U235-091N-4BLRC16-2-5
    XKB(中国星坤)
    插件
    USB连接器 9Pin 弯插 Type-B
U235-091N-4BLRC16-2-5 数据手册
Pin # SIGNAL NAME DESCRIPTION MATING SEQUENCE 1 VBUS POWER SECOND 2 D- THIRD 3 D+ USB 2.0 DIFFERENTIAL PAIR 4 5 GND GROUND FOR POWER RETURN SECOND StdA_SSRX- SUPERSPEED RECEIVER DIFFERENTIAL PAIR LAST 6 StdA_SSRX+ 7 GND_DRAIN GROUND FOR SIGNAL RETURN 8 StdA_SSTX- 9 SUPERSPEED TRANSMITTER DIFFERENTIAL PAIR StdA_SSTX+ Shell Shield CONNECTOR METAL SHELL Material Housing Material: LCP, UL94V-0, blue Contact Terminal: Brass Metallic Shell:Brass Plating Underplating: Nickel Contact Plating: 1µ" Gold Solder Tail: 100µ" Min. Tin Metallic Shell: Nickel Electrical Voltage Rating: 100 V AC Current Rating: 1.5A Contact Resistance: 30mΩ Max. Insulation resistance: 1000MΩ Min. Dielectric withstanding voltage: 100V AC/Minute Mechanical Durability: 1500 cycles Mating Force: 35N (3.57Kgf) Max Unmating Force: 10N (1.02Kgf) Min. initial, 8N min after test Environmental and Processing Operating Temperature: -40°C to +85°C FRIST 6.59 [0.259] 5.60 [0.220] POS 9 3.89 [0.153] 2.20 [0.087] 1.61 [0.063] 18.30 [0.720] 12.21 [0.481] 12.90 [0.508] A 14.26 [0.561] POS 5 2.00 [0.079] 2.71 [0.107] 2.00 [0.079] 4.00 [0.157] 10.30 [0.406] A 8.45 [0.333] 1.87 [0.074] 14.40 [0.567]±0.3 12.00 [0.472] 12.04 [0.474] 8.50 [0.335] 1.77 [0.070] 2.00 [0.079] U235-09XN-4BLRC16-2 1.75 [0.069] Ø0.70 [Ø0.028] 2.00 [0.079] 0.1 5 6 7 8 2 1 3 4 9 A B 1:Au 1U" 5:Au 15U" 6:Au 30U" T:TIN N:NICKEL Ø0.92 [Ø0.036] 0.1 A B Ø2.30 [Ø0.091](2x) 10.30 [0.406] 2.71 [0.107] 0.50 [0.020](5X) 2.50 [0.098] 5.00 [0.197] 8.50 [0.335] A 2.50 [0.098] 4.77 [0.188] CONNECTOR FRONT EDGE RECOMMANDED PCBA LAYOUT X X X MARK DATE DESCRIPTION REVISIONS www.xk-dg.cn www.helloxkb.com B REVISED APPROVED ANGLAR L≤4 4
U235-091N-4BLRC16-2-5 价格&库存
很抱歉,暂时无法提供与“U235-091N-4BLRC16-2-5”相匹配的价格&库存,您可以联系我们找货
