HI-3220PQIF
HI-3220PQIF
    HOLT
    LQFP80
    HI-3220PQIF
HI-3220PQIF 数据手册
HI-3220 High Density 16Rx / 8Tx or 8Rx / 4Tx ARINC 429 Protocol IC with optional Integrated Line Receivers FEATURES The HI-3220, HI-3221, HI-3222 and HI-3223 have integrated ARINC 429 line receivers, capable of RTCA/DO-160 level 3 lightning compliance with external 40kΩ resistors. HI-3225 and HI-3226 utilize external line receivers, for example Holt’s octal HI-8458 family. The HI-3222 and HI-3223 are 8-channel receive, 4-channel transmit options available in smaller package footprints, with HI-3223 having the same slope control feature as HI-3220. Transmit outputs interface directly to external HI-8592, HI-8596, or integrated lightning protected HI-8597 ARINC 429 line drivers. All parts use a 40 MHz 4-wire SPI (Serial Peripheral Interface) host connection. HI-3220 and HI-3225 are available in an 80-pin PQFP package, whereas HI-3221 and HI-3226 are available in a 72-pin 10mm x 10mm QFN package. The HI-3222 (8-ch. Rx, 4-ch. Tx) is available in a very compact 48-pin 7mm x 7mm QFN. APPLICATION Controller Memory HI-3220/3221 (DS3220 Rev. K) ARINC 429 8 x Transmit ARINC 429 16 x Receive CPU · Sixteen ARINC 429 Receive channels with optional integrated line Receivers · Eight ARINC 429 Transmit channels · 8-channel Rx, 4-channel Tx version available in compact 48-pin 7mm x 7mm QFN · 32 KB on chip user-configurable data storage memory · Programmable receive data filtering · Option for programmable transmission schedulers for periodic ARINC 429 broadcasting or CPU directed transmission · Auto-initialization feature allows power-on configuration or independent operation without CPU · 40 MHZ SPI CPU interface · Transmitter rate and tri-state control outputs · Supports 100kbs / 50kbs / 12.5kbs data rates PIN CONFIGURATION SLP7 TX3N TX3P MODE0/ECS EMISO TX7N TX7P MODE1/EMOSI MODE2/ESCLK GND VDD MCLK READY TX6N TX6P SCANSHFT SCANEN TX2N TX2P SLP6 The ARINC 429 buses may operate independently - the IC can be programmed to automatically re-format, re-label, re-packetize and re-transmit data from ARINC 429 receive buses to ARINC 429 transmit buses. Alternatively, a host CPU can send and receive data on multiple buses. 32KB of on-board memory allows received data to be logically organized and automatically updated as new ARINC 429 labels are received via ARINC 429 label mailboxes. A 64 message deep Receive FIFO is also available for each receive channel. Each transmitter has the option to independently enable a programmable scheduler on the ARINC 429 bus, or to have the CPU directly send data. An optional auto-initialization feature allows configuration information to be up-loaded from an external EEPROM on reset to facilitate rapid start-up or operation without a host CPU. · Fully compliant to ARINC 429 Specification 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 The HI-3220 from Holt Integrated Circuits is a family of single chip CMOS high density application data management ICs capable of managing, storing and forwarding avionics data messages between sixteen ARINC 429 receive channels and eight ARINC 429 transmit channels. Options for eight receive and four transmit channels are also available in a compact, cost effective 7mm x 7mm QFN package footprint. SLP3 ARX8P-40 ARX8N-40 ARX0P-40 ARX0N-40 ARX9P-40 ARX9N-40 ARX1P-40 ARX1N-40 VDD GND ARX2P-40 ARX2N-40 ARX10P-40 ARX10N-40 ARX3P-40 ARX3N-40 ARX11P-40 ARX11N-40 SLP0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 HI-3220PQx 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 SLP2 ARX15N-40 ARX15P-40 ARX7N-40 ARX7P-40 ARX14N-40 ARX14P-40 ARX6N-40 ARX6P-40 GND VDD ARX5N-40 ARX5P-40 ARX13N-40 ARX13P-40 ARX4N-40 ARX4P-40 ARX12N-40 ARX12P-40 SLP1 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 GENERAL DESCRIPTION SLP4 TX0P TX0N HCS HMOSI TX4P TX4N HSCLK HMISO VDD GND MRST RUN TX5P TX5N INT ACK TX1P TX1N SLP5 April 2021 80 - Pin Plastic Quad Flat Pack (PQFP) 04/21 HI-3220 BLOCK DIAGRAM Host CPU ARINC 429 RECEIVE DATA MEMORY 0 1K x 8 RECEIVER 0 Interrupt Handler 32 x 32 Transmit FIFO ARINC 429 Descriptor Table 0 FILTER TABLE 0 ARINC 429 TRANSMIT SCHEDULER 0 Message 64 “ “ “ Message 2 Message 1 CHANNEL 0 CHANNEL 1 CHANNEL 2 CHANNEL 3 CHANNEL 4 CHANNEL 5 ............. CHANNEL 15 ECS ESCLK EMOSI EMISO EEPROM SPI GND TRANSMIT TIMER CHANNEL 0 CHANNEL 1 CHANNEL 2 CHANNEL 3 CHANNEL 4 CHANNEL 5 CHANNEL 6 CHANNEL 7 64 x 32 FIFO LABEL FILTER TRANSMITTER 0 Auto-Initialization EEPROM PRODUCT OPTIONS PART NUMBER PACKAGE LINE RECEIVERS TRANSMIT CHANNELS HI-3220 HI-3221 HI-3222 HI-3223 HI-3225 HI-3226 80-pin QFP 72-pin QFN 48-pin QFN 52-pin QFP or 64-pin QFN 80-pin QFP 72-pin QFN 16 on-chip 16 on-chip 8 on-chip 8 on-chip 16 External 16 External 8 Transmitters & SLP7:0 outputs 8 Transmitters. No SLP7:0 outputs 4 Transmitters. No SLP outputs 4 Transmitters & SLP3:0 outputs 8 Transmitters & SLP7:0 outputs 8 Transmitters. No SLP7:0 outputs HOLT INTEGRATED CIRCUITS 2 8 x ARINC 429 Transmit Buses 16 x ARINC 429 Integrated Line Receivers (HI-3220/3221 ONLY) SPI ACK INT HCS HSCLK HMOSI HMISO READY RUN MRST MODE2:0 VDD HI-3220 PIN DESCRIPTIONS (HI-3220, HI-3221, HI-3222, HI-3223) Signal Function ACK INT ARX0N-40 ARX0P-40 ARX1N-40 ARX1P-40 ARX2N-40 ARX2P-40 ARX3N-40 ARX3P-40 ARX4N-40 ARX4P-40 ARX5N-40 ARX5P-40 ARX6N-40 ARX6P-40 ARX7N-40 ARX7P-40 ARX8N-40 ARX8P-40 ARX9N-40 ARX9P-40 ARX10N-40 ARX10P-40 ARX11N-40 ARX11P-40 ARX12N-40 ARX12P-40 ARX13N-40 ARX13P-40 ARX14N-40 ARX14P-40 ARX15N-40 ARX15P-40 TX0N TX0P TX1N TX1P TX2N TX2P TX3N TX3P TX4N TX4P TX5N TX5P TX6N TX6P TX7N TX7P SLP0 SLP1 SLP2 SLP3 SLP4 SLP5 SLP6 SLP7 INPUT OUTPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT ANALOG INPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT Description Internal Pull-Up/Down Interrupt Acknowledge. Active low. Interrupt. Active low, open-drain. ARINC 429 Receive bus negative line input for channel 0. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 0. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 1. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 1. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 2. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 2. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 3. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 3. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 4. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 4. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 5. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 5. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 6. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 6. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 7. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 7. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 8. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 8. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 9. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 9. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 10. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 10. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 11. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 11. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 12. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 12. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 13. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 13. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 14. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 14. Requires external 40KOhm resistor. ARINC 429 Receive bus negative line input for channel 15. Requires external 40KOhm resistor. ARINC 429 Receive bus positive line input for channel 15. Requires external 40KOhm resistor. ARINC 429 Tx channel 0 negative data output to line driver ARINC 429 Tx channel 0 positive data output to line driver ARINC 429 Tx channel 1 negative data output to line driver ARINC 429 Tx channel 1 positive data output to line driver ARINC 429 Tx channel 2 negative data output to line driver ARINC 429 Tx channel 2 positive data output to line driver ARINC 429 Tx channel 3 negative data output to line driver ARINC 429 Tx channel 3 positive data output to line driver ARINC 429 Tx channel 4 negative data output to line driver ARINC 429 Tx channel 4 positive data output to line driver ARINC 429 Tx channel 5 negative data output to line driver ARINC 429 Tx channel 5 positive data output to line driver ARINC 429 Tx channel 6 positive data output to line driver ARINC 429 Tx channel 6 positive data output to line driver ARINC 429 Tx channel 7 positive data output to line driver ARINC 429 Tx channel 7 positive data output to line driver ARINC 429 Tx channel 0 slew rate control (see Tx Control Register) (HI-3220 and HI-3223). ARINC 429 Tx channel 1 slew rate control (see Tx Control Register) (HI-3220 and HI-3223). ARINC 429 Tx channel 2 slew rate control (see Tx Control Register) (HI-3220 and HI-3223). ARINC 429 Tx channel 3 slew rate control (see Tx Control Register) (HI-3220 and HI-3223). ARINC 429 Tx channel 4 slew rate control (see Tx Control Register) (HI-3220 and HI-3223). ARINC 429 Tx channel 5 slew rate control (see Tx Control Register) (HI-3220 and HI-3223). ARINC 429 Tx channel 6 slew rate control (see Tx Control Register) (HI-3220 and HI-3223). ARINC 429 Tx channel 7 slew rate control (see Tx Control Register) (HI-3220 and HI-3223). HOLT INTEGRATED CIRCUITS 3 Pull-Up Pull-Up HI-3220 PIN DESCRIPTIONS (HI-3220, HI-3221, HI-3222, HI-3223) continued Signal Function MODE0/ECS EMISO MODE1/EMOSI MODE2/ESCLK GND VDD HCS HMISO HMOSI HSCLK MCLK MRST READY RUN SCANEN SCANSHFT I/O INPUT I/O I/O POWER POWER INPUT OUTPUT INPUT INPUT INPUT INPUT OUTPUT INPUT INPUT INPUT Description Internal Pull-Up/Down MODE0 configuration input sampled at reset / SPI chip select output for initialization EEPROM SPI serial data input from auto-inialization EEPROM MODE1 configuration input sampled at reset / SPI serial data output to initialization EEPROM MODE2 configuration input sampled at reset / SPI clock for auto-initialization EEPROM Chip 0V supply. All four pins must be connected. 3.3V power supply. All four pins must be powered. Host chip select. Data is shifted into HMOSI and out of HMISO when HCS is low Host CPU SPI interface serial data output Host CPU SPI interface serial data input Host SPI Clock. Data is shifted into or out of the SPI interface using HSCLK Master and reference clock for ARINC 429 bus bit timing. 50MHz +/- 0.1% Master Reset to HI-322X Active Low. 225 ns minimum pulse width. READY goes high when post-RESET initialization is complete Master enable signal for ARINC 429 transmit schedulers Factory test only. Connect to GND. Factory test only. Connect to GND. See Note below Pull-Down See Note below See Note below Pull-Up Pull-Down Pull-Down Pull-Down Pull-Down Pull-Down Pull-Down Pull-Down NOTE: When not using an external EEPROM, the Mode0, Mode1 and Mode2 pins must be connected to either VDD or GND through a suitable pull-up or pull-down resistor (1K - 50K), depending on the desired power up mode. These pins do not have internal pull-up or pull-down resistors and need to be connected to a known state to prevent possible initialization of an un-intended mode. 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 SLP7 TX3N TX3P MODE0/ECS EMISO TX7N TX7P MODE1/EMOSI MODE2/ESCLK GND VDD MCLK READY TX6N TX6P SCANSHFT SCANEN TX2N TX2P SLP6 PIN CONFIGURATIONS 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 HI-3220PQx SLP2 ARX15N-40 ARX15P-40 ARX7N-40 ARX7P-40 ARX14N-40 ARX14P-40 ARX6N-40 ARX6P-40 GND VDD ARX5N-40 ARX5P-40 ARX13N-40 ARX13P-40 ARX4N-40 ARX4P-40 ARX12N-40 ARX12P-40 SLP1 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 SLP4 TX0P TX0N HCS HMOSI TX4P TX4N HSCLK HMISO VDD GND MRST RUN TX5P TX5N INT ACK TX1P TX1N SLP5 SLP3 ARX8P-40 ARX8N-40 ARX0P-40 ARX0N-40 ARX9P-40 ARX9N-40 ARX1P-40 ARX1N-40 VDD GND ARX2P-40 ARX2N-40 ARX10P-40 ARX10N-40 ARX3P-40 ARX3N-40 ARX11P-40 ARX11N-40 SLP0 80 - Pin Plastic Quad Flat Pack (PQFP) HOLT INTEGRATED CIRCUITS 4 HI-3220 HI-3221PCx ARX15N-40 ARX15P-40 ARX7N-40 ARX7P-40 ARX14N-40 ARX14P-40 ARX6N-40 ARX6P-40 GND VDD ARX5N-40 ARX5P-40 ARX13N-40 ARX13P-40 ARX4N-40 ARX4P-40 ARX12N-40 ARX12P-40 TX3N 1 ARX0P-40 2 ARX0N-40 3 ARX1P-40 4 ARX1N-40 5 VDD 6 GND 7 ARX2P-40 8 ARX2N-40 9 ARX3P-40 10 ARX3N-40 11 TX0P 12 HI-3222PCx 36 35 34 33 32 31 30 29 28 27 26 25 TX2P ARX7N-40 ARX7P-40 ARX6N-40 ARX6P-40 GND VDD ARX5N-40 ARX5P-40 ARX4N-40 ARX4P-40 TX1N 13 14 15 16 17 18 19 20 21 22 23 24 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 38 37 TX0N HCS HMOSI HSCLK HMISO VDD GND MRST RUN INT ACK TX1P 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 TX0P TX0N HCS HMOSI TX4P TX4N HSCLK HMISO VDD GND MRST RUN TX5P TX5N INT ACK TX1P TX1N 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 ARX8P-40 ARX8N-40 ARX0P-40 ARX0N-40 ARX9P-40 ARX9N-40 ARX1P-40 ARX1N-40 VDD GND ARX2P-40 ARX2N-40 ARX10P-40 ARX10N-40 ARX3P-40 ARX3N-40 ARX11P-40 ARX11N-40 48 47 46 45 44 43 42 41 40 39 38 37 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 TX3P MODE0/ECS EMISO MODE1/EMOSI MODE2/ESCLK GND VDD MCLK READY SCANSHFT SCANEN TX2N TX3N TX3P MODE0/ECS EMISO TX7N TX7P MODE1/EMOSI MODE2/ESCLK GND VDD MCLK READY TX6N TX6P SCANSHFT SCANEN TX2N TX2P PIN CONFIGURATIONS (continued) 48 - Pin Plastic QFN (Top View) 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 52 51 50 49 48 47 46 45 44 43 42 41 40 TX3N TX3P MODE0/ECS EMISO MODE1/EMOSI MODE2/ESCLK GND VDD MCLK READY SCANSHFT SCANEN TX2N TX2P - TX3P MODE0/ECS EMISO MODE1/EMOSI MODE2/ESCLK GND VDD MCLK READY SCANSHFT SCANEN TX2N TX2P 72 - Pin Plastic QFN (Top View) 39 38 37 36 35 34 33 32 31 30 29 28 27 SLP3 ARX0P-40 ARX0N-40 ARX1P-40 ARX1N-40 VDD GND ARX2P-40 ARX2N-40 ARX3P-40 ARX3N-40 SLP0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 HI-3223PCx 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 52 - Pin Plastic Quad Flat Pack (PQFP) HOLT INTEGRATED CIRCUITS 5 TX0P TX0N HCS HMOSI HSCLK HMISO VDD GND MRST RUN INT ACK TX1P TX1N - 14 15 16 17 18 19 20 21 22 23 24 25 26 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 HI-3223PQx SLP2 ARX7N-40 ARX7P-40 ARX6N-40 ARX6P-40 GND VDD ARX5N-40 ARX5P-40 ARX4N-40 ARX4P-40 SLP1 TX1N TX0P TX0N HCS HMOSI HSCLK HMISO VDD GND MRST RUN INT ACK TX1P TX3N 1 SLP3 2 ARX0P-40 3 ARX0N-40 4 ARX1P-40 5 ARX1N-40 6 VDD 7 GND 8 ARX2P-40 9 ARX2N-40 10 ARX3P-40 11 ARX3N-40 12 SLP0 13 “-” denotes “Not Connected internally” 64 - Pin Plastic QFN (Top View) SLP2 ARX7N-40 ARX7P-40 ARX6N-40 ARX6P-40 GND VDD ARX5N-40 ARX5P-40 ARX4N-40 ARX4P-40 SLP1 HI-3220 PIN DESCRIPTIONS (HI-3225, HI-3226) Signal Function ACK INT RX0N RX0P RX1N RX1P RX2N RX2P RX3N RX3P RX4N RX4P RX5N RX5P RX6N RX6P RX7N RX7P RX8N RX8P RX9N RX9P RX10N RX10P RX11N RX11P RX12N RX12P RX13N RX13P RX14N RX14P RX15N RX15P TX0N TX0P TX1N TX1P TX2N TX2P TX3N TX3P TX4N TX4P TX5N TX5P TX6N TX6P TX7N TX7P SLP0 SLP1 SLP2 SLP3 SLP4 SLP5 SLP6 SLP7 INPUT OUTPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT INPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT Description Internal Pull-Up/Down Interrupt Acknowledge. Active low. Interrupt. Active low, open-drain. ARINC 429 Digital input from line receiver negative