4 16 25 35 50 4 6.3 10 16 25 35 50 63 6.3 10 C C C C C H H H H H H H L C C C C C H H H H H H H L C C C C C C H H H H H H H C C C C C C C H H H H H H C C C C C C C H H H H H C C C C C H H H H C C C C C C C H H H C C C C C C C H H C C C C C C H C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C 0.25 ~ 0.75 16 25 35 50 100 L L L L L L L L L L L L L L L L L L L H L L L L L L L H H L L L L L L L H H H L L L L L L L H H H H L L L L L L L H H H H H L L L L L L L H H H H H H L L L L L L L H H H H H H H L L L L L L L H H H H H H H L L L L L L L H H H H H H H L L L L L L L H H H H H H H L L L L L L L C H H H H H H H L L L L L L L C C H H H H H H H L L L L L L L C C H H H H H H H L L L L L L L L L L L L L L L L L L L L L 4 6.3 10 16 25 35 50 100 CAP. RANGE 1000pF 102 A A 1200 122 A A 1500 152 A A 1800 182 A A 2200 222 A A 2700 272 A A 3300 332 A A 3900 392 A A 4700 472 A A A 5600 562 A A A 6800 682 A A A 8200 822 A A .01uF 103 A A 0.012 123 0.015 153 0.018 183 0.02 203 0.022 223 A A C C C C 0.027 273 A A C C C 0.033 333 A A C C C 0.039 393 C C 0.047 473 C 0.056 563 0.068 683 0.082 823 A A A A A A A A A A A A A A A A A A C C H H H H H H H C H H H H H H H L L L L L L L C H H H H H H H M M M M M M M M M M M M M M M C C H H H H H H H M M M M M M M M M M M M M M M C C C H H H H H H H M M M M M M M M M M M M M M R C C C C H H H H H J J M M M M M M M M M M M M M M R C C C C J J J J J J J M M M M M M M M M M M M M M R C C C C H H H H H J J M M M M M M M M M M M M M R C H H H H H J J M M M M M M M M M M M M M R H H H M M M M M M M M M M M M R H H H M M M M M M R R R R R R R H H H M M M M R R R R R R R H H H M M M M R R R R R R R H H H M M M R R R R R R R H H H M M M R R R R R R R H H H M M M R R R R R R R M M M R R R R R R R M M M R R R R R M M M R R R R R R R M M M R R R R R M M M R R R R R R R N N N R R R R R N N N R R R R R R R N N R R R R R R R N N N N N R R R R R R R R R R R R R R N N N R R R R R R S R R R R R R R R R C 0.1 104 C C C 0.12 124 C C C 0.15 154 C C C 0.18 184 0.22 224 A A 0.27 274 A A 0.33 334 0.39 394 0.47 474 J J J 0.56 564 H H H 0.68 684 H H H 0.82 824 H H H H H H C E B F C F C E C C C C D C D C E C E* C* C* C* C* 1 105 1.5 155 C 2.2 225 E* E* E* 3.3 335 4.7 475 H H H J H H H H H H H H H J J H J H H H H C I I I I I I H H H J* J* J* J* 6.8 685 10 106 K* K* K* N N 15 156 H* H* N N 18 186 I* 22 226 K* K* N N 33 336 47 476 100 107 M M M M N M M M M M M M M N M N M I* N N* N* R R R R R R R R R R R MAX HEIGHT A B C D E F H I J K L M N R S 0.22 0.25 0.33 0.35 0.39 0.45 0.55 0.65 0.7 0.8 0.90 0.95 1.00 1.45 1.5 GMC02 - * L 0.6 ± 0.09 | W 0.3 ± 0.09 GMC04 - * L1 ± 0.2 | W0.5+0.3-0.05 GMC10 - * L1.6 ± 0.3 | W0.8+/-0.3 16 R R R R X5R X5R DIELECTRIC DIMENSION (MM) GMC31 GMC32 GMC43 L(L1) 3.2 ± 0.3 3.2 ± 0.3 4.5 ± 0.35 5.7 ± 0.4 W 1.6 ± 0.2 2.5 ± 0.3 3.2 ± 0.3 5.0 ± 0.4 BW(L2/LW) RATED VOLTAGE 0.25 ~ 0.75 0.25 ~ 0.75 4 6.3 10 16 25 35 50 100 4 6.3 10 16 25 35 GMC55 0.25 ~ 0.75 50 63 100 6.3 0.50 ~ 1.2 10 16 25 35 50 100 6.3 10 16 25 50 100 CAP. RANGE .1uF 104 M M M M M M M M V V V V V V V V V 0.12 124 M M M M M M