CSSH2728FT24L0
CSSH2728FT24L0
    SEI
    贴片电阻 2728 24mΩ ±1% 4W ±15ppm/℃
CSSH2728FT24L0 数据手册
CSS / CSSH Series Stackpole Electronics, Inc. Ultra Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Features: • • • • • • • • High power metal alloy current sense resistor High temperature performance up to 225C (for operation up to 275ºC, contact Stackpole) Low thermal EMF (< 1µ V/C) Proprietary processing technique produces extremely low resistance values Qualified to AEC-Q200 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications - CSS Maximum Type / Code Power Rating (W) CSS0201 0.2 Maximum Rating Current (A) 4.47 11.48 8.12 12.84 11.49 7.41 Maximum Overload Current (A) 7.07 18.16 12.84 20.31 18.16 11.72 CSS0402 0.33 CSS0603 0.33 CSS0508 1 31.63 50 CSS0805 0.5 18.25 15.81 9.12 28.86 25 14.43 CSS1206 1 31.62 63.25 CSS2010 1 31.62 63.25 CSS2512 2 63.25 141.42 CSS2725 4 126.49 316.23 CSS2728 3 27.39 61.24 CSS4527 5 100 173 TCR (ppm/ºC) ± 200 ± 150 ± 100 ± 150 ± 100 ± 75 ± 150 ± 100 ± 100 ± 75 ± 50 ± 50 ± 25 ± 15 ± 50 ± 25 ± 15 ± 50 ± 25 ± 15 ± 100 ± 50 ± 25 ± 15 ± 50 Ohmic Range (Ω) and Tolerance 0.5% - 1% 0.01, 0.02 0.0025 0.005, 0.006, 0.008, 0.01, 0.015, 0.02 0.002 0.0025, 0.003, 0.004, 0.005 0.01, 0.015, 0.02 0.001, 0.0015 0.002, 0.003, 0.004, 0.005 0.0015 0.002, 0.003, 0.004, 0.005 0.006, 0.007, 0.01, 0.015, 0.02 0.001 - 0.004 0.005 - 0.015 0.007 - 0.015 0.016 - 0.05 0.016 - 0.05 0.001 - 0.003 0.004 - 0.006 0.007 - 0.1 0.007 - 0.1 0.0005 - 0.003 0.004 - 0.006 0.007 - 0.075 0.007 - 0.075 0.0002 0.00025 - 0.003 0.004 - 0.007 0.004 -0.007 0.008 - 0.1 0.008 - 0.19 0.0005 - 0.12 0.007 - 0.12 5% - Electrical Specifications – CSSH (High Power) Type / Code Maximum Power Rating (W) Maximum Rating Current (A) 44.72 25.81 20 Maximum Overload Current (A) 89.44 51.63 40 CSSH0805 1 CSSH2512 3 100 223.61 CSSH2728 4 31.62 70.71 TCR (ppm/ºC) ± 100 ± 75 ± 50 ± 150 ± 50 ± 25 ± 50 ± 25 ± 15 Ohmic Range (Ω) and Tolerance 0.5% 0.007 - 0.013 0.007 - 0.01 0.0101 - 0.05 0.004 - 0.007 0.008 - 0.019 1%, 2%, 5% 0.0005 - 0.001 0.0015 - 0.002 0.0025 - 0.013 0.0003 0.0005 - 0.0025 0.003 - 0.01 0.0101 - 0.08 0.004 - 0.007 0.008 - 0.05 Please refer to the High-Power Resistor Application Note (page 11) for more information on designing and implementing high power resistor types. Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Mechanical Specifications 0201 – 0805 Type / Code Maximum Power Rating (W) Resistance Range (Ω) L W H CSS0201 0.2 0.01, 0.02 0.024 ± 0.006 0.60 ± 0.15 0.012 ± 0.006 0.30 ± 0.15 0.010 ± 0.004 0.25 ± 0.10 CSS0402 0.33 0.039 ± 0.006 1.00 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.012 ± 0.004 0.30 ± 0.10 0.063 ± 0.010 1.60 ± 0.25 0.031 ± 0.010 0.80 ± 0.25 0.016 ± 0.010 0.40 ± 0.25 0.049 ± 0.010 1.25 ± 0.25 0.079 ± 0.010 2.00 ± 0.25 0.017 ± 0.006 0.42 ± 0.15 0.079 ± 0.010 2.00 ± 0.25 0.049 ± 0.010 1.25 ± 0.25 0.016 ± 0.010 0.40 ± 0.25 0.0025 0.005 - 0.02 0.002 CSS0603 0.33 0.0025, 0.003 0.004 - 0.02 0.001 0.0015 CSS0508 1 0.002 0.003 - 0.005 0.0015 CSS0805 0.5 0.002 0.003 - 0.02 0.0005 0.001 0.0015 CSSH0805 1 0.002 0.0025 0.081 ± 