signal for channel 0. ARINC 429 Digital input from line receiver positive signal for channel 0. ARINC 429 Digital input from line receiver negative signal for channel 1. ARINC 429 Digital input from line receiver positive signal for channel 1. ARINC 429 Digital input from line receiver negative signal for channel 2. ARINC 429 Digital input from line receiver positive signal for channel 2. ARINC 429 Digital input from line receiver negative signal for channel 3. ARINC 429 Digital input from line receiver positive signal for channel 3. ARINC 429 Digital input from line receiver negative signal for channel 4. ARINC 429 Digital input from line receiver positive signal for channel 4. ARINC 429 Digital input from line receiver negative signal for channel 5. ARINC 429 Digital input from line receiver positive signal for channel 5. ARINC 429 Digital input from line receiver negative signal for channel 6. ARINC 429 Digital input from line receiver positive signal for channel 6. ARINC 429 Digital input from line receiver negative signal for channel 7. ARINC 429 Digital input from line receiver positive signal for channel 7. ARINC 429 Digital input from line receiver negative signal for channel 8. ARINC 429 Digital input from line receiver positive signal for channel 8. ARINC 429 Digital input from line receiver negative signal for channel 9. ARINC 429 Digital input from line receiver positive signal for channel 9. ARINC 429 Digital input from line receiver negative signal for channel 10. ARINC 429 Digital input from line receiver positive signal for channel 10. ARINC 429 Digital input from line receiver negative signal for channel 11. ARINC 429 Digital input from line receiver positive signal for channel 11. ARINC 429 Digital input from line receiver negative signal for channel 12. ARINC 429 Digital input from line receiver positive signal for channel 12. ARINC 429 Digital input from line receiver negative signal for channel 13. ARINC 429 Digital input from line receiver positive signal for channel 13. ARINC 429 Digital input from line receiver negative signal for channel 14. ARINC 429 Digital input from line receiver positive signal for channel 14. ARINC 429 Digital input from line receiver negative signal for channel 15. ARINC 429 Digital input from line receiver positive signal for channel 15. ARINC 429 Tx channel 0 negative data output to line driver ARINC 429 Tx channel 0 positive data output to line driver ARINC 429 Tx channel 1 negative data output to line driver ARINC 429 Tx channel 1 positive data output to line driver ARINC 429 Tx channel 2 negative data output to line driver ARINC 429 Tx channel 2 positive data output to line driver ARINC 429 Tx channel 3 negative data output to line driver ARINC 429 Tx channel 3 positive data output to line driver ARINC 429 Tx channel 4 negative data output to line driver ARINC 429 Tx channel 4 positive data output to line driver ARINC 429 Tx channel 5 negative data output to line driver ARINC 429 Tx channel 5 positive data output to line driver ARINC 429 Tx channel 6 positive data output to line driver ARINC 429 Tx channel 6 positive data output to line driver ARINC 429 Tx channel 7 positive data output to line driver ARINC 429 Tx channel 7 positive data output to line driver ARINC 429 Tx channel 0 slew rate control (see Tx Control Register) (HI-3225). ARINC 429 Tx channel 1 slew rate control (see Tx Control Register) (HI-3225). ARINC 429 Tx channel 2 slew rate control (see Tx Control Register) (HI-3225). ARINC 429 Tx channel 3 slew rate control (see Tx Control Register) (HI-3225). ARINC 429 Tx channel 4 slew rate control (see Tx Control Register) (HI-3225). ARINC 429 Tx channel 5 slew rate control (see Tx Control Register) (HI-3225). ARINC 429 Tx channel 6 slew rate control (see Tx Control Register) (HI-3225). ARINC 429 Tx channel 7 slew rate control (see Tx Control Register) (HI-3225). HOLT INTEGRATED CIRCUITS 6 Pull-Up Pull-Up Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down Pull-down HI-3220 PIN DESCRIPTIONS (HI-3225, HI-3226) continued Signal Function MODE0/ECS EMISO MODE1/EMOSI MODE2/ESCLK GND VDD HCS HMISO HMOSI HSCLK MCLK MRST READY RUN SCANEN SCANSHFT I/O INPUT I/O I/O POWER POWER INPUT OUTPUT INPUT INPUT INPUT INPUT OUTPUT INPUT INPUT INPUT Description Internal Pull-Up/Down MODE0 configuration input sampled at reset / SPI chip select output for EEPROM initialization SPI serial data input from auto-inialization EEPROM MODE1 configuration input sampled at reset / SPI serial data output for EEPROM initialization MODE2 configuration input sampled at reset / SPI clock for EEPROM auto-initialization Chip 0V supply. All four pins must be connected. 3.3V power supply. All four pins must be powered. Host chip select. Data is shifted into HMOSI and out of HMISO when HCS is low Host CPU SPI interface serial data output Host CPU SPI interface serial data input Host SPI Clock. Data is shifted into or out of the SPI interface using HSCLK Master and reference clock for ARINC 429 bus bit timing. 50 MHZ +/- 0.1% Master Reset to HI-322X Active Low. 225 ns minimum pulse width. READY goes high when post-RESET initialization is complete Master enable signal for ARINC 429 transmit schedulers Factory test only. Connect to GND. Factory test only. Connect to GND. See Note below Pull-Down See Note below See Note below Pull-Up Pull-Down Pull-Down Pull-Down Pull-Down Pull-Down Pull-Down Pull-Down NOTE: When not using an external EEPROM, the Mode0, Mode1 and Mode2 pins must be connected to either VDD or GND through a suitable pull-up or pull-down resistor (1K - 50K), depending on the desired power up mode. These pins do not have internal pull-up or pull-down resistors and need to be connected to a known state to prevent possible initialization of an un-intended mode. 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 TX3N TX3P MODE0/ECS EMISO TX7N TX7P MODE1/EMOSI MODE2/ESCLK GND VDD MCLK READY TX6N TX6P SCANSHFT SCANEN TX2N TX2P SLP7 TX3N TX3P MODE0/ECS EMISO TX7N TX7P MODE1/EMOSI MODE2/ESCLK GND VDD MCLK READY TX6N TX6P SCANSHFT SCANEN TX2N TX2P SLP6 PIN CONFIGURATIONS 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 RX8P RX8N RX0P RX0N RX9P RX9N RX1P RX1N VDD GND RX2P RX2N RX10P RX10N RX3P RX3N RX11P RX11N 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 HI-3226PCx 80 - Pin Plastic Quad Flat Pack (PQFP) HOLT INTEGRATED CIRCUITS 7 TX0P TX0N HCS HMOSI TX4P TX4N HSCLK HMISO VDD GND MRST RUN TX5P TX5N INT ACK TX1P TX1N 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 HI-3225PQx SLP2 RX15N RX15P RX7N RX7P RX14N RX14P RX6N RX6P GND VDD RX5N RX5P RX13N RX13P RX4N RX4P RX12N RX12P SLP1 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 SLP4 TX0P TX0N HCS HMOSI TX4P TX4N HSCLK HMISO VDD GND MRST RUN TX5P TX5N INT ACK TX1P TX1N SLP5 SLP3 RX8P RX8N RX0P RX0N RX9P RX9N RX1P RX1N VDD GND RX2P RX2N RX10P RX10N RX3P RX3N RX11P RX11N SLP0 72 - Pin Plastic QFN (Top View) 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 38 37 RX15N RX15P RX7N RX7P RX14N RX14P RX6N RX6P GND VDD RX5N RX5P RX13N RX13P RX4N RX4P RX12N RX12P HI-3220 APPLICATION OVERVIEW The HI-3220 is a flexible device for managing ARINC 429 communications and data storage in many avionics applications. The device architecture centers around a 32K x 8 static RAM used for data storage, data filtering tables and table-driven transmission schedulers. Once configured, the device can operate autonomously without a host CPU, negating the need for software development or DO-178 certification. Configuration data may be uploaded into the device from an external EEPROM, following system reset. The device supports up to sixteen ARINC 429 receive channels. Analog line receivers are on-chip (HI-3220, HI3221 and HI-3222), or off-chip (HI-3225 and HI-3226). Received data is stored in on-chip RAM organized by channel number and label. The data table continually updates as new labels arrive. Programmable interrupts and filters alert the host subsystem to labels of interest. Each ARINC 429 receive channel also includes a 64 message deep FIFO allowing selected label data to be queued for subsequent host access. The HI-3220 supports up to eight independent ARINC 429 transmit channels. Transmission may be controlled entirely by an external CPU, or autonomously by programming one or more of the eight on-chip ARINC 429 transmit schedulers. These allow periodic transmission to occur without CPU. Source data for transmission may be selected from RAM based tables of constants and / or from the received channel data. Powerful options exist for constructing ARINC 429 labels as well as controlling their timing and conditional transmission. Even when running under the control of schedulers, the host CPU may insert new labels for transmission at will. The following examples show five possible configurations of how the HI-3220 may be used: Example 1. ARINC 429 Data reception using on-chip RAM 16 x ARINC 429 Receive Buses RECEIVER 15 Channel 15, Label FF “ “ “ Channel 15, Label 01 Channel 15, Label 00 RECEIVER 14 Channel 14, Label FF “ “ “ Channel 14, Label 01 Channel 14, Label 00 RECEIVER 13 Channel 13, Label FF “ “ “ Channel 13, Label 01 Channel 13, Label 00 RECEIVE INTERRUPT TABLE INT ACK Host CPU RECEIVERS 12-3 RECEIVER 2 RECEIVER 1 RECEIVER 0 Channels 12-3, Label FF “ “ “ Channels 12-3, Label 01 Channels 12-3, Label 00 HCSB HSCLK HMOSI HMISO SPI Channel 2, Label FF “ “ “ Channel 2, Label 01 Channel 2, Label 00 Channel 1, Label FF “ “ “ Channel 1, Label 01 Channel 1, Label 00 Channel 0, Label FF “ “ “ Channel 0, Label 01 Channel 0, Label 00 16K x 8 RAM (of 32K available) HOLT INTEGRATED CIRCUITS 8 HI-3220 HI-3220 Example 2. ARINC 429 Data reception using on-chip filters and FIFOs FILTER TABLE 0 16 x ARINC 429 Receive Buses LABEL FILTER RECEIVER 0 Message 64 “ “ “ Message 2 Message 1 64 x 32 FIFO HCSB HSCLK HMOSI HMISO SPI FIFO STATUS Host CPU FIFO THRESHOLD CHANNEL 0 CHANNEL 1 CHANNEL 2 CHANNEL 3 ............... ............... CHANNEL 14 CHANNEL 15 ARINC 429 RECEIVE FIFO INTERRUPT CONTROL INT ACK HI-3220 Example 3. ARINC 429 Data transmission directly from CPU 32 x 32 FIFOs Host CPU HCS HSCLK HMOSI HMISO FIFO 0 TRANSMITTER 0 FIFO 1 TRANSMITTER 1 FIFO 2 TRANSMITTER 2 FIFO 3 TRANSMITTER 3 FIFO 4 TRANSMITTER 4 FIFO 5 TRANSMITTER 5 FIFO 6 TRANSMITTER 6 FIFO 7 TRANSMITTER 7 8 x ARINC 429 Transmit Buses SPI HI-3220 Example 4. ARINC 429 Data transmission using on-chip schedulers TRANSMITTER 0 Descriptor Table 0 Host CPU HCS HSCLK HMOSI HMISO TRANSMIT SCHEDULER 0 8 x ARINC 429 Transmit Buses SPI Descriptor Table 1 TRANSMIT TIMER CHANNEL 0 Descriptor Tables 2-6 CHANNEL 1 .............. CHANNEL 7 Auto-Initialization EEPROM ECS ESCLK EMOSI EMISO EEPROM SPI Descriptor Table 7 RAM HOLT INTEGRATED CIRCUITS 9 HI-3220 HI-3220 Example 5. Autonomous ARINC 429 Data Concentrator / Repeater RECEIVER 15 RECEIVER 14 Channel 14, Label FF “ Channel 14, Label 01 Channel 14, Label 00 RECEIVER 13 Channel 13, Label FF “ Channel 13, Label 01 Channel 13, Label 00 RECEIVER 12 Channel 12, Label FF “ Channel 12, Label 01 Channel 12, Label 00 RECEIVER 11 Channel 11, Label FF “ Channel 11, Label 01 Channel 11, Label 00 RECEIVER 10 Channel 10, Label FF “ Channel 10, Label 01 Channel 10, Label 00 RECEIVER 9 Channel 9, Label FF “ Channel 9, Label 01 Channel 9, Label 00 RECEIVER 8 Channel 8, Label FF “ Channel 8, Label 01 Channel 8, Label 00 RECEIVER 7 Channel 7, Label FF “ Channel 7, Label 01 Channel 7, Label 00 RECEIVER 6 Channel 6, Label FF “ Channel 6, Label 01 Channel 6, Label 00 RECEIVER 5 Channel 5, Label FF “ Channel 5, Label 01 Channel 5, Label 00 RECEIVER 4 Channel 4, Label FF “ Channel 4, Label 01 Channel 4, Label 00 RECEIVER 3 Channel 3, Label FF “ Channel 3, Label 01 Channel 3, Label 00 RECEIVER 2 Channel 2, Label FF “ Channel 2, Label 01 Channel 2, Label 00 RECEIVER 1 Channel 1, Label FF “ Channel 1, Label 01 Channel 1, Label 00 RECEIVER 0 Channel 0, Label FF “ Channel 0, Label 01 Channel 0, Label 00 TRANSMIT SCHEDULER 6 TRANSMITTER 7 TRANSMIT TIMER Descriptor Table 6 TRANSMIT SCHEDULER 6 TRANSMITTER 6 TRANSMIT TIMER Descriptor Table 5 TRANSMIT SCHEDULER 5 TRANSMITTER 5 TRANSMIT TIMER Descriptor Table 4 TRANSMIT SCHEDULER 4 TRANSMITTER 4 TRANSMIT TIMER Descriptor Table 3 TRANSMIT SCHEDULER 3 TRANSMITTER 3 TRANSMIT TIMER Descriptor Table 2 TRANSMIT SCHEDULER 2 TRANSMITTER 2 TRANSMIT TIMER Descriptor Table 1 TRANSMIT SCHEDULER 1 TRANSMITTER 1 TRANSMIT TIMER Descriptor Table 0 TRANSMIT SCHEDULER 0 TRANSMITTER 0 TRANSMIT TIMER EEPROM SPI HI-3220 ECS ESCLK EMOSI EMISO 16 x ARINC 429 Receive Buses Descriptor Table 7 Channel 15, Label FF “ Channel 15, Label 01 Channel 15, Label 00 Auto-Initialization EEPROM HOLT INTEGRATED CIRCUITS 10 8 x ARINC 429 Transmit Buses HI-3220 HI-3220 MEMORY MAP 0x8XXX Configuration Registers 0x8000 0x7FFF 0x7000 0x6FFF ARINC 429 Receive FIFO ARINC 429 Transmit FIFO 0x6C00 0x6BFF ARINC 429 RX Interrupt Map 0x6A00 0x69FF ARINC 429 RX FIFO Enable Map 0x6800 0x67FF 0x6400 0x63FF 0x6000 0x5FFF 0x5C00 0x5BFF 0x5800 0x57FF 0x5400 0x53FF 0x5000 0x4FFF 0x4800 0x47FF 0x4000 0x3FFF Tx7 Transmit Schedule Table Tx6 Transmit Schedule Table Tx5 Transmit Schedule Table Tx4 Transmit Schedule Table Tx3 Transmit Schedule Table Tx2 Transmit Schedule Table Tx1 Transmit Schedule Table Tx0 Transmit Schedule Table ARINC 429 Receive Data Shaded Area User - Programmed Non-shaded Area Data Storage 0x0000 HOLT INTEGRATED CIRCUITS 11 HI-3220 HI-3220 REGISTER MAP ADDRESS R/W REGISTER MNEMONIC MCR MCR MSR 0x8000 0x8001 0x8002 0x8003 0x8004 0x8005 0x8006 0x8007 0x8008 0x8009 0x800A 0x800B 0x800C 0x800D 0x800E 0x800F 0x8010 0x8011 0x8012 0x8013 0x8014 0x8015 0x8016 0x8017 0x8018 0x8019 0x801A 0x801B 0x801C 0x801D 0x801E 0x801F R/W R R R R* R R* R R* R R* R* R* R R R R R R R R R R R R R R R R R R R MASTER CONTROL REGISTER MASTER CONTROL REGISTER MASTER STATUS REGISTER Not used PENDING INTERRUPT REGISTER Not used RECEIVE PENDING INTERRUPT LOW Not used RECEIVE PENDING INTERRUPT HIGH Not used PENDING INTERRUPT REGISTER RECEIVE PENDING INTERRUPT LOW RECEIVE PENDING INTERRUPT HIGH RECEIVE FIFO THRESHOLD FLAG (LOW) RECEIVE FIFO THRESHOLD FLAG (HIGH) TRANSMITTER FIFO THRESHOLD FLAGS RECEIVE INTERRUPT ADDRESS 0 RECEIVE INTERRUPT ADDRESS 1 RECEIVE INTERRUPT ADDRESS 2 RECEIVE INTERRUPT ADDRESS 3 RECEIVE INTERRUPT ADDRESS 4 RECEIVE INTERRUPT ADDRESS 5 RECEIVE INTERRUPT ADDRESS 6 RECEIVE INTERRUPT ADDRESS 7 RECEIVE INTERRUPT ADDRESS 8 RECEIVE INTERRUPT ADDRESS 9 RECEIVE INTERRUPT ADDRESS 10 RECEIVE INTERRUPT ADDRESS 11 RECEIVE INTERRUPT ADDRESS 12 RECEIVE INTERRUPT ADDRESS 13 RECEIVE INTERRUPT ADDRESS 14 RECEIVE INTERRUPT ADDRESS 15 0x8020 0x8021 0x8022 0x8023 0x8024 0x8025 0x8026 0x8027 0x8028 0x8029 0x802A 0x802B 0x802C 0x802D 0x802E 0x802F R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W RECEIVE CONTROL REGISTER 0 RECEIVE CONTROL REGISTER 1 RECEIVE CONTROL REGISTER 2 RECEIVE CONTROL REGISTER 3 RECEIVE CONTROL REGISTER 4 RECEIVE CONTROL REGISTER 5 RECEIVE CONTROL REGISTER 6 RECEIVE CONTROL REGISTER 7 RECEIVE CONTROL REGISTER 8 RECEIVE CONTROL REGISTER 9 RECEIVE CONTROL REGISTER 10 RECEIVE CONTROL REGISTER 11 RECEIVE CONTROL REGISTER 12 RECEIVE CONTROL REGISTER 13 RECEIVE CONTROL REGISTER 14 RECEIVE CONTROL REGISTER 15 Fast Access Registers Memory mapped