NST175 0.5°C Accurate Temperature
Sensor with I2C and SMBus Interface
NOVOSENSE
Datasheet 1.2
⚫ Features:
⚫ Description
The NST175 is a lower power, higher accuracy
digital temperature sensors ideal for negative
temperature coefficient (NTC) and positive
temperature
coefficient
(PTC)
thermistor
replacement. NST175 Compatible with two-wire
SMBus and I2C interfaces, supports up to 27
devices address and provides SMBus Reset and
Alert function. The NST175 also feature a SMBus
Alert function. The devices offer a typical
accuracy of 0.5 °C without requiring calibration or
external component signal conditioning. The
NST175 temperature sensors are highly linear and
do not require complex calculations or look-up
tables to derive the temperature. The on-chip 12bit analog-to-digital converter (ADC) offers
resolutions down to 0.0625°C. NST175 device
works over a temperature range of –55°C to 125°C,
which makes it suitable for onboard and off board
applications in automotive, industrial, and
consumer markets. The NST175 is very low power
device, which can be applied in IoT. The NST175
is available in an SOIC-8 package and an MSOP-8
package.
➢ High Accuracy Over –55°C to 125°C
Wide Temperature Range
✓ -20 °C ~ 85 °C : 0.5 °C (Typical)
✓ -20 °C ~ 85 °C : 1 °C (Maximum)
✓ -55 °C ~-20 °C: 2 °C (Maximum)
✓ 85 °C ~125 °C: 2 °C (Maximum)
➢ Proportional to Temperature
0.0625°C Resolution
with
➢ Power up Defaults Permit Stand-Alone
Operation as Thermostat
➢ Supports up to 27 Device Addresses
➢ Supply Operation range from 1.62V to
5.5V
➢ Operating current: 30uA(Typical)
➢ Shutdown current: 0.1μA (Typical)
➢ Digital Interface: SMBus, I2C
➢ Package
⚫ Applications
✓ MSOP(8) (3mm x 3mm)
✓ SOIC(8)(4.9mm x 3.91mm)
➢ General System Thermal Management
➢ Computer Peripheral Thermal Protection
Typical Application
➢ Notebook Computers
➢ Industrial Internet of Things (IoT)
➢ Communications Infrastructure
➢ Power-system monitors
➢ Thermal protection
➢ Environmental Monitoring and HVAC
Novosense Confidential
Page 1
NST175
Idenx
1.0
ABSOLUTE MAXIMUM RATINGS ............................................................................................................................... 3
2.0
ELECTRICAL CHARACTERISTICS ............................................................................................................................ 3
2.1.
2.2.
2.3.
3.0
ELECTRICAL CHARACTERISTICS ........................................................................................................................................ 3
I2C TIMING DIAGRAM ....................................................................................................................................................... 5
I2C TIMING CHARACTERISTICS .......................................................................................................................................... 5
TYPICAL CHARACTERISTICS .................................................................................................................................... 6
4.0 FUNCTION DESCRIPTION ................................................................................................................................................. 7
4.1. FUNCTION DESCRIPTION .................................................................................................................................................... 7
4.2. FEATURE DESCRIPTION ..................................................................................................................................................... 7
4.2.1
Digital Temperature Sensor ...................................................................................................................................... 7
4.2.2
Serial Interface .......................................................................................................................................................... 8
4.2.3
I2C Timing Diagram ............................................................................................................................................... 11
4.3
DEVICE FUNCTIONAL MODES ......................................................................................................................................... 14
4.3.1
Shutdown Mode (SD) ............................................................................................................................................. 14
4.3.2
One-shot (OS) ......................................................................................................................................................... 14
4.3.3
Thermostat Mode (TM) .......................................................................................................................................... 14
4.4
PROGRAMMING ............................................................................................................................................................... 14
4.4.1
Pointer Register ...................................................................................................................................................... 14
4.4.2
Temperature Register .............................................................................................................................................. 15
4.4.3
Configuration Register........................................................................................................................................... 16
5.0 TYPICAL APPLICATION ................................................................................................................................................... 20
5.1 APPLICATION INFORMATION ................................................................................................................................................. 20
5.2
TYPICAL APPLICATION ..................................................................................................................................................... 20
6.0 PACKAGE INFORMATION ............................................................................................................................................... 21
6.1 PINOUT DESCRIPTION ............................................................................................................................................................ 21
6.2 MSOP(8) PACKAGE ......................................................................................................................................................... 22
6.3 SOP(8) PACKAGE ............................................................................................................................................................ 23
7.0
ORDER INFORMATION ............................................................................................................................................... 24
8.0 REVISION HISTORY .......................................................................................................................................................... 25
Page 2
NST175
1.0 ABSOLUTE MAXIMUM RATINGS
Parameters
Symbol
Min
VDD
-0.3
6.5
V
Voltage at A0, A1and
A2 Pins
A0,A1,A2
-0.3
6.5
V
Voltage at OS, SCL and
SDA Pins
ALERT,SCL,
SDA
-0.3
6.5
V
-60
155
-55
125
155
Supply Voltage Pin
(VDD)
Storage temperature
Operation temperature
TBoperation
Typ
Max
Maximum junction
temperature
ESD susceptibility
Unit
HBM
±5
KV
CDM
±1
KV
Comments
2.0 ELECTRICAL CHARACTERISTICS
2.1. Electrical characteristics
Parameters
Symbol
Min
Typ
Max
Unit
Supply voltage
Range
VDD
1.62
3.3
5.5
V
Pull up resistor
Range
Rpu
0.5
5
10
KΩ
Comments
Supply
m℃/
V
16
Supply sensitivity
Operation current
Iconv
30
Shutdown current
ISD
ISD
50
uA
Conversion
0.1
uA
Serial bus inactive
60
uA
Serial bus active, SCL
frequency = 400 kHz
Temperature Range and Resolution
Temperature Range
-55
0.0625
Resolution
Accuracy
125
1
From -20℃ to 85℃
2
2
From -50℃ to -20℃
2
2
From 85℃ to125℃
-1
0.5
Page 3
NST175
Conversion time
TCONV
16
24
ALERT Output
Saturation Voltage
ALERT Delay
1
32
ms
For VDD
很抱歉,暂时无法提供与“NST175H-QSPR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.39040
- 10+3.46920
- 30+3.00860
- 100+2.54800