0.010 2.05 ± 0.25 0.003 - 0.008 0.009 - 0.013 Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 0.051 ± 0.012 1.30 ± 0.30 0.024 0.60 0.022 0.55 0.018 0.45 0.014 0.35 0.018 0.45 0.014 0.35 0.014 0.35 ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 T2 Bottom 0.006 ± 0.004 0.15 ± 0.10 0.012 ± 0.004 0.30 ± 0.10 0.009 ± 0.004 0.23 ± 0.10 0.018 ± 0.008 0.45 ± 0.20 0.014 ± 0.008 0.35 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 0.015 ± 0.010 0.38 ± 0.25 0.015 ± 0.010 0.37 ± 0.25 0.014 ± 0.010 0.36 ± 0.25 0.013 ± 0.010 0.32 ± 0.25 0.028 ± 0.008 0.70 ± 0.20 0.024 ± 0.008 0.60 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.030 ± 0.008 0.75 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com Ty MA0 CSS / CSSH Series Ultra Precision Metal Alloy Current Sensing Chip Resistor Stackpole Electronics, Inc. Resistive Product Solutions Mechanical Specifications 1206 – 2728 Type / Code Maximum Power Rating (W) Resistance Range (Ω) L W 0.001 0.002 - 0.004 CSS1206 1 0.005 0.126 ± 0.010 0.063 ± 0.010 3.20 ± 0.25 1.60 ± 0.25 0.006 - 0.05 0.001 - 0.003 CSS2010 1 0.0031 - 0.1 0.0005 - 0.004 CSS2512 2 0.0041 - 0.075 0.200 ± 0.010 0.100 ± 0.010 5.08 ± 0.25 2.54 ± 0.25 0.246 ± 0.010 0.126 ± 0.010 6.25 ± 0.25 3.20 ± 0.25 0.0003 0.0005 0.0006 - 0.0007 0.00075 CSSH2512 3 0.0008 - 0.0029 0.246 ± 0.010 0.126 ± 0.010 6.25 ± 0.25 3.20 ± 0.25 0.003 - 0.0035 0.0036 - 0.004 0.0041 - 0.01 0.0101 - 0.08 Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 H T1 Top Termination 0.025 ± 0.010 0.65 ± 0.25 0.020 0.51 0.022 ± 0.010 0.55 ± 0.25 0.024 0.60 0.020 0.51 0.031 ± 0.010 0.051 0.79 ± 0.25 1.30 0.025 ± 0.010 0.031 0.65 ± 0.25 0.79 0.031 ± 0.010 0.074 0.79 ± 0.25 1.88 0.025 ± 0.010 0.044 0.65 ± 0.25 1.12 0.039 ± 0.010 0.080 1.00 ± 0.25 2.02 0.080 2.02 0.074 1.88 0.054 1.37 0.031 ± 0.010 0.044 0.79 ± 0.25 1.12 0.074 1.88 0.066 1.68 0.026 ± 0.010 0.044 0.65 ± 0.25 1.12 0.039 ± 0.010 0.044 1.00 ± 0.25 1.12 T2 Bottom Termination Unit inches ± 0.010 0.020 ± 0.010 mm ± 0.25 0.51 ± 0.25 inches mm ± 0.010 0.024 ± 0.010 inches ± 0.25 0.60 ± 0.25 mm ± 0.010 0.020 ± 0.010 inches ± 0.25 0.51 ± 0.25 mm ± 0.010 0.051 ± 0.010 inches ± 0.25 1.30 ± 0.25 mm ± 0.010 0.031 ± 0.010 inches ± 0.25 0.79 ± 0.25 mm ± 0.010 0.074 ± 0.010 inches ± 0.25 1.88 ± 0.25 mm ± 0.010 0.044 ± 0.010 inches ± 0.25 1.12 ± 0.25 mm ± 0.010 0.080 ± 0.010 inches ± 0.25 2.02 ± 0.25 mm ± 0.010 0.080 ± 0.010 inches ± 0.25 2.02 ± 0.25 mm ± 0.010 0.074 ± 0.010 inches ± 0.25 1.88 ± 0.25 mm ± 0.010 0.054 ± 0.010 inches ± 0.25 1.37 ± 0.25 mm ± 0.010 0.044 ± 0.010 inches ± 0.25 1.12 ± 0.25 mm ± 0.010 0.074 ± 0.010 inches ± 0.25 1.88 ± 0.25 mm ± 0.010 0.066 ± 0.010 inches ± 0.25 1.68 ± 0.25 mm ± 0.010 0.044 ± 0.010 inches ± 0.25 1.12 ± 0.25 mm ± 0.010 0.004 ~ 0.039 inches ± 0.25 0.10 ~ 1.00 mm www.seielect.com marketing@seielect.com CSS / CSSH Series Ultra Precision Metal Alloy Current Sensing Chip Resistor Stackpole Electronics, Inc. Resistive Product Solutions Mechanical Specifications 1206 – 2728 (cont.) Type / Code Maximum Power Rating (W) Resistance Range (Ω) 0.0002, 0.00025, 0.0005 0.001 0.0015 