register access only PIR DESCRIPTION HI-3220 global configuration (write address) HI-3220 global configuration (read address) Indicates HI-3220 current status Indicates Interrupt type RPIRL Defines channel(7-0) with pending Interrupt RPIRH Defines channel(15-8) with pending Interrupt PIR RPIRL RPIRH FTFL FTFH TFR IAR0 IAR1 IAR2 IAR3 IAR4 IAR5 IAR6 IAR7 IAR8 IAR9 IAR10 IAR11 IAR12 IAR13 IAR14 IAR15 Indicates Interrupt type Defines channel(7-0) with pending Interrupt Defines channel(15-8) with pending Interrupt Shows which Rx FIFOs hold > (thresh) words Shows which Rx FIFOs hold > (thresh) words Shows which Tx FIFOs hold < (thresh) words ARINC 429 Interrupt Vector channel 0 ARINC 429 Interrupt Vector channel 1 ARINC 429 Interrupt Vector channel 2 ARINC 429 Interrupt Vector channel 3 ARINC 429 Interrupt Vector channel 4 ARINC 429 Interrupt Vector channel 5 ARINC 429 Interrupt Vector channel 6 ARINC 429 Interrupt Vector channel 7 ARINC 429 Interrupt Vector channel 8 ARINC 429 Interrupt Vector channel 9 ARINC 429 Interrupt Vector channel 10 ARINC 429 Interrupt Vector channel 11 ARINC 429 Interrupt Vector channel 12 ARINC 429 Interrupt Vector channel 13 ARINC 429 Interrupt Vector channel 14 ARINC 429 Interrupt Vector channel 15 RXC0 RXC1 RXC2 RXC3 RXC4 RXC5 RXC6 RXC7 RXC8 RXC9 RXC10 RXC11 RXC12 RXC13 RXC14 RXC15 Configures ARINC 429 receive channel 0 Configures ARINC 429 receive channel 1 Configures ARINC 429 receive channel 2 Configures ARINC 429 receive channel 3 Configures ARINC 429 receive channel 4 Configures ARINC 429 receive channel 5 Configures ARINC 429 receive channel 6 Configures ARINC 429 receive channel 7 Configures ARINC 429 receive channel 8 Configures ARINC 429 receive channel 9 Configures ARINC 429 receive channel 10 Configures ARINC 429 receive channel 11 Configures ARINC 429 receive channel 12 Configures ARINC 429 receive channel 13 Configures ARINC 429 receive channel 14 Configures ARINC 429 receive channel 15 * Register is cleared when read (auto clear) HOLT INTEGRATED CIRCUITS 12 HI-3220 ADDRESS R/W 0x8030 0x8031 0x8032 0x8033 0x8034 0x8035 0x8036 0x8037 0x8038 0x8039 0x803A 0x803B 0x803C 0x803D 0x803E 0x803F 0x8040 0x8041 0x8042 0x8043 0x8044 0x8045 0x8046 0x8047 0x8048 0x8049 0x804A 0x804B 0x804C 0x804D 0x804E 0x804F 0x8050 0x8051 0x8052 0x8053 0x8054 0x8055 0x8056 0x8057 0x8058 0x8059 0x805A 0x805B 0x805C 0x805D 0x805E 0x805F REGISTER R/W TRANSMIT CONTROL REGISTER 0 R/W TRANSMIT CONTROL REGISTER 1 R/W TRANSMIT CONTROL REGISTER 2 R/W TRANSMIT CONTROL REGISTER 3 R/W TRANSMIT CONTROL REGISTER 4 R/W TRANSMIT CONTROL REGISTER 5 R/W TRANSMIT CONTROL REGISTER 6 R/W TRANSMIT CONTROL REGISTER 7 R/W TRANSMIT REPETITION RATE 0 R/W TRANSMIT REPETITION RATE 1 R/W TRANSMIT REPETITION RATE 2 R/W TRANSMIT REPETITION RATE 3 R/W TRANSMIT REPETITION RATE 4 R/W TRANSMIT REPETITION RATE 5 R/W TRANSMIT REPETITION RATE 6 R/W TRANSMIT REPETITION RATE 7 R TRANSMIT SEQUENCE POINTER 0 R TRANSMIT SEQUENCE POINTER 1 R TRANSMIT SEQUENCE POINTER 2 R TRANSMIT SEQUENCE POINTER 3 R TRANSMIT SEQUENCE POINTER 4 R TRANSMIT SEQUENCE POINTER 5 R TRANSMIT SEQUENCE POINTER 6 R TRANSMIT SEQUENCE POINTER 7 R Not used R/W LOOPBACK R/W PENDING INTERRUPT ENABLE REGISTER R/W RECEIVE INTERRUPT ENABLE (LOW) R/W RECEIVE INTERRUPT ENABLE (HIGH) R/W RECEIVE FIFO INTERRUPT ENABLE (LOW) R/W RECEIVE FIFO INTERRUPT ENABLE (HIGH) R/W TRANSMIT FIFO INTERRUPT ENABLE R/W RECEIVE FIFO THRESHOLD VALUE 0 R/W RECEIVE FIFO THRESHOLD VALUE 1 R/W RECEIVE FIFO THRESHOLD VALUE 2 R/W RECEIVE FIFO THRESHOLD VALUE 3 R/W RECEIVE FIFO THRESHOLD VALUE 4 R/W RECEIVE FIFO THRESHOLD VALUE 5 R/W RECEIVE FIFO THRESHOLD VALUE 6 R/W RECEIVE FIFO THRESHOLD VALUE 7 R/W RECEIVE FIFO THRESHOLD VALUE 8 R/W RECEIVE FIFO THRESHOLD VALUE 9 R/W RECEIVE FIFO THRESHOLD VALUE 10 R/W RECEIVE FIFO THRESHOLD VALUE 11 R/W RECEIVE FIFO THRESHOLD VALUE 12 R/W RECEIVE FIFO THRESHOLD VALUE 13 R/W RECEIVE FIFO THRESHOLD VALUE 14 R/W RECEIVE FIFO THRESHOLD VALUE 15 MNEMONIC DESCRIPTION TXC0 TXC1 TXC2 TXC3 TXC4 TXC5 TXC6 TXC7 TXRR0 TXRR1 TXRR2 TXRR3 TXRR4 TXRR5 TXRR6 TXRR7 TXSP0 TXSP1 TXSP2 TXSP3 TXSP4 TXSP5 TXSP6 TXSP7 Configures ARINC 429 transmit channel 0 Configures ARINC 429 transmit channel 1 Configures ARINC 429 transmit channel 2 Configures ARINC 429 transmit channel 3 Configures ARINC 429 transmit channel 4 Configures ARINC 429 transmit channel 5 Configures ARINC 429 transmit channel 6 Configures ARINC 429 transmit channel 7 Sets sequence repeat time for ARINC 429 TX0 Sets sequence repeat time for ARINC 429 TX1 Sets sequence repeat time for ARINC 429 TX2 Sets sequence repeat time for ARINC 429 Tx3 Sets sequence repeat time for ARINC 429 Tx4 Sets sequence repeat time for ARINC 429 Tx5 Sets sequence repeat time for ARINC 429 Tx6 Sets sequence repeat time for ARINC 429 Tx7 Current address of ARINC transmit sequence 0 Current address of ARINC transmit sequence 1 Current address of ARINC transmit sequence 2 Current address of ARINC transmit sequence 3 Current address of ARINC transmit sequence 4 Current address of ARINC transmit sequence 5 Current address of ARINC transmit sequence 6 Current address of ARINC transmit sequence 7 LOOP PIER RIEL RIEH FIEL FIEH TFIE FTV0 FTV1 FTV2 FTV3 FTV4 FTV5 FTV6 FTV7 FTV8 FTV9 FTV10 FTV11 FTV12 FTV13 FTV14 FTV15 Sets Loopback channels Enables Interrupts on INT pin Enables Interrupts (channels 7-0) Enables Interrupts (channels 15-8) Enables Receive Interrupts (channels 7-0) Enables Receive Interrupts (channels 15-8) Enables Transmit Interrupts Sets flag value for ARINC 429 Receive FIFO 0 Sets flag value for ARINC 429 Receive FIFO 1 Sets flag value for ARINC 429 Receive FIFO 2 Sets flag value for ARINC 429 Receive FIFO 3 Sets flag value for ARINC 429 Receive FIFO 4 Sets flag value for ARINC 429 Receive FIFO 5 Sets flag value for ARINC 429 Receive FIFO 6 Sets flag value for ARINC 429 Receive FIFO 7 Sets flag value for ARINC 429 Receive FIFO 8 Sets flag value for ARINC 429 Receive FIFO 9 Sets flag value for ARINC 429 Receive FIFO 10 Sets flag value for ARINC 429 Receive FIFO 11 Sets flag value for ARINC 429 Receive FIFO 12 Sets flag value for ARINC 429 Receive FIFO 13 Sets flag value for ARINC 429 Receive FIFO 14 Sets flag value for ARINC 429 Receive FIFO 15 HOLT INTEGRATED CIRCUITS 13 HI-3220 ADDRESS R/W REGISTER MNEMONIC DESCRIPTION 0x8060 0x8061 0x8062 0x8063 0x8064 0x8065 0x8066 0x8067 0x8068 0x8069 0x806A 0x806B 0x806C 0x806D 0x806E 0x806F 0x8070 0x8071 0x8072 0x8073 0x8074 0x8075 0x8076 0x8077 0x8078 0x8079 0x807A R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R R R TRANSMIT FIFO THRESHOLD VALUE 0 TRANSMIT FIFO THRESHOLD VALUE 1 TRANSMIT FIFO THRESHOLD VALUE 2 TRANSMIT FIFO THRESHOLD VALUE 3 TRANSMIT FIFO THRESHOLD VALUE 4 TRANSMIT FIFO THRESHOLD VALUE 5 TRANSMIT FIFO THRESHOLD VALUE 6 TRANSMIT FIFO THRESHOLD VALUE 7 RX FIFO COUNT 0 RX FIFO COUNT 1 RX FIFO COUNT 2 RX FIFO COUNT 3 RX FIFO COUNT 4 RX FIFO COUNT 5 RX FIFO COUNT 6 RX FIFO COUNT 7 RX FIFO COUNT 8 RX FIFO COUNT 9 RX FIFO COUNT 10 RX FIFO COUNT 11 RX FIFO COUNT 12 RX FIFO COUNT 13 RX FIFO COUNT 14 RX FIFO COUNT 15 BIST CONTROL/STATUS BIST FAIL ADDRESS [7:0] BIST FAIL ADDRESS [15:8] TFTV0 TFTV1 TFTV2 TFTV3 TFTV4 TFTV5 TFTV6 TFTV7 RFC0 RFC1 RFC2 RFC3 RFC4 RFC5 RFC6 RFC7 RFC8 RFC9 RFC10 RFC11 RFC12 RFC13 RFC14 RFC15 BISTS BISTFL BISTFH 0x807B 0x807C 0x807D 0x807E 0x 807F 0x8080 0x8081 0x8082 0x8083 0x8084 0x8085 0x8086 0x8087 R R R R/W R/W R R R R R R R R AUTO-INIT FAIL LS ADDRESS [7:0] AUTO-INIT FAIL MS ADDRESS [15:8] Not used WATCHDOG CHANNEL MASK [7:0] WATCHDOG TIMER REGISTER [7:0] TX FIFO COUNT 0 TX FIFO COUNT 1 TX FIFO COUNT 2 TX FIFO COUNT 3 TX FIFO COUNT 4 TX FIFO COUNT 5 TX FIFO COUNT 6 TX FIFO COUNT 7 AIFL AIFH Sets flag value for ARINC 429 Transmit FIFO 0 Sets flag value for ARINC 429 Transmit FIFO 1 Sets flag value for ARINC 429 Transmit FIFO 2 Sets flag value for ARINC 429 Transmit FIFO 3 Sets flag value for ARINC 429 Transmit FIFO 4 Sets flag value for ARINC 429 Transmit FIFO 5 Sets flag value for ARINC 429 Transmit FIFO 6 Sets flag value for ARINC 429 Transmit FIFO 7 Current FIFO message count Receiver 0 Current FIFO message count Receiver 1 Current FIFO message count Receiver 2 Current FIFO message count Receiver 3 Current FIFO message count Receiver 4 Current FIFO message count Receiver 5 Current FIFO message count Receiver 6 Current FIFO message count Receiver 7 Current FIFO message count Receiver 8 Current FIFO message count Receiver 9 Current FIFO message count Receiver 10 Current FIFO message count Receiver 11 Current FIFO message count Receiver 12 Current FIFO message count Receiver 13 Current FIFO message count Receiver 14 Current FIFO message count Receiver 15 Built-In Self-Test Low-order failing BIST memory address High-order failing BIST memory address and Mode bits Auto-initialization fail address (low-byte) Auto-initialization fail address (high byte) WCM WTR TFC0 TFC1 TFC2 TFC3 TFC4 TFC5 TFC6 TFC7 1=masked, 0=active Defines watchdog time-out period Current FIFO message count Transmitter 0 Current FIFO message count Transmitter 1 Current FIFO message count Transmitter 2 Current FIFO message count Transmitter 3 Current FIFO message count Transmitter 4 Current FIFO message count Transmitter 5 Current FIFO message count Transmitter 6 Current FIFO message count Transmitter 7 HOLT INTEGRATED CIRCUITS 14 HI-3220 HI-3220 SYSTEM CONFIGURATION Starting at memory address 0x8000, the HI-3220 contains a set of registers that are used to configure the device. The configuration registers are divided into three categories, as follows; 1. HI-3220 global configuration 2. ARINC 429 Receive channel configuration 3. ARINC 429 Transmit channel configuration The user needs only to program the HI-3220 configuration registers to completely define the full system operation. HI-3220 Global Configuration A4 AF 29 A4 RX 29 TX LI TX P M TX SK 7O TX PT D L2 56 The following registers define the HI-3220 top-level configuration: MASTER CONTROL REGISTER (Address 0x8000 - read/write, 0x8001 - read) 7 6 MSB X X 5 4 3 2 1 0 LSB Bit Name R/W Default Description 7 A429RX R/W 0 This bit must be set to a “1” to allow the HI-3220 to receive ARINC 429 data on any of the sixteen ARINC 429 receive channels. If set to a zero, the HI-3220 will not respond to any ARINC 429 receive bus, regardless of the state of the ARINC 429 Receive channel Control Registers. 6 A429TX R/W 0 This bit must be set to a “1” to allow the HI-3220 to transmit ARINC 429 data on any of the eight channels. If set to a zero, the HI-3220 will not output ARINC 429 data and the ARINC 429 transmit sequencers will remain in their reset state. Completes the current TX message* before entering the reset state. 5 - R/W 0 Not Used 4 - R/W 0 Not Used 3 AFLIP R/W 0 When set to a “1”, this bit switches the bit order of the ARINC 429 label byte in both receive and transmit channels. (See ARINC 429 Bit Ordering section) 2 TXMSK R/W 0 When set to a “1”, this bit prevents the external transmission of self-test loop-back data for any transmitter when set to loopback mode. 1 TX7OPT R/W 0 Defines the meaning of Receive Status bit 7 in every ARINC 429 receive data block. When TX7OPT = “1”, Status bit 7 is NEWHOST. When TX7OPT =”0”, Status bit 7 is NEWTX7. See ARINC receive data block description for details. 0 TXDL256 R/W 0 When TXDL256 is “0” transmitter 0 and transmitter 1 descriptor length is 128. When TXDL256 is “1” transmitter 0 and transmitter 1 descriptor length is 256. * A message is defined as one ARINC 429 32-bit message. A frame is defined as multiple messages programmed in a Transmit scheduler. HOLT INTEGRATED CIRCUITS 15 HI-3220 HI-3220 Operational Status Information R EA AC DY T SA IVE F R E AM PR BU O S AU GC Y TO Y IN IT The Master Status Register may be read at any time to determine the current operational state of the HI-3220: X MASTER STATUS REGISTER (Address 0x8002) Bit Name 7 - R/W R X 7 6 MSB 5 4 3 2 1 0 LSB Default Description 0 Not used 6 - R 0 Not Used 5 READY R 0 This bit is high, when the READY output pin is high, indicating that the part is able to accept and respond to host CPU SPI commands 4 ACTIVE R 0 This bit is high after the RUN pin is asserted and the HI-3220 is in normal operating mode. 3 SAFE R 0 This bit goes high when the part enters safe mode as a result of a Built-in Self-test fail or autoinitialization fail. 2 RAM BUSY R 0 This is high during the time the RAM Integrity Check is running and RAM is clearing 1 PROGCY R 0 Indicates that the HI-3220 is currently in the EEPROM programming cycle. Note that READY stays low until the cycle is complete. 0 AUTOINIT R 0 The HI-3220 is currently loading internal memory, registers and look-up tables from the Autoinitialization EEPROM HOLT INTEGRATED CIRCUITS 16 HI-3220 ARINC 429 RECEIVE OPERATION The HI-3220 can receive ARINC 429 messages from up to sixteen ARINC 429 receive buses. Analog line receivers are included on-chip for HI-3220, HI-3221 and HI-3222. Each receiver input line requires only an external 40 kOhm resistor to meet lightning protection DO-160 level 3. The HI-3225 and HI-3226 have digital receiver inputs and are used with off-chip ARINC 429 line receivers. ARINC 429 Receive Channel Configuration RECEIVE CONTROL REGISTER 0 - 15 (Address 0x8020 - 0x802F) PA R D ITY EC E N SD OD 10 ER SD 9 R AT 50 E KO PT EN AB LE Each of the sixteen possible ARINC 429 Receive channels is configured using its own Control Register. Register address 0x8020 controls ARINC 429 Receive channel #0, register address 0x8021 controls channel #1 and so on. X 7 6 MSB 5 4 3 2 1 0 LSB Bit Name R/W Default Description 7 ENABLE R/W 0 This bit must be set to a “1” to enable ARINC 429 data reception on this channel. 6 - R/W 0 Not used 5 PARITYEN R/W 0 When this bit is a one, the 32nd received ARINC bit is overwritten with a parity flag. The flag bit is set to a zero when the received ARINC word, including its parity bit has an odd number of ones. When PARITYEN is a zero, all 32-bits are received without parity checking. 4 DECODER R/W 0 When DECODER is a “1”, bits 9 and 10 of ARINC 429 words received on this channel must match the SD9 and SD10 bits in the register. ARINC words received that do not match the SD conditions are ignored. 3 SD10 R/W 0 If DECODER is set to a “1”, then this bit must match the received ARINC word bit 10 for the word to be accepted. 2 SD9 R/W 0 If DECODER is set to a “1”, then this bit must match the received ARINC word bit 9 for the word to be accepted. 