S-24CS01AFT-TB-G
S-24CS01AFT-TB-G
    ABLIC(艾普凌科)
    TSSOP-8
    IC EEPROM 1KBIT I2C 8TSSOP
S-24CS01AFT-TB-G 数据手册
Rev.4.5_00 S-24CS01A/02A/04A/08A 2-WIRE CMOS SERIAL E2PROM The S-24CS01A/02A/04A/08A is a 2-wired, low power and wide range operation 1-Kbit, 2-Kbit, 4-Kbit and 8-Kbit E2PROM organized as 128 words × 8 bits, 256 words × 8 bits, 512 words × 8 bits and 1024 words × 8 bits in each. Page write and sequential read are available. „ Features • Low power consumption Standby : 2.0 µA Max. (VCC=5.5 V) Read : 0.8 mA Max. (VCC=5.5 V) • Operating voltage range Read : 1.8 to 5.5 V (at −40 to +85°C) Write : 2.55 to 5.5 V (at −40 to +85°C) • Page write : 8 bytes / page (S-24CS01A/02A) 16 bytes / page (S-24CS04A/08A) • Sequential read • Operating Frequency : 400 kHz (VCC = 2.55 to 5.5 V, at −40 to +85°C) • Write disable function when power supply voltage is low • Endurance: 107 cycles/word*1 (at +25°C) write capable, 106 cycles/word*1 (at +85°C) 3 × 105 cycles/word*1 (at +105°C) *1. For each address (Word: 8 bits) • Data retention: 10 years (after rewriting 106 cycles/word at +85°C) • S-24CS01A : 1 Kbit • S-24CS02A : 2 Kbit • S-24CS04A : 4 Kbit • S-24CS08A : 8 Kbit • High-temperature operation : +105°C Max. supported (Only S-24CS0xAFJ-TBH-G, S-24CS0xAFT-TBH-G) • Write protection : 100% • Lead-free product „ Packages Package name 8-Pin DIP 8-Pin SOP(JEDEC) 8-Pin TSSOP SNT-8A Drawing code Package DP008-F FJ008-A FT008-A PH008-A Tape  FJ008-D FT008-E PH008-A Reel  FJ008-D FT008-E PH008-A Land    PH008-A Caution This product is intended to use in general electronic devices such as consumer electronics, office equipment, and communications devices. Before using the product in medical equipment or automobile equipment including car audio, keyless entry and engine control unit, contact to SII is indispensable. Seiko Instruments Inc. 1 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ Pin Configurations 8-Pin DIP Top view Table 1 A0 1 8 VCC A1 2 7 WP A2 3 6 SCL GND 4 5 SDA Figure 1 S-24CS01ADP-G S-24CS02ADP-G S-24CS04ADP-G S-24CS08ADP-1G Pin No. 1 2 3 4 5 6 Symbol A0 A1 A2 GND SDA SCL Description Address input (No connection in S-24CS04A/08A*1) Address input (No connection in S-24CS08A*1) Address input Ground Serial data input / output Serial clock input Write protection input 7 WP Connected to VCC: Protection valid Connected to GND: Protection invalid 8 VCC Power supply *1. Connect to GND or VCC. Remark See Dimensions for details of the package drawings. 8-Pin SOP(JEDEC) Top view A0 1 8 VCC A1 2 7 WP A2 3 6 SCL GND 4 5 SDA Figure 2 S-24CS01AFJ-TB-G S-24CS01AFJ-TBH-G S-24CS02AFJ-TB-G S-24CS02AFJ-TBH-G S-24CS04AFJ-TB-G S-24CS04AFJ-TBH-G S-24CS08AFJ-TB-1G S-24CS08AFJ-TBH-1G 2 Table 2 Pin No. 1 2 3 4 5 6 Symbol A0 A1 A2 GND SDA SCL Description Address input (No connection in S-24CS04A/08A*1) Address input (No connection in S-24CS08A*1) Address input Ground Serial data input / output Serial clock input Write protection input 7 WP Connected to VCC: Protection valid Connected to GND: Protection invalid 8 VCC Power supply *1. Connect to GND or VCC. Remark See Dimensions for details of the package drawings. Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 8-Pin TSSOP Top view 8 7 6 5 1 2 3 4 A0 A1 A2 GND Table 3 VCC WP SCL SDA Figure 3 S-24CS01AFT-TB-G S-24CS01AFT-TBH-G S-24CS02AFT-TB-G S-24CS02AFT-TBH-G S-24CS04AFT-TB-G S-24CS04AFT-TBH-G S-24CS08AFT-TB-1G S-24CS08AFT-TBH-1G Description Address input (No connection in S-24CS04A/08A*1) Address input (No connection in S-24CS08A*1) Address input Ground Serial data input / output Serial clock input Write protection input 7 WP Connected to VCC: Protection valid Connected to GND: Protection invalid 8 VCC Power supply *1. Connect to GND or VCC. Pin No. 1 2 3 4 5 6 Symbol A0 A1 A2 GND SDA SCL Remark See Dimensions for details of the package drawings. SNT-8A Top view A0 A1 A2 GND 1 2 3 4 Table 4 8 7 6 5 VCC WP SCL SDA Figure 4 S-24CS01APH-TF-G S-24CS02APH-TF-G S-24CS04APH-TF-G Pin No. 1 2 3 4 5 6 Symbol A0 A1 A2 GND SDA SCL Description Address input (No connection in S-24CS04A*1) Address input Address input Ground Serial data input / output Serial clock input Write protection input 7 WP Connected to VCC: Protection valid Connected to GND: Protection invalid 8 VCC Power supply *1. Connect to GND or VCC. Remark See Dimensions for details of the package drawings. Seiko Instruments Inc. 3 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ Block diagram WP SCL Start / Stop Detector SDA Serial Clock Controller VCC GND Voltage Detector High-Voltage Generator LOAD COMP Device Address Comparator Data Register INC LOAD A2 R/W *1 A1 *2 A0 Address Counter Y Decoder 2 E PROM Selector Data Output ACK Output Controller DIN DOUT *1. This pin is not available for S-24CS08A. *2. This pin is not available for S-24CS04A/08A. Figure 5 4 X Decoder Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ Absolute Maximum Ratings Table 5 Item Power supply voltage Input voltage Output voltage Operating ambient temperature Storage temperature Symbol VCC VIN VOUT Topr Tstg Ratings −0.3 to +7.0 −0.3 to VCC+0.3 −0.3 to VCC −40 to +105 −65 to +150 Unit V V V °C °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. „ Recommended Operating Conditions Table 6 Item Symbol Power supply voltage Read Operation Write Operation VCC=4.5 to 5.5 V VCC=2.55 to 4.5 V VCC=1.8 to 2.55 V VCC=4.5 to 5.5 V VCC=2.55 to 4.5 V VCC=1.8 to 2.55 V VCC High level input voltage VIH Low level input voltage Conditions VIL Min. 1.8 2.55 0.7×VCC 0.7×VCC 0.8×VCC 0.0 0.0 0.0 −40 to +85°C Typ. Max. 5.5  5.5  VCC  VCC  VCC   0.3×VCC  0.3×VCC  0.2×VCC +85 to +105°C Min. Typ. Max. 4.5 5.5  5.5 4.5  VCC 0.7×VCC        0.0  0.3×VCC       