RGC Series
Stackpole Electronics, Inc.
Semi-Precision Thick Film Chip Resistor
Resistive Product Solutions
Features:
Precision performance
Highly stable performance over time
Tolerances of 0.1% may be available - contact Stackpole for details
Temperature coefficient of resistance as low as ± 50 ppm/ºC
RoHS compliant and halogen free
REACH compliant
0402 and 0603 package sizes are qualified to AEC-Q200
Electrical Specifications
Type / Code
Power Rating (W)
@ 70ºC
Maximum
Working
Voltage (V) (1)
Maximum
Overload
Voltage (V)
TCR
(ppm/ºC)
0.1%
0.5%
1%
RGC0201
0.05
25
50
± 200
10 - 10M
RGC0402
0.063
50
100
± 50
± 100
10 - 1M
± 200
1.02M - 10M
± 50
10 - 1M
± 100
± 200
± 50
10 - 1M
RGC0603
RGC0805
RGC1206
0.1
0.125
0.25
0.25
RGC1210
RGC2010
0.33
0.75
75
150
150
300
200
400
200
200
200
RGC2512
1
± 50
10 - 1M
100 - 1M
1 - 1M
10 - 10M
10 - 1M
1.02M - 10M
1 - 10M
10 - 10M
10 - 1M
1.02M - 10M
1 - 10M
10 - 10M
10 - 1M
1.02M - 10M
± 100
10 - 1M
400
± 50
± 100
± 200
± 50
± 100
10 - 1M
± 200
1.02M - 10M
± 100
± 50
10 - 1M
1 - 9.76
500
1 - 9.76
10 - 10M
10 - 1M
10 - 10M
1.02M - 10M
1 - 10M
10 - 10M
10 - 1M
10 - 10M
10 - 1M
± 100
± 200
1 - 10M
400
400
250
± 100
± 200
± 100
± 200
400
200
Ohmic Range (Ω) and Tolerance
10 - 10M
1.02M - 10M
Note: (1) Lesser of √ P*R or maximum working voltage
Mechanical Specifications
Type / Code
Weight (g)
(1000 pc.)
RGC0201
0.150
L
Body Length
0.024 ± 0.001
0.60 ± 0.03
W
Body Width
0.012 ± 0.001
0.30 ± 0.03
Rev Date: 04/22/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
H
Body Height
0.009 ± 0.001
0.23 ± 0.03
a
Top Termination
0.006 ± 0.002
0.15 ± 0.05
b
Bottom Termination
0.006 ± 0.002
0.15 ± 0.05
Unit
inches
mm
www.seielect.com
marketing@seielect.com
RGC Series
Mechanical Specifications (cont.)
Type / Code
Weight (g)
(1000 pc.)
RGC0402
0.620
RGC0603
2.042
RGC0805
4.368
RGC1206
8.947
RGC1210
15.959
RGC2010
24.241
RGC2512
39.448
L
Body Length
0.039 ± 0.004
1.00 ± 0.10
0.063 ± 0.004
1.60 ± 0.10
0.079 ± 0.004
2.00 ± 0.10
0.122 ± 0.006
3.10 ± 0.15
0.126 ± 0.010
3.20 ± 0.25
0.197 ± 0.008
5.00 ± 0.20
0.250 ± 0.008
6.35 ± 0.20
W
Body Width
0.020 ± 0.002
0.50 ± 0.05
0.031 ± 0.004
0.80 ± 0.10
0.049 ± 0.004
1.25 ± 0.10
0.061 ± 0.004
1.55 ± 0.10
0.102 ± 0.006
2.60 ± 0.15
0.098 ± 0.006
2.50 ± 0.15
0.124 ± 0.008
3.15 ± 0.20
H
Body Height
0.012 ± 0.004
0.30 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
0.020 ± 0.004
0.50 ± 0.10
0.024 ± 0.006
0.60 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
a
Top Termination
0.008 ± 0.004
0.20 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.016 ± 0.010
0.40 ± 0.25
0.020 ± 0.010
0.50 ± 0.25
0.020 ± 0.010
0.50 ± 0.25
0.024 ± 0.010
0.60 ± 0.25
0.024 ± 0.010
0.60 ± 0.25
b
Bottom Termination
0.010 ± 0.006
0.25 ± 0.15
0.012 ± 0.008
0.30 ± 0.20
0.016 ± 0.008
0.40 ± 0.20
0.020 ± 0.012
0.50 ± 0.30
0.020 ± 0.008
0.50 ± 0.20
0.024 ± 0.012
0.60 ± 0.30
0.024 ± 0.012
0.60 ± 0.30
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Performance Characteristics
Test
Test Specification
± 1% and below
Temperature Coefficient of
Resistance
As specified.