1 RATE R/W 0 Selects the ARINC 429 bit rate for the ARINC 429 receive channel. A “0” selects high-speed (100Kb/s) and a “1” selects low-speed (12.5Kb/s). (See 50KOPT bit for non-standard 50kb/s high-speed operation) 0 50KOPT R/W 0 When set to a “1”, the RATE bit is ignored and ARINC 429 data rate is set to 50 Kb/s HOLT INTEGRATED CIRCUITS 17 HI-3220 ARINC 429 Received Data Management The HI-3220 supports up to sixteen ARINC 429 receive buses using on-chip receivers to handle the protocol validation. The sixteen Receive Control Registers, RXC0 15, define the characteristics of each receive channel. Enable Register, the INT output pin is asserted. The label number of the ARINC 429 message causing the interrupt is loaded into that channel’s Receive Interrupt Address Register (IAR0 - IAR15). The ARINC 429 receive function of the HI-3220 is activated by setting the A429RX bit in the Master Control Register. Because the ARINC Receive Memory is organized by label value, it is not necessary to store the received label value (first eight bits of the ARINC message) in the memory. Instead, the first byte is used to store a status byte. When an ARINC 429 message is received by the HI-3220 on any bus, it is checked for protocol compliance. Messages with incorrect encoding are rejected. NOTE: Messages with incorrect parity will be stored. The HI-3220 allocates 16K bytes of on-chip memory for storing ARINC 429 received data. The memory is organized by channel number and ARINC 429 label value. Four bytes of memory are dedicated to each channel / label to store the 32-bit ARINC 429 message. A look-up table is used to enable an interrupt on receipt of a new ARINC 429 message. Look-up table bit positions preloaded by the user with a “1” will cause an Interrupt to be generated. When a message is received that triggers an Interrupt, that channel’s Interrupt bit is set in the Receive Pending Interrupt Register. If this bit is set in the Receive Interrupt The eight active bits of the status byte are set to “1” when a new ARINC word is stored in the memory. These bits flag the ARINC word as new when the location is interrogated by the host CPU or any of the seven ARINC 429 transmit schedulers. (Note: Transmitter 7 operates differently from the other 7 transmitters. The corresponding “New” bit in the receive status word may be selected between new data for Tx7 or new data for Host CPU as defined by the global TX7OPT bit in the Master control Register.) The ARINC 429 Receive memory is not filtered so messages will load unconditionally when received if the channel is enabled in the Receive Control Register. Message blocks are single buffered so the host should read the message before a potential overwrite. ARINC 429 Received Data Memory Organization 0x3FFF Block 4096 Channel 15, Label FF 0x3FFC “ “ 0x0400 Block 256 Channel 0, Label FF 0x03FC “ “ 0x000B Block 3 Channel 0, Label 02 0x0008 0x0007 Block 2 Channel 0, Label 01 0x0003 ARINC data byte 4 0x0002 ARINC data byte 3 Block 1 Channel 0, Label 00 0x0001 ARINC data byte 2 0x0000 Status Byte 0x0004 0x0003 0x0000 Etc. HOLT INTEGRATED CIRCUITS 18 HI-3220 ARINC 429 Received Data Interrupt Look-Up Table 0x6BFF 0x6BE0 0x6A3F 0x6A20 0x6A1F 0x6A00 Label = 0xF8 Label = 0xFF Interrupt Look-Up Table Channel 15 Label = 0x08 Interrupt Look-Up Table Channel 1 Label = 0x0F Interrupt Look-Up Table Channel 0 7 6 5 4 3 2 1 0 Label = 0x00 Label = 0x07 Label = 0x01 N N EW H EW OS N TX T/T EW 6 X 7 N TX EW 5 N TX EW 4 N TX EW 3 N TX EW 2 N TX EW 1 TX 0 ARINC 429 Received Data Status Byte Definition STATUS BYTE 7 6 MSB Bit Name 5 4 3 2 1 0 LSB R/W Default Description 7 NEWHOST/TX7 R/W 0 The meaning of this bit depends upon the setting of TX7OPT bit in the Master Control Register: When TX7OPT is a ‘”1”, this bit is set when a new ARINC 429 word is received and stored in this block. It is reset when the host CPU executes SPI instruction 0xC8 or 0xD0 to read the block. When TX7OPT is a “0”, this bit is set when a new ARINC 429 word is received and stored in this block. It is reset when the ARINC 429 Transmit scheduler #7 reads any bytes from the block. 6 NEWTX6 R/W 0 This bit is set when a new ARINC 429 word is received and stored in this block. It is reset when the ARINC 429 Transmit scheduler #6 reads any bytes from the block. 5 NEWTX5 R/W 0 This bit is set when a new ARINC 429 word is received and stored in this block. It is reset when the ARINC 429 Transmit scheduler #5 reads any bytes from the block. 4 NEWTX4 R/W 0 This bit is set when a new ARINC 429 word is received and stored in this block. It is reset when the ARINC 429 Transmit scheduler #4 reads any bytes from the block. 3 NEWTX3 R/W 0 This bit is set when a new ARINC 429 word is received and stored in this block. It is reset when the ARINC 429 Transmit scheduler #3 reads any bytes from the block. 2 NEWTX2 R/W 0 This bit is set when a new ARINC 429 word is received and stored in this block. It is reset when theARINC 429 Transmit scheduler #2 reads any bytes from the block. 1 NEWTX1 R/W 0 This bit is set when a new ARINC 429 word is received and stored in this block. It is reset when theARINC 429 Transmit scheduler #1 reads any bytes from the block. 0 NEWTX0 R/W 0 This bit is set when a new ARINC 429 word is received and stored in this block. It is reset when the ARINC 429 Transmit scheduler #0 reads any bytes from the block. HOLT INTEGRATED CIRCUITS 19 HI-3220 ARINC 429 Received Data Log FIFO Sixteen FIFOs that are each 64 messages deep. The FIFOs are empty following reset. All three status registers are cleared. For each channel, a user-defined RECEIVE FIFO THRESHOLD VALUE register defines the point where the RECEIVE FIFO THRESHOLD FLAG bit is set. That occurs when the number of words in the FIFO exceed the threshold value. Once a FIFO is full, (i.e. contains 64 messages), a received message will be written to the FIFO and the oldest message lost, maintaining a FIFO full count of 64. A 4K x 8 block of memory located between 0x7000 and 0x7FFF is reserved for a set of sixteen ARINC 429 received data FIFOs. There is one FIFO for each ARINC 429 received data channel. Each FIFO can hold up to 64 ARINC 429 32-bit messages. A look-up table driven filter defines which ARINC 429 messages are stored in each FIFO. The look-up table is initialized by the user with a “1” for each bit position corresponding to a selected channel / label combination. The look-up table is located at memory address 0x6800. The user may generate an Interrupt by enabling one the FIFO status register bits to assert the FLAG bit in the Pending Interrupt Register. Receive Control Register bit 6 enables the triggering of the FLAG interrupt. When a new ARINC 429 message is received that meets the programmed conditions for acceptance (Enable lookup table bit = “1”), it is written into the channel’s Receive Data FIFO. The contents of the FIFO may be read by the host CPU using dedicated FIFO read SPI Instructions. The FIFO feature is particularly useful if the application wishes to accumulate sequential ARINC 429 messages of the same label value before reading them. The regular ARINC 429 receive data memory will, of course, overwrite messages of the same label value if a new message is received before the host CPU extracts the data. The status of each channel’s FIFOs is monitored by a FIFO status register: RECEIVE FIFO THRESHOLD FLAG. Each bit of the register reflects the current status of each FIFO. ARINC 429 Received FIFO Data Enable Look-Up Table 0x69FF 0x69E0 0x683F 0x6820 0x681F 0x6800 Label = 0xF8 Label = 0xFF Filter Look-Up Table Channel 15 Label = 0x08 Filter-Look-Up Table Channel 1 Label = 0x0F Filter Look-Up Table Channel 0 7 6 5 4 3 2 1 0 Label = 0x00 Label = 0x07 Label = 0x01 ARINC 429 received message Message 1 (32-bits) Message 2 (32-bits) ARINC 429 Received Data FIFO (x16) Data read by Host CPU SPI Instruction FIFO THRESHOLD FTFn FLAGn Select FFSOn From Other 15 Channels 0 - 64 Messages (32-bits) HOLT INTEGRATED CIRCUITS 20 } OR PIR FLAG HI-3220 Bit Name 15:0 FTF[15:0] R/W R FT F7 FT F6 FT F FT 5 F4 FT F3 FT F2 FT F1 FT F0 RECEIVE FIFO THRESHOLD REGISTER HIGH / LOW (Address 0x800E, 0x800D) FT F1 FT 5 F1 FT 4 F FT 13 F1 FT 2 F1 FT 1 F1 FT 0 F9 FT F8 ARINC 429 Received Data FIFO Registers 7 6 MSB 7 6 MSB 5 4 3 2 1 0 LSB 5 4 3 2 1 0 LSB Default Description 0 Bits are set to “1” if the corresponding channel’s receive FIFO contains > threshold number of ARINC 429 messages. Receive FIFO Threshold Value Registers Each Receiver has its own Receive FIFO Threshold Register Threshold FIFO THRESHOLD VALUE n (Address 0x8050 - 0x805F) Threshold Value Default = 0x00 0 7 6 MSB 5 4 3 2 1 0 LSB Description 0000000 Threshold flag is set if at least 1 message is in FIFO (FIFO is not empty) - Default 0000001 Threshold flag is set if more than one message is in the FIFO 0000010 Threshold flag is set if more than two messages are in the FIFO 0000011 Threshold flag is set if more than three messages are in the FIFO 0010000 Threshold flag is set if more than sixteen messages are in the FIFO 1111111 Threshold flag is set if 64 messages are in the FIFO (FIFO is full) 5 4 3 2 E6 FI E7 E2 FO E FI 1 E0 0 LSB E3 1 FI 2 E4 3 FI 4 E5 5 FI 7 6 MSB FI RECEIVE FIFO THRESHOLD REGISTER HIGH / LOW (Address 0x804E, 0x804D) FI FI E1 FI 5 E1 FI 4 E1 FI 3 E1 FI 2 E1 FI 1 E1 FI 0 E9 FI E8 Receive FIFO Interrupt Enable 7 6 MSB 1 Bit Name R/W Default Description 15:0 FIE[15:0] R/W 0 Interrupts are enabled for receive channels where the corresponding bit is set. Receive FIFO Count Registers RECEIVE FIFO COUNT(0-15) (Address 0x8068 - 0x8077) Count Default = 0x00 0 7 6 MSB 5 4 3 2 1 0 LSB Bit Name R/W Default Description 7:0 RFCn[7:0] R/W 0 Reads number of words held in Receive FIFO FIFOs may be emptied by writing 0xA5 to this register. HOLT INTEGRATED CIRCUITS 21 0 LSB HI-3220 ARINC 429 Loop-back Self-Test The HI-3220 includes an ARINC 429 loop-back feature, which allows users to exercise the ARINC 429 transmit and receive channels for self-test purposes. The ARINC 429 Loop-Back register, LOOP, defines which receiver channels are in loop-back mode. When a “1” is programmed in the LOOP bit position for a receiver pair, then their ARINC 429 bus connection to the external pins is broken and instead the input is connected to one of the eight ARINC 429 transmit channels. Transmit channel 0 is connected to receive channels 0 and 1, transmit channel 1 is connected to receive channels 2 and 3, and so on. LO O LO P7 O LO P6 O LO P5 O LO P4 O LO P3 O LO P2 O LO P1 O P0 When in loop-back mode, incoming ARINC 429 messages are ignored by the HI-3220. When running in loop-back mode the ARINC 429 transmit pins may be disabled by setting the TXMSK bit high in the Master Control Register. This prevents test messages from being output to the external ARINC 429 transmit buses. SELF-TEST LOOPBACK (Address 0x8049) 7 6 MSB 5 4 3 2 1 0 LSB Bit Name R/W Default Description 7 LOOP7 R/W 0 This bit is set to “1” to loop-back transmit channel 7 to receivers 14 and 15 6 LOOP6 R/W 0 This bit is set to “1” to loop-back transmit channel 6 to receivers 12 and 13 5 LOOP5 R/W 0 This bit is set to “1” to loop-back transmit channel 5 to receivers 10 and 11 4 LOOP4 R/W 0 This bit is set to “1” to loop-back transmit channel 4 to receivers 8 and 9 3 LOOP3 R/W 0 This bit is set to “1” to loop-back transmit channel 3 to receivers 6 and 7 2 LOOP2 R/W 0 This bit is set to “1” to loop-back transmit channel 2 to receivers 4 and 5 1 LOOP1 R/W 0 This bit is set to “1” to loop-back transmit channel 1 to receivers 2 and 3 0 LOOP0 R/W 0 This bit is set to “1” to loop-back transmit channel 0 to receivers 0 and 1 HOLT INTEGRATED CIRCUITS 22 HI-3220 ARINC 429 Bit ordering ARINC 429 messages consist of a 32-bit sequence as shown below. The first eight bits that appear on the ARINC 429 bus are the label byte. The next twenty three bits comprise a data field which presents data in a variety of formats defined in the ARINC 429 specification. The last bit transmitted is an odd parity bit. The ARINC 429 specifies the MSB of the label as ARINC bit 1. Conversely, the data field MSB is bit 31. So the bit significance of the label byte and data fields are opposite. The HI-3220 may be programmed to “flip” the bit ordering of the label byte as soon as it is received and immediately prior to transmission. This is accomplished by setting the FLIP bit to a “1” in the Master Control Register. Note that once the label byte has been flipped, the HI-3220 handles the flipped data byte “post-flip” for the purpose of label interrupt matching, filtering and storage. The HI-3220 stores the received message as four bytes. The bytes are stored in memory in little-endian order. That is to say, the label byte (or status byte) is stored at the lowest memory address, the byte representing received bits 9 through 16 is stored at the next address, the byte representing bits 17 through 24 at the next address and the byte representing bits 25 though 32 at the highest address. ARINC 429 Message as received / transmitted on the ARINC 429 serial bus 1 2 3 4 5 6 7 9 10 11 12 13 14 15 16 8 17 18 19 20 21 22 23 24 ARINC 429 Message as stored in HI-3220 memory Byte 3 32 31 30 29 28 27 26 25 32 31 30 29 28 27 26 25 Byte 2 24 23 22 21 20 19 18 17 24 23 22 21 20 19 18 17 Byte 1 16 15 14 13 12 11 10 9 16 15 14 13 12 11 10 9 1 2 3 4 5 FLIP = “0” 6 IT 25 26 27 28 29 30 31 32 time Byte 0 Y MSB DATA SD SD I LSB PA R LSB LABEL I MSB 7 8 8 7 6 5 4 3 FLIP = “1” HOLT INTEGRATED CIRCUITS 23 2 1 HI-3220 ARINC 429 TRANSMIT OPERATION The HI-3220 has up to eight on-board ARINC 429 transmit channels which directly drive ARINC 429 differential line drivers such as the Holt HI-8596. ARINC 429 words may be written to the transmitters either directly, using an SPI instruction through a transmit FIFO, or be generated automatically using the eight ARINC 429 message schedulers. ARINC 429 Transmit Channel Configuration R U N PR / S E TO PA SC P R AL EV ITY E E /D SK N / AT IP OD A D TR IS R TA AT T E 50 E KO PT Each of the eight available ARINC 429 Transmit channels is configured using its own register. Register address 0x8030 controls ARINC 429 Transmit channel #0, register address 0x8031 controls channel #1 and so on. The TXCn registers may be written or read at any time. TRANSMIT CONTROL REGISTER 0 - 7 (Address 0x8030 - 0x8037) 7 6 MSB 5 4 3 2 1 0 LSB Bit Name R/W Default Description 7 RUN / STOP R/W 0 When zero, transmission from this ARINC 429 transmit channel is suspended after the currently transmitting frame of messages is sent. When this bit is taken high, transmission starts at the beginning of the descriptor table for this channel. The RUN bit can be used for onetime frame transmission (see page 25). 6 PRESCALE R/W 0 This bit sets the LSB value for this transmit channel’s Repetition Rate Counter. A “0” set the LSB value to 10 ms, and a “1” selects 1 ms. 5 PARITY / DATA R/W 0 When this bit is a one, the 32nd transmitted ARINC bit is overwritten with a parity flag. When this bit is a zero, all 32-bits are transmitted as data. 4 EVEN / ODD R/W 0 When PARITY / DATA is a “1”, this bit defines whether th 32nd transmitted bit is set for Even or Odd Parity. A “1” selects even parity and a “0” selects odd parity. 3 SKIP R/W 0 When set to a “1”, instructs the transmit sequencer to wait for the next Repetition Rate Counter rollover before beginning a new transmission cycle. A “0” causes an immediate restart of the cycle following completion of the prior cycle. 