NCA9545
4-channel I2C-bus switch with
interrupt logic and reset
Datasheet (EN) 1.1
Product Overview
Allows Voltage-Level Translation Between 1.8-V, 2.5-V, 3.3V, and 5-V Buses
The NCA9545 is a quad bidirectional translating switch
controlled via the I2C bus. The SCL/SDA upstream pair fans
out to four downstream pairs, or channels. Any individual
SCn/SDn channel or combination of channels can be
selected, determined by the contents of the
programmable control register. Four interrupt inputs
(INT3–INT0), one for each of the downstream pairs, are
provided. One interrupt (INT) output acts as an AND of the
four interrupt inputs.
No Glitch on Power-Up
An active-low reset (RESET) input allows the NCA9545 to
recover from a situation in which one of the downstream
I2C buses is stuck in a low state. Pulling RESET low resets
the I2C state machine and causes all the channels to be
deselected, as does the internal power-on reset function.
ESD Protection Exceeds JESD 22
The pass gates of the switches are constructed such that
the VCC terminal can be used to limit the maximum high
voltage, which will be passed by the NCA9545. This allows
the use of different bus voltages on each pair, so that 1.8V, 2.5-V, or 3.3-V parts can communicate with 5-V parts,
without any additional protection. External pull-up
resistors pull the bus up to the desired voltage level for
each channel. All I/O terminals are 5.5 V tolerant.
Key Features
1-of-4 Bidirectional Translating Switches
Supports Hot Insertion
Low Standby Current
Operating Power-Supply Voltage Range of 2.3 V to 5.5 V
5.5 V Tolerant Inputs
0 to 400-kHz Clock Frequency
Latch-Up Performance Exceeds 100 mA per JESD 78
– 2000-V Human-Body Model (A114-A)
– 1000-V Charged-Device Model (C101)
Applications
Servers
Routers (Telecom Switching Equipment)
Factory Automation
Products With I2C Slave Address Conflicts (e.g. Multiple,
Identical Temp Sensors)
Device Information
Part Number
NCA9545_DTSR
Package
TSSOP20
Body Size
6.5mm*4.5mm
I2C Bus and SMBus Compatible
Four Active-Low Interrupt Inputs
Active-Low Interrupt Output
Active-Low Reset Input
Two Address Terminals, Allowing up to Four Devices on the
I2C Bus
Channel Selection via I2C Bus, in Any Combination
Power-Up With All Switch Channels Deselected
Low RON Switches
Functional Block Diagrams
A0 1
20 VCC
A1 2
19 SDA
3
18 SCL
INT0 4
17 INT
RESET
SD0 5
NCA9545
16 SC3
SC0 6
15 SD3
INT1 7
14 INT3
SD1 8
13 SC2
SC1 9
12 SD2
GND 10
11 INT2
Figure 1. NCA9545 Block Diagram
NCA9545
Datasheet (EN) 1.1
Index
1. PIN CONFIGURATION AND FUNCTIONS ............................................................................................................................... 3
2. ABSOLUTE MAXIMUM RATINGS .......................................................................................................................................... 4
3. RECOMMENDED OPERATING CONDITIONS ......................................................................................................................... 4
4. THERMAL INFORMATION .................................................................................................................................................... 4
5. SPECIFICATIONS................................................................................................................................................................... 5
5.1.
5.2.
5.3.
ELECTRICAL CHARACTERISTICS .......................................................................................................................................... 5
DYNAMIC CHARACTERISTICS ............................................................................................................................................ 6
PARAMETER MEASUREMENT INFORMATION ........................................................................................................................ 7
6. DETAILED DESCRIPTION ....................................................................................................................................................... 9
6.1.
6.2.
6.3.
6.4.
6.5.
6.6.
6.7.
6.8.
6.9.
6.10.
6.11.
6.12.
6.13.
OVERVIEW ................................................................................................................................................................... 9
FUNCTIONAL BLOCK DIAGRAM ......................................................................................................................................... 9
FEATURE DESCRIPTION.................................................................................................................................................. 10
DEVICE FUNCTIONAL MODES ......................................................................................................................................... 10
RESET INPUT ............................................................................................................................................................. 10
POWER-ON RESET ....................................................................................................................................................... 10
PROGRAMMING .......................................................................................................................................................... 10
I2C INTERFACE ............................................................................................................................................................ 10
CONTROL REGISTER ..................................................................................................................................................... 12
DEVICE ADDRESS ..................................................................................................................................................... 12
CONTROL REGISTER DESCRIPTION ................................................................................................................................ 12
CONTROL REGISTER DEFINITION .................................................................................................................................. 12
INTERRUPT HANDLING .............................................................................................................................................. 13
7. APPLICATION AND IMPLEMENTATION ............................................................................................................................... 13
7.1.