Unit V V V V V V V V „ Pin Capacitance Table 7 Item Symbol Input capacitance CIN Input/output capacitance CI / O (Ta=25°C, f=1.0 MHz, VCC=5 V) Conditions Min. Typ. Max. Unit VIN=0 V (S-24CS01A/02A: SCL, A0, A1, A2, WP) — — 10 pF VIN=0 V (S-24CS04A: SCL, A1, A2, WP) — — 10 pF VIN=0 V (S-24CS08A: SCL, A2, WP) — — 10 pF VI / O=0 V (SDA) — — 10 pF „ Endurance Table 8 Item Symbol Operation temperature −40 to +85°C Endurance NW +85 to +105°C *1. For each address (Word: 8 bits) Min. 106 3×105 Seiko Instruments Inc. Typ. — — Max. — — Unit cycles / word*1 cycles / word*1 5 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ DC Electrical Characteristics Table 9 Item −40 to +85°C +85 to +105°C VCC=4.5 to 5.5 V VCC=2.7 to 4.5 V*1 VCC=1.8 to 2.7 V VCC=4.5 to 5.5 V Conditions Unit f = 400 kHz f = 100 kHz f = 100 kHz f = 350 kHz Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Symbol Current consumption ICC1  (READ) Current consumption ICC2  (WRITE) *1. VCC=2.55 to 4.5 V in Write   0.8   0.3   0.2   0.8 mA   4.0   1.5      4.0 mA Table 10 Item Standby current consumption Input leakage current Output leakage current Symbol ISB VIN=VCC or GND   2.0   2.0   2.0   2.0 µA ILI ILO VIN=GND to VCC VOUT=GND to VCC IOL=3.2 mA IOL=1.5 mA     0.1 0.1   1.0 1.0 0.4 0.3     0.1 0.1   1.0 1.0 0.4 0.3     0.1 0.1   1.0 1.0  0.5     0.1 0.1   1.0 1.0 0.4 0.3 µA µA V V  1.5  5.5 1.5  4.5 1.5  2.55 1.5  5.5 V Low level output voltage VOL Current address hold voltage 6 −40 to +85°C +85 to +105°C VCC=4.5 to 5.5 V VCC=2.55 to 4.5 V VCC=1.8 to 2.55 V VCC=4.5 to 5.5 V Unit Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Conditions VAH Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ AC Electrical Characteristics VCC Table 11 Measurement Conditions Input pulse voltage Input pulse rising / falling time Output judgment voltage Output load 0.1×VCC to 0.9×VCC 20 ns 0.5×VCC 100 pF+ Pull-up resistor 1.0 kΩ R=1.0 kΩ SDA C=100 pF Figure 6 Output Load Circuit Table 12 Item Symbol SCL clock frequency SCL clock time “L” SCL clock time “H” SDA output delay time SDA output hold time Start condition setup time Start condition hold time Data input setup time Data input hold time Stop condition setup time SCL, SDA rising time SCL, SDA falling time Bus release time Noise suppression time fSCL tLOW tHIGH tAA tDH tSU.STA tHD.STA tSU.DAT tHD.DAT tSU.STO tR tF tBUF tI +85 to +105°C −40 to +85°C VCC=4.5 to 5.5 V VCC=2.55 to 4.5 V VCC=1.8 to 2.55 V VCC=4.5 to 5.5 V Unit Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. 0 400 400 0 100 0 350 kHz 0     1.0 4.7 1.1 1.0         µs 0.9 4.0 1.0 0.9         µs 0.1 0.9 0.9 0.1 3.5 0.1 1.0 µs 0.1     50 100 50 ns 50         0.6 4.7 0.6 0.6         µs 0.6 4.0 0.6 0.6         µs 100 200 100 ns 100         0 0 0 ns 0         0.6 4.0 0.6 0.6         µs 0.3 0.3 1.0 0.3 µs         0.3 0.3 0.3 0.3 µs         1.3 4.7 1.3 1.3         µs 50 100 100 50 ns         tHIGH tF tLOW tR SCL tSU.STA tHD.DAT tHD.STA tSU.DAT tSU.STO SDA IN tAA tDH tBUF SDA OUT Figure 7 Bus Timing Seiko Instruments Inc. 7 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 Table 13 Item −40 to +85°C VCC=2.55 to 5.5 V Min. Typ. Max. — 4.0 10.0 Symbol Write time tWR +85 to +105°C VCC=4.5 to 5.5 V Min. Typ. Max. — 4.0 10.0 tWR SCL SDA D0 Stop Condition Write data Acknowledge Figure 8 Write Cycle Timing 8 Seiko Instruments Inc. Start Condition Unit ms 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ Pin Functions 1. Address Input Pins (A0, A1 and A2) The slave address is assigned by connecting pins A0, A1 and A2 to the GND or to the VCC respectively. One of the eight different slave address can be assigned to the S-24CS01A/02A by the combination of pins A0, A1 and A2. The slave address is assigned by connecting pins A1 and A2 to the GND or to the VCC respectively. One of the four different slave address can be assigned to the S-24CS04A by the combination of pins A1 and A2. The slave address is assigned by connecting the A2 pin to the GND or to the VCC respectively. The two different slave address can be assigned to the S-24CS08A by A2 pin. The given slave address, which is compared with the slave address transmitted from the master device, is used to select the one among the multiple devices connected to the bus. The address input pin should be connected to the GND or to the VCC. 2. SDA (Serial Data Input / Output) Pin The SDA pin is used for bi-directional transmission of serial data. It consists of a signal input pin and an Nch open-drain output pin. The SDA line is usually pulled up to the VCC, and OR-wired with other open-drain or open-collector output devices. 3. SCL (Serial Clock Input) Pin The SCL pin is used for serial clock input. Since signals are processed at the rising or falling edge of the SCL clock input signal, attention should be paid to the rising time and falling time to conform to the specifications. 4. WP Pin The write protection is enabled by connecting the WP pin to the VCC. When there is no need for write protection, connect the pin to the GND. Seiko Instruments Inc. 9 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ Operation 1. Start Condition Start is identified by a high to low transition of the SDA line while the SCL line is stable at high. Every operation begins from a start condition. 