Approval sheet
WR12, WR08, WR06, WR04
±1%, ±5%
Thick Film General Purpose Chip Resistors
Size 1206, 0805, 0603, 0402
*Contents in this sheet are subject to change without prior notice.
Page 1 of 10
ASC_WR_V23
APR.- 2015
Approval sheet
FEATURE
1. High reliability and stability
2. Reduced size of final equipment
3. Lower assembly costs
4. Higher component and equipment reliability
5. RoHS compliant and Lead free products
APPLICATION
Consumer electrical equipment
EDP, Computer application
Telecom application
DESCRIPTION
The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are
added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The
composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to
within tolerance by laser cutting of this resistive layer.
The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For
ease of soldering the outer layer of these end terminations is a Tin (lead free) alloy.
Fig 1. Construction of Chip-R
Page 2 of 10
ASC_WR_V23
APR.- 2015
Approval sheet
QUICK REFERENCE DATA
Item
General Specification
Series No.
WR12
WR08
WR06
WR04
Size code
1206(3216)
0805(2012)
0603(1608)
0402(1005)
Resistance Range
1Ω~10MΩ (±5% tolerance), Jumper
1Ω~10MΩ (±1% tolerance),
Resistance Tolerance
±1%
±5%
±1%
±5%
±1%
±5%
±1%
±5%
E96/E24
E24
E96/E24
E24
E96/E24
E24
E96/E24
E24
TCR (ppm/°C)
10MΩ ≥R>10Ω
≤ ± 100
R≤10Ω
-200~+400
Max. dissipation
@ Tamb=70°C
1/4 W
1/8 W
1/10 W
1/16 W
Max. Operation
Voltage (DC or RMS)
200V
150V
75V
50V
Max. Overload
Voltage (DC or RMS)
400V
300V
150V
100V
Climatic category
55/155/56
Note :
1.
This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication
60115-8”
2.
Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by
RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower.
3.
The resistance of Jumper is defined 1MΩ
B
Jumper
=000_
D : 7'' reel 20Kpcs
only for 0402
(“_” means a blank)
±1%, E24+E96: 3 significant
digits followed by no. of
zeros
102Ω
=1020
37.4KΩ
=3742
: 7” Reeled taping
: Bulk
A : 7" reel 15Kpcs only
for 0402
WR12, WR08, WR06:
1.
Reeled tape packaging : 8mm width paper taping 5000pcs per 7” reel, 10kpcs per 10” reel, 20kpcs per 13” reel.
2.
Bulk packaging
Page 6 of 10
: 5000pcs per poly-bag
ASC_WR_V23
APR.- 2015
Approval sheet
WR04:
1.
reel.
2.
Reeled tape packaging : 8mm width paper taping 10,000pcs per 7” reel, 20,000pcs per 10” reel. 70,000pcs per 13”
Bulk packaging
Page 7 of 10
: 10,000pcs per poly-bag
ASC_WR_V23
APR.- 2015
Approval sheet
TEST AND REQUIREMENTS
Essentially all tests are carried out according to the schedule of IEC publication 115-8, category
LCT/UCT/56(rated temperature range : Lower Category Temperature, Upper Category Temperature; damp
heat, long term, 56 days). The testing also meets the requirements specified by EIA, EIAJ and JIS.
The tests are carried out in accordance with IEC publication 68, "Recommended basic climatic and mechanical
robustness testing procedure for electronic components" and under standard atmospheric conditions according
to IEC 60068-1, subclause 5.3. Unless otherwise specified, the following value supplied :
Temperature: 15°C to 35°C.
Relative humidity: 45% to 75%.
Air pressure: 86kPa to 106 kPa (860 mbar to 1060 mbar).
All soldering tests are performed with midly activated flux.
TEST
REQUIREMENT
PROCEDURE / TEST METHOD
0Ω
Ω
Resistor
Electrical
- DC resistance values measurement
Within the specified tolerance
Characteristics
- Temperature Coefficient of Resistance (T.C.R)
Refer to “QUICK REFERENCE
Natural resistance change per change in degree centigrade.
DATA”
R2 − R1
× 106
R1 (t2 − t1 )
JISC5201-1: 1998
Clause 4.8
(ppm/°C)
t1 : 20°C+5°C-1°C; t
2
很抱歉,暂时无法提供与“WR08X3903FTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.07447
- 500+0.01870
- 2500+0.01243
- 5000+0.00919
- 国内价格
- 100+0.01159
- 500+0.01087
- 1000+0.00979
- 5000+0.00835
- 10000+0.00749
