NJM5534MD
NJM5534MD
    JRC(⽇本无线)
    DMP8_5X5MM
    IC OPAMP GP 1 CIRCUIT 8DMP
NJM5534MD 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM5534 HIGH PERFORMANCE LOW-NOISE OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM5534 is a high performance low noise operational amplifier. This amplifier features popular pin-out, superior noise performance, and high output drive capability. And also, features guaranteed noise performance with substantially higher gain-bandwidth product, power bandwidth, and slew rate which far exceeds that of the NJM741 type amplifiers. The specially designed low noise input transistors allow the NJM5534 to be used in very low noise signal processing applications such as audio pre-amplifiers and servo error amplifiers. The NJM5534 is internally compensated for a gain of three or higher. Externally compensation for optimizing specific performance can be obtained by use of an external compensation capacitor between COMPENSATION(5PIN) and BALANCE/COMPENSATION(8PIN). If very low noise characteristic is of prime importance, it is recommended D-Rank type products(NJM5534DD/MD). These have specified maximum limits for equivalent input noise voltage. ■ FEATURES ● Operating Voltage ● Single Circuit ● With BALANCE Terminal ● Low Input Noise Voltage ● Power Bandwidth ● Slew Rate ● Package Outline ● Bipolar Technology ■ PACKAGE OUTLINE NJM5534D (DIP8) NJM5534M (DMP8) ±3V~±22V 3.3nV/√Hz typ.@1kHz 200kHz typ. 13V/µs typ. DIP8, DMP8 ■ PIN CONFIGURATION (Top view) 1 8 2 7 3 6 4 5 DIP8, DMP8 Package PIN FUNCTION 1.BALANCE 2.–INPUT 3.+INPUT 4.V5.COMPENSATION 6.OUTPUT 7.V+ 8.BALANCE/COMPENSATION ■ EQUIVALENT CIRCUIT Ver.2011-02-22 -1- NJM5534 ■ ABSOLUTE MAXIMUM RATINGS (Ta=25˚C) PARAMETER Supply Voltage SYMBOL + RATING - UNIT V /V ±22 V Differential Input Voltage VID ±0.5 V Common Mode Input Voltage VIC V Power Dissipation PD mW Operating Temperature Range Topr V+/VDIP8: 500 DMP8: 300 -20~+75 Storage Temperature Range Tstg -40~+125 °C RATING UNIT ±3~±22 V °C ■ RECOMMENDED OPERATING VOLTAGE (Ta=25˚C) PARAMETER Supply Voltage SYMBOL + - V /V ■ ELECTRICAL CHARACTERISTICS (Ta=25˚C,V+/V-=±15V, unless otherwise noted.) PARAMETER SYMBOL TEST CONDITION RS≤10kΩ MIN. TYP. MAX. UNIT - 0.5 4 mV Input Offset Voltage VIO Input Offset Current IIO - 20 300 nA Input Bias Current IB - 500 1500 nA Input Resistance RIN 30 100 - kΩ Large Signal Voltage Gain AV RL≥2kΩ, VO=±10V 88 100 - dB Maximum Output Voltage VOM RL≥600Ω ±12 ±13 - V Common Mode Input Voltage Range VICM ±12 ±13 - V Common Mode Rejection Ratio CMR RS≤10kΩ 70 100 - dB Supply Voltage Rejection Ratio SVR RS≤10kΩ 80 100 - dB Supply Current ICC RL=∞ - 4 8 mA Trainsient Response Rise Time tR VIN=50mV, RL=600Ω, CL=100pF, Cc=22pF - 35 - ns VIN=50mV, RL=600Ω, CL=100pF, Cc=22pF - 17 - % Cc=0 - 13 - V/µs Overshoot Slew Rate SR Gain Bandwidth Product GB Cc=22pF, CL=100pF - 10 - MHz Power Bandwidth WPG Vo=20VPP, Cc=0 - 200 - kHz Equivalent Input Noise Voltage VNI f=20Hz~20kHz - 1 - µVrms Equivalent Input Noise Current INI f=20Hz~20kHz - 25 - pArms Equivalent Input Noise Voltage en Equivalent Input Noise Current in Broadband Noise Figure NF