2. Stop Condition Stop is identified by a low to high transition of the SDA line while the SCL line is stable at high. When a device receives a stop condition during a read sequence, the read operation is interrupted, and the device enters standby mode. When a device receives a stop condition during a write sequence, the reception of the write data is halted, and the E2PROM initiates a write cycle. tSU.STA tHD.STA tSU.STO SCL SDA Start Condition Figure 9 Start / Stop Conditions 10 Seiko Instruments Inc. Stop Condition 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 3. Data Transmission Changing the SDA line while the SCL line is low, data is transmitted. Changing the SDA line while the SCL line is high, a start or stop condition is recognized. tSU.DAT tHD.DAT SCL SDA Figure 10 Data Transmission Timing 4. Acknowledge The unit of data transmission is 8 bits. During the 9th clock cycle period the receiver on the bus pulls down the SDA line to acknowledge the receipt of the 8-bit data. When an internal write cycle is in progress, the device does not generate an acknowledge. SCL 2 (E PROM Input) 1 8 9 SDA (Master Output) SDA (E PROM Output) 2 Acknowledge Output Start Condition tAA tDH Figure 11 Acknowledge Output Timing Seiko Instruments Inc. 11 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 5. Device Addressing To start communication, the master device on the system generates a start condition to the bus line. Next, the master device sends 7-bit device address and a 1-bit read / write instruction code on to the SDA bus. The 4 most significant bits of the device address are called the "Device Code", and are fixed to "1010". In S-24CS01A/02A, successive 3 bits are called the “Slave Address”. These 3 bits are used to identify a device on the system bus and are compared with the predetermined value which is defined by the address input pins (A0, A1 and A2). When the comparison result matches, the slave device responds with an acknowledge during the 9th clock cycle. In S-24CS04A, successive 2 bits are called the "Slave Address". These 2 bits are used to identify a device on the system bus and are compared with the predetermined value which is defined by the address input pins (A1 and A2). When the comparison result matches, the slave device responds with an acknowledge during the 9th clock cycle. The successive 1 bit (P0) is used to define a page address and choose the two 256-byte memory blocks (Address 000h to 0FFh and 100h to 1FFh). In S-24CS08A, successive 1 bit is called the “Slave Addrdess”. This 1 bit is used to identify a device on the system bus and is compared with the predetermined value which is defined by the address input pin (A2). When the comparison result matches, the slave device responds with an acknowledge during the 9th clocks cycle. The successive 2 bits (P1 and P0) are used to define a page address and choose the four 256-byte memory blocks (Address 000h to 0FFh, 100h to 1FFh, 200h to 2FFh and 300h to 3FFh). Device Code S-24CS01A/02A 1 0 1 Slave Address 0 A2 A1 A0 MSB LSB Slave / Page Address Device Code S-24CS04A 1 0 1 0 A2 A1 P0 R/W S-24CS08A 1 0 1 0 A2 P1 P0 R/W MSB LSB Figure 12 Device Address 12 R/W Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 6. Write 6. 1 Byte Write When the master sends a 7-bit device address and a 1-bit read / write instruction code set to "0", following a start condition, the E2PROM acknowledges it. The E2PROM then receives an 8-bit word address and responds with an acknowledge. After the E2PROM receives 8-bit write data and responds with an acknowledge, it receives a stop condition and that initiates the write cycle at the addressed memory. During the write cycle all operations are forbidden and no acknowledge is generated. S T A R T SDA LINE W R I T E DEVICE ADDRESS 1 M S B 0 1 0 A2 A1 A0 0 WORD ADDRESS DATA W7 W6 W5 W4 W3 W2 W1 W0 L R A S / C B WK S T O P D7 D6 D5 D4 D3 D2 D1 D0 A C K A C K ADR INC (ADDRESS INCREMENT) Remark1. A1 is P1 in the S-24CS08A. 2. A0 is P0 in the S-24CS04A/08A. 3. W7 is optional in the S-24CS01A. Figure 13 Byte Write Seiko Instruments Inc. 13 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 6. 2 Page Write The page write mode allows up to 8 bytes to be written in a single write operation in the S-24CS01A/02A and 16 bytes to be written in a single write operation in the S-24CS04A/08A. Basic data transmission procedure is the same as that in the "Byte Write". But instead of generating a stop condition, the master transmits 8-bit write data up to 8 bytes before the page write. When the E2PROM receives a 7-bit device address and a 1-bit read / write instruction code set to "0", following a start condition, it generates an acknowledge. Then the E2PROM receives an 8-bit word address, and responds with an acknowledge. After the E2PROM receives 8-bit write data and responds with an acknowledge, it receives 8-bit write data corresponding to the next word address, and generates an acknowledge. The E2PROM repeats reception of 8-bit write data and generation of acknowledge in succession. The E2PROM can receive as many write data as the maximum page size. Receiving a stop condition initiates a write cycle of the area starting from the designated memory address and having the page size equal to the received write data. S T A R T SDA LINE W R I DEVICE T ADDRESS E 1 M S B 0 1 0 A2 A1 A0 0 WORD ADDRESS (n) W7 W6 W5 W4 W3 W2 W1 W0 L R A S / C B WK Remark1. A1 is P1 in the S-24CS08A. 2. A0 is P0 in the S-24CS04A/08A. 3. W7 is optional in the S-24CS01A. DATA (n) DATA (n+1) D7 D6 D5 D4 D3 D2 D1 D0 A C K D7 A C K ADR INC S T O P DATA (n+x) D0 D7 A C K ADR INC D0 A C K ADR INC Figure 14 Page Write In S-24CS01A/02A, the lower 3 bits of the word address are automatically incremented every time when the E2PROM receives 8-bit write data. If the size of the write data exceeds 8 bytes, the upper 5 bits of the word address remain unchanged, and the lower 3 bits are rolled over and previously received data will be overwritten. In S-24CS04A, the lower 4 bits of the word address are automatically incremented every time when the E2PROM receives 8-bit write data. If the size of the write data exceeds 16 bytes, the upper 4 bits of the word address and page address (P0) remain unchanged, and the lower 4 bits are rolled over and previously received data will be overwritten. In S-24CS08A, the lower 4 bits of the word address are automatically incremented every time when the E2PROM receives 8-bit write data. If the size of the write data exceeds 16 bytes, the upper 4 bits of the word address and page address (P1 and P0) remain unchanged, and the lower 4 bits are rolled over and previously received data will be overwritten. 