NSI8141W1
NSI8141W1
    NOVOSENSE(纳芯微)
    SOIC-16
    高可靠性四通道数字隔离器
NSI8141W1 数据手册
NSi8140/NSi8141/NSi8142: High Relia bility Quad-Channel Digital Isolators NOVOSENSE Datasheet (EN) 1.2 SOIC-16 narrow body SOIC-16 wide body Product Overview The NSi814x devices are high reliability quadchannel digital isolators. The NSi814x device is safety certified by UL1577 support several insulation withstand voltages (3.75kVrms, 5kVrms), while providing high electromagnetic immunity and low emissions at low power consumption. The data rate of the NSi814x is up to 150Mbps, and the common-mode transient immunity (CMTI) is up to 150kV/us. The NSi814x device provides digital channel direction configuration and the default output level configuration when the input power is lost. Wide supply voltage of the NSi814x device support to connect with most digital interface directly, easy to do the level shift. High system level EMC performance enhance reliability and stability of use. AEC-Q100 (Grade 1) option is provided for all devices. Key Features  Up to 5000VRMS Insulation voltage  Date rate: DC to 150Mbps    Power supply voltage: 2.5V to 5.5V AEC-Q100 Grade 1 available for All devices High CMTI: 150kV/us Chip level ESD: HBM: ±6kV  High system level EMC performance: Enhanced system level ESD, EFT, Surge immunity Default output high level or low level option Isolation Barrier Life: >60 years  Low power consumption: 1.5mA/ch (1 Mbps) Low propagation delay: 600 V DIN EN 60112 (VDE 0303-11); IEC 60112 Material Group Ⅰ 3.2. DIN VDE V 0884-10 (VDE V 0884-10) INSULATION CHARATERISTICS Description Test Condition Symbol Value NBSOIC-16 WBSOIC-16 For Rated Mains Voltage ≤ 150Vrms Ⅰto Ⅳ Ⅰto Ⅳ For Rated Mains Voltage ≤ 300Vrms Ⅰto Ⅲ Ⅰto Ⅳ For Rated Mains Voltage ≤ 400Vrms Ⅰto Ⅲ Ⅰto Ⅳ Unit Installation Classification per DIN VDE 0110 Climatic Classification 10/105/21 Pollution Degree per DIN VDE 0110, 2 10/105/21 2 Table 1 Maximum repetitive isolation voltage Input to Output Test Voltage, Method B1 V IORM × 1. 5 = V pd (m) , 100% production test, VIORM 565 800 Vpeak V pd (m) 847 1200 Vpeak V pd (m) 678 960 Vpeak t ini = t m = 1 sec, partial discharge < 5 pC Input to Output Test Voltage, Method A After Environmental Tests Subgroup 1 V IORM × 1.2 = V pd (m) , t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC Novosense Confidential Page 11 NSi8140/NSi8141/NSi8142 After Input and /or Safety Test Subgroup 2 and Subgroup 3 V IORM × 1.2= V pd (m) , t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC V pd (m) 678 960 Vpeak t = 60 sec VIOTM 5300 7000 Vpeak Test method per IEC60065,1.2/50us waveform, VTEST=VIOSM VIOSM 5384 5384 Vpeak VIO =500V RIO >109 >109 Ω f = 1MHz CIO 0.6 0.6 pF Input capacitance CI 2 2 pF Total Power Dissipation at 25℃ Ps Maximum transient isolation voltage Maximum Surge Isolation Voltage Isolation resistance Isolation capacitance θJA = 140 °C/W, V I = 5.5 V, T J = 150 °C, T A = 25 °C Safety input, output, or supply current 160 Is θJA = 84 °C/W, V I = 5.5 V, T J = 150 °C, T A = 25 °C Case Temperature Ts Saftey Limiting Current (mA) 1499 150 W mA 237 