2 TRISTATE R/W 0 When set to a “1” the TXP and TXN output pins for this transmit channel are both forced to a high state. When used with an ARINC 429 line driver that supports tri-state operation, such as the Holt HI-8596, the ARINC 429 databus is forced to a high-impedance state. No ARINC 429 transmission from the HI-3220 occurs when TRISTATE is set. 1 RATE R/W 0 Selects the transmission rate for the ARINC 429 transmit channel. A “0” selects high-speed (100Kb/s) and a “1” selects low-speed (12.5Kb/s). High-speed data-rate is switched to 50Kb/s when the 50KOPT bit is set. 0 50KOPT R/W 0 When this bit is set, the RATE setting is overridden and the ARINC 429 data rate defaults to 50 kb/s SLP[0-7] Pins The HI-3220, HI-3223 and HI-3225 device configurations have a digital output for each transmit channel that may be used to set the slew rate on an external line driver. The SLPx output for a given channel should be connected to the SLP input on an external line driver such as Holt’s HI-8596 or HI-8597. The SLP output slew rate depends on the values of the RATE and 50KOPT bits as follows: RATE 0 0 1 1 50KOPT 0 1 0 1 SLPx 1 1 0 1 Bit Rate 100 Kb/s (ARINC 429 High-Speed) 50 Kb/s 12.5 Kb/s (ARINC 429 Low-Speed) 50 Kb/s HOLT INTEGRATED CIRCUITS 24 HI-3220 ARINC 429 Transmit Scheduler Each ARINC 429 transmit channel 0 through 7 has its own transmit controller. The controller is userprogrammed to output ARINC labels in a predefined order and repetition rate. A sequence of up to 128 ARINC 429 labels may be transmitted before repeating the sequence. A descriptor table with up to 128 entries (descriptors) is compiled by the user to define the sequence of ARINC 429 messages transmitted on each channel. When the RUN/STOP bit in the Transmit Control Register is asserted, the controller compiles the first 32-bit ARINC word from the instructions given by the first descriptor and then transmits it. A Transmit Sequence Pointer then increments to the next descriptor in the table and the process is repeated for Descriptor number 2. ARINC 429 messages continue to be compiled and transmitted until the last descriptor in the table. The end of the table is marked by a special descriptor if not all 128 entries are needed. The Sequence Pointer is then reset to zero. A Repetition Rate Counter is used to time the start of the next transmission cycle. The user is responsible for construction of the descriptor table and for setting the Repetition Rate prior to asserting RUN/STOP. Facilities exist for immediate cycle repetition and for single-cycle operation. The byte content of each ARINC 429 message transmitted is user defined by the descriptor contents. Data bytes may be sourced from the host CPU / autoinitialization EEPROM (immediate data) or from the ARINC 429 receive memory (indexed). This allows received ARINC data to be re-transmitted on another bus with or without filtering, label byte re-assignment, or data modification. It also allows data from multiple ARINC 429 receive buses to be re-packetized into new ARINC 429 transmitted messages. Conditional transmission control allows sequenced words to be skipped if no new data is available. Each transmit channel is independently configured with its own Transmit Control Register, TXCR0-7, as previously described. During scheduler transmissions de-asserting the RUN bit in the Transmit Control register will stop transmissions after the current frame. To immediately stop after the current message transmission, either de-assert the A429TX bit in the Master Control register or set the RUN input pin low. Keep in mind that setting the RUN input pin low will stop all transmitters after the current message completes. Transmit Descriptor table Sequence pointer 0x7F 0x43FF 0x43F8 0x43F0 Sequence 127 Descriptor Frame (Maximum sequence is 256 when TXDL256 is set in MCR) Sequence 126 Descriptor Frame Repetion Rate Register Byte 8 (TX Data 3) 0x4028 Repetition rate counter 0x4020 (Memory Addresses shown for Transmit channel 0) 0x4018 0x4010 Sequence pointer Sequence pointer 0x01 0x4008 0x00 0x4000 Sequence 5 Descriptor Frame Byte 7 (TX Data 2) Sequence 4 Descriptor Frame Byte 6 (TX Data 1 / SDI) Sequence 3 Descriptor Frame Byte 5 (TX Label) Sequence 2 Descriptor Frame Byte 4 (Packet Timer Offset) Sequence 1 Descriptor Frame Byte 3 (Packet Timer Period) Sequence 0 Descriptor Frame Byte 2 (Rx Label) Byte 1 (op-code, RX select) The value of each ARINC 429 label transmitted in the sequence is defined by its eight-byte descriptor. The first two bytes define the source of data for transmission. The next two bytes define transmission timing parameters. The last four bytes contain data to be transmitted as defined by the op-code. Different op-codes allow the data source to be host CPU populated values, or values from specific locations within the ARINC 429 receive memory. The construction of Descriptor frame bytes are described in the next section. HOLT INTEGRATED CIRCUITS 25 HI-3220 Current Sequence number TRANSMIT SEQUENCE POINTERS 0 - 7 (Address 0x8040 - 0x8047) 7 6 MSB 5 4 3 The transmit sequence pointer is set to zero on Master Reset. Once the Control Register RUN / STOP bit goes high, sequence execution begins at sequence count zero. After the first word is sent, the pointer is incremented by one descriptor (counts descriptor frames). 2 1 0 LSB This continues until the programmed sequence is complete. The sequence pointer is then reset to the beginning of the descriptor table and program execution begins as soon as the channel repetition rate counter time elapses. Channel Repetition Period REPETITION RATE REGISTER 0 - 7 (Address 0x8038 - 0x803F) 7 6 MSB 5 The Repetition rate register value defines the time interval between successive starts of the programmed transmit sequence for each ARINC 429 transmit channel. The value is set in binary, with the LSB representing 10 ms when the PRESCALE bit in this channel’s Transmit Control Register is a zero. When the PRESCALE bit is set to a one, the LSB represents 1 ms. Repetition rate time periods may therefore be set from 0 ms to 2.55 seconds 4 3 2 1 0 LSB One-time Sequence Transmission To transmit a frame of messages only once (One-time transmission), set the RUN bit high then low in the Transmit Control Register before the current frame ends. If the repetition rate is shorter than the minimum time needed to transmit all ARINC 429 words in the sequence (but not zero), the transmit sequence will begin again immediately if the Control Register SKIP bit is a zero. If the SKIP bit is a one, the sequencer will wait until the next rollover of the Repetition Rate Counter before starting a new cycle. HOLT INTEGRATED CIRCUITS 26 HI-3220 ARINC 429 TRANSMIT DESCRIPTOR Data Byte 3 (ARINC 429 bits 32-25) Descriptor Byte 8 Data Byte 2 (ARINC 429 bits 24-17) Descriptor Byte 7 Data Byte 1 (ARINC 429 bits 16-9) S Descriptor Byte 6 S Transmit Label (ARINC 429 bits 1-8) Descriptor Byte 5 Packet Timer Offset (PTO) Descriptor Byte 4 O O O O O O O O Packet Timer Period (PTP) Descriptor Byte 3 P P P P P P P P L L L RX Label Descriptor Byte 2 L L L L L Op-Code RX Select Descriptor Byte 1 7 6 MSB Op-Code 5 4 R R R R 3 2 1 0 LSB Description 0000 End of sequence. When op-code 0000 is encountered by the sequencer before it reaches sequence number 127, the sequencer resets to zero and begins the next transmission cycle starting at descriptor number 0 as soon as the repetition rate counter rolls over. Note that the descriptor table is cleared following Master Reset, (Mode 0 - Mode 3) so no ARINC 429 transmissions are possible until the sequence table has been configured. 0001 Delay. Delays the transmission of the next ARINC 429 word by the value of the Packet Timer Period byte in milliseconds. Except for PTP, the value of other descriptor bytes are “don’t care”. A delay with PTP=0 is equivalent to a no-op. 0010 Immediate data. The value contained descriptor bytes 5 through 8 is transmitted on the ARINC 429 bus. 0011 Immediate data conditional. Bytes 5 through 8 are transmitted only if the RX packet selected by receive channel “RRRR” and label ”LLLLLLLL” has new data. The NEWTXn bit is sampled to determine if this location has new data. NEWTXn is then reset. 0100 Indexed data. Transmits descriptor byte 5 as the label appended to the 24 bits of data stored at Receive channel “RRRR” and label “LLLLLLLL”. 0101 Indexed data conditional. Same as op-code 0100, but transmits only if new data exists at the specified location as indicated by the NEWTXn bit. NEWTXn is then reset. 0110 Indexed SDI. Same as op-code 0100 except the ARINC 429 SDI bits are replaced with those loaded in descriptor byte 6, bits 10-9 (”SS”). 0111 Indexed SDI conditional. Same as op-code 0101 except the ARINC 429 SDI bits are replaced with those loaded in descriptor byte 6, bits 10-9 (”SS”). 1XXX Reserved. Do not use. HOLT INTEGRATED CIRCUITS 27 HI-3220 PACKET TIMER Descriptor flow using the Packet Timer Descriptor entry PTP or PTO != 0 Packet Timer Period (PTP) and Packet Timer Offset (PTO) are used in conjunction with the Repetition Rate counter to make individual ARINC 429 word transmission timing possible. The Repetition Rate Counter is programmable from 0 ms to 2.55 s as defined by the PRESCALE bit and Repetition Rate Register contents. PTO = 0 ? If PTO is zero, the word message is transmitted and PRO is reloaded with PTP. If PTO is non-zero it is decremented and the word message is skipped. Yes Transmit Message Reload PTO with PTP No Decrement PTO An initial non-zero value in PTO provides an offset prior to the first transmission. The period between subsequent transmissions is controlled by PTP. A value of all 1’s in PTP indicates that the word will be transmitted once (one-shot mode). Next Descriptor Repetition Rate (RR) = Repetition Rate Timer (10ms or 1ms) x Repetition Rate Register value. See examples 1-4 below. Descriptor message rate = (PTP+1) x Repetition Rate. When PTO is non-zero, the message is skipped until PTO = 0. Each pass of the descriptor block decrements the PTO count. Example 1. 0 80 RR = 80 ms, PTP = 3 and PTO = 1 Transmission in 2nd pass and subsequently every 4th pass (every 320 ms). Example 2. 240 320 400 XMIT 0 RR = 10 ms, PTP = 2 and PTO = 0 Transmission in 1st pass and subsequently every third pass (every 30 ms). 160 10 Time ms XMIT 20 30 XMIT 40 50 Time ms XMIT Example 3. RR = 10 ms, PTP = 1 and PTO = 2 Transmission in 3rd pass and subsequently every 2nd pass (every 20 ms). XMIT XMIT Example 4. RR = 1 (10 ms), PTP = 4 and PTO = 0 Transmission in 1st pass and subsequently every 5th pass (60 ms). XMIT Pass 1 XMIT Pass 2 Pass 3 HOLT INTEGRATED CIRCUITS 28 Pass 4 Pass 5 Pass 6 HI-3220 ARINC 429 Immediate Transmit Option The Host CPU may instruct the HI-3220 to transmit an ARINC 429 message immediately using a special SPI command. The SPI command selects the transmit channel and provides the four bytes of data to be sent as a 32-bit ARINC 429 message. The Transmit Interrupt Enable Register is used to generate an interrupt at INT when selected Flags are enabled. If the transmit sequencer for the selected channel is active, then the new message(s) in the FIFO are transmitted as soon as the current message has been sent. The sequencer then resumes operation at the next location in the queue. A 32-message deep FIFO for each transmitter allows multiple ARINC 429 messages to be queued for transmission reducing host CPU overhead. Each transmit FIFO may be monitored by a flag which is set when the FIFO contains less than a user-defined number of messages. This threshold value is set in each transmitter’s Transmit FIFO Threshold Register. The Flags are accessed via the Transmit Flags register. Both the RUN input and the Master Control Register A429TX bit must be high to enable any ARINC 429 transmission. If the transmit channel’s sequencer is not running (TCR bit RUN/STOP = “0”), or the sequencer is waiting for the repetition rate counter to rollover, then the new ARINC 429 message is transmitted without delay. Table 2 lists the host CPU SPI instruction format. TF R TF 7 R TF 6 R TF 5 R TF 4 R TF 3 R TF 2 R 1 TF R 0 Host writes to a full FIFO will be ignored. TRANSMIT FIFO THRESHOLD REGISTER (Address 0x800F) Bit Name R/W 7 6 MSB 5 4 3 2 1 0 LSB Default Description 7 TFR7 R 1 This bit is set when Transmit FIFO 7 contains less than the programmed threshold number of ARINC 429 messages . 6 TFR6 R 1 This bit is set when Transmit FIFO 6 contains less than the programmed threshold number of ARINC 429 messages . 5 TFR5 R 1 This bit is set when Transmit FIFO 5 contains less than the programmed threshold number of ARINC 429 messages . 4 TFR4 R 1 This bit is set when Transmit FIFO 4 contains less than the programmed threshold number of ARINC 429 messages . 3 TFR3 R 1 This bit is set when Transmit FIFO 3 contains less than the programmed threshold number of ARINC 429 messages . 2 TFR2 R 1 This bit is set when Transmit FIFO 2 contains less than the programmed threshold number of ARINC 429 messages . 1 TFR1 R 1 This bit is set when Transmit FIFO 1 contains less than the programmed threshold number of ARINC 429 messages . 0 TFR0 R 1 This bit is set when Transmit FIFO 0 contains less than the programmed threshold number of ARINC 429 messages . NOTE: This register may be read using fast-access SPI Command Op-code 00111100 (0x3C). Transmit FIFO Count Registers TRANSMIT FIFO COUNT(0-7) (Address 0x8080 - 0x8087) Bit Name 7:0 TFCn[7:0] R/W R 0 Count Default = 0x00 0 7 6 MSB 5 4 3 2 1 0 LSB Default Description 0 Read current transmit message count. HOLT INTEGRATED CIRCUITS 29 HI-3220 Transmit FIFO Threshold Value Registers Each Transmitter has its own Transmit FIFO Threshold Register Threshold TRANSMIT FIFO THRESHOLD VALUE n (Address 0x8060 - 0x8067) Threshold Value 00000 0 0 0 7 6 MSB 5 Default = 0x00 4 3 2 1 0 LSB Description Threshold flag is set there are no messages in FIFO (FIFO is empty) (Default) Threshold flag is set if no more than one message is in the FIFO Threshold flag is set if no more than two messages are in the FIFO 00011 Threshold flag is set if no more than three messages are in the FIFO 10000 Threshold flag is set if no more than sixteen messages are in the FIFO 11111 Threshold flag is set if no more than 31 messages are in the FIFO (FIFO is not full) TX IE TX 7 IE TX 6 IE TX 5 IE TX 4 IE TX 3 IE TX 2 IE TX 1 IE 0 00001 00010 TRANSMIT FLAG INT ENABLE (Address 0x804F) 7 6 MSB 5 4 3 2 1 0 LSB Bit Name R/W Default Description 7 TXIE7 R/W 0 Setting this bit generates an interrupt when ARINC 429 Transmitter 7 FIFO Flag is set. The TXFLAG bit in the Pending Interrupt Register will be set and the INT pin will be asserted if the TXFLAGIE bit is set in the Pending Interrupt Enable Register. 6 TXIE6 R/W 0 Setting this bit generates an interrupt when ARINC 429 Transmitter 6 FIFO Flag is set. The TXFLAG bit in the Pending Interrupt Register will be set and the INT pin will be asserted if the TXFLAGIE bit is set in the Pending Interrupt Enable Register. 5 TXIE5 R/W 0 Setting this bit generates an interrupt when ARINC 429 Transmitter 5 FIFO Flag is set. The TXFLAG bit in the Pending Interrupt Register will be set and the INT pin will be asserted if the TXFLAGIE bit is set in the Pending Interrupt Enable Register. 4 TXIE4 R/W 0 Setting this bit generates an interrupt when ARINC 429 Transmitter 4 FIFO Flag is set. The TXFLAG bit in the Pending Interrupt Register will be set and the INT pin will be asserted if the TXFLAGIE bit is set in the Pending Interrupt Enable Register. 3 TXIE3 R/W 0 Setting this bit generates an interrupt when ARINC 429 Transmitter 3 FIFO Flag is set. The TXFLAG bit in the Pending Interrupt Register will be set and the INT pin will be asserted if the TXFLAGIE bit is set in the Pending Interrupt Enable Register. 