NJM318E-TE2
NJM318E-TE2
    JRC(⽇本无线)
    SOIC-8
    IC OPAMP GP 1 CIRCUIT 8SOP
NJM318E-TE2 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM318 HIGH-SPEED OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION ■ PACKAGE OUTLINE The NJM318 is a precision high-speed operational amplifier, which designed for applications requiring wide bandwidth and high slew rate. They feature a factor of ten increases in speed over general purpose devices without sacrificing DC performance. The NJM318 has internal unity gain frequency compensation. This considerably simplifies its application since no external components are NJM318D necessary for operation. However, unlike most internally compensated amplifiers, external frequency compensation may be added for optimum performance. For inverting applications, feedforward compensation will boost the slew rate to over 150V/µs and almost double the bandwidth. Overcompensation can be used with the amplifier for greater stability when maximum bandwidth is not needed. Further, a single capacitor can NJM318E be added to reduce the 0.1% setting time to under 1µs. The high speed and fast setting time of these op amps make them useful in A/D converters, oscillators, active filters, sample and hold circuits, or general purpose amplifiers. These devices are easy to apply and offer an order of magnitude better AC performance than industry standards such as the NJM741. ■ FEATURES ● Operating Voltage ● Wide Unity Gain Bandwidth ● High Slew Rate ● Package Outline ● Bipolar Technology NJM318M ( ±5V~±20V ) ( 15MHz typ. ) ( 70V/µs typ. ) DIP8,DMP8,SOP8 JEDEC 150mil ■ PIN CONFIGURATION NJM318D NJM318M PIN FUNCTION 1. BAL/COMP1 2. –INPUT 3. +INPUT 4. V5. BAL/COMP3 6. OUTPUT + 7. V 8. COMP2 ■ EQUIVALENT CIRCUIT Ver.2012-10-02 -1- NJM318 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Current ( note1) Input Voltage ( note2) SYMBOL V+/VIID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 20 ± 10 ± 15 ( DIP8 ) 500 ( DMP8 ) 300 ( SOP8 ) 300 -40~+85 -40~+125 UNIT V mA V mW ˚C ˚C ( note1 ) A current limiting resistance is required when the input voltage is higher than 1V. ( note2 ) For supply voltage less than ±15V, the absolute maximum input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS ( Ta=+25˚C,V+/V-=±15V ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Input Resistance Operating Current Large Signal Voltage Gain Slew Rate Unity Gain Bandwidth Input Common Mode Voltage Range Common Mode Rejection Ratio Supply Voltage Rejection Ratio Output Voltage Swing -2- SYMBOL VIO IIO IIB RIN ICC AV SR fT VICM CMR SVR VOM TEST CONDITION RL≥2kΩ,VO=±10V AV=1,RS=10kΩ RL=2kΩ MIN. 0.5 88 50 ± 11.5 70 65 ± 12 TYP. 4 30 150 5 106 70 15 100 80 ± 13 MAX. 10 200 500 10 - UNIT mV nA nA MΩ mA dB V/µs MHz V dB dB V Ver.2012-10-02 NJM318 ■ TYPICAL CHARACTERISTICS (dB) (nA) (nA) (℃) (Hz) Ver.2012-10-02 (Hz) -3- NJM318 ■ TYPICAL CHARACTERISTICS -4- Ver.2012-10-02 NJM318 ■ TYPICAL CHARACTERISTICS ■ ADJUSTMENT METHOD [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2012-10-02 -5-
NJM318E-TE2 价格&库存
很抱歉,暂时无法提供与“NJM318E-TE2”相匹配的价格&库存,您可以联系我们找货