7.2.
7.3.
7.4.
TYPICAL APPLICATION................................................................................................................................................... 13
DESIGN REQUIREMENTS ................................................................................................................................................ 14
DETAILED DESIGN PROCEDURE ....................................................................................................................................... 14
NCA9545 APPLICATION CURVES .................................................................................................................................... 15
8. LAYOUT ............................................................................................................................................................................. 15
8.1.
LAYOUT GUIDELINES..................................................................................................................................................... 15
9. PACKAGE INFORMATION ................................................................................................................................................... 16
10. ORDER INFORMATION ..................................................................................................................................................... 16
11. DOCUMENTATION SUPPORT ........................................................................................................................................... 16
12. TAPE AND REEL INFORMATION ........................................................................................................................................ 17
13. REVISION HISTORY .......................................................................................................................................................... 18
Copyright © 2019, NOVOSENSE
Page 2
NCA9545
Datasheet (EN) 1.1
1. Pin Configuration and Functions
A0 1
20 VCC
A1 2
19 SDA
3
18 SCL
INT0 4
17 INT
RESET
SD0 5
NCA9545
16 SC3
SC0 6
15 SD3
INT1 7
14 INT3
SD1 8
13 SC2
SC1 9
12 SD2
GND 10
11 INT2
Figure 1.1 NCA9545 Package
Table 1.1 Pin Configuration and Description
Symbol
Pin
Description
A0
1
Address input 0. Connect directly to VCC or ground.
A1
2
Address input 1. Connect directly to VCC or ground.
RESET
3
Active-low reset input. Connect to VCC or VDPUM1 through a pull-up resistor if not used.
INT0
4
Active-low interrupt input 0. Connect to VDPU01 through a pull-up resistor.
SD0
5
Serial data 0. Connect to VDPU01 through a pul-up resistor.
SC0
6
Serial clock 0. Connect to VDPU01 through a pull-up resistor.
INT1
7
Active-low interrupt input 1. Connect to VDPU11 through a pull-up resistor.
SD1
8
Serial data 1. Connect to VDPU11 through a pull-up resistor.
SC1
9
Serial clock 1. Connect to VDPU11 through a pull-up resistor.
GND
10
Ground
INT2
11
Active-low interrupt input 2. Connect to VDPU21 through a pull-up resistor.
SD2
12
Serial data 2. Connect to VDPU21 through a pull-up resistor.
SC2
13
Serial clock 2. Connect to VDPU21 through a pull-up resistor.
INT3
14
Active-low interrupt input 3. Connect to VDPU31 through a pull-up resistor.
SD3
15
Serial data 3. Connect to VDPU31 through a pull-up resistor.
SC3
16
Serial clock 3. Connect to VDPU31 through a pull-up resistor.
INT
17
Active-low interrupt output. Connect to VDPUM1 through a pull-up resistor.
SCL
18
Serial clock line. Connect to VDPUM1 through a pull-up resistor.
SDA
19
Serial data line. Connect to VDPUM1 through a pull-up resistor.
VCC
Supply power
VDPUX is the pull-up reference voltage for the associated data line. VDPUM is the master I2C master reference voltage and VDPU0–VDPU3 are
the slave channel reference voltages.
1
Page 3
NCA9545
Datasheet (EN) 1.1
2. Absolute Maximum Ratings
Parameters
Symbol
Min
Max
VCC
-0.5
7
V
VI/VO
-0.5
7
V
Supply Voltage
Input/output Voltage
Unit
Input current
II
±25
mA
Output current
IO
±25
mA
Continuous current through VCC or GND
ICC
±100
mA
Operating Temperature
Topr
-40
85
Storage Temperature
Tstg
-40
150
HBM
±2000
V
CDM
±1000
V
Conditions
VO
很抱歉,暂时无法提供与“NCA9545-DTSR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.14960
- 10+5.64840
- 30+4.90320
- 100+4.15800
- 500+3.71520
- 1000+3.47760
- 国内价格
- 1+6.48760
- 10+5.12540
- 30+4.44920
- 100+3.77300
