Version: 1.2
Document code:SL1210 Low R
Effective date :2015-09-02
Page: 1 of 5
Surface-Mount Device
Feature
SL1210
ROHS
Resettable over current and over temperature protection
Low resistance
Small size of 1210
Fast time-to-trip
Small footprint
ROHS complaint
Application
Part Numbering
Product Dimensions in Millimeter
Part Number
A
B
C
D
E
Max
Min
Min
0.4
-0.4
1.0
0.25
0.10
1.0
0.25
0.10
0.4
-0.4
1.0
0.25
0.10
1.0
0.25
0.10
Min
Max
Min
Max
SL1210150
3.00
3.50
2.35
2.85
SL1210175
3.50 --
2.35
-2.35
2.85
SL1210190
3.00
SL1210200
-3.00
3.50 --
2.85
SL1210210
3.50
0.25
0.10
2.85
1.2
0.25
0.10
SL1210250
-3.00
3.50
2.35
-2.35
0.4
-0.5
1.0
SL1210230
3.00
2.35
-2.35
2.85
0.5
1.2
0.25
0.10
2.35
-2.35
2.85
0.5
1.2
0.25
0.10
SL1210300
3.00
3.50 --
2.85
0.5
1.2
0.25
0.10
SL1210350
-3.00
3.50 --
2.85
0.5
1.2
0.25
0.10
SL1210380
3.50
2.85
0.5
1.2
0.25
0.10
SL1210400
3.00
2.35
-2.35
0.5
1.2
0.25
0.10
SL1210450
3.50
2.35
-2.35
2.85
-3.00
2.85
0.5
1.2
0.25
0.10
SL1210500
3.50 --
2.35
-2.35
2.85
0.6
-0.6
1.5
0.25
0.10
SL1210550
3.00
1.5
0.25
0.10
SL1210600
-3.00
3.50 --
1.5
0.25
0.10
SL1210650
3.00
-0.6
0.6-
SL1210260
Polymer PTC Thermistor
3.50
3.50 --
3.50
3.50 --
3.50
2.35
-2.35
2.85
2.85
2.85
2.85
Min
2.85
1.5
0.25
-Specifications are subject to change without notice
0.10
www.sealand-pptc.com
Version: 1.2
Document code:HB-WI7.3-162-2013
Effective date :2015-02-07
Page: 2 of 5
SL1210
ROHS
Electrical Characteristics
Part Number
I(A)
Vmax
I max
Pdtyp
25℃
Ttrip
Rmin
25℃
Rmax
R1max
25℃
Hold
Trip
(V)
(A)
(W)
Curren
t(A)
SL1210150
1.50
3.0
6.0
50
1.2
8.0
0.5
0.005
0.012
0.050
SL1210175
1.75
3.5
6.0
50
1.2
8.0
1.0
0.005
0.012
0.040
SL1210190
1.90
3.8
6.0
50
1.2
8.0
3.0
0.005
0.011
0.035
SL1210200
2.00
4.0
6.0
50
1.2
8.0
3.0
0.005
0.011
0.032
SL1210210
2.10
4.2
6.0
50
1.2
8.0
5.0
0.005
0.010
0.030
SL1210230
2.30
4.6
6.0
50
1.2
8.0
5.0
0.005
0.010
0.028
SL1210250
2.50
5.0
6.0
50
1.2
8.0
5.0
0.004
0.009
0.025
SL1210260
2.60
5.2
6.0
50
1.2
12.0
5.0
0.004
0.009
0.020
SL1210300
3.00
6.0
6.0
50
1.2
12.0
5.0
0.004
0.008
0.018
SL1210350
3.50
7.0
6.0
50
1.2
12.0
5.0
0.003
0.008
0.017
SL1210380
3.80
7.6
6.0
50
1.5
12.0
5.0
0.003
0.007
0.016
SL1210400
4.00
8.0
6.0
50
1.5
16.0
5.0
0.002
0.007
0.015
SL1210450
4.50
9.0
6.0
50
1.5
16.0
5.0
0.001
0.006
0.014
SL1210500
5.00
10.0
6.0
50
1.5
16.0
5.0
0.001
0.006
0.012
SL1210550
5.50
11.0
6.0
50
1.5
20.0
5.0
0.0008
0.005
0.010
SL1210600
6.00
12.0
6.0
50
1.5
20.0
5.0
0.0008
0.005
0.009
SL1210650
6.50
13.0
6.0
50
1.5
20.0
5.0
0.0005
0.004
0.008
Time(S)
(Ω)
(Ω)
(Ω)
IH=Hold current: maximum current at which the device will not trip at 25℃ still air reflow soldering of 260℃ for 20 sec.
IT=Trip current: minimum current at which the device will always trip at 25℃ still air reflow soldering of 260℃ for 20 sec.
Vmax=Maximum continuous voltage device can withstand without damage at ratedcurrent
Imax=Maximum fault current device can withstand without damage at rated voltage.