14 Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 6. 3 Write Protection Write protection is available in the S-24CS01A/02A/04A/08A. When the WP pin is connected to the VCC, write operation to memory area is forbidden at all. When the WP pin is connected to the GND, the write protection is invalid, and write operation in all memory area is available. Fix the level of the WP pin from the rising edge of SCL for loading the last write data (D0) until the end of the write time (10 ms max.). If the WP pin changes during this time, the address data being written at this time is not guaranteed. There is no need for using write protection, the WP pin should be connected to the GND. The write protection is valid in the operating voltage range. tWR SCL D0 SDA Write Data Acknowledge Stop Condition Start Condition WP WP Pin Fixed Period Figure 15 WP Pin Fixed Period 6. 4 Acknowledge Polling Acknowledge polling is used to know the completion of the write cycle in the E2PROM. After the E2PROM receives a stop condition and once starts the write cycle, all operations are forbidden and no response is made to the signal transmitted by the master device. Accordingly the master device can recognize the completion of the write cycle in the E2PROM by detecting a response from the slave device after transmitting the start condition, the device address and the read/write instruction code to the E2PROM, namely to the slave devices. That is, if the E2PROM does not generate an acknowledge, the write cycle is in progress and if the E2PROM generates an acknowledge, the write cycle has been completed. Keep the level of the WP pin fixed until acknowledge is confirmed. It is recommended to use the read instruction "1" as the read/write instruction code transmitted by the master device. Seiko Instruments Inc. 15 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 7. Read 7. 1 Current Address Read Either in writing or in reading the E2PROM holds the last accessed memory address, internally incremented by one. The memory address is maintained as long as the power voltage is higher than the current address hold voltage VAH. The master device can read the data at the memory address of the current address pointer without assigning the word address as a result, when it recognizes the position of the address pointer in the E2PROM. This is called "Current Address Read". In the following the address counter in the E2PROM is assumed to be “n”. When the E2PROM receives a 7-bit device address and a 1-bit read / write instruction code set to “1” following a start condition, it responds with an acknowledge. However, the page address (P0) in S24CS04A and the page address (P1 and P0) in S-24CS08A become invalid and the memory address of the current address pointer becomes valid. Next an 8-bit data at the address "n" is sent from the E2PROM synchronous to the SCL clock. The address counter is incremented at the falling edge of the SCL clock for the 8th bit data, and the content of the address counter becomes n+1. The master device outputs stop condition not an acknowledge ,the reading of E2PROM is ended. S T A R T SDA LINE DEVICE ADDRESS 1 0 1 0 A2 A1 A0 1 M S B NO ACK from Master Device R E A D S T O P D7 D6 D5 D4 D3 D2 D1 D0 L R A S / C B W K DATA ADR INC Remark1. A1 is P1 in S-24CS08A. 2. A0 is P0 in S-24CS04A/08A. Figure 16 Current Address Read Attention should be paid to the following point on the recognition of the address pointer in the E2PROM. In the read operation the memory address counter in the E2PROM is automatically incremented at every falling edge of the SCL clock for the 8th bit of the output data. In the write operation, on the other hand, the upper bits of the memory address (the upper bits of the word address and page address)*1 are left unchanged and are not incremented at the falling edge of the SCL clock for the 8th bit of the received data. *1. S-24CS01A/02A is the upper 5 bits of the word address. S-24CS04A is the upper 4 bits of the word address and the page address P0. S-24CS08A is the upper 4 bits of the word address and the page address P1 and P0. 16 Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 7. 2 Random Read Random read is used to read the data at an arbitrary memory address. A dummy write is performed to load the memory address into the address counter. When the E2PROM receives a 7-bit device address and a 1-bit read / write instruction code set to "0" following a start condition, it responds with an acknowledge. The E2PROM then receives an 8-bit word address and responds with an acknowledge. The memory address is loaded to the address counter in the E2PROM by these operations. Reception of write data does not follow in a dummy write whereas reception of write data follows in a byte write and in a page write. Since the memory address is loaded into the memory address counter by dummy write, the master device can read the data starting from the arbitrary memory address by transmitting a new start condition and performing the same operation in the current address read. That is, when the E2PROM receives a 7-bit device address and a 1-bit read / write instruction code set to "1", following a start condition signal, it responds with an acknowledge. Next, 8-bit data is transmitted from the E2PROM in synchronous to the SCL clock. The master device outputs stop condition not an acknowledge , the reading of E2PROM is ended. S T A R T SDA LINE DEVICE ADDRESS W R I T E 1 0 1 0 A2 A1 A0 0 M S B S T A R T WORD ADDRESS (n) W7W6W5W4W3W2W1W0 L R A S / C B WK DEVICE ADDRESS R E A D 1 0 1 0 A2 A1 A0 1 A C K M S B L R A S / C B W K S T O P NO ACK from Master Device DATA D7 D6 D5 D4 D3 D2 D1 D0 ADR INC DUMMY WRITE Remark1. A1 is P1 in the S-24CS08A. 2. A0 is P0 in the S-24CS04A/08A. 3. W7 is optional in the S-24CS01A. Figure 17 Random Read Seiko Instruments Inc. 17 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 7. 