2 TXIE2 R/W 0 Setting this bit generates an interrupt when ARINC 429 Transmitter 2 FIFO Flag is set. The TXFLAG bit in the Pending Interrupt Register will be set and the INT pin will be asserted if the TXFLAGIE bit is set in the Pending Interrupt Enable Register. 1 TXIE1 R/W 0 Setting this bit generates an interrupt when ARINC 429 Transmitter 1 FIFO Flag is set. The TXFLAG bit in the Pending Interrupt Register will be set and the INT pin will be asserted if the TXFLAGIE bit is set in the Pending Interrupt Enable Register. 0 TXIE0 R/W 0 Setting this bit generates an interrupt when ARINC 429 Transmitter 0 FIFO Flag is set. The TXFLAG bit in the Pending Interrupt Register will be set and the INT pin will be asserted if the TXFLAGIE bit is set in the Pending Interrupt Enable Register. HOLT INTEGRATED CIRCUITS 30 HI-3220 Transmit Watchdog Timer The Transmit Watchdog Timer (TWDT) is a fail-safe automatic shutdown mechanism that when enabled terminates the automatic transmission of scheduled messages in the event that the host does not refresh the TWDT 8-bit timer value before reaching zero count. The TWDT does not halt any transmit messages currently from the transmit FIFOs. The TWDT is disabled by default after Master Reset. The TWDT is now active and WTR begins decrementing every 20ms. 4. The host must refresh the WTR timer value before it decrements to zero or a Watchdog Timer event will occur and automatic transmit scheduler transmissions will stop after the current frame of message(s) is transmitted as defined in the transmit descriptor tables. Only those channels [TX7:TX0] enabled by corresponding WMR low bits are stopped. Two 8-bit registers control the TWDT: The Watchdog Mask Register (WMR), and Watchdog Timer Register (WTR). 5. Normal ARINC 429 transmissions will resume if a nonzero timer value is written to WTR. Use the following sequence to use the TWDT. The steps must be sequential: 6.Once the TWDT is enabled it cannot be disabled except by a Master Reset or a Software Reset SPI Opcode command. 1. Write 0xFF to WMR 2. Write an 8-bit timer value to WTR. 5 4 4 M W R3 M R W 2 M R W 1 M R 0 7 6 MSB W R 5 W M 6 R W M R R M W W M 7 3. Write a non-0xFF value to WMR. Transmit channels with Watchdog Timer enabled must have 0’s in the corresponding bit position [TX7:TX0]. Default = 0xFF WATCHDOG MASK REGISTER (Address 0x807E) 3 2 1 0 LSB Bit Name R/W Default Description 7 WMR7 R/W 1 Watchdog is enabled for transmitter 7 if WMR7=0 or disabled if WMR7=1. 6 WMR6 R/W 1 Watchdog is enabled for transmitter 6 if WMR6=0 or disabled if WMR6=1. 5 WMR5 R/W 1 Watchdog is enabled for transmitter 5 if WMR5=0 or disabled if WMR5=1. 4 WMR4 R/W 1 Watchdog is enabled for transmitter 4 if WMR4=0 or disabled if WMR4=1. 3 WMR3 R/W 1 Watchdog is enabled for transmitter 3 if WMR3=0 or disabled if WMR3=1. 2 WMR2 R/W 1 Watchdog is enabled for transmitter 2 if WMR2=0 or disabled if WMR2=1. 1 WMR1 R/W 1 Watchdog is enabled for transmitter 1 if WMR1=0 or disabled if WMR1=1. 0 WMR0 R/W 1 Watchdog is enabled for transmitter 0 if WMR0=0 or disabled if WMR0=1. Time-out period WATCHDOG TIMER REGISTER (Address 0x807F) Default = 0x00 7 6 MSB 5 4 3 2 1 0 LSB WTR7:0 sets the time-out period for the Watchdog Timer. The LSB is 20ms. The maximum time-out period of 5.1s is programmed by writing 0xFF to the WTR. HOLT INTEGRATED CIRCUITS 31 HI-3220 RESET AND START-UP MODES After power-on, the HI-3220 is in an undefined state. The MRST pin must be taken low to begin device initialization. The MRST pin may be asserted at any time. Taking MRST low immediately stops all execution and sets the READY output low, indicating that the part is in the reset state. MRST requires a minimum 225 ns pulse. On the rising edge of MRST the HI-3220 samples the state of the MODE2-0 input pins. This is the only occasion these inputs are sampled. Once MRST goes high, the MODE2-0 pins become outputs ESCLK, EMOSI and ECS. The MODE setting is readily accomplished using pull-up/down resistors at the three pins (NOTE: when using an external EEPROM with a pull-up resistor on the ECS (Mode0) pin, the series pull-down resistor on Mode0 needs to be low enough to drive the Mode0 signal to a low state. Holt recommends a 10K:1K ratio). The state of the MODE pins determines one of six possible initialization sequences (Mode 0 through Mode 5). MODE[2:0] = 000 sets Mode 0, MODE[2:0] = 001 sets Mode 1, MODE[2:0] = 101 sets Mode 5, etc. Note Mode 7 is reserved for factory test and must not be used. These six initialization modes allow the user to customize the start-up configuration of the device. See Figure 1, Reset and Start-up Operation Flow Chart. The total time from MRST rising edge to READY pin high depends on the total number of MCLK cycles (50MHz clock input) and is summarized in Table 2 for each mode. Once the initialization is complete, the device enters the Idle State when the ready pin goes high. In Idle State, the host CPU may communicate with the HI-3220 memory and registers using the host CPU SPI link. When in the Idle State, the HI-3220 does not transmit or receive any messages on any of the ARINC 429 buses. To begin data bus operation, the user must transition the RUN input from a low to high state. Immediately following the rising edge of RUN, the part enters the Active State and bus message processing begins. During initialization, various device configuration tasks are performed according to the Mode selection set at the MODE2:0 input pins. The available options are described below in sub-sections 1-4. MODE[2:0] status bits can be examined by reading the upper three bits in the UPPER BIST FAIL ADDRESS REGISTER 0x807A. MODE 6 is reserved for RAM BIST. Software Reset Opcode The SPI software reset opcode 0xFA5(8+mmm) resets the Configuration registers and Transmit descriptor tables, RX Interrupt Map and RX Enable Map areas according to the chart shown in Figure 1 depending on the mmm bit field (mode selection) used in the SPI opcode. See table 2. TABLE 1. Start-up Time for each Mode MODE[2:0] PINS MODE MCLK Cycles Start-up Time* 000 001 010 011 100 101 110 111 0 1 2 3 4 5 6 RESERVED 8,204 555,386 73,745 620,927 53,388 9 - 164.080 µs 11.107720 ms 1.4749 ms 12.41854 ms 107.760 µs 180 ns - * The time (±1 MCLK) from rising edge of MRST to READY pin high. HOLT INTEGRATED CIRCUITS 32 HI-3220 RESET AND START-UP MODES (cont.) 1. RAM Integrity Check In Modes 2 and 3, the HI-3220 performs a RAM integrity check. A read/write check is performed on the entire RAM space. An incrementing pattern is written to sequential RAM locations, then this pattern is read and verified. Each RAM location is re-written with the 1s complement of its current contents then this pattern is read and verified. The incrementing pattern followed by its 1s complement ensures that each RAM location can store both a 1 and 0 state. If the RAM integrity check fails, the INT pin is asserted and the Pending Interrupt Register RAMFAIL bit is set. The part enters the “Safe” state, in which the HI-3220 is able to accept and respond to Host CPU SPI Instructions, but cannot enter Normal Operating mode until the MRST input is taken low to repeat the initialization sequence. The RAMFAIL Interrupt is not maskable. 2. Clear Data Memory In Modes 0 - 4, the HI-3220 automatically clears all memory locations in the address range 0x0000 to 0x3FFF and 0x6C00 to 0x7FFF. This is the space reserved for ARINC 429 message data. Configuration tables and HI-3220 registers are not affected. 4. Auto-Initialize from EEPROM The contents of the Auto-Initialization EEPROM are copied into the HI-3220 memory and registers via the EEPROM SPI interface. The part verifies the integrity of the data transfer from the EEPROM by running through a byte-by-byte compare routine and a checksum validation. If a compare error is detected, the AUTOERR bit is set in the Pending Interrupt Register, the INT output is asserted. The location of the error is captured in the AUTO-INIT FAIL ADDRESS registers 0x807B (Auto-Init Fail LS address) and 0x807C (Auto-Init Fail MS address) and the part enters the Safe state. If a checksum error is detected, the CHKERR bit is set in the Pending Interrupt Register, the INT output is asserted and the part enters the Safe state. The AUTOERR and the CHKERR interrupts are not maskable. Once initialization is successful, the part enters the Idle state. The host CPU may read and write HI-3220 internal memory and registers in all Modes. If not using the autoinitialization feature, the host CPU should configure the device at this time. NOTE: Mode 7 is reserved and must not be selected. 3. Initialize Registers and Clear all memory In addition to clearing data memory (0x0000 to 0x3FFF and 0xc00 to 0x7FFF), Modes 0, 1, 2, and 3 also clear all configuration and look-up tables (0x4000 to 0x6BFF) as well as setting all configuration registers (0x8000 to 0x807F) to their default states. All registers default to zero unless otherwise noted. HOLT INTEGRATED CIRCUITS 33 HI-3220 MRST driven to “0” Stop execution, READY => 0 RESET STATE Delay 225ns minimum before raising MRST high MRST driven to “1” Sample MODE2:0 inputs MODE 0 MODE 1 MODE 2 MODE 3 MODE 4 MODE 5 MODE 6 MODE 7 No No Yes Yes No No RESERVED Clear data memory (0x0000 - 0x3FFF) Yes Yes Yes Yes Yes No RAM BIST ENABLE * Initialize Registers and Clear Configuration Tables (0x4000 - 0x6BFF) Yes Yes Yes Yes No No RESERVED Auto-Initialize from EEPROM No Yes No Yes No No RESERVED Perform RAM Integrity Check RAM Pass ? No Set RAMFAIL INT = 0 No Set AUTOERROR INT = 0 RESERVED Yes Copy OK ? Yes READY => 1 SAFE STATE IDLE STATE RUN driven 0 - 1 * See RAM BIST details is section RAM BUILT-IN SELF-TEST. ACTIVE STATE Figure 1. Reset and Start-up Operation flow chart. HOLT INTEGRATED CIRCUITS 34 HI-3220 INTERRUPTS The HI-3220 includes a simple, user-selectable Interrupt Handler. Two types of Interrupt are possible - Message Event Driven (ARINC 429 Bus), and Fault Driven. ARINC 429 Receive Interrupts As described earlier, the user can elect to generate an interrupt upon receipt of an ARINC 429 message on any combination of the sixteen available channels and for any of the possible 256 label byte (ARINC message bits 1-8) values. Interrupts are enabled when the Receive Interrupt look-up bit is a “1”. When a message arrives that is flagged to generate an Interrupt, that channel’s bit is set in the Receive Pending Interrupt Register RPIRH, RPIRL. The Interrupt Address Register (IAR) for that channel is updated with the ARINC 429 8-bit label value. For example, if ARINC Receive channel 7 is enabled for Interrupts when messages with ARINC label 0xD4 arrive, then on receipt of such a message, RPIRL bit 7 is set to a “1” and the value 0xD4 is written to IAR7. If the corresponding bit in the Receive Interrupt Mask Register is a “1” the INT interrupt output will go low and stay low until the ACK input pin is driven low. Driving ACK low, causes the INT pin to return to one. A special Indexed SPI read instruction is available to allow the host to efficiently retrieve ARINC 429 messages which have Interrupts Enabled (see SPI instruction set section). ARINC 429 Transmit Interrupts The user can elect to generate an interrupt when sending ARINC 429 messages using the transmit FIFOs. The Transmit Flag Interrupt Enable Register is programmed to define which transmit channels may generate an interrupt. If enabled, each time a bit is set in the Transmit FIFO Threshold Flag Register for an enabled channel, INT will be asserted. Fault Interrupts There are four fault Interrupt bits in the PIR. Fault Interrupts are not maskable, and their Interrupt Mask bits are fixed at a “1”. COPYERR is set when the HI-3220 detects a mismatch between RAM and EEPROM after attempting to program the Auto-initialization EEPROM. AUTOERR is set when the Auto-Initialization EEPROM read verification cycle detects a mismatch between the on-chip memory and EEPROM following autoinitialization. CHKERR is set when an auto-initialization checksum error is detected. The RAMFAIL bit is set if the Built-In Self Test sequence fails. Note that if ACK is tied low permanently, the INT pin will go low for approximately 1 us before returning to one. A host CPU read of the RPIRH or RPIRL register reads the current value and resets it to 0x00. HOLT INTEGRATED CIRCUITS 35 RECEIVE PENDING INTERRUPT REGISTER HIGH / LOW (Address 0x8008, 0x8006) (Alternate Address 0x800C, 0x800B) Bit Name 15:0 PIR[15:0] R/W R 7 6 MSB 5 4 3 2 1 0 LSB R 7 PI R 6 PI R 5 PI R 4 PI R 3 PI R 2 PI R 1 PI R 0 PI PI R 1 PI 5 R 1 PI 4 R 1 PI 3 R 1 PI 2 R 1 PI 1 R 1 PI 0 R 9 PI R 8 HI-3220 7 6 MSB 5 4 3 2 1 Default Description 0 When a message is received on a given channel that triggers an interrupt, that channel’s corresponding bit is set, e.g. if a message received on Rx channel 5 triggers an interrupt, the bit PIR5 will be set. If this bit is unmasked in the Receive Interrupt Mask Register (see below), the INT output pin is asserted. 