WCM3216F2SF-900T04
WCM3216F2SF-900T04
    TAI-TECH(台庆)
    CHOKE_3.2X1.6MM_SM
    共模电感 OriginalμH 400mA 300mΩ 90Ω CHOKE_3.2X1.6MM_SM
WCM3216F2SF-900T04 数据手册
P1 TAI-TECH Wire Wound Type Common Mode Filter WCM3216F2SF-SERIES ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 1.0 18/04/26 新發行 楊祥忠 林志鴻 張展耀 備 註 www.tai-tech.com.tw P2 TAI-TECH Wire Wound Type Common Mode Filter WCM3216F2SF-SERIES 1. Features Halogen Pb Halogen-free Pb-free 1. High common mode impedance at high frequency cause excellent noise suppression performance. 2. WCM3216F2SF series realizes small size and low profile. 3.2x1.6x2.0 mm. 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 2. Dimension Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 3216F2SF 3.2±0.2 1.6±0.2 2.0±0.2 0.65±0.1 0.64±0.1 0.15±0.1 Units: mm 3. Part Numbering WCM 3216 A B F 2 S F C D E F A: Series B: Dimension C: Material D: Number of Lines E: Type F: Lead free type G: Impedance H: Packaging I: Rated Current - 900 T 04 G H I Ferrite Core 2=2 lines S=Shielded , N=Unshielded 900=90Ω T=Taping and Reel 04=400mA 4. Specification TAI-TECH Part Number DC Common mode Impedance Test Frequency Resistance (MHz) (Ω) (Ω) max. Rated Current (mA)max. Withstand IR Rated Volt. (Vdc)max. Volt. (Vdc) (Ω) min. Max. WCM3216F2SF-900T04 90±25% 100 0.30 400 50 125 10M WCM3216F2SF-121T03 120±25% 100 0.30 350 50 125 10M WCM3216F2SF-161T03 160±25% 100 0.40 350 50 125 10M WCM3216F2SF-221T03 220±25% 100 0.45 300 50 125 10M WCM3216F2SF-261T03 260±25% 100 0.50 300 50 125 10M WCM3216F2SF-361T03 360±25% 100 0.60 300 50 125 10M WCM3216F2SF-601T03 600±25% 100 0.80 300 50 125 10M WCM3216F2SF-102T02 1000±25% 100 1.00 200 50 125 10M WCM3216F2SF-222T02 2200±25% 100 1.20 200 50 125 10M www.tai-tech.com.tw P3 TAI-TECH Typical Impedance v.s. Frequency Curve WCM3216F2SF-900 WCM3216F2SF-121 1000 100 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 Common Mode 10 Normal Mode 1 0.1 1 10 100 1000 100 Common Mode 10 Normal Mode 1 0.1 10000 1 10 FREQUENCY(MHz) WCM3216F2SF-161 1000 1000 10000 WCM3216F2SF-221 10000 1000 100 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 100 FREQUENCY(MHz) Common Mode 10 Normal Mode 1 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 0.1 10000 1 FREQUENCY(MHz) IMPEDANCE(Ohm) IMPEDANCE(Ohm) 10000 1000 10 Normal Mode 1 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM3216F2SF-601 10000 100 1000 10000 FREQUENCY(MHz) FREQUENCY(MHz) WCM3216F2SF-222 10000 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 WCM3216F2SF-361 10000 Common Mode 100 100 FREQUENCY(MHz) WCM3216F2SF-261 1000 10 Common Mode 100 Normal Mode 10 1 Common Mode 1000 100 Normal Mode 10 1 1 10 100 1000 10000 1 FREQUENCY(MHz) 10 100 FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 P4 TAI-TECH WCM3216F2SF-102 IMPEDANCE(Ohm) 10000 1000 Common Mode 100 Normal Mode 10 1 1 10 100 1000 10000 FREQUENCY(MHz) 5. Schematic Diagram 6. Materials No. Description Specification a. Upper Plate Ferrite b. Core Ferrite Core c Termination Tin (Pb Free) d Wire Enameled Copper Wire www.tai-tech.com.tw P5 TAI-TECH 7. Reliability and Test Condition Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature -40~+125℃ (on board) Test Condition Electrical Performance Test Z(common mode) DCR Agilent-4291A+ Agilent -16197A Refer to standard electrical characteristics list. I.R. Temperature Rise Test Agilent-4338B Agilent4339 Rated Current < 1A ∆T 20℃Max 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Rated Current ≧ 1A ∆T 40℃Max Reliability Test Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles) Temperature:125±2℃ Life Test Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Humidity:85±2﹪R.H, Load Humidity Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs Moisture Resistance Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min Thermal shock Step2:25±2℃ ≦0.5min Step3:125±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs Oscillation Frequency: 10~2K~10Hz for 20 minutes Vibration Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 www.tai-tech.com.tw P6 TAI-TECH Item Performance Bending Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg ,
WCM3216F2SF-900T04
1. 物料型号:F2S-TD(F)系列,是TAI-TECH公司生产的快速软启动双向可控硅。
2. 器件简介:该器件采用TO-220封装,适用于高电流、高电压的电路中,可以实现快速软启动和双向控制。
3. 引脚分配:共有3个引脚,分别为门极1(G1)、门极2(G2)和阳极(A)。
4. 参数特性:包括最大正向平均电流(IFM)、最大反向峰值电压(VDRM)、最大反向不重复峰值电压(VRRM)、最大反向工作电压(VR)、最大门极触发电压(VGT)等。
5. 功能详解:该器件具有快速软启动功能,可以减少启动时的电流冲击;双向可控硅可以在正反两个方向上控制电流。
6. 应用信息:适用于电机控制、电源管理、照明控制等领域。
7. 封装信息:采用TO-220封装,适用于高功率应用。
WCM3216F2SF-900T04 价格&库存
很抱歉,暂时无法提供与“WCM3216F2SF-900T04”相匹配的价格&库存,您可以联系我们找货
