RC2512JK-07160RL
RC2512JK-07160RL
    YAGEO(国巨)
    贴片电阻 2512 160Ω ±5% 1W ±100ppm/℃
RC2512JK-07160RL 数据手册
DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC_L series ±0.1%, ±0.5%, ±1%, ±5% Sizes 0075/0100/0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification – May 15, 2020 V.11 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SCOPE This specification describes RC series chip resistors with lead free terminations made by thick film process. RC_L SERIES 2 10 0075 to 2512 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RC XXXX X X X XX XXXX L APPLICATIONS  All general purpose application (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Halogen Free Epoxy  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes, resistors element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production (2) TOLERANCE B = ± 0.1% D = ± 0.5% F = ± 1.0% J = ± 5.0% (for jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel S = ESD safe reel (0075/0100 only) (4) TEMPERATURE COEFFICIENT OF RESISTANCE -= Based on spec. (5) TAPING REEL & POWER 07= 7 inch dia. Reel 10=10 inch dia. Reel 13=13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 7N = 7 inch dia. Reel, ESD safe reel (0075/0100 only) 3W = 13 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩwith ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KL. NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Jul. 7, 2020 V.11 Product specification Chip Resistor Surface Mount RC_L SERIES 3 10 0075 to 2512 MARKING RC0075 / RC0100 / RC0201 / RC0402 No Marking ynsc007 Fig. 1 RC0603 0 1%, 0.5%,E24 exception values 10/11/13/15/20/75 of E24 series YNSC037 Fig. 2 240 = 24 × 100 = 24 88 YNSC038 1%, 0.5%, E96 refer to EIA-96 marking method, including values 10/11/13/15/20/75 of E24 series Fig. 3 88A = 806 × 100 = 806 Ω 03 YNSC001 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 4 Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC2010 / RC2512 00 YNSC004 1%, 0.5%, E24/E96 series : 4 digits First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ 03 YNSC001 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ RC1218 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros YNSC099 Fig. 7 Value = 10 KΩ 00 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros YNSC103 Fig. 8 Value = 10 KΩ For further marking information, please see special data sheet "Chip resistors marking". www.yageo.com Jul. 7, 2020 V.11 Product specification Chip Resistor Surface Mount SERIES RC_L 4 10 0075 to 2512 Outlines CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Ni-barrier) are added, as shown in Fig.9. For dimensions, please refer to Table 1 marking layer overcoat primary glass layer resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode H ceramic substrate I2 overcoat I1 W YNSC086 L 9 Fig. 9 Chip resistor outlines DIMENSION Table 1 TYPE RC0075 L (mm) W (mm) H (mm) I1 (mm) I2 (mm) 0.30±0.01 0.15±0.01 0.13±0.01 0.08±0.03 0.08±0.03 RC0100 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 RC0201 RC0402 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 RC0805 RC1206 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC1210 RC1218 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.20 0.50±0.20 RC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS POWER OPERATING TEMPERATURE RANGE RC0075 -55℃ to 125℃ 1/50 outlines W Fig. 4 Chip resistor RC0100 1/32 W -55℃ to 125℃ MAXIMUM WORKING VOLTAGE 10V 15V MAXIMUM DIELECTRIC OVERLOAD WITHSTANDING VOLTAGE VOLTAGE 25V 30V 25V 30V RESISTANCE RANGE TEMPERATURE COEFFICIENT JUMPER CRITERIA 5% (E24) 10Ω≦R
RC2512JK-07160RL
物料型号:YAGEO RC_L系列
器件简介: - 该系列电阻器采用厚膜工艺制造,具有无铅端子,符合RoHS标准,无卤素。 - 尺寸范围从0075到2512,提供±0.1%、±0.5%、±1%、±5%的容差选项。
引脚分配:未在文档中明确说明具体的引脚分配,但通常这类表面贴装电阻器有两端的金属电极作为接触点。
参数特性: - 电阻器构建在高级陶瓷基板上,内部金属电极与厚膜电阻元件接触。 - 电阻元件由嵌入玻璃中的贵金属组成,覆盖有第二层玻璃以防止环境影响。 - 电阻器通过激光修调至额定电阻值。 - 电阻器覆盖有保护性环氧涂层,最后添加两个外部端子(镍屏障上的亚光锡)。
功能详解: - 电阻器适用于所有通用应用,具有高组件和设备可靠性,节省PCB空间,未使用任何禁止材料。
应用信息: - 适用于一般用途,包括但不限于消费电子、工业控制、医疗设备等。
封装信息: - 提供多种尺寸的封装,从小型的0075到大型的2512,以适应不同的电路设计需求。
订购信息: - 全球零件编号由系列、尺寸、容差、包装类型、温度系数、胶带卷和电阻值等组成。 - 例如,RC0402JR-07100KL表示0402尺寸、±5%容差、7英寸胶带卷、100KΩ电阻值的电阻器。
电气特性: - 提供了详细的电气特性表,包括功率、工作温度范围、最大工作电压、最大电压、电阻范围和温度系数等。
包装风格和包装数量: - 提供了不同尺寸的胶带卷包装,以及相应的包装数量。
测试和要求: - 包括温度系数、寿命/耐久性、高温暴露、耐湿性、湿热、热冲击、板弯曲、焊接性等多个测试项目和要求。
修订历史: - 记录了从2014年12月首次发布到2020年5月的修订历史,包括电阻范围扩展、尺寸更新、测试和要求的更新等。
RC2512JK-07160RL 价格&库存
很抱歉,暂时无法提供与“RC2512JK-07160RL”相匹配的价格&库存,您可以联系我们找货
RC2512JK-07160RL
  • 4000+0.413664000+0.05368
  • 8000+0.389588000+0.05055
  • 12000+0.3778412000+0.04903
  • 20000+0.3651220000+0.04738
  • 28000+0.3578428000+0.04643
  • 40000+0.3509640000+0.04554
库存:2639
RC2512JK-07160RL
  • 50+0.11565
  • 500+0.10409
  • 5000+0.09638
  • 10000+0.09252
  • 30000+0.08866
  • 50000+0.08635
库存:3300
RC2512JK-07160RL
    • 1+1.23140
    • 100+0.80890
    • 1000+0.54850
    • 2000+0.37790
    • 4000+0.26900
    库存:1750
    RC2512JK-07160RL
    • 1+2.205921+0.28622
    • 10+1.1637010+0.15099
    • 25+0.9339525+0.12118
    • 50+0.8001050+0.10382
    • 100+0.69535100+0.09022
    • 250+0.59042250+0.07661
    • 500+0.52998500+0.06877
    • 1000+0.482041000+0.06255
    库存:2639