CSS2725 4 L W H 0.039 0.99 0.043 1.09 0.268 ± 0.010 0.254 ± 0.010 0.039 6.81 ± 0.25 6.45 ± 0.25 0.99 ± ± ± ± ± ± 0.002 0.035 ± 0.89 ± 0.0025 0.003 CSS2728 3 0.004 - 0.1 CSSH2728 4 0.004 - 0.1 0.264 6.71 0.264 6.71 ± ± ± ± 0.010 0.283 ± 0.010 0.039 ± 0.25 7.19 ± 0.25 0.99 ± 0.010 0.283 ± 0.010 0.039 ± 0.25 7.19 ± 0.25 0.99 ± T1 Top Termination 0.010 0.25 0.010 0.085 ± 0.25 2.16 ± 0.010 0.25 0.071 ± 1.80 ± 0.010 0.065 ± 0.25 1.65 ± 0.051 ± 1.30 ± 0.010 0.045 ± 0.25 1.14 ± 0.010 0.045 ± 0.25 1.14 ± T2 Bottom Termination 0.010 0.085 ± 0.010 0.25 2.16 ± 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.071 1.80 0.065 1.65 0.051 1.30 0.045 1.14 0.045 1.14 ± ± ± ± ± ± ± ± ± ± 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Mechanical Specifications (4527) Type / Code Maximum Power Rating (W) CSS4527 5 Resistance Range (Ω) 0.0005 - 0.005 0.0051 - 0.1 T2 Unit Bottom Termination 0.127 ± 0.010 inches 0.450 ± 0.010 0.270 ± 0.010 0.059 ± 0.010 0.038 ± 0.010 3.22 ± 0.25 mm 11.43 ± 0.25 6.85 ± 0.25 1.50 ± 0.25 0.97 ± 0.25 0.071 ± 0.010 inches 1.82 ± 0.25 mm L W H T1 Top Termination Performance Characteristics Test Temperature Coefficient of Resistance (TCR) Test Method Test Specification JIS-C-5201-1 4.8 Per specification (refer to Electrical Specification table) Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 Test Condition (R2 - R1) X 106 R1 (T2 - T1) R1: resistance of room temperature (T1) R2: resistance of 125ºC (T2) TCR (ppm/ºC) = www.seielect.com marketing@seielect.com CSS / CSSH Series Ultra Precision Metal Alloy Current Sensing Chip Resistor Stackpole Electronics, Inc. Resistive Product Solutions Performance Characteristics (cont.) Test Test Method Test Specification Test Condition The number of rated power are as follows: Short Time Overload JIS C 5201-1 4.13 Size Power (W) Rated Power CSS0201 0.2 2.5 times CSS0402 0.33 2.5 times CSS0603 0.33 2.5 times CSS0508 1 2.5 times CSS0805 0.5 2.5 times CSSH0805 1 4 times CSS1206 1 5 times CSS2010 1 5 times CSS2512 2 5 times CSSH2512 3 5 times CSS2725 4 5 times CSS2728 3 5 times CSSH2728 4 5 times CSS4527 5 5 times Size Power (W) Max. R Change CSS0201 0.2 ≤ ± 0.5 CSS0402 0.33 ± 1% + 0.5mΩ CSS0603 0.33 ± 1% + 0.5mΩ CSS0508 1 ± 1% + 0.5mΩ CSS0805 0.5 ± 1% + 0.5mΩ CSSH0805 1 ≤ ± 1% CSS1206 1 ≤ ± 0.5 CSS2010 1 ≤ ± 0.5 CSS2512 2 ≤ ± 0.5 CSSH2512 3 ≤ ± 0.5 CSS2725 4 ≤ ± 0.5 CSS2728 3 ≤ ± 0.5 CSSH2728 4 ≤ ± 0.5 CSS4527 5 ≤ ± 2% Rating power duration: 5 seconds. Insulation Resistance JIS-C-5201-1 4.6 ≥ 109 Ω Put the resistor in the fixture, add 100 VDC in terminal for 60 seconds then measure the insulation resistance between electrodes and insulating enclosure or between electrodes and base material Dielectric JIS-C-5201-1 4.7 Withstanding Voltage No short or burned in the appearance. Applied 500 VAC for 1 minute and limit surge current 50 mA (max) Operating Temperature Range for size CSS0201 is -55°C to +125°C. Operating Temperature Range for sizes CSS0402, CSS0603 and CSS0805 is -55°C to +155°C. Operating Temperature Range for size CSSH0805 is -55°C to +170°C. Operating Temperature Range for sizes