3 Sequential Read When the E2PROM receives a 7-bit device address and a 1-bit read / write instruction code set to "1" following a start condition both in current and random read operations, it responds with an acknowledge. An 8-bit data is then sent from the E2PROM synchronous to the SCL clock and the address counter is automatically incremented at the falling edge of the SCL clock for the 8th bit data. When the master device responds with an acknowledge, the data at the next memory address is transmitted. Response with an acknowledge by the master device has the memory address counter in the E2PROM incremented and makes it possible to read data in succession. This is called "Sequential Read". The master device outputs stop condition not an acknowledge , the reading of E2PROM is ended. Data can be read in succession in the sequential read mode. When the memory address counter reaches the last word address, it rolls over to the first memory address. NO ACK from Master Device R E DEVICE ADDRESS A D SDA LINE 1 R A / C W K A C K A C K D7 D0 D7 D0 D7 DATA (n+1) DATA(n) ADR INC D0 ADR INC Seiko Instruments Inc. D0 D7 DATA (n+2) Figure 18 Sequential Read 18 S T O P A C K DATA (n+x) ADR INC ADR INC 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 8. Address Increment Timing The timing for the automatic address increment is the falling edge of the SCL clock for the 8th bit of the read data in read operation and the falling edge of the SCL clock for the 8th bit of the received data in write operation. SCL SDA 8 9 R / W=1 1 ACK Output 8 D7 Output 9 D0 Output Address Increment Figure 19 Address Increment Timing in Reading SCL 8 SDA 9 R / W=0 1 ACK Output 8 D7 Input D0 Input 9 ACK Output Address Increment Figure 20 Address Increment Timing in Writing „ Write Inhibition Function at Low Power Voltage The S-24CS01A/02A/04A/08A have a detection circuit for low power voltage. The detection circuit cancels a write instruction when the power voltage is low or the power switch is on. The detection voltage is 1.75 V typically and the release voltage is 2.05 V typically, the hysteresis of approximate 0.3 V thus exists. (See Figure 21.) When a low power voltage is detected, a write instruction is canceled at the reception of a stop condition. When the power voltage lowers during a data transmission or a write operation, the data at the address of the operation is not assured. Hysteresis width 0.3 V approximately Power supply voltage Release voltage (+VDET) 2.05 V typ. Detection voltage (-VDET) 1.75 V typ. Write Instruction cancel Figure 21 Operation at low power voltage Seiko Instruments Inc. 19 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ Using S-24CS01A/02A/04A/08A 1. Adding a pull-up resistor to SDA I/O pin and SCL input pin Add a 1 to 5 kΩ pull-up resistor to the SCL input pin*1 and the SDA I/O pin in order to enable the functions of the I2C-bus protocol. Normal communication cannot be provided without a pull-up resistor. *1. When the SCL input pin of the E2PROM is connected to a tri-state output pin of the microprocessor, connect the same pull-up resistor to prevent a high impedance status from being input to the SCL input pin. This protects the E2PROM from malfunction due to an undefined output (high impedance) from the tristate pin when the microprocessor is reset when the voltage drops. 2. I/O pin equivalent circuit The I/O pins of this IC do not include pull-up and pull-down resistors. The SDA pin is an open-drain output. The following shows the equivalent circuits. SCL Figure 22 SCL Pin SDA Figure 23 SDA Pin 20 Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 WP Figure 24 WP Pin A0, A1, A2 Figure 25 A0, A1, A2 Pin Seiko Instruments Inc. 21 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 3. Matching phases while E2PROM is accessed The S-24CS01A/02A/04A/08A does not have a pin for resetting (the internal circuit), therefore, the E2PROM cannot be forcibly reset externally. If a communication interruption occurs in the E2PROM, it must be reset by software. For example, even if a reset signal is input to the microprocessor, the internal circuit of the E2PROM is not reset as long as the stop condition is not input to the E2PROM. In other words, the E2PROM retains the same status and cannot shift to the next operation. This symptom applies to the case when only the microprocessor is reset when the power supply voltage drops. With this status, if the power supply voltage is restored, reset the E2PROM (after matching the phase with the microprocessor) and input an instruction. The following shows this reset method. [How to reset E2PROM] The E2PROM can be reset by the start and stop instructions. When the E2PROM is reading data “0” or is outputting the acknowledge signal, 0 is output to the SDA line. In this status, the microprocessor cannot output an instruction to the SDA line. In this case, terminate the acknowledge output operation