CERAMIC DISC CAPACITOR
Product Part Number Expression
M
2
CT81
1
1
5
3
Y5V
4
5
5
B
6
102
7
M
8
T
9
E
10
Product Type
Product Type
Type code
CC81
High voltage temperature compensation capacitor
CT1
Low voltage high dielectric constant disk ceramic capacitor
CT81
High voltage high dielectric constant disk ceramic capacitor
CS1
Semiconductor disk ceramic capacitor
CT7
Alternating current disk ceramic capacitor
2
Voltage Code
F
Code
Rated Voltage
50V
L
N
M
500V 1KV
2KV
Q
P
3KV 4KV
S
6KV
U
W
X
Y
250 VAC
400VAC
Z
8KV 10KV 15KV
The Code Chip Diameter Range
3
Code
5
6
10
12
Diameter(mm)
4.5-5.4
5.5-6.4
9.5-10.4
11.5-12.4
4
EIA
Temperature Characteristics ( temperature coefficient and EIA code):
TemperatureCharacteristics
USE code
Temperature
range
EIA code
Capacitance with
temperature change rate
NP0
C0H
N750
U2J
SL
S2L
Y5P
Y5P
Y5R
Y5R
Y5U
Y5U
+22/-56%
Y5V
Y5V
+22/-82%
60PPM/
750
120PPM/
+140~-1000PPM/
-25~-+85
10%
15%
207
5
Lead style
Code
lead Style
1
(16-28mm) Straight lead (16~28m)
3
short lead( cut the feet)
4
Tape straight lead
5
Tape small inside kink
6
Tape large inside kink
Special Straight lead
7
6
9
Outside kink
vertical kink lead
Lead Spacing
B
Code
D
7.5 0.5
5.0 0.5
7
E
K
10.0 0.5
12.5 0.5
Standard capacitance
100
10PF
560
56PF
821
820PF
102
1000PF
pF
3
Note: The unit of standard capacitance if consisting of 3 digits,
the first and second digits stand for effective value of the Standard
capacitance;third digit indicates the number of zeros.
8
Capacitance Tolerance
Code
Tolerance
9
K
10%
Z
20%
+80%~-20%
Packing style
Code
Packing style
10
M
S
T
bulk
Taping
Coating style
code
Coating style
E
P
Epoxy resin
208
Phenol resin
Product Structure and Overall Dimensions
Lead shape
209
Packing style
Bulk
Taping products
Taping products ( P 0 =12.7mm
F=5.0mm,F=7.5mm)
Taping products(P 0 =15.0mm,F=7.5mm)
Taping products(P 0 =15.0mm,F=10.0mm)
210
Packing style
products paking
Packing style
Lead spacing
F=5.0
Bulk
F=7.5
Bulk
Taping(P0=12.7mm D
CT81-M7Y5P1B102KSEW 价格&库存
很抱歉,暂时无法提供与“CT81-M7Y5P1B102KSEW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15903
- 100+0.14508
- 500+0.13578
- 1000+0.12648
- 5000+0.11532
- 10000+0.11067
