RS8032XK
RS8032XK
    RUNIC(润石)
    SOIC-8
    750nA微功耗,15KHz,2通道运放
RS8032XK 数据手册
RS8031, RS8032, RS8034 15kHz, 750nA, Rail-to-Rail I/O CMOS Operational Amplifier FEATURES DESCRIPTION  GAIN BANDWIDTH:15kHz  RAIL-TO-RAIL INPUT AND OUTPUT 0.5mV Typical Vos INPUT VOLTAGE RANGE: -0.1V to +5.6V with Vs = 5.5V   SUPPLY RANGE: +1.4V to +5.5V   SPECIFIED UP TO +125°C MicroSIZE PACKAGES: SOT23-5 The RS8031, RS8032, RS8034, families of products offer low voltage operation and rail-to-rail input and output, as well as excellent speed/power consumption ratio, providing an excellent bandwidth (15kHz) and slew rate of 7.5V/ms. The op-amps are unity gain stable and feature an ultra-low input bias current. The devices are ideal for sensor interfaces, active filters and portable applications. The RS8031, RS8032, RS8034 families of operational amplifiers are specified at the full temperature range of −40°C to +125°C under single or dual power supplies of 1.4V to 5.5V. APPLICATIONS  SENSORS  PHOTODIODE AMPLIFICATION  WEARABLE PRODUCTS  TEMPERATURE MEASUREMENT  BATTERY POWERED SYSTEM PIN CONFIGURATIONS 5 1 V+ + IN 5 1 V+ + V+IN 2 3 + V- - 4 -IN - IN SOT23-5 2 - 3 4 OUT NC 1 -IN 2 +IN 3 V- 4 8 NC 7 V+ + OUT RS8031 RS8031B - RS8031 6 OUT 5 NC SOT23-5 SOIC-8,MSOP-8 RS8032 RS8034 OUT A 1 8 V+ OUT A 1 -IN A 2 7 OUTB -IN A 2 6 -IN B +IN A 5 +IN B +IN A 3 V- 4 + A B+ 14 OUT D 13 -IN D 3 12 +IN D - + D + - V+ 4 11 V- +IN B 5 10 +IN C -IN B 6 9 -IN C OUT B 7 8 OUT C SOIC-8,MSOP-8,TDFN-8 Note: NC indicates no internal connection A - + B + C SOIC-14,TSSOP-14 REV B.1 1 www.run-ic.com RS8031, RS8032, RS8034 ABSOLUTE MAXIMUM RATINGS (1) Supply Voltage, V+ to V-...............................................7.0V (2) Input Terminals, Voltage …………... – 0.5 to (V+) + 0.5V (2) Current …………………....…..... ±10mA Storage Temperature ……….…………… −65°C to +150°C Operating Temperature ……….………… −40°C to +125°C Junction Temperature................................................150°C Package Thermal Resistance @ TA = +25°C SOT23-5, SOT23-6………………….………………200°C/W MSOP-10, SOIC-8 …………………….…………... 150°C/W SOIC-14, TSSOP-14………….……….……………100°C/W Lead Temperature (Soldering, 10s) ……………........260°C ESD Susceptibility HBM …......................................................................5000V MM ……………………….........………………...……….400V ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the supply rails should be current-limited to 10mA or less. PACKAGE/ORDERING INFORMATION PRODUCT RS8031 RS8032 RS8034 TEMPERATURE PACKAGE PACKAGE RANGE LEAD MARKING RS8031XK -40℃~125℃ SOIC-8 RS8031 Tape and Reel,2500 RS8031XF -40℃~125℃ SOT23-5 8031 Tape and Reel,3000 RS8031BXF -40℃~125℃ SOT23-5 8031B Tape and Reel,3000 RS8031XM -40℃~125℃ MSOP-8 RS8031 Tape and Reel,3000 RS8032XK -40℃~125℃ SOIC-8 RS8032 Tape and Reel,2500 RS8032XM -40℃~125℃ MSOP-8 RS8032 Tape and Reel,3000 RS8032XT -40℃~125℃ TDFN-8 RS8032 Tape and Reel,3000 RS8034XP -40℃~125℃ SOIC -14 RS8034 Tape and Reel,2500 RS8034XQ -40℃~125℃ TSSOP-14 RS8034 Tape and Reel,3000 ORDERING NUMBER 2 PACKAGE OPTION www.run-ic.com RS8031, RS8032, RS8034 ELECTRICAL CHARACTERISTICS (At TA = +25C, Vs=5.0V, RL = 1MΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) PARAMETER CONDITIONS RS8031,RS8032,RS8034 MIN TYP MAX UINTS 750 5.5 1500 V nA POWER SUPPLY Vs IQ PSRR Operating Voltage Range Quiescent Current/Amplifier Power-Supply Rejection Ratio 1.4 Vs=2.5V to 5.5V, Vcm=(V-)+0.5V 62 70 dB INPUT Vos ΔVos/ΔT IB Ios Vcm CMRR Input Offset Voltage