or read operation, and then input a start instruction. Figure 26 shows this procedure. First, input the start condition. Then transmit 9 clocks (dummy clocks) of SCL. During this time, the microprocessor sets the SDA line to high level. By this operation, the E2PROM interrupts the acknowledge output operation or data output, so input the start condition*1. When a start condition is input, the E2PROM is reset. To make doubly sure, input the stop condition to the E2PROM. Normal operation is then possible. Start Dummy clock condition SCL 1 2 8 Start Stop condition condition 9 SDA Figure 26 Resetting E2PROM *1. After 9 clocks (dummy clocks), if the SCL clock continues to be output without a start condition being input, a write operation may be started upon receipt of a stop condition. To prevent this, input a start condition after 9 clocks (dummy clocks). Remark It is recommended to perform the above reset using dummy clocks when the system is initialized after the power supply voltage has been raised. 22 Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 4. Acknowledge check The I2C-bus protocol includes an acknowledge check function as a handshake function to prevent a communication error. This function allows detection of a communication failure during data communication between the microprocessor and E2PROM. This function is effective to prevent malfunction, so it is recommended to perform an acknowledge check on the microprocessor side. 5. Built-in power-on-clear circuit E2PROMs have a built-in power-on-clear circuit that initializes the E2PROM. Unsuccessful initialization may cause a malfunction. For the power-on-clear circuit to operate normally, the following conditions must be satisfied for raising the power supply voltage. 5. 1 Raising power supply voltage Raise the power supply voltage, starting at 0.2 V maximum, so that the voltage reaches the power supply voltage to be used within the time defined by tRISE as shown in Figure 27. For example, when the power supply voltage to be used is 5.0 V, tRISE is 200 ms as shown in Figure 28. The power supply voltage must be raised within 200 ms. tRISE (Max.) Power supply voltage (VCC) VINIT (Max.) 0.2 V 0 V*1 tINIT*2 (Max.) *1. 0 V means there is no difference in potential between the VCC pin and the GND pin of the E2PROM. *2. tINIT is the time required to initialize the E2PROM. No instructions are accepted during this time. Figure 27 Raising Power Supply Voltage Seiko Instruments Inc. 23 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 5.0 4.0 Power supply voltage (VCC) [V] 3.0 2.0 50 100 150 200 Rise time (tRISE) Max. [ms] For example: If your E2PROM supply voltage = 5.0 V, raise the power supply voltage to 5.0 V within 200 ms. Figure 28 Raising Time of Power Supply Voltage When initialization is successfully completed via the power-on-clear circuit, the E2PROM enters the standby status. If the power-on-clear circuit does not operate, the following are the possible causes. (1) Because the E2PROM has not been initialized, an instruction formerly input is valid or an instruction may be inappropriately recognized. In this case, writing may be performed. (2) The voltage may have dropped due to power off while the E2PROM is being accessed. Even if the microprocessor is reset due to the low power voltage, the E2PROM may malfunction unless the poweron-clear operation conditions of E2PROM are satisfied. For the power-on-clear operation conditions of E2PROM, refer to 5. 1 Raising power supply voltage. If the power-on-clear circuit does not operate, match the phase (reset) so that the internal E2PROM circuit is normally reset. The statuses of the E2PROM immediately after the power-on-clear circuit operates and when phase is matched (reset) are the same. 24 Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 5. 2 Wait for the initialization sequence to end The E2PROM executes initialization during the time that the supply voltage is increasing to its normal value. All instructions must wait until after initialization. The relationship between the initialization time (tINIT) and rise time (tRISE) is shown in Figure 29. 100 m 10 m E2PROM initialization time (tINIT) Max. [s] 1.0 m 100 µ 10 µ 1.0 µ 1.0 µ 10 µ 100 µ 1.0 m 10 m 100 m Rise time (tRISE) [s] Figure 29 Initialization Time of E2PROM Seiko Instruments Inc. 25 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 6. Data hold time (tHD.DAT = 0 ns) If SCL and SDA of the E2PROM are changed at the same time, it is necessary to prevent the start/stop condition from being mistakenly recognized due to the effect of noise. If a start/stop condition is mistakenly recognized during communication, the E2PROM enters the standby status. It is recommended that SDA is delayed from the falling edge of SCL by 0.3 µs minimum in the S24CS01A/02A/04A/08A. This is to prevent time lag caused by the load of the bus line from generating the stop (or start) condition. tHD.DAT = 0.3 µs Min. SCL SDA Figure 30 E2PROM Data Hold Time 7. SDA pin and SCL pin noise suppression time The S-24CS01A/02A/04A/08A includes a built-in low-pass filter to suppress noise at the SDA and SCL pins. This means that if the power supply voltage is 5.0 V, noise with a pulse width of 160 ns or less can be suppressed. The guaranteed for details, refer to noise suppression time (tI) in Table 12. 300 Noise suppression time (tI) Max. [ns] 200 100 2 3 4 5 Power supply voltage (VCC) [V] Figure 31 Noise Suppression Time for SDA and SCL Pins 26 Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 8. Trap: E2PROM operation in case that the stop condition is received during write operation before receiving the defined data value (less than 8-bit) to SCL pin When the E2PROM receives the stop condition signal compulsorily, during receiving 1 byte of write data, “write” operation is aborted. When the E2PROM receives the stop condition signal after receiving 1 byte or more of data for “page write”, 8-bit of data received normally before receiving the stop condition signal can be written. 