mA 150 ℃ 180 160 140 120 100 80 60 40 20 0 0 50 100 150 200 Case Temperature (℃) Saftey Limiting Current (mA) Figure 3.1 NSi8140N/NSi8141N/NSi8142N Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN V VDE V 0884-10 250 200 150 100 50 0 0 50 100 150 Case Temperature (℃) Novosense Confidential Page 12 200 NSi8140/NSi8141/NSi8142 Figure 3.2 NSi8140W/NSi8141W/NSi8142W Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN V VDE V 0884-10 3.3. REGULATORY INFORMATION The NSi8140N/NSi8141N/NSi8142N are approved or pending approval by the organizations listed in table. UL UL 1577 Component Recognition Program1 CSA Approved under CSA Component Acceptance Notice 5A File (pending) 1 CQC DIN V VDE V088410 (VDE V 088410):2006-122 Certified by CQC11471543-2012 400VRMS basic insulation working voltage Basic Insulation 565Vpeak, VIOSM=7000Vpeak Basic insulation at 400VRMS (565Vpeak) File (pending) File (pending) IEC60950-1 Single Protection, 3750Vrms Isolation voltage VDE GB4943.1-2011 File (pending) In accordance with UL 1577, each NSi8140N/NSi8141N/NSi8142N is proof tested by applying an insulation test voltage ≥ 4500 V rms for 1 sec. 2 In accordance with DIN V VDE V 0884-10, each NSi8140N/NSi8141N/NSi8142N is proof tested by applying an insulation test voltage ≥ 1059 V peak for 1 sec (partial discharge detection limit = 5 pC). The * marking branded on the component designates DIN V VDE V 0884-10 approval. The NSi8140W/NSi8141W/NSi8142W are approved or pending approval by the organizations listed in table. UL UL 1577 Component Recognition Program CSA Approved under CSA Component Acceptance Notice 5A VDE DIN V VDE V088410 (VDE V 088410):2006-12 CQC Certified by CQC11471543-2012 GB4943.1-2011 IEC60950-1 Single Protection, 5000Vrms Isolation voltage 800VRMS basic insulation working voltage 400VRMS Reinforced insulation working voltage File (pending) 1 File (pending) Basic Insulation 1131Vpeak, VIOSM=5384Vpeak File (pending) Basic insulation at 800VRMS (1131Vpeak) Reinforced insulation at 400VRMS (565Vpeak) File (pending) In accordance with UL 1577, each NSi8140W/NSi8141W/NSi8142W is proof tested by applying an insulation test voltage ≥ 6000 V rms for 1 sec. 2 In accordance with DIN V VDE V 0884-10, each NSi8140W/NSi8141W/NSi8142W is proof tested by applying an insulation test voltage ≥ 1592 V peak for 1 sec (partial discharge detection limit = 5 pC). The * marking branded on the component designates DIN V VDE V 0884-10 approval. 4.0 FUNCTION DESCRIPTION The NSi814x is a Quad-channel digital isolator based on a capacitive isolation barrier technique. The digital signal is modulated with RF carrier generated by the internal oscillator at the Transmitter side. Then it is transferred through the capacitive isolation barrier and demodulated at the Receiver side. The NSi814x devices are high reliability quad-channel digital isolator with AEC-Q100 qualified. The NSi814x device is safety certified by UL1577 support several insulation withstand voltages (3.75kVrms, 5kVrms), while providing high electromagnetic immunity and low emissions at low power consumption. The