MM3513L01NRH
MM3513L01NRH
    NMBTECHNOLOGIESCORPORATION
    SC74A
    IC, MULTI CELL, CELL BALANCE, MM
MM3513L01NRH 数据手册
MITSUMI Voltage Monitor IC for Li-ion Cell Balance Voltage Monitor IC for Li-ion Cell Balance MM3513 Series Outline The MM3513 series are voltage monitor ICs for rechargeable Lithium-ion or Lithium-polymer batteries, using a high voltage CMOS process. Each Lithium-ion or Lithium-polymer battery can be balanced. Each of these ICs is composed of voltage detectors, reference voltage sources, an oscillator, a counter circuit and logical circuits. Features (Unless otherwise specified, Topr=+25°C) (1) High-accuracy detection voltage Detection voltage 3.5V to 4.5V, 5mV steps Hysteresis voltage 0V to 0.4V, 50mV steps Accuracy±20mV Accuracy±25mV (Topr=−5 to +60°C) However,"Detection voltage-Hysteresis voltage
MM3513L01NRH
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和快速响应时间。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
MM3513L01NRH 价格&库存
很抱歉,暂时无法提供与“MM3513L01NRH”相匹配的价格&库存,您可以联系我们找货
