PUMX1,115
PUMX1,115
    NEXPERIA(安世)
    SOT-363
    TRANS 2NPN 40V 0.1A 6TSSOP
PUMX1,115 数据手册
PUMX1 40 V, 100 mA NPN/NPN general-purpose transistor Rev. 04 — 20 January 2010 Product data sheet 1. Product profile 1.1 General description NPN/NPN general-purpose transistor with two independently operating transistors in a SOT363 (SC-88) very small Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number Package PUMX1 Nexperia JEITA PNP/PNP complement NPN/PNP complement SOT363 SC-88 PUMT1 PUMZ1 Simplified outline Graphic symbol 1.2 Features „ Double general-purpose transistor „ Board-space reduction „ Very small SMD plastic package 1.3 Applications „ General-purpose switching and amplification 2. Pinning information Table 2. Pinning Pin Description 1 emitter TR1 2 base TR1 3 collector TR2 4 emitter TR2 5 base TR2 6 collector TR1 6 5 4 6 5 4 TR2 TR1 1 2 3 1 2 sym020 3 PUMX1 Nexperia 40 V, 100 mA NPN general-purpose double transistor 3. Ordering information Table 3. Ordering information Type number PUMX1 Package Name Description Version SC-88 plastic surface-mounted package; 6 leads SOT363 4. Marking Table 4. Marking codes Type number Marking code[1] PUMX1 Z*Z [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per transistor VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 40 V open collector VEBO emitter-base voltage - 5 V IC collector current - 100 mA ICM peak collector current - 200 mA IBM peak base current - 200 mA Ptot total power dissipation Tamb ≤ 25 °C - 200 mW Ptot total power dissipation Tamb ≤ 25 °C - 300 mW Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C Per device [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. © PUMX1_4 Product data sheet [1] Rev. 04 — 20 January 2010 Nexperia B.V. 2017. All rights reserved 2 of 8 PUMX1 Nexperia 40 V, 100 mA NPN general-purpose double transistor 6. Thermal characteristics Table 6. Symbol Thermal characteristics Parameter Conditions Min Typ Max Unit - - 416 K/W Per device Rth(j-a) [1] thermal resistance from junction in free air to ambient [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VCB = 30 V; IE = 0 A - - 100 nA VCB = 30 V; IE = 0 A; Tj = 150 °C - - 10 μA nA Per transistor ICBO collector-base cut-off current IEBO emitter-base cut-off current VEB = 4 V; IC = 0 A - - 100 hFE DC current gain VCE = 6 V; IC = 1 mA 120 - - VCEsat collector-emitter saturation voltage IC = 50 mA; IB = 5 mA - - 200 mV fT transition frequency IC = 2 mA; VCE = 12 V; f = 100 MHz 100 - - MHz Cc collector capacitance VCB = 12 V; IE = ie = 0 A; f = 1 MHz - - 1.5 pF [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. © PUMX1_4 Product data sheet [1] Rev. 04 — 20 January 2010 Nexperia B.V. 2017. All rights reserved 3 of 8 PUMX1 Nexperia 40 V, 100 mA NPN general-purpose double transistor 8. Package outline 2.2 1.8 6 2.2 1.35 2.0 1.15 1.1 0.8 5 4 2 3 0.45 0.15 pin 1 index 1 0.3 0.2 0.65 0.25 0.10 1.3 Dimensions in mm Fig 1. 06-03-16 Package outline PUMX1 (SOT363/SC-88) 9. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PUMX1 [1] Package SOT363 Description 3000 10000 4 mm pitch, 8 mm tape and reel; T1 [2] -115 -135 4 mm pitch, 8 mm tape and reel; T2 [3] -125 -165 For further information and the availability of packing methods, see Section 12. [2] T1: normal taping [3] T2: reverse taping © PUMX1_4 Product data sheet Packing quantity Rev. 04 — 20 January 2010 Nexperia B.V. 2017. All rights reserved 4 of 8 PUMX1 Nexperia 40 V, 100 mA NPN general-purpose double transistor 10. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PUMX1_4 20100120 Product data sheet - PUMX1_3 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • • • • Legal texts have been adapted to the new company name where appropriate. Table 1 “Product overview”: added Section 1.2 “Features”: updated Section 1.3 “Applications”: amended Section 2 “Pinning information”: amended Figure 1: superseded by minimized package outline drawing Section 9 “Packing information”: added Section 11 “Legal information”: updated PUMX1_3 19990414 Preliminary specification - PUMX1_2 PUMX1_2 19970709 Preliminary specification - PUMX1_1 © PUMX1_4 Product data sheet Rev. 04 — 20 January 2010 Nexperia B.V. 2017. All rights reserved 5 of 8 PUMX1 Nexperia 40 V, 100 mA NPN general-purpose double transistor 11. Legal information 11.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 11.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 11.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. © PUMX1_4 Product data sheet Rev. 04 — 20 January 2010 Nexperia B.V. 2017. All rights reserved 6 of 8 PUMX1 Nexperia 40 V, 100 mA NPN general-purpose double transistor 12. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © PUMX1_4 Product data sheet Rev. 04 — 20 January 2010 Nexperia B.V. 2017. All rights reserved 7 of 8 PUMX1 Nexperia 40 V, 100 mA NPN general-purpose double transistor 13. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 8 9 10 11 11.1 11.2 11.3 11.4 12 13 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . Contact information. . . . . . . . . . . . . . . . . . . . . . Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 January 2010 1 1 1 1 1 2 2 2 3 3 4 4 5 6 6 6 6 6 7 8
PUMX1,115 价格&库存
很抱歉,暂时无法提供与“PUMX1,115”相匹配的价格&库存,您可以联系我们找货
PUMX1,115
    • 1+0.24113
    • 100+0.22537
    • 300+0.20961
    • 500+0.19385
    • 2000+0.18597
    • 5000+0.18124
