承
認
書
Specification for approval
客戶名稱:
Customer
產品名稱:
Description:
DB-9P 母 传统焊线式 兰胶
客 戶 料 號:
Customer part no:
燦科盟產品編號:
CKM
P/N:
DB0009PF000XH00
承 認 書 編 號:
Approval sheet NO.:
SA150431719
承 認 日 期:
Approval date:
2017-11-17
客 戶 確 認
CUSTOMER
APPROVED
核
准
APPROVED
審
核
ENGINEER
經
辦
CHECK
刘力
2017/11/17
敬請蓋印承認規格之後,將一份交回給本公司,謝謝!
Please return 1sets of this form to confirm your approval of the product
specification thank you!
深圳市燦科盟實業有限公司
工廠地址:深圳市光明楼村鲤鱼水工业区鑫博盛科技园 B 栋四楼
聯繫電話:0755-81488157
傳
真:0755-83425987
Http://www.Ckmtw.com.cn
E-mail:2000@ckmtw.com.cn
業務負責人:
28154692
13316859588
深圳市灿科盟实业有限公司
DB SERIES
内容:此规格书包含 DB 接插件系列。
Scope: This specification covers the DB spacing Connector series.
Index:
1. 产品名称及料号/Product name and part number
2. 额定电压电流/Ratings
3. 特性测试/Performance
3-1.电气特性/Electrical performance
3-1-1.接触阻抗/Contact resistance
3-1-2.绝缘阻抗/Insulation resistance
3-1-3.高压测试/Dielectric strength
3-2.机械特性/Mechanical performance
3-2-1.整组插拔测试/Insertion force and withdrawal force
3-2-2.插入力/Insertion force
3-2-3.拔入力/withdrawal force
3-3.环境特性测试/Environmental performance and others
3-3-1.整组插拔测试后接触阻抗/Repeated insertion/withdrawal
3-3-2.温升测试/Temperature rise
3-3-3.震动测试/Vibration
3-3-4.冲击测试/Shock
3-3-5.耐热测试/Heat resistance
3-3-6.低温测试/Cold resistance
3-3-7.恒温恒湿/Humidity
3-3-8.温度冲击测试/Temperature cycling
3-3-9.盐水喷雾测试/Salt spray
3-3-10.沾锡性测试/Solderability
3-3-11.焊热性测试/Resistance to soldering heat
3-3-12 寿命测试/Life Test
4. 产品规格尺寸及材质/Product shape, dimensions and materials
Page
2
2
2
2
2
2
2
2
2
3
3
3
3
3
3
3
3
3
4
4
4
4
Note::以上测试视公司之测试条件/能力而定。
FILE NO
ENS014
ECR/N NO
New spec
APPROVAL
CHECK
DRAWING
1
Product Name
Part Number
名称
Name
DMS-XP MALE
DMS-XP FEMAEL
2. 额定电压电流及使用线径/Ratings and applicable wires
ITEM
STANDARD
Rated Voltage(Max)
额定电压(最高)
250V DC/AC(rms)
Rated Current(Max)
额定电流(最高)
3A
Ambient Temperature
使用温度范围
-50℃-+105℃
3. 特性测试/Performance
ITEM
Test condition
Requirement
3-1-1
Contact
Resistance
接触阻抗
Mate connectors, reassure by dry circuit ,20mV
MAX,10mv.(Based upon JIS C5402 5.4)
0.02 欧(MAX)
将公母对插,二头接上微电流电压测试。
3-1-2
Insulation
resistance
绝缘阻抗
Mate connectors, apply 500V DC between adjacent
terminal or ground. (Based upon JIS C5402 1000 兆欧(MIN)
5.2/MIL-STD-202 method 302 condition B)
将公母对插,二头接上电压测试
3-1-3
Dielectric
strength
高压测试
Mate connectors, apply 500V AC for 1 minute between
adjacent terminal or ground. (Based upon JIS C5402
5.1/MIL-ST-202 Method 301)
将公母对插,相邻的二支端子接上高压测试
No
breakdown
and flashover
没有损坏/没有电
弧产生
ITEM
3-2-1
3-2-1
3-2-4
Test condition
Insertion
force
and
withdrawal
force
整组插拔测试
Insert and withdraw connectors at the
speed rate of 25±3mm/minute
公母对插插拔 30 次,机器行走速度
25±3mm/分钟。
Insertion force
插入力
Insert the crimped terminal into the
connectors
将公头插入母座内,测试插入值
withdrawal force
拔入力
Apply axial pull out force at the
speed rate of 25±3mm/minute on
the terminal assembled
In the housing.