data rate of the NSi814x is up to 150Mbps, and the common-mode transient immunity (CMTI) is up to 150kV/us. The NSi814x device provides digital channel direction configuration and the default output level configuration when the input power is lost. Wide supply voltage of the NSi814x device support to connect with most digital interface directly, easy to do the level shift. High system level EMC performance enhance reliability and stability of use. The NSi814x has a default output status when VDDIN is unready and VDDOUT is ready as shown in Table 4.1, which helps for diagnosis when power is missing at the transmitter side. The output B follows the same status with the input A within 1us after powering up. Novosense Confidential Page 13 NSi8140/NSi8141/NSi8142 Table 4.1 Output status vs. power status Input ENX VDD1 status VDD2 status Output Comment H H or NC Ready Ready H Normal operation. L H or NC Ready Ready L X L Ready Ready Z Output Disabled, the output is high impedance X H or NC Unready Ready L H The output follows the same status with the input within 60us after input side VDD1 is powered on. X L Unready Ready Z Output Disabled, the output is high impedance X X Ready Unready X The output follows the same status with the input within 60us after output side VDD2 is powered on. 5.0 APPLICATION NOTE 5.1. PCB LAYOUT The NSi814x requires a 0.1 µF bypass capacitor between VDD1 and GND1, VDD2 and GND2. The capacitor should be placed as close as possible to the package. Figure 5.1 to Figure 5.2 show the recommended PCB layout, make sure the space under the chip should keep free from planes, traces, pads and via. To enhance the robustness of a design, the user may also include resistors (50– 300 Ω ) in series with the inputs and outputs if the system is excessively noisy. The series resistors also improve the system reliability such as latch-up immunity. The typical output impedance of an isolator driver channel is approximately 50 Ω, ±40%. When driving loads where transmission line effects will be a factor, output pins should be appropriately terminated with controlled impedance PCB traces. Figure5.1 Recommended PCB Layout — Top Layer Figure5.2 Recommended PCB Layout — Bottom Layer 5.2. HIGH SPEED PERFORMANCE Figure 5.5 shows the eye diagram of NSi814x at 200Mbps data rate output. The result shows a typical measurement on the NSi814x with 350ps p-p jitter. Novosense Confidential Page 14 NSi8140/NSi8141/NSi8142 Figure5.3 NSi814x Eye Diagram 5.3. TYPICAL SUPPLY CURRENT EQUATIONS The typical supply current of NSi814x can be calculated using below equations. IDD1 and IDD2 are typical supply currents measured in mA, f is data rate measured in Mbps, CL is the capacitive load measured in pF NSi8140: IDD1 = 0.19 *a1+1.45*b1+0.82*c1. IDD2 = 1.36+ VDD1*f* CL *c1*10-9 When a1 is the channel number of low input at side 1, b1 is the channel number of high input at side 1, c1 is the channel number of switch signal input at side 1. NSi8141: IDD1 = 0.87 +1.26*b1+0.63*c1+ VDD1*f* CL *c2*10-9 IDD2 = 0.87 +1.26*b2+0.63*c2+ VDD1*f* CL *c1*10-9 When b1 is