CSS1206 - CSS4527, CSSH 2512 and CSSH 2728 is -55°C to +225°C. Power Derating Curve: 100 -55ºC 70°C 100°C Power Load (%) 80 60 CSS0201 CSS0402, 0603, 0805, 0508 40 CSSH0805 CSS1206 - 4527 CSSH2512, 2728 20 0 -60 125°C 155°C 170°C 0 50 100 150 200 225ºC 250 Ambient Temperature (ºC) Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Mechanical Performance Test Item Test Method Test Specifications Test Condition Resistance to Solder Heat JIS C 5201-1 4.18 0201 - 0805 = ± 1% + 0.5mΩ CSSH0805 and ≥ 1206 = ± 0.5% Jumper = < Rmax 260 ± 5°C for 10 ± 1 seconds Solderability JIS C 5201-1 4.17 > 95 % coverage 245 ± 5°C for 3 ± 0.5 seconds Span between fulcrums: 90 mm Bend width: 2 mm Substrate Bending JIS C 5201-1 4.33 Resistance to Solvent JIS C 5201-1 4.29 ± 1% + 0.5mΩ ≤ ± 0.5% No evidence of mechanical damage ≤ ± 0.5% Vibration JIS C 5201-1 4.22 Mechanical Shock JIS C 5202 6.7 No evidence of mechanical damage ± 1% + 0.5mΩ The tested resistor is immersed into isopropyl alcohol of 20 ~ 25°C for 60 seconds, then the resistor is left in the room for 48 hours. The resistor shall be mounted by its terminal leads to the supporting terminals on the solid table. The entire frequency range from 10 Hz to 55 Hz and return to 10 Hz, shall be transferred in 1 minute. Amplitude: 1.5 mm - This motion shall be applied for a period of 4 hours in each 3 mutually perpendicular directions (a total of 12 hours) a = 50 G, t = 11 ms, 5 times shock Environmental Performance Test Item Low Temperature Exposure (Storage) High Temperature Exposure (Storage) Test Method JIS C 5201-1 4.23.4 JIS C 5201-1 4.23.2 Test Specifications 0201 - 0805 = ± 1% + 0.5mΩ ≥ 1206 = ± 0.5% 0201 - 0805 = ± 1% + 0.5mΩ CSSH0805 = ± 1% ≥ 1206 = ± 1% 0201 Jumper: < Rmax 0201 - 0805 = ± 1% + 0.5mΩ Temperature Cycling JIS C 5201-1 4.19 CSSH0805 = ± 0.5% ≥ 1206 = ± 0.5% Bias Humidity JIS C 5201-1 4.24 Load Life JIS C 5201-1 4.25 0201 - 0805 = ± 2% + 0.5mΩ 0201 Jumper = < R max CSSH0805 = ± 0.5% ≥ 1206 = ± 0.5% 0201 - 0805 = ± 2% + 0.5mΩ 0201 Jumper = R max CSSH0805 = ± 1% 1206 - 2728 = ± 1% 4527 = ± 2% Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 Test Condition 1000 hours at -55°C ± 2°C 1000 hours at + 155°C ± 2°C 1000 hours at +170°C ± 5°C 1000 hours at + 125°C ± 2°C 0201 = -55°C to +125°C, 100 cycles 0402 - 0805 = -55°C +155°C, 100 cycles -55°C to +150°C, 100 cycles Lowest temperature: -55 +0/-10°C Highest temperature: 150 + 10/-0°C T = 40 ± 2°C , RH = 90~95%, Load with Rated Current 1.5 hours "ON", 0.5 hours "OFF", 1000 hours 1000 hours at +85°C / 85% R.H., 10% Bias, 1.5 hours "ON" and 0.5 hours "OFF T = 70 ± 2°C, load with Rated Current 1.5 hours "ON", 0.5 hours "OFF", 1000 hours www.seielect.com marketing@seielect.com CSS / CSSH Series Ultra Precision Metal Alloy Current Sensing Chip Resistor Stackpole Electronics, Inc. Resistive Product Solutions Environmental Performance (cont.) Test Item Test Method Test Specifications Test Condition Test item (Thermal Shock Test): Testing Condition Minimum Storage Temperature Maximum Storage Temperature Temperature-Retaining Time Number of Temperature