NJU7051V-TE1
NJU7051V-TE1
    JRC(⽇本无线)
    LSSOP8
    IC OPAMP GP 1 CIRCUIT 8SSOP
NJU7051V-TE1 数据手册
NJU7051/52/54 LOW INPUT OFFSET VOLTAGE C-MOS OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJU7051,52 and 54 are single,dual and quad C-MOS Operational Amplifiers operated on a single-power-supply,low voltage and low operating current. The input offset voltage is lower than 2mV,and the input bias current is as low as less than 1pA,consequently the very small signal around the ground level can be amplified. The minimum operating voltage is 1V and the output stage permits output signal to swing between both of the supply rails. Furthermore,the operating current is also as low as 15µA ( typ ) per circuit,therefore it can be applied especially to battery operated items. ■ FEATURES ● Single-Power-Supply ● Low Input Offset Voltage ( VIO=2mV max ) ● Wide Operating Voltage ( VDD=1~16V ) ● Wide Output Swing Range ( VOM=2.94V typ. @ VDD=3V ) ● Low Operating Current ( 15µA/circuit ) ● Low Bias Current ( IIB=1pA typ. ) ● Internal Compensation Capacitor ● External Offset Null Adjustment ( Only NJU7051 ) ● Package Outline DIP/DMP/SSOP8 ( NJU7051 ) DIP/DMP8 ( NJU7052 ) DIP/DMP/SSOP14 ( NJU7054 ) ● C-MOS Technology ■ PACKAGE OUTLINE NJU7051D NJU7052D NJU7054D NJU7051V NJU7051M NJU7052M NJU7054M NJU7054V ■ PIN CONFIGURATION NJU7051D NJU7051M NJU7051V NJU7052D NJU7052M NJU7054D NJU7054M NJU7054V Ver.2003-03-18 -1- NJU7051/52/54 ■ EQUIVALENT CIRCUIT ‫ ٭‬IN1,IN2 are only for NJU7051 ( NJU7052/54 don’t have these terminals ). -2- Ver.2003-03-18 NJU7051/52/54 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Common Mode Input Voltage SYMBOL VDD VID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS 18 ± 18 ( note1 ) -0.3~18 ( DIP14 ) 700 ( DIP8 ) 500 ( DMP8,14 ) 300 ( SSOP8,14 ) 300 -20~+75 -40~+125 UNIT V V V mW ˚C ˚C ( note1 ) If the supply voltage ( VDD ) is less than 18V, the input voltage must not over the VDD level though 18V is limit specified. ■ ELECTRICAL CHARACTERISTICS ( Ta=25˚C,VDD=3V,RL=∞ ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Input Impedance Large Signal Voltage Gain Input Common Mode Voltage Range Maximum Output Swing Voltage Common Mode Rejection Ratio Supply Voltage Rejection Ratio Operating Current/Circuit Slew Rate Unity Gain Bandwidth SYMBOL VIO IIO IIB RIN AV VICM VOM CMR SVR IDD SR Ft TEST CONDITION RS=50Ω RL=1MΩ AV=40dB,CL=10pF MIN. 80 0~2 2.90 60 60 - TYP. 1 1 1 90 2.94 70 70 15 0.05 0.1 MAX. 2 25 - UNIT mV pA pA TΩ dB V V dB dB µA V/µs MHz ■ OFFSET ADJUSTMENT CIRCUIT ( Only For NJU7051 ) [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2003-03-18 -3-
NJU7051V-TE1
- 物料型号:NJU7051/52/54 - 器件简介:这是单、双、四通道C-MOS运算放大器,适用于单电源、低电压和低操作电流的场合。输入偏置电压低于2mV,输入偏置电流小于1pA,适合放大接近地线水平的微小信号。 - 引脚分配:NJU7051D/M/V、NJU7052D/M、NJU7054D/M/V的引脚配置详细列出,包括非反相输入(IN+)、同相输入(IN-)、输出(OUT)、电源(VDD)和地(Vss)。 - 参数特性:包括输入偏置电压、输入偏置电流、输入阻抗、大信号电压增益、输入共模电压范围、最大输出摆动电压、共模抑制比、电源电压抑制比、工作电流和斜率。 - 功能详解:文档提供了偏置调整电路的说明,仅适用于NJU7051型号。 - 应用信息:文档提到这些运算放大器特别适合用于电池供电的设备。 - 封装信息:提供DIP/DMP/SSOP8(NJU7051)、DIP/DMP8(NJU7052)、DIP/DMP/SSOP14(NJU7054)等封装。
NJU7051V-TE1 价格&库存
很抱歉,暂时无法提供与“NJU7051V-TE1”相匹配的价格&库存,您可以联系我们找货