Short Time Overload
±(1% + 0.05Ω)
Insulation resistance
≥ 10G
Endurance
±(1% + 0.1Ω)
Damp Heat with Load
±(1% + 0.1Ω)
Dry Heat
±(1% + 0.05Ω)
Bending Strength
±(1% + 0.05Ω)
Solderability
95% minimum coverage
Resistance to Soldering Heat
±(0.5% + 0.05Ω)
Voltage Proof
No breakdown or flashover
2
Test Method
JIS-C-5201-1 4.8
IEC-60115-1 4.8
-55°C +125°C, 25°C is the reference temperature
JIS-C-5201-1 4.13
IEC-60115-1 4.13
RCWV*2.5 or max. overload voltage whichever
is lower for 5 seconds;
2 seconds for high power series
JIS-C-5201-1 4.6
IEC-60115-1 4.6
Max. overload voltage for 1 minute
JIS-C-5201-1 4.25
IEC-60115-1 4.25.1
70 ± 2°C, RCWV for 1000 hours with 1.5 hours
"ON" and 0.5 hour "OFF"
JIS-C-5201-1 4.24
IEC-60115-1 4.24
40 ± 2°C, 90 ~ 95% R.H., RCWV for 1000 hours
with 1.5 hour "ON" and 0.5 hour "OFF"
JIS-C-5201-1 4.23
IEC-60115-1 4.23.2
at +125 / +155°C for 1000 hours
JIS-C-5201-1 4.33
IEC-60115-1 4.33
Bending once for 5 seconds
2010, 2512 sizes: 2 mm; other sizes: 3 mm
JIS-C-5201-1 4.17
IEC-60115-1 4.17
245 ± 5°C for 3 seconds
JIS-C-5201-1 4.18
IEC-60115-1 4.18
260 ± 5°C for 10 seconds
JIS-C-5201-1 4.7
IEC-60115-1 4.7
1.42 times max. operating voltage for 1 minute
www.seielect.com
RGC Series
Performance Characteristics (cont.)
Test Specification
± 1% and below
Individual leaching area ≤ 5%
Total leaching area ≤ 10%
Test
Test Method
JIS-C-5201-1 4.18
IEC-60068-2-58 8.2.1
260 ± 5°C for 30 seconds
JIS-C-5201-1 4.19
Rapid Change of Temperature
±(0.5% + 0.05Ω)
IEC-60115-1 4.19
-55°C to +125 / +155°C, 5 cycles
RCWV (Rated Continuous Working Voltage) = √ P*R or max. operating voltage whichever is lower
Storage temperature: 25 ± 3ºC; humidity < 80% RH
Operating temperature range for 0201 is -55°C to +125°C
Operating temperature range for 0402 - 2512 is -55°C to 155°C
Leaching
Power Derating Chart:
Percent Rated Power (%)
100
-55ºC
70ºC
80
60
0402 - 2512
40
0201
60
80
125ºC
100
120
140
155ºC
160
180
Ambient Temperature (ºC)
Recommended Pad Layout
Type / Code
RGC0201
RGC0402
RGC0603
RGC0805
RGC1206
a
b
c
Unit
0.012
0.30
0.020
0.50
0.035
0.90
0.047
1.20
0.079
2.00
0.010
0.25
0.018
0.45
0.024
0.60
0.028
0.70
0.035
0.90
0.012
0.30
0.024
0.60
0.035
0.90
0.051
1.30
0.063
1.60
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
3
www.seielect.com
RGC Series
Recommended Pad Layout (cont.)
Type / Code
RGC1210
RGC2010
RGC2512
a
b
c
Unit
0.079
2.00
0.150
3.80
0.193
4.90
0.035
0.90
0.035
0.90
0.063
1.60
0.110
2.80
0.110
2.80
0.138
3.50
inches
mm
inches
mm
inches
mm
Soldering Profiles
(1) Time of IR reflow soldering at maximum temperature point 260ºC : 10 seconds
(2) Time of wave soldering at maximum temperature point 260ºC : 10 seconds
(3) Time of soldering iron at maximum temperature point 410ºC : 5 seconds
Packaging Specifications
Type / Code
RGC0201
RGC0402
RGC0603
RGC0805
RGC1206
RGC1210
RGC2010
RGC2512
Packaging
Description
Tape
Width
Reel
Diameter
A
B
C
W
T
Unit
Paper
8mm
7 inches
7.028 ± 0.059
178.50 ± 1.50
2.362 ± 0.039
60.00 ± 1.00
0.512 ± 0.008
13.00 ± 0.20
0.354 ± 0.020
9.00 ± 0.50
0.492 ± 0.020
12.50 ± 0.50
inches
mm
Embossed
12mm
7 inches
7.028 ± 0.059
178.50 ± 1.50
2.362 ± 0.039
60.00 ± 1.00
0.512 ± 0.020
13.00 ± 0.50
0.512 ± 0.020
13.00 ± 0.50
0.610 ± 0.020
15.50 ± 0.50
inches
mm
4
www.seielect.com