Cycles JESD Standard No.22A121 class 2 Whisker Test Max 50μm -55 +0 / -10°C 85 + 10 / -0°C 10 minutes 1500 Inspection: Inspect for whisker formation on specimens that underwent the acceleration test, with a magnifier (stereo microscope) of about 40 or higher magnification. If judgement is difficult with this method, use a scanning electron microscope (SEM) of about 1000 or higher magnification. Recommended Pad Layouts Type / Code Maximum Power Rating (W) Resistance Range (Ω) a b i Unit CSS0201 0.2 0.01, 0.02 0.008 0.20 0.013 0.33 CSS0402 0.33 0.024 0.60 0.024 0.60 0.056 1.41 0.053 1.35 0.051 1.30 0.035 0.90 0.033 0.85 0.061 1.55 0.055 1.40 0.053 1.35 0.039 1.00 0.063 1.60 0.036 0.92 0.036 0.92 0.036 0.92 0.091 2.30 0.091 2.30 0.057 1.44 0.057 1.44 0.071 1.80 0.071 1.80 0.086 2.18 0.010 0.25 0.014 0.35 0.016 0.40 0.015 0.38 0.020 0.50 0.024 0.60 0.016 0.40 0.020 0.50 0.020 0.50 0.031 0.80 0.012 0.30 0.039 1.00 0.039 1.00 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm 0.0025 0.005 - 0.02 0.002 CSS0603 0.33 0.0025, 0.003 0.004 - 0.02 0.001, 0.0015, 0.002 CSS0508 1 0.003 - 0.005 0.0015, 0.002 CSS0805 0.5 0.003 - 0.02 0.0005 CSSH0805 1 0.001 - 0.013 CSS1206 1 0.001 - 0.05 Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com CSS / CSSH Series Ultra Precision Metal Alloy Current Sensing Chip Resistor Stackpole Electronics, Inc. Resistive Product Solutions Recommended Pad Layouts (cont.) Type / Code Maximum Power Rating (W) Resistance Range (Ω) a b i Unit 0.114 2.89 0.090 2.29 0.120 3.05 0.083 2.11 0.120 3.05 0.115 2.92 0.115 2.92 0.145 3.68 0.145 3.68 0.145 3.68 0.048 1.22 0.095 2.41 0.050 1.27 0.125 3.18 0.050 1.27 0.0006 - 0.0029 0.086 2.19 0.145 3.68 0.118 3.00 0.003 - 0.004 0.110 2.79 0.145 3.68 0.071 1.80 0.0041 - 0.01 0.086 2.19 0.145 3.68 0.118 3.00 0.0101 - 0.08 0.083 2.11 0.145 3.68 0.125 3.18 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm 0.001 - 0.003 CSS2010 1 0.0031 - 0.1 0.0005 - 0.004 CSS2512 2 0.0041 - 0.075 0.0003 - 0.0005 CSSH2512 3 CSS2725 4 0.0002 - 0.003 0.125 3.18 0.270 6.86 0.052 1.32 CSS2728 3 0.004 - 0.1 0.108 2.75 0.308 7.82 0.138 3.51 CSSH2728 4 0.004 - 0.1 0.108 2.75 0.308 7.82 0.138 3.51 0.0005 - 0.005 0.189 4.80 0.344 8.74 0.217 5.51 0.0051 - 0.12 0.134 3.40 0.344 8.74 0.327 8.31 CSS4527 5 Recommended Solder Profiles This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 8 Minimum 60 seconds 100°C 240°C * N/A www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile Packaging Specifications Type / Code W Tape Width 0201, 0402, 0603 0508, 0805,1206 8 mm CSSH0805 8 mm 2010, 2512, 2725, 2728 12 mm 4527 24 mm 0.354 9.00 0.472 12.00 0.543 13.80 0.984 25.00 ± ± ± ± ± ± ± ± ØD 0.020 0.50 0.020 0.50 0.020 0.50 0.039 1.00 Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2.362 ± 0.079 60.00 ± 2.00 3.150 80.00 2.362 60.00 9 ± ± ± ± 0.039 1.00 0.039 1.00 ØM 7.008 ± 0.197 178.00 ± 5.00 Unit inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com 7” r CSS / CSSH Series Ultra Precision Metal Alloy Current Sensing Chip Resistor Stackpole Electronics, Inc. Resistive Product Solutions Plastic Tape