the channel number of high input at side 1, c1 is the channel number of switch signal input at side 1, b2 is the channel number of high input at side 2, c2 is the channel number of switch signal input at side 2. NSi8142: IDD1 = 0.87 +1.26*b1+0.63*c1+ VDD1*f* CL *c2*10-9 IDD2 = 0.87 +1.26*b2+0.63*c2+ VDD1*f* CL *c1*10-9 When b1 is the channel number of high input at side 1, c1 is the channel number of switch signal input at side 1, b2 is the channel number of high input at side 2, c2 is the channel number of switch signal input at side 2. Novosense Confidential Page 15 NSi8140/NSi8141/NSi8142 6.0 PACKAGE INFORMATION VDD1 1 16 VDD2 VDD1 1 16 VDD2 GND1 2 15 GND2 GND1 2 15 GND2 INA 3 14 OUTA INA 3 14 OUTA INB 4 13 OUTB INB 4 13 OUTB INC 5 12 OUTC INC 5 12 OUTC IND 6 11 OUTD OUTD 6 11 IND EN1 7 10 EN2 NC 7 GND1 8 10 EN2 NSI8140 9 GND2 Figure 6.1 NSi8140N Package GND1 8 Figure 6.2 NSi8141N Package VDD1 1 16 VDD2 GND1 2 15 GND2 INA 3 14 OUTA INB 4 13 OUTB OUTC 5 12 INC OUTD 6 11 IND EN1 7 10 EN2 GND1 8 NSI8141 9 GND2 NSI8142 9 GND2 Figure 6.3 NSi8142N Package Figure 6.4 NB SOIC16 Package Shape and Dimension in millimeters (inches) Table6.1 NSi8140N/ NSi8141N/ NSi8142N Pin Configuration and Description Novosense Confidential Page 16 NSi8140/NSi8141/NSi8142 NSi8140N PIN NO. NSi8141N PIN NO. NSi8142N PIN NO. SYMBOL FUNCTION 1 1 1 VDD1 Power Supply for Isolator Side 1 2 2 2 GND1 Ground 1, the ground reference for Isolator Side 1 3 3 3 INA Logic Input A 4 4 4 INB Logic Input B 5 5 12 INC Logic Input C 6 11 11 IND Logic Input D 7 7 7 NC/ EN1 No Connection. or Output Enable 1. Active high logic input. When EN1 is high or NC, the output of Side 1 are enabled. When EN1 is low, the output of Side 1 are disabled to high impedance state. 8 8 8 GND1 Ground 1, the ground reference for Isolator Side 1 9 9 9 GND2 Ground 2, the ground reference for Isolator Side 2 10 10 10 EN2 Output Enable 2. Active high logic input. When EN2 is high or NC, the output of Side 2 are enabled. When EN2 is low, the output of Side 2 are disabled to high impedance state. 11 6 6 OUTD Logic Output D 12 12 5 OUTC Logic Output C 13 13 13 OUTB Logic Output B 14 14 14 OUTA Logic Output A 15 15 15 GND2 Ground 2, the ground reference for Isolator Side 2 16 16 16 VDD2 Power Supply for Isolator Side 2 VDD1 1 16 VDD2 VDD1 1 16 VDD2 GND1 2 15 GND2 GND1 2 15 GND2 INA 3 14 OUTA INA 3 14 OUTA INB 4 13 OUTB INB 4 13 OUTB INC 5 12 OUTC INC 5 12 OUTC IND 6 11 OUTD OUTD 6 11 IND EN1 7 10 EN2 NC 7 GND1 8 10 EN2 NSI8140 9 GND2 Figure 6.5 NSi8140W Package GND1 8 NSI8141 9 GND2 Figure 6.6 NSi8141W Package Novosense Confidential Page 17 NSi8140/NSi8141/NSi8142 VDD1 1 16 VDD2 GND1 2 15 GND2 INA 3 14 OUTA INB 4 13 OUTB OUTC 5 12 INC OUTD 6 11 IND EN1 7 10 EN2 GND1 8 NSI8142 9 GND2 Figure 6.7 NSi8142W Package Figure 6.8 WB SOIC16 Package Shape and Dimension in millimeters and (inches) Table 6.2 NSi8140W/ NSi8141W/ NSi8142W Pin Configuration and Description NSi8140W PIN NO. NSi8141W PIN NO. NSi8142W PIN NO. SYMBOL FUNCTION 1 1 1 VDD1 Power Supply for Isolator Side 1 2 2 2 GND1 Ground 1, the ground reference for Isolator Side 1 3 3 3 INA Logic Input A 4 4 4 INB Logic Input B 5 5 12 INC Logic Input C 6 11 11 IND Logic Input D 7 7 7 NC/ EN1 No Connection. or Novosense Confidential Page 18 NSi8140/NSi8141/NSi8142 Output Enable 1. Active high logic input. When EN1 is high or NC, the output of Side 1 are enabled. When EN1 is low, the output of Side 1 are disabled to high impedance state. 