NJM4562M-TE2
NJM4562M-TE2
    JRC(⽇本无线)
    DMP8_5X5MM
    IC OPAMP GP 2 CIRCUIT 8DMP
NJM4562M-TE2 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM4562 DUAL OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM4562 integrated circuit is a high-gain, wide-bandwidth, low noise, dual operational amplifier capable of driving 20V peak-to-peak into 600Ω loads. The NJM4562 is frequency compensated for closed loop gains greater than 10.The NJM4562 combines many of the features of the popular NJM4558 as well as providing the capability of wider bandwidth, and higher slew rate and less noise make the NJM4562 ideal for audio preamplifiers, active filters, telecommunications, and many instrumentation applications. The availability of the NJM4562 in the surface mounted micro package allows the NJM4562 to be used in critical applications requiring very high packing densities. ■ FEATURES ● Operating Voltage ● Low Input Noise Voltage ● Package Outline ● Bipolar Technology ■ PACKAGE OUTLINE NJM4562D NJM4562M ( ±4V~±18V ) ( 0.6µVrms typ. ) DIP8,DMP8 ■ PIN CONFIGURATION NJM4562D NJM4562M PIN FUNCTION 1.A OUTPUT 2.A –INPUT 3.A +INPUT 4.V5.B +INPUT 6.B –INPUT 7.B OUTPUT 8.V+ ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) Ver.2011-07-20 -1- NJM4562 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage SYMBOL V+/VVID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 18 ± 30 ± 15 ( note ) ( DIP8 ) 500 ( DMP8 ) 300 -40~+85 -40~+125 UNIT V V V mW ˚C ˚C ( note ) For supply voltage less than ±15V,the absolute maximum input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS ( Ta=25˚C,V+/V-=±15V ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Input Resistance Large Signal Voltage Gain Maximum Output Voltage Swing 1 Maximum Output Voltage Swing 2 Input Common Mode Voltage Range Common Mode Rejection Ratio Supply Voltage Rejection Ratio Operating Current Equivalent Input Noise Voltage -2- SYMBOL VIO IIO IB RIN AV VOM1 VOM2 VICM CMR SVR ICC VNI TEST CONDITION RS≤10kΩ RL≥2kΩ,VO=±10V RL≥10kΩ RL≥2kΩ RS≤10kΩ RS≤10kΩ RS=300Ω,JISA MIN. 0.3 86 ± 12 ± 10 ± 12 70 76.5 - TYP. 0.5 5 100 5 110 ± 14 ± 13 ± 14 90 90 3.5 0.6 MAX. 6 200 500 5.7 - UNIT mV nA nA MΩ dB V V V dB dB mA µVrms Ver.2011-07-20 NJM4562 ■ TYPICAL CHARACTERISTICS Ver.2011-07-20 -3- NJM4562 ■ TYPICAL CHARACTERISTICS [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2011-07-20
NJM4562M-TE2 价格&库存
很抱歉,暂时无法提供与“NJM4562M-TE2”相匹配的价格&库存,您可以联系我们找货