Ttrip=Maximum time to trip(s) at assigned current reflow soldering of 260℃ for 20 sec.
Pdtyp=Typical power dissipation: typical amount of power dissipated by the device when in state air environment.
Rmin= Minimum resistance of device in initial (un-soldered) state.
Rmax= Maximum resistance of device in initial (un-soldered) state.
R1max=Maximum resistance of device at 25℃ measured one hour after reflow soldering of 260℃ for 20 sec.
Value specified is determined by using the PWB with 0.030"*1.5oz coppertraces.
Caution: Operation beyond the specified rating may result in damage and possible arcing andflame.
Environmental Specifications
Test
Test Conditions
Resistance Change/ Criteria
Recommended storage conditions
40°C max, 70% R.H. max
± 5%
Passive aging:
85°C, 1000 hours
≤ R1max
Moisture Resistance
85% RH,85℃,1000hrs
≤ R1max
Thermal Shock
Vibration
MIL-STD-202 Method 107G
+85ºC /-40ºC 20 times
MIL-STD-883C, Method 2007.1,
Condition A
≤ R1max
± 5%
Solvent Resistance
MIL-STD-202, Method 215
Appearance No change
Moisture Level Sensitivity
J-STD-020C
Level 2a
Version: 1.2
Page: 3 of 5
SL1210
ROHS
Thermal Derating [ Hold Current (A) at Ambient Temperature (℃)]
Part Number
Maximum Ambient Operating Temperature (℃)
-40
-20
40
50
60
70
SL1210150
2.3
2.0
1.7
1.5
1.3
1.2
1.1
0.9
SL1210175
2.6
2.3
2.0
1.75
1.5
1.3
1.2
1.1
SL1210190
2.9
2.5
2.2
1.9
1.6
1.5
1.3
1.2
SL1210200
3.0
2.7
2.3
2.0
1.7
1.5
1.4
1.2
SL1210210
3.2
2.8
2.4
2.1
1.8
1.6
1.5
1.3
SL1210230
3.5
3.1
2.7
2.3
2.0
1.8
1.6
1.4
SL1210250
3.8
3.3
2.9
2.5
2.2
1.9
1.8
1.5
SL1210260
3.9
3.5
3.0
2.6
2.2
2.0
1.9
1.6
SL1210300
4.5
4.0
3.5
3.0
2.6
2.3
2.1
1.8
SL1210350
5.3
4.7
4.1
3.5
3.0
2.7
2.5
2.1
SL1210380
5.7
5.1
4.4
3.8
3.3
2.9
2.7
2.3
SL1210400
6.0
5.3
4.6
4.0
3.4
3.1
2.8
2.4
SL1210450
6.8
6.0
5.2
4.5
3.9
3.5
3.2
2.7
SL1210500
7.5
6.7
5.8
5.0
4.3
3.9
3.5
3.1
SL1210550
8.3
7.3
6.4
5.5
4.7
4.2
3.9
3.4
SL1210600
9.0
8.0
7.0
6.0
5.2
4.6
4.2
3.7
SL1210650
9.8
8.6
7.5
6.5
5.6
5.0
4.6
4.0
Solder Reflow Recommendation
Version: 1.2
Page: 4 of 5
SL1210
ROHS
Recommended reflow methods:IR,hot air oven ,nitrogen oven
Devices can be cleaned using standard industry methods and solvents.
NOTE:
If reflow temperatures exceed the recommended profile,devices may not meet the performance requirements.
Caution: Operation beyond the rated voltage or current may result in rupture electrical arcing or flame
Packaging Quantity and Marking
Device
Standard Quantity (pcs)
SL1210150
4000
SL1210175
4000
SL1210190
4000
SL1210200
4000
SL1210210
4000
SL1210230
4000
SL1210250
4000
SL1210260
4000
SL1210300
4000
Version: 1.2
Page: 5 of 5
SMD1210
ROHS
SL1210350
4000
SL1210380
4000
SL1210400
4000
SL1210450
4000
SL1210500
4000
SL1210550
4000
SL1210600
4000
SL1210650
4000
Operation beyond the maximum ratings or improper use may result in device damage and possible electrical arcing and
flame. The devices are intended for protection against occasional over-current or over temperature fault conditions and
should not be used when repeated fault conditions or prolonged trip events are anticipated. Device performance can be
impacted negatively if devices are handled in a manner inconsistent with recommended electronic, thermal, and mechanical
procedures for electronic components.
Contact information
SEA & LAND ELECTRONIC CORP.
13F., No.120-10, Sec. 3, Zhongshan Rd., Zhonghe Dist.,
New Taipei City 235, Taiwan
Rev. letter
Design
Date
Check
Audit
Approve
Tel:886-2-82212567 Fax:886-2-22257268
很抱歉,暂时无法提供与“SL1210450”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.71885
- 50+0.56279
- 150+0.48471
- 国内价格
- 1+0.46401
- 30+0.44801
- 100+0.41601
- 500+0.38401
- 1000+0.36801
