Version: 1.2
Document code:SL1206 Low R
Effective date :2015-09-02
Page: 1 of 4
Surface-Mount Device
SL1206
ROHS
Feature
Resettable over current and over temperature protection
Low resistance
Small size of 1206
Fast time-to-trip
Small footprint
ROHS complaint
Application
Part Numbering
Product Dimensions in Millimeter
Part Number
A
B
C
D
E
Max
Min
Min
0.4
-0.4
1.0
0.25
0.10
1.0
0.25
0.10
0.5
-0.5
1.2
0.25
0.10
1.2
0.25
0.10
1.2
0.25
0.10
Min
Max
Min
Max
SL1206110
3.00
3.50
1.50
1.85
SL1206125
3.00
3.50
1.50
-1.50
1.85
SL1206150
SL1206175
-3.00
3.50
1.85
SL1206200
3.50
SL1206230
3.00
-1.50
-1.50
1.85
0.5
-0.5
1.2
0.25
0.10
SL1206260
-3.00
3.50
-1.50
-1.50
1.85
0.6
1.3
0.25
0.10
SL1206300
3.50
-1.50
-1.50
1.85
0.6
1.3
0.25
0.10
SL1206350
3.00
1.85
0.6
1.3
0.25
0.10
SL1206380
-3.00
3.50
1.85
0.6
1.5
0.25
0.10
SL1206400
3.00
3.50
-1.50
-1.50
1.85
0.6
1.5
0.25
0.10
SL1206450
-Polymer PTC Thermistor
3.50
3.50
3.50
1.85
1.85
Min
-1.50
0.6
3.50
1.85
1.5
0.25
-Specifications are subject to change without notice
0.10
www.sealand-pptc.com
Version: 1.2
Page: 2 of 4
SL1206
ROHS
Electrical Characteristics
Part Number
I(A)
Vmax
I max
Pdtyp
25℃
Ttrip
Rmin
Rmax
R1max
25℃
Time(S)
(Ω)
25℃
(Ω)
(Ω)
Hold
Trip
(V)
(A)
(W)
Current(A)
SL1206110
1.10
2.2
6.0
50
1.2
8.0
0.5
0.009
0.015
0.065
SL1206125
1.25
2.5
6.0
50
1.2
8.0
1.0
0.009
0.015
0.060
SL1206150
1.50
3.0
6.0
50
1.2
8.0
5.0
0.006
0.012
0.055
SL1206175
1.75
3.5
6.0
50
1.2
8.0
5.0
0.006
0.012
0.050
SL1206200
2.00
4.0
6.0
50
1.2
8.0
5.0
0.005
0.011
0.045
SL1206230
2.30
4.6
6.0
50
1.2
8.0
5.0
0.005
0.010
0.040
SL1206260
2.60
5.2
6.0
50
1.2
12.0
5.0
0.004
0.009
0.035
SL1206300
3.00
6.0
6.0
50
1.2
12.0
5.0
0.004
0.008
0.030
SL1206350
3.50
7.0
6.0
50
1.2
12.0
5.0
0.002
0.008
0.025
SL1206380
3.80
7.6
6.0
50
1.2
12.0
5.0
0.002
0.007
0.020
SL1206400
4.00
8.0
6.0
50
1.5
16.0
5.0
0.001
0.007
0.018
SL1206450
4.50
9.0
6.0
50
1.5
16.0
5.0
0.001
0.006
0.015
IH=Hold current: maximum current at which the device will not trip at 25℃ or 60℃ still air reflow soldering of 260℃ for 20
sec.
IT=Trip current: minimum current at which the device will always trip at 25℃
still air reflow soldering of 260℃ for 20 sec.
Vmax=Maximum continuous voltage device can withstand without damage at rated current
Imax=Maximum fault current device can withstand without damage at rated voltage.
Ttrip=Maximum time to trip(s) at assigned current reflow soldering of 260℃ for 20 sec.
Pdtyp=Typical power dissipation: typical amount of power dissipated by the device when in state air environment.
Rmin= Minimum resistance of device in initial (un-soldered) state.