M M O O O O O O O O O 0.15 154 P P P P P P P T O O O O O O O O Y 0.18 184 P P P P P P P T O O O O O O O O Y 0.22 224 Q Q Q Q Q Q Q T O O O O O O O O O 0.27 274 Q Q Q Q Q Q Q T O O O O O O O O T 0.33 334 Q Q Q Q Q Q Q T O O O O O O O O O 0.39 394 U U U U U U U U O O O O O R R Y Y 0.47 474 U U U U U U U U O O O O O O O O O 0.56 564 U U U U U U U U R R R R R R R R Y 0.68 684 U U U U U U U U O O O O O O O O T 0.82 824 U U U U U U U U O O O O O O O O V 1 105 T T T T T T T T T T T T T T T T Y 1.5 155 U U U U U U U Z Z Z Z Z Z Z Z Z 2.2 225 U U U U U U U Z Z Z Z Z Z Z Z Z 3.3 335 U U U U U U U Z Z Z Z Z Z Z Z Z Y Y Y Y Y Y Y V V V V V 4.7 475 U U U U U U U Z Z Z Z Z Z Z Z Z V V V V V V Y V V V V V V 6.8 685 U U U U U U Z Z Z Z Z Y Y Y Y Y Y V V V V V V 10 106 U U U U U U Z Z Z Z Z Y Y Y Y Y Y Y Y Y Y Y Y 15 156 T T T T T T Y Y Y Y 22 226 T T T T T T Y Y Y Y Y Y 33 336 T T T T T V V V 47 476 T T T T T Y Y Y 68 686 U U U V V 100 107 T T T Y Y Y 220 227 U* U* Y Y Y 330 337 Y Y U U U Y Z Y A1 A1 A1 A1 Y Y Y Y Y Y Y Y Y V A1 A1 A1 Y Y Y Y V V V X A1 A1 X X A1 A1 X X A1 A1 X A1 A1 MAX HEIGHT M O P Q R T U V X Y Z A1 0.95 1.1 1.35 1.40 1.45 1.80 1.9 2.2 2.5 2.80 2.9 3.1 GMC31 - * L3.2 ± 0.3 | W1.6+/-0.3 17 Y5V / Z5U Y5V / Z5U DIELECTRIC DIMENSION (MM) GMC02 GMC04 GMC10 GMC21 GMC31 GMC32 GMC43 GMC55 L 0.6 ± 0.03 1.0 ± 0.05 1.6 ± 0.2 2.0 ± 0.3 3.2 ± 0.3 3.2 ± 0.3 4.5 ± 0.35 5.7 ± 0.4 W 0.3 ± 0.03 0.5 ± 0.05 0.8 ± 0.2 1.25 ± 0.2 1.6 ± 0.2 2.5 ± 0.3 3.2 ± 0.3 5.0 ± 0.4 BW 0.15 ± 0.05 0.1 ~ 0.35 0.1 ~ 0.4 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.25 ~ 0.75 0.50 ~ 1.20 RATED VOLTAGE 6.3/10 6.3 10 16 25 50 6.3 10 16 25 50 6.3 10 16 25 50 6.3 10 16 25 50 6.3 10 16 25 50 6.3 10 16 25 50 6.3 10 16 25 50 CAP. RANGE 0.01uF 103 C H H H H H L L L L L M M M M M R R R R R R R R R R 0.012 123 C H H H H H L L L L L M M M M M R R R R R O O O O O 0.015 153 C H H H H H L L L L L M M M M M R R R R R O O O O O 0.018 183 C H H H H H L L L L L M M M M M R R R R R O O O O O 0.02 203 C M M M M M O O O O O 0.022 223 C H H H H H L L L L L M M M M M R R R R R O O O O O 0.027 273 C H H H H H L L L L L M M M M M R R R R R O O O O O 0.03 303 C M M M M M O O O O O 0.033 333 C H H H H H M M M M M M M M M M R R R R R O O O O O 0.039 393 C H H H H H M M M M M M M M M M R R R R R O O O O O 0.047 473 C H H H H H M M M M M M M M M M R R R R R O O O O O R R R R R 0.056 563 C H H H H J M M M M M M M M M M R R R R R O O O O O R R R R R 0.068 683 C J J J J J M M M M M M M M M M R R R R R O O O O O R R R R R V V V V V 0.082 823 C H H H H J M M M M M M M M M M R R R R R O O O O O R R R R R V V V V V 0.1 104 C H H H H J M M M M M M M M M M M M M M M V V V V V R R R R R V V V V V 0.12 124 H H H H H M M M M M M M M M M M M M M M O O O O O R R R R R V V V V V 0.15 154 H H H H M M M M M R R R R R P P P P P O O O O O R R R R R V V V V V 0.18 184 H H H H R R R R R P P P P P O O O O O R R R R R V V V V V 0.22 224 H H H H 0.27 274 H H 0.33 334 H H 0.39 394 H 0.47 474 0.56 564 0.68 M M M M M R R R R R Q Q Q Q Q O O O O O R R R R R V V V V V H M M M M M R R R R R Q