RGC Series
Paper Tape Specifications
Type / Code
RGC0201
RGC0402
RGC0603
RGC0805
RGC1206
RGC2010
Type / Code
RGC0201
RGC0402
RGC0603
RGC0805
RGC1206
RGC2010
A
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
P0
0.157 ± 0.004
4.00 ± 0.10
0.157 ± 0.004
4.00 ± 0.10
0.157 ± 0.004
4.00 ± 0.10
0.157 ± 0.004
4.00 ± 0.10
0.157 ± 0.004
4.00 ± 0.10
0.157 ± 0.004
4.00 ± 0.10
0.015
0.38
0.026
0.65
0.043
1.10
0.063
1.60
0.075
1.90
0.114
2.90
W
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
P2
0.079 ± 0.002
2.00 ± 0.05
0.079 ± 0.002
2.00 ± 0.05
0.079 ± 0.002
2.00 ± 0.05
0.079 ± 0.002
2.00 ± 0.05
0.079 ± 0.002
2.00 ± 0.05
0.079 ± 0.002
2.00 ± 0.05
B
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
P1
0.079 ± 0.002
2.00 ± 0.05
0.079 ± 0.002
2.00 ± 0.05
0.157 ± 0.002
4.00 ± 0.05
0.157 ± 0.002
4.00 ± 0.05
0.157 ± 0.002
4.00 ± 0.05
0.157 ± 0.002
4.00 ± 0.05
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.027
0.68
0.045
1.15
0.075
1.90
0.094
2.40
0.138
3.50
0.138
3.50
E
0.069 ±
1.75 ±
0.069 ±
1.75 ±
0.069 ±
1.75 ±
0.069 ±
1.75 ±
0.069 ±
1.75 ±
0.069 ±
1.75 ±
D0
0.059 ±
1.50 ±
0.059 ±
1.50 ±
0.059 ±
1.50 ±
0.059 ±
1.50 ±
0.059 ±
1.50 ±
0.059 ±
1.50 ±
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.017
0.42
0.018
0.45
0.028
0.70
0.033
0.85
0.033
0.85
0.033
0.85
F
T
0.217
5.50
0.217
5.50
F
0.008
0.20
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
0.002
0.05
0.002
0.05
Unit
inches
mm
inches
mm
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
Embossed Tape Specifications
Type / Code
RGC2010
RGC2512
0.110
2.80
0.138
3.50
A
0.004
0.10
0.004
0.10
0.217
5.50
0.264
6.70
B
W
0.472 ± 0.012
12.00 ± 0.30
0.472 ± 0.012
12.00 ± 0.30
0.004
0.10
0.004
0.10
5
E
0.069 ±
1.75 ±
0.069 ±
1.75 ±
0.004
0.10
0.004
0.10
www.seielect.com
RGC Series
Embossed Tape Specifications (cont.)
Type / Code
RGC2010
RGC2512
0.157
4.00
0.157
4.00
P0
± 0.004
± 0.10
± 0.004
± 0.10
0.157
4.00
0.157
4.00
P1
± 0.004
± 0.10
± 0.004
± 0.10
0.079
2.00
0.079
2.00
P2
± 0.002
± 0.05
± 0.002
± 0.05
D0
0.059 ±
1.50 ±
0.059 ±
1.50 ±
0.004
0.10
0.004
0.10
0.047
1.20
0.047
1.20
T
0.000
0.00
0.000
0.00
Unit
inches
mm
inches
mm
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
SMD
Surface Mount Resistor
Note (1): RoHS Compliant by means of exemption 7c-I.
RGC
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
YES(1)
100% Matte Sn over Ni
Jul-04
04/27
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
6
www.seielect.com
RGC Series
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
R
G
C
F
T
C
4
K
7
Product Series
Semi-Precision
RGC
Thick Film
Size
Size
W
0201
0.05
0402 0.063
0603
0.1
0805 0.125
1206
0.25
1210
0.25
1210
0.33
2010
0.75
2512
1
Tolerance
Code Tol
Value
B
0.1%
D
0.5% E24, E96
F
1%
Packaging
Description
Size
Quantity
0201, 0402
10000
7" Reel
0603, 0805
Paper Tape
5000
T
1206, 1210
7" Reel
2010(*)
4000
Plastic Tape
2512
(*) RGC2010F 1Ω to 9.76Ω MOQ is 12000
Code
7
TCR
Code ppm
C
50
D
100
L
200
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
100 ohm = 100R
10.5 Kohm = 10K5
1 Mohm = 1M00
www.seielect.com
很抱歉,暂时无法提供与“RGC0402DTC20K0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+0.4473010000+0.05414
- 20000+0.4111920000+0.04977
- 30000+0.3917430000+0.04741
- 50000+0.3723050000+0.04506
- 100000+0.34729100000+0.04203