Rmax= Maximum resistance of device in initial (un-soldered) state.
R1max=Maximum resistance of device at 25℃ measured one hour after reflow soldering of 260℃ for 20 sec.
Value specified is determined by using the PWB with 0.030 *1.5oz coppertraces.
Caution: Operation beyond the specified rating may result in damage and possible arcing and flame.
Environmental Specifications
Test
Test Conditions
Resistance Change/ Criteria
Recommended storage conditions
40°C max, 70% R.H. max
± 5%
Passive aging:
85°C, 1000 hours
≤ R1max
Moisture Resistance
85% RH,85℃,1000hrs
≤ R1max
Thermal Shock
Vibration
MIL-STD-202 Method 107G
+85ºC /-40ºC 20 times
MIL-STD-883C, Method 2007.1,
Condition A
≤ R1max
± 5%
Solvent Resistance
MIL-STD-202, Method 215
Appearance No change
Moisture Level Sensitivity
J-STD-020C
Level 2a
Thermal Derating [ Hold Current (A) at Ambient Temperature (℃)]
Version: 1.2
Document code:HB-WI7.3-163-2013
Effective date :2015-02-07
Page: 3 of 4
Part Number
SL1206110
SL1206125
SL1206150
SL1206175
SL1206200
SL1206230
SL1206260
SL1206300
SL1206350
SL1206380
SL1206400
SL1206450
SL1206
ROHS
Maximum Ambient Operating Temperature (℃)
-40
-20
40
50
60
70
1.5
1.7
2.0
2.3
2.7
3.1
3.5
4.0
4.7
5.1
5.4
6.0
1.3
1.5
1.8
2.0
2.3
2.7
3.0
3.5
4.1
4.4
4.7
5.3
1.2
1.4
1.6
1.9
2.2
2.5
2.8
3.2
3.8
4.1
4.3
4.9
1.1
1.25
1.5
1.75
2.0
2.3
2.6
3.0
3.5
3.8
4.0
4.5
0.9
1.1
1.2
1.4
1.6
1.9
2.1
2.5
2.9
3.1
3.3
3.7
0.8
1.0
1.1
1.3
1.5
1.7
1.9
2.2
2.6
2.8
3.0
3.3
0.7
0.9
1.0
1.2
1.4
1.6
1.8
2.0
2.4
2.6
2.7
3.1
0.6
0.7
0.9
1.0
1.1
1.3
1.5
1.7
2.0
2.2
2.3
2.6
Solder Reflow Recommendation
Recommended reflow methods:IR,hot air oven ,nitrogen oven
Devices can be cleaned using standard industry methods and solvents.
NOTE:
If reflow temperatures exceed the recommended profile,devices may not meet the performance requirements.
Caution: Operation beyond the rated voltage or current may result in rupture electrical arcing or flame
Packaging Quantity and Marking
Version: 1.2
Page: 4 of 4
SL1206
Device
ROHS
Standard Quantity (pcs)
SL1206110
4000
SL1206125
4000
SL1206150
4000
SL1206175
4000
SL1206200
4000
SL1206230
4000
SL1206260
4000
SL1206300
4000
SL1206350
4000
SL1206380
4000
SL1206400
4000
SL1206450
4000
Operation beyond the maximum ratings or improper use may result in device damage and possible electrical arcing and
flame. The devices are intended for protection against occasional over-current or over temperature fault conditions and
should not be used when repeated fault conditions or prolonged trip events are anticipated. Device performance can be
impacted negatively if devices are handled in a manner inconsistent with recommended electronic, thermal, and mechanical
procedures for electronic components.
Contact information
SEA & LAND ELECTRONIC CORP.
13F., No.120-10, Sec. 3, Zhongshan Rd., Zhonghe
Dist., New Taipei City 235, Taiwan
Rev. letter
Design
Date
Check
Audit
Approve
Tel:886-2-82212567 Fax:886-2-22257268
很抱歉,暂时无法提供与“SL1206125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.71896
- 50+0.57381
- 150+0.50123