Q Q Q Q O O O O O R R R R R V V V V V H M M M M M R R R R R Q Q Q Q Q O O O O O R R R R R V V V V V H H M M M M M R R R R R U U U U U O O O R R R R R R R V V V V V H H H M M M M M R R R R R U U U U U O O O O O R R R R R V V V V V H H H M M M M M R R R R R U U U U U R R R R R R R R R R V V V V V 684 H H H M M M M M R R R R R U U U U U O O O O O R R R R V V V V V V 0.82 824 H H H M M M M M R R R R R U U U U U O O O O O R R R R V V V V V V 1.0uF 105 H H H M M M M M R R R R R T T T T T T T T T T V V V V V V V V V V 1.2 125 U U U U U Z Z Z Z Z V V V V V V V V V V 1.5 155 U U U U U Z Z Z Z Z V V V V V V V V V V 2.2 225 V V V V 2.7 275 3.3 335 4.7 475 5.6 565 6.8 685 8.2 825 10 106 15 156 22 226 33 336 47 476 68 686 100 107 220 227 330 337 H M M M M M N N R R R R R U U U U U Z Z Z Z Z Y Y Y Y Y V V V V V V R R R R R U U U U U Z Z Z Z Z Y Y Y Y Y V V V V V R R R R R U U U U U Z Z Z Z Z V V V V V V V V V V V V V V V V V V V V Y Y Y Y Y Y Y R R R U U U U U Z Z Z Z Z Z R R R U U U U U Y Y Y Y Y Y Y Y Y R N R R R R T Z T T Y Y T T V V T T Y Y T T T T Y Z Y Y Z Y Y Y Y Y Y Y Y Y Y A1 A1 A1 A1 Y Y Y Y Y Y Y Y Y A1 A1 A1 Y Y Y V V V A1 A1 A1 X X X A1 X X A1 A1 X A1 A1 A1 MAX HEIGHT 18 C H L M N O P Q R T U V X Y Z A1 0.33 0.55 0.90 0.95 1.00 1.10 1.35 1.40 1.45 1.8 1.90 2.20 2.5 2.8 2.9 3.10 PACKAGING (TAPING) Per EIA-481 - Reel Type Size t SYMBOL 7” Reel A E min 10” Reel 13” Reel B C TAPE WIDTH A B C D E W t 8mm Ø178±2.0 MINØ50 Ø13±0.5 21±0.8 2.0±0.5 10±0.5 0.9±0.2 12mm Ø178±2.0 MINØ50 Ø13±0.5 21±0.8 2.0±0.5 13±0.5 1.2±0.2 8mm Ø258±2.0 MINØ70 Ø13±0.5 21±0.8 2.0±0.5 10±0.5 1.8±0.2 8mm Ø330±2.0 MINØ70 Ø13±0.5 21±0.8 2.0±0.5 10±0.5 1.8±0.2 12mm Ø330±2.0 MINØ70 Ø13±0.5 21±0.8 2.0±0.5 13±0.5 2.2±0.2 D W - To peel off the cover tape by the method shown in the right figure apply a peel-off force of 20GF - 60GF (card board); 10GF - 75GF (plastic tape). -The cover tape should not touch the top or bottom of the chip. - If the cover tape has been peeled off it may be difficult to remove the chip due to punch-hole clearance, dirt, and debris. Make sure therefore that no paper waste will adhere to and block the absorption nozzle. - If the cover tape has been peeled off from the top, stick it back on with a suitable adhesive. - Follow the illustration for the start and end of the winding operation. DIMENSION OF PAPER TAPE CARDBOARD CARRIER TAPE FOR 01005, 0201, 0402, 0603, 0805, 1206 UNIT=mm 19 PACKAGING (TAPING) Tape & Reel Dimensions • Embossed plastic carrier tape for 0805/1206/1210/1808/1812/1825/2220 AND 2225 type TYPE A0 B0 T K0 W P0 10XPo P1 P2 D0 D1 0805
GMC21X7R331K100NT
物料型号:MULTILAYER CERAMIC CHIP CAPACITORS - GMC SERIES
器件简介: - 适用于表面贴装装配设备 - 完全集成的制造和全面质量控制系统确保了前所未有的高质量和可靠性标准
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 大容量值在小尺寸中 - 出色的高频特性
功能详解: - 提供了不同类型陶瓷电容器的详细介绍,包括其电容随温度变化、电容随电压变化、耗散因子、绝缘电阻、耐电压、老化率和测试参数。
应用信息: - 主要用于需要高容量、小尺寸和良好高频特性的应用场合。
封装信息: - 提供了多种尺寸的封装信息,如01005、0201、0402、0603、0805、1206、1210、1808、1812、1825、2220、2225等,并给出了详细的尺寸和额定电压信息。
GMC21X7R331K100NT 价格&库存
很抱歉,暂时无法提供与“GMC21X7R331K100NT”相匹配的价格&库存,您可以联系我们找货
