NJM4560M-TE3
NJM4560M-TE3
    JRC(⽇本无线)
    DMP8_5X5MM
    IC OPAMP GP 2 CIRCUIT 8DMP
NJM4560M-TE3 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM4560 DUAL OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM4560 integrated circuit is a high-gain, wide bandwidth, dual operational amplifier capable of driving 20V peak-to-peak into 400Ω loads. The NJM4560 combines many of the features of the NJM4558 as well as providing the capability of wider bandwidth, and higher slew rate make the NJM4560 ideal for active filters, data and telecommunications, and many instrumentation applications. The availability of the NJM4560 in the surface mounted micro-package allows the NJM4560 to be used in critical applications requiring very high packing densities. ■ FEATURES ● Operating Voltage ● Wide Gain Bandwidth Product ● Slew Rate ● Package Outline ● Bipolar Technology ■ PACKAGE OUTLINE NJM4560D ( DIP8) NJM4560M ( DMP8 ) NJM4560E ( SOP8 ) NJM4560L ( SIP8 ) ( ±4V~±18V ) ( 10MHz typ. ) ( 4V/μs typ. ) DIP8, DMP8, SIP8, SOP8 JEDEC 150mil ■ PIN CONFIGURATION PIN FUNCTION 1. A OUTPUT 2. A - INPUT 3. A +INPUT 4. V5. B +INPUT 6. B - INPUT 7. B OUTPUT 8. V+ ( Top View ) 1 8 A 2 A B 3 4 B 7 6 5 NJM4560D, NJM4560M, NJM4560E 1 2 3 4 5 6 7 8 NJM4560L ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) V+ - INPUT + INPUT OUTPUT V- Ver.2011-12-12 -1- NJM4560 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage SYMBOL V+/VVID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 18 ± 30 ± 15 ( note ) ( DIP8 ) 500 ( DMP8 ) 300 ( SOP8 ) 300 ( SIP8 ) 800 -40~+85 -40~+125 UNIT V V V mW ˚C ˚C ( note ) For supply voltage less than ±15V,the absolute maximum input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS ( Ta=25˚C,V+/V-=±15V ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Input Resistance Large Signal Voltage Gain Maximum Output Voltage Swing 1 Maximum Output Voltage Swing 2 Input Common Mode Voltage Range Common Mode Rejection Ratio Supply Voltage Rejection Ratio Operating Current Slew Rate Gain Bandwidth Product Equivalent Input Noise Voltage -2- SYMBOL VIO IIO IB RIN AV VOM1 VOM2 VICM CMR SVR ICC SR GB VNI TEST CONDITION RS≤10kΩ RL≥2kΩ,VO=±10V RL≥2kΩ IO=25mA RS≤10kΩ RS≤10kΩ RIAA,RS=2kΩ,30kHz LPF MIN. 0.3 86 ± 12 ± 10 ± 12 70 76.5 - TYP. 0.5 5 40 5 100 ± 14 ± 11.5 ± 14 90 90 4.3 4 10 1.2 MAX. 6 200 500 5.7 - UNIT mV nA nA MΩ dB V V V dB dB mA V/μs MHz μVrms Ver.2011-12-12 NJM4560 ■ TYPICAL CHARACTERISTICS Ver.2011-12-12 -3- NJM4560 ■ TYPICAL CHARACTERISTICS [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2011-12-12
NJM4560M-TE3 价格&库存
很抱歉,暂时无法提供与“NJM4560M-TE3”相匹配的价格&库存,您可以联系我们找货
