RR0816Q-59R0-D-75R
RR0816Q-59R0-D-75R
    SUSUMU
    薄膜电阻 59Ω ±0.5% 62.5MW
RR0816Q-59R0-D-75R 数据手册
Metal thin film chip resistors (precision) ■RR series Features ・ Precision chip resistors excellent in resistance tolerance, TCR, frequency RR series Thin film surface mount resistors performance, noise characteristics, and linearity. Applications ・ Consumer electronics that requires precision resistors ・ All purpose resistors in any area of electronics ◆Part numbering system RR 0816 P - 102 - D -(M)-(***) Series code only given to 3 digit coders for RR0816 E-96 series Size: RR0306, RR0510, RR0816, RR1220, Temperature coefficient of resistance Letter M is added for RR1220 E-96 series 4digit codes Nominal RR0306, RR0510, RR0816, RR1220 E-24: 3 digit, Resistance RR0306, RR0510, RR0816, RR1220 E-96: 4 digit, Resistance tolerance ◆Electrical Specification Type Power ratings RR0306 1/20W RR0510 1/16W RR0816 RR1220 Temperature coefficient of resistance Resistance range(Ω) Resistance tolerance (ppm/°C) ±0.1% (B) ±0.5% (D) ー ±100(R) ±25(P) ー 100≦R≦100k ー 10,000pcs 25V -55℃ ~ 125℃ 100≦R≦360k ±25(P) ー 75V ー E-24, E-96 10≦R
RR0816Q-59R0-D-75R
1. 物料型号:文档中列出了几种型号,包括RR0306、RR0510、RR0816和RR1220。
2. 器件简介:这些是金属薄膜芯片电阻器,具有优异的电阻公差、温度系数、频率性能、噪声特性和线性度。
3. 引脚分配:文档没有明确提供引脚分配信息,但通常这类电阻器是无引脚的表面贴装元件。
4. 参数特性: - 电阻公差:B级±0.1%,D级±0.5%,F级±1%。 - 温度系数:±25ppm/°C(P级),±100ppm/°C(R级),±50ppm/°C(Q级)。
5. 功能详解:适用于需要精密电阻的电子产品,以及电子领域的通用电阻器。
6. 应用信息:适用于消费电子产品和任何领域的通用电阻器。
7. 封装信息:提供了不同型号的尺寸和尺寸公差,单位为毫米,例如RR0306型号尺寸为0.60±0.05(长)x 0.30±0.05(宽)。
8. 电气规格:包括功率等级、最大电压、电阻值系列、工作温度范围和包装数量。
9. 尺寸信息:提供了详细的尺寸数据,包括长度、宽度、a、b尺寸以及公差。
RR0816Q-59R0-D-75R 价格&库存
很抱歉,暂时无法提供与“RR0816Q-59R0-D-75R”相匹配的价格&库存,您可以联系我们找货
RR0816Q-59R0-D-75R
    RR0816Q-59R0-D-75R
      RR0816Q-59R0-D-75R
      • 5000+0.154185000+0.01998
      • 10000+0.1469310000+0.01904
      • 15000+0.1430515000+0.01853
      • 25000+0.1385325000+0.01795
      • 35000+0.1357635000+0.01759
      • 50000+0.1330150000+0.01723
      库存:4500
      RR0816Q-59R0-D-75R
      • 1+0.884741+0.11461
      • 10+0.2291810+0.02969
      • 25+0.2149025+0.02784
      • 50+0.2044550+0.02649
      • 100+0.19390100+0.02512
      • 250+0.17947250+0.02325
      • 500+0.16960500+0.02197
      • 1000+0.160341000+0.02077
      库存:4500