Specifications Type / Code W CSS0201 E F ØD 0.079 ± 0.004 2.00 ± 0.10 CSS0402 CSS0603 P 0.315 ± 0.012 8.00 ± 0.30 0.069 ± 0.004 1.75 ± 0.10 0.138 ± 0.004 3.50 ± 0.10 0.059 +0.004 / -0 1.50 +0.1 / -0 0.157 ± 0.004 4.00 ± 0.10 CSS0508 CSS0805 CSSH0805 Type / Code G H A 0.016 0.40 0.026 0.65 0.039 0.98 CSS0201 CSS0402 CSS0603 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 CSS0508 CSS0805 CSSH0805 Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 10 ± ± ± ± ± ± B 0.008 0.20 0.008 0.20 0.008 0.20 0.028 0.70 0.043 1.10 0.073 1.85 ± ± ± ± ± ± T 0.008 0.20 0.008 0.20 0.008 0.20 0.061 ± 0.008 1.55 ± 0.20 0.091 ± 0.008 2.30 ± 0.20 0.067 ± 0.004 1.70 ± 0.10 0.096 ± 0.004 2.45 ± 0.10 0.018 0.45 0.017 0.42 0.024 0.60 0.028 0.70 0.030 0.75 0.035 0.90 ± ± ± ± ± ± ± ± ± ± ± ± Unit inches mm inches mm inches mm inches mm inches mm inches mm Unit 0.002 0.05 0.002 0.05 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com Ite MA0 CSS / CSSH Series Stackpole Electronics, Inc. Ultra Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Plastic Tape Specifications Type CSS1206 CSS2010 CSS2512 CSS2725 CSS2728 CSS4527 A 0.137 3.48 0.215 5.45 0.266 6.75 CSS2010 CSS2512 CSS2725 CSS2728 CSS4527 B 0.004 0.10 0.004 0.10 0.004 0.10 0.281 ± 0.004 7.15 ± 0.10 0.465 ± 0.004 11.80 ± 0.10 Type CSS1206 ± ± ± ± ± ± T2 0.008 0.20 0.009 0.23 0.008 0.20 ± ± ± ± ± ± 0.072 1.83 0.114 2.90 0.138 3.50 0.266 6.75 0.303 7.70 0.283 7.20 ± ± ± ± ± ± ± ± ± ± ± ± W 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 P 0.002 0.05 0.002 0.05 0.002 0.05 0.010 ± 0.002 0.25 ± 0.05 0.012 ± 0.004 0.30 ± 0.10 E 0.315 ± 0.006 8.00 ± 0.15 0.472 ± 0.006 12.00 ± 0.15 0.069 ± 0.004 1.75 ± 0.10 0.945 ± 0.006 24.00 ± 0.15 P0 F T1 0.138 ± 0.004 3.50 ± 0.10 0.217 ± 0.004 5.50 ± 0.10 0.453 ± 0.004 11.50 ± 0.10 P1 0.079 ± 0.004 2.00 ± 0.10 0.059 +0.004 / -0 1.50 +0.10 / -0 0.315 ± 0.004 8.00 ± 0.10 0.472 ± 0.004 12.00 ± 0.10 ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm inches mm inches mm Unit ΦD 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.043 1.10 0.052 1.33 0.051 1.30 0.077 1.95 0.057 1.45 0.079 2.00 inches mm inches mm inches mm inches mm inches mm inches mm High Power Chip Resistors and Thermal Management Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had higher power ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to how to reliably use these resistors at the higher power ratings in their designs. The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes an ambient temperature of no more than 100°C for the CSS / CSSH series and 70°C for all other high power resistor series. In addition, IPC and UL best practices dictate that the combined temperature on any resistor due to power dissipated and ambient air shall be no more than 105°C. At first glance this wouldn’t seem too difficult, however the graph below shows typical heat rise for the CSR1206 100 milliohm at full rated power. The heat rise for the RMCP and RNCP would be similar. The RHC with its unique materials, design, and processes would have less heat rise and therefore would be easier to implement for any given customer. Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 11 www.seielect.com marketing@seielect.com CSS / CSSH Series Ultra Precision Metal Alloy Current Sensing Chip Resistor Stackpole Electronics, Inc. Resistive Product Solutions The 102°C heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this part under 105°C total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at the usual power rating for this size would have a heat rise of around 72°C. This additional heat rise may be dealt with using wider conductor traces, larger solder pads and land patterns under the solder mask, heavier copper in the conductors, via through PCB, air movement, and heat sinks, among many other techniques. Because of the variety of methods customers can use to lower the effective heat rise of the circuit, resistor manufacturers simply specify power ratings with the limitations on ambient air temperature and total hot spot temperatures and leave the details of how to best accomplish this to the design engineers. Design guidelines for products in various market segments can vary widely so it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods over another. Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount of solder used. This is especially notable for resistance values ≤ 50 mΩ. This should be taken into account when designing. RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series CSS CSSH Description Ultra Precision Current Sensing Chip Resistor Ultra Precision Current Sensing Chip Resistor (High Power) Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) SMD YES 100% Matte Sn over Ni Always Always SMD YES 100% Matte Sn over Ni Always Always Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 12 www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 C S S 2 7 2 5 F T 3 L 0 0 Product Series Code Description CSS Metal Alloy CSSH High Power Size Size W 0201 0.2 0402 0.33 0603 0.33 0508 1 0805 0.5 (H)0805 1 1206 1 2010 1 2512 2 (H)2512 3 2725 4 2728 3 (H)2728 4 4527 5 Tolerance Code Tol D 0.5% F 1% G 2% J 5% Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Packaging Code T Description Plastic Tape 13 Size 0201, 0402 0603, 0508 0805, (H)0805 1206 2010, 2512 (H)2512 2725, 2728 (H)2728 4527 Quantity 10000 5000 4000 2000 1000 500 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier of 10-3 for any value under 0.1 ohm. 0.00025 ohm = L250 0.004 ohm = 4L00 0.05 ohm = 50L0 0.12 ohm = R120 www.seielect.com marketing@seielect.com
CSSH2728FT24L0
物料型号:CSS / CSSH系列
器件简介: - 这些是超精密的金属合金电流检测芯片电阻,具有高功率金属合金电流感应电阻特性。 - 它们能在高达225°C的温度下工作(CSS系列),而CSSH系列(高功率)则为高功率应用设计。
引脚分配:文档中未明确列出每个型号的引脚分配,但提供了不同尺寸的机械规格,包括长度(L)、宽度(W)、高度(H)。
参数特性: - 包括最大功率额定值、最大额定电流、最大过载电流、电阻的温度系数(TCR)、欧姆范围和公差。 - CSS系列提供0.5%、1%、5%的公差选项,而CSSH系列则提供更严格的公差范围。
功能详解: - 这些电阻具有低热EMF(<1µV/°C)、通过AEC-Q200认证、100%无铅且符合RoHS标准、无卤素且符合REACH标准。
应用信息: - 适用于高功率电阻类型设计和实现的详细说明,建议查阅应用笔记(第11页)。
封装信息: - 提供了从0201至4527不同尺寸的详细机械规格,包括电阻范围、尺寸和单位(英寸和毫米)。
其他信息: - 文档还包含了测试方法、测试规范、测试条件、性能特性、机械性能、环境性能、热管理、RoHS合规性、"冲突矿产"承诺、REACH合规性、环境政策和订购指南。
CSSH2728FT24L0 价格&库存
很抱歉,暂时无法提供与“CSSH2728FT24L0”相匹配的价格&库存,您可以联系我们找货