9. Trap: E2PROM operation and write data in case that write data is input more than defined page size at “page write” When write data is input more than defined page size at page write operation, for example, S-24CS04A (which can be executed 16-byte page write) is received data more than 17 byte, 8-bit data of the 17th byte is over written to the first byte in the same page. Data over the capacity of page address cannot be written. 10. Trap: Severe environments Absolute maximum ratings: Do not operate these ICs in excess of the absolute maximum ratings (as listed on the data sheet). Exceeding the supply voltage rating can cause latch-up. Operations with moisture on the E2PROM pins may occur malfunction by short-circuit between pins. Especially, in occasions like picking the E2PROM up from low temperature tank during the evaluation. Be sure that not remain frost on E2PROM pin to prevent malfunction by short-circuit. Also attention should be paid in using on environment, which is easy to dew for the same reason. Seiko Instruments Inc. 27 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ Precautions ● Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. ● SII claims no responsibility for any and all disputes arising out of or in connection with any infringement of the products including this IC upon patents owned by a third party. 28 Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ Characteristics (Typical Data) 1. DC Characteristics 1. 1 Current consumption (READ) ICC1  Ambient temperature (Ta) 1. 2 Current consumption (READ) ICC1  Ambient temperature (Ta) VCC=3.3 V fSCL=100 kHz DATA=0101 VCC=5.5 V fSCL=100 kHz DATA=0101 ICC1 (µA) 300 200 300 ICC1 (µA) 200 100 100 0 -40 0 0 85 Ta (°C) 1. 3 Current consumption (READ) ICC1  Ambient temperature (Ta) Ta=25°C fCSL=100 kHz DATA=0101 300 ICC1 (µA) 200 ICC1 (µA) -40 200 0 85 0 Ta (°C) 1. 5 Current consumption (READ) ICC1  Power supply voltage VCC Ta=25°C fSCL=400 kHz DATA=0101 300 200 2 3 4 5 6 7 VCC (V) 1. 6 Current consumption (READ) ICC1  Clock frequency fSCL VCC=5.0 V Ta=25 °C 300 ICC1 (µA) 200 100 100 0 300 100 100 ICC1 (µA) 0 85 Ta (°C) 1. 4 Current consumption (READ) ICC1  Power supply voltage VCC VCC= 1.8 V fSCL=100 kHz DATA=0101 0 -40 2 100 k 3 4 5 6 7 VCC (V) 400 k 1M fSCL (Hz) Seiko Instruments Inc. 29 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 1. 7 Current consumption (PROGRAM) ICC2  Ambient temperature (Ta) 1. 8 Current consumption (PROGRAM) ICC2  Ambient temperature (Ta) VCC=3.3 V VCC=5.5 V 1.0 1.0 ICC2 (mA) ICC2 (mA) 0.5 0 0.5 -40 0 85 0 Ta (°C) 1. 9 Current consumption (PROGRAM) ICC2  Ambient temperature (Ta) 1. 10 Current consumption (PROGRAM) ICC2  Power supply voltage VCC VCC=2.5 V Ta=25°C 1.0 1.0 ICC2 (mA) ICC2 (mA) 0.5 0 0.5 -40 85 0 Ta (°C) 0 1. 11 Standby current consumption ISB  Ambient temperature (Ta) 1 2 3 4 5 6 VCC (V) 1. 12 Input leakage current ILI  Ambient temperature (Ta) VCC=5.5 V A0, A1, A2 SDA, SCL, WP=0 V VCC=5.5 V 2.0 1.0 ISB (µA) ILI (µA) 1.0 0 0.5 -40 0 85 0 -40 85 0 Ta (°C) Ta (°C) 30 85 0 Ta (°C) -40 Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 1. 13 Input leakage current ILI  Ambient temperature (Ta) 1.0 VCC=5.5 V SDA=0 V VCC=5.5 V A0, A1, A2 SDA, SCL, P=5.5 V 1.0 ILO (µA) ILI (µA) 0.5 0.5 0 1. 14 Output leakage current ILO  Ambient temperature (Ta) 0 85 0 Ta (°C) -40 1. 15 Output leakage current ILO  Ambient temperature (Ta) VCC=5.5 V SDA=5.5 V -40 0 1. 16 Low level output voltage VOL  Low level output current IOL Ta=-40°C 0.6 1.0 ILO (µA) VOL 0.4 (V) 0.5 VCC=1.8 V 0.2 0 -40 85 0 0 Ta (°C) 1. 17 Low level output voltage VOL  Low level output current IOL VOL 0.4 (V) VOL 0.4 (V) VCC=1.8 V VCC=5.0 V 2 2 3 4 5 6 Ta=85°C 0.6 1 1 1. 18 Low level output voltage VOL  Low level output current IOL 0.6 0 VCC=5.0 V IOL (mA) Ta=25°C 0.2 85 Ta (°C) 3 4 5 6 VCC=1.8 V VCC=5.0 V 0.2 0 IOL (mA) 1 2 3 4 5 6 IOL (mA) Seiko Instruments Inc. 31 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 1. 19 High input inversion voltage VIH  Power supply voltage VCC 1. 20 High input inversion voltage VIH  Ambient temperature (Ta) Ta=25°C A0, A1, A2, SDA, SCL, WP VCC=5.0 V A0, A1, A2 SDA, SCL, WP 3.0 3.0 VIH 2.0 (V) VIH 2.0 (V) 1.0 1.0 0 0 -40 1 2 3 4 5 6 7 0 Ta (°C) VCC (V) 1. 21 Low input inversion voltage VIL  Power supply voltage VCC 1. 22 Low input inversion voltage VIL  Ambient temperature (Ta) VCC=5.0 V A0, A1, A2, SDA, SCL, WP Ta=25°C A0, A1, A2, SDA, SCL, WP 3.0 3.0 VIL 2.0 (V) VIL 2.0 (V) 1.0 1.0 0 0 -40 1 2 3 4 5 6 7 0 85 Ta (°C) VCC (V) 1. 23 Low power supply detection voltage −VDET  Ambient temperature (Ta) 1. 24 Low power supply release voltage +VDET  Ambient temperature (Ta) 2.0 2.0 -VDET (V) +VDET (V) 1.0 0 -40 1.0 0 85 0 -40 Ta (°C) 32 85 0 85 Ta (°C) Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 2. AC Characteristics 2. 1 Maximum operating frequency fMAX.  Power supply voltage VCC 2. 2 Write time tWR  Power supply voltage VCC Ta=25°C fMAX. (Hz) Ta=25°C 8 1M tWR (ms) 100 k 6 4 10 k 2 1 2 3 4 VCC (V) 0 5 2. 3 Write time tWR  Ambient temperature (Ta) VCC=2.7 V 9 9 tWR 6 (ms) tWR 6 (ms) 3 3 -40 0 Ta (°C) 0 85 2. 5 SDA output delay time tAA  Ambient temperature (Ta) 0 Ta (°C) 85 VCC=2.7 V 1.0 tAA (µs) 0.5 0 -40 2. 6 SDA output delay time tAA  Ambient temperature (Ta) VCC=4.5 V tAA (µs) 3 4 5 6 VCC (V) 2. 