NJM084V-TE1
NJM084V-TE1
    JRC(⽇本无线)
    LSSOP14
    IC OPAMP JFET 4 CIRCUIT 14SSOP
NJM084V-TE1 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM074/084 QUAD J-FET INPUT OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM074/084 are quad JFET input operational amplifiers. The NJM074/084 have the same electrical characteristics of NJM072B/082B except supply current. ■ FEATURES ● Operating Voltage ● J-FET Input ● High Input Resistance ● Low Input Bias Current ● High Slew Rate ● Wide Unity Gain Bandwidth ● Package Outline ● Bipolar Technology ■ PACKAGE OUTLINE ( ±4V~±18V ) NJM074D NJM084D ( 1012Ω typ. ) ( 30pA typ. ) ( 13V/µs typ. ) ( 3MHz typ. ) DIP14,DMP14,SSOP14 NJM074M NJM084M NJM074V NJM084V ■ PIN CONFIGURATION NJM074D/084D NJM074M/084M NJM074V/084V PIN FUNCTION 1. A OUTPUT 2. A -INPUT 3. A +INPUT 4. V+ 5. B +INPUT 6. B -INPUT 7. B OUTPUT 8. C OUTPUT 9. C –INPUT 10.C +INPUT 11.V 12.D +INPUT 13.D –INPUT 14.D OUTPUT ■ EQUIVALENT CIRCUIT ( 1/4 Shown ) Ver.2013-01-30 -1- NJM074/084 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage SYMBOL V+/VVID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 18 ± 30 ± 15 ( note1 ) ( DIP14 ) 700 ( DMP14 ) 700 ( note2 ) ( SSOP14 ) 300 -40~+85 -40~+125 UNIT V V V mW ˚C ˚C ( note1 ) For supply voltage less than ±15V. the absolute maximum input voltage is equal to the supply voltage. ( note2 ) At on PC board ■ ELECTRICAL CHARACTERISTICS ( Ta=+25˚C,V+/V-=±15V ) ( ) Applies to NJM084 PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Input Common Mode Voltage Range Maximum Peak-to-peak Output Voltage Swing Large-Signal Voltage Gain Unity Gain Bandwidth Input Resistance Common Mode Rejection Ratio Supply Voltage Rejection Ratio Operating Current Slew Rate Equivalent Input Noise Voltage SYMBOL VIO IIO IB VICM VOPP AV fT RIN CMR SVR ICC SR VNI TEST CONDITION RS=50Ω RL=10kΩ RL≥2kΩ,VO=±10V RS≤10kΩ RS≤10kΩ RS=100Ω,B.W.=10~10kHz MIN. ± 10 24 88 70 70 - TYP. 3(5) 5 30 27 106 3 1012 76 76 6 13 4 MAX. 10(15) 50(200) 200(400) 10(11.2) - UNIT mV pA pA V VP-P dB MHz Ω dB dB mA V/µs µVrms [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -2- Ver.2013-01-30
NJM084V-TE1 价格&库存
很抱歉,暂时无法提供与“NJM084V-TE1”相匹配的价格&库存,您可以联系我们找货