Input Offset Voltage Drift Input Bias Current Input Offset Current Common-Mode Voltage Range Common-Mode Rejection Ratio Vcm=Vs/2 Vcm=Vs/2, -40°C ≤ TA ≤125°C 0.5 2.3 1 1 3 mV µV/°C 10 10 pA pA 5.6 V Vs= 5.5V -0.1 Vs= 5.5V, Vcm=-0.1V to 4V Vs= 5.5V, Vcm=-0.1V to 5.6V 73 60 90 83 dB dB Vs=1.4V,RL=50KΩ,Vo=Vs-0.1V 85 102 dB Vs=5.0V,RL=50kΩ,Vo=Vs-0.1V 92 106 dB 5 11 mV mA 7.5 15 60 V/ms kHz OUTPUT AOL Open-Loop Voltage Gain Iout Output Swing From Rail Output Short-Circuit Current RL=50KΩ FREQUENCY RESPONSE SR GBP PM NOISE enp-p en Slew Rate Gain-Bandwidth Product Phase Margin Input Voltage Noise Input Voltage Noise Density f = 0.1 Hz to 10 Hz f = 1 kHz 3 2.4 160 ° μVpp nV/√Hz www.run-ic.com RS8031, RS8032, RS8034 TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 1MΩconnected to VS/2, CL=60pF VCM = VS/2, unless otherwise noted. SMALL−SIGNAL STEP RESPONSE SMALL−SIGNAL STEP RESPONSE CL=60PF 50mV/div 50mV/div CL=60PF 200us/div 200us/div LARGE−SIGNAL STEP RESPONSE LARGE−SIGNAL STEP RESPONSE CL=60PF 1V/div 1V/div CL=60PF 200us/div 200us/div SOURCE CURRENT vs TEMPERATURE 16 22 14 20 Source Current(mA) Sink Current(mA) SINK CURRENT vs TEMPERATURE 12 10 8 6 18 16 14 12 10 -40 -20 0 20 40 60 80 100 120 140 Temperature(C) -40 -20 4 0 20 40 60 80 100 120 140 Temperature(C) www.run-ic.com RS8031, RS8032, RS8034 PACKAGE OUTLINE DIMENSIONS SOT23-5 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 c θ L A1 Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 5 www.run-ic.com RS8031, RS8032, RS8034 MSOP-8 b e E E1 4.8 1.02 D 0.65 0.41 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 0.820 1.100 0.032 0.043 A1 0.020 0.150 0.001 0.006 A2 0.750 0.950 0.030 0.037 b 0.250 0.380 0.010 0.015 c 0.090 0.230 0.004 0.009 D 2.900 3.100 0.114 0.122 e 0.650(BSC) 0.026(BSC) E 2.900 3.100 0.114 0.122 E1 4.750 5.050 0.187 0.199 L 0.400 0.800 0.016 0.031 θ 0° 6° 0° 6° 6 www.run-ic.com RS8031, RS8032, RS8034 TSSOP-14 e b 5.6 E1 E 1.78 D 0.65 0.42 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 Symbol H C A θ L Dimensions In Millimeters Min Max A Dimensions In Inches Min Max 1.200 0.047 A1 0.050 0.150 0.002 0.006 A2 0.800 1.050 0.031 0.041 b 0.190 0.300 0.007 0.012 c 0.090 0.200 0.004 0.008 D 4.860 5.100 0.191 0.201 E 4.300 4.500 0.169 0.177 E1 6.250 6.550 0.246 0.258 e L 0.650(BSC) 0.500 H θ 0.026(BSC) 0.700 0.020 0.25(TYP) 1° 0.028 0.01(TYP) 7° 7 1° 7° www.run-ic.com RS8031, RS8032, RS8034 SOIC-8 b e 5.2 E E1 2.2 D 1.27 0.6 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.007 0.010 D 4.800 5.000 0.189 0.197 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 8 www.run-ic.com RS8031, RS8032, RS8034 SOIC-14 e b 5.2 1.27 E E1 0.6 D 1.27 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 c A θ L Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.310 0.510 0.012 0.020 c 0.100 0.250 0.004 0.010 D 8.450 8.850 0.333 0.348 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 9 www.run-ic.com RS8031, RS8032, RS8034 TDFN-3x3-8L E b D E1 L e D1 BOTTOM VIEW A1 A2 A TOP VIEW SIDE VIEW Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 0.700 0.800 0.028 0.031 A1 0.000 0.050 0.000 0.002 A2 0.203 0.008 b 0.300 0.400 0.012 0.016 D 2.900 3.100 0.114 0.122 D1 2.510 2.610 0.099 0.103 E 2.900 3.100 0.114 0.122 E1 1.550 1.650 0.061 0.065 e L 0.650 TYP 0.350 0.026 TYP 0.450 10 0.014 0.018 www.run-ic.com
RS8032XK 价格&库存
很抱歉,暂时无法提供与“RS8032XK”相匹配的价格&库存,您可以联系我们找货
RS8032XK
  • 5+3.01320
  • 50+2.24640
  • 150+1.92240
  • 500+1.51200
库存:1641