8 8 8 GND1 Ground 1, the ground reference for Isolator Side 1 9 9 9 GND2 Ground 2, the ground reference for Isolator Side 2 10 10 10 EN2 Output Enable 2. Active high logic input. When EN2 is high or NC, the output of Side 2 are enabled. When EN2 is low, the output of Side 2 are disabled to high impedance state. 11 6 6 OUTD Logic Output D 12 12 5 OUTC Logic Output C 13 13 13 OUTB Logic Output B 14 14 14 OUTA Logic Output A 15 15 15 GND2 Ground 2, the ground reference for Isolator Side 2 16 16 16 VDD2 Power Supply for Isolator Side 2 7.0 ORDER INFORMATION Part No. Isolation Rating(kV) Number Number Max Data Default Temperature Automotive Package of side 1 of side 2 Rate Output inputs inputs (Mbps) State NSi8140N0 3.75 4 0 150 Low NO NB SOIC16 -40 to 125℃ NSi8140N1 3.75 4 0 150 High NO NB SOIC16 -40 to 125℃ NSi8141N0 3.75 3 1 150 Low NO NB SOIC16 -40 to 125℃ NSi8141N1 3.75 3 1 150 High NO NB SOIC16 -40 to 125℃ NSi8142N0 3.75 2 2 150 Low NO NB SOIC16 -40 to 125℃ NSi8142N1 3.75 2 2 150 High NO NB SOIC16 -40 to 125℃ NSi8140W0 5 4 0 150 Low NO WB SOIC16 -40 to 125℃ NSi8140W1 5 4 0 150 High NO WB SOIC16 -40 to 125℃ NSi8141W0 5 3 1 150 Low NO WB SOIC16 -40 to 125℃ NSi8141W1 5 3 1 150 High NO WB SOIC16 -40 to 125℃ NSi8142W0 5 2 2 150 Low NO WB SOIC16 -40 to 125℃ NSi8142W1 5 2 2 150 High NO WB SOIC16 -40 to 125℃ NSi8140W0Q 5 4 0 150 Low YES WB SOIC16 -40 to 125℃ NSi8140W1Q 5 4 0 150 High YES WB SOIC16 -40 to 125℃ NSi8141W0Q 5 3 1 150 Low YES WB SOIC16 -40 to 125℃ NSi8141W1Q 5 3 1 150 High YES WB SOIC16 -40 to 125℃ NSi8142W0Q 5 2 2 150 Low YES WB SOIC16 -40 to 125℃ NSi8142W1Q 5 2 2 150 High YES WB SOIC16 -40 to 125℃ NOTE: All packages are RoHS-compliant with peak reflow temperatures of 260 °C according to the JEDEC industry standard classifications and peak solder temperatures. All devices are AEC-Q100 qualified. Part Number Rule: Novosense Confidential Page 19 NSi8140/NSi8141/NSi8142 NSi(81)(4)(1)(N)(1)(Q) Series Number Total Channel Amount: N=N Channels N=1,2,4… N=0: I2C Part Reverse Channel Amount: N=N Channels N=0,1,2… Q = Automotive version Fail-Safe Output State: 0 = Logic Low 1 = Logic High Package Type: N= NB SOIC16 W= WB SOIC16 8.0 REVISION HISTORY Revision 1.0 1.1 1.2 Description Add maximum operation current spec. Change to ordering information Novosense Confidential Page 20 Date 2017/11/15 2018/10/12 2018/12/20
NSI8141W1 价格&库存
很抱歉,暂时无法提供与“NSI8141W1”相匹配的价格&库存,您可以联系我们找货
NSI8141W1
  • 1+13.80240
  • 10+11.50200
  • 30+10.06560
  • 100+8.58600
  • 500+7.92720
  • 1000+7.63560
库存:685
NSI8141W1
  • 1+12.52440
  • 10+10.43700
  • 30+9.13360
库存:62
NSI8141W1
  • 1+13.39600
  • 10+12.27960
  • 30+11.16330
库存:62
NSI8141W1
  • 1+5.55500
  • 100+4.45500
  • 1000+4.26800
库存:868
