NJM022BM-TE1
NJM022BM-TE1
    JRC(⽇本无线)
    DMP8_5X5MM
    IC OPAMP GP 2 CIRCUIT 8DMP
NJM022BM-TE1 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM022B DUAL LOW POWER OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM022B is a dual low-power operational amplifier.Like the NJM022,the NJM022B is the wide operating voltage range,high input inpedance,low operating current,low input noise voltage,internally frequency compensated,latch-up free,high slew rate amplifier with the short circuit protection.The NJM022B is twice the slew rate and half the input noise voltage comparing to the NJM022 with increased operating current. ■ FEATURES ● Operating Voltage ● Low Operating Current ● Slew Rate ● Short-Circuit Protection ● Package Outline ● Bipolar Technology ■ PACKAGE OUTLINE NJM022BD NJM022BM ( ±2V~±18V ) ( 250µA typ. ) ( 1V/µs typ. ) NJM022BL DIP8,DMP8,SIP8 ■ PIN CONFIGURATION NJM022BD NJM022BM PIN FUNCTION 1.A OUTPUT 2.A -INPUT 3.A +INPUT 4.V5.B +INPUT 6.B -INPUT 7.B OUTPUT 8.V+ NJM022BL ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) Ver.2012-06-13 -1- NJM022B ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Input Voltage Differential Input Voltage SYMBOL V+/VVIC VID Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 18 ± 15 ± 30 ( DIP8 ) 500 ( DMP8 ) 300 ( SIP8 ) 800 -40~+85 -40~+125 UNIT V V V mW ˚C ˚C ( note ) For supply voltage less than ±15V. the absolute maximum input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS ( Ta=+25˚C,V+/V-=±15V ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Large Singal Voltage Gain Common Mode Rejection Ratio Response Time ( Rise Time ) Slew Rate Input Common Mode Voltage Range Supply Voltage Rejection Ratio Equivalent Input Noise Voltage Short-circuit Output Current Operating Current Maximum Peak-to-Peak Output Voltage -2- SYMBOL VIO IIO IB AV CMR tR SR VICM SVR en IOS ICC VOM TEST CONDITION RS≤10kΩ RL≥10kΩ,VO=±10V RS≤10kΩ VIN=20mV,RL=10kΩ,CL=100PF VIN=10V,RL=10kΩ,CL=100PF RS≤10kΩ AV=20dB,f=1kHz RL=10kΩ MIN. 60 60 ± 12 74 ± 10 TYP. 1 1 20 88 92 0.18 1 ± 13 110 25 ±8 250 ± 14 MAX. 5 80 250 500 - UNIT mV nA nA dB dB µs V/µs V dB nV/√Hz mA µA V Ver.2012-06-13 NJM022B ■ TYPICAL CHARACTERISTICS Maximum Output Voltage Swing vs. Frequency (µA) Ver.2012-06-13 -3- NJM022B ■ TYPICAL CHARACTERISTICS [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2012-06-13
NJM022BM-TE1 价格&库存
很抱歉,暂时无法提供与“NJM022BM-TE1”相匹配的价格&库存,您可以联系我们找货