fO=30Hz - 5.5 - nV/√Hz fO=1kHz - 3.3 - nV/√Hz fO=30Hz - 1.5 - pA/√Hz fO=1kHz - 0.4 - pA/√Hz f=10Hz~20kHz, RS=5kΩ - 0.9 - dB ■ ELECTRICAL CHARACTERISTICS (D-rank type(Note1), V+/V-=±15V, Ta=25°C, unless otherwise noted.) PARAMETER Equivalent Input Noise Voltage SYMBOL VNI TEST CONDITION RIAA, RS=2.2kΩ MIN. TYP. MAX. UNIT - - 1.4 µVrms (Note1)D-rank type is a Equivalent Input Noise Voltage selected product. -2- Ver.2011-02-22 NJM5534 ■ TYPICAL CHARACTERISTICS Gain/Phase vs. Frequency 50 20 20 -40 10 -80 0 -120 -10 -160 -20 10k 100k 1M 10M Frequency [Hz] Phase [deg] 0 Maximum Output Voltage [V] Phase 30 10 -Vom V+/V-=±15V 5 0 -5 -10 -15 V+/V-=±22V -25 10 100 1k Load Resistance [Ω] 20 15 10 5 V+/V-=±15V, Ta=25ºC 30 Cc=0pF 25 Cc=50pF Cc=20pF 20 15 10 5 0 10k 10M 100k Frequency [Hz] Voltage Noise vs. Source Resistance THD vs. Output Voltage V+/V-=±15V, Ta=25ºC V+/V-=±15V, RL=10kΩ, Gv=20dB, Ta=25ºC 100 10k Maximum Output Voltage Swing vs. Frequency Maximum Output Voltage Swing [Vpp] 25 100k 1M Frequency [Hz] V+/V-=±15V 35 30 0 10k +Vom -20 -200 100M V+/V-=±15V, Ta=25ºC 35 V+/V-=±22V 15 Maximum Output Voltage Swing vs. Frequency Maximum Output Voltage Swing [Vpp] Ta=25ºC 25 Gain 40 Voltage Gain [dB] Maximum Output Voltage vs. Load Resistance Ta=25ºC 0.01 1M Total Harmonic Distortion [%] Equivalent Input Noise Voltage [µVrms] Weighting 100 10k Rs 10 Flat 100kHz LPF 1 JIS A 0.1 f=20kHz 0.001 f=20Hz f=1kHz 0.0001 10 Ver.2011-02-22 100 1k Source Resistance [Ω] 10k 1 10 Output Voltage [Vrms] -3- NJM5534 ■ TYPICAL CHARACTERISTICS Supply Current vs. Temperature Input Offset Voltage vs. Temperature 9 2.5 8 2 Input Offset Voltage [mV] Supply Current [mV] V+/V-=±15V 7 6 5 4 3 2 1.5 1 0.5 0 -0.5 -1 1 0 -1.5 -50 -25 0 25 50 75 100 Ambient Temperature [ºC] 125 -50 V+/V-=±15V 900 -25 0 25 50 75 100 Ambient Temperature [ºC] 125 Maximum Output Voltage vs. Temperature Input Bias Current vs. Temperature V+/V-=±15V, RL=600Ω 15 Maximum Output Voltage [V] 800 Input Bias Current [nA] V+/V-=±15V 700 600 500 400 300 200 100 0 +Vom 10 5 0 -5 -10 -Vom -15 -50 -25 0 25 50 75 100 Ambient Temperature [ºC] 125 -50 -25 0 25 50 75 100 Ambient Temperature [ºC] 125 Slew Rate vs. Compensation Capacitance Ta=25ºC 16 14 Slew Rate [V/µs] 12 10 8 6 4 2 0 0 -4- 10 20 30 40 50 60 70 80 90 100 Compensation Capacitance Cc [pF] Ver.2011-02-22 NJM5534 ■ TEST CIRCUIT +15V Noise Voltage (RIAA) measurement circuit 100µ Rs 2.2k 3.3µ -15V 100µ 40dB Amp 30kHz LPF 0.47µ 2.2µ Vout 56k 30k 330k 0.0024µ 0.0082µ 220k 47µ 610 ■ ADJUSTMENT METHOD Fig.1-1, Fig.1-2 shows the input offset voltage adjustment circuit, and frequency compensation circuit. Without these features, the adjustment pins are open. Fig.1-1 Input Offset Voltage Adjustment Fig.1-2 Frequency Compensation + V 22k Cc 100k 2 1 8 2 6 8 5 6 3 3 ■ NOTICE When used in voltage follower circuit, put a current limit resistor into non-inverting input terminal in order to avoid inside input diode destruction when the power supply is turned on. ( ref.Fig.2 ) 1k OUTPUT INPUT Fig.2 [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2011-02-22 -5-
NJM5534MD 价格&库存
很抱歉,暂时无法提供与“NJM5534MD”相匹配的价格&库存,您可以联系我们找货