4 Write time tWR  Ambient temperature (Ta) VCC=4.5 V 0 1 2 1.0 0.5 -40 85 0 0 Ta (°C) Seiko Instruments Inc. -40 0 Ta (°C) 85 33 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 2. 7 SDA output delay time tAA  Ambient temperature (Ta) VCC=1.8 V tAA (µs) 1.0 0.5 0 34 -40 0 Ta (°C) 85 Seiko Instruments Inc. 2-WIRE CMOS SERIAL E2PROM S-24CS01A/02A/04A/08A Rev.4.5_00 „ Product Name Structure 1. S-24CS01A/02A/04A S-24CS0xA xx - xx x - G Operation temperature none : −40 to +85°C H : −40 to +105°C (Only 8-Pin SOP(JEDEC), 8-Pin TSSOP) IC direction in tape specification (Except 8-Pin DIP) TB : 8-Pin SOP(JEDEC), 8-Pin TSSOP TF : SNT-8A Package code (abbreviation) DP : 8-Pin DIP FJ : 8-Pin SOP(JEDEC) FT : 8-Pin TSSOP PH : SNT-8A Product name S-24CS01A : 1 Kbit S-24CS02A : 2 Kbit S-24CS04A : 4 Kbit 2. S-24CS08A S-24CS08A xx - TB x - 1 G Fixed Operation temperature none : −40 to +85°C H : −40 to +105°C (Only 8-Pin SOP(JEDEC), 8-Pin TSSOP) IC direction in tape specification (Except 8-Pin DIP) Package code (abbreviation) DP : 8-Pin DIP FJ : 8-Pin SOP(JEDEC) FT : 8-Pin TSSOP Product name S-24CS08A : 8 Kbit Seiko Instruments Inc. 35 9.6(10.6max.) 8 5 1 4 0.89 7.62 1.3 2.54 0.48±0.1 +0.11 0.25 -0.05 0° to 15° No. DP008-F-P-SD-3.0 TITLE DIP8-F-PKG Dimensions DP008-F-P-SD-3.0 No. SCALE UNIT mm Seiko Instruments Inc. 5.02±0.2 8 5 1 4 1.27 0.20±0.05 0.4±0.05 No. FJ008-A-P-SD-2.1 TITLE No. SOP8J-D-PKG Dimensions FJ008-A-P-SD-2.1 SCALE UNIT mm Seiko Instruments Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.55±0.05 0.3±0.05 ø2.0±0.05 8.0±0.1 2.1±0.1 5°max. 6.7±0.1 1 8 4 5 Feed direction No. FJ008-D-C-SD-1.1 TITLE SOP8J-D-Carrier Tape No. FJ008-D-C-SD-1.1 SCALE UNIT mm Seiko Instruments Inc. 60° 2±0.5 13.5±0.5 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FJ008-D-R-SD-1.1 TITLE SOP8J-D-Reel No. FJ008-D-R-SD-1.1 SCALE UNIT QTY. mm Seiko Instruments Inc. 2,000 +0.3 3.00 -0.2 8 5 1 4 0.17±0.05 0.2±0.1 0.65 No. FT008-A-P-SD-1.1 TITLE TSSOP8-E-PKG Dimensions FT008-A-P-SD-1.1 No. SCALE UNIT mm Seiko Instruments Inc. 4.0±0.1 2.0±0.05 ø1.55±0.05 0.3±0.05 +0.1 8.0±0.1 ø1.55 -0.05 (4.4) +0.4 6.6 -0.2 1 8 4 5 Feed direction No. FT008-E-C-SD-1.0 TITLE TSSOP8-E-Carrier Tape FT008-E-C-SD-1.0 No. SCALE UNIT mm Seiko Instruments Inc. 13.4±1.0 17.5±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.5 No. FT008-E-R-SD-1.0 TSSOP8-E-Reel TITLE No. FT008-E-R-SD-1.0 SCALE QTY. UNIT mm Seiko Instruments Inc. 3,000 1.97±0.03 8 7 6 5 3 4 +0.05 1 0.5 2 0.08 -0.02 0.48±0.02 0.2±0.05 No. PH008-A-P-SD-2.0 TITLE SNT-8A-A-PKG Dimensions PH008-A-P-SD-2.0 No. SCALE UNIT mm Seiko Instruments Inc. +0.1 ø1.5 -0 5° 2.25±0.05 4.0±0.1 2.0±0.05 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 4 321 5 6 78 Feed direction No. PH008-A-C-SD-1.0 TITLE SNT-8A-A-Carrier Tape PH008-A-C-SD-1.0 No. SCALE UNIT mm Seiko Instruments Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PH008-A-R-SD-1.0 TITLE SNT-8A-A-Reel No. PH008-A-R-SD-1.0 SCALE UNIT QTY. mm Seiko Instruments Inc. 5,000 0.52 2.01 0.52 0.3 0.2 0.3 0.2 0.3 0.2 0.3 Caution Making the wire pattern under the package is possible. However, note that the package may be upraised due to the thickness made by the silk screen printing and of a solder resist on the pattern because this package does not have the standoff. No. PH008-A-L-SD-3.0 TITLE SNT-8A-A-Land Recommendation PH008-A-L-SD-3.0 No. SCALE UNIT mm Seiko Instruments Inc. • • • • • • The information described herein is subject to change without notice. Seiko Instruments Inc. is not responsible for any problems caused by circuits or diagrams described herein whose related industrial properties, patents, or other rights belong to third parties. The application circuit examples explain typical applications of the products, and do not guarantee the success of any specific mass-production design. When the products described herein are regulated products subject to the Wassenaar Arrangement or other agreements, they may not be exported without authorization from the appropriate governmental authority. Use of the information described herein for other purposes and/or reproduction or copying without the express permission of Seiko Instruments Inc. is strictly prohibited. The products described herein cannot be used as part of any device or equipment affecting the human body, such as exercise equipment, medical equipment, security systems, gas equipment, or any apparatus installed in airplanes and other vehicles, without prior written permission of Seiko Instruments Inc. Although Seiko Instruments Inc. exerts the greatest possible effort to ensure high quality and reliability, the failure or malfunction of semiconductor products may occur. The user of these products should therefore give thorough consideration to safety design, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue.
S-24CS01AFT-TB-G
物料型号: - S-24CS01A/02A/04A/08A
器件简介: - 这些是二线制CMOS串行EEPROM,容量分别为1-Kbit、2-Kbit、4-Kbit和8-Kbit,组织为128×8位、256×8位、512×8位和1024×8位。
引脚分配: - 8引脚DIP、8引脚SOP(JEDEC)、8引脚TSSOP和SNT-8A封装,具体引脚功能包括地址输入(A0、A1、A2)、电源(VCC)、地(GND)、串行数据输入/输出(SDA)、串行时钟输入(SCL)和写保护输入(WP)。
参数特性: - 低功耗、宽工作电压范围(1.8V至5.5V)、页写入功能(S-24CS01A/02A为8字节/页,S-24CS04A/08A为16字节/页)、顺序读取、400kHz的工作频率、低电压下写入禁用功能、写入耐久性(107次/字节在25°C)、数据保持时间(10年)。
功能详解: - 包括页写入、顺序读取、当前地址读取、随机读取、写保护和低电压下写入禁止功能。
应用信息: - 适用于一般电子设备,如消费电子、办公设备和通信设备。在医疗设备或汽车设备中使用前,必须与SII联系。
封装信息: - 提供了8引脚DIP、8引脚SOP、8引脚TSSOP和SNT-8A的封装信息,包括尺寸和引脚排列。
注意事项: - 产品不应承受超过绝对最大额定值的条件,以避免物理损坏。 - 推荐操作条件、引脚电容、耐久性、电气特性等详细信息在文档中有具体说明。
绝对最大额定值: - 包括电源电压、输入电压、输出电压、工作环境温度和存储温度。
推荐操作条件: - 包括不同温度范围下的电源电压、高/低电平输入电压等。
引脚电容: - 提供了在特定条件下的输入电容和输入/输出电容数据。
耐久性: - 给出了在不同操作温度下的写入周期数据。
电气特性: - 包括读/写操作的电流消耗、待机电流、输入泄漏电流、输出泄漏电流和低电平输出电压等。
AC电气特性: - 包括时钟频率、时钟时间、数据输入设置时间、停止条件设置时间等。
S-24CS01AFT-TB-G 价格&库存
很抱歉,暂时无法提供与“S-24CS01AFT-TB-G”相匹配的价格&库存,您可以联系我们找货