将公头从母座中拔出,测试拔出值
Requirement
1.5 KgN(MIN)
2.5Kg
(MAX)
1.0Kg (MIN)
2
ITEM
Test condition
Requirement
3-3-1
Repeated
insertion/
withdrawal
When mated up to 30 cycles repeatedly by the Contact
rate of 10 cycles per minute
Resistance
三十次插拔后,测量接触阻抗
接触阻抗
40mΩ
MAX
3-3-2.
Temperatur
e Rise 温升
Carrying rated current load(Based upon UL1977)
针对额定电流以作测试
30℃
MAX
3-3-3
Vibration
震动测试
Amplitude:1.52mm P.P –调幅
Sweep time:10-55-10Hz in 1 minute 频率
Duration:2 hours in each X.Y.Z axlals 震动
时间
(based upon MIL-STD-202 method 201)
Appearance
No
Damage
Contact
Resistance
40mΩ
MAX
Discontinuity
1u
sec
MAX
不连续性
3-3-4
Shock
冲击测试
50g 3strokes in each X.Y.Z. axlals.
(based upon JIS C0041)
50g 力量,XYZ 轴分别三次冲击。
Appearance
No
Damage
Contact
Resistance
40mΩ
MAX
Discontinuity
1u
sec
MAX
不连续性
3-3-5
Appearance
No
Damage
耐热测试
105±3℃,96hours
(based upon JIS C5402 7.8)
时间 96 小时,温度 85±3℃
Contact
Resistance
40mΩ
MAX
Cold
Resistance
低温测试
-50±3℃,96hours
(based upon JIS C5402 7.9)
时间 96 小时, 温度-20±3℃
Appearance
No
Damage
Contact
Resistance
40mΩ
MAX
Appearance
No Damage
Humidity
恒温恒湿
测试
Temperature:40±2℃,Relative
humidity:90~95%(RH)
(Based upon MIL-STD-202 Method 103B
conditions.B)
温度 40±2℃,湿度 90~95%,时间 96 小时。
Contact
Resistance
40mΩ
MAX
Dielectric
strength
没有损坏/没
Appearance
No Damage
Contact
Resistance
40mΩ
MAX
Appearance
No Damage
Contact
Resistance
40mΩ
MAX
Heat
Resistance
3-3-6
3-3-7
3-3-8
3-3-9
Temperatur
e cycling
温度冲击
测试
5 cycles:
1>.-50℃ 30 minutes.
2>.+105℃ 30 minutes.
3>.+25℃ 30 minutes.
4>.+65℃ 30 minutes
Salt spray
盐水测试
12 hours exposure to a salt spray from
the 5±1% solution at 35±2℃.(Based
upon JIS
C5402/MIL-STD-202method
101D conditions. B)
时 间 12 小 时, 盐水 体比例 5±1% , 温度
35±2℃。
有电弧产生
3
Solderabi
3-3-10
3-3-11
3-3-12
lity
沾 锡 性
测试
Soldering time:3±0.5sec,
solder temperature:230±5℃
时间:3±0.5 秒,
温度:230±5℃
95%以上沾锡面积
Resistance
to soldering
heat
焊热性
测试
Soldering time:5±1sec,
solder temperature:260±5℃
时间:5±1 秒,
温度:230±5℃
No Damage
外观没有影响
Life Test
寿 命 测
试
5000 cycles
5000 次
No Damage
外观,功能没有影响
(见附件图纸)
4
很抱歉,暂时无法提供与“D-DB0009PF-A000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.34470
- 50+1.83930
- 150+1.62690
- 500+1.36190
- 2500+1.24390
- 5000+1.17290
- 国内价格
- 5+2.09272
- 50+1.64171
- 150+1.45206
- 500+1.21554
- 2500+1.11024
- 5000+1.04696
- 国内价格
- 5+1.89895
- 50+1.48970
- 150+1.31761