0 LSB 7 6 MSB 7 6 MSB 5 4 3 2 1 0 LSB IE 7 R IE 6 R IE 5 R IE 4 R IE 3 R IE 2 R IE 1 R IE 0 R RECEIVE INTERRUPT ENABLE REGISTER HIGH / LOW (Address 0x804C, 0x804B) R IE 1 R 5 IE 1 R 4 IE 1 R 3 IE 1 R 2 IE 1 R 1 IE 1 R 0 IE 9 R IE 8 Note: This register pair is automatically cleared when read. 5 4 3 2 1 Name R/W Default Description 15:0 RIE[15:0] R/W 0 Each bit in this register, RIE[15:0], is a mask for a corresponding bit in the Receive Pending Interrupt Register (PIR[15:0], described above). Writing a “1” to an IMR bit results in assertion of the INT output pin when the corresponding PIR bit is set (ARINC 429 message received). Writing a “0” to an IMR bit will mask the corresponding PIR bit in the Receive Pending Interrupt Register, resulting in non-assertion of the INT pin when an ARINC 429 message is received. IA R n IA 7 R n IA 6 R n IA 5 R n IA 4 R n IA 3 R n IA 2 R n IA 1 R n0 Bit RECEIVE INTERRUPT ADDRESS REGISTERS 0 - 15 (Address 0x8010 - 0x801F) Bit Name 7:0 IAR0[7:0] R/W R n = 0 - 15 7 6 MSB 5 4 3 2 1 0 LSB Default Description 0 The label number of the ARINC 429 message causing an interrupt is loaded into this register. Each channel has a corresponding Receive Interrupt Address Register (IAR0 - IAR15). HOLT INTEGRATED CIRCUITS 36 0 LSB EE A C BO O R P T AU YE ER T RR R C OE H R K R R ER AM R R FA XR IL R AM XF N E TX LAG W FL AG HI-3220 PENDING INTERRUPT REGISTER (Address 0x8004) (Alternate Address 0x800A) 7 6 MSB 5 4 3 2 1 0 LSB The INT will be asserted when any of the bits in this register are set. Bit Name R/W Default Description 7 EEABORTERR R 0 EE Abort programming error 6 COPYERR 0 EE copy error. RAM - EEPROM mismatch R 5 AUTOERR R 0 Auto-inititailization RAM read error 4 CHKERR R 0 Auto-initialization checksum fail 3 RAMFAIL R 0 Power-On Reset RAM Integrity Check fail 2 RXRAMNEW R/W 0 Asserted high with any new message reception, all channels 1 RXFLAG R 0 Logical OR of ARINC 429 Receive FIFO FLAG signals 0 TXFLAG R 0 A Transmit FIFO Flag is set EE A C BO O R P T AU YE ER T RR R C OE H R K R R ER AM R R FA XR IL R AM XF N E TX LAG W E FL AG NOTE: This register is cleared when read. PENDING INTERRUPT ENABLE REGISTER (Address 0x804A) Bit Name R/W 7 6 MSB 5 4 3 2 1 0 LSB Default Description 7 EEABORTERR R 1 EE Abort programming error 6 COPYERR R 1 COPYERR is not maskable 5 AUTOERR R 1 AUTOERR is not maskable 4 CHKERR R 1 CHKERR is not maskable 3 RAMFAIL R 1 RAMFAIL is not maskable 2 RXRAMNEWE R/W 0 Enable for RXRAMNEW 1 RXFLAGIE R/W 0 INT pin is asserted if this bit is a “1” and the Pending Interrupt Register RXFLAG bit is set 0 TXFLAGIE R/W 0 INT pin is asserted if this bit is a “1” and the Pending Interrupt Register TXFLAG bit is set HOLT INTEGRATED CIRCUITS 37 HI-3220 INTERRUPT HANDLING The static state of ACK determines if INT is a level or pulse signal. Op-codes for single 8-bit pending register reads INT Level Mode: (SPI clocking = 8 Op-code clocks + 8 data clocks) When an interrupt occurs, the INT pin is asserted low if the ACK pin is high. When ACK is asserted low, the INT pin returns to a high state. ACK should be a negative pulse so it is normally in the inactive state. OP-code Register Address Name 0x10 0x18 0x20 8004 8006 8008 INT Pulse Mode: If ACK is held low, this causes the INT to pulse negative for approximately 1 microsecond when an interrupt occurs. Host Interrupt Servicing Options When an interrupt occurs, the host typically reads one or more interrupt pending registers to determine the source of the interrupt. Depending on system requirements a small or large number of interrupts can be supported. If there are several interrupt sources that span across the three pending interrupt registers (PIR, RPIRH and RPIRL) then all three registers need to be read to determine the interrupt source(s). In a simpler system where there may be eight or less receiver interrupts grouped into either the higher or lower RPIRx registers it is possible to detect the interrupt sources by reading a single pending interrupt register. Reading one register is faster than reading three registers so this is a good way to reduce host interrupt processing time. Although the HI-3220 has a very fast SPI port, some SPI masters insert unwanted delays between bytes, so this helps reduce the time the host takes to determine the interrupt source. PIR RPIRL RPIRH Op-codes for multiple pending interrupt registers To read all three registers issue an 8-bit op-code 0x28 + 24 data clocks. This returns three consecutive bytes representing PIR + RPIRH + RPIRL. This is the fastest method to read in all three interrupt registers. Another way to use op-codes 0x2C or 0x30 may be beneficial depending on the user requirements. For example , to only read the first and second pending interrupt registers, issue the op-code 0x28 and only 16 data clocks. The two returned bytes represent PIR and RPIRH. If op-code 0x2C was used with 16 data clocks then the two returned bytes represent RPIRH and RPIRL. As with any op-code sequence HCS must remain low during the whole time until all the data is fully clocked. Op-code Data Register Bytes Address 0x28 0x2C 0x30 3 2 1 Two op-code groups are available for reading pending interrupt registers so host interrupt servicing can be optimized based on the number of system interrupts. HOLT INTEGRATED CIRCUITS 38 Name 800A, 800B, 800C PIR+RPIRL+RPIRH 800B, 800C RPIRL+RPIRH 800C RPIRH HI-3220 RAM BUILT-IN SELF-TEST The HI-3220 offers a built-in self-test (BIST) feature which can be used to check RAM integrity. The BIST Control/Status Register is used to control the BIST function. All tests are destructive, overwriting data present before test commencement. NOTE: To use BIST self-test, the part needs to be in Mode 6 with the RUN pin low. To use RAM BIST follow these steps: R BF R AIL BS R EL BS 2 R EL BS 1 R EL BS 0 TA RT R BF R AIL BP AS S 1. Power up the part in MODE 6. This can be accomplished by having MODE2 and MODE1 input pins high and MODE0 input pin low while powering up the part. Alternatively, configure the part in MODE-6 by executing the SPI Software Reset Opcode in Mode 6 (mmm=6 in Opcode Byte 2). 2. Set the RUN input pin low. 3. Write to the BIST control/status register with the desired RAM test (RBSEL2:0) and the RBSTRT bit high to initiate the test. 4. Wait for READY to be asserted high by polling the READY pin or by examining READY bit-5 in the MSR register using SPI. 5. After READY is asserted high examine bits 0 and 1 for the RAM BIST Fail or Pass result. BIST CONTROL/STATUS REGISTER (Address 0x8078) X 7 6 MSB 5 4 3 2 1 0 LSB This register controls RAM built-in self-test. Bits 0,1 are Read Only. The remaining bits in this register are Read-Write but can be written only in MODE2:0 = 0x06. BIST Control Register bits provide a means for the host to perform RAM self-test at other times. Register bits 6:4 select RAM test type. Then bit 3 starts the selected RAM test, and bits 1:0 report a fail/pass result after test completion. Bit No. Mnemonic Interrupt Type 7 RBFFAIL 6:4 RBSEL2-0 RAM BIST Select Bits 2-0. This 3-bit field selects the RAM BIST test mode applied when the RBSTART bit is set: RAM BIST Force Failure. When this bit is asserted, RAM test failure is forced to verify that RAM BIST logic is functional. RBSEL2:0 000 001 010 011 100 101 110 111 SELECTED RAM TEST Idle Pattern Test, described below Write 0x00 to RAM address range 0x0000 - 0x7FFF Read and verify 0x00 over RAM address range 0x0000 - 0x7FFF Write 0xFF to RAM address range 0x0000 - 0x7FFF Read and verify 0xFF over RAM address range 0x0000 - 0x7FFF Inc / Dec Test performs only steps 5 - 8 of the Pattern Test below Idle Description of the RAM BIST “PATTERN” test selected when register bits RBSEL2:0 = 001: 1. Write 0x00 to all RAM locations, 0x0000 through 0x7FFF 2. Repeat the following sequence for each RAM location from 0x0000 through 0x7FFF: a. Read and verify 0x00 b. Write then read and verify 0x55 HOLT INTEGRATED CIRCUITS 39 HI-3220 c. d. e. f. g. h. I. j. Write then read and verify 0xAA Write then read and verify 0x33 Write then read and verify 0xCC Write then read and verify 0x0F Write then read and verify 0xF0 Write then read and verify 0x00 Write then read and verify 0xFF Write 0x00 then increment RAM address and go to step (a) 3. Write 0xFF to all RAM locations, 0x0000 through 0x7FFF 4. Repeat the following sequence for each RAM location from 0x0000 through 0x7FFF: a. Read and verify 0xFF b. Write then read and verify 0x55 c. Write then read and verify 0xAA d. Write then read and verify 0x33 e. Write then read and verify 0xCC f. Write then read and verify 0x0F g. Write then read and verify 0xF0 h. Write then read and verify 0x00 I. Write then read and verify 0xFF j. Write 0xFF then increment RAM address and go to step (a) 5. 6. 7. 8. Write an incrementing pattern into sequential RAM locations from 0x0000 to 0x7FFF Read each memory location from 0x0000 to 0x7FFF and verify the contents Write 1s complement of each cell’s current contents, into each RAM location (same addr range) Read each memory location and verify the contents 3 RBSTRT RAM BIST Start. Writing logic 1 to this bit initiates the RAM BIST test selected by register bits RBSEL2:0. The RBSTRT bit can only be set in MODE2:0 = 0x04. This bit is automatically cleared upon test completion. Register bits 1:0 indicate fail / pass test result. 2 --------- Not Used. 1 RBFAIL RAM BIST Fail. Device logic asserts this bit when failure occurs while performing the selected RAM test. This bit is automatically cleared when RBSTRT bit 3 is set. When BIST failure occurs, a clue to the failing RAM address can be read at register addresses 0x8079 and 0x807A. For speed, the RAM BIST concurrently tests four consecutive RAM addresses in parallel. If a test failure occurs, register addresses 0x8079 and 0x807A can be used to determine the four RAM addresses tested. 0 RBPASS RAM BIST Pass. Device logic asserts this bit when the selected RAM test completes without error. This bit is automatically cleared when RBSTRT bit 3 is set. BISTFL LOWER BIST FAIL ADDRESS REGISTER (Address 0x8079) 7 6 MSB 5 4 3 2 1 0 LSB BISTFH UPPER BIST FAIL ADDRESS AND MODE BITS REGISTER (Address 0x807A) m m m 15 14 13 12 11 10 9 8 LSB MSB Bits in Register BISTFH are Mode[2:0] Status Bits HOLT INTEGRATED CIRCUITS 40 HI-3220 HOST SERIAL PERIPHERAL INTERFACE HSCK, and output data for each device changes on the falling edge. These are known as SPI Mode 0 (CPHA = 0, CPOL = 0) and SPI Mode 3 (CPHA = 1, CPOL = 1). Be sure to set the host SPI logic for one of these modes. In the HI-3220, internal RAM and registers occupy a (32K + 128) x 8 address space. The lowest 32K addresses access RAM locations and the remaining addresses access registers. Timing is identical for register operations and RAM operations via the serial peripheral interface, and read and write operations have likewise identical timing. As seen in Figure 2, the difference between SPI Modes 0 and 3 is the idle state for the HSCK signal. There is no configuration setting in the HI-3220 to select SPI Mode 0 or Mode 3 because compatibility is automatic. Beyond this point, the HI-3220 data sheet only shows the SPI Mode 0 HSCK signal in timing diagrams. Host access is only allowed when the part is READY or in SAFE mode. NOTE: writes will be blocked and reads will return the Master Status Register value until either of these modes occur. The SPI protocol transfers serial data as 8-bit bytes. Once HCS chip select is asserted, the next 8 rising edges on HSCK latch input data into the master and slave devices, starting with each byte’s most-significant bit. The HI-3220 SPI can be clocked at 40 MHz. To achieve reliable 40 MHz SPI the hardware should be optimized for low PCB capacitance with a short distance from the device to the host. Serial Peripheral Interface (SPI) Basics The HI-3220 uses an SPI synchronous serial interface for host access to registers and RAM. Host serial communication is enabled through the Chip Select (HCS) pin, and is accessed via a three-wire interface consisting of Serial Data Input (HMOSI) from the host, Serial Data Output (HMISO) to the host and Serial Clock (HSCK). All programming cycles are completely self-timed, and no erase cycle is required before write. Multiple bytes may be transferred when the host holds HCS low after the first byte transferred, and continues to clock HSCK in multiples of 8 clocks. A rising edge on HCS chip select terminates the serial transfer and reinitializes the HI-3220 SPI for the next transfer. If HCS goes high before a full byte is clocked by HSCK, the incomplete byte clocked into the device HMOSI pin is discarded. The SPI (Serial Peripheral Interface) protocol specifies master and slave operation; the HI-3220 Host CPU interface operates as an SPI slave. The SPI protocol defines two parameters, CPOL (clock polarity) and CPHA (clock phase). The possible CPOLCPHA combinations define four possible "SPI Modes." Without describing details of the SPI modes, the HI-3220 operates in the two modes where input data for each device ( master and slave) is clocked on the rising edge of In the general case, both master and slave simultaneously send and receive serial data (full duplex) as shown in Figure 2 below. When the HI-3220 is sending data on HMISO during read operations, activity on its HMOSI input is ignored. Figures 3 and 4 show actual behavior for the HI3220 HMISO output. HSCK (SPI Mode 0) 0 1 2 3 4 5 6 7 HSCK (SPI Mode 3) 0 1 2 3 4 5 6 7 HMOSI HMISO High Z MSB LSB MSB LSB High Z HCS FIGURE 2. Generalized Single-Byte Transfer Using SPI Protocol, HSCK is Shown for SPI Modes 0 and 3 HOLT INTEGRATED CIRCUITS 41 HI-3220 0 1 3 2 5 4 7 6 0 1 3 2 5 4 7 6 HSCK SPI Mode 0 MSB LSB HMOSI Command Byte HMISO LSB MSB MSB High Z High Z Data Byte HCS Host may continue to assert HCS here to read sequential byte(s) when allowed by the instruction. Each byte needs 8 HSCK clocks. FIGURE 3. Single-Byte Read From RAM or a Register 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 HSCK SPI Mode 0 MSB LSB MSB LSB LSB MSB HMOSI Command Byte HMISO Data Byte 0 Data Byte 1 High Z HCS Host may continue to assert HCS here to write sequential byte(s) when allowed by the SPI instruction. Each byte needs 8 SCK clocks. FIGURE 4. 2-Byte Write To RAM or a Register Pair HOLT INTEGRATED CIRCUITS 42 HI-3220 HI-3220 SPI COMMANDS Refer to the HI-3220 SPI command set shown in Table 2. For the HI-3220, each SPI read or write operation begins with an 8- or 16-bit command byte(s) transferred from the host to the device after assertion of HCS. Since HI-3220 command byte reception is half-duplex, the host discards the dummy byte(s) it receives while serially transmitting the command byte(s). Fast Access Commands for Registers 0-31 The SPI command set includes directly-addressed read and write commands for registers 0 through 31 (Memory Address 0x8000 to 0x801F). The 8-bit pattern for these commands has the general form 0-R-R-R-R-R-0-0 where RRRRR is the 4-bit register number. All registers within this address range are read-only, with the exception of the Master Control Register, which utilizes two addresses, one for read and one for write operations. initialized before any indirect read or write operation. Two dedicated SPI instructions are used to write and read the MAP. SPI Instruction 0x98 followed by two data bytes is used to write MAP. SPI instruction 0x90 reads two data bytes from MAP. The first byte is the most significant eight bits of the address. For example, SPI sequence 0x98, 0x12, 0x34 write the value 0x1234 into the MAP. Two SPI instructions read and write data bytes to memory or registers using the MAP as an address pointer. Single or multi-byte reads and writes may be performed. MAP is incremented after each byte access. Two command bytes cannot be “chained”; HCS must be de-asserted after the command, then reasserted for the following Read or Write command. Note: When the primary or fast-access address pointer is used for auto-incrementing multi-word read/write and reaches the top of the memory address range (0x7FFF), or the top of the register address range (0xFFFF) attempts to read further bytes will result the terminal address (0x7FFF or 0xFFFF) being output again. The host should avoid this situation. Figures 3 and 4 show read and write timing as it appears for fast-access register operations. The command byte is immediately followed by a data byte comprising the 8-bit data word read or written. For a single register read or write, HCS is de-asserted after the data byte is transferred. Two single-byte SPI commands use the current address pointer value in MAP without first loading or otherwise modifying it: Command 0x80 Read Operation read location addressed by pointer value Multiple register read or write cycles may be performed by transferring more than one byte before HCS is deasserted. Multiple register access occur in address order starting with the register specified in the SPI instruction. Command 0x88 Write Operation write location addressed by pointer value Note: Register locations not shown in table 2 are “reserved” and cannot be written using any SPI command. Further, these register addresses will not provide meaningful data in response to read commands. Either of these commands can be used to read or write a single location, or may be used when starting a multi-byte read or write by using the pointer’s auto-increment feature. MAP is only used with opcodes 0x80 and 0x84. Register Direct Addressing Special Purpose Commands Two 2-byte