PMBTA42,185
PMBTA42,185
    NEXPERIA(安世)
    SOT-23
    通用三极管 NPN Ic=100mA Vceo=300V hfe=25 P=250mW SOT23
PMBTA42,185 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PMBTA42 300 V, 100 mA NPN high-voltage transistor Rev. 05 — 12 December 2008 Product data sheet 1. Product profile 1.1 General description NPN high-voltage transistor in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package. PNP complement: PMBTA92. 1.2 Features „ High voltage (max. 300 V) 1.3 Applications „ Telephony and professional communication equipment 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 300 V IC collector current - - 100 mA hFE DC current gain IC = 1 mA 25 - - IC = 10 mA 40 - - IC = 30 mA 40 - - VCE = 10 V 2. Pinning information Table 2. Pinning Pin Description 1 base 2 emitter 3 collector Simplified outline Graphic symbol 3 3 1 1 2 2 sym021 PMBTA42 NXP Semiconductors 300 V, 100 mA NPN high-voltage transistor 3. Ordering information Table 3. Ordering information Type number[1] PMBTA42 Package Name Description Version - plastic surface-mounted package; 3 leads SOT23 PMBTA42/DG [1] /DG: halogen-free 4. Marking Table 4. Marking codes Type number[1] Marking code[2] PMBTA42 *1D PMBTA42/DG *BV [1] [2] /DG: halogen-free * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 300 V VCEO collector-emitter voltage open base - 300 V VEBO emitter-base voltage open collector IC collector current ICM peak collector current IBM - 6 V - 100 mA single pulse; tp ≤ 1 ms - 200 mA peak base current single pulse; tp ≤ 1 ms - 100 mA Ptot total power dissipation Tamb ≤ 25 °C - 250 mW Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. PMBTA42_5 Product data sheet [1] © NXP B.V. 2008. All rights reserved. Rev. 05 — 12 December 2008 2 of 9 PMBTA42 NXP Semiconductors 300 V, 100 mA NPN high-voltage transistor 6. Thermal characteristics Table 6. Symbol Rth(j-a) [1] Thermal characteristics Parameter Conditions thermal resistance from junction to ambient in free air [1] Min Typ Max Unit - - 500 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 200 V; IE = 0 A - - 100 nA IEBO emitter-base cut-off current VEB = 6 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 10 V IC = 1 mA 25 - - IC = 10 mA 40 - - IC = 30 mA 40 - - VCEsat collector-emitter saturation voltage IC = 20 mA; IB = 2 mA - - 500 mV VBEsat base-emitter saturation IC = 20 mA; IB = 2 mA voltage - - 900 mV Cre feedback capacitance VCB = 20 V; IC = ic = 0 A; f = 1 MHz - - 3 pF fT transition frequency VCE = 20 V; IC = 10 mA; f = 100 MHz 50 - - MHz PMBTA42_5 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 05 — 12 December 2008 3 of 9 PMBTA42 NXP Semiconductors 300 V, 100 mA NPN high-voltage transistor 8. Package outline Plastic surface-mounted package; 3 leads SOT23 D E B A X HE v M A 3 Q A A1 1 2 e1 bp c w M B Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max. bp c D E e e1 HE Lp Q v w mm 1.1 0.9 0.1 0.48 0.38 0.15 0.09 3.0 2.8 1.4 1.2 1.9 0.95 2.5 2.1 0.45 0.15 0.55 0.45 0.2 0.1 OUTLINE VERSION SOT23 Fig 1. REFERENCES IEC JEDEC JEITA TO-236AB EUROPEAN PROJECTION ISSUE DATE 04-11-04 06-03-16 Package outline SOT23 (TO-236AB) PMBTA42_5 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 05 — 12 December 2008 4 of 9 PMBTA42 NXP Semiconductors 300 V, 100 mA NPN high-voltage transistor 9. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PMBTA42 Package Description SOT23 Packing quantity 4 mm pitch, 8 mm tape and reel 3000 10000 -215 -235 PMBTA42/DG [1] For further information and the availability of packing methods, see Section 13. [2] /DG: halogen-free 10. Soldering 3.3 2.9 1.9 solder lands solder resist 3 2 1.7 solder paste 0.6 (3×) 0.7 (3×) occupied area Dimensions in mm 0.5 (3×) 0.6 (3×) 1 Fig 2. Reflow soldering footprint SOT23 (TO-236AB) PMBTA42_5 Product data sheet sot023_fr © NXP B.V. 2008. All rights reserved. Rev. 05 — 12 December 2008 5 of 9 PMBTA42 NXP Semiconductors 300 V, 100 mA NPN high-voltage transistor 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 Fig 3. Wave soldering footprint SOT23 (TO-236AB) PMBTA42_5 Product data sheet sot023_fw © NXP B.V. 2008. All rights reserved. Rev. 05 — 12 December 2008 6 of 9 PMBTA42 NXP Semiconductors 300 V, 100 mA NPN high-voltage transistor 11. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PMBTA42_5 20081212 Product data sheet - PMBTA42_4 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • Legal texts have been adapted to the new company name where appropriate. Type number PMBTA42/DG added Table 4 “Marking codes”: enhanced Section 12 “Legal information”: updated PMBTA42_4 20040122 Product specification - PMBTA42_3 PMBTA42_3 19990422 Product specification - PMBTA42_43_CNV_2 PMBTA42_5 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 05 — 12 December 2008 7 of 9 PMBTA42 NXP Semiconductors 300 V, 100 mA NPN high-voltage transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 12.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PMBTA42_5 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 05 — 12 December 2008 8 of 9 PMBTA42 NXP Semiconductors 300 V, 100 mA NPN high-voltage transistor 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information . . . . . . . . . . . . . . . . . . . . . Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . Contact information. . . . . . . . . . . . . . . . . . . . . . Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 1 1 1 1 1 2 2 2 3 3 4 5 5 7 8 8 8 8 8 8 9 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2008. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 12 December 2008 Document identifier: PMBTA42_5
PMBTA42,185 价格&库存
很抱歉,暂时无法提供与“PMBTA42,185”相匹配的价格&库存,您可以联系我们找货
PMBTA42,185
  • 30000+0.2198130000+0.02751
  • 60000+0.2005360000+0.02510
  • 90000+0.1907090000+0.02387
  • 150000+0.17966150000+0.02249
  • 210000+0.17312210000+0.02167
  • 300000+0.16676300000+0.02087
PMBTA42,185
    PMBTA42,185
    • 1+1.589671+0.19893
    • 10+0.9708710+0.12150
    • 100+0.59639100+0.07464
    • 500+0.43425500+0.05435
    • 1000+0.381321000+0.04772
    PMBTA42,185