SPI instructions read and write data bytes to registers anywhere in the register address space from 0x8000 through 0x807F for writes or 0x8000 through 0x8087 for reads. The explicit register address is included in the op-code bit sequence. The opcodes take the form: Write: 11011AAA AAAA0000 Read: 1110AAAA AAAA0000 Where AAA AAAA is the least significant seven or eight bits of the register address. Several other HI-3220 SPI commands load or otherwise modify the memory address pointer before initiating a read or write process. These commands are designed to allow speedy access to messages received on the ARINC 429 buses. RAM and Register Indirect Addressing To access the entire address range of the part, SPI commands are included that use an address pointer to indicate the address for read or write transactions. This sixteen-bit memory address pointer (MAP) must be Using a 2-byte SPI command, the address pointer can be directly loaded with the memory address for the last received ARINC 429 message which triggered an interrupt. Op Code 11001000 CCCC0000 The HI-3220 will retrieve the current ARINC Receive Interrupt Vector for a given receive channel (CCCC), calculate the memory address for the first word of the corresponding receive memory data block, and then read the location at that address. HOLT INTEGRATED CIRCUITS 43 HI-3220 This command can be used to read just the most recent ARINC 429 Receive Status Byte, or may be used to start a four-byte read because memory pointer auto-increment occurs after the Status Byte is read. Op Code 11010000 CCCC0000 The HI-3220 will retrieve the current ARINC Receive Interrupt Vector for a given channel (CCCC), calculate the memory address for the first word of the corresponding receive memory data block, then output the value of the Receive Interrupt Vector (ARINC 429 label byte). This command can be used to read just the most recent ARINC 429 label value received, or may be used to start a four-byte read to output the entire four-byte ARINC message, because memory pointer auto-increment occurs after the label byte is output. Op Code 10100TTT Writes an ARINC 429 message to ARINC 429 transmit scheduler TTT for immediate transmission, where TTT represents the transmit channel number. Op Code 11111010 01011010 This op-code forces a reset of the HI-3220. The part will reinitialize in exactly the same manner as if the MRST pin had been asserted. TABLE 2. DEFINED SPI COMMANDS OP CODE byte 1 OP CODE byte 2 Auto Increment Number of Data Bytes 0RRRRR00 10000000 10001000 10010000 10011000 10100TTT 11000000 11001000 None None None None None None CCCC0000 CCCC0000 Yes Yes Yes No No No Yes No 1++* 1++* 1++* 2 2 4, 8, 12... 4, 8, 12... 4 11010000 CCCC0000 No 4 11011AAA 1110AAAA 11111010 AAAA0000 AAAA0000 01011mmm Yes Yes No 1++* 1++* 0 DESCRIPTION Fast Register access at register RRRRR Read memory at address MAP Write memory at address MAP Read MAP Write MAP Transmit ARINC 429 message on transmit bus TTT Read ARINC 429 FIFO # CCCC. Read multiples of four bytes Read ARINC block at receive channel CCCC, label (Reads status word plus data). See Note 3 below. Read ARINC message at receive channel CCCC, label (Reads label plus data). See Note 3 below. Write register number AAA AAAA (0x8000 - 0x807F) Read register number AAAA AAAA (0x8000 - 0x8087) Software Reset with mode 0 - mode 6, 000-110 *NOTE: Supports multi-byte transfer during auto-increment. FAST-ACCESS SPI COMMANDS FOR REGISTERS 0-31 Command Bits 6:2 Convey the 5-Bit Register Address COMMAND BITS 7 6 5 4 3 2 1 0 HEX BYTE FUNCTION COMMAND BITS 7 6 5 4 3 2 1 0 HEX BYTE FUNCTION 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0x00 0x04 0x08 0x0C 0x10 0x14 0x18 0x1C 0x20 0x24 0x28 0x2C 0x30 0x34 0x38 0x3C Write MCR Read MCR Read MSR Reserved Read PIR Reserved Read RPIRL Reserved Read RPIRH Reserved Read PIR+RPIRL/H Read RPIRL/H Read RPIRH Read FTFL Read FTFH Read TFR 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0x40 0x44 0x48 0x4C 0x50 0x54 0x58 0x5C 0x60 0x64 0x68 0x6C 0x70 0x74 0x78 0x7C Read IAR0 Read IAR1 Read IAR2 Read IAR3 Read IAR4 Read IAR5 Read IAR6 Read IAR7 Read IAR8 Read IAR9 Read IAR10 Read IAR11 Read IAR12 Read IAR13 Read IAR14 Read IAR15 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Notes: 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 0 0 0 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 0 0 0 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1. Op-code 0x28 is used to read PIR, RPIRL and RPIRH as a three-byte data field. 2. Op-code 0x02C is used to read RPIRL and RPIRH as a two-byte data field. 3. To use OpCodes 11000000 CCCC 0000 and 11010000 CCCC 0000 the corresponding Received Data Interrupt Look-Up Table bits must be set for the desired channels and labels. Enabling interrupts in the interrupt enable registers are not required. HOLT INTEGRATED CIRCUITS 44 HI-3220 PROGRAMMING THE AUTO-INITIALIZATION EEPROM. Following reset, the HI-3220 may be completely configured by automatically copying the contents of an external EEPROM into HI-3220 memory and registers. An SPI enabled 64KByte EEPROM is used for this purpose. The EEPROM memory space is mapped to the HI-3220. All configuration memory blocks are copied. The ARINC 429 Received Data Memory contents and ARINC 429 Receive log FIFO contents are not copied to or from the EEPROM. The HI-3220 can be used to program the Auto-Initialization EEPROM. When the HI-3220 is in its IDLE state (RUN input = “0”), a five step sequence must be performed to begin the EEPROM programming cycle: 1. Write data value 0x5A to HI-3220 memory address 0x8FFE. 2. Write data value 0x96 to HI-3220 memory address 0x8FFA. Step 2 must occur within 1ms of step 1. 3. Write data value 0xF0 to memory address 0x8FF8 within 10ms. programming cycle is aborted. Step 5 initiates the cycle. The READY pin goes low, and the contents of the HI-3220 memory and registers are copied to the EEPROM. When copying is complete, the HI3220 executes a byte-by-byte comparison of the EEPROM and its own register / memory contents. If the verification completes successfully, the READY pin goes high. A 2’s complement of the checksum is also written to the EEPROM at location 0x8080. The total read back checksum should be zero. The following locations are excluded from the checksum because they are either readonly or unused locations: 0x8001 - 0x800F 0x8010 - 0x801F 0x8040 - 0x8047 0x8068 - 0x807C. If the comparison of the EEPROM contents and HI-3220 memory / register contents results in a discrepancy, the HI3220 enters the SAFE state, the PROGERR bit is set in the Pending Error Register and the INT output is asserted. The user must clear the PROGERR issue before normal operation can resume. 4. Wait > 1ms, but less than 10ms. 5. Write 0xC3 to 0x8FFC If the five step sequence is interrupted by any intervening host activity or improper timing between the steps the If an error occurs during programming the EEABORTERR flag is set in the PIR register. The EE programming time on the Holt ADK-3220 development board using an Atmel EEPROM is approximately 278ms. HOLT INTEGRATED CIRCUITS 45 HI-3220 ABSOLUTE MAXIMUM RATINGS Supply voltage (VDD) RECOMMENDED CONDITIONS Operating Supply Voltage -0.3 V to +5.0 V Logic input voltage range X VDD....................................... 3.3 VDC ±5% -0.3 V DC to +3.6 V X ARINC 429 input voltage -120 V to +120 V Power dissipation at 25°C 1.0 W Reflow Solder Temperature 260°C Junction Temperature 175°C Storage Temperature -65°C to +150°C Operating Temperature Range X Industrial ......................... -40°C to +85°C Extended ....................... -55°C to +125°C NOTE: Stresses above absolute maximum ratings or outside recommended operating conditions may cause permanent damage to the device. These are stress ratings only. Operation at the limits is not recommended. DC ELECTRICAL CHARACTERISTICS Digital Pins VDD = 3.3 V, GND = 0V, TA = Operating Temperature Range (unless otherwise specified). PARAMETER SYMBOL Operating Voltage VDD Supply Current IDD Min. Input Voltage (HI) Max. Input Voltage VIH CONDITION Digital inputs (LO) VIL Digital inputs Pull-Up / Pull-Down Current IPUD See pin definitions table Output Current (HI) IOH VOH = 0.8 VDD MIN TYP MAX 3.15 3.30 3.45 V 75 mA 70% UNITS VDD 30 30% VDD 100 µA -6.0 mA 6.0 mA 90% VDD VDD = 3.15 - 3.45 V Output Current (LO) IOL VOL = 0.4 V VDD = 3.15 - 3.45 V Min. Output Voltage (HI) VOH IOUT = -1.0mA, Digital outputs Max. Output Voltage (LO) VOL IOUT = 1.0mA, Digital outputs 10% VDD Input Capacitance CI 5 pF Output Capacitance CO 5 pF ARINC 429 Receiver Inputs (ARXxx-40) VDD = 3.3 V, GND = 0V, TA = Operating Temperature Range (unless otherwise specified). Measured at ARINC 429 bus with required 40KOhm isolation resistors installed. PARAMETER Input Voltage Input Resistance ONE or ZERO CONDITION MIN TYP MAX UNITS VDIN Differential input voltage 6.5 10 13 V NULL VNIN Differential input voltage 2.5 V Common mode VCOM With respect to GND +/-5.0 V ARXnP-40 to ARXnN-40 RDIFF Supplies floating Input to GND or VDD RSUP Supplies floating Input Hysteresis Input Capacitance SYMBOL VHYS ARINC bus differential CAD ARINC single ended to GND CAS HOLT INTEGRATED CIRCUITS 46 0.5 90 kΩ 45 kΩ 1.0 V 5 10 pF 10 pF HI-3220 AC ELECTRICAL CHARACTERISTICS VDD = 3.3 V, GND = 0V, TA = Operating Temperature Range (unless otherwise specified). LIMITS PARAMETER SYMBOL UNITS MIN TYP MAX SPI Host Bus Interface HSCK clock period HSC set-up time to first HSCK rising edge HSC hold time after last HSCK falling edge HSC inactive between SPI instructions SPI SI Data set-up time to SCK rising edge SPI HMOSI Data hold time after HSCK rising edge HMISO valid after HSCK falling edge HMISO high-impedance after HSC inactive tCYC tCES tCEH tCPH tDS tDH tDV tCHZ 25 15 15 100 10 10 10 90 ns ns ns ns ns ns ns ns SERIAL INPUT TIMING DIAGRAM t CPH t CEH t CYC HSC t CES HSCLK t DS t DH MSB HMOSI LSB SERIAL OUTPUT TIMING DIAGRAM t CPH HSC HSCLK t CHZ t DV HMISO Hi Impedance MSB LSB Power Supply Recommended bypass capacitors (near the device) Provide a 0.1µF ceramic bypass capacitor on GND and VDD power pins (2-4 capacitors). Provide a single 22µF ceramic or tantalum bypass capacitor on any GND and VDD power pins. HOLT INTEGRATED CIRCUITS 47 Hi Impedance HI-3220 ORDERING INFORMATION HI-322xPQ x x PART NUMBER Blank F PART NUMBER PACKAGE DESCRIPTION Tin / Lead (Sn / Pb) Solder 100% Matte Tin (Pb-free RoHS compliant) TEMPERATURE RANGE FLOW BURN IN I -40°C TO +85°C I No T -55°C TO +125°C T No M -55°C TO +125°C M Yes PART NUMBER PACKAGE DESCRIPTION LINE DRIVER SLOPE CONTROL INTERNAL # LINE RX/TX RECEIVERS Channels 3220PQ 80-PIN PLASTIC QFP (80PQTS) Y Y 16 / 8 3223PQ 52-PIN PLASTIC QFP (52PQS) Y Y 8/4 3225PQ 80-PIN PLASTIC QFP (80PQTS) Y N 16 / 8 PART NUMBER PACKAGE DESCRIPTION HI-322xPC x x Blank F PART NUMBER NiPdAu NiPdAu (Pb-free RoHS compliant) TEMPERATURE RANGE FLOW BURN IN I -40°C TO +85°C I No T -55°C TO +125°C T No M -55°C TO +125°C M Yes PART NUMBER PACKAGE DESCRIPTION LINE DRIVER SLOPE CONTROL 3221PC 72-PIN PLASTIC QFN (72PCS) N Y 16 / 8 3222PC 48-PIN PLASTIC QFN (48PCS7) N Y 8/4 3223PC 64-PIN PLASTIC QFN (64PCS) Y Y 8/4 3226PC 72-PIN PLASTIC QFN (72PCS) N N 16 / 8 HOLT INTEGRATED CIRCUITS 48 INTERNAL # RX/TX LINE RECEIVERS Channels HI-3220 REVISION HISTORY Document Rev. Date Description of Change DS3220 New A 01-12-18 05-01-18 B 10-15-18 C 12-14-18 D 03-04-19 E 03-11-19 F G H 08-22-19 03-04-2020 04-22-2020 J K 07/24/2020 04/21/2021 Initial Release. Add HI-3223 device and related package and ordering information. . Correct typo in 80PTQS drawing. Correct other typos and add additional clarification notes. Add “Fully compliant to ARINC 429 Specification” to Features. Correct typo in 3225PQ ordering information (slope control should be “Y”). Update package lead finish. Correct other numerous typos. Add ARINC input voltage to “Absolute Maximum Ratings Table”. Correct typos. Remove non-annunciated fault protection statement. Clarify pullup/pull-down resistor values when using external EEPROM. Correct minor typos. Update Note on pull-ups/pull-downs (p. 4) to make it consistent with Note on p. 7 for HI-3225 and HI-3226. Update Ordering Information for QFN lead finish to NiPdAu. Correct typo in Ordering Information. Correct typos in package pinouts (BMODE should be MODE). Correct typo on p. 43, section “Register Direct Addressing”. Read register range should be 0x8000 to 0x8087. Clarify HI-3223 has integrated, lightning protected line receivers. Clarify operation of SLP pins. HOLT INTEGRATED CIRCUITS 49 PACKAGE DIMENSIONS 80 PIN PLASTIC QUAD FLAT PACK (PQFP) millimeters (inches) Package Type: 80PTQS 0.40 BSC (0.0157) 10.00 BSC SQ (0.394) 12.00 (0.472) BSC SQ 0.22 ± 0.05 (0.009 ± 0.002) 0.60 ± 0.15 (0.024 ± 0.006) 1.40 ± 0.05 (0.055 ± 0.002) See Detail A 1.60 max (0.0630) 0.10 ± 0.05 (0.004 ± 0.002) BSC = “Basic Spacing between Centers” is theoretical true position dimension and has no tolerance. (JEDEC Standard 95) Detail A 72-PIN PLASTIC CHIP-SCALE PACKAGE (QFN) millimeters (inches) Package Type: 72PCS Electrically isolated heat sink pad on bottom of package 10.00 BSC (0.394) Connect to any ground or power plane for optimum thermal dissipation 5.95 ± 0.20 (0.234 ± 0.008) 0.50 BSC (0.0197) 10.00 BSC (0.394) 5.95 ± 0.20 (0.234 ± 0.008) Top View Bottom View 0.20 typ (0.008) 0.40 ± 0.05 (0.016 ± 0.002) 0.20 typ (0.008) BSC = “Basic Spacing between Centers” is theoretical true position dimension and has no tolerance. (JEDEC Standard 95) 1.00 max (0.039) HOLT INTEGRATED CIRCUITS 50 PACKAGE DIMENSIONS 48-PIN PLASTIC CHIP-SCALE PACKAGE (QFN) 7.000 BSC (0.276) millimeters (inches) Package Type: 48PCS7 Electrically isolated heat sink pad on bottom of package. Connect to any ground or power plane for optimum thermal dissipation. 5.550 ± 0.050 (0.218 ± 0.002) 0.50 BSC (0.0197) 7.000 BSC (0.276) 0.80 max (0.031) Bottom View 5.550 ± 0.050 (0.218 ± 0.002) Top View 0.250 typ (0.010) 0.400 ± 0.050 (0.016 ± 0.002) 0.200 typ (0.008) BSC = “Basic Spacing between Centers” is theoretical true position dimension and has no tolerance. (JEDEC Standard 95) 64-PIN PLASTIC CHIP-SCALE PACKAGE (QFN) millimeters (inches) Package Type: 64PCS Electrically isolated heat sink pad on bottom of package 9.00 BSC (0.354) Connect to any ground or power plane for optimum thermal dissipation 7.25 ± 0.50 (0.285 ± 0.020) 0.50 BSC (0.0197) 9.00 BSC (0.354) 7.25 ± 0.50 (0.285 ± 0.020) Top View Bottom View 0.25 typ (0.10) 0.40 ± 0.10 (0.016 ± 0.004) 0.20 typ (0.008) BSC = “Basic Spacing between Centers” is theoretical true position dimension and has no tolerance. (JEDEC Standard 95) 1.00 max (0.039) HOLT INTEGRATED CIRCUITS 51 PACKAGE DIMENSIONS 52-PIN PLASTIC QUAD FLAT PACK (PQFP) millimeters (inches) Package Type: 52PQS 0.65 BSC (0.026) 13.200 BSC SQ (.520) 10.000 BSC SQ (0.394) 0.310 ± 0.090 (0.012 ± 0.004) 0.880 ± 0.150 (0.035 ± 0.006) 1.60 typ (0.063) 0.20 min (0.008) See Detail A 2.70 MAX. (0.106) 0.30 (0.012)R max 2.00 ± 0.20 (0.079 ± 0.008) 0.13 R min (0.005) BSC = “Basic Spacing between Centers” is theoretical true position dimension and has no tolerance. (JEDEC Standard 95) DETAIL A HOLT INTEGRATED CIRCUITS 52 0° £ Q £ 7°
HI-3220PQIF 价格&库存
很抱歉,暂时无法提供与“HI-3220PQIF”相匹配的价格&库存,您可以联系我们找货
